    4. [SourceAnalytix 0.4.8-Final] Released !
      Malz1902 last edited by Malz1902
      Hallo zusammen, ich wollte gerade meine Wallbox auch mit SA loggen. Einstellungen wie immer vorgenommen.
      Der Wert kommt in Wh von der Wallbox. Habe es einmal mit dem Alias versucht und mit den original DP
      sourceanalytix.0
      	2024-01-26 13:09:31.892	error	Initialization of alias.0.strom.wallbox.zaehlerstand failed, check warn messages !
      sourceanalytix.0
      	2024-01-26 13:09:31.892	error	Cannot handle calculations for alias.0.strom.wallbox.zaehlerstand, check log messages and adjust settings!
      sourceanalytix.0
      	2024-01-26 13:09:31.892	error	Troubleshoot Data alias.0.strom.wallbox.zaehlerstand custom Data : {"common":{"alias":{"id":"kecontact.0.eTotal"},"name":"Zählerstand Gesamt","role":"value","type":"number","unit":"Wh","read":true,"write":false,"custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1,"start_day":5274020.7,"start_week":5274020.7,"start_month":5029249.1,"start_quarter":5029249.1,"start_year":5029249.1,"selectedPrice":"ElectricityDay","costs":true,"consumption":true,"basicRate":true,"meter_values":true,"valueAtDeviceReset":7752.531876267876,"valueAtDeviceInit":5274.0207}}},"native":{},"type":"state","_id":"alias.0.strom.wallbox.zaehlerstand","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1706270850756}
      sourceanalytix.0
      	2024-01-26 13:09:31.891	error	Check settings for alias.0.strom.wallbox.zaehlerstand ! Known valueAtDeviceReset : (7752.531876267876) > known cumulative value (0) cannot proceed
      sourceanalytix.0
      	2024-01-26 13:09:17.058	error	Cannot handle calculations for kecontact.0.eTotal, check log messages and adjust settings!
      sourceanalytix.0
      	2024-01-26 13:09:17.057	error	Troubleshoot Data kecontact.0.eTotal custom Data : {"_id":"kecontact.0.eTotal","type":"state","common":{"name":"Total Power Consumption","type":"number","role":"value","unit":"Wh","read":true,"write":false,"desc":"Total power consumption (persistent) without current loading session in Wh.","custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1,"start_day":0,"start_week":0,"start_month":0,"start_quarter":0,"start_year":0,"selectedPrice":"ElectricityDay","costs":true,"consumption":true,"basicRate":true,"meter_values":true,"valueAtDeviceReset":7752.531876267876,"valueAtDeviceInit":5274.0207}}},"native":{"udpKey":"E total","udpMultiplier":0.1},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1706270836645}
      sourceanalytix.0
      	2024-01-26 13:09:17.058	error	Initialization of kecontact.0.eTotal failed, check warn messages !
      sourceanalytix.0
      	2024-01-26 13:09:17.057	error	Check settings for kecontact.0.eTotal ! Known valueAtDeviceReset : (7752.531876267876) > known cumulative value (0) cannot proceed
      2024-01-26 13:25:26.348 - info: sourceanalytix.0 (2870726) Initialising "alias.0.strom.wallbox.zaehlerstand" | (15 of 20)
      2024-01-26 13:25:26.348 - debug: sourceanalytix.0 (2870726) [buildStateDetailsArray] started for alias.0.strom.wallbox.zaehlerstand
      2024-01-26 13:25:26.353 - debug: sourceanalytix.0 (2870726) [buildStateDetailsArray] commonData {"alias":{"id":"kecontact.0.eTotal"},"name":"Zählerstand Gesamt","role":"value","type":"number","unit":"Wh","read":true,"write":false,"custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"Wh","deviceResetLogicEnabled":false,"threshold":1,"start_day":0,"start_week":0,"start_month":0,"start_quarter":0,"start_year":0,"selectedPrice":"ElectricityDay","costs":true,"consumption":true,"basicRate":true,"meter_values":true,"valueAtDeviceReset":7752.531876267876,"valueAtDeviceInit":5274.0207}}}
      2024-01-26 13:25:26.353 - debug: sourceanalytix.0 (2870726) [getCumulatedValue] alias.0.strom.wallbox.zaehlerstand
      2024-01-26 13:25:26.397 - debug: sourceanalytix.0 (2870726) [getCumulatedValue] By using Fresh installation :0
      2024-01-26 13:25:26.397 - debug: sourceanalytix.0 (2870726) [buildStateDetailsArray] cumulativeValue 0 | valueAtDeviceReset 7752.531876267876 | valueAtDeviceInit null
      2024-01-26 13:25:26.397 - debug: sourceanalytix.0 (2870726) [buildStateDetailsArray] unit manually chosen "Wh"
      2024-01-26 13:25:26.397 - error: sourceanalytix.0 (2870726) Check settings for alias.0.strom.wallbox.zaehlerstand ! Known valueAtDeviceReset : (7752.531876267876) > known cumulative value (0) cannot proceed
      2024-01-26 13:25:26.397 - error: sourceanalytix.0 (2870726) Troubleshoot Data alias.0.strom.wallbox.zaehlerstand custom Data : {"common":{"alias":{"id":"kecontact.0.eTotal"},"name":"Zählerstand Gesamt","role":"value","type":"number","unit":"Wh","read":true,"write":false,"custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"Wh","deviceResetLogicEnabled":false,"threshold":1,"start_day":0,"start_week":0,"start_month":0,"start_quarter":0,"start_year":0,"selectedPrice":"ElectricityDay","costs":true,"consumption":true,"basicRate":true,"meter_values":true,"valueAtDeviceReset":7752.531876267876,"valueAtDeviceInit":5274.0207}}},"native":{},"type":"state","_id":"alias.0.strom.wallbox.zaehlerstand","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1706271860708}
      2024-01-26 13:25:26.397 - error: sourceanalytix.0 (2870726) Cannot handle calculations for alias.0.strom.wallbox.zaehlerstand, check log messages and adjust settings!
      2024-01-26 13:25:26.397 - error: sourceanalytix.0 (2870726) Initialization of alias.0.strom.wallbox.zaehlerstand failed, check warn messages !
      v0.4.15-alpha.1
        ManfredHi last edited by
        @Dutchman bzw. @crunchip :
        Da ich im März einen neuen SolarEdge Wechselrichter bekomme möchte ich nichts falsch machen.
        Derzeit hab ich einen Alias-Datenpunkt der über Modbus auf den Gesamt-Wh-Wert des Wechselrichters zeigt. Für diesen Alias habe ich auch SA aktiviert.
        Wenn ich nun den Alias auf den neuen SolarEdge-Wechselrichter ändere, so hat dieser ja einen anderen Gesamt-Wh-Wert (nämlich 0). Was muss ich machen, damit in SA alles einwandfrei weiterläuft und der cumulative Wert weiterhin passt (also alter Wert und neuer Zählerwert).
        Muss ich beim Alias die Konvertierungsfunktion aktivieren und zum Wert der vom neuen WR kommt den letzten Wert vom alten WR hinzufügen?
          Michi_Pi @ManfredHi last edited by
          @manfredhi du musst nichts machen. SA sollte das als Device Reset erkennen und addiert den letzten Wert zu dem neuen.
            ManfredHi @Michi_Pi last edited by
            @michi_pi sagte in [SourceAnalytix 0.4.8-Final] Released !:
            OK, das heißt ich muss aber die Erkennung der Zurücksetzung des Gerätewertes aktivieren? Oder? weil derzeit hab ich diesen nicht aktiviert.
              keiner ne Antwort parat auf mein Problem?
                Thomas Braun Most Active @Malz1902 last edited by
                @malz1902 sagte in [SourceAnalytix 0.4.8-Final] Released !:
                Was ist denn konkret 'dein Problem'?
                  Ich habe momentan folgendes Problem:
                  Der fortlaufende Zähler vom InlineSmartmeter von SolarEdge springt manchmal auf 0 und dann gleich wieder zurück auf den richtigen Wert.
                  In SA löst mir das immer einen DeviceReset aus und dann stimmt der Wert in SA natürlich nicht mehr.
                  Es macht KEINEN Unterschied ob in den Einstellungen im SA die Erkennung der Zurücksetzung des Gerätewerte aktiviert ist oder nicht. Es wird jedesmal ein DeviceReset wert gesetzt.
                  Wie kann ich das umgehen, denn alle paar Tage hab ich mal dieses Problem.
                  • BananaJoe
                    BananaJoe Most Active @ManfredHi last edited by
                    @manfredhi indem du den Datenpunkt mit einem Script überwachst, den Wert in einen weiteren Datenpunkt schreibst sofern dieser größer als der letzte ist und SourceAnalytix auf diesen weiteren Datenpunkt ansetzt statt auf den direkten.
                    Das ist zumindest meine Lösung. So konnte ich auch meinen Datenpunkt des Gaszählers weiterlaufen lassen weil ich zum Zählerstand des neuen Zählers immer noch den Wert des alten hinzuaddiere (hab da noch ein paar andere Dinge laufen die so damit besser umgehen können, z.B. eine Prozentanzeige wieviel des Vorjahresverbrauches wir schon erreicht haben)
                      ManfredHi @BananaJoe last edited by
                      @bananajoe sagte in [SourceAnalytix 0.4.8-Final] Released !:
                      Ja das hab ich mir auch schon gedacht, es so zu machen.
                      Nur das kann ja nicht die Lösung sein.
                      Wozu ist dann der Punkt "Zurücksetzung des Gerätewertes" vorhanden, wenn dieser sowieso keine Funktion hat?
                      Hab jetzt mal probeweise beim Schwellenwert statt 1 den Wert 9999999999 eingetragen. Mal sehen ob das was bringt.
                        Bei nem Alias addiere ich den Wert gleich bei der Konvertierungsfunktion.
                          crunchip Forum Testing Most Active @ManfredHi last edited by
                          @manfredhi sagte in [SourceAnalytix 0.4.8-Final] Released !:
                          Nicht für
                          Sondern wenn ein Gerät sich aus Grund xy zurücksetzt und bei 0 beginnt, ohne das im nächsten Moment wieder der alte Wert drin steht
                            ManfredHi @crunchip last edited by ManfredHi
                            @crunchip
                            also gibt es hier keine andere Lösung als jene mit eigenem Datenpunkt wie @BananaJoe geschrieben hat.
                            Aber der Punkt "Zurücksetzung des Gerätewertes" macht bei mir keinen Unterschied. Es wird jedesmal der Wert als DeviceReset gesetzt. Das dürfte doch nur bei aktiverung dieses Punktes passieren, oder?
                            Was besagt eigentlich der Schwellenwert genau aus?
                              @manfredhi wenn deaktiv sollte da normalerweise nichts passieren
                              Schwellwert bezieht sich auf die ersten Stelle vor dem Komma
                              • icebear
                                icebear last edited by
                                Hi, ich glaub ich werd es nie verstehen, ich hab jetzt ein Punkt in sourceanalytix hinzugefügt, aber die Werte stimmen nur halb
                                Die Werte von Anfang des Jahres waren alle '0', als ich den Wert hinzugefügt habe war der Wert 38,44.
                                Also hab ich bei Tagesbegin 38,44
                                bei Wochenbegin 38,44
                                bei Monatsbegin19,31 (weil im Januar schon 19,31)
                                bei Quartalsbegin 0
                                bei Jahresbegin 0
                                eingetragen.
                                Wieso steht jetzt bei current Month steht richtigerweise der Wert 19,1, warum steht jetzt bei previous Month nix drin
                                T crunchip 2 Replies Last reply Reply Quote 0
                                  TT-Tom @icebear last edited by
                                  @icebear
                                  Die previous Datenpunkte werden immer am letzten des current Datenpunkt beschrieben. Zum Beispiel beim Monat am 31.1. heute ist aber schon der 9.2. darum wird diese Aktion erst wieder am 29.2. ausgelöst. Wie bei der Woche jeden Sonntag der previousWeek geschrieben wird.
                                  icebear 1 Reply Last reply Reply Quote 0
                                  • icebear
                                    icebear @TT-Tom last edited by
                                    @tt-tom
                                    Ah, ok dann werd ich mal warten wie es Ende des Monats aussieht.
                                    Danke für dein Antwort
                                      crunchip Forum Testing Most Active @icebear last edited by
                                      @icebear sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                      bei Quartalsbegin 0
                                      bei Jahresbegin 0
                                      eingetragen.
                                      Da der 1.1.24 ein Montag war, wäre richtig gewesen überall die 38,44 einzutragen
                                        FloJo last edited by
                                        Hallo Zusammen,
                                        ich wollte auch mal den Sourceanalytix Adapter installieren. Hat auch soweit geklappt, aber bei Instanzen zeigt er mir nichts an.
                                        Ich habe bei Objekten nur folgenden Eintrag
                                        Muss ich noch was anderes einstellen oder warum läuft die Installation normal durch und ich kann trotzdem keine Instanz sehen?
                                        Oder muss vorher noch was umgestellt/installliert sein, damit es geht?
                                        • Codierknecht
                                          Codierknecht Developer Most Active @FloJo last edited by
                                          @flojo sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                          Wie hast Du den Adapter installiert?
                                            FloJo @Codierknecht last edited by
                                            @codierknecht
                                            Bin folgendermaßen vorgegangen:
                                            dann
                                            dann hat er es eigentlich alles installiert
                                            Aber dann müßte doch eigentlich hier unter S sowas wie Sourceanalytix stehen oder?
                                            crunchip Codierknecht 2 Replies Last reply Reply Quote 0
                                            2302
                                            1151866
