UNSOLVED Iobroker VIS keine Visualisierung
@glasfaser sagte in Iobroker VIS keine Visualisierung:
das ist nicht die Browserkonsole
Apropos Browser, mal alternativ nen anderen ausprobiert?
@meintre-0 sagte in Iobroker VIS keine Visualisierung:
up to date in 6s228 packages are looking for funding run npm fund for details
Adapter "system.adapter.vis.0" restarted.[Log] 2024-02-05T19:49:38.055Z Connected => authenticate (conn.js, line 310) [Log] 2024-02-05T19:49:38.148Z Authenticated: true (conn.js, line 331) [Error] TypeError: undefined is not an object (evaluating 'views[view].widgets[vgroup].data') getUsedObjectIDs (visUtils.js:479:97) getUsedObjectIDs (vis.js:512) (anonyme Funktion) (vis.js:2047) (anonyme Funktion) (conn.js:585)
@samson71 sagte in Iobroker VIS keine Visualisierung:
Bei Äpfeln ist die Gefahr von Reise sehr groß
[Warning] ApplicationCache is deprecated. Please use ServiceWorkers instead. (edit.html, line 2) [Log] Version vis-colorpicker: 2.0.3 (edit.html, line 3406) [Log] Version vis-ebus: 2.4.4 (edit.html, line 5745) [Log] Version Info-Adapter-Widget: 1.9.26 (info.js, line 29) [Log] Metro version: "1.2.0" (edit.html, line 10053) [Log] Version vis-plumb: 1.0.0 (edit.html, line 11385) [Log] Version trashschedule: 2.3.0 (trashschedule.js, line 176) [Log] [2024-02-05T19:51:42.515Z] Try to connect (socket.io.js, line 83) [Warning] Parsing application manifest data:application/json;charset=8{"name":"ioBroker vis","short_name":"vis","start_url":".#main/%22,%22display%22:%22standalone%22,%22background_color%22:%22#ffffff%22,%22description%22:%22WEB%20visualisation%20for%20ioBroker%20platform%22,%22icons%22:[{%22src%22:%22img/vis.png%22,%22sizes%22:%22192x192%22,%22type%22:%22image/png%22}]}: The manifest is not valid JSON data. [Log] 2024-02-05T19:51:42.529Z Connected => authenticate (conn.js, line 310) [Log] 2024-02-05T19:51:42.584Z Authenticated: true (conn.js, line 331) [Error] TypeError: undefined is not an object (evaluating 'views[view].widgets[vgroup].data') getUsedObjectIDs (visUtils.js:479:97) getUsedObjectIDs (vis.js:512) (anonyme Funktion) (vis.js:2047) (anonyme Funktion) (conn.js:585)
Hast du etwas im View gruppiert !?
ja mehrere Gruppen
Dann liegt dort der Fehler !
bin gerade dabei eine Seite ohne Gruppen zu öffnen
@meintre-0
Und bitte gewöhne Dir an Konsoleninhalte in Code Tags zu posten. Da liest sich extrem gruselig, vor allem am Handy. -
ich habe keine Ahnung wie man das macht?
aber Seite ohne Gruppen funktioniert auch nicht
[Error] TypeError: undefined is not an object (evaluating 'views[view].widgets[vgroup].data') getUsedObjectIDs (visUtils.js:455:97) getUsedObjectIDs (vis.js:519) (anonyme Funktion) (vis.js:2055) (anonyme Funktion) (conn.js:585)
das gesamte Projekt wird geladen!
dann müsstest du ein Projekt ohne Gruppen haben.
Text markieren und dann im Menü oben benutzen
ah, danke für die Antwort . Werde ich in Zukunft machen
dann muß ich alle Gruppen auflösen und es nochmals versuchen.
Das kann dauern!!!!!! -
Das kann dauern!!!!!!dann versuch doch lieber erst einmal einen anderen Browser!
habe ich schon versucht -> gleiches Ergebnis
@meintre-0
alle Gruppen aufgelöst und immer noch keine Visualisierung und Edit
