    4. Update js-Controller 3.x auf 5.x funktioniert nicht
      Frank-KNX @Frank-KNX last edited by
      Und hier noch das Summary:
                              v.2023-10-10
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Installation:           native
      Kernel:                 armv7l
      Userland:               armhf
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      X-Server:               true
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    14
      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                              /usr/bin/node           v18.19.0
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
                              /usr/bin/corepack       0.22.0
      Recommended versions are nodejs  and npm
      MEMORY:
      Mem:           7.9G        1.1G        6.1G         39M        755M        6.6G
      Swap:           99M          0B         99M
      Total:         8.0G        1.1G        6.2G
      Active iob-Instances:   26
      Active repo: Stable (default)
      ioBroker Core:          js-controller           3.1.6
                              admin                   4.1.11
      At least one iobroker host is running.
      Objects type: file
      States  type: file
      + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                3504
      States:                 2438
      Size of iob-Database:
      6.3M    /opt/iobroker/iobroker-data/objects.json.bak
      656K    /opt/iobroker/iobroker-data/states.json.bak
        Thomas Braun Most Active @Frank-KNX last edited by
        @frank-knx
        iob update
        iob upgrade
        iob stop
        iob upgrade self
        iob start
          Frank-KNX @Thomas Braun last edited by
          Hallo Thomas,
          also bei upgrade self bleibt er wieder hängen.
          Nachfolgend die Fehlermeldung:
          pi@raspberrypi:~ $ iob upgrade self
          Update js-controller from @3.1.6 to @5.0.17
          NPM version: 10.2.3
          npm install iobroker.js-controller@5.0.17 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
           Objects 127.0.0.1:36630 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
           States 127.0.0.1:43550 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
           Objects 127.0.0.1:36630 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
           States 127.0.0.1:43550 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
           Objects 127.0.0.1:36630 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
           Objects 127.0.0.1:36630 Error from InMemDB: Error: scan NOT SUPPORTED
          npm ERR! code 1
          npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
          npm ERR! command failed
          npm ERR! command sh -c node iobroker.js setup first
          npm ERR! Unable to increase LUA script timeout: Error CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
          npm ERR!  Unable to enable Expiry Keyspace events from Redis Server: Error CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
          npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
          npm ERR!         throw e;
          npm ERR!         ^
          npm ERR!
          npm ERR! ReplyError: Error scan NOT SUPPORTED
          npm ERR!     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
          npm ERR!     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
          npm ERR! Emitted 'error' event on ScanStream instance at:
          npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
          npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
          npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
          npm ERR!     at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
          npm ERR!   command: {
          npm ERR!     name: 'scan',
          npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
          npm ERR!   }
          npm ERR! }
          npm ERR!
          npm ERR! Node.js v18.19.0
          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-03T00_01_36_505Z-debug-0.log
          Starting node restart.js
          pi@raspberrypi:~ $
            @frank-knx
            Die Adapter-Updates sind durch?
            iob update
            sagt?
              Ja, Updates sind ohne Fehlermeldung durchgelaufen. Auch das iob upgrade.
              Erst nach iob stop und dann upgrade self die Fehlermeldung.
                Muss noch ergänzen..
                Nachfolgend upgrade...
                Alles nicht instalierten Adapter werden angezeigt.. aber die installierten meldet er, als nicht upgedated, weil die JS-Controller Version ja bekanntlich zu alt ist => Das will ich ja gerade ändern...
                Adapter "accuweather"    is not installed.
                Adapter "acme"           is not installed.
                Adapter "adb"            is not installed.
                Adapter "adguard"        is not installed.
                Invalid version of "js-controller". Installed "3.1.6", required ">=3.3.22
                Adapter "aio"            is not installed.
                Adapter "airconwithme"   is not installed.
                Adapter "airzone"        is not installed.
                Adapter "alarm"          is not installed.
                Adapter "alexa-shoppinglist" is not installed.
                Adapter "alexa-timer-vis" is not installed.
                Adapter "alexa2"         is not installed.
                Adapter "alias-manager"  is not installed.
                Adapter "alpha-ess"      is not installed.
                Adapter "alpha2"         is not installed.
                Adapter "amazon-dash"    is not installed.
                Adapter "amtronwallbox"  is not installed.
                Adapter "anelhut"        is not installed.
                Adapter "apcups"         is not installed.
                Adapter "apg-info"       is not installed.
                Adapter "artnet"         is not installed.
                Adapter "artnet-recorder" is not installed.
                Adapter "asterisk"       is not installed.
                Adapter "asuswrt"        is not installed.
                Adapter "atlas-scientific-ezo-i2c" is not installed.
                Adapter "awattar"        is not installed.
                Adapter "awtrix-light"   is not installed.
                Adapter "b-control-em"   is not installed.
                Invalid version of "js-controller". Installed "3.1.6", required ">=4.0.0
                Adapter "beckhoff"       is not installed.
                Adapter "benchmark"      is not installed.
                Adapter "benq"           is not installed.
                Adapter "bestway"        is not installed.
                Adapter "bidirectional-counter" is not installed.
                Adapter "birthdays"      is not installed.
                Adapter "ble"            is not installed.
                Adapter "blebox"         is not installed.
                Adapter "bluelink"       is not installed.
                Adapter "bmw"            is not installed.
                Adapter "bosch-ebike"    is not installed.
                Adapter "bosesoundtouch" is not installed.
                Adapter "botslab360"     is not installed.
                Adapter "botvac"         is not installed.
                Adapter "bring"          is not installed.
                Adapter "broadlink2"     is not installed.
                Adapter "bsblan"         is not installed.
                Adapter "bshb"           is not installed.
                Adapter "bwt"            is not installed.
                Adapter "bydbatt"        is not installed.
                Adapter "bydhvs"         is not installed.
                Adapter "canbus"         is not installed.
                Adapter "cec2"           is not installed.
                Adapter "chromecast"     is not installed.
                Adapter "cleveron"       is not installed.
                Adapter "cloud"          is not installed.
                Adapter "cloudflare"     is not installed.
                Adapter "comfoair"       is not installed.
                Adapter "contactid"      is not installed.
                Adapter "coronavirus-statistics" is not installed.
                Adapter "countdown"      is not installed.
                Adapter "cul"            is not installed.
                Adapter "daikin"         is not installed.
                Adapter "daikin-cloud"   is not installed.
                Adapter "daswetter"      is not installed.
                Adapter "deconz"         is not installed.
                Adapter "denon"          is not installed.
                Adapter "device-reminder" is not installed.
                Adapter "device-watcher" is not installed.
                Adapter "devices"        is not installed.
                Adapter "deyeidc"        is not installed.
                Adapter "digitalstrom"   is not installed.
                Adapter "discord"        is not installed.
                Adapter "discovergy"     is not installed.
                Adapter "discovery"      is up to date.
                Adapter "divera247"      is not installed.
                Adapter "doorbird"       is not installed.
                Adapter "doorio"         is not installed.
                Adapter "drag-indicator" is not installed.
                Adapter "ds18b20"        is not installed.
                Adapter "dwd"            is not installed.
                Adapter "dysonairpurifier" is not installed.
                Adapter "e3dc-rscp"      is not installed.
                Adapter "easee"          is not installed.
                Adapter "ebus"           is not installed.
                Adapter "echarts"        is not installed.
                Adapter "ecovacs-deebot" is not installed.
                Adapter "egigeozone"     is not installed.
                Adapter "ekey"           is not installed.
                Adapter "elero-usb-transmitter" is not installed.
                Adapter "email"          is not installed.
                Adapter "emby"           is not installed.
                Adapter "emporia"        is not installed.
                Adapter "ems-esp"        is not installed.
                Adapter "energiefluss"   is not installed.
                Adapter "energymanager"  is not installed.
                Adapter "enet"           is not installed.
                Adapter "enigma2"        is not installed.
                Adapter "envertech-pv"   is not installed.
                Adapter "epson_ecotank_et_2750" is not installed.
                Adapter "epson_stylus_px830" is not installed.
                Adapter "eusec"          is not installed.
                Adapter "evcc"           is not installed.
                Adapter "eventlist"      is not installed.
                Adapter "exchangerates"  is not installed.
                Adapter "fahrplan"       is not installed.
                Adapter "fakeroku"       is not installed.
                Adapter "fb-checkpresence" is not installed.
                Adapter "feiertage"      is not installed.
                Adapter "fhem"           is not installed.
                Adapter "fiat"           is not installed.
                Adapter "firetv"         is not installed.
                Adapter "fitbit-fitness" is not installed.
                Adapter "flot"           is not installed.
                Adapter "followthesun"   is not installed.
                Adapter "foobar2000"     is not installed.
                Adapter "ford"           is not installed.
                Adapter "frigate"        is not installed.
                Adapter "fritzbox"       is not installed.
                Adapter "fritzdect"      is not installed.
                Adapter "froeling"       is not installed.
                Adapter "fronius"        is not installed.
                Adapter "fronius-solarweb" is not installed.
                Adapter "fronius-wattpilot" is not installed.
                Adapter "frontier_silicon" is not installed.
                Adapter "fuelpricemonitor" is not installed.
                Adapter "fullcalendar"   is not installed.
                Adapter "fullybrowser"   is not installed.
                Adapter "g-homa"         is not installed.
                Adapter "garmin"         is not installed.
                Adapter "geofency"       is not installed.
                Adapter "gigaset-elements" is not installed.
                Adapter "gira-iot"       is not installed.
                Adapter "go-e"           is not installed.
                Adapter "govee-local"    is not installed.
                Adapter "growatt"        is not installed.
                Adapter "gruenbeck"      is not installed.
                Adapter "gsmsms"         is not installed.
                Adapter "haassohn"       is not installed.
                Adapter "habpanel"       is not installed.
                Adapter "haier"          is not installed.
                Adapter "ham"            is not installed.
                Adapter "ham-wemo"       is not installed.
                Adapter "harmony"        is not installed.
                Adapter "hass"           is not installed.
                Adapter "hausbus_de"     is not installed.
                Adapter "heatingcontrol" is not installed.
                Adapter "heizoel"        is not installed.
                Adapter "heizungssteuerung" is not installed.
                Adapter "hekr"           is not installed.
                Adapter "helios"         is not installed.
                Adapter "heos"           is not installed.
                Adapter "heytech"        is not installed.
                Adapter "hid-community"  is not installed.
                Adapter "hikvision-alarmserver" is not installed.
                Adapter "history"        is not installed.
                Adapter "hm-rega"        is not installed.
                Adapter "hm-rpc"         is not installed.
                Adapter "hmip"           is not installed.
                Adapter "homeconnect"    is not installed.
                Adapter "homee"          is not installed.
                Adapter "homekit-controller" is not installed.
                Adapter "homenet"        is not installed.
                Adapter "homepilot"      is not installed.
                Adapter "hoover"         is not installed.
                Adapter "hp-ilo"         is not installed.
                Adapter "hs100"          is not installed.
                Adapter "hue"            is not installed.
                Adapter "huum-sauna"     is not installed.
                Adapter "i2c"            is not installed.
                Invalid version of "admin". Installed "4.1.11", required ">=5.3.2
                Adapter "iceroad"        is not installed.
                Adapter "ico-cloud"      is not installed.
                Adapter "icons-addictive-flavour-png" is not installed.
                Adapter "icons-eclipse-smarthome-classic" is not installed.
                Adapter "icons-fatcow-hosting" is not installed.
                Adapter "icons-freepic"  is not installed.
                Adapter "icons-icons8"   is not installed.
                Adapter "icons-material-png" is not installed.
                Adapter "icons-material-svg" is not installed.
                Adapter "icons-mfd-png"  is up to date.
                Adapter "icons-mfd-svg"  is not installed.
                Adapter "icons-open-icon-library-png" is not installed.
                Adapter "icons-smarthome" is not installed.
                Adapter "icons-ultimate-png" is not installed.
                Adapter "ikettle2"       is not installed.
                Adapter "imap"           is not installed.
                Adapter "imow"           is not installed.
                Invalid version of "js-controller". Installed "3.1.6", required ">=3.3.0
                Update info from @1.7.10 to @2.0.0
                NPM version: 10.2.3
                npm install iobroker.info@2.0.0 --loglevel error --prefix "/opt/iobroker" (System call)
                Adapter "system.adapter.vis.0" restarted.
                Update "system.adapter.info.0"
                upload [90] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
                upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/helper.js lib/js/helper.js application/javascript
                upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootbox.min.js lib/js/bootbox.min.js application/javascript
                upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/redhat.png lib/img/logos/redhat.png image/png
                upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/mandriva.png lib/img/logos/mandriva.png image/png
                upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/centos.png lib/img/logos/centos.png image/png
                upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/graphics.png lib/img/icons/graphics.png image/png
                upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
                upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/de/translations.json i18n/de/translations.json application/json
                Adapter "info" updated
                Adapter "innogy-smarthome" is not installed.
                Adapter "innoxel"        is not installed.
                Adapter "intex"          is not installed.
                Adapter "iot"            is not installed.
                Adapter "iqontrol"       is not installed.
                Adapter "iwg-vpn"        is not installed.
                Adapter "janitza-gridvis" is not installed.
                Adapter "jarvis"         is not installed.
                Invalid version of "admin". Installed "4.1.11", required ">=5.1.28
                Adapter "jeelink"        is not installed.
                Adapter "judoisoft"      is not installed.
                Adapter "kecontact"      is not installed.
                Adapter "klf200"         is not installed.
                Adapter "knmi-weather"   is not installed.
                Adapter "kodi"           is not installed.
                Adapter "kostal-piko-ba" is not installed.
                Adapter "lametric"       is not installed.
                Adapter "lcn"            is not installed.
                Adapter "legrand-ecocompteur" is not installed.
                Adapter "letrika_comgw"  is not installed.
                Adapter "lg-ess-home"    is not installed.
                Adapter "lg-thinq"       is not installed.
                Adapter "lgtv"           is not installed.
                Adapter "lgtv-rs"        is not installed.
                Adapter "lgtv11"         is not installed.
                Adapter "libre"          is not installed.
                Adapter "lifx"           is not installed.
                Adapter "lightcontrol"   is not installed.
                Adapter "lightify"       is not installed.
                Adapter "link"           is not installed.
                Adapter "link2home"      is not installed.
                Adapter "linkeddevices"  is not installed.
                Adapter "linktap"        is not installed.
                Update linux-control from @1.1.2 to @1.1.5
                NPM version: 10.2.3
                npm install iobroker.linux-control@1.1.5 --loglevel error --prefix "/opt/iobroker" (System call)
                upload [20] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/words.js words.js application/javascript
                Update "system.adapter.linux-control.0"
                upload [19] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/style.css style.css text/css
                upload [18] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/linux-control.png linux-control.png image/png
                upload [17] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/updates.json lib/updates.json application/json
                upload [16] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/services.json lib/services.json application/json
                upload [15] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/needrestart.json lib/needrestart.json application/json
                upload [14] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/jquery.fancytree.dnd5.js lib/jquery.fancytree.dnd5.js application/javascript
                upload [13] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/info.json lib/info.json application/json
                upload [12] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/distribution.json lib/distribution.json application/json
                upload [11] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/control.json lib/control.json application/json
                upload [10] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/index_m.js index_m.js application/javascript
                upload [9] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/index_m.html index_m.html text/html
                upload [8] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/state.png img/state.png image/png
                upload [7] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/menu_right.svg img/menu_right.svg image/svg+xml
                upload [6] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/menu_down.svg img/menu_down.svg image/svg+xml
                upload [5] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/info-big.png img/info-big.png image/png
                upload [4] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/folder.png img/folder.png image/png
                upload [3] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/checkbox_marked.svg img/checkbox_marked.svg image/svg+xml
                upload [2] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/checkbox_intermediate.svg img/checkbox_intermediate.svg image/svg+xml
                upload [1] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/checkbox.svg img/checkbox.svg image/svg+xml
                upload [0] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/admin.d.ts admin.d.ts video/mp2t
                Adapter "linux-control" updated
                Adapter "logparser"      is not installed.
                Adapter "loqed"          is not installed.
                Adapter "lovelace"       is not installed.
                Adapter "lowpass-filter" is not installed.
                Adapter "loxone"         is not installed.
                Adapter "luftdaten"      is not installed.
                Adapter "lupusec"        is not installed.
                Adapter "luxtronik1"     is not installed.
                Adapter "material"       is not installed.
                Adapter "matrix-org"     is not installed.
                Adapter "maveo"          is not installed.
                Adapter "maxcube"        is not installed.
                Adapter "maxcul"         is not installed.
                Adapter "mbus"           is not installed.
                Adapter "mclighting"     is not installed.
                Adapter "meater"         is not installed.
                Adapter "mediola-gateway" is not installed.
                Adapter "megad"          is not installed.
                Adapter "megadd"         is not installed.
                Adapter "megaesp"        is not installed.
                Adapter "melcloud"       is not installed.
                Adapter "mercedesme"     is not installed.
                Adapter "mercury"        is not installed.
                Adapter "meross"         is not installed.
                Adapter "meteoalarm"     is not installed.
                Adapter "micronova"      is not installed.
                Adapter "midea"          is not installed.
                Adapter "miele"          is not installed.
                Adapter "mielecloudservice" is not installed.
                Adapter "mihome"         is not installed.
                Adapter "mihome-cloud"   is not installed.
                Adapter "mihome-lamp"    is not installed.
                Adapter "mihome-plug"    is not installed.
                Adapter "mihome-vacuum"  is not installed.
                Adapter "mikrotik"       is not installed.
                Adapter "milight"        is not installed.
                Adapter "milight-smart-light" is not installed.
                Adapter "minuvis"        is not installed.
                Adapter "mobile"         is not installed.
                Adapter "modbus"         is not installed.
                Adapter "moma"           is not installed.
                Adapter "mpd"            is not installed.
                Adapter "mqtt"           is not installed.
                Adapter "mqtt-client"    is not installed.
                Adapter "musiccast"      is not installed.
                Adapter "mydlink"        is not installed.
                Adapter "myenergi"       is not installed.
                Adapter "mysensors"      is not installed.
                Adapter "mystrom"        is not installed.
                Adapter "myvbus"         is not installed.
                Adapter "nanoleaf-lightpanels" is not installed.
                Adapter "net-tools"      is not installed.
                Adapter "netatmo"        is not installed.
                Adapter "netatmo-crawler" is not installed.
                Adapter "netatmo-energy" is not installed.
                Adapter "nibeuplink"     is not installed.
                Adapter "nina"           is not installed.
                Adapter "nissan"         is not installed.
                Adapter "niu"            is not installed.
                Adapter "notification-manager" is not installed.
                Adapter "nsclient"       is not installed.
                Adapter "nuki"           is not installed.
                Adapter "nuki-extended"  is not installed.
                Adapter "nut"            is not installed.
                Adapter "ocpp"           is not installed.
                Adapter "octoprint"      is not installed.
                Adapter "odl"            is not installed.
                Adapter "oekofen-json"   is not installed.
                Adapter "oilfox"         is not installed.
                Adapter "omnicomm-lls"   is not installed.
                Adapter "onkyo"          is not installed.
                Adapter "onvif"          is not installed.
                Adapter "opendtu"        is not installed.
                Adapter "openhab"        is not installed.
                Adapter "openknx"        is not installed.
                Adapter "openligadb"     is not installed.
                Adapter "openweathermap" is not installed.
                Adapter "operating-hours" is not installed.
                Adapter "opi"            is not installed.
                Adapter "oppoplayer"     is not installed.
                Adapter "owfs"           is not installed.
                Adapter "owntracks"      is not installed.
                Adapter "panasonic-comfort-cloud" is not installed.
                Adapter "panasonic-viera" is not installed.
                Adapter "parcel"         is not installed.
                Adapter "parser"         is not installed.
                Adapter "paw"            is not installed.
                Adapter "pegelalarm"     is not installed.
                Adapter "ph803w"         is not installed.
                Adapter "phantomjs"      is not installed.
                Adapter "philips-air"    is not installed.
                Adapter "philips-tv"     is not installed.
                Adapter "pi-hole"        is not installed.
                Adapter "piface"         is not installed.
                Adapter "pimatic"        is not installed.
                Adapter "ping"           is not installed.
                Adapter "pixelit"        is not installed.
                Adapter "places"         is not installed.
                Adapter "plenticore"     is not installed.
                Adapter "plex"           is not installed.
                Adapter "plexconnect"    is not installed.
                Adapter "pollenflug"     is not installed.
                Adapter "porsche"        is not installed.
                Adapter "powerfox2"      is not installed.
                Adapter "procon-ip"      is not installed.
                Adapter "proxmox"        is not installed.
                Adapter "proxy"          is not installed.
                Adapter "psa"            is not installed.
                Adapter "puppeteer"      is not installed.
                Adapter "pushbullet"     is not installed.
                Adapter "pushover"       is not installed.
                Adapter "pushsafer"      is not installed.
                Adapter "pvforecast"     is not installed.
                Adapter "pvoutputorg"    is not installed.
                Adapter "pylontech"      is not installed.
                Adapter "radar2"         is not installed.
                Adapter "radiohead"      is not installed.
                Adapter "rct"            is not installed.
                Adapter "renacidc"       is not installed.
                Adapter "renault"        is not installed.
                Adapter "reolink"        is not installed.
                Adapter "residents"      is not installed.
                Adapter "resol"          is not installed.
                Adapter "rest-api"       is not installed.
                Adapter "rflink"         is not installed.
                Adapter "rickshaw"       is not installed.
                Adapter "ring"           is not installed.
                Adapter "robonect"       is not installed.
                Adapter "roborock"       is not installed.
                Adapter "roomba"         is not installed.
                Adapter "rpi2"           is not installed.
                Adapter "rssfeed"        is not installed.
                Adapter "s7"             is not installed.
                Adapter "sainlogic"      is not installed.
                Adapter "samsung"        is not installed.
                Adapter "samsung_tizen"  is not installed.
                Adapter "sanext"         is not installed.
                Adapter "sayit"          is not installed.
                Adapter "sbfspot"        is not installed.
                Adapter "scenes"         is not installed.
                Adapter "scheduler"      is not installed.
                Adapter "schoolfree"     is not installed.
                Adapter "schwoerer-ventcube" is not installed.
                Adapter "seko"           is not installed.
                Adapter "selverf"        is not installed.
                Adapter "semp"           is not installed.
                Adapter "seq"            is not installed.
                Adapter "shelly"         is not installed.
                Adapter "shuttercontrol" is not installed.
                Adapter "sia"            is not installed.
                Adapter "siegenia"       is not installed.
                Adapter "signal-cmb"     is not installed.
                Adapter "signifylights"  is not installed.
                Adapter "simple-api"     is up to date.
                Adapter "sma-em"         is not installed.
                Adapter "smappee"        is not installed.
                Adapter "smart-eq"       is not installed.
                Adapter "smartcontrol"   is not installed.
                Adapter "smartgarden"    is not installed.
                Adapter "smartmeter"     is not installed.
                Adapter "smartthings"    is not installed.
                Adapter "snips"          is not installed.
                Adapter "snmp"           is not installed.
                Invalid version of "admin". Installed "4.1.11", required ">=5.0.0
                Adapter "solarlog"       is not installed.
                Adapter "solarmanpv"     is not installed.
                Adapter "solarviewdatareader" is not installed.
                Adapter "solarwetter"    is not installed.
                Adapter "solax"          is not installed.
                Adapter "sonnen"         is not installed.
                Adapter "sonoff"         is not installed.
                Adapter "sonos"          is not installed.
                Adapter "sony-bravia"    is not installed.
                Adapter "spotify-premium" is not installed.
                Adapter "sprinklecontrol" is not installed.
                Adapter "sql"            is not installed.
                Adapter "squeezeboxrpc"  is not installed.
                Adapter "starline"       is not installed.
                Adapter "stiebel-isg"    is not installed.
                Adapter "sureflap"       is not installed.
                Adapter "swiss-weather-api" is not installed.
                Adapter "synochat"       is not installed.
                Adapter "synology"       is not installed.
                Adapter "systeminfo"     is not installed.
                Adapter "tado"           is not installed.
                Adapter "tahoma"         is not installed.
                Adapter "tankerkoenig"   is not installed.
                Adapter "tapo"           is not installed.
                Adapter "telegram"       is not installed.
                Adapter "telegram-menu"  is not installed.
                Adapter "terminal"       is not installed.
                Adapter "tesla-motors"   is not installed.
                Adapter "text2command"   is not installed.
                Adapter "tibberlink"     is not installed.
                Adapter "tinker"         is not installed.
                Adapter "tinymqttbroker" is not installed.
                Adapter "toyota"         is not installed.
                Adapter "tr-064"         is up to date.
                Adapter "traccar"        is not installed.
                Adapter "tractive-gps"   is not installed.
                Adapter "tradfri"        is not installed.
                Invalid version of "js-controller". Installed "3.1.6", required ">=4.0.15
                Adapter "trivum"         is not installed.
                Adapter "tronity"        is not installed.
                Adapter "tunnelbroker-endpoint-updater" is not installed.
                Adapter "tuya"           is not installed.
                Adapter "tvprogram"      is not installed.
                Adapter "tvspielfilm"    is not installed.
                Adapter "twinkly"        is not installed.
                Adapter "unifi"          is not installed.
                Adapter "uv-protect"     is not installed.
                Adapter "vaillant"       is not installed.
                Adapter "valloxmv"       is not installed.
                Adapter "valuetrackerovertime" is not installed.
                Adapter "vcard"          is not installed.
                Adapter "vds2465-server" is not installed.
                Adapter "velux"          is not installed.
                Adapter "vesync"         is not installed.
                Adapter "viessmann"      is not installed.
                Adapter "viessmannapi"   is not installed.
                Adapter "virtualpowermeter" is not installed.
                Update vis from @1.3.4 to @1.5.4
                NPM version: 10.2.3
                npm install iobroker.vis@1.5.4 --loglevel error --prefix "/opt/iobroker" (System call)
                upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/6-1.png widgets/timeandweather/img/clock/6-1.png image/png
                upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/01-1.png widgets/timeandweather/img/clock/01-1.png image/png
                upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/sani_valve_60.png widgets/jqui-mfd/img/sani_valve_60.png image/png
                upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_window_roof.svg widgets/jqui-mfd/img/fts_window_roof.svg image/svg+xml
                upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/authors.txt widgets/jqui-mfd/img/authors.txt text/plain
                upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/css/glossy.css widgets/hqwidgets/css/glossy.css text/css
                upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/pin_red5.svg widgets/basic/img/pin_red5.svg image/svg+xml
                upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/bars/js/jquery.sidebar.js widgets/bars/js/jquery.sidebar.js application/javascript
                upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery-ui-timepicker-addon-1.6.3.js lib/js/jquery-ui-timepicker-addon-1.6.3.js application/javascript
                upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditExt.js js/visEditExt.js application/javascript
                upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/back.png js/fm/icon/actions/back.png image/png
                upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/img/zip.png img/zip.png image/png
                upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
                upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
                upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
                upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
                upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
                upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
                upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
                upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
                upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
                upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
                upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
                upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
                upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
                upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
                upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
                upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
                upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
                upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
                upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
                upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
                upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff font/woff
                upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
                upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
                upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
                upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
                upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
                upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                Update "system.adapter.vis.0"
                Adapter "vis" updated
                Adapter "vis-2"          is not installed.
                Adapter "vis-2-widgets-energy" is not installed.
                Adapter "vis-2-widgets-gauges" is not installed.
                Adapter "vis-2-widgets-jaeger-design" is not installed.
                Adapter "vis-2-widgets-material" is not installed.
                Adapter "vis-bars"       is up to date.
                Adapter "vis-canvas-gauges" is not installed.
                Adapter "vis-colorpicker" is up to date.
                Adapter "vis-fancyswitch" is up to date.
                Adapter "vis-google-fonts" is not installed.
                Adapter "vis-history"    is not installed.
                Adapter "vis-hqwidgets"  is up to date.
                Adapter "vis-icontwo"    is not installed.
                Adapter "vis-inventwo"   is not installed.
                Adapter "vis-jqui-mfd"   is up to date.
                Adapter "vis-justgage"   is not installed.
                Adapter "vis-keyboard"   is not installed.
                Adapter "vis-lcars"      is not installed.
                Adapter "vis-map"        is not installed.
                Adapter "vis-material"   is not installed.
                Adapter "vis-material-advanced" is not installed.
                Adapter "vis-materialdesign" is not installed.
                Adapter "vis-metro"      is not installed.
                Adapter "vis-players"    is not installed.
                Adapter "vis-plumb"      is not installed.
                Adapter "vis-rgraph"     is not installed.
                Adapter "vis-timeandweather" is up to date.
                Adapter "vis-weather"    is not installed.
                Adapter "voltoplus"      is not installed.
                Adapter "volumio"        is not installed.
                Adapter "volvo"          is not installed.
                Adapter "vr200"          is not installed.
                Adapter "vw-connect"     is not installed.
                Adapter "wallpanel"      is not installed.
                Adapter "warp"           is not installed.
                Adapter "weather-warnings" is not installed.
                Adapter "weatherflow_udp" is not installed.
                Adapter "weatherunderground" is not installed.
                Invalid version of "admin". Installed "4.1.11", required ">=5.1.0
                Adapter "webcal"         is not installed.
                Adapter "webui"          is not installed.
                Adapter "webuntis"       is not installed.
                Adapter "weishaupt-wem"  is not installed.
                Adapter "welcome"        is not installed.
                Adapter "whatsapp-cmb"   is not installed.
                Adapter "wiegand-tcpip"  is not installed.
                Adapter "wiffi-wz"       is not installed.
                Adapter "wifilight"      is not installed.
                Adapter "windows-control" is not installed.
                Adapter "wiobrowser"     is not installed.
                Adapter "wireguard"      is not installed.
                Adapter "wireless-mbus"  is not installed.
                Adapter "withings"       is not installed.
                Adapter "wlanthermo-nano" is not installed.
                Adapter "wled"           is not installed.
                Adapter "wmswebcontrol"  is not installed.
                Adapter "wolf"           is not installed.
                Adapter "wolf-smartset"  is not installed.
                Adapter "worx"           is not installed.
                Adapter "ws"             is not installed.
                Adapter "x-touch"        is not installed.
                Adapter "xbox"           is not installed.
                Adapter "xs1"            is not installed.
                Adapter "xterm"          is not installed.
                Adapter "yahka"          is not installed.
                Adapter "yahoo-stock-market" is not installed.
                Adapter "yamaha"         is not installed.
                Adapter "yeelight-2"     is not installed.
                Adapter "youtube"        is not installed.
                Adapter "yr"             is not installed.
                Adapter "zehnder-cloud"  is not installed.
                Adapter "zendure-solarflow" is not installed.
                Adapter "zigbee"         is not installed.
                Adapter "zigbee2mqtt"    is not installed.
                Adapter "zont"           is not installed.
                Adapter "zwave2"         is not installed.
                pi@raspberrypi:~ $ iob stop
                  @frank-knx
                  Muss ich mir morgen anschauen. N8
                    OK ich halte mich bereit und mache vor deiner Rückmeldung keine Aktionen (um nichts zu Verschlimmern).
                      Thomas Braun Most Active @Frank-KNX last edited by Thomas Braun
                      @frank-knx
                      Versuch mal:
                      iob stop
                      cd /opt/iobroker
                      sudo -H -u iobroker npm install iobroker.js-controller
                      iob update
                      iob upgrade admin
                      iob upgrade all
                      iob start
                        Alle Befehle sind erfolgreich und ohne Fehlermeldung durchgelaufen.
                        Im iobroker selbst unter Info erscheint die Meldung, dass alle Adapter aktuell sind.
                        ich habe "iob diag" nochmal gestartet und nachfolgend der Report.
                        Habe ich es nun mit deiner Hilfe erfolgreich geschafft oder ist noch etwas zu fixen ?
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm
                        Model           : Raspberry Pi 4 Model B Rev 1.4
                        Docker          : false
                        Virtualization  : none
                        Kernel          : armv7l
                        Userland        : armhf
                        Systemuptime and Load:
                         17:40:21 up 16:57,  3 users,  load average: 0.81, 1.75, 1.33
                        CPU threads: 4
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** Time and Time Zones ***
                                       Local time: Sat 2024-02-03 17:40:21 CET
                                   Universal time: Sat 2024-02-03 16:40:21 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** User and Groups ***
                        pi
                        /home/pi
                        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                        *** X-Server-Setup ***
                        X-Server:       true
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:           7.9G        1.2G        4.9G         39M        1.7G        6.5G
                        Swap:           99M          0B         99M
                        Total:         8.0G        1.2G        5.0G
                                 7898 M total memory
                                 1209 M used memory
                                  531 M active memory
                                 2209 M inactive memory
                                 4942 M free memory
                                  158 M buffer memory
                                 1589 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FAILED SERVICES ***
                          UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
                        * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
                        LOAD   = Reflects whether the unit definition was properly loaded.
                        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                        SUB    = The low-level unit activation state, values depend on unit type.
                        1 loaded units listed. Pass --all to see loaded but inactive units, too.
                        To show all installed unit files use 'systemctl list-unit-files'.
                        *** FILESYSTEM ***
                        /dev/root      ext4      117G   11G  102G  10% /
                        devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
                        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                        tmpfs          tmpfs     3.9G  8.7M  3.9G   1% /run
                        tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
                        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                        tmpfs          tmpfs     790M  4.0K  790M   1% /run/user/1000
                        [Sat Feb  3 00:42:27 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:D3:7A:A7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=def5eda3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                        [Sat Feb  3 00:42:28 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                        [Sat Feb  3 00:42:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Sat Feb  3 00:42:31 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                        TARGET                SOURCE         FSTYPE          OPTIONS
                        /                     /dev/mmcblk0p2 ext4            rw,noatime
                        |-/sys/fs/bpf         none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
                        |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                        `-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        1.5G    /var/
                        1.1G    /var/cache/apt/archives
                        1.1G    /var/cache/apt
                        1.1G    /var/cache
                        250M    /var/lib
                        Archived and active journals take up 8.0M in the file system.
                        /opt/iobroker/backups:
                        101M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        256M    /opt/iobroker/iobroker-data/
                        169M    /opt/iobroker/iobroker-data/files
                        67M     /opt/iobroker/iobroker-data/files/javascript.admin
                        50M     /opt/iobroker/iobroker-data/backup-objects
                        48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                        16M     /opt/iobroker/iobroker-data/objects.jsonl
                        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                        7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
                        7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
                        USB-Devices by-id:
                        *** NodeJS-Installation ***
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Installed: 18.19.0-1nodesource1
                          Candidate: 18.19.0-1nodesource1
                          Version table:
                         *** 18.19.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                                100 /var/lib/dpkg/status
                             18.18.2-1nodesource1 1001
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                             10.24.0~dfsg-1~deb10u3 500
                        No problems detected
                        Errors in npm tree:
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  5.0.17
                        admin:          6.13.15
                        javascript:     7.1.6
                        Adapters from github:   0
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
                        + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                        + system.adapter.knx.0                    : knx                   : raspberrypi                              -  enabled, bind: 192.168.2.98
                          system.adapter.linux-control.0          : linux-control         : raspberrypi                              -  enabled
                        + system.adapter.meldungsliste.0          : meldungsliste         : raspberrypi                              -  enabled
                          system.adapter.meldungsliste.1          : meldungsliste         : raspberrypi                              -  enabled
                        + system.adapter.meldungsliste.10         : meldungsliste         : raspberrypi                              -  enabled
                        + system.adapter.meldungsliste.11         : meldungsliste         : raspberrypi                              -  enabled
                        + system.adapter.meldungsliste.12         : meldungsliste         : raspberrypi                              -  enabled
                        + system.adapter.meldungsliste.13         : meldungsliste         : raspberrypi                              -  enabled
                        + system.adapter.meldungsliste.2          : meldungsliste         : raspberrypi                              -  enabled
                        + system.adapter.meldungsliste.3          : meldungsliste         : raspberrypi                              -  enabled
                        + system.adapter.meldungsliste.4          : meldungsliste         : raspberrypi                              -  enabled
                        + system.adapter.meldungsliste.5          : meldungsliste         : raspberrypi                              -  enabled
                        + system.adapter.meldungsliste.6          : meldungsliste         : raspberrypi                              -  enabled
                        + system.adapter.meldungsliste.7          : meldungsliste         : raspberrypi                              -  enabled
                          system.adapter.meldungsliste.8          : meldungsliste         : raspberrypi                              -  enabled
                        + system.adapter.meldungsliste.9          : meldungsliste         : raspberrypi                              -  enabled
                        + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 192.168.2.98
                        + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
                          system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                          system.adapter.upnp.0                   : upnp                  : raspberrypi                              - disabled
                          system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + instance is alive
                        ioBroker-Repositories
                        Stable (default): http://download.iobroker.net/sources-dist.json
                        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                        Active repo(s): Stable (default)
                        Installed ioBroker-Instances
                        Used repository: Stable (default)
                        Adapter    "admin"        : 6.13.15  , installed 6.13.15
                        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                        Controller "js-controller": 5.0.17   , installed 5.0.17
                        Adapter    "knx"          : 2.0.24   , installed 2.0.24
                        Adapter    "linux-control": 1.1.5    , installed 1.1.5
                        Adapter    "node-red"     : 5.1.0    , installed 5.1.0
                        Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                        Adapter    "web"          : 6.2.3    , installed 6.2.3
                        Adapter    "ws"           : 2.5.10   , installed 2.5.10
                        Objects and States
                        Objects:        3877
                        States:         2729
                        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                        Hit:3 https://repos.influxdata.com/debian stable InRelease
                        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 1
                        *** Listening Ports ***
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17021      555/sshd
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17841      420/cupsd
                        tcp        0      0 192.168.2.98:1880       0.0.0.0:*               LISTEN      1001       49471      9582/node-red
                        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        19766      482/influxd
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       48023      9500/iobroker.js-co
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       48016      9500/iobroker.js-co
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       48066      9521/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       53319      9865/io.web.0
                        tcp6       0      0 :::8086                 :::*                    LISTEN      999        20061      482/influxd
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          17031      555/sshd
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17840      420/cupsd
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17159      484/dhcpcd
                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18593      532/cups-browsed
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16137      413/avahi-daemon: r
                        udp        0      0 0.0.0.0:59135           0.0.0.0:*                           1001       49473      9582/node-red
                        udp        0      0 0.0.0.0:42781           0.0.0.0:*                           108        16139      413/avahi-daemon: r
                        udp        0      0 192.168.2.98:39748      0.0.0.0:*                           1001       53569      10234/io.knx.0
                        udp        0      0 192.168.2.98:46929      0.0.0.0:*                           1001       51070      10234/io.knx.0
                        udp6       0      0 :::546                  :::*                                0          20302      484/dhcpcd
                        udp6       0      0 :::52887                :::*                                108        16140      413/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                108        16138      413/avahi-daemon: r
                        2024-02-03 17:41:57.874  - info: knx.0 (10234) WRITE : mappedName : Temperatur Wasser Teich    dest : 4/3/3  val: 6.4   (DPT9.001) Temperatur_Wasser_Teich
                        2024-02-03 17:41:57.874  - info: knx.0 (10234) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
                        2024-02-03 17:41:57.875  - info: knx.0 (10234) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
                        2024-02-03 17:41:57.875  - info: knx.0 (10234) =====> STATE_TUNNELING_ACK
                        2024-02-03 17:41:57.876  - info: knx.0 (10234) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 55 87 00   ChID : 85 SeqCntIN : 135 SeqCntOUT : 25 queue length : 0
                        2024-02-03 17:41:57.877  - info: knx.0 (10234) ( 4.b ) return to STATE_READY, processing : false
                        2024-02-03 17:41:57.877  - info: knx.0 (10234) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
                        2024-02-03 17:41:56.303  - info: influxdb.0 (9607) Influx DB Version used: 1.x
                        2024-02-03 17:41:56.503  - error: influxdb.0 (9607) Error: authorization failed
                        2024-02-03 17:41:58.728  - info: knx.0 (10234) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 19 04 55 88 00 29 00 bc c0 12 3c 28 03 05 00 80 00 00 01 c4   ChID: 85
                        2024-02-03 17:41:58.729  - info: knx.0 (10234) WRITE : mappedName : Energie kWh    dest : 5/0/3  val: 452   (DPT13.013) Energie_kWh
                        2024-02-03 17:41:58.730  - info: knx.0 (10234) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
                        2024-02-03 17:41:58.730  - info: knx.0 (10234) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
                        2024-02-03 17:41:58.731  - info: knx.0 (10234) =====> STATE_TUNNELING_ACK
                        2024-02-03 17:41:58.733  - info: knx.0 (10234) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 55 88 00   ChID : 85 SeqCntIN : 136 SeqCntOUT : 25 queue length : 0
                        2024-02-03 17:41:58.733  - info: knx.0 (10234) ( 4.b ) return to STATE_READY, processing : false
                        2024-02-03 17:41:58.733  - info: knx.0 (10234) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
                        2024-02-03 17:41:58.751  - info: knx.0 (10234) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 19 04 55 89 00 29 00 bc c0 12 3c 28 02 05 00 80 00 06 e9 02   ChID: 85
                        2024-02-03 17:41:58.753  - info: knx.0 (10234) WRITE : mappedName : Energie Wh    dest : 5/0/2  val: 452866   (DPT13.010) Energie_Wh
                        2024-02-03 17:41:58.754  - info: knx.0 (10234) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
                        2024-02-03 17:41:58.754  - info: knx.0 (10234) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
                        2024-02-03 17:41:58.755  - info: knx.0 (10234) =====> STATE_TUNNELING_ACK
                        2024-02-03 17:41:58.756  - info: knx.0 (10234) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 55 89 00   ChID : 85 SeqCntIN : 137 SeqCntOUT : 25 queue length : 0
                        2024-02-03 17:41:58.756  - info: knx.0 (10234) ( 4.b ) return to STATE_READY, processing : false
                        2024-02-03 17:41:58.757  - info: knx.0 (10234) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
                          @frank-knx sagte in Update js-Controller 3.x auf 5.x funktioniert nicht:
                          Schaut jetzt wohl soweit i. O. aus.
                          Aber was ist denn das für ein Adapter? Der dann auch ein Dutzend Instanzen anschleppt?
                          Backup ziehen und das Betriebssystem auf einen aktuellen Stand bringen. Dein 'Buster' ist tot.
                            Hallo Thomas,
                            herzlichen Dank für deine professionelle Unterstützung.
                            Jetzt muss ich in meiner VIS nur noch schauen, ob durch die Updates am Verhalten eine Änderung aufgetreten ist.
                            Diesen Adapter Meldungsliste nutze ich in der VIS für alle Beleuchtungen und Co, die ich über KNX abgreife. Damit generiere ich auf der Hauptseite dann Meldungen, wie "Licht im Haus an", wenn eines der Lichter an ist oder "Fenster offen". Ich habe dort so viele Gruppen, dass ich jedes Mal einen Adapter benötige. Die laufen aber "bisher" sehr stabil und zuverlässig.
                            Jetzt werde ich das System nochmal genau anschauen, ob alle bisherigen Funktionen laufen und dann werde ich das nächste Projekt mit dem von dir angesprochenen Update in Angriff nehmen.
                            Da werde ich sicher nochmal auf euch Fachleute aus dem Forum zurückkommen, bevor ich als "Halbwissender" hier falsche Dinge mache und am Ende nichts mehr läuft.
                            Besten Dank
                            FRANK
                              Thomas Braun Most Active last edited by Thomas Braun
                              @frank-knx
                              Ich würde den knx auf ein weniger gesprächiges LogLevel setzten.
                              Und bei
                              Pending Updates: 1
                              Kannst du gleich trainieren, wie mal die Kiste aktuell hält.
                              sudo apt update
                              sudo apt full-upgrade
                                Frank579 @Thomas Braun last edited by
                                @thomas-braun sagte in Update js-Controller 3.x auf 5.x funktioniert nicht:
                                sudo full-upgrade
                                fehlt da nicht ein apt ? oder geht das jetzt auch so?
                                  Thomas Braun Most Active @Frank579 last edited by
                                  @frank579 sagte in Update js-Controller 3.x auf 5.x funktioniert nicht:
                                  Gut aufgepasst. Ich hab es korrigiert.
                                  4599
