    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id
    • N
      n811e @Thomas Braun last edited by
      ok, habe ich so gemacht
      Zigbee bleibt aber auch nach einem Neustart Gelb 😕
        Thomas Braun Most Active @n811e last edited by
        @n811e
        Dann zeig mal einen Kaltstart der Instanz.
        Und die aktuelle Ausgabe von
        iob diag
        N 2 Replies Last reply Reply Quote 0
        • N
          n811e @Thomas Braun last edited by Homoran
          @thomas-braun said in USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id:
          iob diag
          da kommt folgendes raus:
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
                    Kernel: Linux 6.1.21-v7l+
              Architecture: arm
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : armhf
          Systemuptime and Load:
           21:17:24 up 52 min,  2 users,  load average: 1.87, 1.77, 1.70
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Tue 2024-01-30 21:17:25 CET
                     Universal time: Tue 2024-01-30 20:17:25 UTC
                           RTC time: Tue 2024-01-30 20:17:25
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            8.3G        2.4G        5.7G        1.0M        355M        5.8G
          Swap:           104M          0B        104M
          Total:          8.4G        2.4G        5.8G
                   7898 M total memory
                   2320 M used memory
                    106 M active memory
                   2196 M inactive memory
                   5464 M free memory
                     32 M buffer memory
                    306 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4      117G  8.0G  105G   8% /
          devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     1.6G  912K  1.6G   1% /run
          /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
          tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
          [Tue Jan 30 20:24:31 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CB:3B:DC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=4927e89a-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Tue Jan 30 20:24:32 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Tue Jan 30 20:24:32 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Tue Jan 30 20:24:36 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
          /var:
          2.0G    /var/
          1.1G    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
          1.1G    /var/log
          709M    /var/lib
          Archived and active journals take up 1.0G in the file system.
          /opt/iobroker/backups:
          93M     /opt/iobroker/backups/
          4.0K    /opt/iobroker/backups/redistmp
          /opt/iobroker/iobroker-data:
          477M    /opt/iobroker/iobroker-data/
          317M    /opt/iobroker/iobroker-data/files
          102M    /opt/iobroker/iobroker-data/backup-objects
          67M     /opt/iobroker/iobroker-data/files/javascript.admin
          48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
          34M     /opt/iobroker/iobroker-data/objects.jsonl
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
          25M     /opt/iobroker/iobroker-data/states.jsonl
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_46f93a68f7d8eb11893d0815b9da5f8b-if00-port0
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          /usr/bin/corepack       0.22.0
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org/debian-security bookworm-security/main armhf Packages
           *** 18.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0+dfsg1-1 500
                  500 http://deb.debian.org/debian bookworm/main armhf Packages
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.17
          admin:          6.12.0
          javascript:     7.1.6
          Adapters from github:   1
          Adapter State
          + system.adapter.admin.3                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
          + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
          + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
          + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
          + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
          + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
          + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          + system.adapter.klf200.0                 : klf200                : raspberrypi                              -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
          + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
          + system.adapter.omada.0                  : omada                 : raspberrypi                              -  enabled, port: 443
          + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
          + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
          + system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
          + system.adapter.samsung_tizen.0          : samsung_tizen         : raspberrypi                              -  enabled, port: 8002
          + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
          + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
          + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
          + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
          + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
            system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
            system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
          + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
          + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_46f93a68f7d8eb11893d0815b9da5f8b-if00-port0
            system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              - disabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.13.15  , installed 6.12.0 [Updatable]
          Adapter    "alexa2"       : 3.26.4   , installed 3.26.3 [Updatable]
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Adapter    "device-watcher": 2.9.6   , installed 2.9.6
          Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
          Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
          Adapter    "hm-rpc"       : 1.16.0   , installed 1.15.19 [Updatable]
          Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "klf200"       : 1.1.2    , installed 1.1.2
          Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
          Adapter    "onvif"        : 1.1.1    , installed 1.1.1
          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
          Adapter    "samsung"      : 0.5.11   , installed 0.5.11
          Adapter    "samsung_tizen": 1.0.0    , installed 1.0.0
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "synology"     : 3.0.1    , installed 3.0.1
          Adapter    "tuya"         : 3.15.0   , installed 3.15.0
          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
          Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
          Adapter    "web"          : 6.2.3    , installed 6.1.10 [Updatable]
          Adapter    "wled"         : 0.7.2    , installed 0.7.2
          Adapter    "worx"         : 2.3.4    , installed 2.3.4
          Adapter    "ws"           : 2.5.10   , installed 2.5.8  [Updatable]
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
          Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
          Objects and States
          Objects:        19613
          States:         15311
          Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
          Hit:2 http://deb.debian.org/debian bookworm InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       19220      2620/io.mqtt.0
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19188      2568/io.shelly.1
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       21636      2483/io.sonoff.0
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17641      964/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17653      964/iobroker.js-con
          tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14899      1035/dnsmasq
          tcp        0      0 192.168.2.113:9292      0.0.0.0:*               LISTEN      1001       18414      2281/io.hm-rpc.2
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       24624      2907/io.jarvis.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17410      1024/sshd: /usr/sbi
          tcp        0      0 192.168.2.113:12010     0.0.0.0:*               LISTEN      1001       17407      2232/io.hm-rpc.1
          tcp        0      0 192.168.2.113:12001     0.0.0.0:*               LISTEN      1001       19532      2200/io.hm-rpc.0
          tcp6       0      0 :::8095                 :::*                    LISTEN      1001       23137      3015/io.onvif.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21252      2795/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17072      1811/io.admin.3
          tcp6       0      0 :::8000                 :::*                    LISTEN      1001       25799      2868/io.upnp.0
          tcp6       0      0 :::46799                :::*                    LISTEN      1001       20335      2808/io.yahka.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          17412      1024/sshd: /usr/sbi
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23644      2949/io.wled.0
          udp        0      0 192.168.2.113:5353      0.0.0.0:*                           1001       20016      2512/io.tr-064.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12028      403/avahi-daemon: r
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       21502      2868/io.upnp.0
          udp        0      0 0.0.0.0:35724           0.0.0.0:*                           1001       23568      2868/io.upnp.0
          udp        0      0 0.0.0.0:40457           0.0.0.0:*                           108        12030      403/avahi-daemon: r
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       21897      2633/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       21898      2633/io.tuya.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       20629      2412/io.shelly.0
          udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14898      1035/dnsmasq
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14895      1035/dnsmasq
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          909        846/dhclient
          udp6       0      0 :::51412                :::*                                108        12031      403/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        12029      403/avahi-daemon: r
          2024-01-30 21:14:11.605  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
          2024-01-30 21:14:11.628  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
          2024-01-30 21:14:39.489  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
          2024-01-30 21:15:06.296  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
          2024-01-30 21:15:06.325  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
          2024-01-30 21:15:09.499  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
          2024-01-30 21:15:15.639  - info: tr-064.0 (2512) forEachConfiguredDevice: in GetSpecificHostEntry 13(fritz.box/08:96:D7:8B:8C:54) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
          2024-01-30 21:15:39.543  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
          2024-01-30 21:16:02.990  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
          2024-01-30 21:16:03.009  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
          2024-01-30 21:16:09.575  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
          2024-01-30 21:16:39.565  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
          2024-01-30 21:16:47.975  - info: tr-064.0 (2512) forEachConfiguredDevice: in GetSpecificHostEntry 13(fritz.box/08:96:D7:8B:8C:54) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
          2024-01-30 21:16:59.510  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
          2024-01-30 21:16:59.532  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
          2024-01-30 21:17:09.594  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
          2024-01-30 21:17:39.602  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
          2024-01-30 21:17:56.062  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
          2024-01-30 21:17:56.088  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
          2024-01-30 21:18:09.613  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
          2024-01-30 21:18:19.159  - info: tr-064.0 (2512) forEachConfiguredDevice: in GetSpecificHostEntry 13(fritz.box/08:96:D7:8B:8C:54) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
          2024-01-30 21:18:39.618  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
          2024-01-30 21:18:55.875  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
          2024-01-30 21:18:55.894  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
          2024-01-30 21:19:09.575  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
          iob diag has finished.
          Press any key for a summary
          • N
            Copy text starting here:
                                    v.2023-10-10
                   Icon name: computer
                Architecture: arm
            Installation:           native
            Kernel:                 armv7l
            Userland:               armhf
            Timezone:               Europe/Berlin (CET, +0100)
            User-ID:                1000
            X-Server:               false
            Boot Target:            graphical.target
            Pending OS-Updates:     0
            Pending iob updates:    5
            Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
            Recommended versions are nodejs 18.19.0 and npm 10.2.3
            MEMORY:
            Mem:            8.3G        2.5G        5.6G        1.0M        472M        5.8G
            Swap:           104M          0B        104M
            Total:          8.4G        2.5G        5.7G
            Active iob-Instances:   40
            ioBroker Core:          js-controller           5.0.17
                                    admin                   6.12.0
            Objects type: jsonl
            States  type: jsonl
            Objects:                19613
            States:                 15311
            Size of iob-Database:
            4.1M    /opt/iobroker/iobroker-data/states.jsonl
            === Mark text until here for copying ===
              @n811e
              Und der Adapter 'Kaltstart' sieht im Log wie aus?
              Instanz stoppen,
              iob logs --watch | uniq
              anschauen, Instanz wieder starten.
              • N
                Was soll ich denn alles kopieren, nachdem ich iob logs --watch | uniq eingegeben habe?
                Der hört ja nie auf, oder wie verstehe ich das?
                  Homoran Global Moderator Administrators @n811e last edited by
                  @n811e den Start der Instanz, die du extra vorher gestoppt hast
                    @n811e sagte in USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id:
                    Mit Strg-C hört 'der' auch wieder auf das Log anzuzeigen.
                    • N
                      So, jetzt habe ichs:
                      2024-01-31 20:02:23.295  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                      2024-01-31 20:02:24.689  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 17095
                      2024-01-31 20:02:37.047  - info: zigbee.0 (17095) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                      2024-01-31 20:02:37.259  - info: zigbee.0 (17095) delete old Backup files. keep only last 10
                      2024-01-31 20:02:37.265  - info: zigbee.0 (17095) Starting Zigbee  npm ...
                      2024-01-31 20:02:38.106  - info: zigbee.0 (17095) Installed Version: iobroker.zigbee@1.10.1
                      2024-01-31 20:03:44.528  - error: zigbee.0 (17095) Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
                      2024-01-31 20:03:44.531  - error: zigbee.0 (17095) Failed to start Zigbee
                      2024-01-31 20:03:44.532  - error: zigbee.0 (17095) Error herdsman start
                      • Meister Mopper
                        Meister Mopper @n811e last edited by
                        Versuch doch mal eine andere PanId, offenbar funkt da noch ein anderes Netzwerk in deinen Bereich.
                        Kann sein, dass du anschließend alles neu anlernen musst.
                        • N
                          n811e @Meister Mopper last edited by
                          @meister-mopper
                          Das ist ja verrückt!!! Das klappt jetzt wieder. Damit hätte ich nicht gerechnet.
                          Vielen Dank an alle, insbesondere @thomas-braun für die viele Mühe, die ihr euch gemacht habt.
                          Dankeschön
                          • N
                            @meister-mopper @thomas-braun
                            Leider wieder am selben Punkt 😕
                            2024-02-01 14:04:36.400  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                            2024-02-01 14:04:37.659  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 26738
                            2024-02-01 14:04:46.093  - info: zigbee.0 (26738) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                            2024-02-01 14:04:46.235  - info: zigbee.0 (26738) delete old Backup files. keep only last 10
                            2024-02-01 14:04:46.239  - info: zigbee.0 (26738) Starting Zigbee  npm ...
                            2024-02-01 14:04:46.707  - info: zigbee.0 (26738) Installed Version: iobroker.zigbee@1.10.1
                            2024-02-01 14:04:47.197  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:falseWert:system.adapter.shelly.1bestätigt:true
                            2024-02-01 14:04:47.679  - error: zigbee.0 (26738) Configuration is not consistent with adapter state/backup!
                            2024-02-01 14:04:47.679  - error: zigbee.0 (26738) - PAN ID: configured=6557, adapter=6556
                            2024-02-01 14:04:47.680  - error: zigbee.0 (26738) - Extended PAN ID: configured=ddd3dddfddddaddd, adapter=ddd3dddfddddaddd
                            2024-02-01 14:04:47.681  - error: zigbee.0 (26738) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                            2024-02-01 14:04:47.682  - error: zigbee.0 (26738) - Channel List: configured=11, adapter=11
                            2024-02-01 14:04:47.683  - error: zigbee.0 (26738) Please update configuration to prevent further issues.
                            2024-02-01 14:04:47.684  - error: zigbee.0 (26738) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                            2024-02-01 14:04:47.685  - error: zigbee.0 (26738) Re-commissioning your network will require re-pairing of all devices!
                            2024-02-01 14:04:47.814  - error: zigbee.0 (26738) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                            2024-02-01 14:04:47.814  - error: zigbee.0 (26738) Failed to start Zigbee
                            2024-02-01 14:04:47.816  - error: zigbee.0 (26738) Error herdsman start
                            2024-02-01 14:04:57.822  - info: zigbee.0 (26738) Try to reconnect. 1 attempts left
                            2024-02-01 14:04:57.823  - info: zigbee.0 (26738) Starting Zigbee  npm ...
                            2024-02-01 14:04:57.841  - info: zigbee.0 (26738) Installed Version: iobroker.zigbee@1.10.1
                            2024-02-01 14:04:58.109  - error: zigbee.0 (26738) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                            2024-02-01 14:04:58.112  - error: zigbee.0 (26738) Failed to start Zigbee
                            2024-02-01 14:04:58.112  - error: zigbee.0 (26738) Error herdsman start
                              Die Werte müssen übereinstimmen.
                              • N
                                die PAN ID, stelle ich ja unter Einstellungen ein, aber wo kann ich den Wert für den Adapter ändern?
                                  @n811e
                                  ? Gar nicht. Aber die PAN-Id in den Einstellungen muss auf den Wert im Adapter geändert werden.
                                    e-i-k-e @Thomas Braun last edited by e-i-k-e
                                    Ich habe leider auch das problem mit
                                    ls: cannot access '/dev/serial/by-ids': No such file or directory
                                    Ich ziehe gerade mit iobroker um und habe iob neu auf ubuntu 22.04 installiert und anschließend ein iob backup eingespielt.
                                    Ausgang von iob diag lautet:
                                    ========== Start marking the full check here ===========
                                    ```bash
                                    Script v.2024-10-19
                                    *** BASE SYSTEM ***
                                     Static hostname: iobroker
                                           Icon name: computer-vm
                                             Chassis: vm 🖴
                                      Virtualization: kvm
                                    Operating System: Ubuntu 24.04.1 LTS
                                              Kernel: Linux 6.8.0-50-generic
                                        Architecture: x86-64
                                     Hardware Vendor: QEMU
                                      Hardware Model: Standard PC _i440FX + PIIX, 1996_
                                    Firmware Version: 4.2023.08-4
                                       Firmware Date: Thu 2024-02-15
                                        Firmware Age: 9month 3w 6d
                                    OS is similar to: debian
                                    model name      : Common KVM processor
                                    Docker          : false
                                    Virtualization  : kvm
                                    Kernel          : x86_64
                                    Userland        : 64 bit
                                     23:59:11 up 21 min,  1 user,  load average: 0.53, 0.40, 0.45
                                    CPU threads: 8
                                    *** LIFE CYCLE STATUS ***
                                    Operating System is the current Ubuntu LTS release codenamed 'noble'!
                                    *** TIME AND TIMEZONES ***
                                                   Local time: Wed 2024-12-11 23:59:11 CET
                                               Universal time: Wed 2024-12-11 22:59:11 UTC
                                                     RTC time: Wed 2024-12-11 22:59:10
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** Users and Groups ***
                                    User that called 'iob diag':
                                    pi
                                    HOME=/home/pi
                                    GROUPS=pi sudo users iobroker
                                    iobroker
                                    HOME=/home/iobroker
                                    GROUPS=iobroker tty dialout audio video plugdev
                                    *** DISPLAY-SERVER SETUP ***
                                    Display-Server: false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:             10G        3.0G        6.9G        5.3M        846M        7.5G
                                    Swap:             0B          0B          0B
                                    Total:           10G        3.0G        6.9G
                                    Active iob-Instances:   58
                                             9938 M total memory
                                             2820 M used memory
                                             2578 M active memory
                                              460 M inactive memory
                                             6572 M free memory
                                               54 M buffer memory
                                              752 M swap cache
                                                0 M total swap
                                                0 M used swap
                                                0 M free swap
                                    top - 23:59:11 up 21 min,  1 user,  load average: 0.53, 0.40, 0.45
                                    Tasks: 179 total,   1 running, 178 sleeping,   0 stopped,   0 zombie
                                    %Cpu(s): 20.5 us,  4.5 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                    MiB Mem :   9938.9 total,   6572.1 free,   2820.9 used,    807.5 buff/cache
                                    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   7118.0 avail Mem
                                    *** DMESG CRITICAL ERRORS ***
                                    No critical errors detected
                                    *** FILESYSTEM ***
                                    tmpfs          tmpfs     994M  1.1M  993M   1% /run
                                    efivarfs       efivarfs  256K   20K  232K   8% /sys/firmware/efi/efivars
                                    /dev/sda1      ext4       51G  6.8G   45G  14% /
                                    tmpfs          tmpfs     4.9G     0  4.9G   0% /dev/shm
                                    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                                    /dev/sda16     ext4      881M  112M  708M  14% /boot
                                    /dev/sda15     vfat      105M  6.1M   99M   6% /boot/efi
                                    tmpfs          tmpfs     994M   12K  994M   1% /run/user/0
                                    [Wed Dec 11 23:38:08 2024] EXT4-fs (sda1): mounted filesystem 428c45af-c748-4f29-9fe5-d56aa4a3f75e ro with ordered data mode. Quota mode: none.
                                    [Wed Dec 11 23:38:09 2024] EXT4-fs (sda1): re-mounted 428c45af-c748-4f29-9fe5-d56aa4a3f75e r/w. Quota mode: none.
                                    [Wed Dec 11 23:38:11 2024] EXT4-fs (sda16): mounted filesystem a4ce610e-4a3c-4ed2-8852-b138eade5b0b r/w with ordered data mode. Quota mode: none.
                                    Show mounted filesystems:
                                    /             /dev/sda1  ext4   rw,relatime,discard,errors=remount-ro,commit=30
                                    `-/boot       /dev/sda16 ext4   rw,relatime
                                      `-/boot/efi /dev/sda15 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
                                    /var:
                                    687M    /var/
                                    344M    /var/cache
                                    314M    /var/cache/apt
                                    216M    /var/cache/apt/archives
                                    199M    /var/lib
                                    Archived and active journals take up 19.2M in the file system.
                                    27M     /opt/iobroker/backups/
                                    213M    /opt/iobroker/iobroker-data/
                                    176M    /opt/iobroker/iobroker-data/files
                                    158M    /opt/iobroker/iobroker-data/files/admin.admin
                                    157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                    36M     /opt/iobroker/iobroker-data/objects.jsonl
                                    7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
                                    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
                                    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
                                    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
                                    USB-Devices by-id:
                                    No Devices found 'by-id'
                                    HINT:
                                    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                    /dev/ttyACM0
                                    /usr/bin/nodejs         v20.18.1
                                    /usr/bin/node           v20.18.1
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    /usr/bin/corepack       0.29.4
                                    nodejs:
                                      Installed: 20.18.1-1nodesource1
                                      Candidate: 20.18.1-1nodesource1
                                      Version table:
                                     *** 20.18.1-1nodesource1 1001
                                            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                         20.18.0-1nodesource1 1001
                                         20.17.0-1nodesource1 1001
                                         20.16.0-1nodesource1 1001
                                         20.15.1-1nodesource1 1001
                                         20.15.0-1nodesource1 1001
                                         20.14.0-1nodesource1 1001
                                         20.13.1-1nodesource1 1001
                                         20.13.0-1nodesource1 1001
                                         20.12.2-1nodesource1 1001
                                         20.12.1-1nodesource1 1001
                                         20.12.0-1nodesource1 1001
                                         20.11.1-1nodesource1 1001
                                         20.11.0-1nodesource1 1001
                                         20.10.0-1nodesource1 1001
                                         20.9.0-1nodesource1 1001
                                         20.8.1-1nodesource1 1001
                                         20.8.0-1nodesource1 1001
                                         20.7.0-1nodesource1 1001
                                         20.6.1-1nodesource1 1001
                                         20.6.0-1nodesource1 1001
                                         20.5.1-1nodesource1 1001
                                         20.5.0-1nodesource1 1001
                                         20.4.0-1nodesource1 1001
                                         20.3.1-1nodesource1 1001
                                         20.3.0-1nodesource1 1001
                                         20.2.0-1nodesource1 1001
                                         20.1.0-1nodesource1 1001
                                         20.0.0-1nodesource1 1001
                                         18.19.1+dfsg-6ubuntu5 500
                                            500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
                                    Errors in npm tree: 0
                                    ioBroker Status
                                    At least one iobroker host is running.
                                    Objects type: redis
                                    States  type: redis
                                    Hosts:
                                    ioBroker-Rock       ioBroker-Rock (version: 7.0.6, hostname: ioBroker-Rock , alive, uptime: 1247)
                                    raspberrypi-display1 raspberrypi-display1 (version: 7.0.2, hostname: raspberrypi-display1, alive, uptime: 1231)
                                    raspberrypi-display2 raspberrypi-display2 (version: 7.0.2, hostname: raspberrypi-display2, alive, uptime: 1233)
                                    raspberrypi-display3 raspberrypi-display3 (version: 4.0.24, hostname: raspberrypi-display3, alive, uptime: 1237)
                                    raspberrypi-display4 raspberrypi-display4 (version: 5.0.19, hostname: raspberrypi-display4, alive, uptime: 1239)
                                    raspberrypi-display5 raspberrypi-display5 (version: 7.0.2, hostname: raspberrypi-display5, alive, uptime: 1239)
                                    raspberrypi-slave   raspberrypi-slave (version: 5.0.8, hostname: raspberrypi-slave, alive, uptime: 1235)
                                    js-controller:  7.0.6
                                    admin:          7.4.4
                                    javascript:     8.8.3
                                    nodejs modules from github:     3
                                    +-- iobroker.energiefluss-erweitert@0.6.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#a898e0cd728900620b9bfea0f1710d8720ebf82f)
                                    | +-- node-milight-promise@0.3.2 (git+ssh://git@github.com/Steiger04/node-milight-promise.git#f1089feac9b7990727adf2016891029436729d33)
                                    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                                    Adapter State
                                    + system.adapter.admin.2                  : admin                 : ioBroker-Rock                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                    + system.adapter.admin.3                  : admin                 : ioBroker-Rock                            -  enabled, port: 8900, bind: 0.0.0.0, run as: admin
                                    + system.adapter.alarm.0                  : alarm                 : ioBroker-Rock                            -  enabled
                                    + system.adapter.alexa2.0                 : alexa2                : ioBroker-Rock                            -  enabled
                                      system.adapter.backitup.0               : backitup              : ioBroker-Rock                            - disabled
                                    + system.adapter.cloud.0                  : cloud                 : ioBroker-Rock                            -  enabled
                                      system.adapter.daswetter.0              : daswetter             : ioBroker-Rock                            -  enabled
                                    + system.adapter.device-reminder.0        : device-reminder       : ioBroker-Rock                            -  enabled
                                    + system.adapter.device-watcher.0         : device-watcher        : ioBroker-Rock                            -  enabled
                                    + system.adapter.discovergy.0             : discovergy            : ioBroker-Rock                            -  enabled
                                      system.adapter.discovery.0              : discovery             : ioBroker-Rock                            - disabled
                                      system.adapter.dwd.0                    : dwd                   : ioBroker-Rock                            -  enabled
                                    + system.adapter.echarts.0                : echarts               : ioBroker-Rock                            -  enabled
                                    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker-Rock                            -  enabled
                                      system.adapter.feiertage.0              : feiertage             : ioBroker-Rock                            -  enabled
                                      system.adapter.flot.0                   : flot                  : ioBroker-Rock                            -  enabled
                                    + system.adapter.hass.0                   : hass                  : ioBroker-Rock                            -  enabled, port: 8123
                                    + system.adapter.heatingcontrol.1         : heatingcontrol        : ioBroker-Rock                            -  enabled
                                    + system.adapter.hm-rega.0                : hm-rega               : ioBroker-Rock                            -  enabled
                                    + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
                                    + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
                                    + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
                                      system.adapter.hoover.0                 : hoover                : ioBroker-Rock                            - disabled
                                      system.adapter.ical.0                   : ical                  : ioBroker-Rock                            -  enabled
                                      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker-Rock                            -  enabled
                                      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-Rock                            -  enabled
                                      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-Rock                            -  enabled
                                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-Rock                            -  enabled
                                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-Rock                            -  enabled
                                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-Rock                            -  enabled
                                    + system.adapter.influxdb.0               : influxdb              : ioBroker-Rock                            -  enabled, port: 8086
                                    + system.adapter.javascript.0             : javascript            : ioBroker-Rock                            -  enabled
                                    + system.adapter.javascript.2             : javascript            : raspberrypi-display1                     -  enabled
                                    + system.adapter.javascript.3             : javascript            : raspberrypi-display4                     -  enabled
                                    + system.adapter.javascript.4             : javascript            : raspberrypi-display2                     -  enabled
                                    + system.adapter.javascript.5             : javascript            : raspberrypi-display5                     -  enabled
                                    + system.adapter.midea.0                  : midea                 : ioBroker-Rock                            -  enabled
                                      system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-Rock                            - disabled, port: 54321, bind: 0.0.0.0
                                      system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker-Rock                            - disabled, port: 54321, bind: 0.0.0.0
                                    + system.adapter.mihome.0                 : mihome                : ioBroker-Rock                            -  enabled, port: 9898, bind: 192.168.3.100
                                    + system.adapter.milight-smart-light.0    : milight-smart-light   : ioBroker-Rock                            -  enabled
                                    + system.adapter.modbus.0                 : modbus                : ioBroker-Rock                            -  enabled
                                      system.adapter.mqtt-client.0            : mqtt-client           : ioBroker-Rock                            - disabled, port: 1883
                                    + system.adapter.mqtt.0                   : mqtt                  : ioBroker-Rock                            -  enabled, port: 1886, bind: 0.0.0.0
                                    + system.adapter.musiccast.0              : musiccast             : ioBroker-Rock                            -  enabled
                                    + system.adapter.nut.0                    : nut                   : ioBroker-Rock                            -  enabled
                                      system.adapter.openweathermap.0         : openweathermap        : ioBroker-Rock                            -  enabled
                                    + system.adapter.proxmox.0                : proxmox               : ioBroker-Rock                            -  enabled, port: 8006
                                    + system.adapter.rpi2.1                   : rpi2                  : raspberrypi-display1                     -  enabled
                                    + system.adapter.rpi2.2                   : rpi2                  : raspberrypi-display2                     -  enabled
                                    + system.adapter.rpi2.3                   : rpi2                  : raspberrypi-display3                     -  enabled
                                    + system.adapter.rpi2.4                   : rpi2                  : raspberrypi-display4                     -  enabled
                                    + system.adapter.rpi2.5                   : rpi2                  : raspberrypi-display5                     -  enabled
                                    + system.adapter.sainlogic.0              : sainlogic             : ioBroker-Rock                            -  enabled, port: 45000, bind: 192.168.3.100
                                    + system.adapter.scenes.0                 : scenes                : ioBroker-Rock                            -  enabled
                                    + system.adapter.shelly.0                 : shelly                : ioBroker-Rock                            -  enabled, port: 1890, bind: 0.0.0.0
                                    + system.adapter.shelly.1                 : shelly                : ioBroker-Rock                            -  enabled, port: 1899, bind: 0.0.0.0
                                    + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker-Rock                            -  enabled
                                      system.adapter.simple-api.0             : simple-api            : ioBroker-Rock                            - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                                    + system.adapter.smartcontrol.0           : smartcontrol          : ioBroker-Rock                            -  enabled
                                    + system.adapter.smartmeter.0             : smartmeter            : ioBroker-Rock                            -  enabled
                                    + system.adapter.sonoff.0                 : sonoff                : ioBroker-Rock                            -  enabled, port: 1883, bind: 0.0.0.0
                                    + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker-Rock                            -  enabled
                                      system.adapter.sprinklecontrol.0        : sprinklecontrol       : ioBroker-Rock                            - disabled
                                    + system.adapter.statistics.0             : statistics            : ioBroker-Rock                            -  enabled
                                    + system.adapter.synology.0               : synology              : ioBroker-Rock                            -  enabled, port: 5001
                                    + system.adapter.telegram.0               : telegram              : ioBroker-Rock                            -  enabled, port: 8443, bind: 0.0.0.0
                                    + system.adapter.text2command.0           : text2command          : ioBroker-Rock                            -  enabled
                                      system.adapter.unifi.0                  : unifi                 : ioBroker-Rock                            - disabled
                                      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker-Rock                            -  enabled
                                      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioBroker-Rock                            -  enabled
                                      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker-Rock                            -  enabled
                                    + system.adapter.vis-2.0                  : vis-2                 : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-bars.0               : vis-bars              : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-history.0            : vis-history           : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker-Rock                            -  enabled
                                    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-material.0           : vis-material          : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-metro.0              : vis-metro             : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-players.0            : vis-players           : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-plumb.0              : vis-plumb             : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-Rock                            -  enabled
                                      system.adapter.vis-weather.0            : vis-weather           : ioBroker-Rock                            -  enabled
                                      system.adapter.vis.0                    : vis                   : ioBroker-Rock                            -  enabled
                                    + system.adapter.vw-connect.0             : vw-connect            : ioBroker-Rock                            -  enabled
                                      system.adapter.web-speedy.0             : web-speedy            : ioBroker-Rock                            - disabled
                                    + system.adapter.web.0                    : web                   : ioBroker-Rock                            -  enabled, port: 8082, bind: 192.168.3.100 (SSL), run as: admin
                                    + system.adapter.web.1                    : web                   : ioBroker-Rock                            -  enabled, port: 8083, bind: 192.168.3.100, run as: admin
                                    + system.adapter.wolf-smartset.0          : wolf-smartset         : ioBroker-Rock                            -  enabled
                                      system.adapter.worx.0                   : worx                  : ioBroker-Rock                            - disabled
                                    + system.adapter.yamaha.0                 : yamaha                : ioBroker-Rock                            -  enabled
                                    + system.adapter.yeelight-2.0             : yeelight-2            : ioBroker-Rock                            -  enabled
                                      system.adapter.yr.0                     : yr                    : ioBroker-Rock                            -  enabled
                                    + system.adapter.zigbee.0                 : zigbee                : ioBroker-Rock                            -  enabled, port: /dev/ttyACM0
                                    + instance is alive
                                    Active repo(s): beta
                                    Upgrade policy: none
                                    Used repository: beta
                                    Adapter    "admin"        : 7.4.4    , installed 7.4.4
                                    Adapter    "alarm"        : 3.6.4    , installed 3.6.4
                                    Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
                                    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                                    Adapter    "daswetter"    : 3.2.1    , installed 3.2.1
                                    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                                    Adapter    "discovergy"   : 0.5.13   , installed 0.5.13
                                    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                                    Adapter    "energiefluss-erweitert": 0.6.0, installed 0.6.0
                                    Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                                    Adapter    "hass"         : 1.4.0    , installed 1.4.0
                                    Adapter    "heatingcontrol": 2.12.13 , installed 2.12.13
                                    Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                                    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                    Adapter    "hoover"       : 0.1.3    , installed 0.1.3
                                    Adapter    "ical"         : 1.16.1   , installed 1.16.1
                                    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                    Controller "js-controller": 7.0.6    , installed 7.0.6
                                    Adapter    "midea"        : 0.0.7    , installed 0.0.7
                                    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                    Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                                    Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
                                    Adapter    "modbus"       : 6.4.0    , installed 6.4.0
                                    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                    Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
                                    Adapter    "musiccast"    : 1.1.4    , installed 1.1.4
                                    Adapter    "nut"          : 1.6.0    , installed 1.6.0
                                    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                                    Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                                    Adapter    "sainlogic"    : 0.11.4   , installed 0.11.4
                                    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                                    Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                                    Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
                                    Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                                    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                                    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                    Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                                    Adapter    "statistics"   : 3.1.0    , installed 3.1.0
                                    Adapter    "synology"     : 3.1.0    , installed 3.1.0
                                    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                    Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                                    Adapter    "vis-2"        : 2.11.1   , installed 2.11.1
                                    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                                    Adapter    "vis-2-widgets-gauges": 1.1.1, installed 1.1.1
                                    Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
                                    Adapter    "vis-2-widgets-jaeger-design": 1.3.9, installed 1.3.9
                                    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                                    Adapter    "vis-icontwo"  : 1.10.1   , installed 1.10.1
                                    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                                    Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                                    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                                    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                    Adapter    "vw-connect"   : 0.6.1    , installed 0.6.1
                                    Adapter    "web"          : 6.3.1    , installed 6.3.1
                                    Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
                                    Adapter    "wolf-smartset": 1.2.3    , installed 1.2.3
                                    Adapter    "worx"         : 3.1.1    , installed 3.1.1
                                    Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                    Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
                                    Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
                                    Adapter    "yr"           : 5.3.0    , installed 5.3.0
                                    Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
                                    Objects and States
                                    Objects:        39194
                                    States:         36289
                                    Hit:1 http://archive.ubuntu.com/ubuntu noble InRelease
                                    Hit:2 http://archive.ubuntu.com/ubuntu noble-updates InRelease
                                    Hit:3 http://archive.ubuntu.com/ubuntu noble-backports InRelease
                                    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                    Hit:5 http://security.ubuntu.com/ubuntu noble-security InRelease
                                    Pending Updates: 0
                                    tcp        0      0 192.168.3.100:2010      0.0.0.0:*               LISTEN      1001       11540      1563/io.hm-rpc.2
                                    tcp        0      0 192.168.3.100:2001      0.0.0.0:*               LISTEN      1001       9811       1487/io.hm-rpc.0
                                    tcp        0      0 192.168.3.100:8701      0.0.0.0:*               LISTEN      1001       11703      1683/io.hm-rpc.1
                                    tcp        0      0 192.168.3.100:45000     0.0.0.0:*               LISTEN      1001       12502      1752/io.sainlogic.0
                                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          715        1/init
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8188       1273/io.sonoff.0
                                    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       10687      1373/io.mqtt.0
                                    tcp        0      0 0.0.0.0:1899            0.0.0.0:*               LISTEN      1001       11519      1548/io.shelly.1
                                    tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      991        6774       633/systemd-resolve
                                    tcp        0      0 192.168.3.100:8083      0.0.0.0:*               LISTEN      1001       13321      1917/io.web.1
                                    tcp        0      0 192.168.3.100:8082      0.0.0.0:*               LISTEN      1001       12687      1977/io.web.0
                                    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      991        6772       633/systemd-resolve
                                    tcp6       0      0 :::8900                 :::*                    LISTEN      1001       8070       1089/io.admin.3
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          8316       1/init
                                    tcp6       0      0 :::111                  :::*                    LISTEN      0          3605       1/init
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8885       973/io.admin.2
                                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11624      1638/io.shelly.0
                                    udp        0      0 0.0.0.0:47970           0.0.0.0:*                           1001       11834      1812/io.milight-sma
                                    udp        0      0 127.0.0.54:53           0.0.0.0:*                           991        6773       633/systemd-resolve
                                    udp        0      0 127.0.0.53:53           0.0.0.0:*                           991        6771       633/systemd-resolve
                                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          716        1/init
                                    udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       10200      1868/io.musiccast.0
                                    udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       11644      1653/io.mihome.0
                                    udp6       0      0 :::111                  :::*                                0          717        1/init
                                      port: 80
                                    2024-12-11 23:59:05.006  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                    2024-12-11 23:59:07.010  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                    2024-12-11 23:59:09.012  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                    2024-12-11 23:59:10.542  - info: influxdb.0 (1202) Store 272 buffered influxDB history points
                                    2024-12-11 23:59:11.015  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                    2024-12-11 23:59:13.018  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                    2024-12-11 23:59:15.019  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                    2024-12-11 23:59:17.022  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                    2024-12-11 23:59:19.024  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                    2024-12-11 23:59:21.027  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                    2024-12-11 23:59:23.030  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                    2024-12-11 23:59:25.031  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                    2024-12-11 23:59:27.034  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                    2024-12-11 23:59:29.036  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                    2024-12-11 23:59:31.039  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                    2024-12-11 23:59:33.041  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                    2024-12-11 23:59:35.044  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                    2024-12-11 23:59:37.046  - warn: smartmeter.0 (1333) No or too long answer from Serial D
                                    ```bash
                                                            v.2024-10-19
                                             Chassis: vm 🖴
                                      Virtualization: kvm
                                    Installation:           kvm
                                    Kernel:                 x86_64
                                    Userland:               64 bit
                                    User-ID:                1000
                                    Boot Target:            multi-user.target
                                    Pending iob updates:    0
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    Recommended versions are nodejs  and npm
                                    nodeJS installation is correct
                                    MEMORY:
                                    Mem:             10G        3.0G        6.6G        5.3M        1.1G        7.4G
                                    Swap:             0B          0B          0B
                                    Total:           10G        3.0G        6.6G
                                    ioBroker Core:          js-controller           7.0.6
                                                            admin                   7.4.4
                                    Objects type: redis
                                    States  type: redis
                                    Objects:                39194
                                    States:                 36289
                                    768K    /opt/iobroker/iobroker-data/states.jsonl
                                      Thomas Braun Most Active @e-i-k-e last edited by
                                      @e-i-k-e sagte in USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id:
                                      Virtualization: kvm
                                      Der Stick muss an die VM durchgereicht werden.
                                      Setz den user in die Gruppe adm rein. Und warum nennt man den user überhaupt ``pi`? Ist doch nicht mal ein Raspberry...
                                      Und bring den Versions-Zoo bei den ganzen hosts auf den gleichen aktuellen Stand.
                                        @thomas-braun sagte in USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id:
                                        Virtualization: kvm
                                        Die sind über Proxmox durchgereicht, werden über lsusb in der VM auch angezeigt.
                                        Kann ich machen, der User pi ist historisch mitgewandert.
                                        Hat das mit der Gruppe adm, denn etwas mit meinem "ls: cannot access '/dev/serial/by-ids': No such file or directory" zutun? Oder wofür wird dies benötigt?
                                        Wird nach und nach, leider sind einige Distribution so alt, dass ein update nicht ohne weiteres mehr möglich ist.
                                          Dann haste da viel zu lange gepennt.
                                          Die Gruppe adm wird für administrative Dinge benötigt. Unter anderem um logfiles auch ohne root-Rechte lesen zu können.
                                          E 2 Replies Last reply Reply Quote 0
                                            Da muss ich dir recht geben 😉
                                            1.0k
                                            14847
