    4. Nach Update Adapter "admin" 6.13.16 kein Port 8081 mehr
      Homoran Global Moderator Administrators @meute last edited by
      @meute sagte in Nach Update Adapter "admin" 6.13.16 kein Port 8081 mehr:
      Nach kurzem googeln habe ich 4 folgende Befehle gefunden und ausgeführt.
      the internet never forgets
      Befehle von >7 Jahren!
      • meute
        meute @DJMarc75 last edited by
        @djmarc75 sagte in Nach Update Adapter "admin" 6.13.16 kein Port 8081 mehr:
        $ sudo iobroker stop
        iob Befehle NIE mit Sudo anpacken bitte !
        Danke. Das habe ich gleich in meiner Doku vermerkt.
        dann zeig mal die Langfassung von
        iob diag
        Bitte schön:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspi01
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 3 Model B Plus Rev 1.3
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         18:41:24 up  1:36,  1 user,  load average: 0.72, 0.70, 0.42
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        ~ Under-voltage has occurred
        *** Time and Time Zones ***
                       Local time: Fri 2024-02-09 18:41:25 CET
                   Universal time: Fri 2024-02-09 17:41:25 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        mf
        /home/mf
        mf adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            909M        576M        106M        0.0K        227M        274M
        Swap:            99M        3.0M         96M
        Total:          1.0G        579M        202M
                  909 M total memory
                  576 M used memory
                  371 M active memory
                  339 M inactive memory
                  106 M free memory
                    3 M buffer memory
                  223 M swap cache
                   99 M total swap
                    3 M used swap
                   96 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
          UNIT                   LOAD   ACTIVE SUB    DESCRIPTION
        * plymouth-start.service loaded failed failed Show Plymouth Boot Screen
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                              Type      Size  Used Avail Use% Mounted on
        /dev/root                               ext4       15G  8.3G  5.4G  61% /
        devtmpfs                                devtmpfs  325M     0  325M   0% /dev
        tmpfs                                   tmpfs     455M     0  455M   0% /dev/shm
        tmpfs                                   tmpfs     182M  780K  182M   1% /run
        tmpfs                                   tmpfs     5.0M  4.0K  5.0M   1% /run/lock
        /dev/sda1                               vfat      253M   31M  222M  13% /boot
        192.168.23.82:/media/nfs_usb_ssd_backup nfs4      110G   47G   58G  45% /media/raspi02_usb_ssd_backup
        tmpfs                                   tmpfs      91M   20K   91M   1% /run/user/1000
        [Fri Feb  9 17:05:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=fc635420-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Fri Feb  9 17:05:28 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Fri Feb  9 17:05:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Fri Feb  9 17:05:31 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
        TARGET                          SOURCE                                  FSTYPE OPTIONS
        /                               /dev/sda2                               ext4   rw,noatime
        |-/media/raspi02_usb_ssd_backup 192.168.23.82:/media/nfs_usb_ssd_backup nfs4   rw,relatime,vers=4.2,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.23.81,local_lock=none,addr=192.168.23.82
        `-/boot                         /dev/sda1                               vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        3.9G    /var/
        2.2G    /var/lib
        2.0G    /var/lib/docker/overlay2
        1.4G    /var/log/journal/dbb184e505344dae88426d3e21a16a3f
        Archived and active journals take up 1.3G in the file system.
        /opt/iobroker/backups:
        50M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        136M    /opt/iobroker/iobroker-data/
        82M     /opt/iobroker/iobroker-data/files
        35M     /opt/iobroker/iobroker-data/backup-objects
        31M     /opt/iobroker/iobroker-data/files/web.admin/static
        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
        14M     /opt/iobroker/iobroker-data/objects.jsonl
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
        6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
        5.1M    /opt/iobroker/iobroker-data/states.jsonl
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v16.20.2
        /usr/bin/node           v16.20.2
        /usr/bin/npm            8.19.4
        /usr/bin/npx            8.19.4
        /usr/bin/corepack       0.17.0
        nodejs:
          Installed: 16.20.2-deb-1nodesource1
          Candidate: 16.20.2-deb-1nodesource1
          Version table:
         *** 16.20.2-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.13.16
        javascript:     "javascript" not found
        Adapters from github:   0
        Adapter State
          system.adapter.admin.0                  : admin                 : raspi01                                  - disabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alias-manager.0          : alias-manager         : raspi01                                  -  enabled
        + system.adapter.backitup.0               : backitup              : raspi01                                  -  enabled
        + system.adapter.discovery.0              : discovery             : raspi01                                  -  enabled
          system.adapter.fritzdect.0              : fritzdect             : raspi01                                  - disabled
        + system.adapter.influxdb.0               : influxdb              : raspi01                                  -  enabled, port: 8086
        + system.adapter.iqontrol.0               : iqontrol              : raspi01                                  -  enabled
          system.adapter.net-tools.0              : net-tools             : raspi01                                  - disabled
          system.adapter.ping.0                   : ping                  : raspi01                                  - disabled
        + system.adapter.shelly.0                 : shelly                : raspi01                                  -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.sonoff.0                 : sonoff                : raspi01                                  -  enabled, port: 1885, bind: 0.0.0.0
        + system.adapter.web.0                    : web                   : raspi01                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Objects and States
        Objects:        452
        States:         301
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://repos.influxdata.com/debian bullseye InRelease
        Hit:6 https://apt.syncthing.net syncthing InRelease
        Get:7 https://deb.nodesource.com/node_16.x bullseye InRelease [4586 B]
        Fetched 4586 B in 4s (1148 B/s)
        Reading package lists...
        Pending Updates: 4
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13957      477/cupsd
        tcp        0      0 192.168.23.81:8384      0.0.0.0:*               LISTEN      1000       15687      924/syncthing
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37791      1767/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       38548      1767/iobroker.js-co
        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       37840      1811/io.sonoff.0
        tcp        0      0 0.0.0.0:2388            0.0.0.0:*               LISTEN      0          13087      537/sshd: /usr/sbin
        tcp6       0      0 :::80                   :::*                    LISTEN      0          14509      589/apache2
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       39465      1856/io.web.0
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        13257      499/influxd
        tcp6       0      0 :::22000                :::*                    LISTEN      1000       13270      924/syncthing
        tcp6       0      0 :::2388                 :::*                    LISTEN      0          13089      537/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13956      477/cupsd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13782      378/avahi-daemon: r
        udp        0      0 0.0.0.0:50961           0.0.0.0:*                           108        13784      378/avahi-daemon: r
        udp        0      0 0.0.0.0:21027           0.0.0.0:*                           1000       13287      924/syncthing
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       36492      1796/io.shelly.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15482      442/dhcpcd
        udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          13098      -
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13981      731/cups-browsed
        udp        0      0 0.0.0.0:41669           0.0.0.0:*                           1000       15690      924/syncthing
        udp6       0      0 :::5353                 :::*                                108        13783      378/avahi-daemon: r
        udp6       0      0 :::37685                :::*                                108        13785      378/avahi-daemon: r
        udp6       0      0 :::37838                :::*                                1000       15688      924/syncthing
        udp6       0      0 :::22000                :::*                                1000       14635      924/syncthing
        udp6       0      0 :::546                  :::*                                0          15532      442/dhcpcd
        udp6       0      0 :::21027                :::*                                1000       13285      924/syncthing
        udp6       0      0 :::51820                :::*                                0          13099      -
        2024-02-09 18:38:24.796  - info: shelly.0 (1796) [CoAP] Device 192.168.23.112 (shelly1 / shelly1-F4CFA2749BBD / SHSW-1#F4CFA2749BBD#1) connected! Polltime set to 15 sec.
        2024-02-09 18:38:25.514  - info: sonoff.0 (1811) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.20.2, js-controller: 5.0.17
        2024-02-09 18:38:25.666  - info: sonoff.0 (1811) Starting MQTT authenticated  server on port 1885
        2024-02-09 18:38:26.762  - info: shelly.0 (1796) [CoAP] Device 192.168.23.111 (shelly1 / shelly1-500291F08F5D / SHSW-1#500291F08F5D#1) connected! Polltime set to 15 sec.
        2024-02-09 18:38:28.342  - info: host.raspi01 instance system.adapter.backitup.0 started with pid 1841
        2024-02-09 18:38:30.307  - info: discovery.0 (1826) starting. Version 4.2.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.20.2, js-controller: 5.0.17
        2024-02-09 18:38:32.327  - info: host.raspi01 instance system.adapter.web.0 started with pid 1856
        2024-02-09 18:38:34.460  - info: backitup.0 (1841) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.20.2, js-controller: 5.0.17
        2024-02-09 18:38:34.685  - info: backitup.0 (1841) [iobroker] backup will be activated at 02:40 every 1 day(s)
        2024-02-09 18:38:36.351  - info: host.raspi01 instance system.adapter.iqontrol.0 started with pid 1871
        2024-02-09 18:38:38.273  - info: web.0 (1856) starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.web, node: v16.20.2, js-controller: 5.0.17
        2024-02-09 18:38:38.961  - info: web.0 (1856) socket.io server listening on port 8082
        2024-02-09 18:38:38.982  - info: web.0 (1856) http server listening on port 8082
        2024-02-09 18:38:41.642  - info: iqontrol.0 (1871) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.iqontrol, node: v16.20.2, js-controller: 5.0.17
        2024-02-09 18:38:41.814  - info: iqontrol.0 (1871) systemLanguage = de
        2024-02-09 18:38:41.817  - info: iqontrol.0 (1871) Creating Passphrase...
        2024-02-09 18:38:41.834  - info: iqontrol.0 (1871) Creating Popup States...
        2024-02-09 18:38:42.068  - info: iqontrol.0 (1871) Creating Widget States...
        2024-02-09 18:38:42.071  - info: iqontrol.0 (1871) Lists deactivated.
        2024-02-09 18:38:42.072  - info: iqontrol.0 (1871) Deleting unused Objects...
        2024-02-09 18:38:42.075  - info: iqontrol.0 (1871) Subscribing to states...
        2024-02-09 18:38:42.080  - info: iqontrol.0 (1871) iQontrol ready.
        2024-02-09 18:38:50.099  - info: sonoff.0 (1811) Client [Stromzaehler] connected with secret 1707500330082_5136
        2024-02-09 18:39:04.899  - info: web.0 (1856) ==> Connected system.user.admin from ::ffff:192.168.23.27
        2024-02-09 18:39:08.885  - info: web.0 (1856) <== Disconnect system.user.admin from ::ffff:192.168.23.27 iqontrol.0
                                v.2023-10-10
                 Icon name: computer
              Architecture: arm64
        Installation:           native
        Kernel:                 aarch64
        Userland:               arm64
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        X-Server:               false
        Pending OS-Updates:     4
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v16.20.2
                                /usr/bin/npm            8.19.4
                                /usr/bin/npx            8.19.4
        Recommended versions are nodejs  and npm
        MEMORY:
        Mem:            909M        518M         77M        0.0K        313M        327M
        Swap:            99M         99M        0.0K
        Total:          1.0G        618M         77M
        Active iob-Instances:   8
        ioBroker Core:          js-controller           5.0.17
                                admin                   6.13.16
        Objects type: jsonl
        States  type: jsonl
        Objects:                452
        States:                 301
        Size of iob-Database:
        5.2M    /opt/iobroker/iobroker-data/states.jsonl
        Glasfaser DJMarc75 2 Replies Last reply Reply Quote 0
        • Glasfaser
          Glasfaser @meute last edited by
          @meute
          iob start admin
          meute 1 Reply Last reply Reply Quote 1
          • Codierknecht
            Codierknecht Developer Most Active last edited by
            @meute
            Node und NPM sind steinalt.
            Die gehören dringend auf aktuellen Stand.
            Aber nicht wieder googeln.
            https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-16-und-18
            meute 1 Reply Last reply Reply Quote 2
            • DJMarc75
              DJMarc75 @meute last edited by
              @meute System nicht aktuell, Hardware zu schwach (RPI3 - 1GB Ram)
              Codierknecht meute 2 Replies Last reply Reply Quote 0
              • Codierknecht
                Codierknecht Developer Most Active @DJMarc75 last edited by
                @djmarc75
                Stimmt auch wieder. Mit so einer kleinen Kiste wird das eher nix.
                @meute
                Du solltest mal in neue Hardware investieren.
                Einen Pi 3 mit 1GB kann man heute höchstens noch zum „reinschnuppern“ verwenden.
                Für ein Produktivsystem ist der kaum zu gebrauchen.
                • Meister Mopper
                  Meister Mopper last edited by
                  @homoran sagte in Nach Update Adapter "admin" 6.13.16 kein Port 8081 mehr:
                  Diese Äußerung habe ich von dir schon häufiger gelesen, und doch bin ich der Meinung, dass ihr mit dem Archivieren und Vorhalten von alten (und teils nicht mehr gültigen Informationen) zur Verwirrung beitragt.
                  Vor ein paar Jahren betreute ich eine Projektseite hospitalkonzert.de. Dort wurden Konzerte präsentiert.
                  Die Seite habe ich entfernt und man findet noch ein paar google Einträge über die Seite aber sicherlich keine Inhalte mehr, zumindest ist es mir noch nicht gelungen, irgendwelche Inhalte zu laden.
                  Da sollte meines Erachtens ein Umdenken erfolgen, damit endlich diese z. B. sudo iobroker Miseren ein Ende haben.
                  Homoran Michael Schmitt 2 Replies Last reply Reply Quote 0
                    Homoran Global Moderator Administrators @Meister Mopper last edited by Homoran
                    @meister-mopper sagte in Nach Update Adapter "admin" 6.13.16 kein Port 8081 mehr:
                    wenn das so wäre, gäbe ich dir recht.
                    aber ich weiß nicht was @meute gefunden hat und wo.
                    wahrscheinlich sogar hier im Forum. Da gibt es ebenfalls Beiträge aus 2014/15 in denen noch sudo verwendet wurde, da es damals die heutige Rechtevergabe noch nicht fab.
                    in den letzten archivierten Dokumenten sollte schon längst kein sudo in Verbindung mit ioBroker mehr drin sein
                    spätestens wenn irgendwelche User ihre sudo iobroker... Konstrukte gepostet haben findet google diese. Auch wenn sue zu dem Zeitpunkt des Postens schon lange obsolet waren.
                    Wer soll das alles prüfen und korrigieren?
                    und das noch ohne den "historischen Zusammenhang" zu zerstören
                    • Michael Schmitt
                      Michael Schmitt @Meister Mopper last edited by
                      @meister-mopper
                      https://web.archive.org/web/20131007171024/http://hospitalkonzert.de/index.php
                      • meute
                        meute @Glasfaser last edited by meute
                        @glasfaser sagte in Nach Update Adapter "admin" 6.13.16 kein Port 8081 mehr:
                        iob start admin
                        Besten Dank. Das war die Lösung. Läuft auch noch nach einem Neustart.
                        Dann war nur der Adapter aus.
                        Das disabled ist mir nach iob diag auch aufgefallen.
                        Ein Thin Client mit Proxmox und ioBroker im LXC-Container steht schon einige Zeit da.
                        Aber ich kam noch nicht dazu, den umzuziehen.
                        Zeit ist endlich...
                          gab es hier im Editor nicht mal eine Inline-Codierung
                          die gibt es immer noch!
                          must du nur manuell mit `immer` machen
                          • meute
                            meute @Codierknecht last edited by
                            @codierknecht sagte in Nach Update Adapter "admin" 6.13.16 kein Port 8081 mehr:
                            @meute
                            Habe ich gemacht.
                            Das sollte jetzt passen:
                            $ type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            /usr/bin/npx
                            v18.19.0
                            v18.19.0
                            10.2.3
                            10.2.3
                            • Meister Mopper
                              Meister Mopper @Michael Schmitt last edited by
                              @michael-schmitt sagte in Nach Update Adapter "admin" 6.13.16 kein Port 8081 mehr:
                              @meister-mopper
                              Sehr gut, hast du das ergoogelt?
                              Würde mich interessieren, es war mir allerdings unbekannt, dass es ein solches Archiv gibt.
                              Vielen Dank.
                              Ich glaube aber nicht, dass @meute dort nachgesehen hat.
                              Michael Schmitt 1 Reply Last reply Reply Quote 0
                              • Michael Schmitt
                                @meister-mopper
                                Ich kannte die Seite schon davor (Wayback Machine). Hatte da mal nach meiner alten Clan Homepage gesucht.
                                • meute
                                  meute @DJMarc75 last edited by meute
                                  sudo iobroker stop
                                  sudo iobroker update
                                  sudo iobroker upgrade self
                                  sudo iobroker start
                                  eher für den JS-Controller !
                                  @meister-mopper
                                  Nein, da habe ich sicher nicht nachgesehen. 😊
                                  Ich löse auf:
                                  Diese Seite hatte ich mir auf die Schnelle für meinen Eingangsbeitrag ergoogelt:
                                  https://forum.iobroker.net/topic/72452/update-js-controller-3-x-auf-5-x-funktioniert-nicht?_=1707646843801
                                  Ich hatte die Hoffnung, dass ein ioBroker-Update das admin-Adapter-Problem fixt.
                                  Ich wusste zu dem Zeitpunkt ja noch nicht, dass der admin-Adapter nur disabled ist.
                                    Ich löse auf:
                                    DANKE!
                                    also wie vermutet
                                    • meute
                                      @meute
                                      Zeit ist endlich...
                                      Ich habe heute über Mittag den ioBroker auf den Proxmox-Thin Client in einen LXC-Container umgezogen.
                                      Vorbereitet hatte ich das ja schon die letzten Wochen.
                                      Aktuell hat ioBroker 2 GB RAM.
                                      Reicht das oder sollte ich mehr geben?
                                                              v.2023-10-10
                                       Static hostname: iobroker84
                                             Icon name: computer-container
                                               Chassis: container ?
                                        Virtualization: lxc
                                                Kernel: Linux 6.5.11-8-pve
                                          Architecture: x86-64
                                      Installation:           lxc
                                      Kernel:                 x86_64
                                      Userland:               amd64
                                      User-ID:                1000
                                      X-Server:               false
                                      Boot Target:            graphical.target
                                      Pending OS-Updates:     0
                                      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                              /usr/bin/node           v18.19.0
                                                              /usr/bin/npm            10.2.3
                                                              /usr/bin/npx            10.2.3
                                                              /usr/bin/corepack       0.22.0
                                      Recommended versions are nodejs 18.19.0 and npm 10.2.3
                                      MEMORY:
                                      Mem:            2.1G        1.5G         88M        1.5M        528M        616M
                                      Swap:           536M         37M        499M
                                      Total:          2.7G        1.6G        587M
                                      Active iob-Instances:   9
                                                              admin                   6.13.16
                                      Objects type: jsonl
                                      States  type: jsonl
                                      + system.adapter.admin.0                  : admin                 : iobroker84                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.web.0                    : web                   : iobroker84                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      Objects:                468
                                      States:                 324
                                      22M     /opt/iobroker/iobroker-data/objects.jsonl
                                      6.7M    /opt/iobroker/iobroker-data/states.jsonl
                                      • DJMarc75
                                        4 GB wären eher sinnvoll da ja schon:
                                        MEMORY:               total        used        free      shared  buff/cache   available
                                        was läuft denn da noch ausser ioBroker drauf ?
                                        meute 1 Reply Last reply Reply Quote 0
                                        • meute
                                          Eine InfluxDB läuft noch, in der die Werte des Stromzähler gespeichert werden.
                                          Nutzen/testen will ich demnächst mal den Adapter eCharts.
                                          Das war der Auslöser, warum ich überhaupt auf Proxmox bin.
                                          Den wollte ich Ende 2023 installieren und der RPi ging in die Grätsche.
                                          Gibt auch hier einen Thread von mir zu dem Thema.
                                          Ich werde dem ioBroker dann mal 4 GB geben.
                                          • Glasfaser
                                            aber nicht im gleichen Container !?
                                            @DJMarc75 fragt nur nach , da noch 88M frei sind .
                                            1571
