    4. VIS 1 / HQWidgets inner Temperature Probleme im Editor
      D.Wermer @Homoran last edited by
      ich habe gerade nach der Anleitung das iob diag durchlaufen lassen.
      Es wurden mit Errors im NPM Tree angezeigt
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: rpi-iobroker
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       11:54:42 up 1 day,  1:46,  1 user,  load average: 1.02, 0.64, 0.45
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Mon 2024-01-29 11:54:43 CET
                 Universal time: Mon 2024-01-29 10:54:43 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c        spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.9G        1.0G        6.0G        0.0K        900M        6.6G
      Swap:            99M          0B         99M
      Total:          8.0G        1.0G        6.1G
               7909 M total memory
               1046 M used memory
                423 M active memory
               1420 M inactive memory
               5962 M free memory
                 85 M buffer memory
                815 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4      118G  5.9G  107G   6% /
      devtmpfs       devtmpfs  3.8G     0  3.8G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  684K  1.6G   1% /run
      /dev/sda1      vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     791M     0  791M   0% /run/user/1000
      [Sun Jan 28 10:08:40 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC        :A6:32:C4:60:1F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=t        tyS0,115200 console=tty1 root=PARTUUID=42af4171-02 rootfstype=ext4 elevator=dead        line fsck.repair=yes rootwait
      [Sun Jan 28 10:08:42 2024] EXT4-fs (sda2): mounted filesystem with ordered data        mode. Opts: (null)
      [Sun Jan 28 10:08:42 2024] VFS: Mounted root (ext4 filesystem) readonly on devic        e 8:2.
      [Sun Jan 28 10:08:43 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharse        t=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.5G    /var/
      780M    /var/cache
      775M    /var/cache/apt
      710M    /var/cache/apt/archives
      551M    /var/log
      Archived and active journals take up 544.1M in the file system.
      /opt/iobroker/backups:
      39M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      489M    /opt/iobroker/iobroker-data/
      385M    /opt/iobroker/iobroker-data/files
      89M     /opt/iobroker/iobroker-data/files/echarts.admin
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      66M     /opt/iobroker/iobroker-data/backup-objects
      25M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7        495c2.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.        js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m        ap
      USB-Devices by-id:
      USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.4.0
      /usr/bin/npx            10.4.0
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Package        s
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   0
      Adapter State
      + system.adapter.adguard.0                : adguard               : rpi-iobroker        -  enabled
      + system.adapter.admin.0                  : admin                 : rpi-iobroker        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
      + system.adapter.backitup.0               : backitup              : rpi-iobroker        -  enabled
      + system.adapter.discovery.0              : discovery             : rpi-iobroker        -  enabled
      + system.adapter.echarts.0                : echarts               : rpi-iobroker        -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : rpi-iobroker        -  enabled
      + system.adapter.fritzbox.1               : fritzbox              : rpi-iobroker        -  enabled
        system.adapter.habpanel.0               : habpanel              : rpi-iobroker        -  enabled
      + system.adapter.history.0                : history               : rpi-iobroker        -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : rpi-iobroker        -  enabled
        system.adapter.ical.0                   : ical                  : rpi-iobroker        -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: rpi        -iobroker                             -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : rpi-iobroker        -  enabled
      + system.adapter.info.0                   : info                  : rpi-iobroker        -  enabled
      + system.adapter.javascript.0             : javascript            : rpi-iobroker        -  enabled
      + system.adapter.net-tools.0              : net-tools             : rpi-iobroker        -  enabled
      + system.adapter.openknx.0                : openknx               : rpi-iobroker        -  enabled
      + system.adapter.proxmox.0                : proxmox               : rpi-iobroker        -  enabled, port: 8006
      + system.adapter.pushover.0               : pushover              : rpi-iobroker        -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : rpi-iobroker        -  enabled
        system.adapter.samsung.0                : samsung               : rpi-iobroker        - disabled
      + system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : rpi-iobroker        -  enabled, port: 9000
      + system.adapter.tr-064.0                 : tr-064                : rpi-iobroker        -  enabled
      + system.adapter.trashschedule.1          : trashschedule         : rpi-iobroker        -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : rpi-iobroker        -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : rpi-iobroker        -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : rpi-iobroker        -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : rpi-iobroker        -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : rpi-iobroker        -  enabled
        system.adapter.vis-material.0           : vis-material          : rpi-iobroker        -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : rpi-iobroker        -  enabled
        system.adapter.vis-players.0            : vis-players           : rpi-iobroker        -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : rpi-iobroker        -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : rpi-iobroker        -  enabled
        system.adapter.vis.0                    : vis                   : rpi-iobroker        -  enabled
      + system.adapter.web.0                    : web                   : rpi-iobroker        -  enabled, port: 8082, bind: 192.168.10.35, run as        : admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "adguard"      : 0.0.8    , installed 0.0.8
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "knx"          : 2.0.24   , installed 2.0.24
      Adapter    "openknx"      : 0.6.3    , installed 0.6.3
      Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
      Adapter    "squeezeboxrpc": 1.3.9    , installed 1.3.9
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Objects and States
      Objects:        2398
      States:         1733
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Hit:3 http://giteduberger.fr rpimonitor/ InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address           Foreign Address         State        User       Inode      PID/Program name
      tcp        0      0 192.168.10.35:8082      0.0.0.0:*               LISTEN        1001       1743951    26212/io.web.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN        0          13075      597/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN        0          102801     7895/perl
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN        1001       546079     17907/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN        1001       546072     17907/iobroker.js-c
      tcp6       0      0 :::8081                 :::*                    LISTEN        1001       544138     17932/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN        0          13077      597/sshd: /usr/sbin
      udp        0      0 0.0.0.0:3483            0.0.0.0:*        1001       545732     18202/io.squeezebox
      udp        0      0 0.0.0.0:68              0.0.0.0:*        0          9162       589/dhcpcd
      udp        0      0 0.0.0.0:40022           0.0.0.0:*        108        11731      344/avahi-daemon: r
      udp        0      0 0.0.0.0:58469           0.0.0.0:*        1001       1743255    26270/io.openknx.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*        108        11729      344/avahi-daemon: r
      udp6       0      0 :::5353                 :::*        108        11730      344/avahi-daemon: r
      udp6       0      0 :::45858                :::*        108        11732      344/avahi-daemon: r
      2024-01-29 11:55:58.159  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.32 GA 1/0/45 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Beleu        chtung.WERT_MESS_-_Küche_-_EG val: 833.28 dpt: DPT9.004
      2024-01-29 11:55:58.310  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.42 GA 1/0/75 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Beleu        chtung.WERT_MESS_-_Diele_-_EG val: 1849.6 dpt: DPT9.004
      2024-01-29 11:55:58.760  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.44 GA 1/0/91 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Beleu        chtung.WERT_MESS_-_WC-Gäste_-_EG val: 5235.2 dpt: DPT9.004
      2024-01-29 11:55:59.160  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.44 GA 1/0/91 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Beleu        chtung.WERT_MESS_-_WC-Gäste_-_EG val: 5253.12 dpt: DPT9.004
      2024-01-29 11:55:59.559  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.42 GA 1/0/75 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Beleu        chtung.WERT_MESS_-_Diele_-_EG val: 1870.08 dpt: DPT9.004
      2024-01-29 11:56:00.060  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.44 GA 1/0/91 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Beleu        chtung.WERT_MESS_-_WC-Gäste_-_EG val: 5283.84 dpt: DPT9.004
      2024-01-29 11:56:00.311  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.0.3 GA 0/7/1 to Object: openknx.0.Zentral.Sonderfunktion.Datum va        l: 1706482800000 dpt: DPT11.001
      2024-01-29 11:56:00.314  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.0.3 GA 0/7/0 to Object: openknx.0.Zentral.Sonderfunktion.Uhrzeit        val: 1706525760313 dpt: DPT10.001
      2024-01-29 11:56:00.409  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.44 GA 1/0/91 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Beleu        chtung.WERT_MESS_-_WC-Gäste_-_EG val: 5309.44 dpt: DPT9.004
      2024-01-29 11:56:00.809  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.42 GA 1/0/75 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Beleu        chtung.WERT_MESS_-_Diele_-_EG val: 1890.56 dpt: DPT9.004
      2024-01-29 11:56:00.812  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.49 GA 1/0/121 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Bele        uchtung.WERT_MESS_-_Kind_1_-_EG val: 364.48 dpt: DPT9.004
      2024-01-29 11:56:01.209  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.44 GA 1/0/91 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Beleu        chtung.WERT_MESS_-_WC-Gäste_-_EG val: 5340.16 dpt: DPT9.004
      2024-01-29 11:56:01.459  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.32 GA 1/0/45 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Beleu        chtung.WERT_MESS_-_Küche_-_EG val: 807.04 dpt: DPT9.004
      2024-01-29 11:56:01.559  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.37 GA 1/0/60 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Beleu        chtung.WERT_MESS_-_Büro_Eltern_-_EG val: 562.56 dpt: DPT9.004
      2024-01-29 11:56:02.059  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.42 GA 1/0/75 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Beleu        chtung.WERT_MESS_-_Diele_-_EG val: 1911.04 dpt: DPT9.004
      2024-01-29 11:56:02.109  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.44 GA 1/0/91 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Beleu        chtung.WERT_MESS_-_WC-Gäste_-_EG val: 5370.88 dpt: DPT9.004
      2024-01-29 11:56:02.210  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.18 GA 1/3/0 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Heizun        g.Hzg__-_Ist_Temp__TS_-_Wohnzimmer_-_EG val: 19.21 dpt: DPT9.001
      2024-01-29 11:56:02.860  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.44 GA 1/0/91 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Beleu        chtung.WERT_MESS_-_WC-Gäste_-_EG val: 5401.6 dpt: DPT9.004
      2024-01-29 11:56:03.659  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.42 GA 1/0/75 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Beleu        chtung.WERT_MESS_-_Diele_-_EG val: 1932.8 dpt: DPT9.004
      2024-01-29 11:56:03.709  - debug: openknx.0 (26270) Inbound GroupValue_Write ind        ication from 1.1.44 GA 1/0/91 to Object: openknx.0.Erdgeschoss_(+Kind1_DG).Beleu        chtung.WERT_MESS_-_WC-Gäste_-_EG val: 5432.32 dpt: DPT9.004
      2024-01-29 11:56:04.012  - error: homeconnect.0 (18799) 502 Bad Gateway
      2024-01-29 11:56:04.012  - error: homeconnect.0 (18799) Start Event Stream Error        : {"type":"error","status":502,"message":"Bad Gateway"}
      2024-01-29 11:56:04.013  - error: homeconnect.0 (18799) Error: 502
      2024-01-29 11:56:04.013  - error: homeconnect.0 (18799) Error: {"type":"error","        status":502,"message":"Bad Gateway"}
      2024-01-29 11:56:04.013  - error: homeconnect.0 (18799) Homeconnect API are not        available please try again later
      iob diag has finished.
      Press any key for a summary
        Homoran Global Moderator Administrators @D.Wermer last edited by
        @d-wermer bitte immer alles zeigen!
        Keine Nacherzählungen.
        Das sieht für mich nach einem Frontend Problem aus, nicht eins der iob Installation.
        im diag output ist mir nichts passendes aufgefallen.
        BTW bitte beim nächsten mal das Putty Fenster breiter ziehen. Dann bleiben die Zeilen zusammenhängend
          soweit sind alle Adapter auf dem neuesten Stand. Mit den Objekten aus der KNX Adapter Instanz läuft es eigentlich. Das Problem ist nur dass dieser Adapter immer nur einmal alle Daten holt und dann nicht mehr. Er meckert es wären zu viele Datenpunkte, dabei sind es 487 und keine über 500. Daher bin ich auf open KNX gewechselt.
            Mein generelle Frage ist: Gibt es eine genaue Erläuterung was das HQWidget als Objekt erwartet? Ich kann keine genaue Erläuterung dazu finden.
              @d-wermer auch hier kann ich nur wieder sagen: zeigen!
              ich kenne nicht die Konfiguration aller 500+ Widgets
                  @d-wermer was möchtest du mir hiermit
                  zeigen?
                  Das ist doch nicht die Konfiguration des Widgets, oder?
                  Wenn ich da etwas glaube erkannt zu haben, hast du unterschiedliche Werte für IST und SOLL.
                  ist dieses Widget nicht für die Steuerung von Heizkörpern gedacht?
                    Das ist die Ansicht aktuell. ich lösche diese und erstelle ein neues um die Daten zu zeigen. Datenpunkte sind wie immer im KNX ein Objektwert für Soll und einer für IST wobei beide dieselben Objekttypen sind. SOLL ist nicht die BASIS SOLLWERTVERSCHIEBUNG
                    Deswegen ist ja interessant zu wissen was jetzt am Ende das Widget an Werte erwartet?
                    Hier die Konfiguration vor dem "unsichtbaren"
                    TYP & ROLLEN sind je State. als Zahlenwert °C
                      Homoran Global Moderator Administrators @D.Wermer last edited by Homoran
                      @d-wermer da muss dir jemand mit KNX-Erfahrung helfen.
                      Das Widget war ursprünglich für Homematic Heizkörperventile gedacht und die dazugehörigen DP wurden hier eingetragen.
                      Welche Werte bei KNX jetzt damit korrelieren kann ich dir nicht sagen.
                      ganz andere Frage:
                      Da ich deinen Screenshot auch nicht entziffern kann, vermute ich dass du ggf. eine zu hohe Auflösung nutzt.
                      kommt der Fehler auch bei fullHD?
                        AAh. also jetzt komme ich der Sache ein bisschen näher.
                        evlt. kann auch wer mit open KNX weiterhelfen.
                        Ein riesen Dankeschön schon mal für deine super schnelle Hilfestellung.
                        Aus meinem Bekanntekreis sind alle zu Home Assistant rüber gewechselt aber ich sehe mehr Zukunft in diesem Projekt. Daher bin ich ziemlich auf einsamen Fusse hier 😉
                          Auflösung ist handeingetragen bei 1920 x 1080 Pixel. Also Full HD
                            @d-wermer sagte in VIS 1 / HQWidgets inner Temperature Probleme im Editor:
                            die deines Monitors?
                              Die Abbildung des VIEW hat fest eingestellte FullHD. Das soll halt mein Standard im Hause sein. Ist halt eine sehr gängiges Format was fast alle Geräte anzeigen können.
                              Aber du hast recht. Mein Notebook hat eine größere Auflösung: 2880x1620 Pixel auf 15 Zoll
                                da gab es mal was, dass es bei hohen Auflösungen seltsame Effekte gab.
                                stell deine mal zum Testen runter
                                  Ai ok? Ich probiere das mal direkt aus. Aber erst morgen. Kinder müssen ins Bett 😉
                                  Hier meine Visu in Vollansicht.
                                  Das ist die Übersicht vom EG. Die Buttons an der Seite sind teils Meldungen teils Verknüpfungen über Alias' um die Gewünschten Elemente in der Visu anzuzeigen.
                                  Beleuchtung kann immer direkt über die Raumwahl angesteuert werden.
                                  Am Ende soll das ganze hier Übersichtlich sein um der ganzen Familie alles zu vereinfachen.
                                  Die Steuerungen sollen halt Sicherheit, Komfort & Sparsamkeit vereinen.
                                    @d-wermer es geht doch um das Phänomen der verschwundenen Eigenschaften Sidebar im Editor!
                                    ich würde gerne ausschließen, dass das an deiner Auflösung des Notebooks liegt.
                                      Hab es jetzt gerade bei Full Hd ausprobiert.
                                      Auch einmal mit anderem Endgerät in Full HD.
                                      Selbes Problem
                                        Selbes Problem
                                        danke!
                                        damit sollte die Auflösung aus dem Rennen sein.
                                          Ja. So sieht es aus. Es ist ja auch komisch das es mit anderen Werten aus anderen Instanzen klappt. Ich vermute da einfach dass HQWidgets mit den Gruppenadressenimportierungen nicht klar kommt. Alle Gruppen sind sauper Deklariert und auch in ihren DPT gekennzeichnet. Das war halt elementar für die KNX Instanz. Sprich die ich vor openKNX genutzt habe.
                                            wieso.
                                            ist ein Wert in einem Datenpunkt wie jeder andere.
                                            höchstens dass er nicht beschreibbar ist.
                                            Möglich dass man da zwei Werte über einen Alias zusammenführen muss
                                            vis
                                            1464
