    4. Performance verbessern
      toki1973 @arteck last edited by
      Die Verzeichnisse sind korrekt:
                              v.2023-10-10
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-16-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.14.0-0-g155821a1990b-prebuilt.qemu.org
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               amd64
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      X-Server:               false
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                              /usr/bin/node           v18.19.0
      /home/iobroker/.diag.sh: line 488: npm: command not found
      /home/iobroker/.diag.sh: line 489: npx: command not found
      /home/iobroker/.diag.sh: line 490: corepack: command not found
      Recommended versions are nodejs  Unable to enable Expiry Keyspace events from Redis Server: Connection is closed.
       Connection is closed. and npm
      *** nodejs is NOT correctly installed ***
      Wrong installation path detected. This needs to be fixed.
      Please check
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      for more information on how to fix these errors.
      MEMORY:
      Mem:            6.3G        3.7G        1.4G        524K        1.5G        2.6G
      Swap:           1.0G        3.2M        1.0G
      Total:          7.4G        3.7G        2.4G
      Active iob-Instances:   35
      Active repo(s): stable
      ioBroker Core:          js-controller           5.0.17
                              admin                   6.12.0
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.web-speedy.0             : web-speedy            : iobroker                                 - disabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.web.1                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                118184
      States:                 91554
      Size of iob-Database:
      82M     /opt/iobroker/iobroker-data/objects.jsonl
      152M    /opt/iobroker/iobroker-data/states.jsonl
      • mcm1957
        mcm1957 @arteck last edited by
        @arteck
        a) schrieb ich GAB
        b) weiss ich nicht ob dieser user im latest unterwegs ist und den Performanceeinfluss gab es schon vor dem fehlerhaften Update mit der aktuellem stable - zumindest gab es es ein7ge (wenige) diesbezügliche Meldungen / Vermutungen. Da das testweise deaktivieren kaium Azfwand darstellt ist ein diesbezüglicher Test m.E. sinnvoll.
        Und ja
        Das fehlerhafte Update mit massivstem Einfluss wurde super rasch korrigiert. 1a Reaktion - besser gegrs nicht. Aber wie geschrueben betrifft das derzeit die latest Schiene.
          Homoran Global Moderator Administrators @toki1973 last edited by Homoran
          @toki1973 sagte in Performance verbessern:
          bitte eigenen Thread aufmachen, wenn nach lesen der angepinnten Ankündigungen noch fragen sind.
          Die wichtigen Infos stehen auch nicht in der Summary.
          EDIT: Ist ja schon dein Thread, sorry!
          aber ich hatte ja nach full gefragt
            Thomas Braun Most Active @toki1973 last edited by
            Schon. Für nodejs und node jedenfalls. Dafür fehlt dir npm, npx und corepack komplett.
            Da wirst du dir die dfsg-Version des Pakets 'nodejs' eingehandelt haben.
            Siehe:
            https://forum.iobroker.net/topic/71478/plötzliche-probleme-durch-nodejs-dfsg-version-npm-fehlt
            T 1 Reply Last reply Reply Quote 2
              toki1973 @Thomas Braun last edited by
              @thomas-braun Vielen Dank mal wieder! Auf diesem Weg wurde es repariert!
              Das ist der Nachteil von regelmäßigen Updates 🙂
                In dem Fall ist es aber kein 'Fehler' gewesen, denn dein Paketmanager hat genau das getan, was er tun soll: Die aktuellste Version die in den Repos bereitgestellt wird einspielen. Das die dfsg-Version nicht die für den ioBroker passende Variante darstellt kann der nicht wissen.
                  sunny9999 last edited by sunny9999
                  Hi an alle,
                  hab hier auch nochmal ein Thema bzgl. Performance.....mein System müsste anhand der Hardware und den in der VM gegebenen Ressourcen deutlich leistungsfähiger sein, der Aufruf z.b. der Objekte oder anderer Seiten im Browser ist manchmal sehr zäh......
                  Alles ist auf Redis am laufen ( Objekte und States)
                  Anbindung an die VM ist mit 10Gb
                  Iobroker VM auf ESXi 7 am laufen mit folgenden Specs :
                  Dual Socket System mit 16 Cores
                  16 GB Ram
                  Iobroker Diag Full Summary sieht wie folgt aus :
                                          v.2023-10-10
                   Static hostname: IOBROKER-MASTER
                           Chassis: vm 🖴
                    Virtualization: vmware
                            Kernel: Linux 6.1.0-17-amd64
                   Hardware Vendor: VMware, Inc.
                    Hardware Model: VMware Virtual Platform
                  Firmware Version: 6.00
                  Installation:           vmware
                  Kernel:                 x86_64
                  Userland:               amd64
                  User-ID:                1000
                  X-Server:               false
                  Pending OS-Updates:     17
                  Pending iob updates:    1
                                          /usr/bin/npm            10.2.3
                                          /usr/bin/npx            10.2.3
                                          /usr/bin/corepack       0.22.0
                  Recommended versions are nodejs 18.19.0 and npm 10.2.3
                  MEMORY:
                  Mem:             12G        8.0G        1.2G        3.2M        3.6G        4.5G
                  Swap:           2.1G        285M        1.9G
                  Total:           14G        8.3G        3.0G
                  Active iob-Instances:   76
                                          admin                   6.13.16
                  At least one iobroker host is running.
                  Objects type: redis
                  States  type: redis
                  + system.adapter.admin.0                  : admin                 : IOBROKER-MASTER                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.web.0                    : web                   : IOBROKER-MASTER                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.webcal.0                 : webcal                : IOBROKER-MASTER                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  Objects:                56453
                  States:                 48398
                  46M     /opt/iobroker/iobroker-data/objects.jsonl
                  22M     /opt/iobroker/iobroker-data/objects.json.migrated
                  22M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                  612K    /opt/iobroker/iobroker-data/states.json
                  260K    /opt/iobroker/iobroker-data/states.json.bak
                  Paar krumme "Hunde" mit drin, aber daran kann es ja nicht liegen oder ?
                  BTW : Kann nicht das volle Log posten , da immer ne Meldung kommt " payload too large" .......komisch, Server überlastet ?
                  Danke für ne helping hand.......
                  Sunny
                    Thomas Braun Most Active @sunny9999 last edited by Thomas Braun
                    @sunny9999
                    Naja, 76 laufende Instanzen halten auch vermeintliche Dickschiffe auf Trab. Stichwort i/o-Last.
                      sunny9999 @Thomas Braun last edited by
                      Ja ist mir bewusst.....
                      was wäre Deine Empfehlung ?
                      Ram Auslastung und CPU Auslastung auf dem ESXI sieht eigentlich alles gut aus, da ist nichts am Limit...
                      Idee ?
                      Grüße und Danke
                      Sunny
                        Homoran Global Moderator Administrators @sunny9999 last edited by
                        @sunny9999 sagte in Performance verbessern:
                        und bei top?
                          sunny9999 @Homoran last edited by
                          Full Diag sieht so aus :
                          Skript v.2023-10-10
                          *** BASE SYSTEM ***
                                   Chassis: vm 🖴
                          model name      : Intel(R) Xeon(R) Gold 6152 CPU @ 2.10GHz
                          Docker          : false
                          Virtualization  : vmware
                          Kernel          : x86_64
                          Userland        : amd64
                          Systemuptime and Load:
                           18:54:06 up 25 days, 10:19,  1 user,  load average: 0.28, 0.29, 0.34
                          CPU threads: 16
                          *** Time and Time Zones ***
                                         Local time: Tue 2024-02-06 18:54:07 CET
                                     Universal time: Tue 2024-02-06 17:54:07 UTC
                                           RTC time: Tue 2024-02-06 17:54:07
                                        NTP service: active
                                    RTC in local TZ: no
                          *** User and Groups ***
                          debian
                          /home/debian
                          debian cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner iobroker
                          *** X-Server-Setup ***
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:             12G        8.2G        1.2G        3.2M        3.4G        4.4G
                          Swap:           2.1G        296M        1.8G
                          Total:           14G        8.5G        3.1G
                                  11926 M total memory
                                   7776 M used memory
                                   1345 M active memory
                                   8112 M inactive memory
                                   1179 M free memory
                                    403 M buffer memory
                                   2883 M swap cache
                                   2043 M total swap
                                    283 M used swap
                                   1760 M free swap
                          *** FAILED SERVICES ***
                            UNIT            LOAD   ACTIVE SUB    DESCRIPTION
                          * apcupsd.service loaded failed failed UPS power management daemon
                          LOAD   = Reflects whether the unit definition was properly loaded.
                          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                          SUB    = The low-level unit activation state, values depend on unit type.
                          1 loaded units listed.
                          *** FILESYSTEM ***
                          Filesystem                                                               Type      Size  Used Avail Use% Mounted on
                          udev        devtmpfs  5.8G     0  5.8G   0% /dev
                          tmpfs        tmpfs     1.2G  1.5M  1.2G   1% /run
                          /dev/mapper/debian10--vg-root                                            ext4      107G   43G   59G  42% /
                          tmpfs        tmpfs     5.9G     0  5.9G   0% /dev/shm
                          tmpfs        tmpfs     5.0M     0  5.0M   0% /run/lock
                          /dev/sda1        ext2      234M  128M   95M  58% /boot
                          /dev/mapper/debian10--vg-tmp                                             ext4      1.2G  144K  1.1G   1% /tmp
                          /dev/mapper/debian10--vg-home                                            ext4       70G  8.6G   58G  13% /home
                          /dev/mapper/debian10--vg-var                                             ext4      6.4G  1.9G  4.1G  32% /var
                          tmpfs        tmpfs     1.2G   68K  1.2G   1% /run/user/116
                          192.168.10.47:/volume1/IOBROKER                                          nfs4      2.7T  1.6T  1.1T  61% /mnt/IOBROKERDATA
                          192.168.10.47:/volume2/Backup                                            nfs4      1.9T  499G  1.4T  26% /mnt/BACKUP
                          192.168.10.47:/volume2/photo/PROJEKTBILDER/Situationen/Diashow-MonitorPi nfs4      1.9T  499G  1.4T  26% /mnt/photosyno
                          tmpfs        tmpfs     1.2G   60K  1.2G   1% /run/user/1000
                          [Fri Jan 12 08:34:47 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Quota mode: none.
                          [Fri Jan 12 08:34:48 2024] EXT4-fs (dm-0): re-mounted. Quota mode: none.
                          [Fri Jan 12 08:34:49 2024] EXT4-fs (sda1): mounting ext2 file system using the ext4 subsystem
                          [Fri Jan 12 08:34:49 2024] EXT4-fs (sda1): mounted filesystem without journal. Quota mode: none.
                          [Fri Jan 12 08:34:49 2024] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Quota mode: none.
                          [Fri Jan 12 08:34:49 2024] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Quota mode: none.
                          [Fri Jan 12 08:34:49 2024] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Quota mode: none.
                          TARGET              SOURCE        FSTYPE OPTIONS
                          /                   /dev/mapper/debian10--vg-root                                            ext4   rw,relatime,errors=remount-ro
                          |-/boot             /dev/sda1        ext2   rw,relatime
                          |-/tmp              /dev/mapper/debian10--vg-tmp                                             ext4   rw,relatime
                          |-/home             /dev/mapper/debian10--vg-home                                            ext4   rw,relatime
                          |-/var              /dev/mapper/debian10--vg-var                                             ext4   rw,relatime
                          |-/mnt/IOBROKERDATA 192.168.10.47:/volume1/IOBROKER                                          nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
                          |-/mnt/BACKUP       192.168.10.47:/volume2/Backup                                            nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
                          `-/mnt/photosyno    192.168.10.47:/volume2/photo/PROJEKTBILDER/Situationen/Diashow-MonitorPi nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
                          /var:
                          1.9G    /var/
                          1.5G    /var/lib
                          525M    /var/lib/grafana
                          520M    /var/lib/grafana/plugins
                          516M    /var/lib/grafana/plugins/grafana-image-renderer
                          Archived and active journals take up 11.1M in the file system.
                          /opt/iobroker/backups:
                          1.8G    /opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          31G     /opt/iobroker/iobroker-data/
                          30G     /opt/iobroker/iobroker-data/history
                          947M    /opt/iobroker/iobroker-data/files
                          195M    /opt/iobroker/iobroker-data/backup-objects
                          176M    /opt/iobroker/iobroker-data/files/vis-2
                          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                          24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                          24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                          USB-Devices by-id:
                          *** NodeJS-Installation ***
                          /usr/bin/npm            10.2.3
                          /usr/bin/npx            10.2.3
                          nodejs:
                            Installed: 18.19.0-1nodesource1
                            Candidate: 18.19.0-1nodesource1
                            Version table:
                               18.19.0+dfsg-6~deb12u1 500
                                  500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                           *** 18.19.0-1nodesource1 1001
                                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                  100 /var/lib/dpkg/status
                               18.18.2-1nodesource1 1001
                               18.18.1-1nodesource1 1001
                               18.18.0-1nodesource1 1001
                               18.17.1-1nodesource1 1001
                               18.17.0-1nodesource1 1001
                               18.16.1-1nodesource1 1001
                               18.16.0-1nodesource1 1001
                               18.15.0-1nodesource1 1001
                               18.14.2-1nodesource1 1001
                               18.14.1-1nodesource1 1001
                               18.14.0-1nodesource1 1001
                               18.13.0+dfsg1-1 500
                                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
                               18.13.0-1nodesource1 1001
                               18.12.0-1nodesource1 1001
                               18.11.0-1nodesource1 1001
                               18.10.0-1nodesource1 1001
                               18.9.1-1nodesource1 1001
                               18.9.0-1nodesource1 1001
                               18.8.0-1nodesource1 1001
                               18.7.0-1nodesource1 1001
                               18.6.0-1nodesource1 1001
                               18.5.0-1nodesource1 1001
                               18.4.0-1nodesource1 1001
                               18.3.0-1nodesource1 1001
                               18.2.0-1nodesource1 1001
                               18.1.0-1nodesource1 1001
                               18.0.0-1nodesource1 1001
                          No problems detected
                          Errors in npm tree:
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: redis
                          States  type: redis
                          Core adapters versions
                          js-controller:  5.0.17
                          admin:          6.13.16
                          javascript:     7.1.6
                          Adapters from github:   21
                          Adapter State
                          + system.adapter.alarm.0                  : alarm                 : IOBROKER-MASTER                          -  enabled
                          + system.adapter.alexa2.0                 : alexa2                : IOBROKER-MASTER                          -  enabled
                            system.adapter.alias-manager.0          : alias-manager         : IOBROKER-MASTER                          -  enabled
                            system.adapter.apcups.0                 : apcups                : IOBROKER-MASTER                          - disabled
                          + system.adapter.asterisk.0               : asterisk              : IOBROKER-MASTER                          -  enabled, port: 5038
                          + system.adapter.backitup.0               : backitup              : IOBROKER-MASTER                          -  enabled
                          + system.adapter.backitup.1               : backitup              : IOBROKER-SLAVE                           -  enabled
                          + system.adapter.chromecast.0             : chromecast            : IOBROKER-MASTER                          -  enabled
                            system.adapter.daswetter.0              : daswetter             : IOBROKER-MASTER                          -  enabled
                            system.adapter.device-watcher.0         : device-watcher        : IOBROKER-MASTER                          - disabled
                            system.adapter.devices.0                : devices               : IOBROKER-MASTER                          -  enabled
                          + system.adapter.discovery.0              : discovery             : IOBROKER-MASTER                          -  enabled
                            system.adapter.dwd.0                    : dwd                   : IOBROKER-MASTER                          -  enabled
                          + system.adapter.echarts.0                : echarts               : IOBROKER-MASTER                          -  enabled
                          + system.adapter.email.0                  : email                 : IOBROKER-MASTER                          -  enabled
                            system.adapter.feiertage.0              : feiertage             : IOBROKER-MASTER                          -  enabled
                            system.adapter.flot.0                   : flot                  : IOBROKER-MASTER                          -  enabled
                          + system.adapter.fullybrowser.0           : fullybrowser          : IOBROKER-MASTER                          -  enabled
                          + system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : IOBROKER-MASTER                          -  enabled
                          + system.adapter.govee-app.0              : govee-app             : IOBROKER-MASTER                          -  enabled
                          + system.adapter.ham.0                    : ham                   : IOBROKER-MASTER                          -  enabled
                          + system.adapter.hass.0                   : hass                  : IOBROKER-MASTER                          -  enabled, port: 8123
                            system.adapter.heatingcontrol.0         : heatingcontrol        : IOBROKER-MASTER                          - disabled
                            system.adapter.hiob.0                   : hiob                  : IOBROKER-MASTER                          - disabled
                          + system.adapter.history.0                : history               : IOBROKER-MASTER                          -  enabled
                          + system.adapter.hm-rega.0                : hm-rega               : IOBROKER-MASTER                          -  enabled
                          + system.adapter.hm-rpc.0                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
                          + system.adapter.hm-rpc.1                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
                          + system.adapter.hm-rpc.2                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
                          + system.adapter.hue.0                    : hue                   : IOBROKER-MASTER                          -  enabled, port: 80
                            system.adapter.husq-automower.0         : husq-automower        : IOBROKER-MASTER                          - disabled
                            system.adapter.ical.0                   : ical                  : IOBROKER-MASTER                          -  enabled
                            system.adapter.ical.1                   : ical                  : IOBROKER-MASTER                          -  enabled
                            system.adapter.ical.2                   : ical                  : IOBROKER-MASTER                          -  enabled
                            system.adapter.icons-material-png.0     : icons-material-png    : IOBROKER-MASTER                          -  enabled
                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : IOBROKER-MASTER                          -  enabled
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IOBROKER-MASTER                          -  enabled
                            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : IOBROKER-MASTER                          -  enabled
                          + system.adapter.influxdb.0               : influxdb              : IOBROKER-MASTER                          -  enabled, port: 8086
                            system.adapter.info.0                   : info                  : IOBROKER-MASTER                          - disabled
                          + system.adapter.javascript.0             : javascript            : IOBROKER-MASTER                          -  enabled
                          + system.adapter.kodi.0                   : kodi                  : IOBROKER-MASTER                          -  enabled, port: 9090
                          + system.adapter.linkeddevices.0          : linkeddevices         : IOBROKER-MASTER                          -  enabled
                          + system.adapter.linktap.0                : linktap               : IOBROKER-MASTER                          -  enabled
                          + system.adapter.linux-control.0          : linux-control         : IOBROKER-MASTER                          -  enabled
                          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IOBROKER-MASTER                          -  enabled, port: 54321
                          + system.adapter.mqtt-client.0            : mqtt-client           : IOBROKER-MASTER                          -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.mqtt.0                   : mqtt                  : IOBROKER-MASTER                          -  enabled, port: 1883, bind: 0.0.0.0
                            system.adapter.mytime.0                 : mytime                : IOBROKER-MASTER                          - disabled
                          + system.adapter.net-tools.0              : net-tools             : IOBROKER-MASTER                          -  enabled
                            system.adapter.netatmo-crawler.0        : netatmo-crawler       : IOBROKER-MASTER                          -  enabled
                          + system.adapter.node-red.0               : node-red              : IOBROKER-MASTER                          -  enabled, port: 1880, bind: 0.0.0.0
                          + system.adapter.notificationforandroidtv.0: notificationforandroidtv: IOBROKER-MASTER                          -  enabled
                          + system.adapter.nuki-extended.0          : nuki-extended         : IOBROKER-MASTER                          -  enabled
                            system.adapter.oasecontrol.0            : oasecontrol           : IOBROKER-MASTER                          - disabled
                          + system.adapter.ocpp.0                   : ocpp                  : IOBROKER-MASTER                          -  enabled, port: 9220
                          + system.adapter.onkyo.0                  : onkyo                 : IOBROKER-MASTER                          -  enabled
                            system.adapter.onvif.0                  : onvif                 : IOBROKER-MASTER                          - disabled
                          + system.adapter.ping.0                   : ping                  : IOBROKER-MASTER                          -  enabled
                          + system.adapter.pushover.0               : pushover              : IOBROKER-MASTER                          -  enabled
                          + system.adapter.reolink.0                : reolink               : IOBROKER-MASTER                          -  enabled
                          + system.adapter.robonect.0               : robonect              : IOBROKER-MASTER                          -  enabled
                          + system.adapter.samsung.0                : samsung               : IOBROKER-MASTER                          -  enabled
                            system.adapter.samsung_tizen.0          : samsung_tizen         : IOBROKER-MASTER                          - disabled, port: 8002
                          + system.adapter.sayit.0                  : sayit                 : IOBROKER-MASTER                          -  enabled
                          + system.adapter.scenes.0                 : scenes                : IOBROKER-MASTER                          -  enabled
                          + system.adapter.scheduler.0              : scheduler             : IOBROKER-MASTER                          -  enabled
                          + system.adapter.shelly.0                 : shelly                : IOBROKER-MASTER                          -  enabled, port: 1882, bind: 0.0.0.0
                            system.adapter.shuttercontrol.0         : shuttercontrol        : IOBROKER-MASTER                          - disabled
                          + system.adapter.simple-api.0             : simple-api            : IOBROKER-MASTER                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                          + system.adapter.slideshow.0              : slideshow             : IOBROKER-MASTER                          -  enabled
                          + system.adapter.smartcontrol.0           : smartcontrol          : IOBROKER-MASTER                          -  enabled
                            system.adapter.smartmeter.0             : smartmeter            : IOBROKER-SLAVE                           - disabled
                          + system.adapter.smartthings.0            : smartthings           : IOBROKER-MASTER                          -  enabled
                          + system.adapter.sonoff.0                 : sonoff                : IOBROKER-MASTER                          -  enabled, port: 1885, bind: 0.0.0.0
                          + system.adapter.sonos.0                  : sonos                 : IOBROKER-MASTER                          -  enabled
                          + system.adapter.sourceanalytix.0         : sourceanalytix        : IOBROKER-MASTER                          -  enabled
                          + system.adapter.synology.0               : synology              : IOBROKER-MASTER                          -  enabled, port: 5000
                          + system.adapter.tahoma.0                 : tahoma                : IOBROKER-MASTER                          -  enabled
                          + system.adapter.tankerkoenig.0           : tankerkoenig          : IOBROKER-MASTER                          -  enabled
                          + system.adapter.telegram.0               : telegram              : IOBROKER-MASTER                          -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.telegram.1               : telegram              : IOBROKER-MASTER                          -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.telegram.2               : telegram              : IOBROKER-MASTER                          -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.text2command.0           : text2command          : IOBROKER-MASTER                          -  enabled
                          + system.adapter.text2command.1           : text2command          : IOBROKER-MASTER                          -  enabled
                          + system.adapter.time-switch.0            : time-switch           : IOBROKER-MASTER                          -  enabled
                          + system.adapter.trashschedule.0          : trashschedule         : IOBROKER-MASTER                          -  enabled
                            system.adapter.trashschedule.1          : trashschedule         : IOBROKER-MASTER                          - disabled
                          + system.adapter.unifi.0                  : unifi                 : IOBROKER-MASTER                          -  enabled
                            system.adapter.upnp.0                   : upnp                  : IOBROKER-MASTER                          - disabled
                          + system.adapter.vaillant.0               : vaillant              : IOBROKER-MASTER                          -  enabled
                          + system.adapter.vis-2.0                  : vis-2                 : IOBROKER-MASTER                          -  enabled
                            system.adapter.vis-bars.0               : vis-bars              : IOBROKER-MASTER                          -  enabled
                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : IOBROKER-MASTER                          -  enabled
                            system.adapter.vis-colorpicker.0        : vis-colorpicker       : IOBROKER-MASTER                          -  enabled
                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : IOBROKER-MASTER                          -  enabled
                            system.adapter.vis-google-fonts.0       : vis-google-fonts      : IOBROKER-MASTER                          -  enabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IOBROKER-MASTER                          -  enabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : IOBROKER-MASTER                          -  enabled
                          + system.adapter.vis-inventwo.0           : vis-inventwo          : IOBROKER-MASTER                          -  enabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IOBROKER-MASTER                          -  enabled
                            system.adapter.vis-justgage.0           : vis-justgage          : IOBROKER-MASTER                          -  enabled
                            system.adapter.vis-material-advanced.0  : vis-material-advanced : IOBROKER-MASTER                          -  enabled
                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : IOBROKER-MASTER                          -  enabled
                            system.adapter.vis-metro.0              : vis-metro             : IOBROKER-MASTER                          - disabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : IOBROKER-MASTER                          -  enabled
                            system.adapter.vis-weather.0            : vis-weather           : IOBROKER-MASTER                          -  enabled
                            system.adapter.vis.0                    : vis                   : IOBROKER-MASTER                          -  enabled
                          + system.adapter.vw-connect.0             : vw-connect            : IOBROKER-MASTER                          -  enabled
                          + system.adapter.vw-connect.1             : vw-connect            : IOBROKER-MASTER                          -  enabled
                            system.adapter.weatherunderground.0     : weatherunderground    : IOBROKER-MASTER                          -  enabled
                          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IOBROKER-MASTER                          -  enabled
                          + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IOBROKER-MASTER                          -  enabled
                          + system.adapter.yahka.0                  : yahka                 : IOBROKER-MASTER                          -  enabled
                          + system.adapter.zigbee.1                 : zigbee                : IOBROKER-SLAVE                           -  enabled, port: /dev/ttyACM0
                          + system.adapter.zigbee.2                 : zigbee                : IOBROKER-MASTER                          -  enabled, port: tcp://192.168.10.24:6638
                          + instance is alive
                          ioBroker-Repositories
                          Installed ioBroker-Instances
                          Used repository: stable
                          Adapter    "alarm"        : 3.6.0    , installed 3.6.0
                          Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                          Adapter    "apcups"       : 1.0.15   , installed 1.0.15
                          Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
                          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                          Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
                          Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                          Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                          Adapter    "device-watcher": 2.9.6   , installed 2.9.6
                          Adapter    "doorio"       : 2.1.4    , installed 2.1.4
                          Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                          Adapter    "email"        : 1.2.2    , installed 1.2.2
                          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                          Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
                          Adapter    "ham"          : 5.3.1    , installed 5.3.1
                          Adapter    "hass"         : 1.4.0    , installed 1.4.0
                          Adapter    "heatingcontrol": 2.12.3  , installed 2.12.3
                          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                          Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
                          Adapter    "hue"          : 3.10.2   , installed 3.10.2
                          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                          Adapter    "iot"          : 2.0.11   , installed 2.0.11
                          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                          Controller "js-controller": 5.0.17   , installed 5.0.17
                          Adapter    "kodi"         : 3.0.0    , installed 3.0.0
                          Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                          Adapter    "linktap"      : 0.3.0    , installed 0.3.0
                          Adapter    "linux-control": 1.1.5    , installed 1.1.5
                          Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
                          Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                          Adapter    "mpd"          : 1.1.1    , installed 1.1.1
                          Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
                          Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
                          Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                          Adapter    "node-red"     : 5.1.0    , installed 5.1.0
                          Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                          Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
                          Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
                          Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                          Adapter    "onvif"        : 1.1.1    , installed 1.1.1
                          Adapter    "paw"          : 0.3.2    , installed 0.3.2
                          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                          Adapter    "reolink"      : 1.0.3    , installed 1.0.3
                          Adapter    "robonect"     : 1.3.4    , installed 1.3.4
                          Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                          Adapter    "samsung_tizen": 1.0.0    , installed 1.0.0
                          Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                          Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
                          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                          Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
                          Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                          Adapter    "smartthings"  : 0.0.4    , installed 0.1.1
                          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                          Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                          Adapter    "synology"     : 3.0.1    , installed 3.0.1
                          Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
                          Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                          Adapter    "text2command" : 3.0.3    , installed 3.0.3
                          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                          Adapter    "unifi"        : 0.6.7    , installed 0.6.7
                          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                          Adapter    "vaillant"     : 0.1.2    , installed 0.4.0
                          Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
                          Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
                          Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
                          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                          Adapter    "volumio"      : 0.1.2    , installed 0.1.3
                          Adapter    "vw-connect"   : 0.0.67   , installed 0.5.1
                          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
                          Adapter    "web"          : 6.2.3    , installed 6.2.3
                          Adapter    "webcal"       : 1.3.0    , installed 1.1.0  [Updatable]
                          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                          Adapter    "ws"           : 2.5.10   , installed 2.5.10
                          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                          Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                          Objects and States
                          Objects:        56453
                          States:         48398
                          W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
                          W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
                          W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
                          W: Target DEP-11 (main/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
                          W: Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
                          W: Target DEP-11-icons-small (main/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
                          W: Target DEP-11-icons (main/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
                          Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                          Hit:4 https://repos.influxdata.com/debian stable InRelease
                          Hit:5 https://apt.grafana.com stable InRelease
                          Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                          Reading package lists...
                          Pending Updates: 17
                          *** Listening Ports ***
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          65         1/init
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16086      969/sshd: /usr/sbin
                          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       74578738   2501883/node-red
                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       74583578   2502418/io.shelly.0
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       74587586   2502993/io.mqtt.0
                          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       74587587   2502993/io.mqtt.0
                          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       74591520   2502919/io.sonoff.0
                          tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       75512632   2690492/nc
                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          73118439   2210884/cupsd
                          tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      121        18592      1008/asterisk
                          tcp        0      0 192.168.10.16:2001      0.0.0.0:*               LISTEN      1001       74582911   2502463/io.hm-rpc.0
                          tcp        0      0 192.168.10.16:2010      0.0.0.0:*               LISTEN      1001       74595393   2502564/io.hm-rpc.1
                          tcp        0      0 192.168.10.16:9292      0.0.0.0:*               LISTEN      1001       74583000   2502888/io.hm-rpc.2
                          tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      118        74603472   2507490/redis-serve
                          tcp        0      0 127.0.0.1:44949         0.0.0.0:*               LISTEN      122        42316113   250044/plugin_start
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          1711       1/init
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          16088      969/sshd: /usr/sbin
                          tcp6       0      0 :::9220                 :::*                    LISTEN      1001       74585814   2503615/io.ocpp.0
                          tcp6       0      0 :::51989                :::*                    LISTEN      1001       74594491   2502433/io.nuki-ext
                          tcp6       0      0 :::35615                :::*                    LISTEN      1001       74591906   2504296/io.yahka.0
                          tcp6       0      0 :::3000                 :::*                    LISTEN      122        42309336   249599/grafana
                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          73118438   2210884/cupsd
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       74592281   2501830/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       74598671   2504408/io.web.0
                          tcp6       0      0 :::8086                 :::*                    LISTEN      998        22728      1022/influxd
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       74591795   2503730/io.simple-a
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15910      1/init
                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          73118444   2210886/cups-browse
                          udp        0      0 0.0.0.0:42823           0.0.0.0:*                           111        23664      879/avahi-daemon: r
                          udp        0      0 192.168.10.16:1905      0.0.0.0:*                           1001       75515310   2502935/io.sonos.0
                          udp        0      0 0.0.0.0:35072           0.0.0.0:*                           121        22715      1008/asterisk
                          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       74596509   2503080/io.mihome-v
                          udp        0      0 0.0.0.0:4569            0.0.0.0:*                           121        18609      1008/asterisk
                          udp        0      0 0.0.0.0:5060            0.0.0.0:*                           121        18610      1008/asterisk
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       74592712   2503132/io.chromeca
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           111        23662      879/avahi-daemon: r
                          udp6       0      0 :::111                  :::*                                0          22563      1/init
                          udp6       0      0 :::50118                :::*                                111        23665      879/avahi-daemon: r
                          udp6       0      0 :::54441                :::*                                121        22716      1008/asterisk
                          udp6       0      0 :::5353                 :::*                                111        23663      879/avahi-daemon: r
                          2024-02-06 18:54:18.958  - info: ocpp.0 (2503615) Received Status Notification from "/2203020632A.2": Available
                          2024-02-06 18:54:18.964  - info: sourceanalytix.0 (2503761) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.2.lastTransactionConsumption
                          2024-02-06 18:54:18.966  - info: sourceanalytix.0 (2503761) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.2.transactionEndMeter
                          2024-02-06 18:54:19.652  - info: ocpp.0 (2503615) Requesting StatusNotification from "/2203020632A"
                          2024-02-06 18:54:19.769  - debug: ocpp.0 (2503615) {"connectorId":1,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T17:54:19.7116565Z","commandOcpp":"StatusNotification"}
                          2024-02-06 18:54:19.770  - info: ocpp.0 (2503615) Received Status Notification from "/2203020632A.1": Available
                          2024-02-06 18:54:19.929  - debug: ocpp.0 (2503615) {"connectorId":2,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T17:54:19.7116827Z","commandOcpp":"StatusNotification"}
                          2024-02-06 18:54:19.930  - info: ocpp.0 (2503615) Received Status Notification from "/2203020632A.2": Available
                          2024-02-06 18:54:20.726  - info: ocpp.0 (2503615) Requesting MeterValues from "/2203020632A"
                          2024-02-06 18:54:21.798  - info: ocpp.0 (2503615) Sending GetConfiguration to "/2203020632A"
                          2024-02-06 18:54:21.937  - debug: ocpp.0 (2503615) Received configuration from /2203020632A: {"configurationKey":[{"key":"NumberOfConnectors","readonly":true,"value":"2"},{"key":"DownLight","readonly":false,"value":"True"},{"key":"Dimmer","readonly":false,"value":"Low"},{"key":"Schuko","readonly":true,"value":"Off"},{"key":"DefaultIdTag","readonly":false,"value":"999999"},{"key":"DefaultIdTagEnabled","readonly":false,"value":"True"},{"key":"StopTransactionOnEVSideDisconnect","readonly":true,"value":"True"},{"key":"StopTransactionOnInvalidId","readonly":false,"value":"True"},{"key":"MeterValueSampleInterval","readonly":false,"value":"30"},{"key":"HeartbeatInterval","readonly":false,"value":"10"},{"key":"AuthorizeRemoteTxRequests","readonly":true,"value":"True"},{"key":"ClockAlignedDataInterval","readonly":false,"value":"0"},{"key":"ConnectionTimeOut","readonly":false,"value":"60"},{"key":"GetConfigurationMaxKeys","readonly":true,"value":"31"},{"key":"LocalAuthorizeOffline","readonly":false,"value":"True"},{"key":"LocalPreAuthorize","readonly":false,"value":"False"},{"key":"MeterValuesAlignedData","readonly":false,"value":""},{"key":"MeterValuesSampledData","readonly":false,"value":"Voltage,Current.Import,Energy.Active.Import.Register"},{"key":"ResetRetries","readonly":false,"value":"0"},{"key":"StopTxnAlignedData","readonly":false,"value":"False"},{"key":"StopTxnSampledData","readonly":false,"value":"False"},{"key":"TransactionMessageAttempts","readonly":false,"value":"0"},{"key":"TransactionMessageRetryInterval","readonly":false,"value":"0"},{"key":"UnlockConnectorOnEVSideDisconnect","readonly":false,"value":"False"},{"key":"ConnectorPhaseRotation","readonly":false,"value":"NotApplicable"},{"key":"SupportedFeatureProfiles","readonly":true,"value":"Core"},{"key":"AllowOfflineTxForUnknownId","readonly":false,"value":"False"},{"key":"AuthorizationCacheEnabled","readonly":false,"value":"True"},{"key":"AssignedCurrent","readonly":false,"value":"32.00;32.00"},{"key":"AuthorizationKey","readonly":false,"value":""},{"key":"SecurityProfile","readonly":false,"value":"0"}],"unknownKey":[]}
                          2024-02-06 18:54:21.990  - info: ocpp.0 (2503615) Supported profiles by client "/2203020632A" are "Core"
                          2024-02-06 18:54:22.001  - info: ocpp.0 (2503615) Removing SmartCharging functionality as unsupported
                          2024-02-06 18:54:22.009  - info: ocpp.0 (2503615) Removing LocalAuthListManagement functionality as unsupported
                          2024-02-06 18:54:27.560  - info: linktap.0 (2504393) updateWateringStatus started
                          2024-02-06 18:54:28.086  - info: linktap.0 (2504393) Queried watering status for device Ventil-1. Status: 200
                          2024-02-06 18:54:28.588  - info: linktap.0 (2504393) Queried watering status for device Ventil-2. Status: 200
                          2024-02-06 18:54:29.087  - info: linktap.0 (2504393) Queried watering status for device Ventil-3. Status: 200
                          2024-02-06 18:54:29.590  - info: linktap.0 (2504393) Queried watering status for device Ventil-4. Status: 200
                          2024-02-06 18:54:30.091  - info: linktap.0 (2504393) Queried watering status for device Ventil-5. Status: 200
                          2024-02-06 18:54:30.591  - info: linktap.0 (2504393) Queried watering status for device Ventil-6. Status: 200
                          2024-02-06 18:54:30.592  - info: linktap.0 (2504393) updateWateringStatus finished
                          2024-02-06 18:54:30.720  - info: javascript.0 (2501928) script.js.common.Diverses.BatterieUeberwachung185: Reaching CheckDeadBatt()
                          2024-02-06 18:54:30.722  - info: javascript.0 (2501928) script.js.common.Diverses.BatterieUeberwachung185: Reaching MakeTable
                          2024-02-06 18:54:30.726  - info: javascript.0 (2501928) script.js.common.Diverses.BatterieUeberwachung185: Reaching MakeJSONTable
                          Top sieht so aus :
                          top - 18:58:10 up 25 days, 10:23,  1 user,  load average: 0.47, 0.44, 0.39
                          Tasks: 420 total,   1 running, 419 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):   1.0/0.5     1[|        ]
                          MiB Mem :  11926.7 total,    930.9 free,   8022.1 used,   3290.3 buff/cache
                          MiB Swap:   2044.0 total,   1761.0 free,    283.0 used.   3904.6 avail Mem
                              PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                          2502494 iobroker  20   0  970908 115660  39628 S   5.9   0.9   0:33.15 io.alexa2.0
                          2502418 iobroker  20   0  718700 119496  38512 S   3.0   1.0   9:29.04 io.shelly.0
                          2507490 redis     20   0 2380112 956748   8916 S   2.6   7.8  25:35.59 redis-server
                          2501928 iobroker  20   0 1228744 348208  45036 S   2.3   2.9  26:04.94 io.javascript.0
                          2501985 iobroker  20   0 1026816 164916  38276 S   1.7   1.4   9:44.20 io.influxdb.0
                          2501872 iobroker  20   0  889924 156760  38196 S   1.0   1.3   9:43.59 io.history.0
                          2502388 iobroker  20   0  677664 104916  38476 S   1.0   0.9   8:04.91 io.kodi.0
                          2503052 iobroker  20   0   10.7g 112432  40076 S   1.0   0.9   1:53.66 io.synology.0
                             1008 asterisk -11   0 5204544  35892  20324 S   0.7   0.3 312:22.63 asterisk
                             1338 Debian-+  20   0 6338796 107844  35444 S   0.7   0.9  63:55.86 gnome-shell
                          2692777 debian    20   0   11648   5448   3296 R   0.7   0.0   0:00.55 top
                              802 root      20   0  241528   9844   6408 S   0.3   0.1  47:58.63 vmtoolsd
                           249599 grafana   20   0 1677572 128360  51340 S   0.3   1.1  24:23.42 grafana
                           250044 grafana   20   0  664160  61604  14420 S   0.3   0.5  72:02.49 plugin_start_li
                          2501812 iobroker  20   0   11.1g 282464  45948 S   0.3   2.3   2:25.60 iobroker.js-con
                          2501894 iobroker  20   0 1004340 131644  44840 S   0.3   1.1   1:03.47 io.telegram.2
                          2501913 iobroker  20   0  687568  79528  38324 S   0.3   0.7   0:13.81 io.email.0
                          2502001 iobroker  20   0 1003480 123116  39248 S   0.3   1.0   1:03.21 io.telegram.0
                          2502018 iobroker  20   0  687428  81080  38204 S   0.3   0.7   0:13.52 io.pushover.0
                          2502357 iobroker  20   0 1005648 130384  44844 S   0.3   1.1   1:03.65 io.telegram.1
                          2502510 iobroker  20   0  698448  92956  38472 S   0.3   0.8   0:19.54 io.hass.0
                          2502935 iobroker  20   0  686568  81752  38264 S   0.3   0.7   0:33.03 io.sonos.0
                          2502993 iobroker  20   0  773696  98832  38352 S   0.3   0.8   0:28.60 io.mqtt.0
                          2503080 iobroker  20   0  693196  88192  38196 S   0.3   0.7   0:29.98 io.mihome-vacuu
                          2503148 iobroker  20   0  690772  83992  38244 S   0.3   0.7   1:53.38 io.net-tools.0
                          2503429 iobroker  20   0  737980 112192  38280 S   0.3   0.9   0:50.42 io.mqtt-client.
                          2504296 iobroker  20   0  760992  93404  39180 S   0.3   0.8   0:58.30 io.yahka.0
                          2504393 iobroker  20   0  958140  93000  39352 S   0.3   0.8   1:01.79 io.linktap.0
                          2662239 root      20   0       0      0      0 I   0.3   0.0   0:03.22 kworker/9:0-events
                                1 root      20   0  169580  12604   7964 S   0.0   0.1   0:34.39 systemd
                                2 root      20   0       0      0      0 S   0.0   0.0   0:04.01 kthreadd
                                3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
                                4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par_gp
                                5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 slub_flushwq
                                6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 netns
                                8 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/0:0H-events_highpri
                               10 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 mm_percpu_wq
                               11 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_kthread
                               12 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_rude_kthread
                               13 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_trace_kthread
                               14 root      20   0       0      0      0 S   0.0   0.0   0:23.37 ksoftirqd/0
                          Da steht oben immer ein anderer Wert drin , je nach dem alle mit io.XXXX , aber nur so um die 9% bis max 30%
                            achwas 🙂
                            aber hiet
                            ist kein Hinweis auf Überlastung durch I/O oder Prozesse
                              @sunny9999
                              Deine .list-Files für influxdb sind komplett chaotisch. Hat aber nix mit deinem 'Problem' direkt zu tun.
                              Und wozu brauchst du die gnome-shell?
                                keine Ahnung wo die herkommt........kann man die deinstallieren und wenn ja wie ? wenns was bringt.......
                                Idee wie ich die Influxdb .list files hinbiegen kann ? ( nur so am Rande).......
                                  @sunny9999 was machst du mit den mounts?
                                  rauschen da die Daten dauerhaft und viel durch?
                                  bei diashow werde ich auch hellhörig
                                    die mounts sind nur für Backups.....die slideshow läuft nicht, war mal ein Versuch, danke für den Hinweis schon fast vergessen....jetzt disabled....
                                      sudo rm /etc/apt/sources.list.d/influx*
                                      wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                      echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                                      echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                      rm influxdata-archive_compat.key
                                      sudo apt update
                                      sudo apt full-upgrade
                                      Setz den user 'debian' in die Gruppe 'adm':
                                      sudo usermod -a -G adm debian
                                      sudo systemctl set-default multi-user.target
                                      sudo reboot
                                      Was ist denn mit dem los?
                                        @thomas-braun sagte in Performance verbessern:
                                        Top Vielen Dank !
                                        das war mal ein daemon für ne apc usv .....die hing damals als Server im Netz, weiss nur nicht wie ich die wieder deinstallieren kann, weisst du das ?
                                        Alles so gemacht.....iob diag sieht nun wie folgt aus :
                                        Skript v.2023-10-10
                                        *** BASE SYSTEM ***
                                                 Chassis: vm 🖴
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : amd64
                                         19:36:28 up 8 min,  1 user,  load average: 0.74, 1.27, 0.75
                                        CPU threads: 16
                                                       Local time: Tue 2024-02-06 19:36:28 CET
                                                   Universal time: Tue 2024-02-06 18:36:28 UTC
                                                         RTC time: Tue 2024-02-06 18:36:28
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        debian
                                        /home/debian
                                        debian adm cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner iobroker
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        Boot Target:    multi-user.target
                                        *** MEMORY ***
                                        Mem:             12G        6.2G        4.5G        1.4M        2.1G        6.3G
                                        Swap:           2.1G          0B        2.1G
                                        Total:           14G        6.2G        6.6G
                                                 5937 M used memory
                                                  505 M active memory
                                                 6580 M inactive memory
                                                 4246 M free memory
                                                  136 M buffer memory
                                                 1892 M swap cache
                                                 2043 M total swap
                                                    0 M used swap
                                                 2043 M free swap
                                        *** FILESYSTEM ***
                                        tmpfs        tmpfs     1.2G  1.3M  1.2G   1% /run
                                        /dev/mapper/debian10--vg-root                                            ext4      107G   43G   60G  42% /
                                        /dev/mapper/debian10--vg-tmp                                             ext4      1.2G  116K  1.1G   1% /tmp
                                        /dev/mapper/debian10--vg-var                                             ext4      6.4G  2.0G  4.0G  34% /var
                                        [Tue Feb  6 19:27:39 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Tue Feb  6 19:27:40 2024] EXT4-fs (dm-0): re-mounted. Quota mode: none.
                                        [Tue Feb  6 19:27:41 2024] EXT4-fs (sda1): mounting ext2 file system using the ext4 subsystem
                                        [Tue Feb  6 19:27:41 2024] EXT4-fs (sda1): mounted filesystem without journal. Quota mode: none.
                                        [Tue Feb  6 19:27:41 2024] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Tue Feb  6 19:27:41 2024] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Quota mode: none.
                                        [Tue Feb  6 19:27:41 2024] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Quota mode: none.
                                        `-/mnt/IOBROKERDATA 192.168.10.47:/volume1/IOBROKER                                          nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
                                        /var:
                                        2.0G    /var/
                                        1.5G    /var/lib
                                        Archived and active journals take up 85.3M in the file system.
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                                        nodejs:
                                          Version table:
                                             18.13.0+dfsg1-1 500
                                        Errors in npm tree:
                                        ioBroker Status
                                        Objects type: redis
                                        States  type: redis
                                        admin:          6.13.16
                                        javascript:     7.1.6
                                        Adapter State
                                          system.adapter.slideshow.0              : slideshow             : IOBROKER-MASTER                          - disabled
                                        + instance is alive
                                        Objects and States
                                        Objects:        56453
                                        States:         48433
                                        Hit:4 https://apt.grafana.com stable InRelease
                                        Hit:5 https://repos.influxdata.com/debian stable InRelease
                                        Pending Updates: 0
                                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15837      2046/io.shelly.0
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       15786      1951/io.mqtt.0
                                        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       14320      1673/node-red
                                        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       15787      1951/io.mqtt.0
                                        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       26969      1916/io.sonoff.0
                                        tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       55666      6053/nc
                                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          23748      934/cupsd
                                        tcp        0      0 192.168.10.16:9292      0.0.0.0:*               LISTEN      1001       25253      2066/io.hm-rpc.2
                                        tcp        0      0 192.168.10.16:2010      0.0.0.0:*               LISTEN      1001       19362      2317/io.hm-rpc.1
                                        tcp        0      0 192.168.10.16:2001      0.0.0.0:*               LISTEN      1001       17928      2299/io.hm-rpc.0
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13258      943/sshd: /usr/sbin
                                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14049      1/init
                                        tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      121        15631      969/asterisk
                                        tcp        0      0 127.0.0.1:40241         0.0.0.0:*               LISTEN      122        35029      1280/plugin_start_l
                                        tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      118        20140      2535/redis-server 0
                                        tcp6       0      0 :::9220                 :::*                    LISTEN      1001       20418      3039/io.ocpp.0
                                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          23747      934/cupsd
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          13260      943/sshd: /usr/sbin
                                        tcp6       0      0 :::111                  :::*                    LISTEN      0          16407      1/init
                                        tcp6       0      0 :::51989                :::*                    LISTEN      1001       15044      2284/io.nuki-extend
                                        tcp6       0      0 :::3000                 :::*                    LISTEN      122        14218      1239/grafana
                                        tcp6       0      0 :::38891                :::*                    LISTEN      1001       32649      2497/io.yahka.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38416      2882/io.web.0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       32148      1304/io.admin.0
                                        tcp6       0      0 :::8086                 :::*                    LISTEN      998        35014      981/influxd
                                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       24244      2692/io.simple-api.
                                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          28072      1/init
                                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          28194      986/cups-browsed
                                        udp        0      0 192.168.10.16:1905      0.0.0.0:*                           1001       62557      2195/io.sonos.0
                                        udp        0      0 0.0.0.0:60858           0.0.0.0:*                           121        33541      969/asterisk
                                        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       15909      2165/io.mihome-vacu
                                        udp        0      0 0.0.0.0:4569            0.0.0.0:*                           121        15648      969/asterisk
                                        udp        0      0 0.0.0.0:45969           0.0.0.0:*                           111        31874      870/avahi-daemon: r
                                        udp        0      0 0.0.0.0:5060            0.0.0.0:*                           121        15649      969/asterisk
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22049      1853/io.chromecast.
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           111        31872      870/avahi-daemon: r
                                        udp6       0      0 :::111                  :::*                                0          17472      1/init
                                        udp6       0      0 :::44160                :::*                                121        33542      969/asterisk
                                        udp6       0      0 :::5353                 :::*                                111        31873      870/avahi-daemon: r
                                        udp6       0      0 :::46869                :::*                                111        31875      870/avahi-daemon: r
                                        2024-02-06 19:36:45.696  - debug: ocpp.0 (3039) {"chargePointSerialNumber":"2203020632A","chargePointModel":"Aura T2 outlet","chargePointVendor":"Charge Amps","firmwareVersion":"72.2.0.0","iccid":"0","commandOcpp":"BootNotification"}
                                        2024-02-06 19:36:45.696  - info: ocpp.0 (3039) Received boot notification from "/2203020632A"
                                        2024-02-06 19:36:45.813  - debug: ocpp.0 (3039) {"connectorId":1,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T18:36:45.7744021Z","commandOcpp":"StatusNotification"}
                                        2024-02-06 19:36:45.813  - info: ocpp.0 (3039) Received Status Notification from "/2203020632A.1": Available
                                        2024-02-06 19:36:45.821  - info: sourceanalytix.0 (2676) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.1.lastTransactionConsumption
                                        2024-02-06 19:36:45.824  - info: sourceanalytix.0 (2676) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.1.transactionEndMeter
                                        2024-02-06 19:36:45.954  - debug: ocpp.0 (3039) {"connectorId":2,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T18:36:45.7744353Z","commandOcpp":"StatusNotification"}
                                        2024-02-06 19:36:45.954  - info: ocpp.0 (3039) Received Status Notification from "/2203020632A.2": Available
                                        2024-02-06 19:36:45.961  - info: sourceanalytix.0 (2676) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.2.lastTransactionConsumption
                                        2024-02-06 19:36:45.964  - info: sourceanalytix.0 (2676) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.2.transactionEndMeter
                                        2024-02-06 19:36:46.641  - info: ocpp.0 (3039) Requesting StatusNotification from "/2203020632A"
                                        2024-02-06 19:36:46.744  - debug: ocpp.0 (3039) {"connectorId":1,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T18:36:46.7099585Z","commandOcpp":"StatusNotification"}
                                        2024-02-06 19:36:46.745  - info: ocpp.0 (3039) Received Status Notification from "/2203020632A.1": Available
                                        2024-02-06 19:36:46.860  - debug: ocpp.0 (3039) {"connectorId":2,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T18:36:46.7099797Z","commandOcpp":"StatusNotification"}
                                        2024-02-06 19:36:46.860  - info: ocpp.0 (3039) Received Status Notification from "/2203020632A.2": Available
                                        2024-02-06 19:36:47.725  - info: ocpp.0 (3039) Requesting MeterValues from "/2203020632A"
                                        2024-02-06 19:36:48.802  - info: ocpp.0 (3039) Sending GetConfiguration to "/2203020632A"
                                        2024-02-06 19:36:48.945  - debug: ocpp.0 (3039) Received configuration from /2203020632A: {"configurationKey":[{"key":"NumberOfConnectors","readonly":true,"value":"2"},{"key":"DownLight","readonly":false,"value":"True"},{"key":"Dimmer","readonly":false,"value":"Low"},{"key":"Schuko","readonly":true,"value":"Off"},{"key":"DefaultIdTag","readonly":false,"value":"999999"},{"key":"DefaultIdTagEnabled","readonly":false,"value":"True"},{"key":"StopTransactionOnEVSideDisconnect","readonly":true,"value":"True"},{"key":"StopTransactionOnInvalidId","readonly":false,"value":"True"},{"key":"MeterValueSampleInterval","readonly":false,"value":"120"},{"key":"HeartbeatInterval","readonly":false,"value":"10"},{"key":"AuthorizeRemoteTxRequests","readonly":true,"value":"True"},{"key":"ClockAlignedDataInterval","readonly":false,"value":"0"},{"key":"ConnectionTimeOut","readonly":false,"value":"60"},{"key":"GetConfigurationMaxKeys","readonly":true,"value":"31"},{"key":"LocalAuthorizeOffline","readonly":false,"value":"True"},{"key":"LocalPreAuthorize","readonly":false,"value":"False"},{"key":"MeterValuesAlignedData","readonly":false,"value":""},{"key":"MeterValuesSampledData","readonly":false,"value":"Voltage,Current.Import,Energy.Active.Import.Register"},{"key":"ResetRetries","readonly":false,"value":"0"},{"key":"StopTxnAlignedData","readonly":false,"value":"False"},{"key":"StopTxnSampledData","readonly":false,"value":"False"},{"key":"TransactionMessageAttempts","readonly":false,"value":"0"},{"key":"TransactionMessageRetryInterval","readonly":false,"value":"0"},{"key":"UnlockConnectorOnEVSideDisconnect","readonly":false,"value":"False"},{"key":"ConnectorPhaseRotation","readonly":false,"value":"NotApplicable"},{"key":"SupportedFeatureProfiles","readonly":true,"value":"Core"},{"key":"AllowOfflineTxForUnknownId","readonly":false,"value":"False"},{"key":"AuthorizationCacheEnabled","readonly":false,"value":"True"},{"key":"AssignedCurrent","readonly":false,"value":"32.00;32.00"},{"key":"AuthorizationKey","readonly":false,"value":""},{"key":"SecurityProfile","readonly":false,"value":"0"}],"unknownKey":[]}
                                        2024-02-06 19:36:48.992  - info: ocpp.0 (3039) Supported profiles by client "/2203020632A" are "Core"
                                        2024-02-06 19:36:49.000  - info: ocpp.0 (3039) Removing SmartCharging functionality as unsupported
                                        2024-02-06 19:36:49.009  - info: ocpp.0 (3039) Removing LocalAuthListManagement functionality as unsupported
                                        2024-02-06 19:36:57.137  - warn: robonect.0 (1764) No connection to lawn mower (Not able to ping it). Check network connection.
                                        2024-02-06 19:36:58.693  - info: smartcontrol.0 (4396) Trigger [Motion.Buero-2] activated Zone 'BUERO2.Benni+Markus'. However, device(s) 'BUERO2.B+M-Lampe-Decke' not turned on as these are already on.
                                        2024-02-06 19:36:58.693  - info: smartcontrol.0 (4396) Trigger [Motion.Buero-2] Zone 'BUERO2.Benni+Markus': Timer of 240s will be set to turn off once no more motion recognized.
                                        2024-02-06 19:36:58.694  - info: smartcontrol.0 (4396) Trigger [Motion.Buero-2] 'zoneOff' 360s timer still running 329s. We stop it and set new to 360s.
                                          hast du vieles auf debug?
                                          kostet auch Ressourcen
                                            So wie du es auch installiert hast?
                                            Einstweilen kannst du es auch maskieren:
                                            sudo systemctl mask apcupsd.service
                                            1983
