    4. Daten unter 0_userdata werden nicht angezeigt/aktualisiert
      A Former User @Schnubby666 last edited by
      @schnubby666
      Ei, das war vor ziemlich genau einem Jahr.. oder.. ? Bist echt geduldig... und ich habs verpennt.. sorry.
      Hier mal ein Script, musste du anpassen, probier einfach mal rum:
      var URL_Chat, URL_ioBroker, URL_Snapshot, Nachricht, timeout, send, timeout2, timeout9, result;
      URL_Chat = 'http://10.10.2.10:5550/webapi/entry.cgi?api=SYNO.Chat.External&method=incoming&version=2&token=xxxx&payload={"text":"';
      URL_ioBroker = 'http://10.1.1.2:81/0_userdata.0/synology/Doorbell.jpg';
      URL_Snapshot = getState('synology.0.SurveillanceStation.cameras.C-Doorbell.linkSnapshot'/*SurveillanceStation cameras C-Doorbell linkSnapshot*/).val;
      Nachricht = 'Camera VideoDoorbell:';
      async function Bild_holen() {
        unlink('0_userdata.0', '/synology/Doorbell.jpg',(e)=>{ if(e) log(e) })
           request({url: URL_Snapshot,encoding: null,},
               (error, response, body) => {if (!error && body) {writeFile("0_userdata.0", "/synology/Doorbell.jpg", body, error);
      async function loesche_Bild() {
      console.log('bild geloescht')
      on({id: '0_userdata.0.Cameras.Videdoorbelllink'/*Videdoorbelllink*/, change: "any"}, async function (obj) {
       var value = obj.state.val;
      //(function () {if (timeout) {clearTimeout(timeout); timeout = null;}})();
      //(function () {if (timeout2) {clearTimeout(timeout2); timeout2 = null;}})();
       timeout = setTimeout(async function () {
           await Bild_holen();
        send = [URL_Chat,String(Nachricht) + '", "file_url": "',URL_ioBroker,'"}'].join('');
      console.log('bild gesendet')
        timeout2 = setTimeout(async function () {
           try {
            require("request")(send, async function (error, response, result) {
              console.log(result);
             }).on("error", function (e) {console.error(e);});
           } catch (e) { console.error(e); }
          console.log(send);
      console.log('Bild fertig');
           }, 7000);
           exec('wget -q -O /opt/iobroker/pics/Doorbell.jpg + "http://10.1.1.2:81/0_userdata.0/synology/Doorbell.jpg"');
       }, 7000);
      exec((['cp /opt/iobroker/pics/Doorbell.jpg /mnt/photo/doorbell/Doorbell-',formatDate(new Date(), "JJJJ_MM_TT_SS_mm_ss"),'.jpg'].join('')));
      //await loesche_Bild();
      //console.log('gewartet jetzt loeschen')
        Schnubby666 @Guest last edited by
        @ilovegym
        Besser spät als nie und ich mag es nicht penetrant ständig nachzufragen. Hinzu kommt das ich jetzt erst wieder mehr Zeit dafür habe.
        Danke aber für das Skript, ich werde es versuchen zu vestehen und ich hoffe ich kann es dann auch implementieren.
          @schnubby666
          Wahrscheinlich wirst du es dir umbauen müssen, aber die Bausteine sind da..
            Schnubby666 @Guest last edited by Schnubby666
            @ilovegym
            ok, folgende Fragen dazu...
            Ich habe zwei Szenarien die ich umsetzten könnte/möchte
            1. Ich generiere einen Snapshot einer Kamera und versende es in dem Chat.
            2. Ich nutze die bereits per ftp von den Kameras abgelegten Bilder auf der Syno um sie per Chat zu versenden
            Die zweite Variante wäre natürlich super, weil die Bilder/Videos eh schon vorhanden sind. Hier habe ich aber keine Idee wie man dies umsetzten müsste.
            Weiter nutze ich nicht den Snologyadapter und auch nicht die Surveillance Station (bei 5 Kameras wollte ich die die Lizenzen nicht zusätzlich erwerben)
            Hast du eine Idee wie man die erste Variante umsetzten kann? Sonst gehe ich auch gerne auf die zweite, hier habe ich es zumindest mit Telegramm schon hinbekommen.
            Aktuell entscheide ich in einem anderen Skript wann ein Snapshot von meinen Kameras abgespeichert wird. Ich speichere sie dann unter
            http://192.168.2.12:8081/opt/iobroker/cam/Garten.jpg
            http://192.168.2.12:8081/opt/iobroker/cam/Vorgarten.jpg
            http://192.168.2.12:8081/opt/iobroker/cam/Keller.jpg
            Kann ich die URL dann auch so in dein Skript implemntieren? Du speicherst das Bild ja in einem Datenpunkt.
              @ilovegym
              Ich komme einfach nicht weiter. Ich habe in den letzten Tagen schon so viele Dinge ausprobiert, komme aber nicht ans Ziel. Egal ob ich es zu Fuß in einem Skript versuche oder über den synochat adapter. Der Snapshot kommt nicht in meinem Chat an. Die Doku habe ich mir auch schon ein paar mal durchgelesen.
              Über telegram bekomme ich es hin aber Ziel ist es eigentlich den Syno Chat zu nutzen.
              Über weitere Hilfe, um die Probleme zu identifizieren, würde ich mich sehr freuen.
              Was mich wundert, wenn ich im message DP des Adapters ein Bildlink aus dem Internet eingebe, wird das Bild auch versendet, füge ich die Snapshot URL ein, dann kommt nix an.
                A Former User @Schnubby666 last edited by A Former User
                @schnubby666
                Die Bilder muessen im iobroker-filesystem vorhanden sein, also du musst diese unter Dateien sehen, so wie hier :
                Hochladen z.bsp. mit
                  unlink('0_userdata.0', '/synology/Doorbell.jpg',(e)=>{ if(e) log(e) }) //altes Bild loeschen
                     request({url: URL_Snapshot,encoding: null,},  //Bild holen
                         (error, response, body) => {if (!error && body) {writeFile("0_userdata.0", "/synology/Doorbell.jpg", body, error); //Bild schreiben
                  @ilovegym said in Synology Chat ...:
                  @schnubby666
                  Das ist schon das erste was ich bisher nicht hinbekommen habe.
                  Wenn ich in dem Ordner einen Datenpunkt anlege bekomme ich das nur ohne Endung .jpg hin, sonst erstell er mir einen weiteren Unterordner
                  Wie muss ich den Datenpunkt dort also genau erstellen, damit es so aussieht wie bei dir?
                  Und warum kann ich die Bilder nicht aus/opt/ioBroker/cam herausholen?
                  • Glasfaser
                    Glasfaser @Schnubby666 last edited by Glasfaser
                    @schnubby666 sagte in Synology Chat ...:
                    Warum anlegen !?
                    Der wird automatisch vom Script erstellt wenn das Bild geholt wird und dort unter 0_userdata.0/synology/ gelegt
                      Schnubby666 @Glasfaser last edited by
                      @glasfaser
                      Warum anlegen !?
                      Selbst bei meinen Versuchen vorher wurde es nicht automatisch angelegt
                      Ich hab das mal runtergebrochen auf
                      und die Funktion sieht dann so aus
                      request(
                          url: URL_Snapshot ,
                          encoding: null,
                            writeFile("0_userdata.0", "/Bilder/Garten.jpg", body);
                      Trotzdem wird der Datenpunkt nicht erstellt mit dem Bild
                      • Glasfaser
                        Dann liegt ein Fehler vor ,
                        ändere die URL auf eine andere z.b .
                        https://www.mein-schoener-garten.de/sites/default/files/styles/inline_scaled_l_16_9/public/vergissmeinnicht-13816903-istock.jpg
                          @glasfaser
                          Auch so wird kein Bild dort abgelegt
                          In der Javaskriptinstanz habe ich folgendes auch hinzugefügt
                          • haus-automatisierung
                            haus-automatisierung Developer Most Active @Schnubby666 last edited by
                            request ist deprecated. Bitte nicht mehr verwenden.
                              Schnubby666 @haus-automatisierung last edited by
                              ok, was ist dann zu verwenden?
                              Glasfaser haus-automatisierung 3 Replies Last reply Reply Quote 0
                              • Glasfaser
                                @schnubby666
                                Funktioniert doch :
                                Hier das Blockly :
                                 <variables>
                                   <variable id="u^a{RwAvq(*-0PK`(`@4">URL_Snapshot</variable>
                                 </variables>
                                 <block type="variables_set" id="fT*7tvvXRtyOgN,6C,2?" x="138" y="-537">
                                   <field name="VAR" id="u^a{RwAvq(*-0PK`(`@4">URL_Snapshot</field>
                                     <block type="text" id="N]=+,oldD=_C5-KIA*6[">
                                       <field name="TEXT">https://www.mein-schoener-garten.de/sites/default/files/styles/inline_scaled_l_16_9/public/vergissmeinnicht-13816903-istock.jpg</field>
                                     <block type="procedures_callcustomnoreturn" id=":~_=6funbwt@zxPTkGtT">
                                       <mutation name="Bild_holen"></mutation>
                                 <block type="procedures_defcustomnoreturn" id="Fh|~ouZqovH}}ZEi:0P{" x="138" y="-462">
                                   <mutation statements="false"></mutation>
                                   <field name="NAME">Bild_holen</field>
                                   <field name="SCRIPT">DQoNCg0KcmVxdWVzdCgNCg0KICB7DQoNCiAgICB1cmw6IFVSTF9TbmFwc2hvdCAsDQoNCiAgICBlbmNvZGluZzogbnVsbCwNCg0KICB9LA0KDQogIChlcnJvciwgcmVzcG9uc2UsIGJvZHkpID0+IHsNCg0KICAgIGlmICghZXJyb3IgJiYgYm9keSkgew0KDQogICAgICB3cml0ZUZpbGUoIjBfdXNlcmRhdGEuMCIsICIvc3lub2xvZ3kvYmx1bWUuanBnIiwgYm9keSk7DQoNCiAgICB9DQoNCiAgfQ0KDQopOw0K</field>
                                siehe auch hier ... habe es mal selber gebaut :
                                https://forum.iobroker.net/post/689426
                                S haus-automatisierung 2 Replies Last reply Reply Quote 0
                                  @schnubby666 axios, got, such dir was aus 🙂
                                  • Glasfaser
                                    kein request eintragen , in NPM - Zusätzliche Module !
                                      Schnubby666 @Glasfaser last edited by Schnubby666
                                      @glasfaser said in Synology Chat ...:
                                      Hier das Blockly :
                                      sry, das klappt bei mir nicht
                                      Hab ich auch schon alles gesehen und versucht
                                      ok, wenn ich das raus nehme würde aber der JS-Block nicht mehr funktionieren mit "Bild holen", oder?
                                      • Glasfaser
                                        im Container :
                                        curl -L -o vergissmeinnicht-13816903-istock.jpg https://www.mein-schoener-garten.de/sites/default/files/styles/inline_scaled_l_16_9/public/vergissmeinnicht-13816903-istock.jpg
                                        Ausgabe dazu zeigen
                                          im Container :
                                          mein ioBroker läuft in keinem Container, sondern auf Debian auf einem Raspi, kann ich den Befel dann dort auch eingeben oder brauch ich einen anderen?
                                          • Glasfaser
                                            So weit nach hinten ... habe ich nicht gelesen was du hast ... ging von einer Synology aus .
                                            ja ist auch dafür.
                                            Versuche auch mal danach ein
                                            iob fix
                                            und danch nochmal mein Blockly von oben versuchen !
                                            2390
