    5. *ERLEDIGT*Handtuchheizung, TIMER Problem
    • Nicoloma
      Nicoloma last edited by Nicoloma
      ich schreibe schon seit einiger Zeit an meinem Blockly.
      ABER:
      • Er hört erst bei 1809 Sekunden auf
      • Er startet nach 10 Sekunden wieder den TImer
        <variables>
          <variable id="k{urv5:d*$21r3^eU1uH">dusche_an</variable>
          <variable id="YUa0(J+Yz1jv$b,HAJnV">heiz_an_timer</variable>
          <variable id="m!T2C{3jG}C2+mFo{{+t">tempDifferenz</variable>
          <variable id="C4=te:_+4!*#?$$i`FMI">liste</variable>
          <variable id="*VDIMI93Si7+.0,*m?D$">heizbedarf</variable>
          <variable id="nFaszOE_N_;S0AIaL!^7">timer_an_aus</variable>
          <variable type="interval" id="heiz_timer">heiz_timer</variable>
        </variables>
        <block type="update" id="6FMGBDnU[@lJ;:P)O#*f" disabled="true" x="-362" y="-162">
          <field name="OID">0_userdata.0.Badezimmer.Timer_Badezimmer</field>
            <block type="variables_get" id="_vH@ozJNgEF/vnhHG^f@">
              <field name="VAR" id="YUa0(J+Yz1jv$b,HAJnV">heiz_an_timer</field>
        <block type="variables_set" id="*8o}a($+Jq37{Hqnf09q" x="-463" y="-88">
          <field name="VAR" id="k{urv5:d*$21r3^eU1uH">dusche_an</field>
            <block type="get_value" id="RWu?Ij;l/Q~l!S|:~G.:">
              <field name="OID">0_userdata.0.Badezimmer.dusche_an</field>
            <block type="variables_set" id="-GBv{H?tO,H}*Dz_YiPD">
              <field name="VAR" id="m!T2C{3jG}C2+mFo{{+t">tempDifferenz</field>
                <block type="get_value" id="w6x;Bpn|*#Y5[4Q8!J)F">
                  <field name="OID">0_userdata.0.Badezimmer.feuchtigkeits_diff</field>
                <block type="variables_set" id="r8t.SQ@@vfv1qBai(dR@">
                  <field name="VAR" id="C4=te:_+4!*#?$$i`FMI">liste</field>
                    <block type="lists_create_with" id="F81YYU`J?1AJ50rRF.bp">
                    <block type="timeouts_clearinterval" id="2ycD2ZpB:I1._8!(?w]T">
                      <field name="NAME">heiz_timer</field>
                        <block type="variables_set" id="AQ_d!Qwhtcb)[9-jl951">
                            <block type="get_value" id="#8BOo~PcVL}_4)BsKZ_u">
                            <block type="on" id="=3436}WLW?~-c.9%gYf`">
                              <field name="OID">mqtt.0.Esp_gross.temp_wohnzimmer.Humidity</field>
                                <block type="controls_if" id="QJDXSGQ,lvALqN0T5`(s" collapsed="true" disabled="true">
                                    <block type="logic_compare" id="y~u3B*g0o]-9pgpL^#^%">
                                      <field name="OP">LT</field>
                                        <block type="get_value" id="U3g{9w4m8GcEa:BKc7F7">
                                          <field name="OID">tuya.0.bf2d324fcc025f1ef4swea.3</field>
                                        <block type="get_value" id="{d6R:-2qAROHDCgKNtEb">
                                          <field name="OID">tuya.0.bf2d324fcc025f1ef4swea.2</field>
                                    <block type="variables_set" id="72ImrJ1ARW7VU[`6$bJF">
                                      <field name="VAR" id="*VDIMI93Si7+.0,*m?D$">heizbedarf</field>
                                        <block type="logic_boolean" id=",SeL[`*rC5DE!813)i~l">
                                  <statement name="ELSE">
                                    <block type="variables_set" id="A@A=T9ZpDP3Do|a.aYJ1">
                                        <block type="logic_boolean" id="*CpX4mYAyy#$put1:iY6">
                                    <block type="debug" id="-4?ZpyvExG:MbRmzP!|1" collapsed="true" disabled="true">
                                      <value name="TEXT">
                                        <shadow type="text" id="WhMK}rs~DirtWG9qaygI">
                                        <block type="text_join" id="(@y~(jMSUf(HxL1^mFTA">
                                          <value name="ADD0">
                                            <block type="text" id="iW1x*9QjY/m~0@}0A[@?">
                                              <field name="TEXT">Heizbedarf:</field>
                                          <value name="ADD1">
                                            <block type="variables_get" id="Ai#h$ZL/cn:-%nyT~ZR!">
                                        <block type="debug" id="L;axa0y#O]vgNqmxsZoo" collapsed="true" disabled="true">
                                          <value name="TEXT">
                                            <block type="text_join" id="w:o`5Y2vmz(P,K#ts~gu">
                                              <value name="ADD0">
                                                <block type="text" id="RJEhA_fiFeYmFmQkErTc">
                                                  <field name="TEXT">feuchtigkeit</field>
                                              <value name="ADD1">
                                                <block type="get_value" id="=1OD#kP(/5a9Jz!)^[%-">
                                            <block type="debug" id="iK4oTMchdCobt2?x+.1I" collapsed="true" disabled="true">
                                              <value name="TEXT">
                                                <shadow type="text" id="8W*Tyzn,a-O*N(9T?CBk">
                                                <block type="lists_setIndex" id="(.,LUkXDr+Q^{oZ!}..n">
                                                  <mutation at="false"></mutation>
                                                  <field name="WHERE">LAST</field>
                                                  <value name="LIST">
                                                    <block type="variables_get" id="_iynJ_0%aO`/HA_^@U$|">
                                                  <value name="TO">
                                                    <block type="get_value" id="=9*16]1))KJ4Eb{D(k{F">
                                                    <block type="controls_if" id="D~:?H0_x*C{kk!wvmqTl">
                                                        <block type="logic_compare" id="-yRnKAY/)Qsg[I|I~g/Q">
                                                          <field name="OP">GTE</field>
                                                            <block type="lists_length" id="Ug@_~h+XD.yA+sLUrz39">
        <block type="variables_get" id="#c1}Oe[2lH~1{[U/8b/X">
                                                            <block type="math_number" id="U%Bl_`KVXBstplm}E:lf">
                                                              <field name="NUM">5</field>
                                                        <block type="lists_getIndex" id="e#w~fan2/~5rwgIvoU7j">
                                                          <mutation statement="true" at="false"></mutation>
                                                          <field name="MODE">REMOVE</field>
                                                          <field name="WHERE">FIRST</field>
                                                            <block type="variables_get" id="VA$G%~OlNxs,0j0O|4~f">
                                                        <block type="variables_set" id="DhaqVe*A(qLOm3nJl|^8">
                                                            <block type="math_arithmetic" id="z@mk|1g(?zYkPgJ,`+^.">
        <shadow type="math_number" id="5!XE|7=}49x?o=zsCs?F">
        <field name="NUM">1</field>
        <block type="lists_getIndex" id="4!e31@x+ld1qjw;FTcGQ">
        <mutation statement="false" at="false"></mutation>
        <block type="variables_get" id="byHCG?p2J}EQ.=(pQ1~8">
        <shadow type="math_number" id="/P%TSO:}^85VloVh8r(B">
        <block type="lists_getIndex" id="Xgqwkvd0%GQN6]=@SR?0">
        <block type="variables_get" id="VY:ky0a#G8c{4bT.[OP~">
                                                            <block type="update" id="9}2[}rOmRc@n5-({*Y$e">
        <block type="variables_get" id="M}mZ8v2#JIr,:q:v3/Zb">
        <block type="controls_if" id="Y2G.j7o+lExReGJX{L8/">
        <mutation elseif="1" else="1"></mutation>
        <block type="logic_compare" id="UQ#p;i+XpK7q?w7CT7d5" inline="false">
        <field name="OP">GT</field>
        <block type="variables_get" id=":xL;I_83n`HV40)1wxx8">
        <block type="math_number" id="(tRF9mq^FChM6(?wB9v3">
        <field name="NUM">4</field>
        <block type="debug" id="6h^S`xnhaHx3daVj~,Gg" collapsed="true" disabled="true">
        <field name="Severity">warn</field>
        <value name="TEXT">
        <shadow type="text" id="|KZxaQ,]:*kzmZO:3f@T">
        <block type="text_join" id="]0HSy_vV^2:V#lx+t249">
        <value name="ADD0">
        <block type="text" id="#Le*t:RE_B44..|sR}Gn">
        <field name="TEXT">Feuchtigkeitdifferenz: </field>
        <value name="ADD1">
        <block type="math_arithmetic" id="~o$+Bkb]~]h30+ZiCU1u">
        <block type="lists_getIndex" id="S9B-PFM]~gcJ,1i3e_p:">
        <block type="variables_get" id="_3m5r{Glrg0=8loaaGP8">
        <block type="lists_getIndex" id="YC]eFfa?/SA)=-2!CAa~">
        <block type="variables_get" id="`Isazr*%I{@,T:eeVORP">
        <block type="variables_set" id="px/w45?,OuJ07_SrP*H4">
        <block type="logic_boolean" id="KEkuKLsD{0[wNU,-cHV!">
        <value name="IF1">
        <block type="logic_compare" id="k;e;ks$]d,V7yhZ7gD6N" inline="false">
        <block type="variables_get" id="cd~#X?@H0,DGjWQRnnHL">
        <block type="math_number" id="]K}Y!uF]?AFo9`dH]67F">
        <field name="NUM">-4</field>
        <statement name="DO1">
        <block type="comment" id="u.%)g5HsbeS%l*V#3+qB">
        <field name="COMMENT">Dusche zuende_es wurd gelüftet</field>
        <block type="variables_set" id="*op|a;%^~(hB$^SJ%UDk">
        <block type="logic_boolean" id="2qoOURaGDc29C|CJc.6/">
        <block type="variables_set" id="b!ZtkV38/4Csd@(y~]Z-">
        <block type="logic_boolean" id="CwYB7+QGW{0}CKS4Bw%8">
        <block type="update" id="@i2$cSGBn(gW,igPr/6U" disabled="true">
        <block type="variables_get" id="/CLaCUl{{|UgMrm0*]my">
        <block type="debug" id="hor#t7q.L%Q3Q/QML$Nk" collapsed="true" disabled="true">
        <value name="TEXT">
        <shadow type="text" id="ffNm4A%)!%3?-L5=N8p#">
        <block type="variables_get" id="S9W0}rkh=K9N0P)aceu3">
        <block type="debug" id="9[A8RHBuK9C7(CjYsv1)" collapsed="true" disabled="true">
        <value name="TEXT">
        <block type="get_value" id="G0FJIHibRHZXk0INrT!G">
        <block type="debug" id="C]|R$IM~z%vB*3-.FgLD">
        <value name="TEXT">
        <shadow type="text" id="7sstB/Tj$%]n,71NE%4@">
        <block type="variables_get" id="/F11daBSG,_=r}~f/*[(">
        <field name="VAR" id="nFaszOE_N_;S0AIaL!^7">timer_an_aus</field>
        <block type="comment" id="oWZ,asic)[u.{E0Kr^`a">
        <field name="COMMENT">Setze Timer auf 0 und aus wenn 1800 sekunden an</field>
        <block type="controls_if" id="a#-)(`_@Zp[0PUXs~;~8">
        <block type="logic_compare" id="X+#SrT_Gnoj;p-kn~7tl">
        <field name="OP">LTE</field>
        <block type="get_value" id="g85MuYUv{`{Lx,Lv2Mg-">
        <block type="math_number" id="~:^1Eflfyi5`s0B#(!0:">
        <field name="NUM">1800</field>
        <block type="variables_set" id="x:h4_{fdxFVuW^frO8qT">
        <block type="logic_boolean" id="mud]+!+GZ.y7T,7FFr%j">
        <block type="variables_set" id="3@^K]j-j;ft3[w4+fw`D">
        <block type="logic_boolean" id="9KeLpUXS4tLq;a%5F4x/">
        <block type="variables_set" id="J:FLiT6Cb5Oxs~+?*.UT">
        <block type="math_number" id="Qlti(`[f;rhQEOjj[uDj">
        <field name="NUM">0</field>
        <block type="controls_if" id="wS?Vj~b3DY6MQn#BoBX+">
        <block type="logic_operation" id="T%:F!ybSL3DB+ky_?5(V">
        <field name="OP">OR</field>
        <block type="variables_get" id="oz2,k;1~(@dh)$D_AE%m">
        <block type="variables_get" id="uv2:Zc!ieyN]Z$UAnQkc">
        <block type="comment" id="$`^{/(x!j?Re.XU!TcbY">
        <field name="COMMENT">dsadas</field>
        <block type="controls_if" id="f=g,HJ`9Dkc$=CoDk^`n">
        <block type="logic_compare" id="!D0G2x[,UhkmMR?5?z%b">
        <block type="variables_get" id="5!?Yi]8MJY1syV3H_K7!">
        <block type="math_number" id="HoagxsfX3z{Vi)ujti;J">
        <block type="timeouts_clearinterval" id="0t=]mztKBNoG+F}#t@5j">
        <block type="variables_set" id="G6:Yt2E]%KNJ1gN6#7IU">
        <block type="math_number" id="f3H[~@T{WIhVZ0Pi[E6|">
        <block type="variables_set" id="75l3R8$:gJ1(l[L#+jB%">
        <block type="logic_boolean" id="$?FXySZs_xXoG@X,+r,T">
        <block type="update" id="By^bTKjkpQ/0.x+~6FH*" disabled="true">
        <block type="math_number" id="JEGb|tblIyG,cwZ^Csx#">
        <field name="NUM">20</field>
        <block type="control" id="Gw-J.hvUKDlu~b3!P{Fx">
        <block type="math_number" id="A[n5]MB~@og|=hsUH`Ak">
        <block type="variables_set" id="=.uG8oOOgq0XQ^o|z6_D">
        <block type="logic_boolean" id="?THLi3F0]9(qX)fhLGMs">
        <block type="update" id="G-{Y}{1p7+Fi}v^[}N$z" disabled="true">
        <block type="math_number" id="iPRoy;$c[aikdVz4ojjc">
        <field name="NUM">30</field>
        <block type="control" id="x7ws^y!:Xru;B=)7ZWyy">
        <block type="math_number" id="v+$_mi7j5DcLa@A`y5#@">
        <block type="timeouts_clearinterval" id="it9I1FuPb-YLN9)eGVGj">
        <block type="timeouts_setinterval" id=")DCko/rL6NjZ0+HHyX@H">
        <field name="INTERVAL">1</field>
        <block type="variables_set" id="MXN(xlU2:O]it/uL]DqJ">
        <block type="logic_boolean" id="3=5t{HoWSBN{t:2E?|:!">
        <block type="math_change" id="y`O0tes!Z3A|VE(/5lGc">
        <value name="DELTA">
        <shadow type="math_number" id="ANCfoU/v0j!_vv*?),G?">
        <block type="math_number" id="dG4cuG_m2Fk#HyCA(|NR">
        <block type="update" id="+6f0[V5fh}Y@{ovyc^az">
        <block type="variables_get" id="|dT@BHeL;aApN6eY_J,,">
        <value name="IF1">
        <block type="logic_negate" id="/@HvRn`byvBN|[s~2+qo">
        <value name="BOOL">
        <block type="variables_get" id="/AmJ-s?L_^2)X=b7yqX?">
        <block type="timeouts_clearinterval" id="B136.Zk0=)dZ^FRB?q2A">
        <block type="timeouts_clearinterval" id="fU4QN3#KMisi1vN{-JT[">
        <block type="update" id="O+}ll3|DgjT}::b*VD`l">
        <block type="variables_get" id="Lc_y6*F)bb9L,Glz:^/!">
