    • U
      uwe72 @lolmeister77 last edited by uwe72
      Habe das Problem das öfters (1x pro Tag) Jarvis abstürzt:
      Kann mir jemand weiterhelfen wie ich hier das Problem lösen kann?
      Dies zeigt das Log für den betroffenen Zeitraum:
      2024-01-28 10:17:25.369  - warn: hm-rpc.1 (294) xmlrpc <- undefined method undefined with parameters undefined
      2024-01-28 10:17:25.845  - warn: jarvis.0 (157473) Install/InstallWizard.aspx: Not exists
      2024-01-28 10:17:25.851  - warn: jarvis.0 (157473) opennms/login.jsp: Not exists
      2024-01-28 10:17:25.863  - warn: jarvis.0 (157473) DesktopModules/AuthenticationServices/OpenID/license.txt: Not exists
      2024-01-28 10:17:25.875  - warn: jarvis.0 (157473) login.jsp: Not exists
      2024-01-28 10:17:25.897  - warn: jarvis.0 (157473) assets/login.jsp: Not exists
      2024-01-28 10:17:25.904  - warn: jarvis.0 (157473) dotnetduke/default.aspx: Not exists
      2024-01-28 10:17:25.951  - warn: jarvis.0 (157473) dotnetduke/Install/InstallWizard.aspx: Not exists
      2024-01-28 10:17:25.972  - warn: jarvis.0 (157473) dotnetduke/DesktopModules/AuthenticationServices/OpenID/license.txt: Not exists
      2024-01-28 10:17:26.001  - warn: jarvis.0 (157473) dotnetduke/: Not exists
      2024-01-28 10:17:26.042  - warn: jarvis.0 (157473) dnnarticle/default.aspx: Not exists
      2024-01-28 10:17:26.076  - warn: jarvis.0 (157473) dnnarticle/Install/InstallWizard.aspx: Not exists
      2024-01-28 10:17:26.095  - warn: jarvis.0 (157473) dnnarticle/DesktopModules/AuthenticationServices/OpenID/license.txt: Not exists
      2024-01-28 10:17:26.139  - warn: jarvis.0 (157473) dnnarticle/: Not exists
      2024-01-28 10:17:26.159  - warn: jarvis.0 (157473) cms/default.aspx: Not exists
      2024-01-28 10:17:26.191  - warn: jarvis.0 (157473) cms/Install/InstallWizard.aspx: Not exists
      2024-01-28 10:17:26.217  - warn: jarvis.0 (157473) cms/DesktopModules/AuthenticationServices/OpenID/license.txt: Not exists
      2024-01-28 10:17:26.251  - warn: jarvis.0 (157473) cms/: Not exists
      2024-01-28 10:17:26.280  - warn: jarvis.0 (157473) DotNetNuke/default.aspx: Not exists
      2024-01-28 10:17:26.312  - warn: jarvis.0 (157473) DotNetNuke/Install/InstallWizard.aspx: Not exists
      2024-01-28 10:17:26.344  - warn: jarvis.0 (157473) DotNetNuke/DesktopModules/AuthenticationServices/OpenID/license.txt: Not exists
      2024-01-28 10:17:26.370  - warn: hm-rpc.1 (294) xmlrpc <- undefined method undefined with parameters undefined
      2024-01-28 10:17:26.378  - warn: hm-rpc.0 (264) xmlrpc <- undefined method undefined with parameters undefined
      2024-01-28 10:17:26.393  - warn: jarvis.0 (157473) DotNetNuke/: Not exists
      2024-01-28 10:17:26.425  - warn: hm-rpc.1 (294) xmlrpc <- undefined method undefined with parameters undefined
      2024-01-28 10:17:26.426  - warn: hm-rpc.0 (264) xmlrpc <- undefined method undefined with parameters undefined
      2024-01-28 10:17:26.459  - warn: hm-rpc.0 (264) xmlrpc <- undefined method undefined with parameters undefined
      2024-01-28 10:17:26.523  - warn: jarvis.0 (157473) Install/InstallWizard.aspx: Not exists
      2024-01-28 10:17:26.546  - warn: jarvis.0 (157473) DesktopModules/AuthenticationServices/OpenID/license.txt: Not exists
      2024-01-28 10:17:26.587  - warn: jarvis.0 (157473) assets/Install/InstallWizard.aspx: Not exists
      2024-01-28 10:17:26.619  - warn: jarvis.0 (157473) assets/DesktopModules/AuthenticationServices/OpenID/license.txt: Not exists
      2024-01-28 10:17:26.709  - warn: jarvis.0 (157473) index.php: Not exists
      2024-01-28 10:17:26.716  - warn: host.iobroker-Server Cannot read file jarvis / assets/: EISDIR: illegal operation on a directory, read
      2024-01-28 10:17:26.750  - error: jarvis.0 (157473) uncaught exception: Cannot read properties of null (reading 'message')
      2024-01-28 10:17:26.751  - error: jarvis.0 (157473) TypeError: Cannot read properties of null (reading 'message')
          at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.jarvis/lib/server.js:1:11860)
          at process.processImmediate (node:internal/timers:478:21)
      2024-01-28 10:17:26.751  - error: jarvis.0 (157473) Cannot read properties of null (reading 'message')
      2024-01-28 10:17:26.754  - warn: jarvis.0 (157473) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2024-01-28 10:17:26.772  - warn: jarvis.0 (157473) admin/index.php: Not exists
      2024-01-28 10:17:26.834  - warn: jarvis.0 (157473) : Not exists
      2024-01-28 10:17:26.883  - warn: jarvis.0 (157473) index.php: Not exists
      2024-01-28 10:17:26.899  - warn: jarvis.0 (157473) login.php: Not exists
      2024-01-28 10:17:26.926  - warn: host.iobroker-Server Cannot read file jarvis / assets/: EISDIR: illegal operation on a directory, read
      2024-01-28 10:17:26.927  - error: jarvis.0 (157473) uncaught exception: Cannot read properties of null (reading 'message')
      2024-01-28 10:17:26.928  - error: jarvis.0 (157473) TypeError: Cannot read properties of null (reading 'message')
      2024-01-28 10:17:26.928  - error: jarvis.0 (157473) Cannot read properties of null (reading 'message')
      2024-01-28 10:17:26.947  - warn: hm-rpc.0 (264) xmlrpc <- undefined method undefined with parameters undefined
      2024-01-28 10:17:26.966  - warn: hm-rpc.1 (294) xmlrpc <- undefined method undefined with parameters undefined
      2024-01-28 10:17:26.999  - warn: hm-rpc.1 (294) xmlrpc <- undefined method undefined with parameters undefined
      2024-01-28 10:17:27.023  - warn: hm-rpc.1 (294) xmlrpc <- undefined method undefined with parameters undefined
      2024-01-28 10:17:27.050  - warn: hm-rpc.1 (294) xmlrpc <- undefined method undefined with parameters undefined
      2024-01-28 10:17:27.066  - warn: hm-rpc.1 (294) xmlrpc <- undefined method undefined with parameters undefined
      2024-01-28 10:17:27.097  - warn: hm-rpc.1 (294) xmlrpc <- undefined method undefined with parameters undefined
      2024-01-28 10:17:27.217  - warn: jarvis.0 (157473) trackit/Account/LogIn: Not exists
      2024-01-28 10:17:27.226  - warn: jarvis.0 (157473) TrackIt/Account/LogIn: Not exists
      2024-01-28 10:17:27.233  - warn: jarvis.0 (157473) TrackIT/Account/LogIn: Not exists
      2024-01-28 10:17:27.243  - warn: jarvis.0 (157473) TrackItWeb/Account/LogIn: Not exists
      2024-01-28 10:17:27.248  - warn: jarvis.0 (157473) tiweb/Account/LogIn: Not exists
      2024-01-28 10:17:27.260  - warn: jarvis.0 (157473) Account/LogIn: Not exists
      2024-01-28 10:17:27.307  - error: host.iobroker instance system.adapter.jarvis.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2024-01-28 10:17:27.307  - info: host.iobroker Restart adapter system.adapter.jarvis.0 because enabled
      2024-01-28 10:17:27.307  - warn: host.iobroker Do not restart adapter system.adapter.jarvis.0 because restart loop detected
      2024-01-28 10:17:28.202  - warn: hm-rpc.0 (264) xmlrpc <- undefined method undefined with parameters undefined
      2024-01-28 10:17:28.229  - warn: hm-rpc.0 (264) xmlrpc <- undefined method undefined with parameters undefined
      2024-01-28 10:17:28.246  - warn: hm-rpc.0 (264) xmlrpc <- undefined method undefined with parameters undefined
        MCU last edited by
        @uwe72 Direkt als Issue anlegen in github. Version?
        https://github.com/Zefau/ioBroker.jarvis/issues
          deta Most Active last edited by
          ich wollte Einstellungen einfach kopieren, geht aber nicht. Beispiel
          Wollte den Inhalt der Datenpunkte kopieren, so das ich Sie wo anders einfügen kann.
          Markieren geht nicht weder Firefox, Chrome. Wenn man auf die "..." Klickt geht der Editor auf, aber es steht dann nichts drinnen.
          Mh.
          Ach ja jarvis ist v.3.1.8
          cu Deta
          PS Wie stabil läuft die neue Beta?
            MCU @deta last edited by MCU
            @deta Das sind nur Beispielhinweise, wie es aussehen kann.
            Deswegen sind sie auch grau.
            Wenn etwas enthalten ist, so ist es weiss dargestellt.
            Thema alpha
            Ist noch alpha und somit noch sehr fehlerhaft.
              deta Most Active last edited by deta
              Noch was, ich habe 3 neue Homatic IP Thermostatet an der ccu3 in Betrieb genommen. Wollte diese jetzt ins Jarvis mit Scannen. Geht nicht, besser findet Sie aber siehe Screen.
              Es geht hier um Heizung Emilia, Inga und Lilly. Die anderen Thermostate sind damals bei der Erstinstall autoatisch installiert mit worden. Die neuen im Scan will er nicht.
                @deta Die musss mannanden Entwickler melden.
                Also in github Issue eintragen.
                  el-lutschi last edited by el-lutschi
                  Sorry. Falscher Post.
                    Merowinger last edited by
                    ich versuche die vis vom pvforecast Adaper im jarvis als iFrame darzustellen.
                    Ich weiß nicht welche Änderung es einmal gab, aber seit langer Zeit zeigt diese nur noch einen drehenden Kreis an.
                    Anzeigen sollte es aber eigentlich eher dieses hier:
                    Dies wird aus dem jsonGraph im MaterialDesign Widget in der vis gebastelt.
                    Wo kann ich bitte nachschauen was der Fehler ist, bzw. kann ihn mir gleich jemand direkt nennen 😉
                    Vielen lieben Dank
                      MCU @Merowinger last edited by
                      @merowinger Sandbox-Optionen alle ausgewählt?
                        Merowinger @MCU last edited by Merowinger
                        @mcu Leider ja.
                        Aber bei den Sandbox Optionen, alle aktivieren.
                        Das hat geholfen!
                        Also Vielen lieben Dank!
                          Meikie last edited by
                          Heizungsautomation
                          Hey, ich wollte mal Fragen wie ihr mit Jarvis eine Heizungsautomation umgesetzt habt. Oder gibt es hierfür eine andere Möglichkeit. Mir geht es nicht darum, die Heizung Manuel in Jarvis zu schalten, sondern die Heizung einzustellen, damit diese autom. arbeitet.
                          Vielen Dank für Eure Hilfe.
                          Liebe Grüße
                            bios123 last edited by
                            Hallo, ich hätte mal eine Frage zu Labels: Ist es möglich ein Label im Popup zu ignorieren und statt dessen den DP Schlüssel zu zeigen? Das Label soll nur im secondary DP genutz werden, da es in meinem Fall möglichst kurz sein sollte.
                            Beispiel:
                            Im Popup hätte ich gerne 'AC IN Last' stehen -> Label ignorieren:
                            Im secondary DP soll das Label dann berücksichtigt werden (wie gezeigt):
                            Hab ich da eine Option übersehen oder gibt es einen Trick?
                              MCU @bios123 last edited by
                              @bios123 Nein
                              • PackElend
                                PackElend last edited by
                                kann mir jemand sagen, ob jarvis auch FR: Dedicated User Management for vis · Issue #94 · ioBroker/ioBroker.vis-2 .
                                Ich konnte nichts in der Dokumentation finden, Google spuckt auch nichts aus.
                                  LE-R.Kelly last edited by
                                  ich kann meine Geräteliste nur noch im Expert-Modus anschauen und editieren.
                                  Wie komme ich wieder an die Geräteliste im Normal-Modus?
                                  Ronny
                                    MCU @LE-R.Kelly last edited by
                                    @le-r-kelly Rechts oben klicken.
                                      LE-R.Kelly @MCU last edited by
                                      @mcu
                                      Ich Honk! Danke
                                        Hallo,,
                                        wie kann man den Scrollbalken entfernen (PC-Ansicht)? Auf dem Tablet verschwinden das Icon und der Text zur Hälfte, so als würde sich der Inhalt nicht nach der Widget-Größe richten.
                                        Ich habe schon im Icon-Stil mit {"default":{"width":"30px","height":"30px"}} experimentiert. Ich kriege es aber nicht im Widget zentriert.
                                        Hat jemand einen Tipp?
                                        VG
                                        Ronny
                                          @le-r-kelly
                                          https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/styles/scrollbalken#scrollbalken-ausblenden
                                          Ist das ein HomeKitTile?
                                          Welche Größe im Layout?
                                            @mcu
                                            Das ist ein StateList. Die Größe ist 1w x 4h.
                                            Kann man im Layout die jeweilige Widget-Breite feiner einstellen so wie bei der Widget-Höhe? Wenn man die Breite einstellen will hat man ganz schöne Sprünge drin und verschwendet mitunter viel Platz, weil man das Widget weiter aufziehen muss als nötig.
                                            In dem Zusammenhang: Ich schaffe es nicht ein StateHTML zu zentrieren bzw. zu ändern.
                                            Die Einstellungen werden ignoriert und per CSS konnte ich auch nichts erreichen. Bspw. bewirkt nachfolgender Code nichts.
                                            .jarvis-widget-9cc9e479-2e16-4061-bdfe-f0c9ff4f5c04.q-item_label {
                                            	font-size: 10px;
                                            Und innerhalb eines StateList-Widgets - wie kann ich die Schriftgröße des Datenpunktes ändern? Weder im Gerät (Datenpunkt Stil) noch per CSS konnte ich etwas erreichen.
                                            Sorry, viele Fragen auf einmal. Aber ich ziehe gerade auf ein neues Tablet mit einer höheren Auflösung um und musste feststellen, dass sich das (für mich) nicht so auf die Schnelle umstellen lässt und ich jedes Widget einzeln händsich anpassen muss.
                                            Viele Grüße
                                            Ronny
                                            254
                                            4489
                                            2559583
