    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id
    • N
      n811e @Thomas Braun last edited by Homoran
      @thomas-braun said in USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id:
      iob diag
      da kommt folgendes raus:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.21-v7l+
          Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       21:17:24 up 52 min,  2 users,  load average: 1.87, 1.77, 1.70
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Tue 2024-01-30 21:17:25 CET
                 Universal time: Tue 2024-01-30 20:17:25 UTC
                       RTC time: Tue 2024-01-30 20:17:25
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.3G        2.4G        5.7G        1.0M        355M        5.8G
      Swap:           104M          0B        104M
      Total:          8.4G        2.4G        5.8G
               7898 M total memory
               2320 M used memory
                106 M active memory
               2196 M inactive memory
               5464 M free memory
                 32 M buffer memory
                306 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4      117G  8.0G  105G   8% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  912K  1.6G   1% /run
      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
      [Tue Jan 30 20:24:31 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:CB:3B:DC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=4927e89a-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Tue Jan 30 20:24:32 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue Jan 30 20:24:32 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Tue Jan 30 20:24:36 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      2.0G    /var/
      1.1G    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
      1.1G    /var/log
      709M    /var/lib
      Archived and active journals take up 1.0G in the file system.
      /opt/iobroker/backups:
      93M     /opt/iobroker/backups/
      4.0K    /opt/iobroker/backups/redistmp
      /opt/iobroker/iobroker-data:
      477M    /opt/iobroker/iobroker-data/
      317M    /opt/iobroker/iobroker-data/files
      102M    /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      34M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
      25M     /opt/iobroker/iobroker-data/states.jsonl
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_46f93a68f7d8eb11893d0815b9da5f8b-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main armhf Packages
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main armhf Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.3                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
      + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.klf200.0                 : klf200                : raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
      + system.adapter.omada.0                  : omada                 : raspberrypi                              -  enabled, port: 443
      + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
      + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
      + system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
      + system.adapter.samsung_tizen.0          : samsung_tizen         : raspberrypi                              -  enabled, port: 8002
      + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
      + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
      + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_46f93a68f7d8eb11893d0815b9da5f8b-if00-port0
        system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.13.15  , installed 6.12.0 [Updatable]
      Adapter    "alexa2"       : 3.26.4   , installed 3.26.3 [Updatable]
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "device-watcher": 2.9.6   , installed 2.9.6
      Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
      Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.16.0   , installed 1.15.19 [Updatable]
      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "klf200"       : 1.1.2    , installed 1.1.2
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "onvif"        : 1.1.1    , installed 1.1.1
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
      Adapter    "samsung_tizen": 1.0.0    , installed 1.0.0
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
      Adapter    "web"          : 6.2.3    , installed 6.1.10 [Updatable]
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "worx"         : 2.3.4    , installed 2.3.4
      Adapter    "ws"           : 2.5.10   , installed 2.5.8  [Updatable]
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
      Objects and States
      Objects:        19613
      States:         15311
      Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       19220      2620/io.mqtt.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19188      2568/io.shelly.1
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       21636      2483/io.sonoff.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17641      964/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17653      964/iobroker.js-con
      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14899      1035/dnsmasq
      tcp        0      0 192.168.2.113:9292      0.0.0.0:*               LISTEN      1001       18414      2281/io.hm-rpc.2
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       24624      2907/io.jarvis.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17410      1024/sshd: /usr/sbi
      tcp        0      0 192.168.2.113:12010     0.0.0.0:*               LISTEN      1001       17407      2232/io.hm-rpc.1
      tcp        0      0 192.168.2.113:12001     0.0.0.0:*               LISTEN      1001       19532      2200/io.hm-rpc.0
      tcp6       0      0 :::8095                 :::*                    LISTEN      1001       23137      3015/io.onvif.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21252      2795/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17072      1811/io.admin.3
      tcp6       0      0 :::8000                 :::*                    LISTEN      1001       25799      2868/io.upnp.0
      tcp6       0      0 :::46799                :::*                    LISTEN      1001       20335      2808/io.yahka.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17412      1024/sshd: /usr/sbi
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23644      2949/io.wled.0
      udp        0      0 192.168.2.113:5353      0.0.0.0:*                           1001       20016      2512/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12028      403/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       21502      2868/io.upnp.0
      udp        0      0 0.0.0.0:35724           0.0.0.0:*                           1001       23568      2868/io.upnp.0
      udp        0      0 0.0.0.0:40457           0.0.0.0:*                           108        12030      403/avahi-daemon: r
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       21897      2633/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       21898      2633/io.tuya.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       20629      2412/io.shelly.0
      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14898      1035/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14895      1035/dnsmasq
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          909        846/dhclient
      udp6       0      0 :::51412                :::*                                108        12031      403/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        12029      403/avahi-daemon: r
      2024-01-30 21:14:11.605  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
      2024-01-30 21:14:11.628  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
      2024-01-30 21:14:39.489  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
      2024-01-30 21:15:06.296  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
      2024-01-30 21:15:06.325  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
      2024-01-30 21:15:09.499  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
      2024-01-30 21:15:15.639  - info: tr-064.0 (2512) forEachConfiguredDevice: in GetSpecificHostEntry 13(fritz.box/08:96:D7:8B:8C:54) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2024-01-30 21:15:39.543  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
      2024-01-30 21:16:02.990  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
      2024-01-30 21:16:03.009  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
      2024-01-30 21:16:09.575  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
      2024-01-30 21:16:39.565  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
      2024-01-30 21:16:47.975  - info: tr-064.0 (2512) forEachConfiguredDevice: in GetSpecificHostEntry 13(fritz.box/08:96:D7:8B:8C:54) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2024-01-30 21:16:59.510  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
      2024-01-30 21:16:59.532  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
      2024-01-30 21:17:09.594  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
      2024-01-30 21:17:39.602  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
      2024-01-30 21:17:56.062  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
      2024-01-30 21:17:56.088  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
      2024-01-30 21:18:09.613  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
      2024-01-30 21:18:19.159  - info: tr-064.0 (2512) forEachConfiguredDevice: in GetSpecificHostEntry 13(fritz.box/08:96:D7:8B:8C:54) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2024-01-30 21:18:39.618  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
      2024-01-30 21:18:55.875  - error: shelly.1 (2568) [MQTT] Wrong MQTT authentification of client "shellyplus1-a8032abcbcd8"
      2024-01-30 21:18:55.894  - info: shelly.1 (2568) [MQTT] Client Close:  (shellyplus1 / shellyplus1-a8032abcbcd8 / shellyplus1#a8032abcbcd8#1) (false)
      2024-01-30 21:19:09.575  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:trueWert:system.adapter.shelly.1bestätigt:true
      iob diag has finished.
      Press any key for a summary
      • N
        Copy text starting here:
                                v.2023-10-10
               Icon name: computer
            Architecture: arm
        Installation:           native
        Kernel:                 armv7l
        Userland:               armhf
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        X-Server:               false
        Boot Target:            graphical.target
        Pending OS-Updates:     0
        Pending iob updates:    5
        Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
        Recommended versions are nodejs 18.19.0 and npm 10.2.3
        MEMORY:
        Mem:            8.3G        2.5G        5.6G        1.0M        472M        5.8G
        Swap:           104M          0B        104M
        Total:          8.4G        2.5G        5.7G
        Active iob-Instances:   40
        ioBroker Core:          js-controller           5.0.17
                                admin                   6.12.0
        Objects type: jsonl
        States  type: jsonl
        Objects:                19613
        States:                 15311
        Size of iob-Database:
        4.1M    /opt/iobroker/iobroker-data/states.jsonl
        === Mark text until here for copying ===
          Thomas Braun Most Active @n811e last edited by
          @n811e
          Und der Adapter 'Kaltstart' sieht im Log wie aus?
          Instanz stoppen,
          iob logs --watch | uniq
          anschauen, Instanz wieder starten.
          • N
            Was soll ich denn alles kopieren, nachdem ich iob logs --watch | uniq eingegeben habe?
            Der hört ja nie auf, oder wie verstehe ich das?
              Homoran Global Moderator Administrators @n811e last edited by
              @n811e den Start der Instanz, die du extra vorher gestoppt hast
                @n811e sagte in USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id:
                Mit Strg-C hört 'der' auch wieder auf das Log anzuzeigen.
                • N
                  So, jetzt habe ichs:
                  2024-01-31 20:02:23.295  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                  2024-01-31 20:02:24.689  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 17095
                  2024-01-31 20:02:37.047  - info: zigbee.0 (17095) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                  2024-01-31 20:02:37.259  - info: zigbee.0 (17095) delete old Backup files. keep only last 10
                  2024-01-31 20:02:37.265  - info: zigbee.0 (17095) Starting Zigbee  npm ...
                  2024-01-31 20:02:38.106  - info: zigbee.0 (17095) Installed Version: iobroker.zigbee@1.10.1
                  2024-01-31 20:03:44.528  - error: zigbee.0 (17095) Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
                  2024-01-31 20:03:44.531  - error: zigbee.0 (17095) Failed to start Zigbee
                  2024-01-31 20:03:44.532  - error: zigbee.0 (17095) Error herdsman start
                  • Meister Mopper
                    Meister Mopper @n811e last edited by
                    Versuch doch mal eine andere PanId, offenbar funkt da noch ein anderes Netzwerk in deinen Bereich.
                    Kann sein, dass du anschließend alles neu anlernen musst.
                    • N
                      n811e @Meister Mopper last edited by
                      @meister-mopper
                      Das ist ja verrückt!!! Das klappt jetzt wieder. Damit hätte ich nicht gerechnet.
                      Vielen Dank an alle, insbesondere @thomas-braun für die viele Mühe, die ihr euch gemacht habt.
                      Dankeschön
                      • N
                        @meister-mopper @thomas-braun
                        Leider wieder am selben Punkt 😕
                        2024-02-01 14:04:36.400  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
                        2024-02-01 14:04:37.659  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 26738
                        2024-02-01 14:04:46.093  - info: zigbee.0 (26738) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                        2024-02-01 14:04:46.235  - info: zigbee.0 (26738) delete old Backup files. keep only last 10
                        2024-02-01 14:04:46.239  - info: zigbee.0 (26738) Starting Zigbee  npm ...
                        2024-02-01 14:04:46.707  - info: zigbee.0 (26738) Installed Version: iobroker.zigbee@1.10.1
                        2024-02-01 14:04:47.197  - info: javascript.0 (1828) script.js.Beleuchtung.Debug_Licht: Wert:falseWert:system.adapter.shelly.1bestätigt:true
                        2024-02-01 14:04:47.679  - error: zigbee.0 (26738) Configuration is not consistent with adapter state/backup!
                        2024-02-01 14:04:47.679  - error: zigbee.0 (26738) - PAN ID: configured=6557, adapter=6556
                        2024-02-01 14:04:47.680  - error: zigbee.0 (26738) - Extended PAN ID: configured=ddd3dddfddddaddd, adapter=ddd3dddfddddaddd
                        2024-02-01 14:04:47.681  - error: zigbee.0 (26738) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                        2024-02-01 14:04:47.682  - error: zigbee.0 (26738) - Channel List: configured=11, adapter=11
                        2024-02-01 14:04:47.683  - error: zigbee.0 (26738) Please update configuration to prevent further issues.
                        2024-02-01 14:04:47.684  - error: zigbee.0 (26738) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
                        2024-02-01 14:04:47.685  - error: zigbee.0 (26738) Re-commissioning your network will require re-pairing of all devices!
                        2024-02-01 14:04:47.814  - error: zigbee.0 (26738) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                        2024-02-01 14:04:47.814  - error: zigbee.0 (26738) Failed to start Zigbee
                        2024-02-01 14:04:47.816  - error: zigbee.0 (26738) Error herdsman start
                        2024-02-01 14:04:57.822  - info: zigbee.0 (26738) Try to reconnect. 1 attempts left
                        2024-02-01 14:04:57.823  - info: zigbee.0 (26738) Starting Zigbee  npm ...
                        2024-02-01 14:04:57.841  - info: zigbee.0 (26738) Installed Version: iobroker.zigbee@1.10.1
                        2024-02-01 14:04:58.109  - error: zigbee.0 (26738) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                        2024-02-01 14:04:58.112  - error: zigbee.0 (26738) Failed to start Zigbee
                        2024-02-01 14:04:58.112  - error: zigbee.0 (26738) Error herdsman start
                          Die Werte müssen übereinstimmen.
                          • N
                            die PAN ID, stelle ich ja unter Einstellungen ein, aber wo kann ich den Wert für den Adapter ändern?
                              @n811e
                              ? Gar nicht. Aber die PAN-Id in den Einstellungen muss auf den Wert im Adapter geändert werden.
                                e-i-k-e @Thomas Braun last edited by e-i-k-e
                                Ich habe leider auch das problem mit
                                ls: cannot access '/dev/serial/by-ids': No such file or directory
                                Ich ziehe gerade mit iobroker um und habe iob neu auf ubuntu 22.04 installiert und anschließend ein iob backup eingespielt.
                                Ausgang von iob diag lautet:
                                ========== Start marking the full check here ===========
                                ```bash
                                Script v.2024-10-19
                                *** BASE SYSTEM ***
                                 Static hostname: iobroker
                                       Icon name: computer-vm
                                         Chassis: vm 🖴
                                  Virtualization: kvm
                                Operating System: Ubuntu 24.04.1 LTS
                                          Kernel: Linux 6.8.0-50-generic
                                    Architecture: x86-64
                                 Hardware Vendor: QEMU
                                  Hardware Model: Standard PC _i440FX + PIIX, 1996_
                                Firmware Version: 4.2023.08-4
                                   Firmware Date: Thu 2024-02-15
                                    Firmware Age: 9month 3w 6d
                                OS is similar to: debian
                                model name      : Common KVM processor
                                Docker          : false
                                Virtualization  : kvm
                                Kernel          : x86_64
                                Userland        : 64 bit
                                 23:59:11 up 21 min,  1 user,  load average: 0.53, 0.40, 0.45
                                CPU threads: 8
                                *** LIFE CYCLE STATUS ***
                                Operating System is the current Ubuntu LTS release codenamed 'noble'!
                                *** TIME AND TIMEZONES ***
                                               Local time: Wed 2024-12-11 23:59:11 CET
                                           Universal time: Wed 2024-12-11 22:59:11 UTC
                                                 RTC time: Wed 2024-12-11 22:59:10
                                              NTP service: active
                                          RTC in local TZ: no
                                *** Users and Groups ***
                                User that called 'iob diag':
                                pi
                                HOME=/home/pi
                                GROUPS=pi sudo users iobroker
                                iobroker
                                HOME=/home/iobroker
                                GROUPS=iobroker tty dialout audio video plugdev
                                *** DISPLAY-SERVER SETUP ***
                                Display-Server: false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:             10G        3.0G        6.9G        5.3M        846M        7.5G
                                Swap:             0B          0B          0B
                                Total:           10G        3.0G        6.9G
                                Active iob-Instances:   58
                                         9938 M total memory
                                         2820 M used memory
                                         2578 M active memory
                                          460 M inactive memory
                                         6572 M free memory
                                           54 M buffer memory
                                          752 M swap cache
                                            0 M total swap
                                            0 M used swap
                                            0 M free swap
                                top - 23:59:11 up 21 min,  1 user,  load average: 0.53, 0.40, 0.45
                                Tasks: 179 total,   1 running, 178 sleeping,   0 stopped,   0 zombie
                                %Cpu(s): 20.5 us,  4.5 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                MiB Mem :   9938.9 total,   6572.1 free,   2820.9 used,    807.5 buff/cache
                                MiB Swap:      0.0 total,      0.0 free,      0.0 used.   7118.0 avail Mem
                                *** DMESG CRITICAL ERRORS ***
                                No critical errors detected
                                *** FILESYSTEM ***
                                tmpfs          tmpfs     994M  1.1M  993M   1% /run
                                efivarfs       efivarfs  256K   20K  232K   8% /sys/firmware/efi/efivars
                                /dev/sda1      ext4       51G  6.8G   45G  14% /
                                tmpfs          tmpfs     4.9G     0  4.9G   0% /dev/shm
                                tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                                /dev/sda16     ext4      881M  112M  708M  14% /boot
                                /dev/sda15     vfat      105M  6.1M   99M   6% /boot/efi
                                tmpfs          tmpfs     994M   12K  994M   1% /run/user/0
                                [Wed Dec 11 23:38:08 2024] EXT4-fs (sda1): mounted filesystem 428c45af-c748-4f29-9fe5-d56aa4a3f75e ro with ordered data mode. Quota mode: none.
                                [Wed Dec 11 23:38:09 2024] EXT4-fs (sda1): re-mounted 428c45af-c748-4f29-9fe5-d56aa4a3f75e r/w. Quota mode: none.
                                [Wed Dec 11 23:38:11 2024] EXT4-fs (sda16): mounted filesystem a4ce610e-4a3c-4ed2-8852-b138eade5b0b r/w with ordered data mode. Quota mode: none.
                                Show mounted filesystems:
                                /             /dev/sda1  ext4   rw,relatime,discard,errors=remount-ro,commit=30
                                `-/boot       /dev/sda16 ext4   rw,relatime
                                  `-/boot/efi /dev/sda15 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
                                /var:
                                687M    /var/
                                344M    /var/cache
                                314M    /var/cache/apt
                                216M    /var/cache/apt/archives
                                199M    /var/lib
                                Archived and active journals take up 19.2M in the file system.
                                27M     /opt/iobroker/backups/
                                213M    /opt/iobroker/iobroker-data/
                                176M    /opt/iobroker/iobroker-data/files
                                158M    /opt/iobroker/iobroker-data/files/admin.admin
                                157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                36M     /opt/iobroker/iobroker-data/objects.jsonl
                                7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
                                7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
                                7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
                                7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
                                USB-Devices by-id:
                                No Devices found 'by-id'
                                HINT:
                                Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                /dev/ttyACM0
                                /usr/bin/nodejs         v20.18.1
                                /usr/bin/node           v20.18.1
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                /usr/bin/corepack       0.29.4
                                nodejs:
                                  Installed: 20.18.1-1nodesource1
                                  Candidate: 20.18.1-1nodesource1
                                  Version table:
                                 *** 20.18.1-1nodesource1 1001
                                        500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                     20.18.0-1nodesource1 1001
                                     20.17.0-1nodesource1 1001
                                     20.16.0-1nodesource1 1001
                                     20.15.1-1nodesource1 1001
                                     20.15.0-1nodesource1 1001
                                     20.14.0-1nodesource1 1001
                                     20.13.1-1nodesource1 1001
                                     20.13.0-1nodesource1 1001
                                     20.12.2-1nodesource1 1001
                                     20.12.1-1nodesource1 1001
                                     20.12.0-1nodesource1 1001
                                     20.11.1-1nodesource1 1001
                                     20.11.0-1nodesource1 1001
                                     20.10.0-1nodesource1 1001
                                     20.9.0-1nodesource1 1001
                                     20.8.1-1nodesource1 1001
                                     20.8.0-1nodesource1 1001
                                     20.7.0-1nodesource1 1001
                                     20.6.1-1nodesource1 1001
                                     20.6.0-1nodesource1 1001
                                     20.5.1-1nodesource1 1001
                                     20.5.0-1nodesource1 1001
                                     20.4.0-1nodesource1 1001
                                     20.3.1-1nodesource1 1001
                                     20.3.0-1nodesource1 1001
                                     20.2.0-1nodesource1 1001
                                     20.1.0-1nodesource1 1001
                                     20.0.0-1nodesource1 1001
                                     18.19.1+dfsg-6ubuntu5 500
                                        500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
                                Errors in npm tree: 0
                                ioBroker Status
                                At least one iobroker host is running.
                                Objects type: redis
                                States  type: redis
                                Hosts:
                                ioBroker-Rock       ioBroker-Rock (version: 7.0.6, hostname: ioBroker-Rock , alive, uptime: 1247)
                                raspberrypi-display1 raspberrypi-display1 (version: 7.0.2, hostname: raspberrypi-display1, alive, uptime: 1231)
                                raspberrypi-display2 raspberrypi-display2 (version: 7.0.2, hostname: raspberrypi-display2, alive, uptime: 1233)
                                raspberrypi-display3 raspberrypi-display3 (version: 4.0.24, hostname: raspberrypi-display3, alive, uptime: 1237)
                                raspberrypi-display4 raspberrypi-display4 (version: 5.0.19, hostname: raspberrypi-display4, alive, uptime: 1239)
                                raspberrypi-display5 raspberrypi-display5 (version: 7.0.2, hostname: raspberrypi-display5, alive, uptime: 1239)
                                raspberrypi-slave   raspberrypi-slave (version: 5.0.8, hostname: raspberrypi-slave, alive, uptime: 1235)
                                js-controller:  7.0.6
                                admin:          7.4.4
                                javascript:     8.8.3
                                nodejs modules from github:     3
                                +-- iobroker.energiefluss-erweitert@0.6.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#a898e0cd728900620b9bfea0f1710d8720ebf82f)
                                | +-- node-milight-promise@0.3.2 (git+ssh://git@github.com/Steiger04/node-milight-promise.git#f1089feac9b7990727adf2016891029436729d33)
                                | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                                Adapter State
                                + system.adapter.admin.2                  : admin                 : ioBroker-Rock                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                + system.adapter.admin.3                  : admin                 : ioBroker-Rock                            -  enabled, port: 8900, bind: 0.0.0.0, run as: admin
                                + system.adapter.alarm.0                  : alarm                 : ioBroker-Rock                            -  enabled
                                + system.adapter.alexa2.0                 : alexa2                : ioBroker-Rock                            -  enabled
                                  system.adapter.backitup.0               : backitup              : ioBroker-Rock                            - disabled
                                + system.adapter.cloud.0                  : cloud                 : ioBroker-Rock                            -  enabled
                                  system.adapter.daswetter.0              : daswetter             : ioBroker-Rock                            -  enabled
                                + system.adapter.device-reminder.0        : device-reminder       : ioBroker-Rock                            -  enabled
                                + system.adapter.device-watcher.0         : device-watcher        : ioBroker-Rock                            -  enabled
                                + system.adapter.discovergy.0             : discovergy            : ioBroker-Rock                            -  enabled
                                  system.adapter.discovery.0              : discovery             : ioBroker-Rock                            - disabled
                                  system.adapter.dwd.0                    : dwd                   : ioBroker-Rock                            -  enabled
                                + system.adapter.echarts.0                : echarts               : ioBroker-Rock                            -  enabled
                                + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker-Rock                            -  enabled
                                  system.adapter.feiertage.0              : feiertage             : ioBroker-Rock                            -  enabled
                                  system.adapter.flot.0                   : flot                  : ioBroker-Rock                            -  enabled
                                + system.adapter.hass.0                   : hass                  : ioBroker-Rock                            -  enabled, port: 8123
                                + system.adapter.heatingcontrol.1         : heatingcontrol        : ioBroker-Rock                            -  enabled
                                + system.adapter.hm-rega.0                : hm-rega               : ioBroker-Rock                            -  enabled
                                + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
                                + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
                                + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker-Rock                            -  enabled, port: 0
                                  system.adapter.hoover.0                 : hoover                : ioBroker-Rock                            - disabled
                                  system.adapter.ical.0                   : ical                  : ioBroker-Rock                            -  enabled
                                  system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker-Rock                            -  enabled
                                  system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-Rock                            -  enabled
                                  system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-Rock                            -  enabled
                                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-Rock                            -  enabled
                                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-Rock                            -  enabled
                                  system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-Rock                            -  enabled
                                + system.adapter.influxdb.0               : influxdb              : ioBroker-Rock                            -  enabled, port: 8086
                                + system.adapter.javascript.0             : javascript            : ioBroker-Rock                            -  enabled
                                + system.adapter.javascript.2             : javascript            : raspberrypi-display1                     -  enabled
                                + system.adapter.javascript.3             : javascript            : raspberrypi-display4                     -  enabled
                                + system.adapter.javascript.4             : javascript            : raspberrypi-display2                     -  enabled
                                + system.adapter.javascript.5             : javascript            : raspberrypi-display5                     -  enabled
                                + system.adapter.midea.0                  : midea                 : ioBroker-Rock                            -  enabled
                                  system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-Rock                            - disabled, port: 54321, bind: 0.0.0.0
                                  system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker-Rock                            - disabled, port: 54321, bind: 0.0.0.0
                                + system.adapter.mihome.0                 : mihome                : ioBroker-Rock                            -  enabled, port: 9898, bind: 192.168.3.100
                                + system.adapter.milight-smart-light.0    : milight-smart-light   : ioBroker-Rock                            -  enabled
                                + system.adapter.modbus.0                 : modbus                : ioBroker-Rock                            -  enabled
                                  system.adapter.mqtt-client.0            : mqtt-client           : ioBroker-Rock                            - disabled, port: 1883
                                + system.adapter.mqtt.0                   : mqtt                  : ioBroker-Rock                            -  enabled, port: 1886, bind: 0.0.0.0
                                + system.adapter.musiccast.0              : musiccast             : ioBroker-Rock                            -  enabled
                                + system.adapter.nut.0                    : nut                   : ioBroker-Rock                            -  enabled
                                  system.adapter.openweathermap.0         : openweathermap        : ioBroker-Rock                            -  enabled
                                + system.adapter.proxmox.0                : proxmox               : ioBroker-Rock                            -  enabled, port: 8006
                                + system.adapter.rpi2.1                   : rpi2                  : raspberrypi-display1                     -  enabled
                                + system.adapter.rpi2.2                   : rpi2                  : raspberrypi-display2                     -  enabled
                                + system.adapter.rpi2.3                   : rpi2                  : raspberrypi-display3                     -  enabled
                                + system.adapter.rpi2.4                   : rpi2                  : raspberrypi-display4                     -  enabled
                                + system.adapter.rpi2.5                   : rpi2                  : raspberrypi-display5                     -  enabled
                                + system.adapter.sainlogic.0              : sainlogic             : ioBroker-Rock                            -  enabled, port: 45000, bind: 192.168.3.100
                                + system.adapter.scenes.0                 : scenes                : ioBroker-Rock                            -  enabled
                                + system.adapter.shelly.0                 : shelly                : ioBroker-Rock                            -  enabled, port: 1890, bind: 0.0.0.0
                                + system.adapter.shelly.1                 : shelly                : ioBroker-Rock                            -  enabled, port: 1899, bind: 0.0.0.0
                                + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker-Rock                            -  enabled
                                  system.adapter.simple-api.0             : simple-api            : ioBroker-Rock                            - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                                + system.adapter.smartcontrol.0           : smartcontrol          : ioBroker-Rock                            -  enabled
                                + system.adapter.smartmeter.0             : smartmeter            : ioBroker-Rock                            -  enabled
                                + system.adapter.sonoff.0                 : sonoff                : ioBroker-Rock                            -  enabled, port: 1883, bind: 0.0.0.0
                                + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker-Rock                            -  enabled
                                  system.adapter.sprinklecontrol.0        : sprinklecontrol       : ioBroker-Rock                            - disabled
                                + system.adapter.statistics.0             : statistics            : ioBroker-Rock                            -  enabled
                                + system.adapter.synology.0               : synology              : ioBroker-Rock                            -  enabled, port: 5001
                                + system.adapter.telegram.0               : telegram              : ioBroker-Rock                            -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.text2command.0           : text2command          : ioBroker-Rock                            -  enabled
                                  system.adapter.unifi.0                  : unifi                 : ioBroker-Rock                            - disabled
                                  system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker-Rock                            -  enabled
                                  system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioBroker-Rock                            -  enabled
                                  system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker-Rock                            -  enabled
                                + system.adapter.vis-2.0                  : vis-2                 : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-bars.0               : vis-bars              : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-history.0            : vis-history           : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker-Rock                            -  enabled
                                + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-material.0           : vis-material          : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-metro.0              : vis-metro             : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-players.0            : vis-players           : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-plumb.0              : vis-plumb             : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-Rock                            -  enabled
                                  system.adapter.vis-weather.0            : vis-weather           : ioBroker-Rock                            -  enabled
                                  system.adapter.vis.0                    : vis                   : ioBroker-Rock                            -  enabled
                                + system.adapter.vw-connect.0             : vw-connect            : ioBroker-Rock                            -  enabled
                                  system.adapter.web-speedy.0             : web-speedy            : ioBroker-Rock                            - disabled
                                + system.adapter.web.0                    : web                   : ioBroker-Rock                            -  enabled, port: 8082, bind: 192.168.3.100 (SSL), run as: admin
                                + system.adapter.web.1                    : web                   : ioBroker-Rock                            -  enabled, port: 8083, bind: 192.168.3.100, run as: admin
                                + system.adapter.wolf-smartset.0          : wolf-smartset         : ioBroker-Rock                            -  enabled
                                  system.adapter.worx.0                   : worx                  : ioBroker-Rock                            - disabled
                                + system.adapter.yamaha.0                 : yamaha                : ioBroker-Rock                            -  enabled
                                + system.adapter.yeelight-2.0             : yeelight-2            : ioBroker-Rock                            -  enabled
                                  system.adapter.yr.0                     : yr                    : ioBroker-Rock                            -  enabled
                                + system.adapter.zigbee.0                 : zigbee                : ioBroker-Rock                            -  enabled, port: /dev/ttyACM0
                                + instance is alive
                                Active repo(s): beta
                                Upgrade policy: none
                                Used repository: beta
                                Adapter    "admin"        : 7.4.4    , installed 7.4.4
                                Adapter    "alarm"        : 3.6.4    , installed 3.6.4
                                Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
                                Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                                Adapter    "daswetter"    : 3.2.1    , installed 3.2.1
                                Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                                Adapter    "discovergy"   : 0.5.13   , installed 0.5.13
                                Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                                Adapter    "energiefluss-erweitert": 0.6.0, installed 0.6.0
                                Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                                Adapter    "hass"         : 1.4.0    , installed 1.4.0
                                Adapter    "heatingcontrol": 2.12.13 , installed 2.12.13
                                Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                                Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                Adapter    "hoover"       : 0.1.3    , installed 0.1.3
                                Adapter    "ical"         : 1.16.1   , installed 1.16.1
                                Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                Controller "js-controller": 7.0.6    , installed 7.0.6
                                Adapter    "midea"        : 0.0.7    , installed 0.0.7
                                Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                                Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                                Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
                                Adapter    "modbus"       : 6.4.0    , installed 6.4.0
                                Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                Adapter    "mqtt-client"  : 2.1.0    , installed 2.1.0
                                Adapter    "musiccast"    : 1.1.4    , installed 1.1.4
                                Adapter    "nut"          : 1.6.0    , installed 1.6.0
                                Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                                Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                                Adapter    "sainlogic"    : 0.11.4   , installed 0.11.4
                                Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                                Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                                Adapter    "shuttercontrol": 1.8.5   , installed 1.8.5
                                Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                                Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                                Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                                Adapter    "statistics"   : 3.1.0    , installed 3.1.0
                                Adapter    "synology"     : 3.1.0    , installed 3.1.0
                                Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                                Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                                Adapter    "vis-2"        : 2.11.1   , installed 2.11.1
                                Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                                Adapter    "vis-2-widgets-gauges": 1.1.1, installed 1.1.1
                                Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
                                Adapter    "vis-2-widgets-jaeger-design": 1.3.9, installed 1.3.9
                                Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                                Adapter    "vis-icontwo"  : 1.10.1   , installed 1.10.1
                                Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                                Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                                Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                                Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                Adapter    "vw-connect"   : 0.6.1    , installed 0.6.1
                                Adapter    "web"          : 6.3.1    , installed 6.3.1
                                Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
                                Adapter    "wolf-smartset": 1.2.3    , installed 1.2.3
                                Adapter    "worx"         : 3.1.1    , installed 3.1.1
                                Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
                                Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
                                Adapter    "yr"           : 5.3.0    , installed 5.3.0
                                Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
                                Objects and States
                                Objects:        39194
                                States:         36289
                                Hit:1 http://archive.ubuntu.com/ubuntu noble InRelease
                                Hit:2 http://archive.ubuntu.com/ubuntu noble-updates InRelease
                                Hit:3 http://archive.ubuntu.com/ubuntu noble-backports InRelease
                                Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                Hit:5 http://security.ubuntu.com/ubuntu noble-security InRelease
                                Pending Updates: 0
                                tcp        0      0 192.168.3.100:2010      0.0.0.0:*               LISTEN      1001       11540      1563/io.hm-rpc.2
                                tcp        0      0 192.168.3.100:2001      0.0.0.0:*               LISTEN      1001       9811       1487/io.hm-rpc.0
                                tcp        0      0 192.168.3.100:8701      0.0.0.0:*               LISTEN      1001       11703      1683/io.hm-rpc.1
                                tcp        0      0 192.168.3.100:45000     0.0.0.0:*               LISTEN      1001       12502      1752/io.sainlogic.0
                                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          715        1/init
                                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       8188       1273/io.sonoff.0
                                tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       10687      1373/io.mqtt.0
                                tcp        0      0 0.0.0.0:1899            0.0.0.0:*               LISTEN      1001       11519      1548/io.shelly.1
                                tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      991        6774       633/systemd-resolve
                                tcp        0      0 192.168.3.100:8083      0.0.0.0:*               LISTEN      1001       13321      1917/io.web.1
                                tcp        0      0 192.168.3.100:8082      0.0.0.0:*               LISTEN      1001       12687      1977/io.web.0
                                tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      991        6772       633/systemd-resolve
                                tcp6       0      0 :::8900                 :::*                    LISTEN      1001       8070       1089/io.admin.3
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          8316       1/init
                                tcp6       0      0 :::111                  :::*                    LISTEN      0          3605       1/init
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8885       973/io.admin.2
                                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11624      1638/io.shelly.0
                                udp        0      0 0.0.0.0:47970           0.0.0.0:*                           1001       11834      1812/io.milight-sma
                                udp        0      0 127.0.0.54:53           0.0.0.0:*                           991        6773       633/systemd-resolve
                                udp        0      0 127.0.0.53:53           0.0.0.0:*                           991        6771       633/systemd-resolve
                                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          716        1/init
                                udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       10200      1868/io.musiccast.0
                                udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       11644      1653/io.mihome.0
                                udp6       0      0 :::111                  :::*                                0          717        1/init
                                  port: 80
                                2024-12-11 23:59:05.006  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                2024-12-11 23:59:07.010  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                2024-12-11 23:59:09.012  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                2024-12-11 23:59:10.542  - info: influxdb.0 (1202) Store 272 buffered influxDB history points
                                2024-12-11 23:59:11.015  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                2024-12-11 23:59:13.018  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                2024-12-11 23:59:15.019  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                2024-12-11 23:59:17.022  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                2024-12-11 23:59:19.024  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                2024-12-11 23:59:21.027  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                2024-12-11 23:59:23.030  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                2024-12-11 23:59:25.031  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                2024-12-11 23:59:27.034  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                2024-12-11 23:59:29.036  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                2024-12-11 23:59:31.039  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                2024-12-11 23:59:33.041  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                2024-12-11 23:59:35.044  - warn: smartmeter.0 (1333) No or too long answer from Serial Device after last request.
                                2024-12-11 23:59:37.046  - warn: smartmeter.0 (1333) No or too long answer from Serial D
                                ```bash
                                                        v.2024-10-19
                                         Chassis: vm 🖴
                                  Virtualization: kvm
                                Installation:           kvm
                                Kernel:                 x86_64
                                Userland:               64 bit
                                User-ID:                1000
                                Boot Target:            multi-user.target
                                Pending iob updates:    0
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                Recommended versions are nodejs  and npm
                                nodeJS installation is correct
                                MEMORY:
                                Mem:             10G        3.0G        6.6G        5.3M        1.1G        7.4G
                                Swap:             0B          0B          0B
                                Total:           10G        3.0G        6.6G
                                ioBroker Core:          js-controller           7.0.6
                                                        admin                   7.4.4
                                Objects type: redis
                                States  type: redis
                                Objects:                39194
                                States:                 36289
                                768K    /opt/iobroker/iobroker-data/states.jsonl
                                  Thomas Braun Most Active @e-i-k-e last edited by
                                  @e-i-k-e sagte in USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id:
                                  Virtualization: kvm
                                  Der Stick muss an die VM durchgereicht werden.
                                  Setz den user in die Gruppe adm rein. Und warum nennt man den user überhaupt ``pi`? Ist doch nicht mal ein Raspberry...
                                  Und bring den Versions-Zoo bei den ganzen hosts auf den gleichen aktuellen Stand.
                                    @thomas-braun sagte in USB Port Zuweisung, fehlendes Verzeichnis /dev/serial/by-id:
                                    Virtualization: kvm
                                    Die sind über Proxmox durchgereicht, werden über lsusb in der VM auch angezeigt.
                                    Kann ich machen, der User pi ist historisch mitgewandert.
                                    Hat das mit der Gruppe adm, denn etwas mit meinem "ls: cannot access '/dev/serial/by-ids': No such file or directory" zutun? Oder wofür wird dies benötigt?
                                    Wird nach und nach, leider sind einige Distribution so alt, dass ein update nicht ohne weiteres mehr möglich ist.
                                      Dann haste da viel zu lange gepennt.
                                      Die Gruppe adm wird für administrative Dinge benötigt. Unter anderem um logfiles auch ohne root-Rechte lesen zu können.
                                      E 2 Replies Last reply Reply Quote 0
                                        Da muss ich dir recht geben 😉
                                          Ich komme aber trotzdem leider nicht weiter.
                                          pi@iobroker:~$ lsusb
                                          Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
                                          Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                                          Bus 002 Device 002: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
                                          Bus 002 Device 003: ID 0451:bef3 Texas Instruments, Inc. CC1352R1 Launchpad
                                          Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                          pi@iobroker:~$ sudo ls /dev/serial/by-id
                                          ls: cannot access '/dev/serial/by-id': No such file or directory
                                            @e-i-k-e
                                            Schau dir per
                                            dmesg -wT
                                            die Meldungen an, wenn der Stickk entfernt und nach einer Minute wieder eingesteckt wird.
                                            14847
