    4. Frigate Adapter für ioBroker
      tombox @QuesT last edited by
      @quest brauch ich den Fehler log
        hagst @tombox last edited by
        @tombox sagte in Frigate Adapter für ioBroker:
        Kannst die logs wieder löschen und die GitHub version drüber installieren
        frigate.0
        2024-01-28 14:36:00.603	info	Device information created
        frigate.0
        2024-01-28 14:36:00.600	info	Fetch event history for 3 cameras
        frigate.0
        2024-01-28 14:36:00.586	info	Create device information for: Wald
        frigate.0
        2024-01-28 14:36:00.573	info	Create device information for: Terrasse
        frigate.0
        2024-01-28 14:36:00.558	info	Create device information for: Einfahrt
        frigate.0
        2024-01-28 14:36:00.527	info	Create Device information and fetch Event History
        frigate.0
        2024-01-28 14:35:55.551	info	frigate.0 (1789) MQTT client frigate subscribed to topics: frigate/# from broker 00d2ab76-66f6-4aa7-8018-159a69db4997
        frigate.0
        2024-01-28 14:35:55.526	info	Filter for message from client: frigate
        frigate.0
        2024-01-28 14:35:55.526	info	New client: frigate
        frigate.0
        2024-01-28 14:35:51.876	info	If you don't see a new client connected, please restart frigate and adapter.
        frigate.0
        2024-01-28 14:35:51.876	info	Please enter host: 'iobroker' and port: '1885' in frigate config
        frigate.0
        2024-01-28 14:35:51.876	info	MQTT server started and listening on port 1885
        frigate.0
        2024-01-28 14:35:51.793	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.frigate) in /opt/iobroker/node_modules/iobroker.frigate, node: v20.11.0, js-controller: 5.0.17
        frigate.0
        2024-01-28 14:35:48.503	info	terminating
        frigate.0
        2024-01-28 14:35:48.002	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        frigate.0
        2024-01-28 14:35:48.002	info	terminating
        frigate.0
        2024-01-28 14:35:48.001	info	Got terminate signal TERMINATE_YOURSELF
        Jetzt sind die Einträge erstellt worden!
        • Q
          QuesT @tombox last edited by QuesT
          @tombox
          2024-01-28 15:10:07.144 - error: pushover.0 (1040) Error from Pushover: message cannot be blank
          2024-01-28 15:10:08.172 - error: pushover.0 (1040) Error from Pushover: message cannot be blank
          2024-01-28 15:10:27.144 - error: pushover.0 (1040) Error from Pushover: SyntaxError: Unexpected token < in JSON at position 0
          2024-01-28 15:10:27.639 - error: pushover.0 (1040) Error from Pushover: SyntaxError: Unexpected token < in JSON at position 0
          Danach startet der ioBroker neu.
            @quest bitte mal die GitHub version testen
            • Q
              @tombox
              2024-01-28 17:16:45.523 - error: pushover.0 (4298) Error from Pushover: message cannot be blank
              Stürzt aber nicht mehr ab.
                @quest dann nochmal installieren
                • Q
                  @tombox
                  Bild kommt nun an. Video noch nicht: pushover.0 (1051) Error from Pushover: SyntaxError: Unexpected token < in JSON at position 0
                    @quest für den clip wäre noch ein debug log gut auch gerne per PN
                    • Q
                      @tombox
                      Vergiss es Pushover kann nur jpg.
                      Danke für die schnelle Hilfe.
                        MrHenker27 last edited by
                        Also zum ersten mal danke für den neuen Adapter.
                        Leider bekomm ich Warn Meldungen im Log -.-
                        State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
                          tombox @MrHenker27 last edited by
                          @mrhenker27 kommt das mit der 1.0.2?
                            MrHenker27 @tombox last edited by
                            @tombox
                            okay, war die 1.0.0 hab jetzt über GIT mal die 1.0.2 installiert. Scheint behoben zu sein.
                              MarkA @MrHenker27 last edited by
                              Leider geht mit dem neuen Adapter die Kombination von Frigate in Verbindung mit Touble-Take und Compreface zur Personenerkennung nicht mehr, da alle mit dem gleichen MQTT Server sprechen müssen.
                                tombox @MarkA last edited by
                                @marka Eigentlich sollte das gehen. Bitte mal die GitHub version installieren und einfach als mqtt host den iobroker eingeben
                                  MarkA @tombox last edited by
                                  das geht bei mir so leider nicht. So wie ich die neue Version verstanden habe, bringt sie einen eigenen MQTT Broker mit. Dies möchte ich nicht, da ich bereits den MQTT Adapter, sowie den SONOFF Adapter für MQTT laufen habe, mit jeweils vielen Integrationen, je nachdem wie die Daten ankommen.
                                  Dazu kommt noch, dass der Frigate Adapter MQTT keine Authentifizierung benutzt.
                                    ralf2201 last edited by
                                    wie kann ich denn wieder auf die alte Version zurück? Kann mir da jemand helfen?
                                      martinschm @ralf2201 last edited by martinschm
                                      Installation hat gleich geklappt, hab lediglich den MQTT Port angepasst. Telegram Benachrichtiung kam auch gleich an, sehr cool gemacht. Vielen Dank für die neue Adapter Version.
                                      Kurze Frage noch zu den State
                                      Warum hat der Channel "Motion" auch nochmal einen Wert ?
                                      Und welchen State muß ich nehmen wenn ich in meiner Visualisierung "kurz" anzeigen will ob es eine Bewegung gab. Irgendwann sollte der State ja auch mal wieder falsch sein, oder ?
                                      Bei mir schein der State "state" unter Motion immer auf true zu stehen.
                                      Und wisst ihr zufällig wie ich den Livestream einer Kamera aus frigate in meiner Visualisierung einbinde ?
                                        @MarkA
                                        Alles klar aber wenn man Double Take mit dem Adapter verbindet werden alle Double Take Status korrekt in den Adapter Objekten angezeigt
                                        @ralf2201
                                        Das letzte Symbol mit dem Plus
                                          @tombox said in Frigate Adapter für ioBroker:
                                          @MarkA
                                          ich Verstehe es wohl nicht. Aktuell läuft das bei mir wie folgt:
                                          • Frigate erkennt eine Person und meldet das per MQTT
                                          • per MQTT bekommt wiederum DoubleTake das ganze mit und sendet die entsprechenden Images per MQTT weiter an Compreface
                                          • Compreface schaut ob die Person bekannt ist und wenn ja, wird per MQTT zurückgemeldet, welche Person das ist
                                          Wenn ich alle drei Komponenten auf den Adapter MQTT einstelle, funktioniert das o.g. Verhalten nicht mehr, da keine MQTT Verbindungen von DT und CF aufgebaut werden können.
                                            @marka
                                            Frigate verbindet sich mit Adapter MQTT und sendet Events
                                            DoubleTake verbindet sich mit Adapter MQTT und empfängt die Events und sendet eigene Events die unter Adapter Objekte abgespeichert werden
                                            DoubleTake verbindet sich via API und API Key mit Compreface
                                            1.0k
                                            367
                                            98602
