    3. Entwicklung
    4. Ecovacs Deebot Adapter: Status und Feedback
    • schmerenko
      schmerenko @mrbungle64 last edited by
      @mrbungle64 Dies mein LOG nach dem starten 57e2d0a8-6d34-46d3-997b-7ee520fe4a57-image.png
      mrbungle64 1 Reply Last reply Reply Quote 0
      • mrbungle64
        mrbungle64 Developer @schmerenko last edited by
        @schmerenko sagte in Ecovacs Deebot Adapter: Status und Feedback:
        Welches Modell hast du eingerichtet? Hast du einen Yeedi?
        schmerenko 1 Reply Last reply Reply Quote 0
        • schmerenko
          @mrbungle64 YEEDI 2 hybrid lauft seit Jahren eigentlich stabil
          2024-01-31 12:41:16.858 - error: ecovacs-deebot.0 (23826) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2024-01-31 12:41:16.859 - error: ecovacs-deebot.0 (23826) unhandled promise rejection: undefined is not a valid state value
          2024-01-31 12:41:16.864 - error: ecovacs-deebot.0 (23826) Error: undefined is not a valid state value
          at Object.maybeCallbackWithError (/opt/iobroker/node_modules/@iobroker/js-controller-common/build/lib/common/maybeCallback.js:35:17)
          at EcovacsDeebot._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5448:49)
          at EcovacsDeebot.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5409:21)
          at Immediate. (/opt/iobroker/node_modules/iobroker.ecovacs-deebot/main.js:1113:30)
          at process.processImmediate (node: internal/timers:478:21)
          • mrbungle64
            @schmerenko
            Die scheinen an der API für die Yeedi Modelle was geändert zu haben.
            Bei GitHub habe ich vor wenigen Tagen auch schon einen Issue dazu rein bekommen.
            https://github.com/mrbungle64/ioBroker.ecovacs-deebot/issues/629
            Ich muss schauen wann ich Zeit dafür finde und mir das in Ruhe anschauen.
            jay-jey created this issue in mrbungle64/ioBroker.ecovacs-deebot
            closed Adapter Error undefined is not a valid state value #629
            • schmerenko
              @mrbungle64 Danke
              • mrbungle64
                @schmerenko
                Könntest du bitte das Log Level auf "debug" stellen und die Ausgabe vom Log dann posten?
                Mir scheint das an den Daten der Map(s) zu liegen. Da wird sich was geändert haben.
                  jay-jey @mrbungle64 last edited by
                  @schmerenko Hab mal auf Github geantwortet aber auch nochmal hier.
                  Bis jetzt geht es leider nicht.
                  Ach aber danke fürs kümmern.
                  • mrbungle64
                    mrbungle64 Developer @jay-jey last edited by
                    @jay-jey @schmerenko
                    Probiert mal bitte die aktuelle Alpha von GitHub
                    J schmerenko 2 Replies Last reply Reply Quote 0
                      @mrbungle64 Vielen Dank. Hat funktioniert. Jetzt läuft es wieder.
                      • mrbungle64
                        @jay-jey sagte in Ecovacs Deebot Adapter: Status und Feedback:
                        Das ist ja schon mal erfreulich 😉
                        Sind Warnungen im Log?
                          jay-jey @mrbungle64 last edited by jay-jey
                          @mrbungle64
                          Nein kann erstmal keine sehen und nochmal danke für die schnelle Reaktion.
                          • schmerenko
                            schmerenko @mrbungle64 last edited by schmerenko
                            @mrbungle64 Adapter ist wieder auf "Grün", YEDEE hört wieder auf mich
                            Anbei noch die jetzigen Fehlerprotokolle:
                            • mrbungle64
                              @schmerenko
                              Hast du ein Skript was die Map mehrmals die Minute aktualisiert?
                              • mrbungle64
                                mrbungle64 Developer @mrbungle64 last edited by
                                ab heute wird die Version 1.4.14 über Beta/Latest verfügbar sein.
                                ❗ Wichtige Änderung:
                                • Die Minimale Version für Node.js ist nun die Version 16
                                ℹ Änderungen/Neues:
                                • Modelle:
                                  • Support für den AIRBOT Z1 (inkl. dem Z1 Air Quality Monitor)
                                  • Verbesserte Unterstützung der Serien T20 und X2
                                  • Es wurden weitere Modelle in der Konfig registriert
                                • Zusätzliche Verbesserungen und Optimierungen:
                                  • Man kann nun bis zu 20 Geräte ansteuern
                                  • Es wurden weitere Länder in die Auswahl aufgenommen
                                  • Aktualisierung von Abhängigkeiten
                                  rebel85 last edited by
                                  bei mir nun auch die selbe Meldung.
                                  • mrbungle64
                                    mrbungle64 Developer @rebel85 last edited by
                                    @rebel85 sagte in Ecovacs Deebot Adapter: Status und Feedback:
                                    Welche Version, welches Modell?
                                      rebel85 @mrbungle64 last edited by rebel85
                                      @mrbungle64
                                      Adapter: v1.4.13
                                      Modell T10
                                      auch nach Update auf 1.4.14 bleibt er aktiv aber rot
                                      rebuild mit
                                      cd /opt/iobroker/node_modules
                                      npm install object-assign --save-dev
                                      npm rebuild canvas --update-binary
                                      brachte auch nichts
                                      teste grad
                                      npm install canvas --build-from-source
                                      mrbungle64 R 2 Replies Last reply Reply Quote 0
                                      • mrbungle64
                                        @mrbungle64
                                        Adapter: v1.4.13
                                        Modell T10
                                        Ja, das ist eine neue Fehlermeldung. Ich weiß leider nicht, was Ecovacs da gerade mit der API macht.
                                        Bei mir funktioniert noch alles.
                                        rebuild mit
                                        brachte auch nichts
                                        Das hat auch mit dem gemeldeten Problem nichts zu tun.
                                          @mrbungle64
                                          deine Befehle von der Github Page hatte ich auch schon gemacht, bevor ich mich hier gemeldet habe.
                                          • mrbungle64
                                            @mrbungle64
                                            Das bezieht sich aber leider auf eine komplett andere Problematik
                                            deebot ecovacs ecovacs-deebot ecovacs-deebot adapter saugroboter vacuum
                                            36
                                            576
                                            139122
