Silverscrest Smart Button *gelöst*
Hab mehrere Buttons da... auch neue... die LED blinkt das er Pairen will... Hab Kanal 11 ...
@ralla66 DAS ST EINE FEHLERHAFTE FIRMWARE..... die du da postest.. also LASS ES
@gluecksmann na was erwartest du noch ?? bei mir läuft er.. punkt.. und da du nicht mehr an LOG lieferst als nur
type:zStack3x0 version:2-1.2.7.1. revision:20210708was soll ich damit anfangen ??
welche adapter version ?? welcher adapter überhaupt ?? welche node version??
Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.1.0-rpi7-rpi-v8 Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Kernel : aarch64 Userland : arm64 Systemuptime and Load: 11:34:18 up 11 days, 15:25, 4 users, load average: 1.67, 1.23, 0.77 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Mon 2024-01-29 11:34:18 CET Universal time: Mon 2024-01-29 10:34:18 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 8.2G 3.5G 3.4G 16M 1.5G 4.7G Swap: 104M 0B 104M Total: 8.3G 3.5G 3.5G 7811 M total memory 3317 M used memory 3364 M active memory 938 M inactive memory 3270 M free memory 150 M buffer memory 1257 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 782M 1.3M 780M 1% /run /dev/mmcblk0p2 ext4 58G 6.8G 49G 13% / tmpfs tmpfs 3.9G 140K 3.9G 1% /dev/shm tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 510M 73M 438M 15% /boot/firmware tmpfs tmpfs 782M 36K 782M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Wed Jan 17 20:08:59 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=9e5696c9-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE [Wed Jan 17 20:09:02 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none. [Wed Jan 17 20:09:04 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime,commit=600 |-/run/user/1000/doc portal fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 576M /var/ 191M /var/lib 186M /var/cache 173M /var/cache/apt 132M /var/lib/apt/lists Archived and active journals take up 95.9M in the file system. /opt/iobroker/backups: 55M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 460M /opt/iobroker/iobroker-data/ 335M /opt/iobroker/iobroker-data/files 78M /opt/iobroker/iobroker-data/backup-objects 67M /opt/iobroker/iobroker-data/files/javascript.admin 48M /opt/iobroker/iobroker-data/files/javascript.admin/static The five largest files in iobroker-data are: 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 34M /opt/iobroker/iobroker-data/objects.jsonl 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map 21M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map 13M /opt/iobroker/iobroker-data/states.jsonl USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0 *** NodeJS-Installation *** /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.0-1nodesource1 Candidate: 18.19.0-1nodesource1 Version table: 18.19.0+dfsg-6~deb12u1 500 500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages *** 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.13.0+dfsg1-1 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.17 admin: 6.12.0 javascript: 7.1.6 Adapters from github: 1 Adapter State + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : raspberrypi - enabled system.adapter.alias-manager.0 : alias-manager : raspberrypi - disabled + system.adapter.awtrix-light.0 : awtrix-light : raspberrypi - enabled + system.adapter.backitup.0 : backitup : raspberrypi - enabled + system.adapter.ble.0 : ble : raspberrypi - enabled system.adapter.chromecast.0 : chromecast : raspberrypi - disabled system.adapter.daswetter.0 : daswetter : raspberrypi - enabled system.adapter.devices.0 : devices : raspberrypi - disabled + system.adapter.discovery.0 : discovery : raspberrypi - enabled system.adapter.dwd.0 : dwd : raspberrypi - enabled + system.adapter.fullybrowser.0 : fullybrowser : raspberrypi - enabled + system.adapter.govee.0 : govee : raspberrypi - enabled + system.adapter.gruenbeck.0 : gruenbeck : raspberrypi - enabled system.adapter.history.0 : history : raspberrypi - disabled + system.adapter.hue.0 : hue : raspberrypi - enabled, port: 443 system.adapter.ical.0 : ical : raspberrypi - enabled system.adapter.icons-mfd-png.0 : icons-mfd-png : raspberrypi - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspberrypi - disabled + system.adapter.info.0 : info : raspberrypi - enabled + system.adapter.iot.0 : iot : raspberrypi - enabled + system.adapter.javascript.0 : javascript : raspberrypi - enabled + system.adapter.meross.0 : meross : raspberrypi - enabled + system.adapter.mielecloudservice.0 : mielecloudservice : raspberrypi - enabled + system.adapter.musiccast.0 : musiccast : raspberrypi - enabled + system.adapter.net-tools.0 : net-tools : raspberrypi - enabled + system.adapter.netatmo.0 : netatmo : raspberrypi - enabled + system.adapter.philips-air.0 : philips-air : raspberrypi - enabled system.adapter.philips-air.1 : philips-air : raspberrypi - disabled system.adapter.ping.0 : ping : raspberrypi - disabled + system.adapter.pollenflug.0 : pollenflug : raspberrypi - enabled + system.adapter.scenes.0 : scenes : raspberrypi - enabled + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 system.adapter.shuttercontrol.0 : shuttercontrol : raspberrypi - disabled + system.adapter.smartcontrol.0 : smartcontrol : raspberrypi - enabled + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.sonos.0 : sonos : raspberrypi - enabled + system.adapter.trashschedule.0 : trashschedule : raspberrypi - enabled + system.adapter.tuya.0 : tuya : raspberrypi - enabled system.adapter.vis-colorpicker.0 : vis-colorpicker : raspberrypi - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - disabled system.adapter.vis-icontwo.0 : vis-icontwo : raspberrypi - disabled + system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - enabled system.adapter.vis-material-advanced.0 : vis-material-advanced : raspberrypi - disabled system.adapter.vis-metro.0 : vis-metro : raspberrypi - disabled system.adapter.vis-players.0 : vis-players : raspberrypi - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi - disabled system.adapter.vis.0 : vis : raspberrypi - enabled system.adapter.weatherunderground.0 : weatherunderground : raspberrypi - enabled + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hue.0 : hue : raspberrypi - enabled, port: 443 + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0 ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.12.0 , installed 6.12.0 Adapter "alexa2" : 3.26.4 , installed 3.26.4 Adapter "alias-manager": 1.2.6 , installed 1.2.6 Adapter "awtrix-light" : 0.11.0 , installed 0.11.0 Adapter "backitup" : 2.9.8 , installed 2.9.8 Adapter "ble" : 0.13.4 , installed 0.13.4 Adapter "chromecast" : 3.0.3 , installed 3.0.3 Adapter "daswetter" : 3.1.13 , installed 3.1.13 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "fullybrowser" : 3.0.9 , installed 3.0.9 Adapter "gruenbeck" : 0.0.42 , installed 0.0.42 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hue" : 3.10.2 , installed 3.10.2 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "info" : 2.0.0 , installed 2.0.0 Adapter "iot" : 2.0.11 , installed 2.0.11 Adapter "javascript" : 7.1.6 , installed 7.1.6 Controller "js-controller": 5.0.17 , installed 5.0.17 Adapter "meross" : 1.17.0 , installed 1.17.0 Adapter "mielecloudservice": 6.5.4, installed 6.5.4 Adapter "musiccast" : 1.1.3 , installed 1.1.3 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "netatmo" : 3.1.0 , installed 3.1.0 Adapter "philips-air" : 1.0.3 , installed 1.0.3 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "scenes" : 2.3.9 , installed 2.3.9 Adapter "shelly" : 6.6.1 , installed 6.6.1 Adapter "shuttercontrol": 1.6.3 , installed 1.6.3 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "smartcontrol" : 2.0.1 , installed 2.0.1 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "sonoff" : 3.0.3 , installed 3.0.3 Adapter "sonos" : 3.0.0 , installed 3.0.0 Adapter "trashschedule": 2.3.0 , installed 2.3.0 Adapter "tuya" : 3.15.0 , installed 3.15.0 Adapter "vis" : 1.5.4 , installed 1.5.4 Adapter "vis-colorpicker": 2.0.3 , installed 2.0.3 Adapter "vis-hqwidgets": 1.4.0 , installed 1.4.0 Adapter "vis-icontwo" : 1.3.0 , installed 1.3.0 Adapter "vis-inventwo" : 3.3.3 , installed 3.3.3 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "weatherunderground": 3.6.0, installed 3.6.0 Adapter "web" : 6.1.10 , installed 6.1.10 Adapter "ws" : 2.5.8 , installed 2.5.8 Adapter "zigbee" : 1.10.1 , installed 1.10.1 Objects and States Please stand by - This may take a while Objects: 11348 States: 9351 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease Hit:4 http://deb.debian.org/debian bookworm-updates InRelease Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 23 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 2842789 3024037/iobroker.js tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 2842782 3024037/iobroker.js tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 32441242 3930610/cupsd tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 10445423 2756269/io.sonoff.0 tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 17390 808/sshd: /usr/sbin tcp6 0 0 :::8082 :::* LISTEN 1001 2843281 3024355/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 2841856 3024055/io.admin.0 tcp6 0 0 :::3500 :::* LISTEN 1001 2842904 3024108/io.sonos.0 tcp6 0 0 :::3000 :::* LISTEN 1001 2846866 3025481/io.fullybro tcp6 0 0 ::1:631 :::* LISTEN 0 32441241 3930610/cupsd tcp6 0 0 :::22 :::* LISTEN 0 17392 808/sshd: /usr/sbin udp 0 0 0.0.0.0:41100 0.0.0.0:* 1001 2844258 3024576/io.musiccas udp 0 0 0.0.0.0:631 0.0.0.0:* 0 32440084 3930611/cups-browse udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 16973 521/avahi-daemon: r udp 0 0 0.0.0.0:54745 0.0.0.0:* 1001 2841070 3024234/io.philips- udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 2842112 3024249/io.shelly.0 udp 0 0 0.0.0.0:59623 0.0.0.0:* 104 16975 521/avahi-daemon: r udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 2841116 3024279/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 2841117 3024279/io.tuya.0 udp6 0 0 :::41086 :::* 104 16976 521/avahi-daemon: r udp6 0 0 fe80::e996:6ae8:1bc:546 :::* 0 15326 660/NetworkManager udp6 0 0 :::5353 :::* 104 16974 521/avahi-daemon: r *** Log File - Last 25 Lines *** 2024-01-29 11:33:50.039 - error: govee.0 (3024453) AxiosError: Request failed with status code 429 2024-01-29 11:33:53.886 - info: web.0 (3024355) ==> Connected system.user.admin from ::ffff:192.168.2.109 2024-01-29 11:34:00.029 - error: govee.0 (3024453) AxiosError: Request failed with status code 429 2024-01-29 11:34:05.408 - info: meross.0 (3024181) Device: 2112164654005790863748e1e981c954 closed: null 2024-01-29 11:34:10.036 - error: govee.0 (3024453) AxiosError: Request failed with status code 429 2024-01-29 11:34:10.408 - info: meross.0 (3024181) Device: 2112164654005790863748e1e981c954 reconnected 2024-01-29 11:34:10.544 - info: meross.0 (3024181) Device: 2112164654005790863748e1e981c954 connected 2024-01-29 11:34:20.038 - error: govee.0 (3024453) AxiosError: Request failed with status code 429 2024-01-29 11:34:30.051 - error: govee.0 (3024453) AxiosError: Request failed with status code 429 2024-01-29 11:34:35.409 - info: meross.0 (3024181) Device: 2112164654005790863748e1e981c954 closed: null 2024-01-29 11:34:40.014 - error: govee.0 (3024453) AxiosError: Request failed with status code 429 2024-01-29 11:34:40.409 - info: meross.0 (3024181) Device: 2112164654005790863748e1e981c954 reconnected 2024-01-29 11:34:40.539 - info: meross.0 (3024181) Device: 2112164654005790863748e1e981c954 connected 2024-01-29 11:34:50.042 - error: govee.0 (3024453) AxiosError: Request failed with status code 429 2024-01-29 11:35:00.043 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 1173320 2024-01-29 11:35:00.045 - error: govee.0 (3024453) AxiosError: Request failed with status code 429 2024-01-29 11:35:02.928 - info: dwd.0 (1173320) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17 2024-01-29 11:35:04.469 - info: dwd.0 (1173320) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2024-01-29 11:35:05.071 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2024-01-29 11:35:05.410 - info: meross.0 (3024181) Device: 2112164654005790863748e1e981c954 closed: null 2024-01-29 11:35:10.027 - error: govee.0 (3024453) AxiosError: Request failed with status code 429 2024-01-29 11:35:10.410 - info: meross.0 (3024181) Device: 2112164654005790863748e1e981c954 reconnected 2024-01-29 11:35:10.552 - info: meross.0 (3024181) Device: 2112164654005790863748e1e981c954 connected 2024-01-29 11:35:20.044 - error: govee.0 (3024453) AxiosError: Request failed with status code 429 2024-01-29 11:35:30.020 - error: govee.0 (3024453) AxiosError: Request failed with status code 429 -
@gluecksmann na also damit kann man arbeiten...
Adapter "zigbee" : 1.10.1 , installed 1.10.1 mit ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plusdie Firmware ist sehr alt.. bitte diese erstmal flashen wobei du schauen musst was bei dir besser funktioniert
es gibt Probleme mit der Firmware ..wird aber noch dauern..also entweder wartest du oder spielst eine von hier auf
https://github.com/Koenkk/Z-Stack-firmware/discussions/483
preferiert wird diese 20231112
Na toll das ich den Stick gerade erst gekauft habe...
@gluecksmann sagte in Silverscrest Smart Button:
und wo ist das problem ???
@arteck said in Silverscrest Smart Button:
Naja, man hofft ja schon, dass auf einem frisch gekauften Gerät auch eine aktuelle Firmware ist.
Ist aber wohl in dieser Preisklasse nicht zu erwarten, dass der Händler da vor dem Versenden noch einmal Hand anlegt.... -
@martinp sagte in Silverscrest Smart Button:
das ist quack .. noch nichtmal die grossen machen das.. wie den auch..
wenn ein Gerät länger auf dem Lager liegt.. meinst du wird dieser ausgepackt um dem Kunden eine neue Firmware aufzuspielen..
als nächstes regt sich der Kunde auf.. dass er ein offenes Gerät bekommen hat.flash das ding und gut ist
Gibt aber halt auch immer Leute, so wie mich, die mit "flasch das Ding" Probleme haben... Erst mal weil es meine technischen Fähigkeiten übersteigt...zweitens scheint es, schon hier im Forum, Uneinigkeiz zu geben leche Firmware denn die geegnete ist...
@arteck Deswegen ja mein Satz "Ist aber wohl in dieser Preisklasse nicht zu erwarten, dass der Händler da vor dem Versenden noch einmal Hand anlegt...."
Bei einem Auto sähe das anders aus ... Da erwarte ich, dass der aktuelle Stand aller Bordsoftware vor Übergabe an mich durch den Händler aufgespielt ist .... auch wenn das ein Wagen ist, der schon einige Zeit beim Händler herumstand ("Tageszulassung").
Aber selbst bei einem Notebook für um die 1000 € fängt man ja erstmal an, Updates einzuspielen, nachdem man ihn ausgepackt hat .... -
ja weil es da gerade probleme gibt.. steht auch im Forum
Hallo, würde auf den ersten Blick sagen das wir identische Konfiguration haben... was könnte dann dann noch das Problem sein?
Es war in der Tat die Firmwareversion des Zigbee Sticks. Hat mich etwas Mühe gekostet, aber nun klappt es.
