    4. E-INK Display OpenEPaperLink - Displayanzeige mit Batterie
      Revobobo @bimmi last edited by
      @bimmi
      Huiuiui - das hört sich nach einem neuen AP an - der MINI schafft dass bestimmt nicht mehr....
      Viele Grüße
        Revobobo @Revobobo last edited by
        Ist das hier der Aktuellste oder gibt es schon Neuere?
        Link Text
          Beowolf last edited by Beowolf
          Ich habe jetzt einen zweiten AP hier bei mir im Haus.
          In dem LOG Fenster erscheint nun ständig dieses hier:
          22:28:58 moved AP from local to external 00007E1C3E8CB29D
          22:28:58 moved AP from external to local 00007E1C3E8CB29D
          22:28:54 moved AP from local to external 000001811F073B3A
          22:28:54 moved AP from external to local 000001811F073B3A
          22:28:51 moved AP from local to external 00007E1BDCACB294
          22:28:50 moved AP from external to local 00007E1BDCACB294
          22:28:43 moved AP from local to external 000001814A2E3B31
          22:28:43 moved AP from external to local 000001814A2E3B31
          22:28:42 moved AP from local to external 0000018141903B3F
          22:28:41 moved AP from external to local 0000018141903B3F
          22:28:39 moved AP from local to external 00007E1BD7F3B295
          22:28:39 moved AP from external to local 00007E1BD7F3B295
          22:28:39 moved AP from local to external 000001811F763B3C
          22:28:38 moved AP from external to local 000001811F763B3C
          22:28:37 moved AP from local to external 0000018171233B34
          22:28:37 moved AP from external to local 0000018171233B34
          22:28:34 moved AP from local to external 00007E1BDDE2B29F
          22:28:33 moved AP from external to local 00007E1BDDE2B29F
          22:28:30 moved AP from local to external 00007E1C34B6B29E
          22:28:29 moved AP from external to local 00007E1C34B6B29E
          22:28:27 moved AP from local to external 00007E1C46F8B291
          22:28:27 moved AP from external to local 00007E1C46F8B291
          22:28:24 moved AP from local to external 00007E211D11B296
          22:28:23 moved AP from external to local 00007E211D11B296
          22:28:19 moved AP from local to external 00007E1C3E8CB29D
          22:28:18 moved AP from external to local 00007E1C3E8CB29D
          22:28:14 moved AP from local to external 000001811F073B3A
          22:28:14 moved AP from external to local 000001811F073B3A
          22:28:06 moved AP from local to external 00007E1BDCACB294
          22:28:05 moved AP from external to local 00007E1BDCACB294
          22:28:03 moved AP from local to external 000001814A2E3B31
          22:28:03 moved AP from external to local 000001814A2E3B31
          22:27:59 moved AP from local to external 00007E1BD7F3B295
          22:27:58 moved AP from external to local 00007E1BD7F3B295
          22:27:58 moved AP from local to external 000001811F763B3C
          22:27:58 moved AP from external to local 000001811F763B3C
          22:27:57 moved AP from local to external 0000018171233B34
          22:27:57 moved AP from external to local 0000018171233B34
          22:27:49 moved AP from local to external 00007E1C34B6B29E
          22:27:49 moved AP from external to local 00007E1C34B6B29E
          22:27:47 moved AP from local to external 00007E1C46F8B291
          22:27:47 moved AP from external to local 00007E1C46F8B291
          Das sieht für mich so aus, als ob die TAGs ständig versuchen sich bei dem einen oder anderen AP anzumelden.
          Ich musste den zweiten AP ausschalten. Es wird nur versucht die TAG hin und her zu schieben. Kein TAG wird mehr aktualisiert.
          Da funktioniert etwas noch nicht.
            bimmi last edited by bimmi
            Da sind die ap zu nah bei einander. Das hatte ich auch bei ein paar Tags. Roaming.
            Das kannst du nur unterbinden indem du beide ap auf unterschiedlichen zigbee Kanälen laufen lässt. Ich habe meine auf 11 und 20.
              Beowolf @bimmi last edited by
              @bimmi
              Kann es sein, das die weissen TAGs nur Kanal 11 können?
                bimmi @Beowolf last edited by
                @beowolf nein. Habe ich bei mir unterschiedlich.
                  @bimmi
                  Geht jetzt. Die ganze Geschichte benötigt manchml sehr viel Zeit, damit sich alle untereinander finden und zufrieden sind.😊
                    @bimmi
                    Gibt es schon etwas zu bewundern?
                    PS
                    Warum ist im ersten Beitrag der Link durchgestrichen?
                      bimmi @Beowolf last edited by bimmi
                      @beowolf ups. Da wollte ich eigentlich den ursprünglichen tindy link durchstreichen und nicht den github link. Danke!
                      Was sollte es denn zu bewundern geben?
                        @bimmi
                        Natürlich die angekündigten Neuigkeiten aus diesem Beitrag
                        https://forum.iobroker.net/topic/66380/eps-e-ink-display-ansteuerung-statusdisplay-für-2/345?_=1707207991400
                        Freu. 😳
                          @beowolf nein. Da gibt es nix neues 😂 aber ich berichte dann
                            OpenEPaperLink Mini Access Point v4
                            What the heck can I do with this?
                            Basicly, this is a universal WiFi <-> IEEE 802.15.4 gateway, with a size smaller than a credit card.
                            You can use this set to setup your own E-Paper display system at home. The displays can display nearly anything. Just send a jpg file to the AP, and it can be displayed on one of the displays. The AP can generate all kinds of content itself too! Stuff like weather forecasts and the date can be shown on a tag, making for a nice dynamic little screen. It's also possible to use the AP with HomeAssistant thanks to an integration.
                            All details can be found here: OpenEPaperLink. With this Access Point and some displays, you have a fully working system.
                            New: the access point has a flasher port! Now, you can revive your tags after a firmware update goes wrong, or when you find compatible tags on eBay which are not preflashed yet.
                            --> jetzt neu, Access Point V4 inkl. integriertem Flasher!
                            https://www.tindie.com/products/electronics-by-nic/openepaperlink-mini-ap-v3-zigbee-wifi-gateway/
                            Edit: alle weg.
                              diwoma @bimmi last edited by
                              @bimmi
                              Ich habe das Mail bekommen und um 12:33 Uhr noch welche bekommen.
                              Ich bin neugierig, ob das schon der V4 ist, wie ich jetzt gerade gelesen habe
                                bimmi @diwoma last edited by
                                @diwoma ja ist der v4. Er konnte nur den Titel nicht mehr ändern, da sonst alle verteilten links nicht mehr gültig sind.
                                  @bimmi sagte in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
                                  Ja, so habe ich es auch verstanden 🙂
                                    Freak last edited by
                                    Hallo Zusammen,
                                    die Anleitung oben habe ich gesehe, vielen Dank dafür. Ist ganz schön aufwändig.
                                    Es gibt ja inzwischen auch einen Adapter dafür. Darüber ist aber (noch) keine steuerung möglich, oder?
                                    Wird der das Schicken der bilder auf die Displays über den adapter möglich sein? Bzw. ist das angedacht?
                                    ? mcm1957 2 Replies Last reply Reply Quote 0
                                      A Former User @Freak last edited by
                                      @freak
                                      ich hatte den Adapter mal testweise installiert, aber ausser Auslesen von den Tags kann er zur Zeit noch nichts, ist noch im Alpha-Status.
                                      Es gibt auf Github einige PR's, aber seit November ist da nichts mehr passiert, und die Software des AP's hat sich ja weiterentwickelt..
                                      Vielleicht kann uns einer der Dev's @Dutchman und/oder @ticaki etwas dazu sagen?
                                      • mcm1957
                                        mcm1957 @Freak last edited by
                                        @freak said in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
                                        Wenn du diesen Adapter meinst:
                                        ioBroker.open-epaper-link
                                        muss ich leider drauf hinweeisen, dass dieser bisher nicht in die offiziellen Repositories aufgenommen wurde und nach der anfänglichen Entwicklung derzeit scheinbar NICHT mehr gewartet wird. Beim Check zur Aufnahme in das Latest Repository sind einige Kleinigkeiten aufgefallen. Allerdings wurden diese nicht (mehr) behoben und es erfolgte auch trotz mehrfachen Nachfragen keine Reaktion.
                                        Siehe https://github.com/ioBroker/ioBroker.repositories/pull/3003
                                        Derzeit kann zu diesem Adapeter nur gesagt werden - use completly at own risk...
                                        Leider.
                                        DutchmanNL created this issue in ioBroker/ioBroker.repositories
                                        closed Add open-epaper-link to latest #3003
                                          ticaki @Guest last edited by
                                          @ilovegym
                                          Ich gehöre nicht zu den devs - dutchman hat den an einem Sonntag als ich keine Zeit habe geschrieben und da er fast fertig war, hatte ich dann kein interesse mehr mich einzubringen. Hatte auch nix da um zu testen oder so 🙂
                                            Danke für die Rückmeldungen, schade eigentlich, dann werde ich mich wohl doch mal an der Blockly Anleitung versuchen.
                                            1028
                                            330804
