    4. Repository-Verzeichnisse werden nicht gespeichert
    • Zaphod
      Zaphod @Glasfaser last edited by Zaphod
      @glasfaser
      config:
        "common": {
          "name": "System configuration",
          "city": "Wettenberg",
          "country": "Germany",
          "longitude": "...",
          "latitude": "...",
          "language": "de",
          "tempUnit": "°C",
          "currency": "€",
          "dateFormat": "DD.MM.YYYY",
          "isFloatComma": false,
          "licenseConfirmed": true,
          "defaultHistory": "history.0",
          "activeRepo": [
            "stable"
          "diag": "no-city",
          "tabs": [
            "tab-adapters",
            "tab-instances",
            "tab-logs",
            "tab-scenes",
            "tab-javascript",
            "tab-text2command-0",
            "tab-enums",
            "tab-intro",
            "tab-wetty-0",
            "tab-fullcalendar-0",
            "tab-hosts",
            "tab-objects",
            "tab-terminal-0",
            "tab-devices"
          "defaultNewAcl": {
            "object": 1636,
            "state": 1636,
            "file": 1636,
            "owner": "system.user.admin",
          "intro": {},
          "wizard": true,
          "infoAdapterInstall": true,
          "tabsVisible": [
              "name": "tab-intro",
              "visible": true
              "name": "tab-adapters",
              "visible": true
              "name": "tab-instances",
              "visible": true
              "name": "tab-objects",
              "visible": true
              "name": "tab-enums",
              "visible": true
              "name": "tab-logs",
              "visible": true
              "name": "tab-users",
              "visible": true
              "name": "tab-hosts",
              "visible": true
              "name": "tab-files",
              "visible": true
              "name": "tab-backitup-0",
              "visible": true
              "name": "tab-info",
              "visible": true
              "name": "tab-devices",
              "visible": false
              "name": "tab-javascript",
              "visible": true
              "name": "tab-alias-manager",
              "visible": true
              "name": "tab-terminal-0",
              "visible": true
          "firstDayOfWeek": "monday",
          "expertMode": false
        "acl": {
          "object": 1636,
        "_id": "system.config",
        "native": {
          "secret": "bc84dd0d172e1a0c583c4d3d96648f039bc649ffc8e39a58"
        "type": "config",
        "user": "system.user.admin",
        "ts": 1707069666415
      repositories:
        "common": {},
        "native": {},
        "type": "meta",
        "_id": "system.repositories",
        "acl": {
          "object": 1636,
      repositories ist ein leerer Ordner
      • Glasfaser
        @glasfaser sagte in Repository-Verzeichnisse werden nicht gespeichert:
        und seit wann hast du dieses Problem !?
        Zaphod 2 Replies Last reply Reply Quote 0
        • Zaphod
          @Glasfaser
          schon sehr lange (> 1 Jahr)
          Hab's damals erfolglos selbst versucht zu lösen.
          .. ich weiß - Probleme verschieben ist auch keine Lösung.
          .. die Not war nicht groß - das System läuft stabil
          • Glasfaser
            Glasfaser @Zaphod last edited by
            @zaphod sagte in Repository-Verzeichnisse werden nicht gespeichert:
            Naja ( falscher Gedanke )
            du kannst versuchen :
            Tausch den Inhalt hiermit :
            Mußte es Zippen , also bei dir entpacken ..
            repo.zip
            Zaphod 1 Reply Last reply Reply Quote 0
            • Zaphod
              @glasfaser
              redis_2023_12_09-02_00_33_ioBroker_backupiobroker.tar.gz
              historyDB_2023_12_09-02_00_34_ioBroker_backupiobroker.tar.gz
              javascripts_2023_12_09-02_01_01_ioBroker_backupiobroker.tar.gz
              iobroker_2023_12_10-02_00_10_ioBroker_backupiobroker.tar.gz
              ich hab' in meiner Dropbox Backups seit Anfang 22 - fast täglich .. vielleicht können die ja auch helfen (obwohl die nicht objects und states differenzieren)
              • Zaphod
                @glasfaser
                hab's in "repository" reinkopiert.
                .. der "schreiben"-button ist aber ausgegraut.
                • Glasfaser
                  @zaphod
                  Klicke auf 644 dann :
                  • Zaphod
                    @glasfaser
                    verdammt: hab' die Rechte so gesetzt (also insb. bei "Jeder"/schreiben - kann immer noch nicht schreiben.
                    Hab' dann alles gesetzt (666) immer noch kein Schreibrecht.
                    Nutzer/Gruppe ist bei mir "admin"/"Administrator"
                    • Glasfaser
                      Glasfaser last edited by Glasfaser
                      @zaphod
                      Bei mir ( Testsystem ) geht auch 644
                      dann :
                      iob stop
                      iob fix
                      sudo reboot
                      • Zaphod
                        @glasfaser
                        mach ich.
                        was mich wundert ist, dass bei mir "repositories" als Ordner angezeigt wird,
                        dessen Daten man bearbeiten kann.
                        wo liegt das Ding denn im Filesystem - dann kann ich auch dort mal schauen, ob das ein directory ist und ggf eine repository-Datei mit Deinen Daten anlegen - User/Group und Rechte könnte ich dann auch im Dateisystem eintragen.
                        .. aber erstmal "fixen" (hab' ich heute aber schon mehrmals gemacht;)
                        • Glasfaser
                          Glasfaser @Zaphod last edited by Glasfaser
                          @zaphod
                          Ahh ... diese wichtige Information fehlte
                          Importiere das mal :
                          system.repositories.json
                          • Zaphod
                            @glasfaser
                            in system.repositories.json steht
                            .. also ein leeres json. War das Dein Inhalt?
                            Beim Hochladen wird "ungültige Struktur" gemeldet.
                            Soll ich den Ordner "repositories" 'mal aus den Objekten löschen, bevor ich es hochladen
                            • Glasfaser
                              @glasfaser
                              mach ich.
                              Kannst du mir einen gesamten Screenshot zeigen was alles in system. ist !
                              • Zaphod
                                @glasfaser
                                Ich hab' 'mal die nächste EBene aufgeklappt - wird sonst etwas zu groß für einen ScreenDump.
                                Ich hoffe, Du kannst es noch lesen:
                                • Glasfaser
                                  @zaphod
                                  also endet er bei repositories
                                  Zaphod Homoran 2 Replies Last reply Reply Quote 0
                                  • Zaphod
                                    @glasfaser
                                    yepp
                                    • Glasfaser
                                      @zaphod
                                      lösche den Ordner repositories , dann :
                                      iob stop
                                      iob setup first
                                      • Zaphod
                                        Zaphod @Zaphod last edited by
                                        @zaphod
                                        und in repositories sind auch keine weiteren Objekte drinnen ...
                                        • Zaphod
                                          @glasfaser
                                          ok
                                          • Zaphod
                                            @glasfaser said in Repository-Verzeichnisse werden nicht gespeichert:
                                            iob setup first
                                            DU BIST EIN HELD!
                                            repositories-Objekt wieder da (mit den INhalten, die Du mir gezipped geschickt hattest)!
                                            Unter Einstellungen sind die Repositories "stable" und "beta" auch eingetragen !
                                            Die Adapter zeigen nun auch updates an!
                                            ich bin wieder im business 🚀
                                            DANKE DIR!
                                            4775
