    4. Frigate Adapter für ioBroker
      tombox @MarkA last edited by
      @marka
      Frigate verbindet sich mit Adapter MQTT und sendet Events
      DoubleTake verbindet sich mit Adapter MQTT und empfängt die Events und sendet eigene Events die unter Adapter Objekte abgespeichert werden
      DoubleTake verbindet sich via API und API Key mit Compreface
      • Q
        QuesT last edited by
        Hallo wollte heute mal mit dem gotify Adapter versuchen. Bring aber folgende Fehlermeldung:
        2024-02-02 13:12:57.666 - error: gotify.0 (2275) Error while sending message to gotify:{"message":"Request failed with status code 400","name":"Error","stack":"Error: Request failed with status code 400\n at createError (/opt/iobroker/node_modules/iobroker.gotify/node_modules/axios/lib/core/createError.js:16:15)\n at settle (/opt/iobroker/node_modules/iobroker.gotify/node_modules/axios/lib/core/settle.js:17:12)\n at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/iobroker.gotify/node_modules/axios/lib/adapters/http.js:312:11)\n at IncomingMessage.emit (node:events:529:35)\n at endReadableNT (node:internal/streams/readable:1368:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"headers":{"Accept":"application/json, text/plain, /","Content-Type":"application/json","User-Agent":"axios/0.25.0","Content-Length":33},"method":"post","url":"http://192.168.1.2xx/message?token=Axxxxxxxx","data":"{"extras":{"client::display":{}}}"},"status":400}
        Wäre eine coole alternative.
          tombox @QuesT last edited by
          @quest Was ist genau die Frage?
          Q H 2 Replies Last reply Reply Quote 0
          • Q
            QuesT @tombox last edited by
            @tombox
            Sorry ob man auch Gotify oder ntfy (https://github.com/sestriel/ioBroker.ntfy) unterstützen könnte. Will meine Bilder nicht aus dem internen Netz hinausgeben.
              hagst @tombox last edited by
              @tombox
              Error: ENAMETOOLONG: name too long, unlink '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
              [viele viele Zeichen gelöscht]
              Hast Du eine Idee?
                tombox @hagst last edited by
                @hagst der Temp folder ist zu lang. Was ist das genau für ein System
                  @tombox sagte in Frigate Adapter für ioBroker:
                  Debian 12, Proxmox, LXC (Debian 12)
                    @quest
                    @sestriel kannst du kurz erklären wie ein sendTo Objekt aussehen muss wird aus dem code nicht ganz klar..
                    Kannst du kurz ein Beispiel nennen wie man iobroker.ntfy senden muss
                      @hagst probier mal die GitHub version ob das da geht
                        Gerade mal neu installiert, jetzt muss ich warten bis jemand vor der Kamera rumrennt, hier regnet es und ich will nicht nass werden 🙂
                          @hagst Bitte nochmal installieren
                          @QuesT bitte mal die GitHub installieren die könnten mit iobroker.ntfy oder iobroker.gotify funktionieren
                            hagst @tombox last edited by hagst
                            @tombox
                            Mir ist gerade wieder etwas aufgefallen.
                            Ich habe um den Fehler nachvollziehen zu können, nochmal die Version 1.0.0 installiert.
                            In der Version 1.0.0 wird der detaillierte Screenshot per Telegram versendet. Nach einem Update auf die 1.0.2 wird er nicht mehr gesendet.
                            Nach einem downgrade auf die 1.0.0 wird er wieder versendet. Der andere Fehler ist mit der De- und Neuinstallation verschwunden.
                              @hagst Danke für den Hinweis bitte nochmal GitHub version testen
                                Klappt, jetzt kommt auch in der GitHub Version der detaillierte Screenshot per Telegram. Was mir noch aufgefallen ist (ich hoffe es nervt nicht). ist der Text der Meldung unter den Screenshots bei Telegram:
                                In der original Config wurde, bis auf die mqtt Einstellungen, nichts verändert.
                                Bildunterschrift bei den normalen Screenshots: "Terrasse person erkannt end 0.84375"
                                Bildunterschrift bei den detaillierte Screenshots:Terrasse person erkannt undefined undefined"
                                Bildunterschift unter den Videoclips: Terrasse person erkannt end 0.84375"
                                Vielleicht verschwindet ja das undefined, wenn der ioBroker / frigate neu gestartet wurde, mal schauen.
                                Edit:
                                Neustart vom ioBroker und frigate:
                                  @hagst ist korrigiert
                                    ist korrigiert
                                    Sieht gut aus.
                                    • Q
                                      @tombox
                                      2024-02-04 11:45:40.075 - error: ntfy.0 (1189) Ntfy error: AxiosError: Request failed with status code 400
                                      2024-02-04 11:45:40.075 - error: ntfy.0 (1189) Ntfy error: {"code":40009,"http":400,"error":"invalid request: topic invalid"}
                                      2024-02-04 11:45:40.075 - error: ntfy.0 (1189) Ntfy with config: {}
                                        @quest was wäre denn eine korrekte topic
                                        • Q
                                          @tombox
                                          Hatte nur kein standart Topic gesetzt im Adapter. Geht nun aber es wird kein Bild mitgesendet.
                                          cam1 person erkannt end 0.80859375
                                          /tmp/8d9cb83e-3f51-44b5-b704-0af816bbcabe.jpg
                                          T T 2 Replies Last reply Reply Quote 0
                                            Tschaeens @QuesT last edited by
                                            @tombox
                                            Erstmal danke für das Update. Bei mir läuft alles tiptop. Ich würde gern den Wert motion weiterverarbeiten. Leider geht dieser bei jedem motion auf ON. Gibt es einen state der nur auf ON geht, wenn Frigate eine Person erkennt und der Wert über meinen eingestellten Wert ist? Also dann wenn Frigate auch einen snapshot erstellt. Danke dir.
                                            VG
                                            367
                                            98661
