    4. Vis2 ab 09.01.2024 im stable
      Homoran Global Moderator Administrators @Santos last edited by
      @santos sagte in Vis2 ab morgen im stable:
      Vermutlich schickt ihr mich gleich die nodejs, npm und js-controller zu updaten
      Alleine schon deswegen, weil ungerade nodejs Versionen nur Entwicklerversionen sind, npm immer nur mit nodejs zusammen installiert werden soll und der Controller v5 Bedingung für vis2 ist
        Thomas Braun Most Active @Santos last edited by
        E: Broken packages
        Deine Paketdatenbank ist inkonsistent.
        sudo apt update
        sudo apt full-upgrade
        zeigen.
        • Santos
          So, jetzt fertig.
          Skript v.2023-10-10
          *** BASE SYSTEM ***
            Static hostname: raspberrypi
                  Icon name: computer
           Operating System: Raspbian GNU/Linux 10 (buster)
                     Kernel: Linux 5.10.103-v7l+
               Architecture: arm
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : armhf
          Systemuptime and Load:
          22:11:07 up 46 days,  1:35,  2 users,  load average: 1.61, 3.09, 2.87
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          This system needs to be REBOOTED!
          *** Time and Time Zones ***
                        Local time: Fri 2024-02-02 22:11:07 CET
                    Universal time: Fri 2024-02-02 21:11:07 UTC
                          RTC time: n/a
                       NTP service: active
                   RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin g        pio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:           7.9G        1.2G        3.2G        395M        3.5G        6.3G
          Swap:           99M          0B         99M
          Total:         8.0G        1.2G        3.3G
                  7898 M total memory
                  1200 M used memory
                  1004 M active memory
                  3455 M inactive memory
                  3189 M free memory
                   262 M buffer memory
                  3246 M swap cache
                    99 M total swap
                     0 M used swap
                    99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed. Pass --all to see loaded but inactive units, too.
          To show all installed unit files use 'systemctl list-unit-files'.
          *** FILESYSTEM ***
          /dev/root      ext4       59G  8.3G   48G  15% /
          devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     3.9G  396M  3.5G  11% /run
          tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
          /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
          tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
          [Mon Dec 18 20:35:49 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC        :A6:32:E2:25:2C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=t        tyS0,115200 console=tty1 root=PARTUUID=848b4126-02 rootfstype=ext4 elevator=dead        line fsck.repair=yes rootwait
          [Mon Dec 18 20:35:50 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Opts: (null)
          [Mon Dec 18 20:35:50 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
          [Mon Dec 18 20:35:52 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
          TARGET        SOURCE         FSTYPE OPTIONS
          /             /dev/mmcblk0p2 ext4   rw,noatime
          |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
          `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=4        37,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          516M    /var/
          193M    /var/cache
          182M    /var/cache/apt
          125M    /var/lib
          122M    /var/cache/apt/archives
          Archived and active journals take up 394.7M in the file system.
          /opt/iobroker/backups:
          17M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.1G    /opt/iobroker/iobroker-data/
          540M    /opt/iobroker/iobroker-data/files
          385M    /opt/iobroker/iobroker-data/history
          138M    /opt/iobroker/iobroker-data/files/vis-2
          124M    /opt/iobroker/iobroker-data/backup-objects
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.m        ap
          22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.m        ap
          22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.j        s.map
          19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc        3820.js.map
          18M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e642d05b.js.map
          USB-Devices by-id:
          USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
          /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          /usr/bin/corepack       0.22.0
          nodejs:
           Installed: 18.19.0-1nodesource1
           Candidate: 18.19.0-1nodesource1
           Version table:
          *** 18.19.0-1nodesource1 1001
                 500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                 100 /var/lib/dpkg/status
              18.18.2-1nodesource1 1001
              18.18.1-1nodesource1 1001
              18.18.0-1nodesource1 1001
              18.17.1-1nodesource1 1001
              18.17.0-1nodesource1 1001
              18.16.1-1nodesource1 1001
              18.16.0-1nodesource1 1001
              18.15.0-1nodesource1 1001
              18.14.2-1nodesource1 1001
              18.14.1-1nodesource1 1001
              18.14.0-1nodesource1 1001
              18.13.0-1nodesource1 1001
              18.12.0-1nodesource1 1001
              18.11.0-1nodesource1 1001
              18.10.0-1nodesource1 1001
              18.9.1-1nodesource1 1001
              18.9.0-1nodesource1 1001
              18.8.0-1nodesource1 1001
              18.7.0-1nodesource1 1001
              18.6.0-1nodesource1 1001
              18.5.0-1nodesource1 1001
              18.4.0-1nodesource1 1001
              18.3.0-1nodesource1 1001
              18.2.0-1nodesource1 1001
              18.1.0-1nodesource1 1001
              18.0.0-1nodesource1 1001
              10.24.0~dfsg-1~deb10u3 500
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.17
          admin:          6.13.15
          javascript:     7.1.6
          Adapters from github:   0
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi        -  enabled
          + system.adapter.backitup.0               : backitup              : raspberrypi        -  enabled
           system.adapter.daswetter.0              : daswetter             : raspberrypi        -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi        -  enabled
          + system.adapter.fronius.0                : fronius               : raspberrypi        -  enabled
           system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi        - disabled
          + system.adapter.history.0                : history               : raspberrypi        -  enabled
          + system.adapter.info.0                   : info                  : raspberrypi        -  enabled
          + system.adapter.iot.0                    : iot                   : raspberrypi        -  enabled
          + system.adapter.jarvis.0                 : jarvis                : raspberrypi        -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi        -  enabled
          + system.adapter.mihome.0                 : mihome                : raspberrypi        -  enabled, port: 9898, bind: 192.168.1.32
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi        -  enabled, port: 1884, bind: 0.0.0.0
          + system.adapter.pushover.0               : pushover              : raspberrypi        -  enabled
           system.adapter.pvforecast.0             : pvforecast            : raspberrypi        - disabled
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi        -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.telegram.0               : telegram              : raspberrypi        -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.1               : telegram              : raspberrypi        -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi        -  enabled, port: /dev/ttyUSB0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.13.15  , installed 6.13.15
          Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
          Adapter    "fronius"      : 2.0.2    , installed 2.0.2
          Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
          Adapter    "fullybrowser" : 3.0.9    , installed 2.1.2  [Updatable]
          Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
          Adapter    "modbus"       : 6.1.0    , installed 6.1.0
          Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
          Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
          Adapter    "reolink"      : 1.0.3    , installed 1.0.3
          Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
          Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
          Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "telegram"     : 3.0.1    , installed 3.0.1
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
          Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
          Adapter    "web"          : 6.2.3    , installed 6.2.3
          Adapter    "webuntis"     : 0.3.4    , installed 0.3.4
          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
          Adapter    "worx"         : 2.3.4    , installed 2.3.4
          Adapter    "ws"           : 2.5.10   , installed 2.5.10
          Adapter    "zigbee"       : 1.10.1   , installed 1.8.24 [Updatable]
          Objects and States
          Objects:        7581
          States:         9658
          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
          Get:4 https://pkgs.tailscale.com/stable/raspbian buster InRelease
          Fetched 6564 B in 3s (2131 B/s)
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       54931202   14511/io.jarvis.0
          tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          16284      522/dnsmasq
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          54988018   27703/sshd
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          54986327   27773/cupsd
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       54928185   14328/io.sonoff.0
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       54928156   14270/io.mqtt.0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       54927526   13964/iobroker.js-c
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       54923960   13964/iobroker.js-c
          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          16961      510/vncserver-x11-c
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54926940   13982/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       54931003   14478/io.web.0
          tcp6       0      0 :::53                   :::*                    LISTEN      0          16286      522/dnsmasq
          tcp6       0      0 :::22                   :::*                    LISTEN      0          54988020   27703/sshd
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          54986326   27773/cupsd
          tcp6       0      0 :::5900                 :::*                    LISTEN      0          16960      510/vncserver-x11-c
          udp        0      0 0.0.0.0:46015           0.0.0.0:*                           108        54987139   27929/avahi-daemon:
          udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          16283      522/dnsmasq
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18815      457/dhcpcd
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          54989164   27832/cups-browsed
          udp        0      0 0.0.0.0:41641           0.0.0.0:*                           0          54983888   27133/tailscaled
          udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       54929576   14216/io.mihome.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        54987137   27929/avahi-daemon:
          udp6       0      0 :::55206                :::*                                108        54987140   27929/avahi-daemon:
          udp6       0      0 :::546                  :::*                                0          21396      457/dhcpcd
          udp6       0      0 :::53                   :::*                                0          16285      522/dnsmasq
          udp6       0      0 :::41641                :::*                                0          54983879   27133/tailscaled
          udp6       0      0 :::5353                 :::*                                108        54987138   27929/avahi-daemon:
          2024-02-02 21:53:50.068  - info: info.0 (14419) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
          2024-02-02 21:53:50.789  - info: discovery.0 (14593) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
          2024-02-02 21:53:51.458  - info: discovery.0 (14593) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v17.6.0, js-controller: 5.0.17
          2024-02-02 21:53:51.556  - info: info.0 (14419) cpu Temp res = {"main":62.809,"cores":[],"max":62.809,"socket":[],"chipset":null}
          2024-02-02 21:53:54.555  - info: fronius.0 (14661) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.fronius, node: v17.6.0, js-controller: 5.0.17
          2024-02-02 21:54:14.769  - info: daswetter.0 (14563) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
          2024-02-02 21:54:15.297  - info: daswetter.0 (14563) cleaned everything up...
          2024-02-02 21:54:15.410  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-02-02 21:54:30.220  - info: alexa2.0 (14146) Unknown Device, but enabling commands, Try it and report back if commands work.
          2024-02-02 21:54:30.222  - info: alexa2.0 (14146) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
          2024-02-02 21:54:30.223  - info: alexa2.0 (14146)     Device-type:A1CFVS523BQYZ7 - Oleg's Mi Watch (Mi Watch) (SLEEP,SUPPORTS_LOCALE_SWITCH,TIMERS_AND_ALARMS,DEEZER,VOLUME_SETTING,KINDLE_BOOKS,SET_LOCALE,AMAZON_MUSIC,SIRIUSXM,REMINDERS,DEREGISTER_DEVICE,CHANGE_NAME,AUDIBLE,I_HEART_RADIO,SUPPORTS_LOCALE,ADAPTIVE_LISTENING,TIDAL,ASCENDING_ALARM_VOLUME,DIALOG_INTERFACE_VERSION,PERSISTENT_CONNECTION,MICROPHONE,SPEECH_RECOGNIZER_USS,SOUND_SETTINGS,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,CUSTOM_ALARM_TONE,TOUCH_INITIATED,DREAM_TRAINING,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,TUNE_IN,MUSIC_SKILL,MULTI_WAKEWORDS_SUPPORTED,GOLDFISH,SET_TIME_ZONE,APPLE_MUSIC,EARCONS,AUDIO_PLAYER)
          2024-02-02 21:54:37.499  - info: alexa2.0 (14146) Using cached smart home devices list from Fri Feb 02 2024 21:47:06 GMT+0100 (Mitteleuropäische Normalzeit)
          2024-02-02 21:54:38.446  - info: alexa2.0 (14146) No smart home devices to query
          2024-02-02 21:54:39.378  - info: alexa2.0 (14146) Subscribing to states...
          2024-02-02 21:54:39.387  - info: alexa2.0 (14146) Deleting the following states: ["Smart-Home-Devices.54d4a433-7a90-481c-b72b-57b2afa41876","Smart-Home-Devices.54d4a433-7a90-481c-b72b-57b2afa41876.#enabled","Smart-Home-Devices.54d4a433-7a90-481c-b72b-57b2afa41876.#delete"]
          2024-02-02 21:54:41.421  - info: alexa2.0 (14146) Alexa-Push-Connection (macDms = true) established. Disable Polling
          2024-02-02 21:54:54.670  - info: alexa2.0 (14146) Initialization Done ...
          2024-02-02 22:00:00.256  - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 19160
          2024-02-02 22:00:02.752  - info: daswetter.0 (19160) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
          2024-02-02 22:00:02.879  - info: daswetter.0 (19160) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v17.6.0, js-controller: 5.0.17
          2024-02-02 22:00:10.894  - info: daswetter.0 (19160) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
          2024-02-02 22:00:11.408  - info: daswetter.0 (19160) cleaned everything up...
          2024-02-02 22:00:11.427  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-02-02 22:06:39.130  - info: sonoff.0 (14328) Client [Sonoff-Touch1-Tim] connection closed: closed
          2024-02-02 22:06:39.528  - info: sonoff.0 (14328) Client [Sonoff-Touch1-Tim] connected with secret 1706907999526_2818
            vncserver-x11-c
            Was macht der da?
            Schalt den (vermutlich in raspi-config) aus.
            Den fully und zigbee auch noch updaten.
            Santos 1 Reply Last reply Reply Quote 1
            • Santos
              Santos @Thomas Braun last edited by
              @thomas-braun sagte in Vis2 ab morgen im stable:
              vncserver-x11-c
              Was macht der da?
              Den vncserver habe ich am Anfang noch genutzt, war einfach zu bedienen.
              Jetzt funzt alles wieder und die VIS-2 wurde installiert. Die nächsten Tage schnuppere ich mich dann rein.
              Vielen Dank für die schnelle, vor allem professionelle Hilfe!
                MasterXY last edited by
                Ich bin gerade mit der Responsive Funktion der Vis 2 am experimentieren.
                Leider gibt es wenig Infos darüber.
                Hat einer von euch einen Link mit Infos oder ein Beispielprojekt wie man die Responsive Funktionen der Vis 2 richtig verwendet?
                Ich vermute mal die Slider in den Seiteneigenschaften repräsentieren die Breite in Pixel. Ich möchte gerne dieses Raster unterteilen bzw. zwei Spalten für manche Widgets verwenden. Damit dieses gelingt habe ich neue Seiten mit immer kleiner werdenden Spaltenbreiten angelegt und bei dem größeren Raster das View in Widget verwendet. Am Ende sind das aber sehr viele Seiten was denke ich mal so nicht gedacht ist.
                Der Sinn hinter diesem a5afb011-fe0e-4eae-8f03-6a9dbb89d3cc-image.png Button verstehe ich auch nicht so richtig. Der begrenzt nur die Breite auf 50% und der restliche Spaltenplatz ist dann einfach leer. Ich hätte erwartet, dass man dann wenigstens ein zweites halbes Widget daneben setzen kann.
                • Agrippinenser
                  Agrippinenser last edited by Agrippinenser
                  ich vermisse seit heute das Widget "tplEnergy2Consumption".
                  Unter "Energie-Widgets" sind nur noch die beiden "Verteilung" und "Intervallwähler" zu sehen.
                  Korrektur: zu früh gepostet. Issue #195
                    Micha 3 @Agrippinenser last edited by Micha 3
                    @agrippinenser schon mal probiert iob u vis-2
                    zumindest sind bei mir dann die Widget Anzeigefehler weg. Issues #318
                    Keine Ahnung warum ich das nach jedem Update machen muss. Achso, die CSS Daten sind dann leider auch weg. Also vorher sichern falls vorhanden.
                    Agrippinenser 1 Reply Last reply Reply Quote 0
                      kafibo last edited by
                      bei mir werden keine Signalbilder mehr angezeigt. Ich meine das ist seit Version 2.9.25 oder 2.9.26 der Fall. Bin mir aber nicht genau sicher. Hat noch jemand das Problem ?
                      JS-Controller 5.0.19
                      nodejs 18.19.0
                      npm 10.2.3
                      Admin 6.13.16
                      Web 6.2.3
                      • Feuersturm
                        Feuersturm @kafibo last edited by
                        @kafibo Hi, führ doch bitte Mal ein downgrade auf eine frühere vis-2 Version durch und schaue wo es noch geht. Dann am besten ein issue einstellen, damit foxriver es sich anschauen kann.
                        Es gab in den letzten Wochen Änderungen, wenn man in den geschlossenen issues nach Signalbild sucht.
                          kafibo @Feuersturm last edited by
                          @feuersturm
                          So ich habe jetzt mal ein bischen getestet. Bin bis 2.9.24 zurück und da war das Problem auch noch, noch weiter wollte ich nicht zurück da gab es das Problem das alles (vor allem die Navigation) ganz langsam war.
                          Ich habe dann mehrere Standard-Widgets ausprobiert und festgestellt, dass die Signalbilder nicht mehr bei allen Widgets funktioniert. Darunter auch das normale HTML-Widget !!!
                          Dieses habe ich z.B. bei den Homematicgeräten die bei Batterie nur true und false kennen und nicht die Batteriespannung wie die HMIP-Geräte anzeigen. Dort verwende ich das HTML-Widget und lasse mir für true und false halt Signalbilder anzeigen, welche nicht mehr angezeigt werden. In früheren Verdsionen konnte man bei allen Standard - Widgets Signalbilder anzeigen lassen. Warum geht das jetzt nicht mehr.
                          Bin jetzt wieder auf 2.9.28 und dort funktionieren halt die Signalbilder nicht bei allen Widgets !
                          • Agrippinenser
                            Agrippinenser @Micha 3 last edited by
                            @micha-3 sagte in Vis2 ab morgen im stable:
                            iob u vis-2
                            bis Dato klappte das ohne Zusatz einwandfrei. Ich habe aber iob u vis-2gerade mal ausprobiert, leider erfolglos 😉
                            • Feuersturm
                              @kafibo Dann erstelle bitte einmal hier https://github.com/ioBroker/ioBroker.vis-2/issues ein entsprechendes issue. Am besten mit einem Export von einem betroffenem Widget. Schau auch parallel mal in der Konsole, wenn die Bedingung für das Signalbild auf true geht, ob es Fehler in der Konsole (F12) gibt.
                                Ritter last edited by
                                bei der Einstellung Full HD Querformat wird der Hintergrund im Editor nicht ganz ausgefüllt. Bei der normalen Seite (nicht im Editor) ist der Hintergrund dann aber komplett. Kann man da noch etwas einstellen?
                                Homoran M 2 Replies Last reply Reply Quote 0
                                  Homoran Global Moderator Administrators @Ritter last edited by
                                  @ritter welche Auflösung hat dein Monitor?
                                    Ritter @Homoran last edited by
                                    @homoran 1920x1080 auch das Notebook
                                      @ritter sagte in Vis2 ab morgen im stable:
                                      Danke!
                                      hatte befürchtet 4k
                                        Bis HD Landschaft scheint es noch richtig zu funktionieren.
                                        • N
                                          NoVinoPhobie last edited by
                                          hab das auch. Ich hab den 1920x1080 im Hochformat hängen. Der Hintergrund hört mitten drin auf. Hab ihn jetzt erstmal einfarbig bis das funktioniert.
                                            Marsx79 @Ritter last edited by
                                            @ritter
                                            Bei mir besteht das Problem auch. Stört mich schon seit längerem. Hat schon jemand ein Issue aufgemacht oder ließt der Entwickler mit?
                                            422
                                            114300
