Admin Seite nach Update auf 6.13.15 nicht erreichbar
@marc_el_k sagte in Problem nach update:
Leider ohne Erfolg
Das stimmt nicht. Die npm errors wurden weniger.
Jetzt klemmt es hier:
npm ERR! missing: homebridge-camera-ffmpeg@^3.1.4, required by iobroker.ham@5.3.1 npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
Fehlen da in der ham-Instanz die Module?
@thomas-braun Den nutze ich glaube ich gar nicht mehr...
======== Start marking the full check here =========Skript v.2023-10-10 *** BASE SYSTEM *** Static hostname: raspberrypi Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 6.1.21-v8+ Architecture: arm64 Model : Raspberry Pi 4 Model B Rev 1.4 Docker : false Virtualization : none Kernel : aarch64 Userland : armhf Systemuptime and Load: 22:01:32 up 12 min, 1 user, load average: 1.75, 2.35, 1.75 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Fri 2024-02-02 22:01:32 CET Universal time: Fri 2024-02-02 21:01:32 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** User and Groups *** pi /home/pi pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: graphical.target *** MEMORY *** total used free shared buff/cache available Mem: 7.8G 1.9G 5.1G 0.0K 762M 5.8G Swap: 99M 0B 99M Total: 7.9G 1.9G 5.2G 7812 M total memory 1923 M used memory 1967 M active memory 492 M inactive memory 5126 M free memory 159 M buffer memory 603 M swap cache 99 M total swap 0 M used swap 99 M free swap Raspberry only: oom events: 0 lifetime oom required: 0 Mbytes total time in oom handler: 0 ms max time spent in oom handler: 0 ms *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 117G 19G 94G 17% / devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 1.6G 880K 1.6G 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 253M 51M 202M 20% /boot /dev/sda1 vfat 233G 30G 204G 13% /media/usb tmpfs tmpfs 782M 0 782M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Fri Feb 2 21:48:59 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=DC:A6:32:D9:04:68 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 #console=ttyS0,115200 console=tty1 root=PARTUUID=cdb3ca5a-02 rootfstype=ext4 fsck.repair=yes rootwait [Fri Feb 2 21:49:00 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none. [Fri Feb 2 21:49:00 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Fri Feb 2 21:49:03 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none. Show mounted filesystems \(real ones only\): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime |-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro `-/media/usb /dev/sda1 vfat rw,nosuid,nodev,noexec,relatime,sync,fmask=0000,dmask=0000,allow_utime=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 5.2G /var/ 2.7G /var/cache/apt 2.7G /var/cache 2.6G /var/cache/apt/archives 2.4G /var/log Archived and active journals take up 2.2G in the file system. /opt/iobroker/backups: 1.6G /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 804M /opt/iobroker/iobroker-data/ 493M /opt/iobroker/iobroker-data/files 234M /opt/iobroker/iobroker-data/backup-objects 89M /opt/iobroker/iobroker-data/files/echarts.admin 67M /opt/iobroker/iobroker-data/files/javascript.admin The five largest files in iobroker-data are: 33M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map 28M /opt/iobroker/iobroker-data/objects.jsonl 24M /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map 24M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map 23M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id': find: '/dev/serial/by-id/': No such file or directory *** NodeJS-Installation *** /usr/bin/nodejs v18.19.0 /usr/bin/node v18.19.0 /usr/bin/npm 10.2.3 /usr/bin/npx 10.2.3 /usr/bin/corepack 0.22.0 nodejs: Installed: 18.19.0-1nodesource1 Candidate: 18.19.0-1nodesource1 Version table: *** 18.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 18.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.2-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.1-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 18.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages 12.22.12~dfsg-1~deb11u4 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: npm ERR! code ELSPROBLEMS npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2 npm ERR! extraneous: undici-types@5.26.5 /opt/iobroker/node_modules/undici-types npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data npm ERR! missing: homebridge-camera-ffmpeg@^3.1.4, required by iobroker.ham@5.3.1 npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1 npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-02T21_01_41_174Z-debug-0.log *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.17 admin: 6.13.15 javascript: 7.1.6 Adapters from github: 6 Adapter State + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : raspberrypi - enabled + system.adapter.backitup.0 : backitup : raspberrypi - enabled + system.adapter.ble.1 : ble : raspberrypi - enabled + system.adapter.bring.0 : bring : raspberrypi - enabled + system.adapter.daswetter.0 : daswetter : raspberrypi - enabled system.adapter.discovery.0 : discovery : raspberrypi - disabled + system.adapter.dwd.0 : dwd : raspberrypi - enabled + system.adapter.echarts.0 : echarts : raspberrypi - enabled + system.adapter.esphome.0 : esphome : raspberrypi - enabled system.adapter.feiertage.0 : feiertage : raspberrypi - enabled + system.adapter.fritzdect.0 : fritzdect : raspberrypi - enabled + system.adapter.fullybrowser.0 : fullybrowser : raspberrypi - enabled system.adapter.ham.0 : ham : raspberrypi - disabled + system.adapter.history.0 : history : raspberrypi - enabled + system.adapter.homeconnect.0 : homeconnect : raspberrypi - enabled system.adapter.ical.0 : ical : raspberrypi - enabled + system.adapter.info.0 : info : raspberrypi - enabled + system.adapter.iot.0 : iot : raspberrypi - enabled + system.adapter.jarvis.0 : jarvis : raspberrypi - enabled + system.adapter.javascript.0 : javascript : raspberrypi - enabled + system.adapter.meross.0 : meross : raspberrypi - enabled + system.adapter.mqtt.0 : mqtt : raspberrypi - enabled, port: 1883, bind: 192.168.178.76 + system.adapter.nut.0 : nut : raspberrypi - enabled system.adapter.octoprint.0 : octoprint : raspberrypi - disabled + system.adapter.parser.0 : parser : raspberrypi - enabled system.adapter.paw.0 : paw : raspberrypi - disabled, port: 8898 system.adapter.ping.0 : ping : raspberrypi - disabled + system.adapter.pollenflug.0 : pollenflug : raspberrypi - enabled + system.adapter.pvforecast.0 : pvforecast : raspberrypi - enabled + system.adapter.rpi2.0 : rpi2 : raspberrypi - enabled + system.adapter.rssfeed.0 : rssfeed : raspberrypi - enabled + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspberrypi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1885, bind: 0.0.0.0 + system.adapter.tado.0 : tado : raspberrypi - enabled + system.adapter.tankerkoenig.1 : tankerkoenig : raspberrypi - enabled system.adapter.telegram.0 : telegram : raspberrypi - disabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : raspberrypi - enabled + system.adapter.tr-064.0 : tr-064 : raspberrypi - enabled + system.adapter.trashschedule.0 : trashschedule : raspberrypi - enabled + system.adapter.tuya.0 : tuya : raspberrypi - enabled system.adapter.tvspielfilm.0 : tvspielfilm : raspberrypi - enabled + system.adapter.upnp.0 : upnp : raspberrypi - enabled + system.adapter.viessmannapi.0 : viessmannapi : raspberrypi - enabled system.adapter.vis.0 : vis : raspberrypi - disabled + system.adapter.vw-connect.0 : vw-connect : raspberrypi - enabled system.adapter.weatherunderground.0 : weatherunderground : raspberrypi - enabled + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : raspberrypi - enabled + system.adapter.wled.0 : wled : raspberrypi - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.mqtt.0 : mqtt : raspberrypi - enabled, port: 1883, bind: 192.168.178.76 + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : raspberrypi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : raspberrypi - enabled, port: 1885, bind: 0.0.0.0 + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories Stable (default): http://download.iobroker.net/sources-dist.json Beta (latest) : http://download.iobroker.net/sources-dist-latest.json Active repo(s): Stable (default) Installed ioBroker-Instances Used repository: Stable (default) Adapter "admin" : 6.13.15 , installed 6.13.15 Adapter "alexa2" : 3.26.4 , installed 3.26.4 Adapter "backitup" : 2.9.8 , installed 2.9.8 Adapter "ble" : 0.14.0 , installed 0.14.0 Adapter "bring" : 1.8.4 , installed 1.8.4 Adapter "chromecast" : 3.0.3 , installed 3.0.3 Adapter "daswetter" : 3.1.13 , installed 3.1.13 Adapter "deconz" : 1.3.23 , installed 1.3.23 Adapter "discovery" : 4.2.0 , installed 4.2.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 1.7.2 , installed 1.7.2 Adapter "fb-checkpresence": 1.2.3 , installed 1.2.3 Adapter "feiertage" : 1.1.4 , installed 1.1.4 Adapter "firetv" : 2.0.2 , installed 2.0.2 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "fritzdect" : 2.5.9 , installed 2.5.9 Adapter "fullybrowser" : 3.0.9 , installed 3.0.9 Adapter "ham" : 5.3.1 , installed 5.3.1 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "homeconnect" : 1.3.0 , installed 1.3.0 Adapter "ical" : 1.13.3 , installed 1.13.3 Adapter "info" : 2.0.0 , installed 2.0.0 Adapter "iot" : 2.0.11 , installed 2.0.11 Adapter "jarvis" : 3.1.8 , installed 3.1.9-beta.2 Adapter "javascript" : 7.1.6 , installed 7.1.6 Controller "js-controller": 5.0.17 , installed 5.0.17 Adapter "meross" : 1.17.0 , installed 1.17.0 Adapter "mqtt" : 5.1.0 , installed 5.1.0 Adapter "net-tools" : 0.2.0 , installed 0.2.0 Adapter "nut" : 1.6.0 , installed 1.6.0 Adapter "octoprint" : 5.1.0 , installed 5.1.0 Adapter "parser" : 2.1.0 , installed 2.1.0 Adapter "paw" : 0.3.2 , installed 0.3.2 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "pollenflug" : 1.0.6 , installed 1.0.6 Adapter "pvforecast" : 2.9.1 , installed 2.9.1 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "rssfeed" : 2.6.1 , installed 2.6.1 Adapter "shelly" : 6.6.1 , installed 6.6.1 Adapter "simple-api" : 2.7.2 , installed 2.7.2 Adapter "socketio" : 6.6.0 , installed 6.6.0 Adapter "sonoff" : 3.0.3 , installed 3.0.3 Adapter "tado" : 0.5.1 , installed 0.5.1 Adapter "tankerkoenig" : 3.3.7 , installed 3.3.7 Adapter "telegram" : 3.0.1 , installed 3.0.1 Adapter "text2command" : 3.0.3 , installed 3.0.3 Adapter "tr-064" : 4.2.18 , installed 4.2.18 Adapter "trashschedule": 2.3.0 , installed 2.3.0 Adapter "tuya" : 3.15.0 , installed 3.15.0 Adapter "tvprogram" : 1.1.2 , installed 1.1.2 Adapter "tvspielfilm" : 2.0.5 , installed 2.0.5 Adapter "upnp" : 1.0.21 , installed 1.0.21 Adapter "viessmannapi" : 2.3.0 , installed 2.3.0 Adapter "virtualpowermeter": 1.4.6, installed 1.4.6 Adapter "vis" : 1.5.4 , installed 1.5.4 Adapter "vw-connect" : 0.0.67 , installed 0.2.0 Adapter "weatherunderground": 3.6.0, installed 3.6.0 Adapter "web" : 6.2.3 , installed 6.2.3 Adapter "whatsapp-cmb" : 0.2.3 , installed 0.2.3 Adapter "wled" : 0.7.2 , installed 0.7.2 Adapter "ws" : 2.5.10 , installed 2.5.10 Adapter "yahoo-stock-market": 0.0.5, installed 0.0.5 Adapter "zigbee2mqtt" : 2.13.4 , installed 2.13.4 Objects and States Please stand by - This may take a while Objects: 28595 States: 23209 *** OS-Repositories and Updates *** Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:2 http://phoscon.de/apt/deconz bullseye InRelease Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:1885 0.0.0.0:* LISTEN 1001 17356 1570/io.sonoff.0 tcp 0 0 127.0.0.1:3493 0.0.0.0:* LISTEN 0 16890 1228/upsd tcp 0 0 192.168.178.76:1883 0.0.0.0:* LISTEN 1001 19791 1481/io.mqtt.0 tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 16545 532/iobroker.js-con tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 12052 532/iobroker.js-con tcp 0 0 0.0.0.0:8400 0.0.0.0:* LISTEN 1001 30133 3868/io.jarvis.0 tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 1000 11903 410/deCONZ tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 11882 582/sshd: /usr/sbin tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 1000 14984 410/deCONZ tcp 0 0 192.168.178.76:3493 0.0.0.0:* LISTEN 0 16889 1228/upsd tcp6 0 0 :::1984 :::* LISTEN 1000 14955 413/go2rtc_linux_ar tcp6 0 0 :::22 :::* LISTEN 0 11884 582/sshd: /usr/sbin tcp6 0 0 :::8555 :::* LISTEN 1000 15626 413/go2rtc_linux_ar tcp6 0 0 :::8554 :::* LISTEN 1000 15623 413/go2rtc_linux_ar tcp6 0 0 :::8087 :::* LISTEN 1001 23642 2151/io.simple-api. tcp6 0 0 :::8082 :::* LISTEN 1001 20110 1796/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 52561 9084/io.admin.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 23029 2890/io.wled.0 udp 0 0 192.168.178.76:5353 0.0.0.0:* 1001 16344 1090/io.tr-064.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 2008 404/avahi-daemon: r udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 16333 1198/io.shelly.0 udp 0 0 0.0.0.0:46853 0.0.0.0:* 108 2010 404/avahi-daemon: r udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 22369 2126/io.upnp.0 udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 16505 410/deCONZ udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 18978 1280/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 18979 1280/io.tuya.0 udp 0 0 0.0.0.0:36575 0.0.0.0:* 1001 21943 2126/io.upnp.0 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 16508 820/dhcpcd udp6 0 0 :::546 :::* 0 65344 820/dhcpcd udp6 0 0 :::5353 :::* 108 2009 404/avahi-daemon: r udp6 0 0 :::42682 :::* 108 2011 404/avahi-daemon: r *** Log File - Last 25 Lines *** 2024-02-02 22:03:00.022 - warn: javascript.0 (985) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38) 2024-02-02 22:03:00.022 - warn: javascript.0 (985) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29) 2024-02-02 22:03:00.022 - warn: javascript.0 (985) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62) 2024-02-02 22:03:00.023 - warn: javascript.0 (985) at processImmediate (node:internal/timers:476:21) 2024-02-02 22:03:00.025 - error: javascript.0 (985) Error in callback: TypeError: Cannot read properties of null (reading 'substring') 2024-02-02 22:03:00.026 - error: javascript.0 (985) at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:251:50) 2024-02-02 22:03:00.026 - error: javascript.0 (985) at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9) 2024-02-02 22:03:00.026 - error: javascript.0 (985) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38) 2024-02-02 22:03:00.027 - error: javascript.0 (985) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29) 2024-02-02 22:03:00.039 - error: javascript.0 (985) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62) 2024-02-02 22:03:00.040 - error: javascript.0 (985) at processImmediate (node:internal/timers:476:21) 2024-02-02 22:03:00.465 - warn: javascript.0 (985) getState "alexa2.0.Echo-Devices.G0911M09951329SR.Info.macAddress" not found (3) 2024-02-02 22:03:00.466 - warn: javascript.0 (985) at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:251:24) 2024-02-02 22:03:00.467 - warn: javascript.0 (985) at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9) 2024-02-02 22:03:00.467 - warn: javascript.0 (985) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38) 2024-02-02 22:03:00.467 - warn: javascript.0 (985) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29) 2024-02-02 22:03:00.467 - warn: javascript.0 (985) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62) 2024-02-02 22:03:00.468 - warn: javascript.0 (985) at processImmediate (node:internal/timers:476:21) 2024-02-02 22:03:00.469 - error: javascript.0 (985) Error in callback: TypeError: Cannot read properties of null (reading 'substring') 2024-02-02 22:03:00.470 - error: javascript.0 (985) at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:251:50) 2024-02-02 22:03:00.470 - error: javascript.0 (985) at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9) 2024-02-02 22:03:00.470 - error: javascript.0 (985) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38) 2024-02-02 22:03:00.470 - error: javascript.0 (985) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29) 2024-02-02 22:03:00.470 - error: javascript.0 (985) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62) 2024-02-02 22:03:00.471 - error: javascript.0 (985) at processImmediate (node:internal/timers:476:21)
da sind noch
@marc_el_k sagte in Admin Seite nach Update auf 6.13.15 nicht erreichbar:
ELSPROBLEMS
und Probleme mit der fremden Frau im Haus
Kernel : aarch64
Userland : armhfStell das in den nächsten Monaten auf eine reines 64Bit-System um. Geht aber nur per Neuinstallation (Dann halt direkt Raspberry OS 12 installieren).
Setz das auf
sudo systemctl set-default multi-user.target
Hattest du den ham-Adapter nicht rausgeworfen?
Der zickt aber noch herum. -
@homoran sagte in Admin Seite nach Update auf 6.13.15 nicht erreichbar:
da sind noch
ELSPROBLEMS
Was heißt das?
da sind noch
ELSPROBLEMS
Was heißt das?
deine Alexa gat wohl die IP gewechselt
Im Skript
sind Fehler enthalten. -
@thomas-braun sagte in Admin Seite nach Update auf 6.13.15 nicht erreichbar:
Setz das auf
sudo systemctl set-default multi-user.targetHattest du den ham-Adapter nicht rausgeworfen?
Der zickt aber noch herum.Hab ich gesetzt.
Den HAM Adapter habe ich nicht entfernt, da ich ihn noch nutze.
Dann schau dir die angemeckerten Module an. Irgendwas klemmt da.
Das ist mir gar nicht bewusst gewesen. Danke für den Hinweis. Zu blöd, dass ich dafür ne Neuinstallation brauche. Ich habe auf meinem Raspberry weitere Dinge eingerichtet, wo ich nicht mal mehr weiß ob ich die Anleitungen noch finde 🫣
PS: den ham Adapter habe jetzt deinstalliert.
