    4. Admin Seite nach Update auf 6.13.15 nicht erreichbar
      Thomas Braun Most Active @Marc_el_K last edited by
      @marc_el_k
      Dan zeig jetzt noch mal
      iob diag
      Marc_el_K 1 Reply Last reply Reply Quote 0
      • Marc_el_K
        Marc_el_K @Thomas Braun last edited by
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : armhf
        Systemuptime and Load:
         22:01:32 up 12 min,  1 user,  load average: 1.75, 2.35, 1.75
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Fri 2024-02-02 22:01:32 CET
                   Universal time: Fri 2024-02-02 21:01:32 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            7.8G        1.9G        5.1G        0.0K        762M        5.8G
        Swap:            99M          0B         99M
        Total:          7.9G        1.9G        5.2G
                 7812 M total memory
                 1923 M used memory
                 1967 M active memory
                  492 M inactive memory
                 5126 M free memory
                  159 M buffer memory
                  603 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4      117G   19G   94G  17% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  880K  1.6G   1% /run
        /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
        /dev/sda1      vfat      233G   30G  204G  13% /media/usb
        tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
        [Fri Feb  2 21:48:59 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:D9:04:68 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  #console=ttyS0,115200 console=tty1 root=PARTUUID=cdb3ca5a-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Fri Feb  2 21:49:00 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Fri Feb  2 21:49:00 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Fri Feb  2 21:49:03 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET       SOURCE         FSTYPE OPTIONS
        /            /dev/mmcblk0p2 ext4   rw,noatime
        |-/boot      /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        `-/media/usb /dev/sda1      vfat   rw,nosuid,nodev,noexec,relatime,sync,fmask=0000,dmask=0000,allow_utime=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        5.2G    /var/
        2.7G    /var/cache/apt
        2.7G    /var/cache
        2.6G    /var/cache/apt/archives
        2.4G    /var/log
        Archived and active journals take up 2.2G in the file system.
        /opt/iobroker/backups:
        1.6G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        804M    /opt/iobroker/iobroker-data/
        493M    /opt/iobroker/iobroker-data/files
        234M    /opt/iobroker/iobroker-data/backup-objects
        89M     /opt/iobroker/iobroker-data/files/echarts.admin
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        28M     /opt/iobroker/iobroker-data/objects.jsonl
        24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
        npm ERR! extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
        npm ERR! extraneous: coffeescript@2.7.0 /opt/iobroker/node_modules/coffeescript
        npm ERR! extraneous: jsonata@2.0.3 /opt/iobroker/node_modules/jsonata
        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
        npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
        npm ERR! extraneous: undici-types@5.26.5 /opt/iobroker/node_modules/undici-types
        npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
        npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
        npm ERR! missing: homebridge-camera-ffmpeg@^3.1.4, required by iobroker.ham@5.3.1
        npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
        npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
        npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-02-02T21_01_41_174Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.13.15
        javascript:     7.1.6
        Adapters from github:   6
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        + system.adapter.ble.1                    : ble                   : raspberrypi                              -  enabled
        + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled
        + system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
          system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
        + system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
        + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
        + system.adapter.esphome.0                : esphome               : raspberrypi                              -  enabled
          system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
          system.adapter.ham.0                    : ham                   : raspberrypi                              - disabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.76
        + system.adapter.nut.0                    : nut                   : raspberrypi                              -  enabled
          system.adapter.octoprint.0              : octoprint             : raspberrypi                              - disabled
        + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
          system.adapter.paw.0                    : paw                   : raspberrypi                              - disabled, port: 8898
          system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
        + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
        + system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        + system.adapter.rssfeed.0                : rssfeed               : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
        + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
        + system.adapter.tankerkoenig.1           : tankerkoenig          : raspberrypi                              -  enabled
          system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
        + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
          system.adapter.tvspielfilm.0            : tvspielfilm           : raspberrypi                              -  enabled
        + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
        + system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
        + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
        + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): Stable (default)
        Installed ioBroker-Instances
        Used repository: Stable (default)
        Adapter    "admin"        : 6.13.15  , installed 6.13.15
        Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "ble"          : 0.14.0   , installed 0.14.0
        Adapter    "bring"        : 1.8.4    , installed 1.8.4
        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
        Adapter    "deconz"       : 1.3.23   , installed 1.3.23
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "fb-checkpresence": 1.2.3 , installed 1.2.3
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "firetv"       : 2.0.2    , installed 2.0.2
        Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
        Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.2
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "meross"       : 1.17.0   , installed 1.17.0
        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
        Adapter    "parser"       : 2.1.0    , installed 2.1.0
        Adapter    "paw"          : 0.3.2    , installed 0.3.2
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
        Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "tado"         : 0.5.1    , installed 0.5.1
        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
        Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
        Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
        Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
        Adapter    "vw-connect"   : 0.0.67   , installed 0.2.0
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "wled"         : 0.7.2    , installed 0.7.2
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Adapter    "yahoo-stock-market": 0.0.5, installed 0.0.5
        Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
        Objects and States
        Objects:        28595
        States:         23209
        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:2 http://phoscon.de/apt/deconz bullseye InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       17356      1570/io.sonoff.0
        tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          16890      1228/upsd
        tcp        0      0 192.168.178.76:1883     0.0.0.0:*               LISTEN      1001       19791      1481/io.mqtt.0
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       16545      532/iobroker.js-con
        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       12052      532/iobroker.js-con
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       30133      3868/io.jarvis.0
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       11903      410/deCONZ
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11882      582/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       14984      410/deCONZ
        tcp        0      0 192.168.178.76:3493     0.0.0.0:*               LISTEN      0          16889      1228/upsd
        tcp6       0      0 :::1984                 :::*                    LISTEN      1000       14955      413/go2rtc_linux_ar
        tcp6       0      0 :::22                   :::*                    LISTEN      0          11884      582/sshd: /usr/sbin
        tcp6       0      0 :::8555                 :::*                    LISTEN      1000       15626      413/go2rtc_linux_ar
        tcp6       0      0 :::8554                 :::*                    LISTEN      1000       15623      413/go2rtc_linux_ar
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23642      2151/io.simple-api.
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20110      1796/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       52561      9084/io.admin.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       23029      2890/io.wled.0
        udp        0      0 192.168.178.76:5353     0.0.0.0:*                           1001       16344      1090/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        2008       404/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       16333      1198/io.shelly.0
        udp        0      0 0.0.0.0:46853           0.0.0.0:*                           108        2010       404/avahi-daemon: r
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       22369      2126/io.upnp.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       16505      410/deCONZ
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       18978      1280/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       18979      1280/io.tuya.0
        udp        0      0 0.0.0.0:36575           0.0.0.0:*                           1001       21943      2126/io.upnp.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16508      820/dhcpcd
        udp6       0      0 :::546                  :::*                                0          65344      820/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        2009       404/avahi-daemon: r
        udp6       0      0 :::42682                :::*                                108        2011       404/avahi-daemon: r
        2024-02-02 22:03:00.022  - warn: javascript.0 (985)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
        2024-02-02 22:03:00.022  - warn: javascript.0 (985)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2024-02-02 22:03:00.022  - warn: javascript.0 (985)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
        2024-02-02 22:03:00.023  - warn: javascript.0 (985)     at processImmediate (node:internal/timers:476:21)
        2024-02-02 22:03:00.025  - error: javascript.0 (985) Error in callback: TypeError: Cannot read properties of null (reading 'substring')
        2024-02-02 22:03:00.026  - error: javascript.0 (985)     at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:251:50)
        2024-02-02 22:03:00.026  - error: javascript.0 (985)     at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9)
        2024-02-02 22:03:00.026  - error: javascript.0 (985)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
        2024-02-02 22:03:00.027  - error: javascript.0 (985)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2024-02-02 22:03:00.039  - error: javascript.0 (985)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
        2024-02-02 22:03:00.040  - error: javascript.0 (985)     at processImmediate (node:internal/timers:476:21)
        2024-02-02 22:03:00.465  - warn: javascript.0 (985) getState "alexa2.0.Echo-Devices.G0911M09951329SR.Info.macAddress" not found (3)
        2024-02-02 22:03:00.466  - warn: javascript.0 (985)     at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:251:24)
        2024-02-02 22:03:00.467  - warn: javascript.0 (985)     at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9)
        2024-02-02 22:03:00.467  - warn: javascript.0 (985)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
        2024-02-02 22:03:00.467  - warn: javascript.0 (985)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2024-02-02 22:03:00.467  - warn: javascript.0 (985)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
        2024-02-02 22:03:00.468  - warn: javascript.0 (985)     at processImmediate (node:internal/timers:476:21)
        2024-02-02 22:03:00.469  - error: javascript.0 (985) Error in callback: TypeError: Cannot read properties of null (reading 'substring')
        2024-02-02 22:03:00.470  - error: javascript.0 (985)     at setJSON (script.js.common.Netzwerk_Geräte.JSON_mit_Links:251:50)
        2024-02-02 22:03:00.470  - error: javascript.0 (985)     at Object.<anonymous> (script.js.common.Netzwerk_Geräte.JSON_mit_Links:118:9)
        2024-02-02 22:03:00.470  - error: javascript.0 (985)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
        2024-02-02 22:03:00.470  - error: javascript.0 (985)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2024-02-02 22:03:00.470  - error: javascript.0 (985)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
        2024-02-02 22:03:00.471  - error: javascript.0 (985)     at processImmediate (node:internal/timers:476:21)
          Homoran Global Moderator Administrators @Marc_el_K last edited by
          da sind noch
          @marc_el_k sagte in Admin Seite nach Update auf 6.13.15 nicht erreichbar:
          ELSPROBLEMS
          und Probleme mit der fremden Frau im Haus
            Kernel : aarch64
            Userland : armhf
            Stell das in den nächsten Monaten auf eine reines 64Bit-System um. Geht aber nur per Neuinstallation (Dann halt direkt Raspberry OS 12 installieren).
            Boot Target: graphical.target
            Setz das auf
            sudo systemctl set-default multi-user.target
            Hattest du den ham-Adapter nicht rausgeworfen?
            Der zickt aber noch herum.
            • Marc_el_K
              Marc_el_K @Homoran last edited by
              @homoran sagte in Admin Seite nach Update auf 6.13.15 nicht erreichbar:
              da sind noch
              ELSPROBLEMS
              Was heißt das?
                da sind noch
                ELSPROBLEMS
                Was heißt das?
                deine Alexa gat wohl die IP gewechselt
                  @marc_el_k
                  Im Skript Netzwerk_Geräte.JSON_mit_Links sind Fehler enthalten.
                  • Marc_el_K
                    @thomas-braun sagte in Admin Seite nach Update auf 6.13.15 nicht erreichbar:
                    Setz das auf
                    Hab ich gesetzt.
                    Den HAM Adapter habe ich nicht entfernt, da ich ihn noch nutze.
                      Dann schau dir die angemeckerten Module an. Irgendwas klemmt da.
                      • Marc_el_K
                        Das ist mir gar nicht bewusst gewesen. Danke für den Hinweis. Zu blöd, dass ich dafür ne Neuinstallation brauche. Ich habe auf meinem Raspberry weitere Dinge eingerichtet, wo ich nicht mal mehr weiß ob ich die Anleitungen noch finde 🫣
                        PS: den ham Adapter habe jetzt deinstalliert.
                        1251
