    3. Off Topic
    4. Mqtt zum Victron Cerbo GX ?
    • mickym
      mickym Most Active @Humidor last edited by
      @humidor sagte in Mqtt zum Victron Cerbo GX ?:
      @mickym ja ja schon verstanden, bin ja schon dabei, hab mir den notepad++ geholt, ändere jetzt
      und wenn Du das Ganze dann noch in CodeTags hier postest mach ich mit ... 😉
      Humidor 1 Reply Last reply Reply Quote 0
      • Humidor
        Humidor @mickym last edited by Humidor
        @mickym
            "Dc": {
                "Power": 321.6,
                "Voltage": 52.7,
                "Current": 6.10,
                "Temperature": 23
            "InstalledCapacity": 200.0,
            "ConsumedAmphours": 74.5,
            "Capacity": 125.5,
            "Soc": 63,
            "TimeToGo": 43967,
            "Balancing": 0,
            "SystemSwitch": 0,
            "Alarms": {
                "LowVoltage": 0,
                "HighVoltage": 0,
                "LowSoc": 0,
                "HighChargeCurrent": 0,
                "HighDischargeCurrent": 0,
                "HighCurrent": 0,
                "CellImbalance": 0,
                "HighChargeTemperature": 0,
                "LowChargeTemperature": 0,
                "LowCellVoltage": 0,
                "LowTemperature": 0,
                "HighTemperature": 0,
                "FuseBlown": 0
            "Info": {
                "ChargeRequest": 0,
                "MaxChargeVoltage": 55.2,
                "MaxChargeCurrent": 80.0,
                "MaxDischargeCurrent": 120.0
            "History": {
                "ChargeCycles": 5,
                "MinimumVoltage": 40.8,
                "MaximumVoltage": 58.4,
                "TotalAhDrawn": 1057.3
            "System": {
                "MinVoltageCellId": "C3",
                "MinCellVoltage": 3.392,
                "MaxVoltageCellId": "C15",
                "MaxCellVoltage": 3.417,
                "MinTemperatureCellId": "C2",
                "MinCellTemperature": 22.5,
                "MaxTemperatureCellId": "C9",
                "MaxCellTemperature": 23.5,
                "MOSTemperature": 23.5,
                "NrOfModulesOnline": 0,
                "NrOfModulesOffline": 0,
                "NrOfModulesBlockingCharge": 0,
                "NrOfModulesBlockingDischarge": 0
            "Voltages": {
                "Cell1":  3.201,
                "Cell2":  3.202,
                "Cell3":  3.203,
                "Cell4":  3.204,
                "Cell5":  3.205,
                "Cell6":  3.206,
                "Cell7":  3.207,
                "Cell8":  3.208,
                "Cell9":  3.209,
                "Cell10": 3.210,
                "Cell11": 3.211,
                "Cell12": 3.212,
                "Cell13": 3.213,
                "Cell14": 3.214,
                "Cell15": 3.215,
                "Cell16": 3.216,
                "Cell17": 3.217,
                "Cell18": 3.218,
                "Cell19": 3.219,
                "Cell20": 3.220,
                "Cell21": 3.221,
                "Cell22": 3.222,
                "Cell23": 3.223,
                "Cell24": 3.224
            "Balances": {
                "Cell1":  0,
                "Cell2":  0,
                "Cell3":  0,
                "Cell4":  0,
                "Cell5":  0,
                "Cell6":  0,
                "Cell7":  0,
                "Cell8":  0,
                "Cell9":  0,
                "Cell10": 0,
                "Cell11": 0,
                "Cell12": 0,
                "Cell13": 0,
                "Cell14": 0,
                "Cell15": 0,
                "Cell16": 0,
                "Cell17": 0,
                "Cell18": 0,
                "Cell19": 0,
                "Cell20": 0,
                "Cell21": 0,
                "Cell22": 0,
                "Cell23": 0,
                "Cell24": 0
            "Io": {
                "AllowToCharge": 0,
                "AllowToDischarge": 0,
                "AllowToBalance": 0,
                "ExternalRelay": 0
        ich entferne jetzt noch alle Werte oder ?
        • mickym
          mickym Most Active @Humidor last edited by mickym
          @humidor NEIN - wir machen jetzt ein paar Übungen - OK?
          Humidor 1 Reply Last reply Reply Quote 1
          • Humidor
            @mickym Ja bitte!
            • mickym
              @humidor Als erstes kopierstes Du dieses Objekt nun in eine payload - in eine Inject Node und gibst es im Debug Fenster aus.
              Wenn das geklappt hat - melden. Das debug Fenster ist das mit dem Bug (Wanze)
              • Humidor
                @mickym hab ich
                • mickym
                  @humidor Gut so könntest Du also das ganze Objekt wieder mit mqtt schreiben. OK?
                  Nun willst Du einen Wert in dem Objekt zum Beispiel ändern. Such Dir mal einen aus.
                  • Humidor
                    @mickym wie der Inject Node oben, der schickt alle 15s die erste 3 Werte, soweit denke ich ist es klar
                    ändern wir diese ersten 3 Werte mit den aktuellen von der Batterie
                    aber die stehen da gar nicht drin??
                    • mickym
                      @humidor Ganz langsam.
                      Du meinst also diese 3 gelb markierten?
                      • Humidor
                        @mickym ja, ich musste im Debug fenster noch auf object drücken, jetzt sind sie da
                        ja genau.
                        • mickym
                          @humidor Gut dann siehst Du (grün markiert) das ganze ist die payload - und mit den Pfeilen kannst Du weitere Objekte expandieren oder zusammenfassen (einklappen). Jeder dieser Eigenschaften hat einen Pfad - den bekommst Du wenn du im Debugfenster auf das Pfad Icon klickst und dann ist dieser in der Zwischenablage.
                          Wir machen das erst mal nur mit Power.
                          • Humidor
                            @mickym dieser
                            • mickym
                              @humidor Genau:
                              Wenn du das geklickt hast, dann hast Du nun in der Zwischenablage folgendes stehen:
                              payload.Dc.Power
                              Das ist der Pfad oder die Adresse dieser Eigenschaft im payload Objekt. Um das nun zu ÄNDERN werden wir eine CHANGE Node verwenden und uns das Ergebnis wieder ausgeben lassen - OK?
                              • Humidor
                                @mickym ja, ich lausche aufmerksam
                                • mickym
                                  @humidor
                                  In dieser ChangeNode sagen wir also welchen Wert oder was wir ändern wollen und fürgen den geänderten Wert ein. Nehmen wir mal an wir wollen die Power auf 555.5 setzen.
                                  In der Change Node setzen wir also den Pfad aus der Zwischenablage ein und setzen diesen Wert auf 555.5
                                  • Humidor
                                    @mickym die erste inject ist mein kompletter payload nehme ich an
                                    den change sollten wir mit echten Daten füttern
                                    • mickym
                                      @humidor Du lernst erst mal wie Du auf einzelne Eigenschaften in Deinem Objekt zugreifst - und was änderst - die Daten sind erst mal nicht echt - Du lernst erstmal Daten aus dem Inject Objekt nachträglich zu verändern - Wenn Du das unten gemacht hast, dann bekommst Du 2 Ausgaben im Debug Fenster.
                                      Achte darauf, dass Du den kopierten Pfad in das msg Objekt übernimmst und die den Datentyp Zahl nimmst.
                                      • Humidor
                                        @mickym gemacht, er zeigt mir den Debug nicht so an wie gewollt
                                        • mickym
                                          @humidor
                                          Nun das wird ja auch in einer 2 Nachricht weiter unten ausgegeben. Also in debug 2 - da müsste dann der veränderte Wert drin stehen, wie in meinem Screenshot
                                          • Humidor
                                            @mickym er zeigt mir nur die erste debug node an
                                            33487
