    4. Problem mit Shelly Adapter - Shelly 2.5 Position rot
    • haselchen
      haselchen Most Active @guitardoc last edited by
      @guitardoc
      Und wie immer , mehr Infos bitte.
      iob diag
      z..B.
      und dann noch, womit steuerst du den DP?
      Blockly?
      Javascript?
        guitardoc @haselchen last edited by
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 6.5.11-8-pve
            Architecture: x86-64
        model name      : Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         20:31:18 up  1:17,  4 users,  load average: 0.29, 0.23, 0.29
        CPU threads: 2
        *** Time and Time Zones ***
                       Local time: Mon 2024-02-05 20:31:18 CET
                   Universal time: Mon 2024-02-05 19:31:18 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** User and Groups ***
        mn
        /home/mn
        mn adm dialout sudo users iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            4.3G        2.1G        1.6G        139K        637M        2.2G
        Swap:           536M          0B        536M
        Total:          4.8G        2.1G        2.1G
                 4096 M total memory
                 1965 M used memory
                 1921 M active memory
                  485 M inactive memory
                 1522 M free memory
                    0 M buffer memory
                  608 M swap cache
                  512 M total swap
                    0 M used swap
                  512 M free swap
        *** FAILED SERVICES ***
          UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        2 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--101--disk--0 ext4      7.8G  3.7G  3.8G  50% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        /dev/mapper/pve-root             ext4       94G  6.2G   83G   7% /dev/ttyACM0
        udev                             devtmpfs   32G     0   32G   0% /dev/tty
        tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
        tmpfs                            tmpfs      13G  128K   13G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs                            tmpfs     6.3G     0  6.3G   0% /run/user/1001
        dmesg: read kernel buffer failed: Operation not permitted
        TARGET         SOURCE                                                 FSTYPE OPTIONS
        /              /dev/mapper/pve-vm--101--disk--0                       ext4   rw,relatime,stripe=16
        `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/101/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
        /var:
        700M    /var/
        306M    /var/cache
        302M    /var/cache/apt
        248M    /var/log
        247M    /var/log/journal/105f04df101b4fd9aa5af34dea5da7f8
        Archived and active journals take up 246.9M in the file system.
        /opt/iobroker/backups:
        48M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        325M    /opt/iobroker/iobroker-data/
        193M    /opt/iobroker/iobroker-data/files
        105M    /opt/iobroker/iobroker-data/backup-objects
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
        21M     /opt/iobroker/iobroker-data/objects.jsonl
        8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org bookworm-security/main amd64 Packages
         *** 18.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0+dfsg1-1 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.13.16
        javascript:     7.1.6
        Adapters from github:   2
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alarm.0                  : alarm                 : iobroker                                 - disabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        + system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
        + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
        + system.adapter.shuttercontrol.1         : shuttercontrol        : iobroker                                 -  enabled
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          system.adapter.viessmannapi.0           : viessmannapi          : iobroker                                 - disabled
          system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
        + instance is alive
        ioBroker-Repositories
        stable        : https://download.iobroker.net/sources-dist.json
        beta          : https://download.iobroker.net/sources-dist-latest.json
        live-stable   : http://iobroker.live/repo/sources-dist.json
        live-beta     : http://iobroker.live/repo/sources-dist-latest.json
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "alarm"        : 3.6.0    , installed 3.6.0
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "eusec"        : 1.2.1    , installed 1.2.1
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "followthesun" : 0.5.0    , installed 0.5.0
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "logparser"    : 2.2.1    , installed 2.2.1
        Adapter    "modbus"       : 6.1.0    , installed 6.1.0
        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
        Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vw-connect"   : 0.0.67   , installed 0.1.3
        Adapter    "weatherunderground": 3.6.0, installed 3.6.0
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
        Objects and States
        Objects:        11953
        States:         9388
        Hit:2 http://security.debian.org bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      1000       1690163    2200/go2rtc
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1687127    1913/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1688015    1913/iobroker.js-co
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1598978    1/init
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       1688301    2034/io.shelly.1
        tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1000       1688213    2004/io.mqtt.0
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       1688212    2004/io.mqtt.0
        tcp        0      0 127.0.0.1:38951         0.0.0.0:*               LISTEN      1000       1693153    2298/io.yahka.0
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1602640    302/master
        tcp6       0      0 :::8554                 :::*                    LISTEN      1000       1690158    2200/go2rtc
        tcp6       0      0 :::43617                :::*                    LISTEN      1000       1693938    2298/io.yahka.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          1598980    1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          1596297    1/init
        tcp6       0      0 :::1984                 :::*                    LISTEN      1000       1690157    2200/go2rtc
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1602641    302/master
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1690746    2125/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1688092    1932/io.admin.0
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1692839    2268/io.simple-api.
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1598979    1/init
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1693939    2298/io.yahka.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1688254    2019/io.shelly.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       1687505    2049/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       1687506    2049/io.tuya.0
        udp        0      0 0.0.0.0:40295           0.0.0.0:*                           1000       1690104    2170/io.eusec.0
        udp        0      0 0.0.0.0:8555            0.0.0.0:*                           1000       1690159    2200/go2rtc
        udp        0      0 0.0.0.0:44352           0.0.0.0:*                           1000       1691187    2170/io.eusec.0
        udp6       0      0 :::111                  :::*                                0          1598981    1/init
        2024-02-05 19:50:44.994  - error: eusec.0 (2170) Station: T8010P2320100018 command CMD_SDINFO_EX failed with error: undefined (-148)
        2024-02-05 19:50:45.028  - error: eusec.0 (2170) Station: T8010N2320201304 command CMD_SDINFO_EX failed with error: undefined (-148)
        2024-02-05 19:52:49.298  - warn: zigbee.0 (2079) DeviceAvailability:Stopping to ping 0xa4c1382ad59e8217 TS011F after 4 ping attempts
        2024-02-05 19:53:52.712  - error: vw-connect.0 (2283) restart adapter in 10min
        2024-02-05 19:53:52.712  - warn: vw-connect.0 (2283) Restart initiated
        2024-02-05 19:53:52.712  - info: vw-connect.0 (2283) cleaned everything up...
        2024-02-05 19:53:52.715  - info: vw-connect.0 (2283) terminating
        2024-02-05 19:53:52.715  - info: vw-connect.0 (2283) Terminated (NO_ERROR): Without reason
        2024-02-05 19:53:53.214  - info: vw-connect.0 (2283) terminating
        2024-02-05 19:54:23.906  - info: vw-connect.0 (2689) starting. Version 0.1.3 (non-npm: TA2k/ioBroker.vw-connect#d6af9940664239b28c563db9ca1eadf10d6b5ce5) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v18.19.0, js-controller: 5.0.17
        2024-02-05 19:54:23.914  - info: vw-connect.0 (2689) Login in with id
        2024-02-05 19:54:26.306  - info: vw-connect.0 (2689) ID login successfull
        2024-02-05 19:54:26.306  - info: vw-connect.0 (2689) History limit: -1, set to -1 to disable wallcharging login
        2024-02-05 19:54:26.306  - info: vw-connect.0 (2689) History limit is set to -1, no wall charging login
        2024-02-05 19:54:26.306  - info: vw-connect.0 (2689) Login successful
        2024-02-05 19:54:27.179  - info: vw-connect.0 (2689) Found 1 vehicles
        2024-02-05 19:54:27.179  - info: vw-connect.0 (2689) Create vehicle WVGZZZCR7RD005807
        2024-02-05 20:00:46.041  - error: eusec.0 (2170) Station: T8010P2320100018 command CMD_SDINFO_EX failed with error: undefined (-148)
        2024-02-05 20:00:46.060  - error: eusec.0 (2170) Station: T8010N2320201304 command CMD_SDINFO_EX failed with error: undefined (-148)
        2024-02-05 20:10:47.174  - error: eusec.0 (2170) Station: T8010N2320201304 command CMD_SDINFO_EX failed with error: undefined (-148)
        2024-02-05 20:10:47.194  - error: eusec.0 (2170) Station: T8010P2320100018 command CMD_SDINFO_EX failed with error: undefined (-148)
        2024-02-05 20:20:48.320  - error: eusec.0 (2170) Station: T8010P2320100018 command CMD_SDINFO_EX failed with error: undefined (-148)
        2024-02-05 20:20:48.323  - error: eusec.0 (2170) Station: T8010N2320201304 command CMD_SDINFO_EX failed with error: undefined (-148)
        2024-02-05 20:30:49.318  - error: eusec.0 (2170) Station: T8010P2320100018 command CMD_SDINFO_EX failed with error: undefined (-148)
        2024-02-05 20:30:49.338  - error: eusec.0 (2170) Station: T8010N2320201304 command CMD_SDINFO_EX failed with error: undefined (-148)
        Steuerung eigentlich mit Shuttercontrol, zum Test im Moment allerdings per Hand.
          Wildbill @guitardoc last edited by Wildbill
          @guitardoc Beim Test von Hand wichtig, dass Du dann unten den Haken bei „Bestätigt“ NICHT setzen darfst. Sonst wird auch nix ausgeführt!
          Kommen irgendwelche Meldungen im Log, wenn Du von Hand schaltest?
          Gruss, Jürgen
          EDIT: Mach mal einen Reboot, da scheinen ein paar Services sich aufgehängt zu haben.
          EDIT2: Du hast zwei Shelly-Adapter laufen. Einmal auf Port 1882 und einmal auf 1883. Absicht? Sind die Shelly mit dem richtigen Adapter verbunden (Port im Shelly richtig)?
            guitardoc @Wildbill last edited by
            Die Fehlermeldungen kommen immer nach dem Reboot des Systems, schon seit langer Zeit. Sind teils auch schon bekannte Probleme wo dran gearbeitet wird.
            Die beiden Shelly Instanzen sind Absicht - einmal für Coap-Geräte und einmal für MQTT-Geräte.
            • da_Woody
              da_Woody @guitardoc last edited by
              @guitardoc seit wann braucht CoAP einen port?
                guitardoc @da_Woody last edited by
                @da_woody das weiß ich nicht, es müssen aber die alten Geräte von den neueren durch zwei Instanzen getrennt werden.
                Das ist aber alles nicht das Problem, denn es lief ja monatelang.
                da_Woody 2 Replies Last reply Reply Quote 0
                • da_Woody
                  @guitardoc du hast mich falsch verstanden. Ich hab auch 2 Instanzen. .0 für CoAP (gen1), .1 für MQTT (gen2).
                  Aber bei gen1 (CoAP) gibt's keinen Port!
                  • da_Woody
                    @guitardoc sagte in Problem mit Shelly Adapter - Shelly 2.5 Position rot:
                    Ich hab da so einen Verdacht nach der Aussage. Zeig mal deine Einstellungen der Instanzen und von einem gen1 und gen2 Gerät...
                    Imho biste noch auf mcast unterwegs...
                      Haha! Ich denke, ich habe das Problem gefunden. ioBroker und Homebridge für Homekit laufen bei mir auf einem Proxmox in jeweiligen CTs. Der Neustart der CTs reicht offensichtlich nicht immer aus - man muss den gesamten Proxmox neu starten. Dann läuft es wieder. So ein Theater…
                      Hier aber trotzdem mal noch die Einstellungen:
                      • haus-automatisierung
                        haus-automatisierung Developer Most Active @da_Woody last edited by haus-automatisierung
                        @da_woody sagte in Problem mit Shelly Adapter - Shelly 2.5 Position rot:
                        Natürlich gibt es den. Unicast richtig konfigurieren. Wie sollen Geräte sonst kommunizieren? Port 5683.
                        5683 tcp coap Constrained Application Protocol (CoAP) [RFC8323] , registered 2017-12-22
                        Siehe
                        https://github.com/iobroker-community-adapters/ioBroker.shelly/blob/master/docs/de/protocol-coap.md
                        • da_Woody
                          @guitardoc schön und gut. die 2. seiten wären etwas aussagekräftiger, was du da eingestellt hast..
                          was mich aber noch mehr interessiert:
                          coap
                          wenn da mcast steht, könnte das auch probleme machen.
                          mqtt
                          nebenbei wäre schon im ersten posting nicht schlecht gewesen wie dein system läuft. sonst is das stochern im trüben und kristallkugel.gif
                          • da_Woody
                            da_Woody @haus-automatisierung last edited by
                            warum ich wohl gefragt habe?
                              guitardoc @da_Woody last edited by guitardoc
                              @da_woody MQTT hab ich die gleich Einstellungen.
                              Bei Coap steht bei mir vermutlich in allen Shellys das hier drin (über die App lässt sich da ja nichts einstellen und in der Oberfläche der Shellys per IP hab ich nur gelegentlich was eingestellt):
                              Wenn ich aber die IP dezidiert hier eintrage, dann befürchte ich, dass dann keine Übertragung mehr zu Homekit über die Homebridge stattfindet sondern eben nur noch zu ioB. Das ist es doch was Multicast macht, oder?
                              • da_Woody
                                da_Woody @guitardoc last edited by da_Woody
                                @guitardoc und somit hat sich meine Vermutung bestätigt!
                                mcast wurde schon vor längerer Zeit auf unicast umgestellt. Funktioniert bei einigen noch, irgendwann kommen die probs.
                                Dort gehört auch nur die IP vom iobroker rein, save, der Port wird automatisch zugefügt. Hab ich auch schon in gefühlten Postings geschrieben.
                                Ja, jeh mehr shelly, um so mehr Arbeit. Bei mir waren es mehr als 60. Bei neuen mach ich das automatisch gleich beim Einrichten (gen1) wie auch im Router die IP an die MAC binden.
                                Edith: sorry mit deinem homekit Gedöns kenn ich mich nicht aus.
                                  @da_woody Hab’s gerade getestet, mit dezidierter IP geht die Steuerung über Homekit nicht mehr. Mit mcast funktioniert alles so wie es soll.
                                  • da_Woody
                                    @guitardoc ok. mir stellt sich nur gerade die frage, warum ioB und Homekit. ist m.W. was ähnliches.
                                    warum beides? was bietet dir homekit mehr als ioB?
                                    nachdem dein problem ja abgehakt ist, wäre das eventuell auch für andere interessant.
                                    ansonsten wäre der tread als gelöst zu markieren...
                                      guitardoc last edited by guitardoc
                                      @da_woody über HomeKit lassen sich alle Geräte per Tastendruck steuern ohne dass man erst eine Visualisierung bauen muss. Auch diverse Automationen (nicht alle, dafür brauche ich ja eben den ioB) gehen mit HomeKit super einfach zu erstellen und zu nutzen. Und über Kurzbefehle lassen sich auch mehrere Geräte komplex auswerten und ausführen. Über das integrierte Geofencing wird die Haustür automatisch verriegelt wenn ich das Haus verlasse. Und ich kann die Geräte von Ferne aus steuern ohne irgend etwas programmieren zu müssen. Alles schon fertig vorhanden…
                                      Möglicherweise geht vieles davon auch in ioBroker, aber in HomeKit ist das meiste (bis auf komplexe Steuerungen) mit zwei drei Klicks zusammen geklickt und schon fertig da. Einschließlich Übersichten von Überwachungskameras, Visualisierung der Standorte von Fahrzeugen, etc…
                                      • da_Woody
                                        @guitardoc also im prinzip so wie ich ioB und die shelly cloud verwende... ok, ich hab da noch iQontrol als visu. ja, die alexa tusse treibt sich auch in diversen ecken hier rum...
                                        klappert aber auch in timbuktu, wenns dort inet zugang gibt.
                                        aber gut, ich bin apfel verweigerer, hab nur ein kleines macbook als spielerei und für kleinigkeiten unterwegs.
                                        532
