    4. Update js-Controller 3.x auf 5.x funktioniert nicht
      Thomas Braun Most Active @Frank-KNX last edited by
      @frank-knx
      iob update
      iob upgrade
      iob stop
      iob upgrade self
      iob start
        Frank-KNX @Thomas Braun last edited by
        Hallo Thomas,
        also bei upgrade self bleibt er wieder hängen.
        Nachfolgend die Fehlermeldung:
        pi@raspberrypi:~ $ iob upgrade self
        Update js-controller from @3.1.6 to @5.0.17
        NPM version: 10.2.3
        npm install iobroker.js-controller@5.0.17 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
         Objects 127.0.0.1:36630 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
         States 127.0.0.1:43550 Error from InMemDB: Error: CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
         Objects 127.0.0.1:36630 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
         States 127.0.0.1:43550 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
         Objects 127.0.0.1:36630 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
         Objects 127.0.0.1:36630 Error from InMemDB: Error: scan NOT SUPPORTED
        npm ERR! code 1
        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
        npm ERR! command failed
        npm ERR! command sh -c node iobroker.js setup first
        npm ERR! Unable to increase LUA script timeout: Error CONFIG-UNSUPPORTED for ["SET","lua-time-limit","10000"]
        npm ERR!  Unable to enable Expiry Keyspace events from Redis Server: Error CONFIG-UNSUPPORTED for ["SET","notify-keyspace-events","Exe"]
        npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
        npm ERR!         throw e;
        npm ERR!         ^
        npm ERR!
        npm ERR! ReplyError: Error scan NOT SUPPORTED
        npm ERR!     at parseError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:179:12)
        npm ERR!     at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:302:14)
        npm ERR! Emitted 'error' event on ScanStream instance at:
        npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
        npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
        npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
        npm ERR!     at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
        npm ERR!   command: {
        npm ERR!     name: 'scan',
        npm ERR!     args: [ '0', 'MATCH', 'cfg.o.system.host.*', 'COUNT', '250' ]
        npm ERR!   }
        npm ERR! }
        npm ERR!
        npm ERR! Node.js v18.19.0
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-03T00_01_36_505Z-debug-0.log
        Starting node restart.js
        pi@raspberrypi:~ $
          @frank-knx
          Die Adapter-Updates sind durch?
          iob update
          sagt?
            Ja, Updates sind ohne Fehlermeldung durchgelaufen. Auch das iob upgrade.
            Erst nach iob stop und dann upgrade self die Fehlermeldung.
              Frank-KNX @Frank-KNX last edited by
              Muss noch ergänzen..
              Nachfolgend upgrade...
              Alles nicht instalierten Adapter werden angezeigt.. aber die installierten meldet er, als nicht upgedated, weil die JS-Controller Version ja bekanntlich zu alt ist => Das will ich ja gerade ändern...
              Adapter "accuweather"    is not installed.
              Adapter "acme"           is not installed.
              Adapter "adb"            is not installed.
              Adapter "adguard"        is not installed.
              Invalid version of "js-controller". Installed "3.1.6", required ">=3.3.22
              Adapter "aio"            is not installed.
              Adapter "airconwithme"   is not installed.
              Adapter "airzone"        is not installed.
              Adapter "alarm"          is not installed.
              Adapter "alexa-shoppinglist" is not installed.
              Adapter "alexa-timer-vis" is not installed.
              Adapter "alexa2"         is not installed.
              Adapter "alias-manager"  is not installed.
              Adapter "alpha-ess"      is not installed.
              Adapter "alpha2"         is not installed.
              Adapter "amazon-dash"    is not installed.
              Adapter "amtronwallbox"  is not installed.
              Adapter "anelhut"        is not installed.
              Adapter "apcups"         is not installed.
              Adapter "apg-info"       is not installed.
              Adapter "artnet"         is not installed.
              Adapter "artnet-recorder" is not installed.
              Adapter "asterisk"       is not installed.
              Adapter "asuswrt"        is not installed.
              Adapter "atlas-scientific-ezo-i2c" is not installed.
              Adapter "awattar"        is not installed.
              Adapter "awtrix-light"   is not installed.
              Adapter "b-control-em"   is not installed.
              Invalid version of "js-controller". Installed "3.1.6", required ">=4.0.0
              Adapter "beckhoff"       is not installed.
              Adapter "benchmark"      is not installed.
              Adapter "benq"           is not installed.
              Adapter "bestway"        is not installed.
              Adapter "bidirectional-counter" is not installed.
              Adapter "birthdays"      is not installed.
              Adapter "ble"            is not installed.
              Adapter "blebox"         is not installed.
              Adapter "bluelink"       is not installed.
              Adapter "bmw"            is not installed.
              Adapter "bosch-ebike"    is not installed.
              Adapter "bosesoundtouch" is not installed.
              Adapter "botslab360"     is not installed.
              Adapter "botvac"         is not installed.
              Adapter "bring"          is not installed.
              Adapter "broadlink2"     is not installed.
              Adapter "bsblan"         is not installed.
              Adapter "bshb"           is not installed.
              Adapter "bwt"            is not installed.
              Adapter "bydbatt"        is not installed.
              Adapter "bydhvs"         is not installed.
              Adapter "canbus"         is not installed.
              Adapter "cec2"           is not installed.
              Adapter "chromecast"     is not installed.
              Adapter "cleveron"       is not installed.
              Adapter "cloud"          is not installed.
              Adapter "cloudflare"     is not installed.
              Adapter "comfoair"       is not installed.
              Adapter "contactid"      is not installed.
              Adapter "coronavirus-statistics" is not installed.
              Adapter "countdown"      is not installed.
              Adapter "cul"            is not installed.
              Adapter "daikin"         is not installed.
              Adapter "daikin-cloud"   is not installed.
              Adapter "daswetter"      is not installed.
              Adapter "deconz"         is not installed.
              Adapter "denon"          is not installed.
              Adapter "device-reminder" is not installed.
              Adapter "device-watcher" is not installed.
              Adapter "devices"        is not installed.
              Adapter "deyeidc"        is not installed.
              Adapter "digitalstrom"   is not installed.
              Adapter "discord"        is not installed.
              Adapter "discovergy"     is not installed.
              Adapter "discovery"      is up to date.
              Adapter "divera247"      is not installed.
              Adapter "doorbird"       is not installed.
              Adapter "doorio"         is not installed.
              Adapter "drag-indicator" is not installed.
              Adapter "ds18b20"        is not installed.
              Adapter "dwd"            is not installed.
              Adapter "dysonairpurifier" is not installed.
              Adapter "e3dc-rscp"      is not installed.
              Adapter "easee"          is not installed.
              Adapter "ebus"           is not installed.
              Adapter "echarts"        is not installed.
              Adapter "ecovacs-deebot" is not installed.
              Adapter "egigeozone"     is not installed.
              Adapter "ekey"           is not installed.
              Adapter "elero-usb-transmitter" is not installed.
              Adapter "email"          is not installed.
              Adapter "emby"           is not installed.
              Adapter "emporia"        is not installed.
              Adapter "ems-esp"        is not installed.
              Adapter "energiefluss"   is not installed.
              Adapter "energymanager"  is not installed.
              Adapter "enet"           is not installed.
              Adapter "enigma2"        is not installed.
              Adapter "envertech-pv"   is not installed.
              Adapter "epson_ecotank_et_2750" is not installed.
              Adapter "epson_stylus_px830" is not installed.
              Adapter "eusec"          is not installed.
              Adapter "evcc"           is not installed.
              Adapter "eventlist"      is not installed.
              Adapter "exchangerates"  is not installed.
              Adapter "fahrplan"       is not installed.
              Adapter "fakeroku"       is not installed.
              Adapter "fb-checkpresence" is not installed.
              Adapter "feiertage"      is not installed.
              Adapter "fhem"           is not installed.
              Adapter "fiat"           is not installed.
              Adapter "firetv"         is not installed.
              Adapter "fitbit-fitness" is not installed.
              Adapter "flot"           is not installed.
              Adapter "followthesun"   is not installed.
              Adapter "foobar2000"     is not installed.
              Adapter "ford"           is not installed.
              Adapter "frigate"        is not installed.
              Adapter "fritzbox"       is not installed.
              Adapter "fritzdect"      is not installed.
              Adapter "froeling"       is not installed.
              Adapter "fronius"        is not installed.
              Adapter "fronius-solarweb" is not installed.
              Adapter "fronius-wattpilot" is not installed.
              Adapter "frontier_silicon" is not installed.
              Adapter "fuelpricemonitor" is not installed.
              Adapter "fullcalendar"   is not installed.
              Adapter "fullybrowser"   is not installed.
              Adapter "g-homa"         is not installed.
              Adapter "garmin"         is not installed.
              Adapter "geofency"       is not installed.
              Adapter "gigaset-elements" is not installed.
              Adapter "gira-iot"       is not installed.
              Adapter "go-e"           is not installed.
              Adapter "govee-local"    is not installed.
              Adapter "growatt"        is not installed.
              Adapter "gruenbeck"      is not installed.
              Adapter "gsmsms"         is not installed.
              Adapter "haassohn"       is not installed.
              Adapter "habpanel"       is not installed.
              Adapter "haier"          is not installed.
              Adapter "ham"            is not installed.
              Adapter "ham-wemo"       is not installed.
              Adapter "harmony"        is not installed.
              Adapter "hass"           is not installed.
              Adapter "hausbus_de"     is not installed.
              Adapter "heatingcontrol" is not installed.
              Adapter "heizoel"        is not installed.
              Adapter "heizungssteuerung" is not installed.
              Adapter "hekr"           is not installed.
              Adapter "helios"         is not installed.
              Adapter "heos"           is not installed.
              Adapter "heytech"        is not installed.
              Adapter "hid-community"  is not installed.
              Adapter "hikvision-alarmserver" is not installed.
              Adapter "history"        is not installed.
              Adapter "hm-rega"        is not installed.
              Adapter "hm-rpc"         is not installed.
              Adapter "hmip"           is not installed.
              Adapter "homeconnect"    is not installed.
              Adapter "homee"          is not installed.
              Adapter "homekit-controller" is not installed.
              Adapter "homenet"        is not installed.
              Adapter "homepilot"      is not installed.
              Adapter "hoover"         is not installed.
              Adapter "hp-ilo"         is not installed.
              Adapter "hs100"          is not installed.
              Adapter "hue"            is not installed.
              Adapter "huum-sauna"     is not installed.
              Adapter "i2c"            is not installed.
              Invalid version of "admin". Installed "4.1.11", required ">=5.3.2
              Adapter "iceroad"        is not installed.
              Adapter "ico-cloud"      is not installed.
              Adapter "icons-addictive-flavour-png" is not installed.
              Adapter "icons-eclipse-smarthome-classic" is not installed.
              Adapter "icons-fatcow-hosting" is not installed.
              Adapter "icons-freepic"  is not installed.
              Adapter "icons-icons8"   is not installed.
              Adapter "icons-material-png" is not installed.
              Adapter "icons-material-svg" is not installed.
              Adapter "icons-mfd-png"  is up to date.
              Adapter "icons-mfd-svg"  is not installed.
              Adapter "icons-open-icon-library-png" is not installed.
              Adapter "icons-smarthome" is not installed.
              Adapter "icons-ultimate-png" is not installed.
              Adapter "ikettle2"       is not installed.
              Adapter "imap"           is not installed.
              Adapter "imow"           is not installed.
              Invalid version of "js-controller". Installed "3.1.6", required ">=3.3.0
              Update info from @1.7.10 to @2.0.0
              NPM version: 10.2.3
              npm install iobroker.info@2.0.0 --loglevel error --prefix "/opt/iobroker" (System call)
              Adapter "system.adapter.vis.0" restarted.
              Update "system.adapter.info.0"
              upload [90] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
              upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/helper.js lib/js/helper.js application/javascript
              upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootbox.min.js lib/js/bootbox.min.js application/javascript
              upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/redhat.png lib/img/logos/redhat.png image/png
              upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/mandriva.png lib/img/logos/mandriva.png image/png
              upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/centos.png lib/img/logos/centos.png image/png
              upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/graphics.png lib/img/icons/graphics.png image/png
              upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
              upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
              upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
              upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
              upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
              upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
              upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
              upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
              upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
              upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
              upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
              upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
              upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
              upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
              upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
              upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
              upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/it/translations.json i18n/it/translations.json application/json
              upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
              upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/es/translations.json i18n/es/translations.json application/json
              upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/en/translations.json i18n/en/translations.json application/json
              upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/de/translations.json i18n/de/translations.json application/json
              Adapter "info" updated
              Adapter "innogy-smarthome" is not installed.
              Adapter "innoxel"        is not installed.
              Adapter "intex"          is not installed.
              Adapter "iot"            is not installed.
              Adapter "iqontrol"       is not installed.
              Adapter "iwg-vpn"        is not installed.
              Adapter "janitza-gridvis" is not installed.
              Adapter "jarvis"         is not installed.
              Invalid version of "admin". Installed "4.1.11", required ">=5.1.28
              Adapter "jeelink"        is not installed.
              Adapter "judoisoft"      is not installed.
              Adapter "kecontact"      is not installed.
              Adapter "klf200"         is not installed.
              Adapter "knmi-weather"   is not installed.
              Adapter "kodi"           is not installed.
              Adapter "kostal-piko-ba" is not installed.
              Adapter "lametric"       is not installed.
              Adapter "lcn"            is not installed.
              Adapter "legrand-ecocompteur" is not installed.
              Adapter "letrika_comgw"  is not installed.
              Adapter "lg-ess-home"    is not installed.
              Adapter "lg-thinq"       is not installed.
              Adapter "lgtv"           is not installed.
              Adapter "lgtv-rs"        is not installed.
              Adapter "lgtv11"         is not installed.
              Adapter "libre"          is not installed.
              Adapter "lifx"           is not installed.
              Adapter "lightcontrol"   is not installed.
              Adapter "lightify"       is not installed.
              Adapter "link"           is not installed.
              Adapter "link2home"      is not installed.
              Adapter "linkeddevices"  is not installed.
              Adapter "linktap"        is not installed.
              Update linux-control from @1.1.2 to @1.1.5
              NPM version: 10.2.3
              npm install iobroker.linux-control@1.1.5 --loglevel error --prefix "/opt/iobroker" (System call)
              upload [20] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/words.js words.js application/javascript
              Update "system.adapter.linux-control.0"
              upload [19] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/style.css style.css text/css
              upload [18] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/linux-control.png linux-control.png image/png
              upload [17] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/updates.json lib/updates.json application/json
              upload [16] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/services.json lib/services.json application/json
              upload [15] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/needrestart.json lib/needrestart.json application/json
              upload [14] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/jquery.fancytree.dnd5.js lib/jquery.fancytree.dnd5.js application/javascript
              upload [13] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/info.json lib/info.json application/json
              upload [12] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/distribution.json lib/distribution.json application/json
              upload [11] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/control.json lib/control.json application/json
              upload [10] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/index_m.js index_m.js application/javascript
              upload [9] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/index_m.html index_m.html text/html
              upload [8] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/state.png img/state.png image/png
              upload [7] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/menu_right.svg img/menu_right.svg image/svg+xml
              upload [6] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/menu_down.svg img/menu_down.svg image/svg+xml
              upload [5] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/info-big.png img/info-big.png image/png
              upload [4] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/folder.png img/folder.png image/png
              upload [3] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/checkbox_marked.svg img/checkbox_marked.svg image/svg+xml
              upload [2] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/checkbox_intermediate.svg img/checkbox_intermediate.svg image/svg+xml
              upload [1] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/checkbox.svg img/checkbox.svg image/svg+xml
              upload [0] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/admin.d.ts admin.d.ts video/mp2t
              Adapter "linux-control" updated
              Adapter "logparser"      is not installed.
              Adapter "loqed"          is not installed.
              Adapter "lovelace"       is not installed.
              Adapter "lowpass-filter" is not installed.
              Adapter "loxone"         is not installed.
              Adapter "luftdaten"      is not installed.
              Adapter "lupusec"        is not installed.
              Adapter "luxtronik1"     is not installed.
              Adapter "material"       is not installed.
              Adapter "matrix-org"     is not installed.
              Adapter "maveo"          is not installed.
              Adapter "maxcube"        is not installed.
              Adapter "maxcul"         is not installed.
              Adapter "mbus"           is not installed.
              Adapter "mclighting"     is not installed.
              Adapter "meater"         is not installed.
              Adapter "mediola-gateway" is not installed.
              Adapter "megad"          is not installed.
              Adapter "megadd"         is not installed.
              Adapter "megaesp"        is not installed.
              Adapter "melcloud"       is not installed.
              Adapter "mercedesme"     is not installed.
              Adapter "mercury"        is not installed.
              Adapter "meross"         is not installed.
              Adapter "meteoalarm"     is not installed.
              Adapter "micronova"      is not installed.
              Adapter "midea"          is not installed.
              Adapter "miele"          is not installed.
              Adapter "mielecloudservice" is not installed.
              Adapter "mihome"         is not installed.
              Adapter "mihome-cloud"   is not installed.
              Adapter "mihome-lamp"    is not installed.
              Adapter "mihome-plug"    is not installed.
              Adapter "mihome-vacuum"  is not installed.
              Adapter "mikrotik"       is not installed.
              Adapter "milight"        is not installed.
              Adapter "milight-smart-light" is not installed.
              Adapter "minuvis"        is not installed.
              Adapter "mobile"         is not installed.
              Adapter "modbus"         is not installed.
              Adapter "moma"           is not installed.
              Adapter "mpd"            is not installed.
              Adapter "mqtt"           is not installed.
              Adapter "mqtt-client"    is not installed.
              Adapter "musiccast"      is not installed.
              Adapter "mydlink"        is not installed.
              Adapter "myenergi"       is not installed.
              Adapter "mysensors"      is not installed.
              Adapter "mystrom"        is not installed.
              Adapter "myvbus"         is not installed.
              Adapter "nanoleaf-lightpanels" is not installed.
              Adapter "net-tools"      is not installed.
              Adapter "netatmo"        is not installed.
              Adapter "netatmo-crawler" is not installed.
              Adapter "netatmo-energy" is not installed.
              Adapter "nibeuplink"     is not installed.
              Adapter "nina"           is not installed.
              Adapter "nissan"         is not installed.
              Adapter "niu"            is not installed.
              Adapter "notification-manager" is not installed.
              Adapter "nsclient"       is not installed.
              Adapter "nuki"           is not installed.
              Adapter "nuki-extended"  is not installed.
              Adapter "nut"            is not installed.
              Adapter "ocpp"           is not installed.
              Adapter "octoprint"      is not installed.
              Adapter "odl"            is not installed.
              Adapter "oekofen-json"   is not installed.
              Adapter "oilfox"         is not installed.
              Adapter "omnicomm-lls"   is not installed.
              Adapter "onkyo"          is not installed.
              Adapter "onvif"          is not installed.
              Adapter "opendtu"        is not installed.
              Adapter "openhab"        is not installed.
              Adapter "openknx"        is not installed.
              Adapter "openligadb"     is not installed.
              Adapter "openweathermap" is not installed.
              Adapter "operating-hours" is not installed.
              Adapter "opi"            is not installed.
              Adapter "oppoplayer"     is not installed.
              Adapter "owfs"           is not installed.
              Adapter "owntracks"      is not installed.
              Adapter "panasonic-comfort-cloud" is not installed.
              Adapter "panasonic-viera" is not installed.
              Adapter "parcel"         is not installed.
              Adapter "parser"         is not installed.
              Adapter "paw"            is not installed.
              Adapter "pegelalarm"     is not installed.
              Adapter "ph803w"         is not installed.
              Adapter "phantomjs"      is not installed.
              Adapter "philips-air"    is not installed.
              Adapter "philips-tv"     is not installed.
              Adapter "pi-hole"        is not installed.
              Adapter "piface"         is not installed.
              Adapter "pimatic"        is not installed.
              Adapter "ping"           is not installed.
              Adapter "pixelit"        is not installed.
              Adapter "places"         is not installed.
              Adapter "plenticore"     is not installed.
              Adapter "plex"           is not installed.
              Adapter "plexconnect"    is not installed.
              Adapter "pollenflug"     is not installed.
              Adapter "porsche"        is not installed.
              Adapter "powerfox2"      is not installed.
              Adapter "procon-ip"      is not installed.
              Adapter "proxmox"        is not installed.
              Adapter "proxy"          is not installed.
              Adapter "psa"            is not installed.
              Adapter "puppeteer"      is not installed.
              Adapter "pushbullet"     is not installed.
              Adapter "pushover"       is not installed.
              Adapter "pushsafer"      is not installed.
              Adapter "pvforecast"     is not installed.
              Adapter "pvoutputorg"    is not installed.
              Adapter "pylontech"      is not installed.
              Adapter "radar2"         is not installed.
              Adapter "radiohead"      is not installed.
              Adapter "rct"            is not installed.
              Adapter "renacidc"       is not installed.
              Adapter "renault"        is not installed.
              Adapter "reolink"        is not installed.
              Adapter "residents"      is not installed.
              Adapter "resol"          is not installed.
              Adapter "rest-api"       is not installed.
              Adapter "rflink"         is not installed.
              Adapter "rickshaw"       is not installed.
              Adapter "ring"           is not installed.
              Adapter "robonect"       is not installed.
              Adapter "roborock"       is not installed.
              Adapter "roomba"         is not installed.
              Adapter "rpi2"           is not installed.
              Adapter "rssfeed"        is not installed.
              Adapter "s7"             is not installed.
              Adapter "sainlogic"      is not installed.
              Adapter "samsung"        is not installed.
              Adapter "samsung_tizen"  is not installed.
              Adapter "sanext"         is not installed.
              Adapter "sayit"          is not installed.
              Adapter "sbfspot"        is not installed.
              Adapter "scenes"         is not installed.
              Adapter "scheduler"      is not installed.
              Adapter "schoolfree"     is not installed.
              Adapter "schwoerer-ventcube" is not installed.
              Adapter "seko"           is not installed.
              Adapter "selverf"        is not installed.
              Adapter "semp"           is not installed.
              Adapter "seq"            is not installed.
              Adapter "shelly"         is not installed.
              Adapter "shuttercontrol" is not installed.
              Adapter "sia"            is not installed.
              Adapter "siegenia"       is not installed.
              Adapter "signal-cmb"     is not installed.
              Adapter "signifylights"  is not installed.
              Adapter "simple-api"     is up to date.
              Adapter "sma-em"         is not installed.
              Adapter "smappee"        is not installed.
              Adapter "smart-eq"       is not installed.
              Adapter "smartcontrol"   is not installed.
              Adapter "smartgarden"    is not installed.
              Adapter "smartmeter"     is not installed.
              Adapter "smartthings"    is not installed.
              Adapter "snips"          is not installed.
              Adapter "snmp"           is not installed.
              Invalid version of "admin". Installed "4.1.11", required ">=5.0.0
              Adapter "solarlog"       is not installed.
              Adapter "solarmanpv"     is not installed.
              Adapter "solarviewdatareader" is not installed.
              Adapter "solarwetter"    is not installed.
              Adapter "solax"          is not installed.
              Adapter "sonnen"         is not installed.
              Adapter "sonoff"         is not installed.
              Adapter "sonos"          is not installed.
              Adapter "sony-bravia"    is not installed.
              Adapter "spotify-premium" is not installed.
              Adapter "sprinklecontrol" is not installed.
              Adapter "sql"            is not installed.
              Adapter "squeezeboxrpc"  is not installed.
              Adapter "starline"       is not installed.
              Adapter "stiebel-isg"    is not installed.
              Adapter "sureflap"       is not installed.
              Adapter "swiss-weather-api" is not installed.
              Adapter "synochat"       is not installed.
              Adapter "synology"       is not installed.
              Adapter "systeminfo"     is not installed.
              Adapter "tado"           is not installed.
              Adapter "tahoma"         is not installed.
              Adapter "tankerkoenig"   is not installed.
              Adapter "tapo"           is not installed.
              Adapter "telegram"       is not installed.
              Adapter "telegram-menu"  is not installed.
              Adapter "terminal"       is not installed.
              Adapter "tesla-motors"   is not installed.
              Adapter "text2command"   is not installed.
              Adapter "tibberlink"     is not installed.
              Adapter "tinker"         is not installed.
              Adapter "tinymqttbroker" is not installed.
              Adapter "toyota"         is not installed.
              Adapter "tr-064"         is up to date.
              Adapter "traccar"        is not installed.
              Adapter "tractive-gps"   is not installed.
              Adapter "tradfri"        is not installed.
              Invalid version of "js-controller". Installed "3.1.6", required ">=4.0.15
              Adapter "trivum"         is not installed.
              Adapter "tronity"        is not installed.
              Adapter "tunnelbroker-endpoint-updater" is not installed.
              Adapter "tuya"           is not installed.
              Adapter "tvprogram"      is not installed.
              Adapter "tvspielfilm"    is not installed.
              Adapter "twinkly"        is not installed.
              Adapter "unifi"          is not installed.
              Adapter "uv-protect"     is not installed.
              Adapter "vaillant"       is not installed.
              Adapter "valloxmv"       is not installed.
              Adapter "valuetrackerovertime" is not installed.
              Adapter "vcard"          is not installed.
              Adapter "vds2465-server" is not installed.
              Adapter "velux"          is not installed.
              Adapter "vesync"         is not installed.
              Adapter "viessmann"      is not installed.
              Adapter "viessmannapi"   is not installed.
              Adapter "virtualpowermeter" is not installed.
              Update vis from @1.3.4 to @1.5.4
              NPM version: 10.2.3
              npm install iobroker.vis@1.5.4 --loglevel error --prefix "/opt/iobroker" (System call)
              upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
              upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/6-1.png widgets/timeandweather/img/clock/6-1.png image/png
              upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/01-1.png widgets/timeandweather/img/clock/01-1.png image/png
              upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/sani_valve_60.png widgets/jqui-mfd/img/sani_valve_60.png image/png
              upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_window_roof.svg widgets/jqui-mfd/img/fts_window_roof.svg image/svg+xml
              upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/authors.txt widgets/jqui-mfd/img/authors.txt text/plain
              upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/hqwidgets/css/glossy.css widgets/hqwidgets/css/glossy.css text/css
              upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/pin_red5.svg widgets/basic/img/pin_red5.svg image/svg+xml
              upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/bars/js/jquery.sidebar.js widgets/bars/js/jquery.sidebar.js application/javascript
              upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery-ui-timepicker-addon-1.6.3.js lib/js/jquery-ui-timepicker-addon-1.6.3.js application/javascript
              upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditExt.js js/visEditExt.js application/javascript
              upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/back.png js/fm/icon/actions/back.png image/png
              upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/img/zip.png img/zip.png image/png
              upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
              upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
              upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
              upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
              upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
              upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
              upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
              upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
              upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
              upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
              upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
              upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
              upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
              upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
              upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
              upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
              upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
              upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
              upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
              upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
              upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff font/woff
              upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
              upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
              upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
              upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
              upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
              upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
              Update "system.adapter.vis.0"
              Adapter "vis" updated
              Adapter "vis-2"          is not installed.
              Adapter "vis-2-widgets-energy" is not installed.
              Adapter "vis-2-widgets-gauges" is not installed.
              Adapter "vis-2-widgets-jaeger-design" is not installed.
              Adapter "vis-2-widgets-material" is not installed.
              Adapter "vis-bars"       is up to date.
              Adapter "vis-canvas-gauges" is not installed.
              Adapter "vis-colorpicker" is up to date.
              Adapter "vis-fancyswitch" is up to date.
              Adapter "vis-google-fonts" is not installed.
              Adapter "vis-history"    is not installed.
              Adapter "vis-hqwidgets"  is up to date.
              Adapter "vis-icontwo"    is not installed.
              Adapter "vis-inventwo"   is not installed.
              Adapter "vis-jqui-mfd"   is up to date.
              Adapter "vis-justgage"   is not installed.
              Adapter "vis-keyboard"   is not installed.
              Adapter "vis-lcars"      is not installed.
              Adapter "vis-map"        is not installed.
              Adapter "vis-material"   is not installed.
              Adapter "vis-material-advanced" is not installed.
              Adapter "vis-materialdesign" is not installed.
              Adapter "vis-metro"      is not installed.
              Adapter "vis-players"    is not installed.
              Adapter "vis-plumb"      is not installed.
              Adapter "vis-rgraph"     is not installed.
              Adapter "vis-timeandweather" is up to date.
              Adapter "vis-weather"    is not installed.
              Adapter "voltoplus"      is not installed.
              Adapter "volumio"        is not installed.
              Adapter "volvo"          is not installed.
              Adapter "vr200"          is not installed.
              Adapter "vw-connect"     is not installed.
              Adapter "wallpanel"      is not installed.
              Adapter "warp"           is not installed.
              Adapter "weather-warnings" is not installed.
              Adapter "weatherflow_udp" is not installed.
              Adapter "weatherunderground" is not installed.
              Invalid version of "admin". Installed "4.1.11", required ">=5.1.0
              Adapter "webcal"         is not installed.
              Adapter "webui"          is not installed.
              Adapter "webuntis"       is not installed.
              Adapter "weishaupt-wem"  is not installed.
              Adapter "welcome"        is not installed.
              Adapter "whatsapp-cmb"   is not installed.
              Adapter "wiegand-tcpip"  is not installed.
              Adapter "wiffi-wz"       is not installed.
              Adapter "wifilight"      is not installed.
              Adapter "windows-control" is not installed.
              Adapter "wiobrowser"     is not installed.
              Adapter "wireguard"      is not installed.
              Adapter "wireless-mbus"  is not installed.
              Adapter "withings"       is not installed.
              Adapter "wlanthermo-nano" is not installed.
              Adapter "wled"           is not installed.
              Adapter "wmswebcontrol"  is not installed.
              Adapter "wolf"           is not installed.
              Adapter "wolf-smartset"  is not installed.
              Adapter "worx"           is not installed.
              Adapter "ws"             is not installed.
              Adapter "x-touch"        is not installed.
              Adapter "xbox"           is not installed.
              Adapter "xs1"            is not installed.
              Adapter "xterm"          is not installed.
              Adapter "yahka"          is not installed.
              Adapter "yahoo-stock-market" is not installed.
              Adapter "yamaha"         is not installed.
              Adapter "yeelight-2"     is not installed.
              Adapter "youtube"        is not installed.
              Adapter "yr"             is not installed.
              Adapter "zehnder-cloud"  is not installed.
              Adapter "zendure-solarflow" is not installed.
              Adapter "zigbee"         is not installed.
              Adapter "zigbee2mqtt"    is not installed.
              Adapter "zont"           is not installed.
              Adapter "zwave2"         is not installed.
              pi@raspberrypi:~ $ iob stop
                @frank-knx
                Muss ich mir morgen anschauen. N8
                  OK ich halte mich bereit und mache vor deiner Rückmeldung keine Aktionen (um nichts zu Verschlimmern).
                    Thomas Braun Most Active @Frank-KNX last edited by Thomas Braun
                    @frank-knx
                    Versuch mal:
                    iob stop
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.js-controller
                    iob update
                    iob upgrade admin
                    iob upgrade all
                    iob start
                      Alle Befehle sind erfolgreich und ohne Fehlermeldung durchgelaufen.
                      Im iobroker selbst unter Info erscheint die Meldung, dass alle Adapter aktuell sind.
                      ich habe "iob diag" nochmal gestartet und nachfolgend der Report.
                      Habe ich es nun mit deiner Hilfe erfolgreich geschafft oder ist noch etwas zu fixen ?
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                         Static hostname: raspberrypi
                               Icon name: computer
                        Operating System: Raspbian GNU/Linux 10 (buster)
                                  Kernel: Linux 5.10.103-v7l+
                            Architecture: arm
                      Model           : Raspberry Pi 4 Model B Rev 1.4
                      Docker          : false
                      Virtualization  : none
                      Kernel          : armv7l
                      Userland        : armhf
                      Systemuptime and Load:
                       17:40:21 up 16:57,  3 users,  load average: 0.81, 1.75, 1.33
                      CPU threads: 4
                      *** RASPBERRY THROTTLING ***
                      Current issues:
                      Previously detected issues:
                      *** Time and Time Zones ***
                                     Local time: Sat 2024-02-03 17:40:21 CET
                                 Universal time: Sat 2024-02-03 16:40:21 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      *** User and Groups ***
                      pi
                      /home/pi
                      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                      *** X-Server-Setup ***
                      X-Server:       true
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:           7.9G        1.2G        4.9G         39M        1.7G        6.5G
                      Swap:           99M          0B         99M
                      Total:         8.0G        1.2G        5.0G
                               7898 M total memory
                               1209 M used memory
                                531 M active memory
                               2209 M inactive memory
                               4942 M free memory
                                158 M buffer memory
                               1589 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FAILED SERVICES ***
                        UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
                      * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
                      LOAD   = Reflects whether the unit definition was properly loaded.
                      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                      SUB    = The low-level unit activation state, values depend on unit type.
                      1 loaded units listed. Pass --all to see loaded but inactive units, too.
                      To show all installed unit files use 'systemctl list-unit-files'.
                      *** FILESYSTEM ***
                      /dev/root      ext4      117G   11G  102G  10% /
                      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
                      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                      tmpfs          tmpfs     3.9G  8.7M  3.9G   1% /run
                      tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
                      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                      tmpfs          tmpfs     790M  4.0K  790M   1% /run/user/1000
                      [Sat Feb  3 00:42:27 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:D3:7A:A7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=def5eda3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                      [Sat Feb  3 00:42:28 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                      [Sat Feb  3 00:42:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [Sat Feb  3 00:42:31 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                      TARGET                SOURCE         FSTYPE          OPTIONS
                      /                     /dev/mmcblk0p2 ext4            rw,noatime
                      |-/sys/fs/bpf         none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
                      |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                      `-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      1.5G    /var/
                      1.1G    /var/cache/apt/archives
                      1.1G    /var/cache/apt
                      1.1G    /var/cache
                      250M    /var/lib
                      Archived and active journals take up 8.0M in the file system.
                      /opt/iobroker/backups:
                      101M    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      256M    /opt/iobroker/iobroker-data/
                      169M    /opt/iobroker/iobroker-data/files
                      67M     /opt/iobroker/iobroker-data/files/javascript.admin
                      50M     /opt/iobroker/iobroker-data/backup-objects
                      48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                      16M     /opt/iobroker/iobroker-data/objects.jsonl
                      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                      7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
                      7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
                      USB-Devices by-id:
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v18.19.0
                      /usr/bin/node           v18.19.0
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      /usr/bin/corepack       0.22.0
                      nodejs:
                        Installed: 18.19.0-1nodesource1
                        Candidate: 18.19.0-1nodesource1
                        Version table:
                       *** 18.19.0-1nodesource1 1001
                              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                              100 /var/lib/dpkg/status
                           18.18.2-1nodesource1 1001
                           18.18.1-1nodesource1 1001
                           18.18.0-1nodesource1 1001
                           18.17.1-1nodesource1 1001
                           18.17.0-1nodesource1 1001
                           18.16.1-1nodesource1 1001
                           18.16.0-1nodesource1 1001
                           18.15.0-1nodesource1 1001
                           18.14.2-1nodesource1 1001
                           18.14.1-1nodesource1 1001
                           18.14.0-1nodesource1 1001
                           18.13.0-1nodesource1 1001
                           18.12.0-1nodesource1 1001
                           18.11.0-1nodesource1 1001
                           18.10.0-1nodesource1 1001
                           18.9.1-1nodesource1 1001
                           18.9.0-1nodesource1 1001
                           18.8.0-1nodesource1 1001
                           18.7.0-1nodesource1 1001
                           18.6.0-1nodesource1 1001
                           18.5.0-1nodesource1 1001
                           18.4.0-1nodesource1 1001
                           18.3.0-1nodesource1 1001
                           18.2.0-1nodesource1 1001
                           18.1.0-1nodesource1 1001
                           18.0.0-1nodesource1 1001
                           10.24.0~dfsg-1~deb10u3 500
                      No problems detected
                      Errors in npm tree:
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Core adapters versions
                      js-controller:  5.0.17
                      admin:          6.13.15
                      javascript:     7.1.6
                      Adapters from github:   0
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
                      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                      + system.adapter.knx.0                    : knx                   : raspberrypi                              -  enabled, bind: 192.168.2.98
                        system.adapter.linux-control.0          : linux-control         : raspberrypi                              -  enabled
                      + system.adapter.meldungsliste.0          : meldungsliste         : raspberrypi                              -  enabled
                        system.adapter.meldungsliste.1          : meldungsliste         : raspberrypi                              -  enabled
                      + system.adapter.meldungsliste.10         : meldungsliste         : raspberrypi                              -  enabled
                      + system.adapter.meldungsliste.11         : meldungsliste         : raspberrypi                              -  enabled
                      + system.adapter.meldungsliste.12         : meldungsliste         : raspberrypi                              -  enabled
                      + system.adapter.meldungsliste.13         : meldungsliste         : raspberrypi                              -  enabled
                      + system.adapter.meldungsliste.2          : meldungsliste         : raspberrypi                              -  enabled
                      + system.adapter.meldungsliste.3          : meldungsliste         : raspberrypi                              -  enabled
                      + system.adapter.meldungsliste.4          : meldungsliste         : raspberrypi                              -  enabled
                      + system.adapter.meldungsliste.5          : meldungsliste         : raspberrypi                              -  enabled
                      + system.adapter.meldungsliste.6          : meldungsliste         : raspberrypi                              -  enabled
                      + system.adapter.meldungsliste.7          : meldungsliste         : raspberrypi                              -  enabled
                        system.adapter.meldungsliste.8          : meldungsliste         : raspberrypi                              -  enabled
                      + system.adapter.meldungsliste.9          : meldungsliste         : raspberrypi                              -  enabled
                      + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 192.168.2.98
                      + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
                        system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                        system.adapter.upnp.0                   : upnp                  : raspberrypi                              - disabled
                        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + instance is alive
                      ioBroker-Repositories
                      Stable (default): http://download.iobroker.net/sources-dist.json
                      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                      Active repo(s): Stable (default)
                      Installed ioBroker-Instances
                      Used repository: Stable (default)
                      Adapter    "admin"        : 6.13.15  , installed 6.13.15
                      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                      Controller "js-controller": 5.0.17   , installed 5.0.17
                      Adapter    "knx"          : 2.0.24   , installed 2.0.24
                      Adapter    "linux-control": 1.1.5    , installed 1.1.5
                      Adapter    "node-red"     : 5.1.0    , installed 5.1.0
                      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                      Adapter    "web"          : 6.2.3    , installed 6.2.3
                      Adapter    "ws"           : 2.5.10   , installed 2.5.10
                      Objects and States
                      Objects:        3877
                      States:         2729
                      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                      Hit:3 https://repos.influxdata.com/debian stable InRelease
                      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 1
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17021      555/sshd
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17841      420/cupsd
                      tcp        0      0 192.168.2.98:1880       0.0.0.0:*               LISTEN      1001       49471      9582/node-red
                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        19766      482/influxd
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       48023      9500/iobroker.js-co
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       48016      9500/iobroker.js-co
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       48066      9521/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       53319      9865/io.web.0
                      tcp6       0      0 :::8086                 :::*                    LISTEN      999        20061      482/influxd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          17031      555/sshd
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17840      420/cupsd
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17159      484/dhcpcd
                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18593      532/cups-browsed
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16137      413/avahi-daemon: r
                      udp        0      0 0.0.0.0:59135           0.0.0.0:*                           1001       49473      9582/node-red
                      udp        0      0 0.0.0.0:42781           0.0.0.0:*                           108        16139      413/avahi-daemon: r
                      udp        0      0 192.168.2.98:39748      0.0.0.0:*                           1001       53569      10234/io.knx.0
                      udp        0      0 192.168.2.98:46929      0.0.0.0:*                           1001       51070      10234/io.knx.0
                      udp6       0      0 :::546                  :::*                                0          20302      484/dhcpcd
                      udp6       0      0 :::52887                :::*                                108        16140      413/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                108        16138      413/avahi-daemon: r
                      2024-02-03 17:41:57.874  - info: knx.0 (10234) WRITE : mappedName : Temperatur Wasser Teich    dest : 4/3/3  val: 6.4   (DPT9.001) Temperatur_Wasser_Teich
                      2024-02-03 17:41:57.874  - info: knx.0 (10234) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
                      2024-02-03 17:41:57.875  - info: knx.0 (10234) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
                      2024-02-03 17:41:57.875  - info: knx.0 (10234) =====> STATE_TUNNELING_ACK
                      2024-02-03 17:41:57.876  - info: knx.0 (10234) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 55 87 00   ChID : 85 SeqCntIN : 135 SeqCntOUT : 25 queue length : 0
                      2024-02-03 17:41:57.877  - info: knx.0 (10234) ( 4.b ) return to STATE_READY, processing : false
                      2024-02-03 17:41:57.877  - info: knx.0 (10234) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
                      2024-02-03 17:41:56.303  - info: influxdb.0 (9607) Influx DB Version used: 1.x
                      2024-02-03 17:41:56.503  - error: influxdb.0 (9607) Error: authorization failed
                      2024-02-03 17:41:58.728  - info: knx.0 (10234) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 19 04 55 88 00 29 00 bc c0 12 3c 28 03 05 00 80 00 00 01 c4   ChID: 85
                      2024-02-03 17:41:58.729  - info: knx.0 (10234) WRITE : mappedName : Energie kWh    dest : 5/0/3  val: 452   (DPT13.013) Energie_kWh
                      2024-02-03 17:41:58.730  - info: knx.0 (10234) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
                      2024-02-03 17:41:58.730  - info: knx.0 (10234) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
                      2024-02-03 17:41:58.731  - info: knx.0 (10234) =====> STATE_TUNNELING_ACK
                      2024-02-03 17:41:58.733  - info: knx.0 (10234) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 55 88 00   ChID : 85 SeqCntIN : 136 SeqCntOUT : 25 queue length : 0
                      2024-02-03 17:41:58.733  - info: knx.0 (10234) ( 4.b ) return to STATE_READY, processing : false
                      2024-02-03 17:41:58.733  - info: knx.0 (10234) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
                      2024-02-03 17:41:58.751  - info: knx.0 (10234) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 19 04 55 89 00 29 00 bc c0 12 3c 28 02 05 00 80 00 06 e9 02   ChID: 85
                      2024-02-03 17:41:58.753  - info: knx.0 (10234) WRITE : mappedName : Energie Wh    dest : 5/0/2  val: 452866   (DPT13.010) Energie_Wh
                      2024-02-03 17:41:58.754  - info: knx.0 (10234) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
                      2024-02-03 17:41:58.754  - info: knx.0 (10234) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
                      2024-02-03 17:41:58.755  - info: knx.0 (10234) =====> STATE_TUNNELING_ACK
                      2024-02-03 17:41:58.756  - info: knx.0 (10234) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 55 89 00   ChID : 85 SeqCntIN : 137 SeqCntOUT : 25 queue length : 0
                      2024-02-03 17:41:58.756  - info: knx.0 (10234) ( 4.b ) return to STATE_READY, processing : false
                      2024-02-03 17:41:58.757  - info: knx.0 (10234) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
                        @frank-knx sagte in Update js-Controller 3.x auf 5.x funktioniert nicht:
                        Schaut jetzt wohl soweit i. O. aus.
                        Aber was ist denn das für ein Adapter? Der dann auch ein Dutzend Instanzen anschleppt?
                        Backup ziehen und das Betriebssystem auf einen aktuellen Stand bringen. Dein 'Buster' ist tot.
                          Hallo Thomas,
                          herzlichen Dank für deine professionelle Unterstützung.
                          Jetzt muss ich in meiner VIS nur noch schauen, ob durch die Updates am Verhalten eine Änderung aufgetreten ist.
                          Diesen Adapter Meldungsliste nutze ich in der VIS für alle Beleuchtungen und Co, die ich über KNX abgreife. Damit generiere ich auf der Hauptseite dann Meldungen, wie "Licht im Haus an", wenn eines der Lichter an ist oder "Fenster offen". Ich habe dort so viele Gruppen, dass ich jedes Mal einen Adapter benötige. Die laufen aber "bisher" sehr stabil und zuverlässig.
                          Jetzt werde ich das System nochmal genau anschauen, ob alle bisherigen Funktionen laufen und dann werde ich das nächste Projekt mit dem von dir angesprochenen Update in Angriff nehmen.
                          Da werde ich sicher nochmal auf euch Fachleute aus dem Forum zurückkommen, bevor ich als "Halbwissender" hier falsche Dinge mache und am Ende nichts mehr läuft.
                          Besten Dank
                          FRANK
                            Thomas Braun Most Active last edited by Thomas Braun
                            @frank-knx
                            Ich würde den knx auf ein weniger gesprächiges LogLevel setzten.
                            Und bei
                            Pending Updates: 1
                            Kannst du gleich trainieren, wie mal die Kiste aktuell hält.
                            sudo apt update
                            sudo apt full-upgrade
                              Frank579 @Thomas Braun last edited by
                              @thomas-braun sagte in Update js-Controller 3.x auf 5.x funktioniert nicht:
                              sudo full-upgrade
                              fehlt da nicht ein apt ? oder geht das jetzt auch so?
                                Thomas Braun Most Active @Frank579 last edited by
                                @frank579 sagte in Update js-Controller 3.x auf 5.x funktioniert nicht:
                                Gut aufgepasst. Ich hab es korrigiert.
                                4599
