    4. Admin Seite nach Update auf 6.13.15 nicht erreichbar
    • Marc_el_K
      Marc_el_K @Thomas Braun last edited by
      @thomas-braun sagte in Mach Admin-Update leerer Bildschirm:
      @marc_el_k
      Gib mal die Langfassung bekannt.
      Ich bin mir nicht sicher, ob das die Langfassung ist:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : armhf
      Systemuptime and Load:
       21:19:33 up 15 min,  1 user,  load average: 2.77, 2.93, 2.13
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Fri 2024-02-02 21:19:33 CET
                 Universal time: Fri 2024-02-02 20:19:33 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.8G        1.8G        5.2G        0.0K        762M        5.9G
      Swap:            99M          0B         99M
      Total:          7.9G        1.8G        5.3G
               7812 M total memory
               1836 M used memory
               1881 M active memory
                492 M inactive memory
               5213 M free memory
                159 M buffer memory
                603 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT               LOAD   ACTIVE SUB    DESCRIPTION
      * nut-server.service loaded failed failed Network UPS Tools - power devices information server
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4      117G   19G   94G  17% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  872K  1.6G   1% /run
      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
      /dev/sda1      vfat      233G   30G  204G  13% /media/usb
      tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
      [Fri Feb  2 21:04:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:D9:04:68 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  #console=ttyS0,115200 console=tty1 root=PARTUUID=cdb3ca5a-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Fri Feb  2 21:04:03 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Feb  2 21:04:03 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Fri Feb  2 21:04:06 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET       SOURCE         FSTYPE OPTIONS
      /            /dev/mmcblk0p2 ext4   rw,noatime
      |-/boot      /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      `-/media/usb /dev/sda1      vfat   rw,nosuid,nodev,noexec,relatime,sync,fmask=0000,dmask=0000,allow_utime=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      5.2G    /var/
      2.7G    /var/cache/apt
      2.7G    /var/cache
      2.6G    /var/cache/apt/archives
      2.4G    /var/log
      Archived and active journals take up 2.2G in the file system.
      /opt/iobroker/backups:
      1.6G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      801M    /opt/iobroker/iobroker-data/
      484M    /opt/iobroker/iobroker-data/files
      234M    /opt/iobroker/iobroker-data/backup-objects
      89M     /opt/iobroker/iobroker-data/files/echarts.admin
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      35M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
      npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
      npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
      npm ERR! invalid: iobroker.admin@6.13.15 /opt/iobroker/node_modules/iobroker.admin
      npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
      npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
      npm ERR! extraneous: undici-types@5.26.5 /opt/iobroker/node_modules/undici-types
      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
      npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
      npm ERR! invalid: @iobroker/adapter-core@2.6.0 /opt/iobroker/node_modules/@iobroker/adapter-core
      npm ERR! invalid: ajv@6.12.6 /opt/iobroker/node_modules/ajv
      npm ERR! invalid: body-parser@1.20.1 /opt/iobroker/node_modules/body-parser
      npm ERR! invalid: mime@1.6.0 /opt/iobroker/node_modules/mime
      npm ERR! invalid: semver@7.5.0 /opt/iobroker/node_modules/semver
      npm ERR! missing: homebridge-camera-ffmpeg@^3.1.4, required by iobroker.ham@5.3.1
      npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
      npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
      npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-02T20_19_43_923Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.13.15
      javascript:     7.1.6
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-02T20_20_18_807Z-debug-0.log
      Adapters from github:   6
      Adapter State
        system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.ble.1                    : ble                   : raspberrypi                              -  enabled
      + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled
      + system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      + system.adapter.esphome.0                : esphome               : raspberrypi                              -  enabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
        system.adapter.ham.0                    : ham                   : raspberrypi                              - disabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.76
      + system.adapter.nut.0                    : nut                   : raspberrypi                              -  enabled
        system.adapter.octoprint.0              : octoprint             : raspberrypi                              - disabled
      + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
        system.adapter.paw.0                    : paw                   : raspberrypi                              - disabled, port: 8898
        system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
      + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.rssfeed.0                : rssfeed               : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
      + system.adapter.tankerkoenig.1           : tankerkoenig          : raspberrypi                              -  enabled
        system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
        system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
      + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
      + system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
      + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "admin"        : 6.13.15  , installed 6.13.15
      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "ble"          : 0.14.0   , installed 0.14.0
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
      Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
      Adapter    "deconz"       : 1.3.23   , installed 1.3.23
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "fb-checkpresence": 1.2.3 , installed 1.2.3
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "firetv"       : 2.0.2    , installed 2.0.2
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.2
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
      Adapter    "parser"       : 2.1.0    , installed 2.1.0
      Adapter    "paw"          : 0.3.2    , installed 0.3.2
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
      Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "tado"         : 0.5.1    , installed 0.5.1
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
      Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
      Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
      Adapter    "vw-connect"   : 0.0.67   , installed 0.2.0
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Adapter    "yahoo-stock-market": 0.0.5, installed 0.0.5
      Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
      Objects and States
      Objects:        28608
      States:         23231
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://phoscon.de/apt/deconz bullseye InRelease
      Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       19136      1692/io.sonoff.0
      tcp        0      0 192.168.178.76:1883     0.0.0.0:*               LISTEN      1001       20785      1546/io.mqtt.0
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       15595      544/iobroker.js-con
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       15307      544/iobroker.js-con
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       2032       410/deCONZ
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15166      582/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       27186      3676/io.jarvis.0
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       13999      410/deCONZ
      tcp6       0      0 :::1984                 :::*                    LISTEN      1000       13946      418/go2rtc_linux_ar
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15168      582/sshd: /usr/sbin
      tcp6       0      0 :::8555                 :::*                    LISTEN      1000       15521      418/go2rtc_linux_ar
      tcp6       0      0 :::8554                 :::*                    LISTEN      1000       15519      418/go2rtc_linux_ar
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21125      1979/io.web.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       20430      2343/io.simple-api.
      udp        0      0 192.168.178.76:43139    0.0.0.0:*                           1000       29302      418/go2rtc_linux_ar
      udp        0      0 0.0.0.0:35222           0.0.0.0:*                           108        15055      404/avahi-daemon: r
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       18047      1263/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       18048      1263/io.tuya.0
      udp        0      0 0.0.0.0:48490           0.0.0.0:*                           1000       27324      418/go2rtc_linux_ar
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15190      1048/dhcpcd
      udp        0      0 0.0.0.0:41191           0.0.0.0:*                           1000       29280      418/go2rtc_linux_ar
      udp        0      0 192.168.178.76:45324    0.0.0.0:*                           1000       29277      418/go2rtc_linux_ar
      udp        0      0 0.0.0.0:33290           0.0.0.0:*                           1001       22092      2310/io.upnp.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       29300      418/go2rtc_linux_ar
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       27308      418/go2rtc_linux_ar
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24977      2767/io.wled.0
      udp        0      0 192.168.178.76:5353     0.0.0.0:*                           1001       22696      1856/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15053      404/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       16249      1113/io.shelly.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       22347      2310/io.upnp.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       16411      410/deCONZ
      udp6       0      0 2003:e4:7743:6800:35094 :::*                                1000       27310      418/go2rtc_linux_ar
      udp6       0      0 :::43920                :::*                                1000       29279      418/go2rtc_linux_ar
      udp6       0      0 2003:e4:7743:6800:52716 :::*                                1000       29303      418/go2rtc_linux_ar
      udp6       0      0 :::49519                :::*                                108        15056      404/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          19461      1048/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        15054      404/avahi-daemon: r
      udp6       0      0 :::46511                :::*                                1000       27323      418/go2rtc_linux_ar
      2024-02-02 21:21:33.433  - warn: javascript.0 (909)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
      2024-02-02 21:21:33.433  - warn: javascript.0 (909)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2024-02-02 21:21:33.433  - warn: javascript.0 (909)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
      2024-02-02 21:21:33.434  - warn: javascript.0 (909)     at processImmediate (node:internal/timers:476:21)
      2024-02-02 21:21:33.434  - warn: javascript.0 (909) getState "tuya.0.680585848cce4ec0379e.ip" not found (3) states[id]=null
      2024-02-02 21:21:33.435  - warn: javascript.0 (909)     at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:313:24)
      2024-02-02 21:21:33.435  - warn: javascript.0 (909)     at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9)
      2024-02-02 21:21:33.435  - warn: javascript.0 (909)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
      2024-02-02 21:21:33.435  - warn: javascript.0 (909)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2024-02-02 21:21:33.436  - warn: javascript.0 (909)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
      2024-02-02 21:21:33.436  - warn: javascript.0 (909)     at processImmediate (node:internal/timers:476:21)
      2024-02-02 21:21:33.436  - warn: javascript.0 (909) getState "tuya.0.68058584e09806b44933.ip" not found (3) states[id]=null
      2024-02-02 21:21:33.437  - warn: javascript.0 (909)     at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:313:24)
      2024-02-02 21:21:33.437  - warn: javascript.0 (909)     at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9)
      2024-02-02 21:21:33.437  - warn: javascript.0 (909)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
      2024-02-02 21:21:33.437  - warn: javascript.0 (909)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2024-02-02 21:21:33.438  - warn: javascript.0 (909)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
      2024-02-02 21:21:33.441  - warn: javascript.0 (909)     at processImmediate (node:internal/timers:476:21)
      2024-02-02 21:21:33.441  - warn: javascript.0 (909) getState "tuya.0.68058584e09806b44920.ip" not found (3) states[id]=null
      2024-02-02 21:21:33.442  - warn: javascript.0 (909)     at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:313:24)
      2024-02-02 21:21:33.442  - warn: javascript.0 (909)     at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9)
      2024-02-02 21:21:33.443  - warn: javascript.0 (909)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
      2024-02-02 21:21:33.443  - warn: javascript.0 (909)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2024-02-02 21:21:33.443  - warn: javascript.0 (909)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
      2024-02-02 21:21:33.443  - warn: javascript.0 (909)     at processImmediate (node:internal/timers:476:21)
      • Marc_el_K
        @thomas-braun Aber ich komme doch gar nicht auf die Admin Seite?
        • O
          oFbEQnpoLKKl6mbY5e13 @Marc_el_K last edited by
          @marc_el_k
          Nutzt du denn überhaupt NoScript in Verbindung mit Firefox?
          Marc_el_K 1 Reply Last reply Reply Quote 0
          • Marc_el_K
            Marc_el_K @oFbEQnpoLKKl6mbY5e13 last edited by
            @ofbeqnpolkkl6mby5e13 Nein. Ich nutze den Chrome Browser und bis vorhin war die Admin Seite normal erreichbar. Seit dem Update, bleibt der Bildschirm leer.
            O Thomas Braun 2 Replies Last reply Reply Quote 0
            • O
              oFbEQnpoLKKl6mbY5e13 @Marc_el_K last edited by oFbEQnpoLKKl6mbY5e13
              @marc_el_k
              Dann hast du ein gänzlich anderes Problem und das Update auf die neueste Admin-Version wird dir nicht helfen.
                Thomas Braun Most Active @Marc_el_K last edited by Thomas Braun
                @marc_el_k
                Hier liegt dein Problem:
                Reinstallier den per
                iob update
                iobroker upgrade iobroker.admin@6.13.15 --debug
                • Marc_el_K
                  @thomas-braun Oh, vielen Dank. Gehen mir dadurch Daten verloren?
                    ich hab das mal abgetrennt.
                    @Marc_el_K bitte provisorischen Threadtitel anpassen
                    Marc_el_K 1 Reply Last reply Reply Quote 1
                      @marc_el_k sagte in Mach Admin-Update leerer Bildschirm:
                      Natürlich.
                      Und die Katze stirbt auch.
                      • Marc_el_K
                        @thomas-braun Leider ohne Erfolg
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : armhf
                         21:36:41 up 2 min,  1 user,  load average: 5.21, 2.28, 0.87
                        CPU threads: 4
                        Current issues:
                                       Local time: Fri 2024-02-02 21:36:41 CET
                                   Universal time: Fri 2024-02-02 20:36:41 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            7.8G        1.7G        5.5G        0.0K        575M        6.0G
                        Swap:            99M          0B         99M
                        Total:          7.9G        1.7G        5.6G
                                 7812 M total memory
                                 1733 M used memory
                                 1819 M active memory
                                  340 M inactive memory
                                 5502 M free memory
                                   83 M buffer memory
                                  492 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        tmpfs          tmpfs     1.6G  880K  1.6G   1% /run
                        [Fri Feb  2 21:34:04 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:D9:04:68 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  #console=ttyS0,115200 console=tty1 root=PARTUUID=cdb3ca5a-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Fri Feb  2 21:34:05 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                        [Fri Feb  2 21:34:05 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Fri Feb  2 21:34:08 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                        /var:
                        5.2G    /var/
                        2.7G    /var/cache/apt
                        2.7G    /var/cache
                        2.4G    /var/log
                        814M    /opt/iobroker/iobroker-data/
                        493M    /opt/iobroker/iobroker-data/files
                        37M     /opt/iobroker/iobroker-data/objects.jsonl
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-02T20_37_06_330Z-debug-0.log
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.13.15
                        javascript:     7.1.6
                        Adapter State
                        Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
                        /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                                throw e;
                        Error: Connection is closed.
                            at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                            at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                            at Object.onceWrapper (node:events:632:26)
                            at Socket.emit (node:events:517:28)
                            at TCP.<anonymous> (node:net:350:12)
                        Emitted 'error' event on ScanStream instance at:
                            at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                            at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                            at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                            at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                        Node.js v18.19.0
                        Objects and States
                        Objects:        28608
                        States:         23213
                        Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
                        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                        Pending Updates: 0
                        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       11174      410/deCONZ
                        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       29562      3837/io.jarvis.0
                        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       11151      410/deCONZ
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11121      583/sshd: /usr/sbin
                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       14118      546/iobroker.js-con
                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       15581      546/iobroker.js-con
                        tcp        0      0 192.168.178.76:3493     0.0.0.0:*               LISTEN      0          17016      1261/upsd
                        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       20801      1956/io.sonoff.0
                        tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          17017      1261/upsd
                        tcp        0      0 192.168.178.76:1883     0.0.0.0:*               LISTEN      1001       22677      1901/io.mqtt.0
                        tcp6       0      0 :::8554                 :::*                    LISTEN      1000       16427      415/go2rtc_linux_ar
                        tcp6       0      0 :::8555                 :::*                    LISTEN      1000       16430      415/go2rtc_linux_ar
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          11123      583/sshd: /usr/sbin
                        tcp6       0      0 :::1984                 :::*                    LISTEN      1000       13820      415/go2rtc_linux_ar
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21223      2622/io.simple-api.
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20998      2264/io.web.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24845      3075/io.wled.0
                        udp        0      0 192.168.178.76:5353     0.0.0.0:*                           1001       17864      1119/io.tr-064.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10973      404/avahi-daemon: r
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17080      1229/io.shelly.0
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       25773      2589/io.upnp.0
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       11177      410/deCONZ
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19691      1349/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19692      1349/io.tuya.0
                        udp        0      0 0.0.0.0:56396           0.0.0.0:*                           108        10975      404/avahi-daemon: r
                        udp        0      0 0.0.0.0:48585           0.0.0.0:*                           1001       20332      2589/io.upnp.0
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15532      854/dhcpcd
                        udp6       0      0 :::42188                :::*                                108        10976      404/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                108        10974      404/avahi-daemon: r
                        udp6       0      0 :::546                  :::*                                0          11189      854/dhcpcd
                        2024-02-02 21:38:59.245  - warn: javascript.0 (996)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
                        2024-02-02 21:38:59.246  - warn: javascript.0 (996)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
                        2024-02-02 21:38:59.246  - warn: javascript.0 (996)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
                        2024-02-02 21:38:59.246  - warn: javascript.0 (996)     at processImmediate (node:internal/timers:476:21)
                        2024-02-02 21:38:59.246  - warn: javascript.0 (996) getState "tuya.0.680585848cce4ec0379e.ip" not found (3) states[id]=null
                        2024-02-02 21:38:59.247  - warn: javascript.0 (996)     at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:313:24)
                        2024-02-02 21:38:59.248  - warn: javascript.0 (996)     at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9)
                        2024-02-02 21:38:59.248  - warn: javascript.0 (996)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
                        2024-02-02 21:38:59.248  - warn: javascript.0 (996)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
                        2024-02-02 21:38:59.248  - warn: javascript.0 (996)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
                        2024-02-02 21:38:59.248  - warn: javascript.0 (996)     at processImmediate (node:internal/timers:476:21)
                        2024-02-02 21:38:59.248  - warn: javascript.0 (996) getState "tuya.0.68058584e09806b44933.ip" not found (3) states[id]=null
                        2024-02-02 21:38:59.249  - warn: javascript.0 (996)     at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:313:24)
                        2024-02-02 21:38:59.249  - warn: javascript.0 (996)     at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9)
                        2024-02-02 21:38:59.250  - warn: javascript.0 (996)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
                        2024-02-02 21:38:59.252  - warn: javascript.0 (996)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
                        2024-02-02 21:38:59.252  - warn: javascript.0 (996)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
                        2024-02-02 21:38:59.252  - warn: javascript.0 (996)     at processImmediate (node:internal/timers:476:21)
                        2024-02-02 21:38:59.253  - warn: javascript.0 (996) getState "tuya.0.68058584e09806b44920.ip" not found (3) states[id]=null
                        2024-02-02 21:38:59.254  - warn: javascript.0 (996)     at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:313:24)
                        2024-02-02 21:38:59.254  - warn: javascript.0 (996)     at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9)
                        2024-02-02 21:38:59.254  - warn: javascript.0 (996)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
                        2024-02-02 21:38:59.255  - warn: javascript.0 (996)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
                        2024-02-02 21:38:59.255  - warn: javascript.0 (996)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
                        2024-02-02 21:38:59.255  - warn: javascript.0 (996)     at processImmediate (node:internal/timers:476:21)
                        • Marc_el_K
                          Marc_el_K @Homoran last edited by
                          @homoran Danke, würdest du bitte meinn letzten Beitrag ebenfalls hierein setzen?
                            Homoran Global Moderator Administrators @Marc_el_K last edited by
                            @marc_el_k sagte in Problem nach update:
                            aber nur wenn du in der Zwischenzeit den Threadtitel anpasst 😁
                            • Marc_el_K
                              @homoran Danke. Ich suche die Funktion...
                                drei Punkte menü im ersten Posting
                                editieren
                                Dann in den Titel gehen
                                  Leider ohne Erfolg
                                  Das stimmt nicht. Die npm errors wurden weniger.
                                  Jetzt klemmt es hier:
                                  Fehlen da in der ham-Instanz die Module?
                                  • Marc_el_K
                                    @thomas-braun Den nutze ich glaube ich gar nicht mehr...
                                      @marc_el_k
                                      Dann schmeiß den Krempel raus, macht der auch keine Zicken mehr.
                                      iob del iobroker.ham
                                      • Marc_el_K
                                        iob start admin.0
                                        hat nun geholfen
                                          @marc_el_k
                                          Dan zeig jetzt noch mal
                                          iob diag
                                          • Marc_el_K
                                            Skript v.2023-10-10
                                            *** BASE SYSTEM ***
                                                     Icon name: computer
                                                  Architecture: arm64
                                            Docker          : false
                                            Kernel          : aarch64
                                            Userland        : armhf
                                             22:01:32 up 12 min,  1 user,  load average: 1.75, 2.35, 1.75
                                            CPU threads: 4
                                            Current issues:
                                                           Local time: Fri 2024-02-02 22:01:32 CET
                                                       Universal time: Fri 2024-02-02 21:01:32 UTC
                                                             RTC time: n/a
                                                          NTP service: active
                                                      RTC in local TZ: no
                                            pi
                                            /home/pi
                                            X-Server:       false
                                            Desktop:
                                            Terminal:       tty
                                            *** MEMORY ***
                                            Mem:            7.8G        1.9G        5.1G        0.0K        762M        5.8G
                                            Swap:            99M          0B         99M
                                            Total:          7.9G        1.9G        5.2G
                                                     7812 M total memory
                                                     1923 M used memory
                                                     1967 M active memory
                                                     5126 M free memory
                                                      159 M buffer memory
                                                      603 M swap cache
                                                       99 M total swap
                                                        0 M used swap
                                                       99 M free swap
                                            Raspberry only:
                                            oom events: 0
                                            *** FILESYSTEM ***
                                            [Fri Feb  2 21:48:59 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:D9:04:68 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  #console=ttyS0,115200 console=tty1 root=PARTUUID=cdb3ca5a-02 rootfstype=ext4 fsck.repair=yes rootwait
                                            [Fri Feb  2 21:49:00 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                            [Fri Feb  2 21:49:00 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                            [Fri Feb  2 21:49:03 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                            /var:
                                            5.2G    /var/
                                            2.7G    /var/cache/apt
                                            2.7G    /var/cache
                                            2.4G    /var/log
                                            804M    /opt/iobroker/iobroker-data/
                                            28M     /opt/iobroker/iobroker-data/objects.jsonl
                                            USB-Devices by-id:
                                            /usr/bin/npm            10.2.3
                                            /usr/bin/npx            10.2.3
                                            nodejs:
                                              Version table:
                                            Errors in npm tree:
                                            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-02T21_01_41_174Z-debug-0.log
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            admin:          6.13.15
                                            javascript:     7.1.6
                                            Adapter State
                                            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                            + system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                                            + instance is alive
                                            Objects and States
                                            Objects:        28595
                                            States:         23209
                                            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                            Pending Updates: 0
                                            tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       17356      1570/io.sonoff.0
                                            tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          16890      1228/upsd
                                            tcp        0      0 192.168.178.76:1883     0.0.0.0:*               LISTEN      1001       19791      1481/io.mqtt.0
                                            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       16545      532/iobroker.js-con
                                            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       12052      532/iobroker.js-con
                                            tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       30133      3868/io.jarvis.0
                                            tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       11903      410/deCONZ
                                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11882      582/sshd: /usr/sbin
                                            tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       14984      410/deCONZ
                                            tcp        0      0 192.168.178.76:3493     0.0.0.0:*               LISTEN      0          16889      1228/upsd
                                            tcp6       0      0 :::1984                 :::*                    LISTEN      1000       14955      413/go2rtc_linux_ar
                                            tcp6       0      0 :::22                   :::*                    LISTEN      0          11884      582/sshd: /usr/sbin
                                            tcp6       0      0 :::8555                 :::*                    LISTEN      1000       15626      413/go2rtc_linux_ar
                                            tcp6       0      0 :::8554                 :::*                    LISTEN      1000       15623      413/go2rtc_linux_ar
                                            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23642      2151/io.simple-api.
                                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20110      1796/io.web.0
                                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       52561      9084/io.admin.0
                                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23029      2890/io.wled.0
                                            udp        0      0 192.168.178.76:5353     0.0.0.0:*                           1001       16344      1090/io.tr-064.0
                                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2008       404/avahi-daemon: r
                                            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       16333      1198/io.shelly.0
                                            udp        0      0 0.0.0.0:46853           0.0.0.0:*                           108        2010       404/avahi-daemon: r
                                            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       22369      2126/io.upnp.0
                                            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       16505      410/deCONZ
                                            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       18978      1280/io.tuya.0
                                            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       18979      1280/io.tuya.0
                                            udp        0      0 0.0.0.0:36575           0.0.0.0:*                           1001       21943      2126/io.upnp.0
                                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16508      820/dhcpcd
                                            udp6       0      0 :::546                  :::*                                0          65344      820/dhcpcd
                                            udp6       0      0 :::5353                 :::*                                108        2009       404/avahi-daemon: r
                                            udp6       0      0 :::42682                :::*                                108        2011       404/avahi-daemon: r
                                            2024-02-02 22:03:00.022  - warn: javascript.0 (985)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
                                            2024-02-02 22:03:00.022  - warn: javascript.0 (985)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
                                            2024-02-02 22:03:00.022  - warn: javascript.0 (985)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
                                            2024-02-02 22:03:00.023  - warn: javascript.0 (985)     at processImmediate (node:internal/timers:476:21)
                                            2024-02-02 22:03:00.025  - error: javascript.0 (985) Error in callback: TypeError: Cannot read properties of null (reading 'substring')
                                            2024-02-02 22:03:00.026  - error: javascript.0 (985)     at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:251:50)
                                            2024-02-02 22:03:00.026  - error: javascript.0 (985)     at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9)
                                            2024-02-02 22:03:00.026  - error: javascript.0 (985)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
                                            2024-02-02 22:03:00.027  - error: javascript.0 (985)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
                                            2024-02-02 22:03:00.039  - error: javascript.0 (985)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
                                            2024-02-02 22:03:00.040  - error: javascript.0 (985)     at processImmediate (node:internal/timers:476:21)
                                            2024-02-02 22:03:00.465  - warn: javascript.0 (985) getState "alexa2.0.Echo-Devices.G0911M09951329SR.Info.macAddress" not found (3)
                                            2024-02-02 22:03:00.466  - warn: javascript.0 (985)     at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:251:24)
                                            2024-02-02 22:03:00.467  - warn: javascript.0 (985)     at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9)
                                            2024-02-02 22:03:00.467  - warn: javascript.0 (985)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
                                            2024-02-02 22:03:00.467  - warn: javascript.0 (985)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
                                            2024-02-02 22:03:00.467  - warn: javascript.0 (985)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
                                            2024-02-02 22:03:00.468  - warn: javascript.0 (985)     at processImmediate (node:internal/timers:476:21)
                                            2024-02-02 22:03:00.469  - error: javascript.0 (985) Error in callback: TypeError: Cannot read properties of null (reading 'substring')
                                            2024-02-02 22:03:00.470  - error: javascript.0 (985)     at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:251:50)
                                            2024-02-02 22:03:00.470  - error: javascript.0 (985)     at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9)
                                            2024-02-02 22:03:00.470  - error: javascript.0 (985)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
                                            2024-02-02 22:03:00.470  - error: javascript.0 (985)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
                                            2024-02-02 22:03:00.470  - error: javascript.0 (985)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
                                            2024-02-02 22:03:00.471  - error: javascript.0 (985)     at processImmediate (node:internal/timers:476:21)
                                            1260
