    5. Blockly Anwesenheit Ble.0 Adapter Mi Band Problem ( Gelöst )
    • Walter.O.
      Walter.O. last edited by Walter.O.
      Hab mal dieses Blocky :
      <variables>
      <variable id="]%[Pv~2OU1w5nijZ:/I">Anwesenheit</variable> <variable type="timeout" id="timeout">timeout</variable> </variables> <block type="variables_set" id="Ufc^7Tg^$.Yj/r*[lVuk" x="13" y="13"> <field name="VAR" id="]%[Pv~2OU1w5nijZ:/I">Anwesenheit</field>
      <block type="logic_boolean" id="roJ~Uigo|5*+ahNK,_">
      <block type="on" id="ogPjCIwOw.8o=@RUnwT">
      <field name="OID">ble.0.f2:55:92:c3:13:0d.rssi</field>
      <block type="timeouts_cleartimeout" id="S/QlljbFlTqk6PBofij?">
      <block type="controls_if" id="y[yC:Mo#:lD~(wpQcQ7H">
      <block type="logic_negate" id="6$
      !vu^C9Go:bUd#Y3S)">
      <value name="BOOL">
      <block type="variables_get" id="g.8[?4eQ3{4YuqN=Lk">
      <field name="VAR" id="]%[Pv~2OU1w5nijZ:/I">Anwesenheit</field> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="}o4z!3h9I$i+{7RMB5q">
      <field name="VAR" id="]%[Pv~2OU1w5nijZ:/I">Anwesenheit</field> <value name="VALUE"> <block type="logic_boolean" id="Lj/{P=rbVmWU.wHFMkEg"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="}W*WRq1:Pr-w2F^Btcr}"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">0_userdata.0.Diverse.Test.Anwesenheit-MiBand</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="Y?PT1pL8~gzwAJHhQ!Z">
      <block type="debug" id="%rfT]WDUYS7Vmwi}SMp"> <field name="Severity">error</field> <value name="TEXT"> <shadow type="text" id="ra;wNRDryR%^{05VA^,E"> <field name="TEXT">Bin zu Hause. Mi Band</field> </shadow> </value> </block> </next> </block> </next> </block> </statement> <next> <block type="timeouts_settimeout" id="ZaZMXpJ6h^]D{}~YZl;">
      <field name="DELAY">30</field>
      <block type="controls_if" id="2tr1HC@()p9?Ux]9}4,9">
      <block type="variables_get" id="0N:y0M5h8K]HZE6Wp81.">
      <field name="VAR" id="]%[Pv~2OU1w5nijZ:/I">Anwesenheit</field> </block> </value> <statement name="DO0"> <block type="variables_set" id=",Qcig],)rM(g@[CbA4xG"> <field name="VAR" id="]%[Pv~2OU1w5nijZ:/I">Anwesenheit</field>
      <block type="logic_boolean" id="W!_OqMp3t,q$/xO%?[R"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="control" id="QLOH$5Pzb}?zyph2juv4"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">0_userdata.0.Diverse.Test.Anwesenheit-MiBand</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="logic_boolean" id="ZpCO,,vd8++-OYh@Zh1y"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="debug" id=".C(S$pWa+l-3n+r7WE.;"> <field name="Severity">error</field> <value name="TEXT"> <shadow type="text" id=",%f6+ikK)G-ztOiQ-YP">
      <field name="TEXT">Bin dann mal weg. Mi Band</field>
      <block type="create" id="Go.K(A.5u){y(mr/[pUM" x="113" y="662">
      <field name="NAME">0_userdata.0.Diverse.Test.Anwesenheit-MiBand</field>
      Die Ausgabe in den Logs:
      Soweit funktioniert das ja wohl, wenn ich das Richtig verstehe.
      Aber warum Ändert sich der Datenpunkt nicht?
      Kann mir mal jemand lweiterhelfen?
      Ich Danke schon mal im vorab
      DJMarc75 paul53 2 Replies Last reply Reply Quote 0
      • DJMarc75
        DJMarc75 @Walter.O. last edited by DJMarc75
        @walter-o sagte in Blockly Anwesenheit Ble.0 Adapter Mi Band Problem:
        Was steht im LOG ?
        Welcher TYP hat Dein Datenpunkt ? Eher nicht Boolean vermute ich 🙂
          paul53 @Walter.O. last edited by
          @walter-o sagte: Aber warum Ändert sich der Datenpunkt nicht?
          Der Wert des Trigger-DP (RSSI) wird nicht ausgewertet.
          Walter.O. 1 Reply Last reply Reply Quote 1
          • Walter.O.
            Walter.O. @paul53 last edited by
            Ich gehe davon aus das der Trigger-DP (RSSI) ausgewertet wurde , denn das würde erklären das sich
            die werte im Log :
            script.js.common.Tracking.test-mi-band: Bin zu Hause. Mi Band
            script.js.common.Tracking.test-mi-band: Bin dann mal weg. Mi Band
            dahingehend verändern wenn ich die Reichwerte des Ble scanners verlasse
            W paul53 2 Replies Last reply Reply Quote 0
              wolfi913 @Walter.O. last edited by
              @walter-o
              Schau mal (Stift hinter dem Datenpunkt) ob dieser wirklich auf "boolean" steht (Logikwert für wahr/falsch)
              und ändere das ggf. ab.
              Walter.O. 1 Reply Last reply Reply Quote 0
              • Walter.O.
                Walter.O. @wolfi913 last edited by Walter.O.
                @wolfi913
                So, der Zustands Typ stand auf Gemischt, habe ich auf Bolean Logigwert geändert.
                Ergebniss, keine Änderung bei True False
                  paul53 @Walter.O. last edited by paul53
                  @walter-o sagte: Ich gehe davon aus das der Trigger-DP (RSSI) ausgewertet wurde
                  Wo?
                  EDIT: Es sollte etwa so aussehen:
                   <variables>
                   </variables>
                           <block type="controls_if" id="snNGA}vmf{sH}zRjpUJ3">
                               <block type="logic_compare" id="6?|Hp=l-94A_]OSZ^I.Z">
                                 <field name="OP">GT</field>
                                   <block type="on_source" id="aycQRX!J/=_[(d]8}ZYN">
                                   <block type="math_number" id="I1V/qF/%}B2C[/sH)/J{">
                                     <field name="NUM">-60</field>
                                       <block type="logic_negate" id="6$!vu^C9Go:bUd#Y3S)">
                                         <value name="BOOL">
                                                 <value name="TEXT">
                             <value name="IF1">
                               <block type="logic_compare" id="tVHsGQ;~Pi=;/da0-h/)">
                                   <block type="on_source" id="$zYu3;@4iZPL#yI+ia$%">
                                     <field name="ATTR">oldState.val</field>
                                   <block type="math_number" id="kLBF!%+a7Umfs*,iHrRJ">
                             <statement name="DO1">
                                                 <value name="TEXT">
