    4. Performance verbessern
      sunny9999 @Thomas Braun last edited by
      Ja ist mir bewusst.....
      was wäre Deine Empfehlung ?
      Ram Auslastung und CPU Auslastung auf dem ESXI sieht eigentlich alles gut aus, da ist nichts am Limit...
      Idee ?
      Grüße und Danke
      Sunny
        Homoran Global Moderator Administrators @sunny9999 last edited by
        @sunny9999 sagte in Performance verbessern:
        und bei top?
          sunny9999 @Homoran last edited by
          Full Diag sieht so aus :
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: IOBROKER-MASTER
                 Icon name: computer-vm
                   Chassis: vm 🖴
            Virtualization: vmware
                    Kernel: Linux 6.1.0-17-amd64
              Architecture: x86-64
           Hardware Vendor: VMware, Inc.
            Hardware Model: VMware Virtual Platform
          Firmware Version: 6.00
          model name      : Intel(R) Xeon(R) Gold 6152 CPU @ 2.10GHz
          Docker          : false
          Virtualization  : vmware
          Kernel          : x86_64
          Userland        : amd64
          Systemuptime and Load:
           18:54:06 up 25 days, 10:19,  1 user,  load average: 0.28, 0.29, 0.34
          CPU threads: 16
          *** Time and Time Zones ***
                         Local time: Tue 2024-02-06 18:54:07 CET
                     Universal time: Tue 2024-02-06 17:54:07 UTC
                           RTC time: Tue 2024-02-06 17:54:07
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          debian
          /home/debian
          debian cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:             12G        8.2G        1.2G        3.2M        3.4G        4.4G
          Swap:           2.1G        296M        1.8G
          Total:           14G        8.5G        3.1G
                  11926 M total memory
                   7776 M used memory
                   1345 M active memory
                   8112 M inactive memory
                   1179 M free memory
                    403 M buffer memory
                   2883 M swap cache
                   2043 M total swap
                    283 M used swap
                   1760 M free swap
          *** FAILED SERVICES ***
            UNIT            LOAD   ACTIVE SUB    DESCRIPTION
          * apcupsd.service loaded failed failed UPS power management daemon
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          1 loaded units listed.
          *** FILESYSTEM ***
          Filesystem                                                               Type      Size  Used Avail Use% Mounted on
          udev        devtmpfs  5.8G     0  5.8G   0% /dev
          tmpfs        tmpfs     1.2G  1.5M  1.2G   1% /run
          /dev/mapper/debian10--vg-root                                            ext4      107G   43G   59G  42% /
          tmpfs        tmpfs     5.9G     0  5.9G   0% /dev/shm
          tmpfs        tmpfs     5.0M     0  5.0M   0% /run/lock
          /dev/sda1        ext2      234M  128M   95M  58% /boot
          /dev/mapper/debian10--vg-tmp                                             ext4      1.2G  144K  1.1G   1% /tmp
          /dev/mapper/debian10--vg-home                                            ext4       70G  8.6G   58G  13% /home
          /dev/mapper/debian10--vg-var                                             ext4      6.4G  1.9G  4.1G  32% /var
          tmpfs        tmpfs     1.2G   68K  1.2G   1% /run/user/116
          192.168.10.47:/volume1/IOBROKER                                          nfs4      2.7T  1.6T  1.1T  61% /mnt/IOBROKERDATA
          192.168.10.47:/volume2/Backup                                            nfs4      1.9T  499G  1.4T  26% /mnt/BACKUP
          192.168.10.47:/volume2/photo/PROJEKTBILDER/Situationen/Diashow-MonitorPi nfs4      1.9T  499G  1.4T  26% /mnt/photosyno
          tmpfs        tmpfs     1.2G   60K  1.2G   1% /run/user/1000
          [Fri Jan 12 08:34:47 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Quota mode: none.
          [Fri Jan 12 08:34:48 2024] EXT4-fs (dm-0): re-mounted. Quota mode: none.
          [Fri Jan 12 08:34:49 2024] EXT4-fs (sda1): mounting ext2 file system using the ext4 subsystem
          [Fri Jan 12 08:34:49 2024] EXT4-fs (sda1): mounted filesystem without journal. Quota mode: none.
          [Fri Jan 12 08:34:49 2024] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Quota mode: none.
          [Fri Jan 12 08:34:49 2024] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Quota mode: none.
          [Fri Jan 12 08:34:49 2024] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Quota mode: none.
          TARGET              SOURCE        FSTYPE OPTIONS
          /                   /dev/mapper/debian10--vg-root                                            ext4   rw,relatime,errors=remount-ro
          |-/boot             /dev/sda1        ext2   rw,relatime
          |-/tmp              /dev/mapper/debian10--vg-tmp                                             ext4   rw,relatime
          |-/home             /dev/mapper/debian10--vg-home                                            ext4   rw,relatime
          |-/var              /dev/mapper/debian10--vg-var                                             ext4   rw,relatime
          |-/mnt/IOBROKERDATA 192.168.10.47:/volume1/IOBROKER                                          nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
          |-/mnt/BACKUP       192.168.10.47:/volume2/Backup                                            nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
          `-/mnt/photosyno    192.168.10.47:/volume2/photo/PROJEKTBILDER/Situationen/Diashow-MonitorPi nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
          /var:
          1.9G    /var/
          1.5G    /var/lib
          525M    /var/lib/grafana
          520M    /var/lib/grafana/plugins
          516M    /var/lib/grafana/plugins/grafana-image-renderer
          Archived and active journals take up 11.1M in the file system.
          /opt/iobroker/backups:
          1.8G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          31G     /opt/iobroker/iobroker-data/
          30G     /opt/iobroker/iobroker-data/history
          947M    /opt/iobroker/iobroker-data/files
          195M    /opt/iobroker/iobroker-data/backup-objects
          176M    /opt/iobroker/iobroker-data/files/vis-2
          46M     /opt/iobroker/iobroker-data/objects.jsonl
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
          24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          /usr/bin/corepack       0.22.0
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
           *** 18.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0+dfsg1-1 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          At least one iobroker host is running.
          Objects type: redis
          States  type: redis
          Core adapters versions
          js-controller:  5.0.17
          admin:          6.13.16
          javascript:     7.1.6
          Adapters from github:   21
          Adapter State
          + system.adapter.admin.0                  : admin                 : IOBROKER-MASTER                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alarm.0                  : alarm                 : IOBROKER-MASTER                          -  enabled
          + system.adapter.alexa2.0                 : alexa2                : IOBROKER-MASTER                          -  enabled
            system.adapter.alias-manager.0          : alias-manager         : IOBROKER-MASTER                          -  enabled
            system.adapter.apcups.0                 : apcups                : IOBROKER-MASTER                          - disabled
          + system.adapter.asterisk.0               : asterisk              : IOBROKER-MASTER                          -  enabled, port: 5038
          + system.adapter.backitup.0               : backitup              : IOBROKER-MASTER                          -  enabled
          + system.adapter.backitup.1               : backitup              : IOBROKER-SLAVE                           -  enabled
          + system.adapter.chromecast.0             : chromecast            : IOBROKER-MASTER                          -  enabled
            system.adapter.daswetter.0              : daswetter             : IOBROKER-MASTER                          -  enabled
            system.adapter.device-watcher.0         : device-watcher        : IOBROKER-MASTER                          - disabled
            system.adapter.devices.0                : devices               : IOBROKER-MASTER                          -  enabled
          + system.adapter.discovery.0              : discovery             : IOBROKER-MASTER                          -  enabled
            system.adapter.dwd.0                    : dwd                   : IOBROKER-MASTER                          -  enabled
          + system.adapter.echarts.0                : echarts               : IOBROKER-MASTER                          -  enabled
          + system.adapter.email.0                  : email                 : IOBROKER-MASTER                          -  enabled
            system.adapter.feiertage.0              : feiertage             : IOBROKER-MASTER                          -  enabled
            system.adapter.flot.0                   : flot                  : IOBROKER-MASTER                          -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : IOBROKER-MASTER                          -  enabled
          + system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : IOBROKER-MASTER                          -  enabled
          + system.adapter.govee-app.0              : govee-app             : IOBROKER-MASTER                          -  enabled
          + system.adapter.ham.0                    : ham                   : IOBROKER-MASTER                          -  enabled
          + system.adapter.hass.0                   : hass                  : IOBROKER-MASTER                          -  enabled, port: 8123
            system.adapter.heatingcontrol.0         : heatingcontrol        : IOBROKER-MASTER                          - disabled
            system.adapter.hiob.0                   : hiob                  : IOBROKER-MASTER                          - disabled
          + system.adapter.history.0                : history               : IOBROKER-MASTER                          -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : IOBROKER-MASTER                          -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
          + system.adapter.hm-rpc.2                 : hm-rpc                : IOBROKER-MASTER                          -  enabled, port: 0
          + system.adapter.hue.0                    : hue                   : IOBROKER-MASTER                          -  enabled, port: 80
            system.adapter.husq-automower.0         : husq-automower        : IOBROKER-MASTER                          - disabled
            system.adapter.ical.0                   : ical                  : IOBROKER-MASTER                          -  enabled
            system.adapter.ical.1                   : ical                  : IOBROKER-MASTER                          -  enabled
            system.adapter.ical.2                   : ical                  : IOBROKER-MASTER                          -  enabled
            system.adapter.icons-material-png.0     : icons-material-png    : IOBROKER-MASTER                          -  enabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : IOBROKER-MASTER                          -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IOBROKER-MASTER                          -  enabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : IOBROKER-MASTER                          -  enabled
          + system.adapter.influxdb.0               : influxdb              : IOBROKER-MASTER                          -  enabled, port: 8086
            system.adapter.info.0                   : info                  : IOBROKER-MASTER                          - disabled
          + system.adapter.javascript.0             : javascript            : IOBROKER-MASTER                          -  enabled
          + system.adapter.kodi.0                   : kodi                  : IOBROKER-MASTER                          -  enabled, port: 9090
          + system.adapter.linkeddevices.0          : linkeddevices         : IOBROKER-MASTER                          -  enabled
          + system.adapter.linktap.0                : linktap               : IOBROKER-MASTER                          -  enabled
          + system.adapter.linux-control.0          : linux-control         : IOBROKER-MASTER                          -  enabled
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IOBROKER-MASTER                          -  enabled, port: 54321
          + system.adapter.mqtt-client.0            : mqtt-client           : IOBROKER-MASTER                          -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mqtt.0                   : mqtt                  : IOBROKER-MASTER                          -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.mytime.0                 : mytime                : IOBROKER-MASTER                          - disabled
          + system.adapter.net-tools.0              : net-tools             : IOBROKER-MASTER                          -  enabled
            system.adapter.netatmo-crawler.0        : netatmo-crawler       : IOBROKER-MASTER                          -  enabled
          + system.adapter.node-red.0               : node-red              : IOBROKER-MASTER                          -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.notificationforandroidtv.0: notificationforandroidtv: IOBROKER-MASTER                          -  enabled
          + system.adapter.nuki-extended.0          : nuki-extended         : IOBROKER-MASTER                          -  enabled
            system.adapter.oasecontrol.0            : oasecontrol           : IOBROKER-MASTER                          - disabled
          + system.adapter.ocpp.0                   : ocpp                  : IOBROKER-MASTER                          -  enabled, port: 9220
          + system.adapter.onkyo.0                  : onkyo                 : IOBROKER-MASTER                          -  enabled
            system.adapter.onvif.0                  : onvif                 : IOBROKER-MASTER                          - disabled
          + system.adapter.ping.0                   : ping                  : IOBROKER-MASTER                          -  enabled
          + system.adapter.pushover.0               : pushover              : IOBROKER-MASTER                          -  enabled
          + system.adapter.reolink.0                : reolink               : IOBROKER-MASTER                          -  enabled
          + system.adapter.robonect.0               : robonect              : IOBROKER-MASTER                          -  enabled
          + system.adapter.samsung.0                : samsung               : IOBROKER-MASTER                          -  enabled
            system.adapter.samsung_tizen.0          : samsung_tizen         : IOBROKER-MASTER                          - disabled, port: 8002
          + system.adapter.sayit.0                  : sayit                 : IOBROKER-MASTER                          -  enabled
          + system.adapter.scenes.0                 : scenes                : IOBROKER-MASTER                          -  enabled
          + system.adapter.scheduler.0              : scheduler             : IOBROKER-MASTER                          -  enabled
          + system.adapter.shelly.0                 : shelly                : IOBROKER-MASTER                          -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.shuttercontrol.0         : shuttercontrol        : IOBROKER-MASTER                          - disabled
          + system.adapter.simple-api.0             : simple-api            : IOBROKER-MASTER                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.slideshow.0              : slideshow             : IOBROKER-MASTER                          -  enabled
          + system.adapter.smartcontrol.0           : smartcontrol          : IOBROKER-MASTER                          -  enabled
            system.adapter.smartmeter.0             : smartmeter            : IOBROKER-SLAVE                           - disabled
          + system.adapter.smartthings.0            : smartthings           : IOBROKER-MASTER                          -  enabled
          + system.adapter.sonoff.0                 : sonoff                : IOBROKER-MASTER                          -  enabled, port: 1885, bind: 0.0.0.0
          + system.adapter.sonos.0                  : sonos                 : IOBROKER-MASTER                          -  enabled
          + system.adapter.sourceanalytix.0         : sourceanalytix        : IOBROKER-MASTER                          -  enabled
          + system.adapter.synology.0               : synology              : IOBROKER-MASTER                          -  enabled, port: 5000
          + system.adapter.tahoma.0                 : tahoma                : IOBROKER-MASTER                          -  enabled
          + system.adapter.tankerkoenig.0           : tankerkoenig          : IOBROKER-MASTER                          -  enabled
          + system.adapter.telegram.0               : telegram              : IOBROKER-MASTER                          -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.1               : telegram              : IOBROKER-MASTER                          -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.2               : telegram              : IOBROKER-MASTER                          -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : IOBROKER-MASTER                          -  enabled
          + system.adapter.text2command.1           : text2command          : IOBROKER-MASTER                          -  enabled
          + system.adapter.time-switch.0            : time-switch           : IOBROKER-MASTER                          -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : IOBROKER-MASTER                          -  enabled
            system.adapter.trashschedule.1          : trashschedule         : IOBROKER-MASTER                          - disabled
          + system.adapter.unifi.0                  : unifi                 : IOBROKER-MASTER                          -  enabled
            system.adapter.upnp.0                   : upnp                  : IOBROKER-MASTER                          - disabled
          + system.adapter.vaillant.0               : vaillant              : IOBROKER-MASTER                          -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : IOBROKER-MASTER                          -  enabled
            system.adapter.vis-bars.0               : vis-bars              : IOBROKER-MASTER                          -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : IOBROKER-MASTER                          -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : IOBROKER-MASTER                          -  enabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : IOBROKER-MASTER                          -  enabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : IOBROKER-MASTER                          -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IOBROKER-MASTER                          -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : IOBROKER-MASTER                          -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : IOBROKER-MASTER                          -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IOBROKER-MASTER                          -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : IOBROKER-MASTER                          -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : IOBROKER-MASTER                          -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : IOBROKER-MASTER                          -  enabled
            system.adapter.vis-metro.0              : vis-metro             : IOBROKER-MASTER                          - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : IOBROKER-MASTER                          -  enabled
            system.adapter.vis-weather.0            : vis-weather           : IOBROKER-MASTER                          -  enabled
            system.adapter.vis.0                    : vis                   : IOBROKER-MASTER                          -  enabled
          + system.adapter.vw-connect.0             : vw-connect            : IOBROKER-MASTER                          -  enabled
          + system.adapter.vw-connect.1             : vw-connect            : IOBROKER-MASTER                          -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : IOBROKER-MASTER                          -  enabled
          + system.adapter.web.0                    : web                   : IOBROKER-MASTER                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.webcal.0                 : webcal                : IOBROKER-MASTER                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IOBROKER-MASTER                          -  enabled
          + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : IOBROKER-MASTER                          -  enabled
          + system.adapter.yahka.0                  : yahka                 : IOBROKER-MASTER                          -  enabled
          + system.adapter.zigbee.1                 : zigbee                : IOBROKER-SLAVE                           -  enabled, port: /dev/ttyACM0
          + system.adapter.zigbee.2                 : zigbee                : IOBROKER-MASTER                          -  enabled, port: tcp://192.168.10.24:6638
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "alarm"        : 3.6.0    , installed 3.6.0
          Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
          Adapter    "apcups"       : 1.0.15   , installed 1.0.15
          Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
          Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
          Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
          Adapter    "device-watcher": 2.9.6   , installed 2.9.6
          Adapter    "doorio"       : 2.1.4    , installed 2.1.4
          Adapter    "echarts"      : 1.7.2    , installed 1.7.2
          Adapter    "email"        : 1.2.2    , installed 1.2.2
          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
          Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
          Adapter    "ham"          : 5.3.1    , installed 5.3.1
          Adapter    "hass"         : 1.4.0    , installed 1.4.0
          Adapter    "heatingcontrol": 2.12.3  , installed 2.12.3
          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
          Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
          Adapter    "hue"          : 3.10.2   , installed 3.10.2
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "kodi"         : 3.0.0    , installed 3.0.0
          Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
          Adapter    "linktap"      : 0.3.0    , installed 0.3.0
          Adapter    "linux-control": 1.1.5    , installed 1.1.5
          Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
          Adapter    "mobile"       : 1.0.1    , installed 1.0.1
          Adapter    "mpd"          : 1.1.1    , installed 1.1.1
          Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
          Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
          Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
          Adapter    "node-red"     : 5.1.0    , installed 5.1.0
          Adapter    "nuki"         : 1.6.0    , installed 1.6.0
          Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
          Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
          Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
          Adapter    "onvif"        : 1.1.1    , installed 1.1.1
          Adapter    "paw"          : 0.3.2    , installed 0.3.2
          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
          Adapter    "reolink"      : 1.0.3    , installed 1.0.3
          Adapter    "robonect"     : 1.3.4    , installed 1.3.4
          Adapter    "samsung"      : 0.5.11   , installed 0.5.11
          Adapter    "samsung_tizen": 1.0.0    , installed 1.0.0
          Adapter    "sayit"        : 3.0.5    , installed 3.0.5
          Adapter    "scheduler"    : 1.1.9    , installed 1.1.9
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
          Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
          Adapter    "smartthings"  : 0.0.4    , installed 0.1.1
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
          Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
          Adapter    "synology"     : 3.0.1    , installed 3.0.1
          Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
          Adapter    "telegram"     : 3.0.1    , installed 3.0.1
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
          Adapter    "unifi"        : 0.6.7    , installed 0.6.7
          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
          Adapter    "vaillant"     : 0.1.2    , installed 0.4.0
          Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
          Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
          Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
          Adapter    "volumio"      : 0.1.2    , installed 0.1.3
          Adapter    "vw-connect"   : 0.0.67   , installed 0.5.1
          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
          Adapter    "web"          : 6.2.3    , installed 6.2.3
          Adapter    "webcal"       : 1.3.0    , installed 1.1.0  [Updatable]
          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
          Adapter    "ws"           : 2.5.10   , installed 2.5.10
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
          Objects and States
          Objects:        56453
          States:         48398
          W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
          W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
          W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
          W: Target DEP-11 (main/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
          W: Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
          W: Target DEP-11-icons-small (main/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
          W: Target DEP-11-icons (main/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list.d/influxdata.list:1 and /etc/apt/sources.list.d/influxdb.list:1
          Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://repos.influxdata.com/debian stable InRelease
          Hit:5 https://apt.grafana.com stable InRelease
          Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 17
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          65         1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16086      969/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       74578738   2501883/node-red
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       74583578   2502418/io.shelly.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       74587586   2502993/io.mqtt.0
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       74587587   2502993/io.mqtt.0
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       74591520   2502919/io.sonoff.0
          tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       75512632   2690492/nc
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          73118439   2210884/cupsd
          tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      121        18592      1008/asterisk
          tcp        0      0 192.168.10.16:2001      0.0.0.0:*               LISTEN      1001       74582911   2502463/io.hm-rpc.0
          tcp        0      0 192.168.10.16:2010      0.0.0.0:*               LISTEN      1001       74595393   2502564/io.hm-rpc.1
          tcp        0      0 192.168.10.16:9292      0.0.0.0:*               LISTEN      1001       74583000   2502888/io.hm-rpc.2
          tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      118        74603472   2507490/redis-serve
          tcp        0      0 127.0.0.1:44949         0.0.0.0:*               LISTEN      122        42316113   250044/plugin_start
          tcp6       0      0 :::111                  :::*                    LISTEN      0          1711       1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          16088      969/sshd: /usr/sbin
          tcp6       0      0 :::9220                 :::*                    LISTEN      1001       74585814   2503615/io.ocpp.0
          tcp6       0      0 :::51989                :::*                    LISTEN      1001       74594491   2502433/io.nuki-ext
          tcp6       0      0 :::35615                :::*                    LISTEN      1001       74591906   2504296/io.yahka.0
          tcp6       0      0 :::3000                 :::*                    LISTEN      122        42309336   249599/grafana
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          73118438   2210884/cupsd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       74592281   2501830/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       74598671   2504408/io.web.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      998        22728      1022/influxd
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       74591795   2503730/io.simple-a
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15910      1/init
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          73118444   2210886/cups-browse
          udp        0      0 0.0.0.0:42823           0.0.0.0:*                           111        23664      879/avahi-daemon: r
          udp        0      0 192.168.10.16:1905      0.0.0.0:*                           1001       75515310   2502935/io.sonos.0
          udp        0      0 0.0.0.0:35072           0.0.0.0:*                           121        22715      1008/asterisk
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       74596509   2503080/io.mihome-v
          udp        0      0 0.0.0.0:4569            0.0.0.0:*                           121        18609      1008/asterisk
          udp        0      0 0.0.0.0:5060            0.0.0.0:*                           121        18610      1008/asterisk
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       74592712   2503132/io.chromeca
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           111        23662      879/avahi-daemon: r
          udp6       0      0 :::111                  :::*                                0          22563      1/init
          udp6       0      0 :::50118                :::*                                111        23665      879/avahi-daemon: r
          udp6       0      0 :::54441                :::*                                121        22716      1008/asterisk
          udp6       0      0 :::5353                 :::*                                111        23663      879/avahi-daemon: r
          2024-02-06 18:54:18.958  - info: ocpp.0 (2503615) Received Status Notification from "/2203020632A.2": Available
          2024-02-06 18:54:18.964  - info: sourceanalytix.0 (2503761) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.2.lastTransactionConsumption
          2024-02-06 18:54:18.966  - info: sourceanalytix.0 (2503761) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.2.transactionEndMeter
          2024-02-06 18:54:19.652  - info: ocpp.0 (2503615) Requesting StatusNotification from "/2203020632A"
          2024-02-06 18:54:19.769  - debug: ocpp.0 (2503615) {"connectorId":1,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T17:54:19.7116565Z","commandOcpp":"StatusNotification"}
          2024-02-06 18:54:19.770  - info: ocpp.0 (2503615) Received Status Notification from "/2203020632A.1": Available
          2024-02-06 18:54:19.929  - debug: ocpp.0 (2503615) {"connectorId":2,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T17:54:19.7116827Z","commandOcpp":"StatusNotification"}
          2024-02-06 18:54:19.930  - info: ocpp.0 (2503615) Received Status Notification from "/2203020632A.2": Available
          2024-02-06 18:54:20.726  - info: ocpp.0 (2503615) Requesting MeterValues from "/2203020632A"
          2024-02-06 18:54:21.798  - info: ocpp.0 (2503615) Sending GetConfiguration to "/2203020632A"
          2024-02-06 18:54:21.937  - debug: ocpp.0 (2503615) Received configuration from /2203020632A: {"configurationKey":[{"key":"NumberOfConnectors","readonly":true,"value":"2"},{"key":"DownLight","readonly":false,"value":"True"},{"key":"Dimmer","readonly":false,"value":"Low"},{"key":"Schuko","readonly":true,"value":"Off"},{"key":"DefaultIdTag","readonly":false,"value":"999999"},{"key":"DefaultIdTagEnabled","readonly":false,"value":"True"},{"key":"StopTransactionOnEVSideDisconnect","readonly":true,"value":"True"},{"key":"StopTransactionOnInvalidId","readonly":false,"value":"True"},{"key":"MeterValueSampleInterval","readonly":false,"value":"30"},{"key":"HeartbeatInterval","readonly":false,"value":"10"},{"key":"AuthorizeRemoteTxRequests","readonly":true,"value":"True"},{"key":"ClockAlignedDataInterval","readonly":false,"value":"0"},{"key":"ConnectionTimeOut","readonly":false,"value":"60"},{"key":"GetConfigurationMaxKeys","readonly":true,"value":"31"},{"key":"LocalAuthorizeOffline","readonly":false,"value":"True"},{"key":"LocalPreAuthorize","readonly":false,"value":"False"},{"key":"MeterValuesAlignedData","readonly":false,"value":""},{"key":"MeterValuesSampledData","readonly":false,"value":"Voltage,Current.Import,Energy.Active.Import.Register"},{"key":"ResetRetries","readonly":false,"value":"0"},{"key":"StopTxnAlignedData","readonly":false,"value":"False"},{"key":"StopTxnSampledData","readonly":false,"value":"False"},{"key":"TransactionMessageAttempts","readonly":false,"value":"0"},{"key":"TransactionMessageRetryInterval","readonly":false,"value":"0"},{"key":"UnlockConnectorOnEVSideDisconnect","readonly":false,"value":"False"},{"key":"ConnectorPhaseRotation","readonly":false,"value":"NotApplicable"},{"key":"SupportedFeatureProfiles","readonly":true,"value":"Core"},{"key":"AllowOfflineTxForUnknownId","readonly":false,"value":"False"},{"key":"AuthorizationCacheEnabled","readonly":false,"value":"True"},{"key":"AssignedCurrent","readonly":false,"value":"32.00;32.00"},{"key":"AuthorizationKey","readonly":false,"value":""},{"key":"SecurityProfile","readonly":false,"value":"0"}],"unknownKey":[]}
          2024-02-06 18:54:21.990  - info: ocpp.0 (2503615) Supported profiles by client "/2203020632A" are "Core"
          2024-02-06 18:54:22.001  - info: ocpp.0 (2503615) Removing SmartCharging functionality as unsupported
          2024-02-06 18:54:22.009  - info: ocpp.0 (2503615) Removing LocalAuthListManagement functionality as unsupported
          2024-02-06 18:54:27.560  - info: linktap.0 (2504393) updateWateringStatus started
          2024-02-06 18:54:28.086  - info: linktap.0 (2504393) Queried watering status for device Ventil-1. Status: 200
          2024-02-06 18:54:28.588  - info: linktap.0 (2504393) Queried watering status for device Ventil-2. Status: 200
          2024-02-06 18:54:29.087  - info: linktap.0 (2504393) Queried watering status for device Ventil-3. Status: 200
          2024-02-06 18:54:29.590  - info: linktap.0 (2504393) Queried watering status for device Ventil-4. Status: 200
          2024-02-06 18:54:30.091  - info: linktap.0 (2504393) Queried watering status for device Ventil-5. Status: 200
          2024-02-06 18:54:30.591  - info: linktap.0 (2504393) Queried watering status for device Ventil-6. Status: 200
          2024-02-06 18:54:30.592  - info: linktap.0 (2504393) updateWateringStatus finished
          2024-02-06 18:54:30.720  - info: javascript.0 (2501928) script.js.common.Diverses.BatterieUeberwachung185: Reaching CheckDeadBatt()
          2024-02-06 18:54:30.722  - info: javascript.0 (2501928) script.js.common.Diverses.BatterieUeberwachung185: Reaching MakeTable
          2024-02-06 18:54:30.726  - info: javascript.0 (2501928) script.js.common.Diverses.BatterieUeberwachung185: Reaching MakeJSONTable
          Top sieht so aus :
          top - 18:58:10 up 25 days, 10:23,  1 user,  load average: 0.47, 0.44, 0.39
          Tasks: 420 total,   1 running, 419 sleeping,   0 stopped,   0 zombie
          %Cpu(s):   1.0/0.5     1[|        ]
          MiB Mem :  11926.7 total,    930.9 free,   8022.1 used,   3290.3 buff/cache
          MiB Swap:   2044.0 total,   1761.0 free,    283.0 used.   3904.6 avail Mem
              PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
          2502494 iobroker  20   0  970908 115660  39628 S   5.9   0.9   0:33.15 io.alexa2.0
          2502418 iobroker  20   0  718700 119496  38512 S   3.0   1.0   9:29.04 io.shelly.0
          2507490 redis     20   0 2380112 956748   8916 S   2.6   7.8  25:35.59 redis-server
          2501928 iobroker  20   0 1228744 348208  45036 S   2.3   2.9  26:04.94 io.javascript.0
          2501985 iobroker  20   0 1026816 164916  38276 S   1.7   1.4   9:44.20 io.influxdb.0
          2501872 iobroker  20   0  889924 156760  38196 S   1.0   1.3   9:43.59 io.history.0
          2502388 iobroker  20   0  677664 104916  38476 S   1.0   0.9   8:04.91 io.kodi.0
          2503052 iobroker  20   0   10.7g 112432  40076 S   1.0   0.9   1:53.66 io.synology.0
             1008 asterisk -11   0 5204544  35892  20324 S   0.7   0.3 312:22.63 asterisk
             1338 Debian-+  20   0 6338796 107844  35444 S   0.7   0.9  63:55.86 gnome-shell
          2692777 debian    20   0   11648   5448   3296 R   0.7   0.0   0:00.55 top
              802 root      20   0  241528   9844   6408 S   0.3   0.1  47:58.63 vmtoolsd
           249599 grafana   20   0 1677572 128360  51340 S   0.3   1.1  24:23.42 grafana
           250044 grafana   20   0  664160  61604  14420 S   0.3   0.5  72:02.49 plugin_start_li
          2501812 iobroker  20   0   11.1g 282464  45948 S   0.3   2.3   2:25.60 iobroker.js-con
          2501894 iobroker  20   0 1004340 131644  44840 S   0.3   1.1   1:03.47 io.telegram.2
          2501913 iobroker  20   0  687568  79528  38324 S   0.3   0.7   0:13.81 io.email.0
          2502001 iobroker  20   0 1003480 123116  39248 S   0.3   1.0   1:03.21 io.telegram.0
          2502018 iobroker  20   0  687428  81080  38204 S   0.3   0.7   0:13.52 io.pushover.0
          2502357 iobroker  20   0 1005648 130384  44844 S   0.3   1.1   1:03.65 io.telegram.1
          2502510 iobroker  20   0  698448  92956  38472 S   0.3   0.8   0:19.54 io.hass.0
          2502935 iobroker  20   0  686568  81752  38264 S   0.3   0.7   0:33.03 io.sonos.0
          2502993 iobroker  20   0  773696  98832  38352 S   0.3   0.8   0:28.60 io.mqtt.0
          2503080 iobroker  20   0  693196  88192  38196 S   0.3   0.7   0:29.98 io.mihome-vacuu
          2503148 iobroker  20   0  690772  83992  38244 S   0.3   0.7   1:53.38 io.net-tools.0
          2503429 iobroker  20   0  737980 112192  38280 S   0.3   0.9   0:50.42 io.mqtt-client.
          2504296 iobroker  20   0  760992  93404  39180 S   0.3   0.8   0:58.30 io.yahka.0
          2504393 iobroker  20   0  958140  93000  39352 S   0.3   0.8   1:01.79 io.linktap.0
          2662239 root      20   0       0      0      0 I   0.3   0.0   0:03.22 kworker/9:0-events
                1 root      20   0  169580  12604   7964 S   0.0   0.1   0:34.39 systemd
                2 root      20   0       0      0      0 S   0.0   0.0   0:04.01 kthreadd
                3 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_gp
                4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 rcu_par_gp
                5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 slub_flushwq
                6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 netns
                8 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/0:0H-events_highpri
               10 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 mm_percpu_wq
               11 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_kthread
               12 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_rude_kthread
               13 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_trace_kthread
               14 root      20   0       0      0      0 S   0.0   0.0   0:23.37 ksoftirqd/0
          Da steht oben immer ein anderer Wert drin , je nach dem alle mit io.XXXX , aber nur so um die 9% bis max 30%
            achwas 🙂
            aber hiet
            ist kein Hinweis auf Überlastung durch I/O oder Prozesse
              Thomas Braun Most Active @sunny9999 last edited by
              @sunny9999
              Deine .list-Files für influxdb sind komplett chaotisch. Hat aber nix mit deinem 'Problem' direkt zu tun.
              Und wozu brauchst du die gnome-shell?
                keine Ahnung wo die herkommt........kann man die deinstallieren und wenn ja wie ? wenns was bringt.......
                Idee wie ich die Influxdb .list files hinbiegen kann ? ( nur so am Rande).......
                  @sunny9999 was machst du mit den mounts?
                  rauschen da die Daten dauerhaft und viel durch?
                  bei diashow werde ich auch hellhörig
                    die mounts sind nur für Backups.....die slideshow läuft nicht, war mal ein Versuch, danke für den Hinweis schon fast vergessen....jetzt disabled....
                      Thomas Braun Most Active @sunny9999 last edited by Thomas Braun
                      sudo rm /etc/apt/sources.list.d/influx*
                      wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                      echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                      echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                      rm influxdata-archive_compat.key
                      sudo apt update
                      sudo apt full-upgrade
                      Setz den user 'debian' in die Gruppe 'adm':
                      sudo usermod -a -G adm debian
                      Boot Target: graphical.target
                      sudo systemctl set-default multi-user.target
                      sudo reboot
                      Was ist denn mit dem los?
                        @thomas-braun sagte in Performance verbessern:
                        Top Vielen Dank !
                        das war mal ein daemon für ne apc usv .....die hing damals als Server im Netz, weiss nur nicht wie ich die wieder deinstallieren kann, weisst du das ?
                        Alles so gemacht.....iob diag sieht nun wie folgt aus :
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Chassis: vm 🖴
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : amd64
                         19:36:28 up 8 min,  1 user,  load average: 0.74, 1.27, 0.75
                        CPU threads: 16
                                       Local time: Tue 2024-02-06 19:36:28 CET
                                   Universal time: Tue 2024-02-06 18:36:28 UTC
                                         RTC time: Tue 2024-02-06 18:36:28
                                      NTP service: active
                                  RTC in local TZ: no
                        debian
                        /home/debian
                        debian adm cdrom floppy sudo audio dip video plugdev netdev bluetooth lpadmin scanner iobroker
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        Boot Target:    multi-user.target
                        *** MEMORY ***
                        Mem:             12G        6.2G        4.5G        1.4M        2.1G        6.3G
                        Swap:           2.1G          0B        2.1G
                        Total:           14G        6.2G        6.6G
                                 5937 M used memory
                                  505 M active memory
                                 6580 M inactive memory
                                 4246 M free memory
                                  136 M buffer memory
                                 1892 M swap cache
                                 2043 M total swap
                                    0 M used swap
                                 2043 M free swap
                        *** FILESYSTEM ***
                        tmpfs        tmpfs     1.2G  1.3M  1.2G   1% /run
                        /dev/mapper/debian10--vg-root                                            ext4      107G   43G   60G  42% /
                        /dev/mapper/debian10--vg-tmp                                             ext4      1.2G  116K  1.1G   1% /tmp
                        /dev/mapper/debian10--vg-var                                             ext4      6.4G  2.0G  4.0G  34% /var
                        [Tue Feb  6 19:27:39 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Quota mode: none.
                        [Tue Feb  6 19:27:40 2024] EXT4-fs (dm-0): re-mounted. Quota mode: none.
                        [Tue Feb  6 19:27:41 2024] EXT4-fs (sda1): mounting ext2 file system using the ext4 subsystem
                        [Tue Feb  6 19:27:41 2024] EXT4-fs (sda1): mounted filesystem without journal. Quota mode: none.
                        [Tue Feb  6 19:27:41 2024] EXT4-fs (dm-3): mounted filesystem with ordered data mode. Quota mode: none.
                        [Tue Feb  6 19:27:41 2024] EXT4-fs (dm-4): mounted filesystem with ordered data mode. Quota mode: none.
                        [Tue Feb  6 19:27:41 2024] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Quota mode: none.
                        `-/mnt/IOBROKERDATA 192.168.10.47:/volume1/IOBROKER                                          nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.10.16,local_lock=none,addr=192.168.10.47
                        /var:
                        2.0G    /var/
                        1.5G    /var/lib
                        Archived and active journals take up 85.3M in the file system.
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: redis
                        States  type: redis
                        admin:          6.13.16
                        javascript:     7.1.6
                        Adapter State
                          system.adapter.slideshow.0              : slideshow             : IOBROKER-MASTER                          - disabled
                        + instance is alive
                        Objects and States
                        Objects:        56453
                        States:         48433
                        Hit:4 https://apt.grafana.com stable InRelease
                        Hit:5 https://repos.influxdata.com/debian stable InRelease
                        Pending Updates: 0
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15837      2046/io.shelly.0
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       15786      1951/io.mqtt.0
                        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       14320      1673/node-red
                        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       15787      1951/io.mqtt.0
                        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       26969      1916/io.sonoff.0
                        tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1000       55666      6053/nc
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          23748      934/cupsd
                        tcp        0      0 192.168.10.16:9292      0.0.0.0:*               LISTEN      1001       25253      2066/io.hm-rpc.2
                        tcp        0      0 192.168.10.16:2010      0.0.0.0:*               LISTEN      1001       19362      2317/io.hm-rpc.1
                        tcp        0      0 192.168.10.16:2001      0.0.0.0:*               LISTEN      1001       17928      2299/io.hm-rpc.0
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13258      943/sshd: /usr/sbin
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14049      1/init
                        tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      121        15631      969/asterisk
                        tcp        0      0 127.0.0.1:40241         0.0.0.0:*               LISTEN      122        35029      1280/plugin_start_l
                        tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      118        20140      2535/redis-server 0
                        tcp6       0      0 :::9220                 :::*                    LISTEN      1001       20418      3039/io.ocpp.0
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          23747      934/cupsd
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          13260      943/sshd: /usr/sbin
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          16407      1/init
                        tcp6       0      0 :::51989                :::*                    LISTEN      1001       15044      2284/io.nuki-extend
                        tcp6       0      0 :::3000                 :::*                    LISTEN      122        14218      1239/grafana
                        tcp6       0      0 :::38891                :::*                    LISTEN      1001       32649      2497/io.yahka.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38416      2882/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       32148      1304/io.admin.0
                        tcp6       0      0 :::8086                 :::*                    LISTEN      998        35014      981/influxd
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       24244      2692/io.simple-api.
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          28072      1/init
                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          28194      986/cups-browsed
                        udp        0      0 192.168.10.16:1905      0.0.0.0:*                           1001       62557      2195/io.sonos.0
                        udp        0      0 0.0.0.0:60858           0.0.0.0:*                           121        33541      969/asterisk
                        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       15909      2165/io.mihome-vacu
                        udp        0      0 0.0.0.0:4569            0.0.0.0:*                           121        15648      969/asterisk
                        udp        0      0 0.0.0.0:45969           0.0.0.0:*                           111        31874      870/avahi-daemon: r
                        udp        0      0 0.0.0.0:5060            0.0.0.0:*                           121        15649      969/asterisk
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22049      1853/io.chromecast.
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           111        31872      870/avahi-daemon: r
                        udp6       0      0 :::111                  :::*                                0          17472      1/init
                        udp6       0      0 :::44160                :::*                                121        33542      969/asterisk
                        udp6       0      0 :::5353                 :::*                                111        31873      870/avahi-daemon: r
                        udp6       0      0 :::46869                :::*                                111        31875      870/avahi-daemon: r
                        2024-02-06 19:36:45.696  - debug: ocpp.0 (3039) {"chargePointSerialNumber":"2203020632A","chargePointModel":"Aura T2 outlet","chargePointVendor":"Charge Amps","firmwareVersion":"72.2.0.0","iccid":"0","commandOcpp":"BootNotification"}
                        2024-02-06 19:36:45.696  - info: ocpp.0 (3039) Received boot notification from "/2203020632A"
                        2024-02-06 19:36:45.813  - debug: ocpp.0 (3039) {"connectorId":1,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T18:36:45.7744021Z","commandOcpp":"StatusNotification"}
                        2024-02-06 19:36:45.813  - info: ocpp.0 (3039) Received Status Notification from "/2203020632A.1": Available
                        2024-02-06 19:36:45.821  - info: sourceanalytix.0 (2676) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.1.lastTransactionConsumption
                        2024-02-06 19:36:45.824  - info: sourceanalytix.0 (2676) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.1.transactionEndMeter
                        2024-02-06 19:36:45.954  - debug: ocpp.0 (3039) {"connectorId":2,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T18:36:45.7744353Z","commandOcpp":"StatusNotification"}
                        2024-02-06 19:36:45.954  - info: ocpp.0 (3039) Received Status Notification from "/2203020632A.2": Available
                        2024-02-06 19:36:45.961  - info: sourceanalytix.0 (2676) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.2.lastTransactionConsumption
                        2024-02-06 19:36:45.964  - info: sourceanalytix.0 (2676) Updating SourceAnalytix configuration for : ocpp.0./2203020632A.2.transactionEndMeter
                        2024-02-06 19:36:46.641  - info: ocpp.0 (3039) Requesting StatusNotification from "/2203020632A"
                        2024-02-06 19:36:46.744  - debug: ocpp.0 (3039) {"connectorId":1,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T18:36:46.7099585Z","commandOcpp":"StatusNotification"}
                        2024-02-06 19:36:46.745  - info: ocpp.0 (3039) Received Status Notification from "/2203020632A.1": Available
                        2024-02-06 19:36:46.860  - debug: ocpp.0 (3039) {"connectorId":2,"errorCode":"NoError","info":"","status":"Available","timestamp":"2024-02-06T18:36:46.7099797Z","commandOcpp":"StatusNotification"}
                        2024-02-06 19:36:46.860  - info: ocpp.0 (3039) Received Status Notification from "/2203020632A.2": Available
                        2024-02-06 19:36:47.725  - info: ocpp.0 (3039) Requesting MeterValues from "/2203020632A"
                        2024-02-06 19:36:48.802  - info: ocpp.0 (3039) Sending GetConfiguration to "/2203020632A"
                        2024-02-06 19:36:48.945  - debug: ocpp.0 (3039) Received configuration from /2203020632A: {"configurationKey":[{"key":"NumberOfConnectors","readonly":true,"value":"2"},{"key":"DownLight","readonly":false,"value":"True"},{"key":"Dimmer","readonly":false,"value":"Low"},{"key":"Schuko","readonly":true,"value":"Off"},{"key":"DefaultIdTag","readonly":false,"value":"999999"},{"key":"DefaultIdTagEnabled","readonly":false,"value":"True"},{"key":"StopTransactionOnEVSideDisconnect","readonly":true,"value":"True"},{"key":"StopTransactionOnInvalidId","readonly":false,"value":"True"},{"key":"MeterValueSampleInterval","readonly":false,"value":"120"},{"key":"HeartbeatInterval","readonly":false,"value":"10"},{"key":"AuthorizeRemoteTxRequests","readonly":true,"value":"True"},{"key":"ClockAlignedDataInterval","readonly":false,"value":"0"},{"key":"ConnectionTimeOut","readonly":false,"value":"60"},{"key":"GetConfigurationMaxKeys","readonly":true,"value":"31"},{"key":"LocalAuthorizeOffline","readonly":false,"value":"True"},{"key":"LocalPreAuthorize","readonly":false,"value":"False"},{"key":"MeterValuesAlignedData","readonly":false,"value":""},{"key":"MeterValuesSampledData","readonly":false,"value":"Voltage,Current.Import,Energy.Active.Import.Register"},{"key":"ResetRetries","readonly":false,"value":"0"},{"key":"StopTxnAlignedData","readonly":false,"value":"False"},{"key":"StopTxnSampledData","readonly":false,"value":"False"},{"key":"TransactionMessageAttempts","readonly":false,"value":"0"},{"key":"TransactionMessageRetryInterval","readonly":false,"value":"0"},{"key":"UnlockConnectorOnEVSideDisconnect","readonly":false,"value":"False"},{"key":"ConnectorPhaseRotation","readonly":false,"value":"NotApplicable"},{"key":"SupportedFeatureProfiles","readonly":true,"value":"Core"},{"key":"AllowOfflineTxForUnknownId","readonly":false,"value":"False"},{"key":"AuthorizationCacheEnabled","readonly":false,"value":"True"},{"key":"AssignedCurrent","readonly":false,"value":"32.00;32.00"},{"key":"AuthorizationKey","readonly":false,"value":""},{"key":"SecurityProfile","readonly":false,"value":"0"}],"unknownKey":[]}
                        2024-02-06 19:36:48.992  - info: ocpp.0 (3039) Supported profiles by client "/2203020632A" are "Core"
                        2024-02-06 19:36:49.000  - info: ocpp.0 (3039) Removing SmartCharging functionality as unsupported
                        2024-02-06 19:36:49.009  - info: ocpp.0 (3039) Removing LocalAuthListManagement functionality as unsupported
                        2024-02-06 19:36:57.137  - warn: robonect.0 (1764) No connection to lawn mower (Not able to ping it). Check network connection.
                        2024-02-06 19:36:58.693  - info: smartcontrol.0 (4396) Trigger [Motion.Buero-2] activated Zone 'BUERO2.Benni+Markus'. However, device(s) 'BUERO2.B+M-Lampe-Decke' not turned on as these are already on.
                        2024-02-06 19:36:58.693  - info: smartcontrol.0 (4396) Trigger [Motion.Buero-2] Zone 'BUERO2.Benni+Markus': Timer of 240s will be set to turn off once no more motion recognized.
                        2024-02-06 19:36:58.694  - info: smartcontrol.0 (4396) Trigger [Motion.Buero-2] 'zoneOff' 360s timer still running 329s. We stop it and set new to 360s.
                          hast du vieles auf debug?
                          kostet auch Ressourcen
                            So wie du es auch installiert hast?
                            Einstweilen kannst du es auch maskieren:
                            sudo systemctl mask apcupsd.service
                            1987
