    4. vis Editor "Verbindungsfehler"
    • haselchen
      haselchen Most Active @Roelli last edited by
      @roelli
      Warum Iobroker unter Port 7777 ?
        Thomas Braun Most Active @Roelli last edited by
        @roelli sagte in vis Editor "Verbindungsfehler":
        Pending OS-Updates: 42
        Aktuell halten.
        Und bitte die Langfassung von
        iob diag
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: iobroker-lxc
                   Icon name: computer-container
                     Chassis: container
              Virtualization: lxc
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 5.15.126-1-pve
                Architecture: x86-64
          model name      : AMD Ryzen 9 4900H with Radeon Graphics
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : amd64
          Systemuptime and Load:
           16:16:47 up 24 min,  1 user,  load average: 4.91, 4.50, 3.92
          CPU threads: 16
          *** Time and Time Zones ***
                         Local time: Sat 2024-02-10 16:16:47 CET
                     Universal time: Sat 2024-02-10 15:16:47 UTC
                           RTC time: n/a
                        NTP service: inactive
                    RTC in local TZ: no
          *** User and Groups ***
          iobroker
          /home/iobroker
          iobroker tty dialout audio video redis
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:             16G        7.9G        6.9G        0.0K        1.6G        8.5G
          Swap:           8.2G          0B        8.2G
          Total:           24G        7.9G         15G
                  16384 M total memory
                   7898 M used memory
                    669 M active memory
                   8309 M inactive memory
                   6890 M free memory
                      0 M buffer memory
                   1594 M swap cache
                   8191 M total swap
                      0 M used swap
                   8191 M free swap
          *** FAILED SERVICES ***
            UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
          * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
          * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
          * nut-driver.service            loaded failed failed Network UPS Tools - power device driver controller
          * nut-monitor.service           loaded failed failed Network UPS Tools - power device monitor and shutdown controller
          * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          5 loaded units listed.
          *** FILESYSTEM ***
          Filesystem                       Type      Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--201--disk--1 ext4       63G   24G   36G  40% /
          none                             tmpfs     492K  4.0K  488K   1% /dev
          udev                             devtmpfs   16G     0   16G   0% /dev/tty
          tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
          tmpfs                            tmpfs     6.2G  488K  6.2G   1% /run
          tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs                            tmpfs     3.1G     0  3.1G   0% /run/user/0
          tmpfs                            tmpfs     3.1G     0  3.1G   0% /run/user/1000
          [sudo] password for iobroker:
          Sorry, try again.
          dmesg: read kernel buffer failed: Operation not permitted
          TARGET SOURCE                           FSTYPE OPTIONS
          /      /dev/mapper/pve-vm--201--disk--1 ext4   rw,relatime,stripe=16
          /var:
          15G     /var/
          14G     /var/lib
          13G     /var/lib/docker
          9.0G    /var/lib/docker/containers/66af97a102d568e200f457413a4542fc75b1add1081eb2cd0a8d88ba309befcd
          Archived and active journals take up 93.4M in the file system.
          /opt/iobroker/backups:
          2.7G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.1G    /opt/iobroker/iobroker-data/
          546M    /opt/iobroker/iobroker-data/files
          190M    /opt/iobroker/iobroker-data/backup-objects
          156M    /opt/iobroker/iobroker-data/esphome.0/.esphome
          find: Failed to change directory: /root: Permission denied
          find: Failed to restore initial working directory: /root: Permission denied
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          /usr/bin/corepack       0.22.0
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
           *** 18.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                  500 http://security.debian.org bullseye-security/main amd64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          At least one iobroker host is running.
          Objects type: redis
          States  type: redis
          Core adapters versions
          js-controller:  5.0.17
          admin:          6.13.16
          javascript:     7.1.6
          Adapters from github:   5
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker-lxc                             -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker-lxc                             -  enabled
          + system.adapter.artnet.0                 : artnet                : iobroker-lxc                             -  enabled, port: 6454
          + system.adapter.backitup.0               : backitup              : iobroker-lxc                             -  enabled
          + system.adapter.bring.0                  : bring                 : iobroker-lxc                             -  enabled
          + system.adapter.cloud.0                  : cloud                 : iobroker-lxc                             -  enabled
          + system.adapter.countdown.0              : countdown             : iobroker-lxc                             -  enabled
          + system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker-lxc                             -  enabled
          + system.adapter.daikin.0                 : daikin                : iobroker-lxc                             -  enabled
          + system.adapter.daikin.1                 : daikin                : iobroker-lxc                             -  enabled
          + system.adapter.daikin.2                 : daikin                : iobroker-lxc                             -  enabled
          + system.adapter.daikin.3                 : daikin                : iobroker-lxc                             -  enabled
          + system.adapter.daikin.4                 : daikin                : iobroker-lxc                             -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker-lxc                             -  enabled
          + system.adapter.device-reminder.0        : device-reminder       : iobroker-lxc                             -  enabled
          + system.adapter.device-watcher.0         : device-watcher        : iobroker-lxc                             -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker-lxc                             -  enabled
          + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker-lxc                             -  enabled
          + system.adapter.email.0                  : email                 : iobroker-lxc                             -  enabled
          + system.adapter.fakeroku.0               : fakeroku              : iobroker-lxc                             -  enabled
          + system.adapter.followthesun.0           : followthesun          : iobroker-lxc                             -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : iobroker-lxc                             -  enabled
          + system.adapter.geofency.0               : geofency              : iobroker-lxc                             -  enabled, port: 7999, bind: 0.0.0.0
          + system.adapter.geofency.1               : geofency              : iobroker-lxc                             -  enabled, port: 7999, bind: 0.0.0.0
          + system.adapter.harmony.0                : harmony               : iobroker-lxc                             -  enabled
          + system.adapter.hass.0                   : hass                  : iobroker-lxc                             -  enabled, port: 8123
          + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker-lxc                             -  enabled
          + system.adapter.hikvision-alarmserver.0  : hikvision-alarmserver : iobroker-lxc                             -  enabled, port: 8089, bind: 192.168.64.3
          + system.adapter.history.0                : history               : iobroker-lxc                             -  enabled
            system.adapter.ical.0                   : ical                  : iobroker-lxc                             -  enabled
            system.adapter.iceroad.0                : iceroad               : iobroker-lxc                             -  enabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-lxc                             - disabled
          + system.adapter.influxdb.0               : influxdb              : iobroker-lxc                             -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : iobroker-lxc                             -  enabled
          + system.adapter.iot.0                    : iot                   : iobroker-lxc                             -  enabled
            system.adapter.javascript.0             : javascript            : iobroker-lxc                             -  enabled
            system.adapter.javascript.1             : javascript            : iobroker-lxc                             -  enabled
            system.adapter.life360.0                : life360               : iobroker-lxc                             - disabled
          + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker-lxc                             -  enabled
          + system.adapter.modbus.0                 : modbus                : iobroker-lxc                             -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker-lxc                             -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.net-tools.0              : net-tools             : iobroker-lxc                             -  enabled
            system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker-lxc                             -  enabled
          + system.adapter.netatmo-energy.0         : netatmo-energy        : iobroker-lxc                             -  enabled
          + system.adapter.netatmo-energy.1         : netatmo-energy        : iobroker-lxc                             -  enabled
          + system.adapter.netatmo-energy.2         : netatmo-energy        : iobroker-lxc                             -  enabled
          + system.adapter.netatmo-energy.3         : netatmo-energy        : iobroker-lxc                             -  enabled
          + system.adapter.nina.0                   : nina                  : iobroker-lxc                             -  enabled
            system.adapter.odl.0                    : odl                   : iobroker-lxc                             -  enabled
          + system.adapter.onvif.0                  : onvif                 : iobroker-lxc                             -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
            system.adapter.owntracks.0              : owntracks             : iobroker-lxc                             - disabled, port: 1883, bind: 127.0.0.1
          + system.adapter.parser.1                 : parser                : iobroker-lxc                             -  enabled
          + system.adapter.ping.0                   : ping                  : iobroker-lxc                             -  enabled
          + system.adapter.proxmox.0                : proxmox               : iobroker-lxc                             -  enabled, port: 8006
          + system.adapter.proxmox.1                : proxmox               : iobroker-lxc                             -  enabled, port: 8006
          + system.adapter.radar2.0                 : radar2                : iobroker-lxc                             -  enabled
          + system.adapter.scenes.0                 : scenes                : iobroker-lxc                             -  enabled
            system.adapter.schoolfree.0             : schoolfree            : iobroker-lxc                             -  enabled
          + system.adapter.shelly.0                 : shelly                : iobroker-lxc                             -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker-lxc                             -  enabled
          + system.adapter.simple-api.0             : simple-api            : iobroker-lxc                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : iobroker-lxc                             -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-lxc                             -  enabled
          + system.adapter.telegram.0               : telegram              : iobroker-lxc                             -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : iobroker-lxc                             -  enabled
          + system.adapter.time-switch.0            : time-switch           : iobroker-lxc                             -  enabled
          + system.adapter.tr-064.0                 : tr-064                : iobroker-lxc                             -  enabled
          + system.adapter.tractive-gps.0           : tractive-gps          : iobroker-lxc                             -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker-lxc                             -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker-lxc                             -  enabled
          + system.adapter.unifi.0                  : unifi                 : iobroker-lxc                             -  enabled
          + system.adapter.vds2465-server.0         : vds2465-server        : iobroker-lxc                             -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-lxc                             -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-lxc                             -  enabled
            system.adapter.vis.0                    : vis                   : iobroker-lxc                             -  enabled
          + system.adapter.web.0                    : web                   : iobroker-lxc                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.windows-control.0        : windows-control       : iobroker-lxc                             -  enabled
          + system.adapter.wled.0                   : wled                  : iobroker-lxc                             -  enabled
          + system.adapter.ws.0                     : ws                    : iobroker-lxc                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.yahka.1                  : yahka                 : iobroker-lxc                             -  enabled
            system.adapter.yr.0                     : yr                    : iobroker-lxc                             -  enabled
          + system.adapter.zigbee.0                 : zigbee                : iobroker-lxc                             -  enabled, port: tcp://192.168.64.6:20108
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "adguard"      : 0.0.8    , installed 0.0.8
          Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
          Adapter    "artnet"       : 1.2.2    , installed 1.2.2
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Adapter    "ble"          : 0.14.0   , installed 0.14.0
          Adapter    "bring"        : 1.8.4    , installed 1.8.4
          Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
          Adapter    "countdown"    : 2.2.0    , installed 2.2.0
          Adapter    "daikin"       : 1.4.2    , installed 1.4.2
          Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
          Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
          Adapter    "device-reminder": 3.1.2  , installed 3.1.2
          Adapter    "device-watcher": 2.9.6   , installed 2.9.14
          Adapter    "doorio"       : 2.1.4    , installed 2.1.4
          Adapter    "drag-indicator": 2.1.4   , installed 2.1.4
          Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
          Adapter    "email"        : 1.2.2    , installed 1.2.2
          Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
          Adapter    "followthesun" : 0.5.0    , installed 0.5.0
          Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
          Adapter    "geofency"     : 1.2.4    , installed 1.2.4
          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
          Adapter    "harmony"      : 1.3.0    , installed 1.3.0
          Adapter    "hass"         : 1.4.0    , installed 1.4.0
          Adapter    "heatingcontrol": 2.12.3  , installed 2.12.3
          Adapter    "hikvision-alarmserver": 0.1.0, installed 0.1.0
          Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
          Adapter    "imap"         : 0.1.1    , installed 0.1.1
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "material"     : 1.3.1    , installed 1.3.1
          Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
          Adapter    "modbus"       : 6.1.0    , installed 6.1.0
          Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
          Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
          Adapter    "netatmo-energy": 2.7.3   , installed 2.7.3
          Adapter    "nina"         : 0.0.25   , installed 0.0.25
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "odl"          : 3.0.1    , installed 3.0.1
          Adapter    "onvif"        : 1.1.1    , installed 1.1.1
          Adapter    "owntracks"    : 1.0.5    , installed 1.0.5
          Adapter    "parcel"       : 0.0.27   , installed 0.0.27
          Adapter    "parser"       : 2.1.0    , installed 2.1.0
          Adapter    "pegelalarm"   : 1.3.2    , installed 1.3.2
          Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
          Adapter    "radar2"       : 2.1.0    , installed 2.1.0
          Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "telegram"     : 3.0.1    , installed 3.0.1
          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "traccar"      : 1.1.4    , installed 1.1.4
          Adapter    "tractive-gps" : 1.1.0    , installed 1.1.0
          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
          Adapter    "tuya"         : 3.15.0   , installed 3.15.0
          Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
          Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
          Adapter    "unifi"        : 0.6.7    , installed 0.6.7
          Adapter    "upnp"         : 1.0.21   , installed 1.0.21
          Adapter    "vds2465-server": 0.1.10  , installed 0.1.10
          Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "web"          : 6.2.3    , installed 6.2.3
          Adapter    "windows-control": 0.1.5  , installed 0.1.5
          Adapter    "wled"         : 0.7.2    , installed 0.7.2
          Adapter    "ws"           : 2.5.10   , installed 2.5.10
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "yr"           : 5.3.0    , installed 5.3.0
          Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
          Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
          Objects and States
          Objects:        340478
          States:         199813
          Hit:1 http://security.debian.org bullseye-security InRelease
          Hit:2 http://ftp.debian.org/debian bullseye InRelease
          Hit:3 https://download.docker.com/linux/debian bullseye InRelease
          Hit:4 http://ftp.debian.org/debian bullseye-updates InRelease
          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Hit:6 https://packages.redis.io/deb bullseye InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          24912460   2251/upsd
          tcp        0      0 127.0.0.1:33305         0.0.0.0:*               LISTEN      1000       24932911   5470/io.yahka.1
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          25137443   42131/master
          tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          25128734   43521/docker-proxy
          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      110        25137584   42449/redis-server
          tcp        0      0 0.0.0.0:10001           0.0.0.0:*               LISTEN      0          25136625   43495/docker-proxy
          tcp        0      0 0.0.0.0:10003           0.0.0.0:*               LISTEN      0          25136601   43429/docker-proxy
          tcp        0      0 0.0.0.0:10002           0.0.0.0:*               LISTEN      0          25142292   43449/docker-proxy
          tcp        0      0 0.0.0.0:10005           0.0.0.0:*               LISTEN      0          25132519   43381/docker-proxy
          tcp        0      0 0.0.0.0:10004           0.0.0.0:*               LISTEN      0          25136584   43409/docker-proxy
          tcp        0      0 192.168.64.3:8089       0.0.0.0:*               LISTEN      1000       24917524   2383/io.hikvision-a
          tcp        0      0 0.0.0.0:4100            0.0.0.0:*               LISTEN      1000       24912194   1867/io.vds2465-ser
          tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        24896898   110/systemd-resolve
          tcp        0      0 192.168.64.3:9093       0.0.0.0:*               LISTEN      1000       24939777   5941/io.fakeroku.0
          tcp        0      0 0.0.0.0:8086            0.0.0.0:*               LISTEN      0          25135939   43320/docker-proxy
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          24902935   1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25124645   42354/sshd: /usr/sb
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        24896904   110/systemd-resolve
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       24901378   1814/io.sonoff.0
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       24898331   1582/io.mqtt.0
          tcp        0      0 0.0.0.0:34027           0.0.0.0:*               LISTEN      1000       24925114   5470/io.yahka.1
          tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      0          25132495   43277/docker-proxy
          tcp6       0      0 :::61991                :::*                    LISTEN      1000       24918297   2359/io.harmony.0
          tcp6       0      0 :::8765                 :::*                    LISTEN      0          25128739   43528/docker-proxy
          tcp6       0      0 :::10001                :::*                    LISTEN      0          25135952   43502/docker-proxy
          tcp6       0      0 :::10003                :::*                    LISTEN      0          25132529   43435/docker-proxy
          tcp6       0      0 :::10002                :::*                    LISTEN      0          25137746   43457/docker-proxy
          tcp6       0      0 :::10005                :::*                    LISTEN      0          25135943   43394/docker-proxy
          tcp6       0      0 :::10004                :::*                    LISTEN      0          25142283   43417/docker-proxy
          tcp6       0      0 :::9443                 :::*                    LISTEN      0          25128700   43291/portainer
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          25137444   42131/master
          tcp6       0      0 :::5355                 :::*                    LISTEN      104        24896901   110/systemd-resolve
          tcp6       0      0 :::7777                 :::*                    LISTEN      1000       24902118   1009/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       24935725   5167/io.web.0
          tcp6       0      0 :::8084                 :::*                    LISTEN      1000       24934282   5731/io.ws.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       24922647   4237/io.simple-api.
          tcp6       0      0 :::8086                 :::*                    LISTEN      0          25136573   43328/docker-proxy
          tcp6       0      0 :::8000                 :::*                    LISTEN      0          25137740   43291/portainer
          tcp6       0      0 :::7999                 :::*                    LISTEN      1000       24897177   1465/io.geofency.0
          tcp6       0      0 ::1:3493                :::*                    LISTEN      0          24912461   2251/upsd
          tcp6       0      0 :::33673                :::*                    LISTEN      1000       24925115   5470/io.yahka.1
          tcp6       0      0 :::111                  :::*                    LISTEN      0          24902937   1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          25124647   42354/sshd: /usr/sb
          tcp6       0      0 :::3000                 :::*                    LISTEN      0          25136558   43283/docker-proxy
          tcp6       0      0 ::1:6379                :::*                    LISTEN      110        25137585   42449/redis-server
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       24939778   5941/io.fakeroku.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       24925116   5470/io.yahka.1
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       24925111   5470/io.yahka.1
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       24925070   5411/io.wled.0
          udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        24896897   110/systemd-resolve
          udp        0   1280 0.0.0.0:38293           0.0.0.0:*                           1000       24992278   2073/io.artnet.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       24905690   1786/io.shelly.0
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       24898507   1840/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       24898508   1840/io.tuya.0
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       24918298   2359/io.harmony.0
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        24896903   110/systemd-resolve
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           1000       24910383   1746/io.radar2.0
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          24902936   1/init
          udp6       0      0 :::5355                 :::*                                104        24896900   110/systemd-resolve
          udp6       0      0 :::111                  :::*                                0          24902938   1/init
          2024-02-10 16:15:24.043  - warn: influxdb.0 (1098) Error on writePoint("{"value":3738,"time":"2024-02-10T15:15:23.994Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: connect ECONNREFUSED 127.0.0.1:8086 / "connect ECONNREFUSED 127.0.0.1:8086""
          2024-02-10 16:15:25.576  - warn: shelly.0 (1786) Cannot get view: NOSCRIPT No matching script. Please use EVAL.
          2024-02-10 16:15:25.577  - error: shelly.0 (1786) ReplyError: NOSCRIPT No matching script. Please use EVAL.
          2024-02-10 16:15:34.045  - info: influxdb.0 (1098) Connecting http://localhost:8086/ ...
          2024-02-10 16:15:34.045  - info: influxdb.0 (1098) Influx DB Version used: 1.x
          2024-02-10 16:15:34.049  - error: influxdb.0 (1098) Error: socket hang up
          2024-02-10 16:15:37.256  - error: host.iobroker-lxc Could not execute primary host determination: NOSCRIPT No matching script. Please use EVAL.
          2024-02-10 16:15:44.049  - info: influxdb.0 (1098) Connecting http://localhost:8086/ ...
          2024-02-10 16:15:44.050  - info: influxdb.0 (1098) Influx DB Version used: 1.x
          2024-02-10 16:15:47.514  - error: javascript.0 (1135) Objects database error: write EPIPE
          2024-02-10 16:15:47.533  - error: javascript.0 (1135) States database error: write EPIPE
          2024-02-10 16:16:00.012  - info: host.iobroker-lxc instance system.adapter.yr.0 started with pid 46200
          2024-02-10 16:16:01.506  - info: yr.0 (46200) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v18.19.0, js-controller: 5.0.17
          2024-02-10 16:16:01.513  - info: yr.0 (46200) longitude/longitude not set, get data from system
          2024-02-10 16:16:01.523  - info: yr.0 (46200) system latitude: 51.2374097 longitude: 6.4129197
          2024-02-10 16:16:11.537  - info: yr.0 (46200) Data updated.
          2024-02-10 16:16:11.538  - info: yr.0 (46200) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-02-10 16:16:12.049  - info: host.iobroker-lxc instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-02-10 16:16:20.977  - info: influxdb.0 (1098) Store 29 buffered influxDB history points
          2024-02-10 16:16:21.027  - warn: fullybrowser.0 (2333) [REST] 192.168.77.128: Sending command get axiosGetDevicesInfo  failed: No response
          2024-02-10 16:16:48.013  - info: host.iobroker-lxc instance system.adapter.odl.0 started with pid 47702
          2024-02-10 16:16:49.745  - info: odl.0 (47702) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.odl, node: v18.19.0, js-controller: 5.0.17
          2024-02-10 16:16:51.174  - info: odl.0 (47702) Terminated (NO_ERROR): Without reason
          2024-02-10 16:16:51.687  - info: host.iobroker-lxc instance system.adapter.odl.0 terminated with code 0 (NO_ERROR)
          2024-02-10 16:17:21.027  - warn: fullybrowser.0 (2333) [REST] 192.168.77.128: Sending command get axiosGetDevicesInfo  failed: No response
          Glasfaser 2 Replies Last reply Reply Quote 0
            Roelli @haselchen last edited by
            @haselchen sagte in vis Editor "Verbindungsfehler":
            @roelli
            Weis auch nicht mehr genau. Irgendwas wollte in der Vergangenheit auch mal 8082 sein, hab dann ioBroker von 8082 auf 7777 gemacht. Nicht so gut? Hat 3 Jahre funktioniert bisher.
              @roelli
              Leg dir einen User an und hantiere mit dem.
              Der user 'iobroker' ist nicht dafür gedacht und vorgesehen.
                Roelli @Thomas Braun last edited by
                @thomas-braun sagte in vis Editor "Verbindungsfehler":
                Aktuell halten.
                Update hab ich jetzt gemacht. Jetzt ist's schlimmer als vorher. 🙂
                Javascript Adapter hat Wackelkontakt... geht an.. geht kaputt.. geht an... geht kaputt...
                Machst Du auch virtuelle Hausbesuche per Teamviewer gegen Stundenlohn? Besser wenn man jemand drüber guckt der schlauer ist als ich!
                  Aktuell halten.
                  Die OS-Updates haben aber nix (unmittelbar) mit dem ioBroker zu tun.
                  Nein. Mit TeamViewer ohnehin nicht, weil das kein Werkzeug für einen Server ist. Da geht man ausschließlich per SSH/einem Terminal drauf.
                    Und der sagt dazu nichts im LogFile?
                    • wendy2702
                      wendy2702 last edited by
                      Das VIS Problem lässt sich vermutlich durch eine zweite WEB Instanz lösen.
                      Dazu gibt es hier schon Beiträge. Da ich aber gerade unterwegs bin ist die Suche für mich danach kein Thema.
                        Garnix! Dafür verbraucht die javascript Instanz jetzt so zwischen 800MB und 1,2GB. Fühlt sich eher viel an.
                          @roelli
                          Hast du denn den LXC gescheit eingerichtet? Mit einem user? Siehe:
                          https://www.iobroker.net/#de/documentation/install/proxmox.md
                          • Glasfaser
                            Glasfaser @Roelli last edited by
                            Objects: 340478
                            States: 199813
                            Mhh ... was ist das 🤔 ...
                            Du toppst ja die Objects und States in Rekordhöhe !
                              @roelli
                              Eher nicht gescheit eingerichtet. Damals gab's dieses praktische Tutorial nocht nicht. Das hatte mein "Linux-Kumpel" eingerichtet.
                              Ist immer noch meine erste ioBroker Installation von vor Jahren. Als man z.B. noch Datenpunkte direkt im Javascript-Adapter erstellt hatte.
                              Was muss ich tun? Alles nochmal neu machen, diese mal nach Anleitung und dann Backup aus dem Backitup-Adapter einspielen? Hab ganz doll Angst. Willst Du das nicht für mich machen? 100€/h? (ich arbeite nämlich schon 12h/Tag von Montags-Sonntags) Ich hab heute so viele Lichtschalter manuell! betätigt wie noch nie. 🙂 Ging früher irgenwie alles automatisch. 😉
                                Roelli @Glasfaser last edited by
                                @glasfaser sagte in vis Editor "Verbindungsfehler":
                                Objects: 340478
                                States: 199813
                                Vermutlich ein unfreiwilliger Rekord! 🙂 Aber ich weis auch nicht wie ich das weg bekomme.
                                  Wäre ein Ansatz.
                                  Nein.
                                  • Glasfaser
                                    Glasfaser last edited by Glasfaser
                                    Ich hab so ein Problemchen mit dem VIS Editor.
                                    und warum nicht in deinem Thread weiter gemacht !?
                                    https://forum.iobroker.net/topic/71386/gelöst-vis-kaputt-verbindungsfehler
                                    Auch nochmal gleicher Hinweis .. von
                                    @wendy2702 sagte in vis Editor "Verbindungsfehler":
                                    • Glasfaser
                                      Glasfaser @Roelli last edited by Glasfaser
                                      tcp 0 0 0.0.0.0:4100 0.0.0.0:* LISTEN 1000 24912194 1867/io.vds2465-server
                                      Schon sehr Profihaft aufgebaut ... !
                                        Weil der Fehler danach erstmal weg war. Hat auch ein paar Wochen funktioniert.
                                        Installieren kann ich! 🙂 Aber... warum hilft ein zweiter Web Adapter? Egal.
                                        Was muss einstellen? Nix? Nirgendwo ein Haken machen? Port auch 8082?
                                          Und was noch schlimmer ist... ich weis nicht mal was falsch ist und/oder wie ich's verbessern kann oder wonach ich googeln müsste. Deswegen wäre es besser wenn's mal jemand macht der weis wie's geht. 😉
                                          • haselchen
                                            @roelli
                                            Und dann?
                                            Lebenslanger personal Support?
                                            Befasse Dich einfach damit.
                                            Wir können nur UNTERSTÜTZEND helfen.
                                            R 1 Reply Last reply Reply Quote 2
                                            1231
