    4. ioBroker als Docker & ble.0
    • Glasfaser
      Glasfaser @Mor9oth last edited by
      @mor9oth sagte in ioBroker als Docker & ble.0:
        volume:
            nocopy: true
      gehört nicht in den Compose von ioBroker
        Mor9oth @Glasfaser last edited by
        @glasfaser said in ioBroker als Docker & ble.0:
        Zeige mal die Full Ausgabe von
        iob diag
        denn ... man kennt gar nicht deine Basis !
        Reicht die Summary aus?
                                v.2023-10-10
        Model           : Raspberry Pi 4 Model B Rev 1.1
        Kernel          : aarch64
        Userland        : arm64
        Docker          : v9.1.1
        Installation:           Docker
        Kernel:                 aarch64
        Userland:               arm64
        Timezone:               Etc/UTC
        User-ID:                0
        X-Server:               false
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                /usr/bin/node           v18.19.0
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                /usr/bin/corepack       0.22.0
        Recommended versions are nodejs 18.19.0 and npm 10.2.3
        MEMORY:
        Mem:            4.0G        874M        1.5G        7.4M        1.7G        3.1G
        Swap:           104M          0B        104M
        Total:          4.1G        874M        1.6G
        Active iob-Instances:   4
        Active repo(s): stable
        ioBroker Core:          js-controller           5.0.17
                                admin                   6.13.16
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        Objects:                146
        States:                 108
        Size of iob-Database:
        8.3M    /opt/iobroker/iobroker-data/objects.jsonl
        2.1M    /opt/iobroker/iobroker-data/states.jsonl
        === Mark text until here for copying ===
          Thomas Braun Most Active @Mor9oth last edited by
          Nein. Poste die Langfassung.
            Mor9oth @Thomas Braun last edited by Homoran
            @thomas-braun said in ioBroker als Docker & ble.0:
            ok!
            Skript v.2023-10-10
            *** BASE SYSTEM ***
            cat: /sys/devices/virtual/dmi/id/sys_vendor: No such file or directory
            Hardware Vendor :
            Kernel          : aarch64
            Userland        : arm64
            Docker          : v9.1.1
            Virtualization  : Docker
            Kernel          : aarch64
            Userland        : arm64
            Systemuptime and Load:
             23:54:15 up 1 day,  3:25,  0 user,  load average: 0.79, 0.50, 0.40
            CPU threads: 4
            *** Time and Time Zones ***
            Thu Feb  8 22:54:15 UTC 2024
            Thu Feb  8 23:54:15 CET 2024
            CET +0100
            Etc/UTC
            *** User and Groups ***
            root
            /root
            root
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:
            *** MEMORY ***
            Mem:            4.0G        985M        1.2G        7.4M        1.8G        3.0G
            Swap:           104M          0B        104M
            Total:          4.1G        985M        1.4G
                     3793 M total memory
                      939 M used memory
                     1974 M active memory
                      380 M inactive memory
                     1187 M free memory
                      145 M buffer memory
                     1582 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            *** FILESYSTEM ***
            Filesystem     Type     Size  Used Avail Use% Mounted on
            overlay        overlay  917G  8.9G  871G   2% /
            tmpfs          tmpfs     64M     0   64M   0% /dev
            shm            tmpfs     64M     0   64M   0% /dev/shm
            /dev/root      ext4     917G  8.9G  871G   2% /opt/iobroker
            tmpfs          tmpfs    1.9G     0  1.9G   0% /proc/asound
            tmpfs          tmpfs    1.9G     0  1.9G   0% /sys/firmware
            dmesg: read kernel buffer failed: Operation not permitted
            TARGET           SOURCE        FSTYPE OPTIONS
            /opt/iobroker    /dev/root[/var/lib/docker/volumes/iobroker_data/_data]                                                             ext4   rw,noatime
            /etc/resolv.conf /dev/root[/var/lib/docker/containers/752a4d492d9ce74f0231e9be00680fb7f138089fa1df8aca04cf30a685d9c975/resolv.conf] ext4   rw,noatime
            /etc/hostname    /dev/root[/var/lib/docker/containers/752a4d492d9ce74f0231e9be00680fb7f138089fa1df8aca04cf30a685d9c975/hostname]    ext4   rw,noatime
            /etc/hosts       /dev/root[/var/lib/docker/containers/752a4d492d9ce74f0231e9be00680fb7f138089fa1df8aca04cf30a685d9c975/hosts]       ext4   rw,noatime
            /var:
            16M     /var/
            14M     /var/lib
            13M     /var/lib/dpkg
            12M     /var/lib/dpkg/info
            1.9M    /var/cache
            /opt/iobroker/backups:
            28M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            62M     /opt/iobroker/iobroker-data/
            34M     /opt/iobroker/iobroker-data/backup-objects
            18M     /opt/iobroker/iobroker-data/files
            13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
            8.4M    /opt/iobroker/iobroker-data/objects.jsonl
            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
            2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
            2.6M    /opt/iobroker/iobroker-data/files/ble.admin/build/index.js.map
            2.3M    /opt/iobroker/iobroker-data/states.jsonl
            USB-Devices by-id:
            *** NodeJS-Installation ***
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            nodejs:
              Installed: 18.19.0-1nodesource1
              Candidate: 18.19.0-1nodesource1
              Version table:
             *** 18.19.0-1nodesource1 100
                    100 /var/lib/dpkg/status
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.17
            admin:          6.13.16
            javascript:     "javascript" not found
            Adapters from github:   0
            Adapter State
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            + system.adapter.ble.0                    : ble                   : iobroker                                 -  enabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            + instance is alive
            ioBroker-Repositories
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "backitup"     : 2.9.8    , installed 2.9.8
            Adapter    "ble"          : 0.14.0   , installed 0.14.0
            Controller "js-controller": 5.0.17   , installed 5.0.17
            Objects and States
            Objects:        168
            States:         124
            Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       1494640    -
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1496144    -
            tcp        0      0 127.0.0.11:38775        0.0.0.0:*               LISTEN      0          1491329    -
            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1493783    -
            udp        0      0 127.0.0.11:42246        0.0.0.0:*                           0          1491328    -
            2024-02-08 23:53:28.636  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
            2024-02-08 23:53:30.265  - info: admin.0 (654) Repository received successfully.
            2024-02-08 23:53:31.035  - info: discovery.0 (696) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.17
            2024-02-08 23:53:31.757  - info: host.iobroker instance system.adapter.backitup.0 started with pid 715
            2024-02-08 23:53:31.926  - info: admin.0 (654) failed connection to socket.io from ::ffff:192.168.178.18: Passport was not initialized
            2024-02-08 23:53:34.598  - info: backitup.0 (715) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
            2024-02-08 23:53:34.670  - info: admin.0 (654) ==> Connected system.user.admin from ::ffff:192.168.178.18
            2024-02-08 23:53:34.684  - info: backitup.0 (715) [iobroker] backup will be activated at 02:40 every 1 day(s)
            2024-02-08 23:53:35.813  - error: backitup.0 (715) Error: Command failed: sudo mount :/sharename/backupDir /opt/iobroker/backups
            mount.nfs: Failed to resolve server : Name or service not known
            2024-02-08 23:53:35.950  - info: host.iobroker instance system.adapter.ble.0 started with pid 734
            2024-02-08 23:53:38.231  - info: ble.0 (734) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v18.19.0, js-controller: 5.0.17
            2024-02-08 23:53:38.290  - info: ble.0 (734) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
            2024-02-08 23:53:38.291  - info: ble.0 (734) enabled plugins: _default
            2024-02-08 23:53:38.293  - info: ble.0 (734) monitored services:
            2024-02-08 23:53:38.360  - info: ble.0 (734) starting scanner process...
            2024-02-08 23:53:38.682  - error: ble.0 (734) Cannot find module '@abandonware/bluetooth-hci-socket'
            Require stack:
            - /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js
            - /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/bindings.js
            - /opt/iobroker/node_modules/@abandonware/noble/lib/resolve-bindings.js
            - /opt/iobroker/node_modules/@abandonware/noble/with-custom-binding.js
            - /opt/iobroker/node_modules/@abandonware/noble/index.js
            - /opt/iobroker/node_modules/iobroker.ble/build/scanProcess.js
            iob diag has finished.
              Mor9oth @Glasfaser last edited by Mor9oth
              Hat vielleicht noch jemand anderes hier einen Lösungsansatz?
              Ich lese hier still mit ...
              und finde es amüsant das du Pakete hier installierst
              sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
              und nicht über den Hinweis :
              @marc-berg sagte in ioBroker als Docker & ble.0:
              Dazu gibt es die "PACKAGES" Umgebungsvariable.
              Man sollte nichts manuell in den Container installieren, weil das beim nächsten Deploy wieder weg ist.
              und auch nicht den Hinweis zu "Deploy" beachtest .
              und dazu auch Beta Tester bist :
              image: buanet/iobroker:latest
              Siehe auch hier zu ble :
              https://forum.iobroker.net/post/504523
              Autsch! Da hab ich wohl paar Dinge missverstanden!
              Dein Link hat aber geholfen!
              Das Package ist nun im Stack und das latest habe ich entfernt. Nur das mit dem Device:
                 devices:
                    - "/dev/hci0:/dev/hci0"
              Erzeugt eine Fehlermeldung beim Speichern/Deployen des Stacks.
              So sieht das Stack nun aus:
              version: '3.8'
              services:
                iobroker:
                  container_name: iobroker
                  hostname: iobroker
                  restart: always
                  environment:
                    - PACKAGES=bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
                  networks:
                    macvlan-network:
                      ipv4_address: xxx.xxx.xxx.xxx
                  ports:
                    - '8081:8081'
                  devices:
                  volumes:
                    - type: volume
                      source: data
                      target: /opt/iobroker
              networks:
                macvlan-network:
                  external:
              volumes:
                data:
              Fehlermeldung: "dev/hci0": no such file or directory
                @mor9oth
                versuche mal anstatt den " ein ' und das wirds gewesen sein! >??
                Warum hast du bei MacVlan Ports gemappt? kannste eigentlich weglassen... einfach mal ein # vor die Eintraege machen..
                • Glasfaser
                  Gegenfrage ... was ich so hier von oben noch unten nicht erlese , hast du schon geschaut ob es überhaupt vorhanden ist ( nicht im Docker )
                  mit
                  ls -al /dev/hci*
                    Mor9oth @Guest last edited by
                    @ilovegym said in ioBroker als Docker & ble.0:
                    @mor9oth
                    Habe ich mal versucht mit '' anstatt "". Führt aber beides zum gleichen Fehler.
                    Oh klar, die Ports brauche ich mit MacVlan ja nicht … Danke!
                    • Glasfaser
                      @mor9oth
                      Steht doch da ... nicht vorhanden
                        mit
                        ls -al /dev/hci*
                        Hmm! Ich dachte, dass ich das am Host mit hciconfig auch sehe:
                        Dein Befehl im Host führt aber auch dazu:
                        ls -al /dev/hci*
                        ls: cannot access '/dev/hci*': No such file or directory
                        Ich verstehe halt nicht, warum es nicht mehr durchgereicht wird. Es hatte ja schon mal im MacVlan funktioniert.
                        • Glasfaser
                          ich kenne es nur mit
                          net=host mode
                          und das es nicht per --device funktioniert
                            net=host mode
                            Wenn ich keine Lösung finde, bzw. nicht mehr rekonstruiert bekomme, wie es mal funktioniert hatte, würde ich dann wohl das Netzwerk auf Host ändern um den ble.0 funktionsfähig zu haben.
                            1703
