    4. iob stoppt und startet neu
    • wendy2702
      wendy2702 @amg_666 last edited by
      @amg_666 Was sagt das Linux Syslog zu dem Zeitpunkt?
      und
      iob diag
      • amg_666
        amg_666 @wendy2702 last edited by amg_666
        @wendy2702 iob diag:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 6.5.11-8-pve
            Architecture: x86-64
        model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         11:53:38 up 4 days, 15:34,  2 users,  load average: 1.11, 1.10, 1.09
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Fri 2024-02-09 11:53:38 CET
                   Universal time: Fri 2024-02-09 10:53:38 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** User and Groups ***
        andreas
        /home/andreas
        andreas sudo iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:             12G        3.6G        2.3G         45K        7.0G        9.3G
        Swap:           4.3G         73K        4.3G
        Total:           17G        3.6G        6.6G
                12288 M total memory
                 3421 M used memory
                 3278 M active memory
                 6553 M inactive memory
                 2160 M free memory
                    0 M buffer memory
                 6706 M swap cache
                 4096 M total swap
                    0 M used swap
                 4095 M free swap
        *** FAILED SERVICES ***
          UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        2 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--100--disk--1 ext4      147G   37G  103G  27% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
        tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
        tmpfs                            tmpfs     3.1G  100K  3.1G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        dmesg: read kernel buffer failed: Operation not permitted
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--100--disk--1 ext4   rw,relatime,stripe=16
        /var:
        1.9G    /var/
        1.3G    /var/cache/apt
        1.3G    /var/cache
        1.2G    /var/cache/apt/archives
        365M    /var/log
        Archived and active journals take up 80.3M in the file system.
        /opt/iobroker/backups:
        2.3G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        15G     /opt/iobroker/iobroker-data/
        14G     /opt/iobroker/iobroker-data/history
        546M    /opt/iobroker/iobroker-data/files
        165M    /opt/iobroker/iobroker-data/backup-objects
        92M     /opt/iobroker/iobroker-data/files/vis-2-beta
        66M     /opt/iobroker/iobroker-data/objects.jsonl
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        25M     /opt/iobroker/iobroker-data/states.jsonl
        24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
         *** 18.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0+dfsg1-1 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.13.16
        javascript:     7.8.0
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
        + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
        + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.backitup.1               : backitup              : iobroker                                 -  enabled
        + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
        + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
        + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
          system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
          system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
        + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
        + system.adapter.history.0                : history               : iobroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
          system.adapter.ical.6                   : ical                  : iobroker                                 -  enabled
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.klf200.0                 : klf200                : iobroker                                 -  enabled
        + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
        + system.adapter.lgtv.1                   : lgtv                  : iobroker                                 -  enabled
        + system.adapter.milight-smart-light.0    : milight-smart-light   : iobroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
        + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        + system.adapter.plenticore.0             : plenticore            : iobroker                                 -  enabled, port: 80
        + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
        + system.adapter.proxmox.1                : proxmox               : iobroker                                 -  enabled, port: 8006
        + system.adapter.rpi2.0                   : rpi2                  : iostrom                                  -  enabled
        + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
          system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
        + system.adapter.smartmeter.0             : smartmeter            : iostrom                                  -  enabled
        + system.adapter.snmp.0                   : snmp                  : iobroker                                 -  enabled
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.tr-064.2                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
        + system.adapter.vis-2-beta.0             : vis-2-beta            : iobroker                                 -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
          system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
        + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
        + system.adapter.wolf.0                   : wolf                  : iobroker                                 -  enabled, port: 12004, bind: 0.0.0.0
        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Cannot download repository hash file from "http://download.iobroker.net/sources-dist-latest-hash.json": timeout of 10000ms exceeded
        Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
        Adapter    "awtrix-light" : 0.13.1   , installed 0.13.1
        Adapter    "backitup"     : 2.10.10  , installed 2.10.10
        Adapter    "bmw"          : 2.8.0    , installed 2.8.0
        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
        Adapter    "device-watcher": 2.10.3  , installed 2.10.3
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "email"        : 1.2.2    , installed 1.2.2
        Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "fullcalendar" : 2.3.4    , installed 2.3.4
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
        Adapter    "ical"         : 1.14.2   , installed 1.14.2
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Adapter    "klf200"       : 1.1.2    , installed 1.1.2
        Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
        Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "nina"         : 0.0.26   , installed 0.0.26
        Adapter    "plenticore"   : 2.3.1    , installed 2.3.1
        Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
        Adapter    "rssfeed"      : 2.8.1    , installed 2.8.1
        Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
        Adapter    "shelly"       : 6.7.0    , installed 6.7.0
        Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
        Adapter    "snmp"         : 3.1.0    , installed 3.1.0
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
        Adapter    "trashschedule": 3.2.0    , installed 3.2.0
        Adapter    "unifi"        : 0.6.7    , installed 0.6.7
        Adapter    "vis-2-widgets-gauges": 1.0.2, installed 1.0.2
        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
        Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
        Adapter    "wolf"         : 1.7.0    , installed 1.7.0
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Adapter    "zigbee"       : 1.10.2   , installed 1.10.2
        Objects and States
        Objects:        40719
        States:         33254
        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          3753447    1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3753652    142/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       17352930   139909/iobroker.js-
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       17352604   140210/io.mqtt.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17359011   140308/io.sonoff.0
        tcp        0      0 0.0.0.0:12004           0.0.0.0:*               LISTEN      1001       17359121   140387/io.wolf.0
        tcp        0      0 192.168.1.23:8701       0.0.0.0:*               LISTEN      1001       17354281   140089/io.hm-rpc.1
        tcp        0      0 192.168.1.23:2001       0.0.0.0:*               LISTEN      1001       17355183   140074/io.hm-rpc.0
        tcp        0      0 192.168.1.23:2010       0.0.0.0:*               LISTEN      1001       17353677   140104/io.hm-rpc.2
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          3755269    293/master
        tcp        0      0 192.168.1.23:9292       0.0.0.0:*               LISTEN      1001       17352422   140120/io.hm-rpc.3
        tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      109        3754589    123/redis-server 0.
        tcp6       0      0 :::111                  :::*                    LISTEN      0          3753449    1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          3752909    142/sshd: /usr/sbin
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          3755270    293/master
        tcp6       0      0 :::20002                :::*                    LISTEN      1001       17364626   141174/io.web.1
        tcp6       0      0 :::4400                 :::*                    LISTEN      1001       17363211   140966/io.milight-s
        tcp6       0      0 ::1:6379                :::*                    LISTEN      109        3754590    123/redis-server 0.
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17365524   141163/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17353006   139927/io.admin.0
        udp        0      0 0.0.0.0:49105           0.0.0.0:*                           1001       17366202   141060/io.snmp.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          3753448    1/init
        udp        0      0 0.0.0.0:59805           0.0.0.0:*                           1001       17364160   141060/io.snmp.0
        udp        0      0 0.0.0.0:35552           0.0.0.0:*                           1001       17360739   140966/io.milight-s
        udp        0      0 192.168.1.23:5353       0.0.0.0:*                           1001       17357216   140323/io.tr-064.0
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17358044   140275/io.shelly.0
        udp6       0      0 :::111                  :::*                                0          3753450    1/init
        2024-02-09 11:35:00.052  - info: host.iobroker instance system.adapter.ical.1 started with pid 142829
        2024-02-09 11:35:02.733  - info: ical.1 (142829) starting. Version 1.14.2 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.19
        2024-02-09 11:35:08.965  - info: ical.1 (142829) processing URL: xxxxxxxxxxxxxxxxxxxxxs
        2024-02-09 11:35:15.011  - info: ical.1 (142829) Terminated (NO_ERROR): Without reason
        2024-02-09 11:35:15.546  - info: host.iobroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
        2024-02-09 11:40:00.044  - info: host.iobroker instance system.adapter.ical.2 started with pid 142911
        2024-02-09 11:40:02.548  - info: ical.2 (142911) starting. Version 1.14.2 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.19
        2024-02-09 11:40:08.338  - info: ical.2 (142911) processing URL: xxxxxxxxxxxxxxxxxxxxxx
        2024-02-09 11:40:13.465  - info: ical.2 (142911) Terminated (NO_ERROR): Without reason
        2024-02-09 11:40:13.996  - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
        2024-02-09 11:42:10.408  - info: javascript.0 (139976) script.js.AnAbwesenheit.BT_Anwesenheit_tr-64: Martina ist weg
        2024-02-09 11:45:00.043  - info: host.iobroker instance system.adapter.ical.3 started with pid 143007
        2024-02-09 11:45:02.727  - info: ical.3 (143007) starting. Version 1.14.2 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.19
        2024-02-09 11:45:09.203  - info: ical.3 (143007) processing URL:xxxxxxxxxxxxxxxxxxxxxxxx
        2024-02-09 11:45:18.754  - info: ical.3 (143007) Terminated (NO_ERROR): Without reason
        2024-02-09 11:45:19.302  - info: host.iobroker instance system.adapter.ical.3 terminated with code 0 (NO_ERROR)
        2024-02-09 11:46:21.345  - warn: bmw.0 (140449) Out of call volume quota. Quota will be replenished in 00:13:39.
        2024-02-09 11:48:00.042  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 143076
        2024-02-09 11:48:02.600  - info: daswetter.0 (143076) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.19.0, js-controller: 5.0.19
        2024-02-09 11:48:04.192  - info: zigbee.0 (140402) Device '0xbc33acfffe8663a9' announced itself
        2024-02-09 11:48:36.493  - info: daswetter.0 (143076) still wrong data structure from server received! repaired...
        2024-02-09 11:48:42.026  - info: daswetter.0 (143076) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2024-02-09 11:48:42.539  - info: daswetter.0 (143076) cleaned everything up...
        2024-02-09 11:48:42.562  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-02-09 11:52:21.362  - warn: bmw.0 (140449) Out of call volume quota. Quota will be replenished in 00:07:39.
        iob diag has finished.
        Press any key for a summary
        Summary
                                v.2023-10-10
          Virtualization: lxc
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               amd64
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        X-Server:               false
        Boot Target:            graphical.target
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
        Recommended versions are nodejs 18.19.0 and npm 10.2.3
        MEMORY:
        Mem:             12G        3.9G        2.0G         45K        7.0G        9.0G
        Swap:           4.3G         73K        4.3G
        Total:           17G        3.9G        6.3G
        Active iob-Instances:   51
        ioBroker Core:          js-controller           5.0.19
                                admin                   6.13.16
        Objects type: jsonl
        States  type: redis
        Objects:                40719
        States:                 33254
        Size of iob-Database:
        72M     /opt/iobroker/iobroker-data/objects.jsonl
        15M     /opt/iobroker/iobroker-data/objects.json.migrated
        15M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        3.4M    /opt/iobroker/iobroker-data/states.json.migrated
        3.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
        • Glasfaser
          Glasfaser @amg_666 last edited by
          @amg_666 sagte in iob stoppt und startet neu:
          info: ical.1 (142829) processing URL: Andreas https://calendar.google.com/calendar/ical/.........
          Editiere den URL Link in deinem Log !!
          Stolze Zahlen bei beiden ... sammelst du " Modern Talking Songs " 🙂
          info: daswetter.0 (139674) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled,
          verschiebe mal den scheduled
          Dann :
          2024-02-09 11:00:00.003 - info: javascript.0 (338) script.js.Devicemanagement.HM_Status: HM Check läuft
          du hast doch den dafür
          Der macht auch Probleme , eventuell killt der dein System
          Homoran amg_666 2 Replies Last reply Reply Quote 0
            Homoran Global Moderator Administrators @Glasfaser last edited by
            @glasfaser sagte in iob stoppt und startet neu:
            war's das?
            • amg_666
              amg_666 @Glasfaser last edited by
              @glasfaser Url Link editieren: Danke für den Hinweis, hab ich nicht dran gedacht
              Ich sammle keine Modern Talking Songs, aber ich "historisiere" in der Tat sehr viel (Solaranlage Einspeisung/Batterie etc) und Wärmepumpe und und und
              verschiebe mal den scheduled: Was meinst du damit? Ich hab die Instanz jetzt auf stündlich gestellt
              devicewatcher macht Probleme: Ich hab den mal deaktiviert. Kannst du mir da weitere Infos geben oder einen Link auf einen thread wo ich mich innformieren kann?
              Glasfaser 2 Replies Last reply Reply Quote 0
              • Glasfaser
                Du hast geschrieben ... genau um 11 :00 Uhr und auch dort hat der Wetteradapter die Daten geholt ,
                Ich würde Ihn nicht genau zur vollen Stunde die Daten holen , versetze die Abholzeit .
                nicht genau ... suche mal danach... da gibt es auch ein Thread dazu , das er Speicherhungrig ist .
                • Glasfaser
                  Auch unter
                  da liegt eher etwas anderes
                  • amg_666
                    Schau mal bitte hier:
                    andreas@iobroker:/opt/iobroker/iobroker-data$ ls -l
                    insgesamt 141104
                    drwxrwxr-x+   2 iobroker iobroker     4096 11. Feb 2022  backitup
                    drwxrwxr-x+   2 iobroker iobroker    12288  9. Feb 13:00 backup-objects
                    drwxrwxr-x+  83 iobroker iobroker     4096  4. Feb 18:29 files
                    drwxrwxr-x+ 758 iobroker iobroker    20480  9. Feb 00:09 history
                    -rw-rwxr--+   1 iobroker iobroker     5348  4. Feb 18:26 iobroker.json
                    -rw-rw-r--+   1 iobroker iobroker     5348  4. Feb 18:26 iobroker.json.bak
                    drwxrwxr-x+   3 iobroker iobroker     4096  6. Jun 2023  iot.0
                    drwxrwxr-x+   2 iobroker iobroker     4096  6. Apr 2021  lgtv_0
                    drwxrwxr-x+   2 iobroker iobroker     4096 28. Jan 2022  lgtv_1
                    drwxrwxr-x+   2 iobroker iobroker     4096 15. Jun 2023  lgtvs_0
                    -rw-rwxr--+   1 iobroker iobroker      648  4. Feb 20:19 notifications.json
                    -rw-rwxr--+   1 iobroker iobroker 15436128 31. Jan 2022  objects.json.bak.migrated
                    -rw-rw-r--+   1 iobroker iobroker 81260071  9. Feb 14:27 objects.jsonl
                    drwxrwxr-x+   2 iobroker iobroker     4096  9. Feb 14:34 objects.jsonl.lock
                    -rw-rwxr--+   1 iobroker iobroker 15436809 31. Jan 2022  objects.json.migrated
                    drwxrwxr-x+   2 iobroker iobroker     4096  6. Apr 2021  plenticore.0
                    drwxrwxr-x+  16 iobroker iobroker     4096 16. Nov 00:17 scripte
                    -rw-rwxr--+   1 iobroker iobroker  3488621 31. Jan 2022  states.json.bak.migrated
                    -rw-rw-r--+   1 iobroker iobroker 25207372  4. Feb 18:26 states.jsonl
                    -rw-rwxr--+   1 iobroker iobroker  3488681 31. Jan 2022  states.json.migrated
                    drwxrwxr-x+   2 iobroker iobroker     4096 24. Apr 2022  telegram_0
                    drwxrwxr-x+   3 iobroker iobroker     4096  8. Jan 2022  tmp
                    drwxrwxr-x+   2 iobroker iobroker     4096  9. Feb 14:02 zigbee_0
                    ich habe grade erst auf redis umgestellt, zumindest die "...bak.migrated" Dateine können doch weg, oder?
                    • Glasfaser
                      Kann du
                      ls -lh
                      zeigen ... habe kein Taschenrechner 🙂
                      • amg_666
                        @glasfaser
                        die .bak.migrated habe ich schon weg kopiert und gelöscht.
                        andreas@iobroker:/opt/iobroker/iobroker-data$ ls -lh
                        insgesamt 120M
                        drwxrwxr-x+   2 iobroker iobroker 4,0K 11. Feb 2022  backitup
                        drwxrwxr-x+   2 iobroker iobroker  12K  9. Feb 13:00 backup-objects
                        drwxrwxr-x+  83 iobroker iobroker 4,0K  4. Feb 18:29 files
                        drwxrwxr-x+ 758 iobroker iobroker  20K  9. Feb 00:09 history
                        -rw-rwxr--+   1 iobroker iobroker 5,3K  4. Feb 18:26 iobroker.json
                        -rw-rw-r--+   1 iobroker iobroker 5,3K  4. Feb 18:26 iobroker.json.bak
                        drwxrwxr-x+   3 iobroker iobroker 4,0K  6. Jun 2023  iot.0
                        drwxrwxr-x+   2 iobroker iobroker 4,0K  6. Apr 2021  lgtv_0
                        drwxrwxr-x+   2 iobroker iobroker 4,0K 28. Jan 2022  lgtv_1
                        drwxrwxr-x+   2 iobroker iobroker 4,0K 15. Jun 2023  lgtvs_0
                        -rw-rw-r--+   1 iobroker iobroker  78M  9. Feb 14:50 objects.jsonl
                        drwxrwxr-x+   2 iobroker iobroker 4,0K  9. Feb 14:53 objects.jsonl.lock
                        -rw-rwxr--+   1 iobroker iobroker  15M 31. Jan 2022  objects.json.migrated
                        drwxrwxr-x+   2 iobroker iobroker 4,0K  6. Apr 2021  plenticore.0
                        drwxrwxr-x+  16 iobroker iobroker 4,0K 16. Nov 00:17 scripte
                        -rw-rw-r--+   1 iobroker iobroker  25M  4. Feb 18:26 states.jsonl
                        -rw-rwxr--+   1 iobroker iobroker 3,4M 31. Jan 2022  states.json.migrated
                        drwxrwxr-x+   2 iobroker iobroker 4,0K 24. Apr 2022  telegram_0
                        drwxrwxr-x+   3 iobroker iobroker 4,0K  8. Jan 2022  tmp
                        drwxrwxr-x+   2 iobroker iobroker 4,0K  9. Feb 14:02 zigbee_0
                        • Glasfaser
                          sieht doch schon besser aus 🙂
                          iobroker stürzt ab
                          364
