    4. Update js-Controller 3.x auf 5.x funktioniert nicht
      Frank-KNX @Thomas Braun last edited by
      Hier die aktuelle Version:
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       00:47:21 up 4 min,  3 users,  load average: 0.92, 1.06, 0.53
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sat 2024-02-03 00:47:21 CET
                 Universal time: Fri 2024-02-02 23:47:21 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           7.9G        1.0G        6.3G         40M        572M        6.6G
      Swap:           99M          0B         99M
      Total:         8.0G        1.0G        6.4G
               7898 M total memory
               1023 M used memory
                197 M active memory
               1257 M inactive memory
               6302 M free memory
                 70 M buffer memory
                502 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
      * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      /dev/root      ext4      117G   11G  103G   9% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     3.9G  8.7M  3.9G   1% /run
      tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     790M  4.0K  790M   1% /run/user/1000
      [Sat Feb  3 00:42:27 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:D3:7A:A7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=def5eda3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sat Feb  3 00:42:28 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Sat Feb  3 00:42:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sat Feb  3 00:42:31 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      TARGET                SOURCE         FSTYPE          OPTIONS
      /                     /dev/mmcblk0p2 ext4            rw,noatime
      |-/sys/fs/bpf         none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
      |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.5G    /var/
      1.1G    /var/cache/apt/archives
      1.1G    /var/cache/apt
      1.1G    /var/cache
      262M    /var/lib
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      101M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      148M    /opt/iobroker/iobroker-data/
      69M     /opt/iobroker/iobroker-data/files
      59M     /opt/iobroker/iobroker-data/backup-objects
      16M     /opt/iobroker/iobroker-data/files/javascript.admin
      13M     /opt/iobroker/iobroker-data/files/vis.0
      6.3M    /opt/iobroker/iobroker-data/objects.json.bak
      4.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.7e0b7583.chunk.js.map
      3.5M    /opt/iobroker/iobroker-data/files/vis.0/Grundriss_final.png
      3.4M    /opt/iobroker/iobroker-data/files/vis.0/Parkplatz.jpg
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: file
      States  type: file
      Core adapters versions
      js-controller:  3.1.6
      admin:          4.1.11
      javascript:     4.8.4
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.discovery.0             : discovery             -  enabled
        system.adapter.ical.0                  : ical                  -  enabled
        system.adapter.icons-mfd-png.0         : icons-mfd-png         -  enabled
      + system.adapter.influxdb.0              : influxdb              -  enabled, port: 8086
      + system.adapter.info.0                  : info                  -  enabled
      + system.adapter.javascript.0            : javascript            -  enabled
      + system.adapter.knx.0                   : knx                   -  enabled, bind: 192.168.2.98
      + system.adapter.linux-control.0         : linux-control         -  enabled
      + system.adapter.meldungsliste.0         : meldungsliste         -  enabled
      + system.adapter.meldungsliste.1         : meldungsliste         -  enabled
      + system.adapter.meldungsliste.10        : meldungsliste         -  enabled
      + system.adapter.meldungsliste.11        : meldungsliste         -  enabled
      + system.adapter.meldungsliste.12        : meldungsliste         -  enabled
      + system.adapter.meldungsliste.13        : meldungsliste         -  enabled
      + system.adapter.meldungsliste.2         : meldungsliste         -  enabled
      + system.adapter.meldungsliste.3         : meldungsliste         -  enabled
      + system.adapter.meldungsliste.4         : meldungsliste         -  enabled
      + system.adapter.meldungsliste.5         : meldungsliste         -  enabled
      + system.adapter.meldungsliste.6         : meldungsliste         -  enabled
      + system.adapter.meldungsliste.7         : meldungsliste         -  enabled
      + system.adapter.meldungsliste.8         : meldungsliste         -  enabled
      + system.adapter.meldungsliste.9         : meldungsliste         -  enabled
      + system.adapter.node-red.0              : node-red              -  enabled, port: 1880, bind: 192.168.2.98
      + system.adapter.statistics.0            : statistics            -  enabled
        system.adapter.tr-064.0                : tr-064                - disabled
      + system.adapter.trashschedule.0         : trashschedule         -  enabled
        system.adapter.upnp.0                  : upnp                  - disabled
        system.adapter.vis-bars.0              : vis-bars              -  enabled
        system.adapter.vis-colorpicker.0       : vis-colorpicker       -  enabled
        system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
        system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
        system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
        system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
        system.adapter.vis.0                   : vis                   -  enabled
      + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest): http://download.iobroker.net/sources-dist-latest.json
      Active repo: Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      hash unchanged, use cached sources
      update done
      Adapter    "admin"         : 6.13.15  , installed 4.1.11 [Updateable]
      Adapter    "backitup"      : 2.9.8    , installed 2.9.8
      Adapter    "discovery"     : 4.2.0    , installed 4.2.0
      Adapter    "ical"          : 1.13.3   , installed 1.7.4 [Updateable]
      Adapter    "icons-mfd-png" : 1.2.1    , installed 1.2.1
      Adapter    "influxdb"      : 3.2.0    , installed 1.9.4 [Updateable]
      Adapter    "info"          : 2.0.0    , installed 1.7.10 [Updateable]
      Adapter    "javascript"    : 7.1.6    , installed 4.8.4 [Updateable]
      Controller "js-controller" : 5.0.17   , installed 3.1.6 [Updateable]
      Adapter    "knx"           : 2.0.24   , installed 1.0.39 [Updateable]
      Adapter    "linux-control" : 1.1.5    , installed 1.1.2 [Updateable]
      Adapter    "node-red"      : 5.1.0    , installed 2.0.1 [Updateable]
      Adapter    "simple-api"    : 2.7.2    , installed 2.7.2
      Adapter    "socketio"      : 6.6.0    , installed 6.6.0
      Adapter    "statistics"    : 2.4.0    , installed 1.0.2 [Updateable]
      Adapter    "tr-064"        : 4.2.18   , installed 4.2.18
      Adapter    "trashschedule" : 2.3.0    , installed 1.0.3 [Updateable]
      Adapter    "upnp"          : 1.0.21   , installed 1.0.17 [Updateable]
      Adapter    "vis"           : 1.5.4    , installed 1.3.4 [Updateable]
      Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
      Adapter    "vis-colorpicker": 2.0.3   , installed 2.0.3
      Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
      Adapter    "vis-hqwidgets" : 1.4.0    , installed 1.4.0
      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
      Adapter    "vis-timeandweather": 1.2.2   , installed 1.2.2
      Adapter    "web"           : 6.2.3    , installed 3.1.0 [Updateable]
      Objects and States
      Objects:        3504
      States:         2438
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Hit:3 https://repos.influxdata.com/debian stable InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17021      555/sshd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17841      420/cupsd
      tcp        0      0 192.168.2.98:1880       0.0.0.0:*               LISTEN      1001       21249      1730/node-red
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        19766      482/influxd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20250      938/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20249      938/iobroker.js-con
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20322      1096/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21218      1771/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        20061      482/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17031      555/sshd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17840      420/cupsd
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17159      484/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18593      532/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16137      413/avahi-daemon: r
      udp        0      0 192.168.2.98:40181      0.0.0.0:*                           1001       21165      1197/io.knx.0
      udp        0      0 0.0.0.0:40203           0.0.0.0:*                           1001       21251      1730/node-red
      udp        0      0 0.0.0.0:42781           0.0.0.0:*                           108        16139      413/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          20302      484/dhcpcd
      udp6       0      0 :::52887                :::*                                108        16140      413/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        16138      413/avahi-daemon: r
      2024-02-03 00:48:18.227  - info: knx.0 (1197) Received CONNECTIONSTATE_RESPONSE :    06 10 02 08 00 08 4f 00                                                              192.168.2.99:3671 ChID : 79 SeqCntIN : 129 SeqCntOUT : 25  msgCode : [object Object]
      2024-02-03 00:48:18.227  - info: knx.0 (1197) Change state from STATE_CONNECTION_STATE_REQUEST(5) to STATE_CONNECTION_STATE_RESPONSE(6)
      2024-02-03 00:48:18.228  - info: knx.0 (1197) Change state from STATE_CONNECTION_STATE_RESPONSE(6) to STATE_READY(7)
      2024-02-03 00:48:18.236  - info: knx.0 (1197) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 19 04 4f 82 00 29 00 bc c0 12 3c 28 04 05 00 80 42 f2 00 00   ChID: 79
      2024-02-03 00:48:18.237  - info: knx.0 (1197) WRITE : mappedName : Leistung    dest : 5/0/4  val: 121   (DPT14.056) Leistung
      2024-02-03 00:48:18.237  - info: knx.0 (1197) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
      2024-02-03 00:48:18.238  - info: knx.0 (1197) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
      2024-02-03 00:48:18.238  - info: knx.0 (1197) =====> STATE_TUNNELING_ACK
      2024-02-03 00:48:18.239  - info: knx.0 (1197) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 4f 82 00   ChID : 79 SeqCntIN : 130 SeqCntOUT : 25 queue length : 0
      2024-02-03 00:48:18.240  - info: knx.0 (1197) ( 4.b ) return to STATE_READY, processing : false
      2024-02-03 00:48:18.240  - info: knx.0 (1197) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
      2024-02-03 00:48:28.241  - info: knx.0 (1197) checkConnectionState 192.168.2.99   State : true
      2024-02-03 00:48:28.242  - info: knx.0 (1197) Send : conCheck Connection State Request :  06 10 02 07 00 10 4f 00 08 01 c0 a8 02 62 9c f5        sent to 192.168.2.99:3671
      2024-02-03 00:48:28.242  - info: knx.0 (1197) Change state from STATE_READY(7) to STATE_CONNECTION_STATE_REQUEST(5)
      2024-02-03 00:48:28.245  - info: knx.0 (1197) Received CONNECTIONSTATE_RESPONSE :    06 10 02 08 00 08 4f 00                                                              192.168.2.99:3671 ChID : 79 SeqCntIN : 130 SeqCntOUT : 25  msgCode : [object Object]
      2024-02-03 00:48:28.246  - info: knx.0 (1197) Change state from STATE_CONNECTION_STATE_REQUEST(5) to STATE_CONNECTION_STATE_RESPONSE(6)
      2024-02-03 00:48:28.246  - info: knx.0 (1197) Change state from STATE_CONNECTION_STATE_RESPONSE(6) to STATE_READY(7)
      2024-02-03 00:48:28.263  - info: knx.0 (1197) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 19 04 4f 83 00 29 00 bc c0 12 3c 28 04 05 00 80 42 f8 00 00   ChID: 79
      2024-02-03 00:48:28.265  - info: knx.0 (1197) WRITE : mappedName : Leistung    dest : 5/0/4  val: 124   (DPT14.056) Leistung
      2024-02-03 00:48:28.265  - info: knx.0 (1197) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
      2024-02-03 00:48:28.266  - info: knx.0 (1197) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
      2024-02-03 00:48:28.266  - info: knx.0 (1197) =====> STATE_TUNNELING_ACK
      2024-02-03 00:48:28.268  - info: knx.0 (1197) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 4f 83 00   ChID : 79 SeqCntIN : 131 SeqCntOUT : 25 queue length : 0
      2024-02-03 00:48:28.268  - info: knx.0 (1197) ( 4.b ) return to STATE_READY, processing : false
      2024-02-03 00:48:28.269  - info: knx.0 (1197) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
        Frank-KNX @Frank-KNX last edited by
        Und hier noch das Summary:
                                v.2023-10-10
                 Icon name: computer
              Architecture: arm
        Installation:           native
        Kernel:                 armv7l
        Userland:               armhf
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        X-Server:               true
        Boot Target:            graphical.target
        Pending OS-Updates:     0
        Pending iob updates:    14
        Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
        Recommended versions are nodejs  and npm
        MEMORY:
        Mem:           7.9G        1.1G        6.1G         39M        755M        6.6G
        Swap:           99M          0B         99M
        Total:         8.0G        1.1G        6.2G
        Active iob-Instances:   26
        ioBroker Core:          js-controller           3.1.6
                                admin                   4.1.11
        Objects type: file
        States  type: file
        Objects:                3504
        States:                 2438
        Size of iob-Database:
        656K    /opt/iobroker/iobroker-data/states.json.bak
          Thomas Braun Most Active @Frank-KNX last edited by
          @frank-knx
          iob update
          iob upgrade
          iob stop
          iob upgrade self
          iob start
            Hallo Thomas,
            also bei upgrade self bleibt er wieder hängen.
            Nachfolgend die Fehlermeldung:
            pi@raspberrypi:~ $ iob upgrade self
            Update js-controller from @3.1.6 to @5.0.17
            NPM version: 10.2.3
            npm install iobroker.js-controller@5.0.17 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
             Objects 127.0.0.1:36630 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
             States 127.0.0.1:43550 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
             Objects 127.0.0.1:36630 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
             States 127.0.0.1:43550 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
             Objects 127.0.0.1:36630 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
             Objects 127.0.0.1:36630 Error from InMemDB: Error: scan NOT SUPPORTED
            npm ERR! code 1
            npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
            npm ERR! command failed
            npm ERR! command sh -c node iobroker.js setup first
            npm ERR! Unable to increase LUA script timeout: Error CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
            npm ERR!  Unable to enable Expiry Keyspace events from Redis Server: Error CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
            npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            npm ERR!         throw e;
            npm ERR!         ^
            npm ERR!
            npm ERR! ReplyError: Error scan NOT SUPPORTED
            npm ERR!     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
            npm ERR!     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
            npm ERR! Emitted 'error' event on ScanStream instance at:
            npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
            npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
            npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
            npm ERR!     at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
            npm ERR!   command: {
            npm ERR!     name: 'scan',
            npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
            npm ERR!   }
            npm ERR! }
            npm ERR!
            npm ERR! Node.js v18.19.0
            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-03T00_01_36_505Z-debug-0.log
            Starting node restart.js
            pi@raspberrypi:~ $
              @frank-knx
              Die Adapter-Updates sind durch?
              iob update
              sagt?
                Ja, Updates sind ohne Fehlermeldung durchgelaufen. Auch das iob upgrade.
                Erst nach iob stop und dann upgrade self die Fehlermeldung.
                  Muss noch ergänzen..
                  Nachfolgend upgrade...
                  Alles nicht instalierten Adapter werden angezeigt.. aber die installierten meldet er, als nicht upgedated, weil die JS-Controller Version ja bekanntlich zu alt ist => Das will ich ja gerade ändern...
                  Adapter "accuweather"    is not installed.
                  Adapter "acme"           is not installed.
                  Adapter "adb"            is not installed.
                  Adapter "adguard"        is not installed.
                  Invalid version of "js-controller". Installed "3.1.6", required ">=3.3.22
                  Adapter "aio"            is not installed.
                  Adapter "airconwithme"   is not installed.
                  Adapter "airzone"        is not installed.
                  Adapter "alarm"          is not installed.
                  Adapter "alexa-shoppinglist" is not installed.
                  Adapter "alexa-timer-vis" is not installed.
                  Adapter "alexa2"         is not installed.
                  Adapter "alias-manager"  is not installed.
                  Adapter "alpha-ess"      is not installed.
                  Adapter "alpha2"         is not installed.
                  Adapter "amazon-dash"    is not installed.
                  Adapter "amtronwallbox"  is not installed.
                  Adapter "anelhut"        is not installed.
                  Adapter "apcups"         is not installed.
                  Adapter "apg-info"       is not installed.
                  Adapter "artnet"         is not installed.
                  Adapter "artnet-recorder" is not installed.
                  Adapter "asterisk"       is not installed.
                  Adapter "asuswrt"        is not installed.
                  Adapter "atlas-scientific-ezo-i2c" is not installed.
                  Adapter "awattar"        is not installed.
                  Adapter "awtrix-light"   is not installed.
                  Adapter "b-control-em"   is not installed.
                  Invalid version of "js-controller". Installed "3.1.6", required ">=4.0.0
                  Adapter "beckhoff"       is not installed.
                  Adapter "benchmark"      is not installed.
                  Adapter "benq"           is not installed.
                  Adapter "bestway"        is not installed.
                  Adapter "bidirectional-counter" is not installed.
                  Adapter "birthdays"      is not installed.
                  Adapter "ble"            is not installed.
                  Adapter "blebox"         is not installed.
                  Adapter "bluelink"       is not installed.
                  Adapter "bmw"            is not installed.
                  Adapter "bosch-ebike"    is not installed.
                  Adapter "bosesoundtouch" is not installed.
                  Adapter "botslab360"     is not installed.
                  Adapter "botvac"         is not installed.
                  Adapter "bring"          is not installed.
                  Adapter "broadlink2"     is not installed.
                  Adapter "bsblan"         is not installed.
                  Adapter "bshb"           is not installed.
                  Adapter "bwt"            is not installed.
                  Adapter "bydbatt"        is not installed.
                  Adapter "bydhvs"         is not installed.
                  Adapter "canbus"         is not installed.
                  Adapter "cec2"           is not installed.
                  Adapter "chromecast"     is not installed.
                  Adapter "cleveron"       is not installed.
                  Adapter "cloud"          is not installed.
                  Adapter "cloudflare"     is not installed.
                  Adapter "comfoair"       is not installed.
                  Adapter "contactid"      is not installed.
                  Adapter "coronavirus-statistics" is not installed.
                  Adapter "countdown"      is not installed.
                  Adapter "cul"            is not installed.
                  Adapter "daikin"         is not installed.
                  Adapter "daikin-cloud"   is not installed.
                  Adapter "daswetter"      is not installed.
                  Adapter "deconz"         is not installed.
                  Adapter "denon"          is not installed.
                  Adapter "device-reminder" is not installed.
                  Adapter "device-watcher" is not installed.
                  Adapter "devices"        is not installed.
                  Adapter "deyeidc"        is not installed.
                  Adapter "digitalstrom"   is not installed.
                  Adapter "discord"        is not installed.
                  Adapter "discovergy"     is not installed.
                  Adapter "discovery"      is up to date.
                  Adapter "divera247"      is not installed.
                  Adapter "doorbird"       is not installed.
                  Adapter "doorio"         is not installed.
                  Adapter "drag-indicator" is not installed.
                  Adapter "ds18b20"        is not installed.
                  Adapter "dwd"            is not installed.
                  Adapter "dysonairpurifier" is not installed.
                  Adapter "e3dc-rscp"      is not installed.
                  Adapter "easee"          is not installed.
                  Adapter "ebus"           is not installed.
                  Adapter "echarts"        is not installed.
                  Adapter "ecovacs-deebot" is not installed.
                  Adapter "egigeozone"     is not installed.
                  Adapter "ekey"           is not installed.
                  Adapter "elero-usb-transmitter" is not installed.
                  Adapter "email"          is not installed.
                  Adapter "emby"           is not installed.
                  Adapter "emporia"        is not installed.
                  Adapter "ems-esp"        is not installed.
                  Adapter "energiefluss"   is not installed.
                  Adapter "energymanager"  is not installed.
                  Adapter "enet"           is not installed.
                  Adapter "enigma2"        is not installed.
                  Adapter "envertech-pv"   is not installed.
                  Adapter "epson_ecotank_et_2750" is not installed.
                  Adapter "epson_stylus_px830" is not installed.
                  Adapter "eusec"          is not installed.
                  Adapter "evcc"           is not installed.
                  Adapter "eventlist"      is not installed.
                  Adapter "exchangerates"  is not installed.
                  Adapter "fahrplan"       is not installed.
                  Adapter "fakeroku"       is not installed.
                  Adapter "fb-checkpresence" is not installed.
                  Adapter "feiertage"      is not installed.
                  Adapter "fhem"           is not installed.
                  Adapter "fiat"           is not installed.
                  Adapter "firetv"         is not installed.
                  Adapter "fitbit-fitness" is not installed.
                  Adapter "flot"           is not installed.
                  Adapter "followthesun"   is not installed.
                  Adapter "foobar2000"     is not installed.
                  Adapter "ford"           is not installed.
                  Adapter "frigate"        is not installed.
                  Adapter "fritzbox"       is not installed.
                  Adapter "fritzdect"      is not installed.
                  Adapter "froeling"       is not installed.
                  Adapter "fronius"        is not installed.
                  Adapter "fronius-solarweb" is not installed.
                  Adapter "fronius-wattpilot" is not installed.
                  Adapter "frontier_silicon" is not installed.
                  Adapter "fuelpricemonitor" is not installed.
                  Adapter "fullcalendar"   is not installed.
                  Adapter "fullybrowser"   is not installed.
                  Adapter "g-homa"         is not installed.
                  Adapter "garmin"         is not installed.
                  Adapter "geofency"       is not installed.
                  Adapter "gigaset-elements" is not installed.
                  Adapter "gira-iot"       is not installed.
                  Adapter "go-e"           is not installed.
                  Adapter "govee-local"    is not installed.
                  Adapter "growatt"        is not installed.
                  Adapter "gruenbeck"      is not installed.
                  Adapter "gsmsms"         is not installed.
                  Adapter "haassohn"       is not installed.
                  Adapter "habpanel"       is not installed.
                  Adapter "haier"          is not installed.
                  Adapter "ham"            is not installed.
                  Adapter "ham-wemo"       is not installed.
                  Adapter "harmony"        is not installed.
                  Adapter "hass"           is not installed.
                  Adapter "hausbus_de"     is not installed.
                  Adapter "heatingcontrol" is not installed.
                  Adapter "heizoel"        is not installed.
                  Adapter "heizungssteuerung" is not installed.
                  Adapter "hekr"           is not installed.
                  Adapter "helios"         is not installed.
                  Adapter "heos"           is not installed.
                  Adapter "heytech"        is not installed.
                  Adapter "hid-community"  is not installed.
                  Adapter "hikvision-alarmserver" is not installed.
                  Adapter "history"        is not installed.
                  Adapter "hm-rega"        is not installed.
                  Adapter "hm-rpc"         is not installed.
                  Adapter "hmip"           is not installed.
                  Adapter "homeconnect"    is not installed.
                  Adapter "homee"          is not installed.
                  Adapter "homekit-controller" is not installed.
                  Adapter "homenet"        is not installed.
                  Adapter "homepilot"      is not installed.
                  Adapter "hoover"         is not installed.
                  Adapter "hp-ilo"         is not installed.
                  Adapter "hs100"          is not installed.
                  Adapter "hue"            is not installed.
                  Adapter "huum-sauna"     is not installed.
                  Adapter "i2c"            is not installed.
                  Invalid version of "admin". Installed "4.1.11", required ">=5.3.2
                  Adapter "iceroad"        is not installed.
                  Adapter "ico-cloud"      is not installed.
                  Adapter "icons-addictive-flavour-png" is not installed.
                  Adapter "icons-eclipse-smarthome-classic" is not installed.
                  Adapter "icons-fatcow-hosting" is not installed.
                  Adapter "icons-freepic"  is not installed.
                  Adapter "icons-icons8"   is not installed.
                  Adapter "icons-material-png" is not installed.
                  Adapter "icons-material-svg" is not installed.
                  Adapter "icons-mfd-png"  is up to date.
                  Adapter "icons-mfd-svg"  is not installed.
                  Adapter "icons-open-icon-library-png" is not installed.
                  Adapter "icons-smarthome" is not installed.
                  Adapter "icons-ultimate-png" is not installed.
                  Adapter "ikettle2"       is not installed.
                  Adapter "imap"           is not installed.
                  Adapter "imow"           is not installed.
                  Invalid version of "js-controller". Installed "3.1.6", required ">=3.3.0
                  Update info from @1.7.10 to @2.0.0
                  NPM version: 10.2.3
                  npm install iobroker.info@2.0.0 --loglevel error --prefix "/opt/iobroker" (System call)
                  Adapter "system.adapter.vis.0" restarted.
                  Update "system.adapter.info.0"
                  upload [90] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
                  upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/helper.js lib/js/helper.js application/javascript
                  upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootbox.min.js lib/js/bootbox.min.js application/javascript
                  upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/redhat.png lib/img/logos/redhat.png image/png
                  upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/mandriva.png lib/img/logos/mandriva.png image/png
                  upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/centos.png lib/img/logos/centos.png image/png
                  upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/graphics.png lib/img/icons/graphics.png image/png
                  upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                  upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                  upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                  upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                  upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                  upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                  upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                  upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                  upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
                  upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                  upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                  upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  Adapter "info" updated
                  Adapter "innogy-smarthome" is not installed.
                  Adapter "innoxel"        is not installed.
                  Adapter "intex"          is not installed.
                  Adapter "iot"            is not installed.
                  Adapter "iqontrol"       is not installed.
                  Adapter "iwg-vpn"        is not installed.
                  Adapter "janitza-gridvis" is not installed.
                  Adapter "jarvis"         is not installed.
                  Invalid version of "admin". Installed "4.1.11", required ">=5.1.28
                  Adapter "jeelink"        is not installed.
                  Adapter "judoisoft"      is not installed.
                  Adapter "kecontact"      is not installed.
                  Adapter "klf200"         is not installed.
                  Adapter "knmi-weather"   is not installed.
                  Adapter "kodi"           is not installed.
                  Adapter "kostal-piko-ba" is not installed.
                  Adapter "lametric"       is not installed.
                  Adapter "lcn"            is not installed.
                  Adapter "legrand-ecocompteur" is not installed.
                  Adapter "letrika_comgw"  is not installed.
                  Adapter "lg-ess-home"    is not installed.
                  Adapter "lg-thinq"       is not installed.
                  Adapter "lgtv"           is not installed.
                  Adapter "lgtv-rs"        is not installed.
                  Adapter "lgtv11"         is not installed.
                  Adapter "libre"          is not installed.
                  Adapter "lifx"           is not installed.
                  Adapter "lightcontrol"   is not installed.
                  Adapter "lightify"       is not installed.
                  Adapter "link"           is not installed.
                  Adapter "link2home"      is not installed.
                  Adapter "linkeddevices"  is not installed.
                  Adapter "linktap"        is not installed.
                  Update linux-control from @1.1.2 to @1.1.5
                  NPM version: 10.2.3
                  npm install iobroker.linux-control@1.1.5 --loglevel error --prefix "/opt/iobroker" (System call)
                  upload [20] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/words.js words.js application/javascript
                  Update "system.adapter.linux-control.0"
                  upload [19] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/style.css style.css text/css
                  upload [18] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/linux-control.png linux-control.png image/png
                  upload [17] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/updates.json lib/updates.json application/json
                  upload [16] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/services.json lib/services.json application/json
                  upload [15] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/needrestart.json lib/needrestart.json application/json
                  upload [14] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/jquery.fancytree.dnd5.js lib/jquery.fancytree.dnd5.js application/javascript
                  upload [13] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/info.json lib/info.json application/json
                  upload [12] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/distribution.json lib/distribution.json application/json
                  upload [11] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/control.json lib/control.json application/json
                  upload [10] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/index_m.js index_m.js application/javascript
                  upload [9] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/index_m.html index_m.html text/html
                  upload [8] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/state.png img/state.png image/png
                  upload [7] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/menu_right.svg img/menu_right.svg image/svg+xml
                  upload [6] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/menu_down.svg img/menu_down.svg image/svg+xml
                  upload [5] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/info-big.png img/info-big.png image/png
                  upload [4] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/folder.png img/folder.png image/png
                  upload [3] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/checkbox_marked.svg img/checkbox_marked.svg image/svg+xml
                  upload [2] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/checkbox_intermediate.svg img/checkbox_intermediate.svg image/svg+xml
                  upload [1] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/checkbox.svg img/checkbox.svg image/svg+xml
                  upload [0] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/admin.d.ts admin.d.ts video/mp2t
                  Adapter "linux-control" updated
                  Adapter "logparser"      is not installed.
                  Adapter "loqed"          is not installed.
                  Adapter "lovelace"       is not installed.
                  Adapter "lowpass-filter" is not installed.
                  Adapter "loxone"         is not installed.
                  Adapter "luftdaten"      is not installed.
                  Adapter "lupusec"        is not installed.
                  Adapter "luxtronik1"     is not installed.
                  Adapter "material"       is not installed.
                  Adapter "matrix-org"     is not installed.
                  Adapter "maveo"          is not installed.
                  Adapter "maxcube"        is not installed.
                  Adapter "maxcul"         is not installed.
                  Adapter "mbus"           is not installed.
                  Adapter "mclighting"     is not installed.
                  Adapter "meater"         is not installed.
                  Adapter "mediola-gateway" is not installed.
                  Adapter "megad"          is not installed.
                  Adapter "megadd"         is not installed.
                  Adapter "megaesp"        is not installed.
                  Adapter "melcloud"       is not installed.
                  Adapter "mercedesme"     is not installed.
                  Adapter "mercury"        is not installed.
                  Adapter "meross"         is not installed.
                  Adapter "meteoalarm"     is not installed.
                  Adapter "micronova"      is not installed.
                  Adapter "midea"          is not installed.
                  Adapter "miele"          is not installed.
                  Adapter "mielecloudservice" is not installed.
                  Adapter "mihome"         is not installed.
                  Adapter "mihome-cloud"   is not installed.
                  Adapter "mihome-lamp"    is not installed.
                  Adapter "mihome-plug"    is not installed.
                  Adapter "mihome-vacuum"  is not installed.
                  Adapter "mikrotik"       is not installed.
                  Adapter "milight"        is not installed.
                  Adapter "milight-smart-light" is not installed.
                  Adapter "minuvis"        is not installed.
                  Adapter "mobile"         is not installed.
                  Adapter "modbus"         is not installed.
                  Adapter "moma"           is not installed.
                  Adapter "mpd"            is not installed.
                  Adapter "mqtt"           is not installed.
                  Adapter "mqtt-client"    is not installed.
                  Adapter "musiccast"      is not installed.
                  Adapter "mydlink"        is not installed.
                  Adapter "myenergi"       is not installed.
                  Adapter "mysensors"      is not installed.
                  Adapter "mystrom"        is not installed.
                  Adapter "myvbus"         is not installed.
                  Adapter "nanoleaf-lightpanels" is not installed.
                  Adapter "net-tools"      is not installed.
                  Adapter "netatmo"        is not installed.
                  Adapter "netatmo-crawler" is not installed.
                  Adapter "netatmo-energy" is not installed.
                  Adapter "nibeuplink"     is not installed.
                  Adapter "nina"           is not installed.
                  Adapter "nissan"         is not installed.
                  Adapter "niu"            is not installed.
                  Adapter "notification-manager" is not installed.
                  Adapter "nsclient"       is not installed.
                  Adapter "nuki"           is not installed.
                  Adapter "nuki-extended"  is not installed.
                  Adapter "nut"            is not installed.
                  Adapter "ocpp"           is not installed.
                  Adapter "octoprint"      is not installed.
                  Adapter "odl"            is not installed.
                  Adapter "oekofen-json"   is not installed.
                  Adapter "oilfox"         is not installed.
                  Adapter "omnicomm-lls"   is not installed.
                  Adapter "onkyo"          is not installed.
                  Adapter "onvif"          is not installed.
                  Adapter "opendtu"        is not installed.
                  Adapter "openhab"        is not installed.
                  Adapter "openknx"        is not installed.
                  Adapter "openligadb"     is not installed.
                  Adapter "openweathermap" is not installed.
                  Adapter "operating-hours" is not installed.
                  Adapter "opi"            is not installed.
                  Adapter "oppoplayer"     is not installed.
                  Adapter "owfs"           is not installed.
                  Adapter "owntracks"      is not installed.
                  Adapter "panasonic-comfort-cloud" is not installed.
                  Adapter "panasonic-viera" is not installed.
                  Adapter "parcel"         is not installed.
                  Adapter "parser"         is not installed.
                  Adapter "paw"            is not installed.
                  Adapter "pegelalarm"     is not installed.
                  Adapter "ph803w"         is not installed.
                  Adapter "phantomjs"      is not installed.
                  Adapter "philips-air"    is not installed.
                  Adapter "philips-tv"     is not installed.
                  Adapter "pi-hole"        is not installed.
                  Adapter "piface"         is not installed.
                  Adapter "pimatic"        is not installed.
                  Adapter "ping"           is not installed.
                  Adapter "pixelit"        is not installed.
                  Adapter "places"         is not installed.
                  Adapter "plenticore"     is not installed.
                  Adapter "plex"           is not installed.
                  Adapter "plexconnect"    is not installed.
                  Adapter "pollenflug"     is not installed.
                  Adapter "porsche"        is not installed.
                  Adapter "powerfox2"      is not installed.
                  Adapter "procon-ip"      is not installed.
                  Adapter "proxmox"        is not installed.
                  Adapter "proxy"          is not installed.
                  Adapter "psa"            is not installed.
                  Adapter "puppeteer"      is not installed.
                  Adapter "pushbullet"     is not installed.
                  Adapter "pushover"       is not installed.
                  Adapter "pushsafer"      is not installed.
                  Adapter "pvforecast"     is not installed.
                  Adapter "pvoutputorg"    is not installed.
                  Adapter "pylontech"      is not installed.
                  Adapter "radar2"         is not installed.
                  Adapter "radiohead"      is not installed.
                  Adapter "rct"            is not installed.
                  Adapter "renacidc"       is not installed.
                  Adapter "renault"        is not installed.
                  Adapter "reolink"        is not installed.
                  Adapter "residents"      is not installed.
                  Adapter "resol"          is not installed.
                  Adapter "rest-api"       is not installed.
                  Adapter "rflink"         is not installed.
                  Adapter "rickshaw"       is not installed.
                  Adapter "ring"           is not installed.
                  Adapter "robonect"       is not installed.
                  Adapter "roborock"       is not installed.
                  Adapter "roomba"         is not installed.
                  Adapter "rpi2"           is not installed.
                  Adapter "rssfeed"        is not installed.
                  Adapter "s7"             is not installed.
                  Adapter "sainlogic"      is not installed.
                  Adapter "samsung"        is not installed.
                  Adapter "samsung_tizen"  is not installed.
                  Adapter "sanext"         is not installed.
                  Adapter "sayit"          is not installed.
                  Adapter "sbfspot"        is not installed.
                  Adapter "scenes"         is not installed.
                  Adapter "scheduler"      is not installed.
                  Adapter "schoolfree"     is not installed.
                  Adapter "schwoerer-ventcube" is not installed.
                  Adapter "seko"           is not installed.
                  Adapter "selverf"        is not installed.
                  Adapter "semp"           is not installed.
                  Adapter "seq"            is not installed.
                  Adapter "shelly"         is not installed.
                  Adapter "shuttercontrol" is not installed.
                  Adapter "sia"            is not installed.
                  Adapter "siegenia"       is not installed.
                  Adapter "signal-cmb"     is not installed.
                  Adapter "signifylights"  is not installed.
                  Adapter "simple-api"     is up to date.
                  Adapter "sma-em"         is not installed.
                  Adapter "smappee"        is not installed.
                  Adapter "smart-eq"       is not installed.
                  Adapter "smartcontrol"   is not installed.
                  Adapter "smartgarden"    is not installed.
                  Adapter "smartmeter"     is not installed.
                  Adapter "smartthings"    is not installed.
                  Adapter "snips"          is not installed.
                  Adapter "snmp"           is not installed.
                  Invalid version of "admin". Installed "4.1.11", required ">=5.0.0
                  Adapter "solarlog"       is not installed.
                  Adapter "solarmanpv"     is not installed.
                  Adapter "solarviewdatareader" is not installed.
                  Adapter "solarwetter"    is not installed.
                  Adapter "solax"          is not installed.
                  Adapter "sonnen"         is not installed.
                  Adapter "sonoff"         is not installed.
                  Adapter "sonos"          is not installed.
                  Adapter "sony-bravia"    is not installed.
                  Adapter "spotify-premium" is not installed.
                  Adapter "sprinklecontrol" is not installed.
                  Adapter "sql"            is not installed.
                  Adapter "squeezeboxrpc"  is not installed.
                  Adapter "starline"       is not installed.
                  Adapter "stiebel-isg"    is not installed.
                  Adapter "sureflap"       is not installed.
                  Adapter "swiss-weather-api" is not installed.
                  Adapter "synochat"       is not installed.
                  Adapter "synology"       is not installed.
                  Adapter "systeminfo"     is not installed.
                  Adapter "tado"           is not installed.
                  Adapter "tahoma"         is not installed.
                  Adapter "tankerkoenig"   is not installed.
                  Adapter "tapo"           is not installed.
                  Adapter "telegram"       is not installed.
                  Adapter "telegram-menu"  is not installed.
                  Adapter "terminal"       is not installed.
                  Adapter "tesla-motors"   is not installed.
                  Adapter "text2command"   is not installed.
                  Adapter "tibberlink"     is not installed.
                  Adapter "tinker"         is not installed.
                  Adapter "tinymqttbroker" is not installed.
                  Adapter "toyota"         is not installed.
                  Adapter "tr-064"         is up to date.
                  Adapter "traccar"        is not installed.
                  Adapter "tractive-gps"   is not installed.
                  Adapter "tradfri"        is not installed.
                  Invalid version of "js-controller". Installed "3.1.6", required ">=4.0.15
                  Adapter "trivum"         is not installed.
                  Adapter "tronity"        is not installed.
                  Adapter "tunnelbroker-endpoint-updater" is not installed.
                  Adapter "tuya"           is not installed.
                  Adapter "tvprogram"      is not installed.
                  Adapter "tvspielfilm"    is not installed.
                  Adapter "twinkly"        is not installed.
                  Adapter "unifi"          is not installed.
                  Adapter "uv-protect"     is not installed.
                  Adapter "vaillant"       is not installed.
                  Adapter "valloxmv"       is not installed.
                  Adapter "valuetrackerovertime" is not installed.
                  Adapter "vcard"          is not installed.
                  Adapter "vds2465-server" is not installed.
                  Adapter "velux"          is not installed.
                  Adapter "vesync"         is not installed.
                  Adapter "viessmann"      is not installed.
                  Adapter "viessmannapi"   is not installed.
                  Adapter "virtualpowermeter" is not installed.
                  Update vis from @1.3.4 to @1.5.4
                  NPM version: 10.2.3
                  npm install iobroker.vis@1.5.4 --loglevel error --prefix "/opt/iobroker" (System call)
                  upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                  upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/6-1.png widgets/timeandweather/img/clock/6-1.png image/png
                  upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/01-1.png widgets/timeandweather/img/clock/01-1.png image/png
                  upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/sani_valve_60.png widgets/jqui-mfd/img/sani_valve_60.png image/png
                  upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_window_roof.svg widgets/jqui-mfd/img/fts_window_roof.svg image/svg+xml
                  upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/authors.txt widgets/jqui-mfd/img/authors.txt text/plain
                  upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/css/glossy.css widgets/hqwidgets/css/glossy.css text/css
                  upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/pin_red5.svg widgets/basic/img/pin_red5.svg image/svg+xml
                  upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/bars/js/jquery.sidebar.js widgets/bars/js/jquery.sidebar.js application/javascript
                  upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery-ui-timepicker-addon-1.6.3.js lib/js/jquery-ui-timepicker-addon-1.6.3.js application/javascript
                  upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditExt.js js/visEditExt.js application/javascript
                  upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/back.png js/fm/icon/actions/back.png image/png
                  upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/img/zip.png img/zip.png image/png
                  upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
                  upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
                  upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
                  upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
                  upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
                  upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
                  upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
                  upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
                  upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
                  upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
                  upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
                  upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
                  upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
                  upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
                  upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
                  upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
                  upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
                  upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
                  upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
                  upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
                  upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff font/woff
                  upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
                  upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
                  upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
                  upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
                  upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
                  upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                  Update "system.adapter.vis.0"
                  Adapter "vis" updated
                  Adapter "vis-2"          is not installed.
                  Adapter "vis-2-widgets-energy" is not installed.
                  Adapter "vis-2-widgets-gauges" is not installed.
                  Adapter "vis-2-widgets-jaeger-design" is not installed.
                  Adapter "vis-2-widgets-material" is not installed.
                  Adapter "vis-bars"       is up to date.
                  Adapter "vis-canvas-gauges" is not installed.
                  Adapter "vis-colorpicker" is up to date.
                  Adapter "vis-fancyswitch" is up to date.
                  Adapter "vis-google-fonts" is not installed.
                  Adapter "vis-history"    is not installed.
                  Adapter "vis-hqwidgets"  is up to date.
                  Adapter "vis-icontwo"    is not installed.
                  Adapter "vis-inventwo"   is not installed.
                  Adapter "vis-jqui-mfd"   is up to date.
                  Adapter "vis-justgage"   is not installed.
                  Adapter "vis-keyboard"   is not installed.
                  Adapter "vis-lcars"      is not installed.
                  Adapter "vis-map"        is not installed.
                  Adapter "vis-material"   is not installed.
                  Adapter "vis-material-advanced" is not installed.
                  Adapter "vis-materialdesign" is not installed.
                  Adapter "vis-metro"      is not installed.
                  Adapter "vis-players"    is not installed.
                  Adapter "vis-plumb"      is not installed.
                  Adapter "vis-rgraph"     is not installed.
                  Adapter "vis-timeandweather" is up to date.
                  Adapter "vis-weather"    is not installed.
                  Adapter "voltoplus"      is not installed.
                  Adapter "volumio"        is not installed.
                  Adapter "volvo"          is not installed.
                  Adapter "vr200"          is not installed.
                  Adapter "vw-connect"     is not installed.
                  Adapter "wallpanel"      is not installed.
                  Adapter "warp"           is not installed.
                  Adapter "weather-warnings" is not installed.
                  Adapter "weatherflow_udp" is not installed.
                  Adapter "weatherunderground" is not installed.
                  Invalid version of "admin". Installed "4.1.11", required ">=5.1.0
                  Adapter "webcal"         is not installed.
                  Adapter "webui"          is not installed.
                  Adapter "webuntis"       is not installed.
                  Adapter "weishaupt-wem"  is not installed.
                  Adapter "welcome"        is not installed.
                  Adapter "whatsapp-cmb"   is not installed.
                  Adapter "wiegand-tcpip"  is not installed.
                  Adapter "wiffi-wz"       is not installed.
                  Adapter "wifilight"      is not installed.
                  Adapter "windows-control" is not installed.
                  Adapter "wiobrowser"     is not installed.
                  Adapter "wireguard"      is not installed.
                  Adapter "wireless-mbus"  is not installed.
                  Adapter "withings"       is not installed.
                  Adapter "wlanthermo-nano" is not installed.
                  Adapter "wled"           is not installed.
                  Adapter "wmswebcontrol"  is not installed.
                  Adapter "wolf"           is not installed.
                  Adapter "wolf-smartset"  is not installed.
                  Adapter "worx"           is not installed.
                  Adapter "ws"             is not installed.
                  Adapter "x-touch"        is not installed.
                  Adapter "xbox"           is not installed.
                  Adapter "xs1"            is not installed.
                  Adapter "xterm"          is not installed.
                  Adapter "yahka"          is not installed.
                  Adapter "yahoo-stock-market" is not installed.
                  Adapter "yamaha"         is not installed.
                  Adapter "yeelight-2"     is not installed.
                  Adapter "youtube"        is not installed.
                  Adapter "yr"             is not installed.
                  Adapter "zehnder-cloud"  is not installed.
                  Adapter "zendure-solarflow" is not installed.
                  Adapter "zigbee"         is not installed.
                  Adapter "zigbee2mqtt"    is not installed.
                  Adapter "zont"           is not installed.
                  Adapter "zwave2"         is not installed.
                  pi@raspberrypi:~ $ iob stop
                    @frank-knx
                    Muss ich mir morgen anschauen. N8
                      OK ich halte mich bereit und mache vor deiner Rückmeldung keine Aktionen (um nichts zu Verschlimmern).
                        Thomas Braun Most Active @Frank-KNX last edited by Thomas Braun
                        @frank-knx
                        Versuch mal:
                        iob stop
                        cd /opt/iobroker
                        sudo -H -u iobroker npm install iobroker.js-controller
                        iob update
                        iob upgrade admin
                        iob upgrade all
                        iob start
                          Alle Befehle sind erfolgreich und ohne Fehlermeldung durchgelaufen.
                          Im iobroker selbst unter Info erscheint die Meldung, dass alle Adapter aktuell sind.
                          ich habe "iob diag" nochmal gestartet und nachfolgend der Report.
                          Habe ich es nun mit deiner Hilfe erfolgreich geschafft oder ist noch etwas zu fixen ?
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm
                          Docker          : false
                          Kernel          : armv7l
                          Userland        : armhf
                           17:40:21 up 16:57,  3 users,  load average: 0.81, 1.75, 1.33
                          CPU threads: 4
                          Current issues:
                                         Local time: Sat 2024-02-03 17:40:21 CET
                                     Universal time: Sat 2024-02-03 16:40:21 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          /home/pi
                          X-Server:       true
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:           7.9G        1.2G        4.9G         39M        1.7G        6.5G
                          Swap:           99M          0B         99M
                          Total:         8.0G        1.2G        5.0G
                                   7898 M total memory
                                   1209 M used memory
                                    531 M active memory
                                   2209 M inactive memory
                                   4942 M free memory
                                    158 M buffer memory
                                   1589 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /dev/root      ext4      117G   11G  102G  10% /
                          /var:
                          1.5G    /var/
                          1.1G    /var/cache/apt
                          1.1G    /var/cache
                          250M    /var/lib
                          256M    /opt/iobroker/iobroker-data/
                          169M    /opt/iobroker/iobroker-data/files
                          67M     /opt/iobroker/iobroker-data/files/javascript.admin
                          50M     /opt/iobroker/iobroker-data/backup-objects
                          48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                          22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                          16M     /opt/iobroker/iobroker-data/objects.jsonl
                          8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                          7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
                          7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
                          USB-Devices by-id:
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          js-controller:  5.0.17
                          admin:          6.13.15
                          javascript:     7.1.6
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
                          + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                          + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                          + system.adapter.knx.0                    : knx                   : raspberrypi                              -  enabled, bind: 192.168.2.98
                            system.adapter.linux-control.0          : linux-control         : raspberrypi                              -  enabled
                          + system.adapter.meldungsliste.0          : meldungsliste         : raspberrypi                              -  enabled
                            system.adapter.meldungsliste.1          : meldungsliste         : raspberrypi                              -  enabled
                          + system.adapter.meldungsliste.10         : meldungsliste         : raspberrypi                              -  enabled
                          + system.adapter.meldungsliste.11         : meldungsliste         : raspberrypi                              -  enabled
                          + system.adapter.meldungsliste.12         : meldungsliste         : raspberrypi                              -  enabled
                          + system.adapter.meldungsliste.13         : meldungsliste         : raspberrypi                              -  enabled
                          + system.adapter.meldungsliste.2          : meldungsliste         : raspberrypi                              -  enabled
                          + system.adapter.meldungsliste.3          : meldungsliste         : raspberrypi                              -  enabled
                          + system.adapter.meldungsliste.4          : meldungsliste         : raspberrypi                              -  enabled
                          + system.adapter.meldungsliste.5          : meldungsliste         : raspberrypi                              -  enabled
                          + system.adapter.meldungsliste.6          : meldungsliste         : raspberrypi                              -  enabled
                          + system.adapter.meldungsliste.7          : meldungsliste         : raspberrypi                              -  enabled
                            system.adapter.meldungsliste.8          : meldungsliste         : raspberrypi                              -  enabled
                          + system.adapter.meldungsliste.9          : meldungsliste         : raspberrypi                              -  enabled
                          + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 192.168.2.98
                          + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
                            system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                            system.adapter.upnp.0                   : upnp                  : raspberrypi                              - disabled
                            system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
                            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          + instance is alive
                          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                          Active repo(s): Stable (default)
                          Adapter    "admin"        : 6.13.15  , installed 6.13.15
                          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                          Controller "js-controller": 5.0.17   , installed 5.0.17
                          Adapter    "knx"          : 2.0.24   , installed 2.0.24
                          Adapter    "linux-control": 1.1.5    , installed 1.1.5
                          Adapter    "node-red"     : 5.1.0    , installed 5.1.0
                          Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                          Adapter    "web"          : 6.2.3    , installed 6.2.3
                          Adapter    "ws"           : 2.5.10   , installed 2.5.10
                          Objects and States
                          Objects:        3877
                          States:         2729
                          Pending Updates: 1
                          tcp        0      0 192.168.2.98:1880       0.0.0.0:*               LISTEN      1001       49471      9582/node-red
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       48023      9500/iobroker.js-co
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       48016      9500/iobroker.js-co
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       48066      9521/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       53319      9865/io.web.0
                          udp        0      0 0.0.0.0:59135           0.0.0.0:*                           1001       49473      9582/node-red
                          udp        0      0 192.168.2.98:39748      0.0.0.0:*                           1001       53569      10234/io.knx.0
                          udp        0      0 192.168.2.98:46929      0.0.0.0:*                           1001       51070      10234/io.knx.0
                          2024-02-03 17:41:57.874  - info: knx.0 (10234) WRITE : mappedName : Temperatur Wasser Teich    dest : 4/3/3  val: 6.4   (DPT9.001) Temperatur_Wasser_Teich
                          2024-02-03 17:41:57.874  - info: knx.0 (10234) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
                          2024-02-03 17:41:57.875  - info: knx.0 (10234) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
                          2024-02-03 17:41:57.875  - info: knx.0 (10234) =====> STATE_TUNNELING_ACK
                          2024-02-03 17:41:57.876  - info: knx.0 (10234) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 55 87 00   ChID : 85 SeqCntIN : 135 SeqCntOUT : 25 queue length : 0
                          2024-02-03 17:41:57.877  - info: knx.0 (10234) ( 4.b ) return to STATE_READY, processing : false
                          2024-02-03 17:41:57.877  - info: knx.0 (10234) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
                          2024-02-03 17:41:56.303  - info: influxdb.0 (9607) Influx DB Version used: 1.x
                          2024-02-03 17:41:56.503  - error: influxdb.0 (9607) Error: authorization failed
                          2024-02-03 17:41:58.728  - info: knx.0 (10234) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 19 04 55 88 00 29 00 bc c0 12 3c 28 03 05 00 80 00 00 01 c4   ChID: 85
                          2024-02-03 17:41:58.729  - info: knx.0 (10234) WRITE : mappedName : Energie kWh    dest : 5/0/3  val: 452   (DPT13.013) Energie_kWh
                          2024-02-03 17:41:58.730  - info: knx.0 (10234) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
                          2024-02-03 17:41:58.730  - info: knx.0 (10234) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
                          2024-02-03 17:41:58.731  - info: knx.0 (10234) =====> STATE_TUNNELING_ACK
                          2024-02-03 17:41:58.733  - info: knx.0 (10234) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 55 88 00   ChID : 85 SeqCntIN : 136 SeqCntOUT : 25 queue length : 0
                          2024-02-03 17:41:58.733  - info: knx.0 (10234) ( 4.b ) return to STATE_READY, processing : false
                          2024-02-03 17:41:58.733  - info: knx.0 (10234) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
                          2024-02-03 17:41:58.751  - info: knx.0 (10234) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 19 04 55 89 00 29 00 bc c0 12 3c 28 02 05 00 80 00 06 e9 02   ChID: 85
                          2024-02-03 17:41:58.753  - info: knx.0 (10234) WRITE : mappedName : Energie Wh    dest : 5/0/2  val: 452866   (DPT13.010) Energie_Wh
                          2024-02-03 17:41:58.754  - info: knx.0 (10234) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
                          2024-02-03 17:41:58.754  - info: knx.0 (10234) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
                          2024-02-03 17:41:58.755  - info: knx.0 (10234) =====> STATE_TUNNELING_ACK
                          2024-02-03 17:41:58.756  - info: knx.0 (10234) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 55 89 00   ChID : 85 SeqCntIN : 137 SeqCntOUT : 25 queue length : 0
                          2024-02-03 17:41:58.756  - info: knx.0 (10234) ( 4.b ) return to STATE_READY, processing : false
                          2024-02-03 17:41:58.757  - info: knx.0 (10234) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
                            @frank-knx sagte in Update js-Controller 3.x auf 5.x funktioniert nicht:
                            Schaut jetzt wohl soweit i. O. aus.
                            Aber was ist denn das für ein Adapter? Der dann auch ein Dutzend Instanzen anschleppt?
                            Backup ziehen und das Betriebssystem auf einen aktuellen Stand bringen. Dein 'Buster' ist tot.
                              Hallo Thomas,
                              herzlichen Dank für deine professionelle Unterstützung.
                              Jetzt muss ich in meiner VIS nur noch schauen, ob durch die Updates am Verhalten eine Änderung aufgetreten ist.
                              Diesen Adapter Meldungsliste nutze ich in der VIS für alle Beleuchtungen und Co, die ich über KNX abgreife. Damit generiere ich auf der Hauptseite dann Meldungen, wie "Licht im Haus an", wenn eines der Lichter an ist oder "Fenster offen". Ich habe dort so viele Gruppen, dass ich jedes Mal einen Adapter benötige. Die laufen aber "bisher" sehr stabil und zuverlässig.
                              Jetzt werde ich das System nochmal genau anschauen, ob alle bisherigen Funktionen laufen und dann werde ich das nächste Projekt mit dem von dir angesprochenen Update in Angriff nehmen.
                              Da werde ich sicher nochmal auf euch Fachleute aus dem Forum zurückkommen, bevor ich als "Halbwissender" hier falsche Dinge mache und am Ende nichts mehr läuft.
                              Besten Dank
                              FRANK
                                Thomas Braun Most Active last edited by Thomas Braun
                                @frank-knx
                                Ich würde den knx auf ein weniger gesprächiges LogLevel setzten.
                                Und bei
                                Pending Updates: 1
                                Kannst du gleich trainieren, wie mal die Kiste aktuell hält.
                                sudo apt update
                                sudo apt full-upgrade
                                  Frank579 @Thomas Braun last edited by
                                  @thomas-braun sagte in Update js-Controller 3.x auf 5.x funktioniert nicht:
                                  sudo full-upgrade
                                  fehlt da nicht ein apt ? oder geht das jetzt auch so?
                                    Thomas Braun Most Active @Frank579 last edited by
                                    @frank579 sagte in Update js-Controller 3.x auf 5.x funktioniert nicht:
                                    Gut aufgepasst. Ich hab es korrigiert.
                                    4599
