    4. vis Editor "Verbindungsfehler"
      Roelli last edited by
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: iobroker-lxc
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.15.126-1-pve
            Architecture: x86-64
      model name      : AMD Ryzen 9 4900H with Radeon Graphics
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       16:16:47 up 24 min,  1 user,  load average: 4.91, 4.50, 3.92
      CPU threads: 16
      *** Time and Time Zones ***
                     Local time: Sat 2024-02-10 16:16:47 CET
                 Universal time: Sat 2024-02-10 15:16:47 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** User and Groups ***
      iobroker
      /home/iobroker
      iobroker tty dialout audio video redis
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             16G        7.9G        6.9G        0.0K        1.6G        8.5G
      Swap:           8.2G          0B        8.2G
      Total:           24G        7.9G         15G
              16384 M total memory
               7898 M used memory
                669 M active memory
               8309 M inactive memory
               6890 M free memory
                  0 M buffer memory
               1594 M swap cache
               8191 M total swap
                  0 M used swap
               8191 M free swap
      *** FAILED SERVICES ***
        UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
      * nut-driver.service            loaded failed failed Network UPS Tools - power device driver controller
      * nut-monitor.service           loaded failed failed Network UPS Tools - power device monitor and shutdown controller
      * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      5 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--201--disk--1 ext4       63G   24G   36G  40% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs   16G     0   16G   0% /dev/tty
      tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
      tmpfs                            tmpfs     6.2G  488K  6.2G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs     3.1G     0  3.1G   0% /run/user/0
      tmpfs                            tmpfs     3.1G     0  3.1G   0% /run/user/1000
      [sudo] password for iobroker:
      Sorry, try again.
      dmesg: read kernel buffer failed: Operation not permitted
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--201--disk--1 ext4   rw,relatime,stripe=16
      /var:
      15G     /var/
      14G     /var/lib
      13G     /var/lib/docker
      9.0G    /var/lib/docker/containers/66af97a102d568e200f457413a4542fc75b1add1081eb2cd0a8d88ba309befcd
      Archived and active journals take up 93.4M in the file system.
      /opt/iobroker/backups:
      2.7G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.1G    /opt/iobroker/iobroker-data/
      546M    /opt/iobroker/iobroker-data/files
      190M    /opt/iobroker/iobroker-data/backup-objects
      156M    /opt/iobroker/iobroker-data/esphome.0/.esphome
      find: Failed to change directory: /root: Permission denied
      find: Failed to restore initial working directory: /root: Permission denied
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://ftp.debian.org/debian bullseye/main amd64 Packages
              500 http://security.debian.org bullseye-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.13.16
      javascript:     7.1.6
      Adapters from github:   5
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker-lxc                             -  enabled, port: 7777, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker-lxc                             -  enabled
      + system.adapter.artnet.0                 : artnet                : iobroker-lxc                             -  enabled, port: 6454
      + system.adapter.backitup.0               : backitup              : iobroker-lxc                             -  enabled
      + system.adapter.bring.0                  : bring                 : iobroker-lxc                             -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker-lxc                             -  enabled
      + system.adapter.countdown.0              : countdown             : iobroker-lxc                             -  enabled
      + system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker-lxc                             -  enabled
      + system.adapter.daikin.0                 : daikin                : iobroker-lxc                             -  enabled
      + system.adapter.daikin.1                 : daikin                : iobroker-lxc                             -  enabled
      + system.adapter.daikin.2                 : daikin                : iobroker-lxc                             -  enabled
      + system.adapter.daikin.3                 : daikin                : iobroker-lxc                             -  enabled
      + system.adapter.daikin.4                 : daikin                : iobroker-lxc                             -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker-lxc                             -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : iobroker-lxc                             -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : iobroker-lxc                             -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker-lxc                             -  enabled
      + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker-lxc                             -  enabled
      + system.adapter.email.0                  : email                 : iobroker-lxc                             -  enabled
      + system.adapter.fakeroku.0               : fakeroku              : iobroker-lxc                             -  enabled
      + system.adapter.followthesun.0           : followthesun          : iobroker-lxc                             -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker-lxc                             -  enabled
      + system.adapter.geofency.0               : geofency              : iobroker-lxc                             -  enabled, port: 7999, bind: 0.0.0.0
      + system.adapter.geofency.1               : geofency              : iobroker-lxc                             -  enabled, port: 7999, bind: 0.0.0.0
      + system.adapter.harmony.0                : harmony               : iobroker-lxc                             -  enabled
      + system.adapter.hass.0                   : hass                  : iobroker-lxc                             -  enabled, port: 8123
      + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker-lxc                             -  enabled
      + system.adapter.hikvision-alarmserver.0  : hikvision-alarmserver : iobroker-lxc                             -  enabled, port: 8089, bind: 192.168.64.3
      + system.adapter.history.0                : history               : iobroker-lxc                             -  enabled
        system.adapter.ical.0                   : ical                  : iobroker-lxc                             -  enabled
        system.adapter.iceroad.0                : iceroad               : iobroker-lxc                             -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-lxc                             - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker-lxc                             -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker-lxc                             -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker-lxc                             -  enabled
        system.adapter.javascript.0             : javascript            : iobroker-lxc                             -  enabled
        system.adapter.javascript.1             : javascript            : iobroker-lxc                             -  enabled
        system.adapter.life360.0                : life360               : iobroker-lxc                             - disabled
      + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker-lxc                             -  enabled
      + system.adapter.modbus.0                 : modbus                : iobroker-lxc                             -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker-lxc                             -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : iobroker-lxc                             -  enabled
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker-lxc                             -  enabled
      + system.adapter.netatmo-energy.0         : netatmo-energy        : iobroker-lxc                             -  enabled
      + system.adapter.netatmo-energy.1         : netatmo-energy        : iobroker-lxc                             -  enabled
      + system.adapter.netatmo-energy.2         : netatmo-energy        : iobroker-lxc                             -  enabled
      + system.adapter.netatmo-energy.3         : netatmo-energy        : iobroker-lxc                             -  enabled
      + system.adapter.nina.0                   : nina                  : iobroker-lxc                             -  enabled
        system.adapter.odl.0                    : odl                   : iobroker-lxc                             -  enabled
      + system.adapter.onvif.0                  : onvif                 : iobroker-lxc                             -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
        system.adapter.owntracks.0              : owntracks             : iobroker-lxc                             - disabled, port: 1883, bind: 127.0.0.1
      + system.adapter.parser.1                 : parser                : iobroker-lxc                             -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker-lxc                             -  enabled
      + system.adapter.proxmox.0                : proxmox               : iobroker-lxc                             -  enabled, port: 8006
      + system.adapter.proxmox.1                : proxmox               : iobroker-lxc                             -  enabled, port: 8006
      + system.adapter.radar2.0                 : radar2                : iobroker-lxc                             -  enabled
      + system.adapter.scenes.0                 : scenes                : iobroker-lxc                             -  enabled
        system.adapter.schoolfree.0             : schoolfree            : iobroker-lxc                             -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker-lxc                             -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker-lxc                             -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker-lxc                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker-lxc                             -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-lxc                             -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker-lxc                             -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : iobroker-lxc                             -  enabled
      + system.adapter.time-switch.0            : time-switch           : iobroker-lxc                             -  enabled
      + system.adapter.tr-064.0                 : tr-064                : iobroker-lxc                             -  enabled
      + system.adapter.tractive-gps.0           : tractive-gps          : iobroker-lxc                             -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker-lxc                             -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker-lxc                             -  enabled
      + system.adapter.unifi.0                  : unifi                 : iobroker-lxc                             -  enabled
      + system.adapter.vds2465-server.0         : vds2465-server        : iobroker-lxc                             -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-lxc                             -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-lxc                             -  enabled
        system.adapter.vis.0                    : vis                   : iobroker-lxc                             -  enabled
      + system.adapter.web.0                    : web                   : iobroker-lxc                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.windows-control.0        : windows-control       : iobroker-lxc                             -  enabled
      + system.adapter.wled.0                   : wled                  : iobroker-lxc                             -  enabled
      + system.adapter.ws.0                     : ws                    : iobroker-lxc                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.yahka.1                  : yahka                 : iobroker-lxc                             -  enabled
        system.adapter.yr.0                     : yr                    : iobroker-lxc                             -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker-lxc                             -  enabled, port: tcp://192.168.64.6:20108
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "adguard"      : 0.0.8    , installed 0.0.8
      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
      Adapter    "artnet"       : 1.2.2    , installed 1.2.2
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "ble"          : 0.14.0   , installed 0.14.0
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
      Adapter    "countdown"    : 2.2.0    , installed 2.2.0
      Adapter    "daikin"       : 1.4.2    , installed 1.4.2
      Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
      Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "device-watcher": 2.9.6   , installed 2.9.14
      Adapter    "doorio"       : 2.1.4    , installed 2.1.4
      Adapter    "drag-indicator": 2.1.4   , installed 2.1.4
      Adapter    "ecovacs-deebot": 1.4.13  , installed 1.4.13
      Adapter    "email"        : 1.2.2    , installed 1.2.2
      Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
      Adapter    "followthesun" : 0.5.0    , installed 0.5.0
      Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
      Adapter    "geofency"     : 1.2.4    , installed 1.2.4
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "harmony"      : 1.3.0    , installed 1.3.0
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "heatingcontrol": 2.12.3  , installed 2.12.3
      Adapter    "hikvision-alarmserver": 0.1.0, installed 0.1.0
      Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
      Adapter    "imap"         : 0.1.1    , installed 0.1.1
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "mielecloudservice": 6.5.4, installed 6.5.4
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "netatmo-energy": 2.7.3   , installed 2.7.3
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "odl"          : 3.0.1    , installed 3.0.1
      Adapter    "onvif"        : 1.1.1    , installed 1.1.1
      Adapter    "owntracks"    : 1.0.5    , installed 1.0.5
      Adapter    "parcel"       : 0.0.27   , installed 0.0.27
      Adapter    "parser"       : 2.1.0    , installed 2.1.0
      Adapter    "pegelalarm"   : 1.3.2    , installed 1.3.2
      Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
      Adapter    "radar2"       : 2.1.0    , installed 2.1.0
      Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "traccar"      : 1.1.4    , installed 1.1.4
      Adapter    "tractive-gps" : 1.1.0    , installed 1.1.0
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "tvprogram"    : 1.1.2    , installed 1.1.2
      Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
      Adapter    "unifi"        : 0.6.7    , installed 0.6.7
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vds2465-server": 0.1.10  , installed 0.1.10
      Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "windows-control": 0.1.5  , installed 0.1.5
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
      Objects and States
      Objects:        340478
      States:         199813
      Hit:1 http://security.debian.org bullseye-security InRelease
      Hit:2 http://ftp.debian.org/debian bullseye InRelease
      Hit:3 https://download.docker.com/linux/debian bullseye InRelease
      Hit:4 http://ftp.debian.org/debian bullseye-updates InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:6 https://packages.redis.io/deb bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          24912460   2251/upsd
      tcp        0      0 127.0.0.1:33305         0.0.0.0:*               LISTEN      1000       24932911   5470/io.yahka.1
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          25137443   42131/master
      tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          25128734   43521/docker-proxy
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      110        25137584   42449/redis-server
      tcp        0      0 0.0.0.0:10001           0.0.0.0:*               LISTEN      0          25136625   43495/docker-proxy
      tcp        0      0 0.0.0.0:10003           0.0.0.0:*               LISTEN      0          25136601   43429/docker-proxy
      tcp        0      0 0.0.0.0:10002           0.0.0.0:*               LISTEN      0          25142292   43449/docker-proxy
      tcp        0      0 0.0.0.0:10005           0.0.0.0:*               LISTEN      0          25132519   43381/docker-proxy
      tcp        0      0 0.0.0.0:10004           0.0.0.0:*               LISTEN      0          25136584   43409/docker-proxy
      tcp        0      0 192.168.64.3:8089       0.0.0.0:*               LISTEN      1000       24917524   2383/io.hikvision-a
      tcp        0      0 0.0.0.0:4100            0.0.0.0:*               LISTEN      1000       24912194   1867/io.vds2465-ser
      tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        24896898   110/systemd-resolve
      tcp        0      0 192.168.64.3:9093       0.0.0.0:*               LISTEN      1000       24939777   5941/io.fakeroku.0
      tcp        0      0 0.0.0.0:8086            0.0.0.0:*               LISTEN      0          25135939   43320/docker-proxy
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          24902935   1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25124645   42354/sshd: /usr/sb
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        24896904   110/systemd-resolve
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       24901378   1814/io.sonoff.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       24898331   1582/io.mqtt.0
      tcp        0      0 0.0.0.0:34027           0.0.0.0:*               LISTEN      1000       24925114   5470/io.yahka.1
      tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      0          25132495   43277/docker-proxy
      tcp6       0      0 :::61991                :::*                    LISTEN      1000       24918297   2359/io.harmony.0
      tcp6       0      0 :::8765                 :::*                    LISTEN      0          25128739   43528/docker-proxy
      tcp6       0      0 :::10001                :::*                    LISTEN      0          25135952   43502/docker-proxy
      tcp6       0      0 :::10003                :::*                    LISTEN      0          25132529   43435/docker-proxy
      tcp6       0      0 :::10002                :::*                    LISTEN      0          25137746   43457/docker-proxy
      tcp6       0      0 :::10005                :::*                    LISTEN      0          25135943   43394/docker-proxy
      tcp6       0      0 :::10004                :::*                    LISTEN      0          25142283   43417/docker-proxy
      tcp6       0      0 :::9443                 :::*                    LISTEN      0          25128700   43291/portainer
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          25137444   42131/master
      tcp6       0      0 :::5355                 :::*                    LISTEN      104        24896901   110/systemd-resolve
      tcp6       0      0 :::7777                 :::*                    LISTEN      1000       24902118   1009/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       24935725   5167/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1000       24934282   5731/io.ws.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       24922647   4237/io.simple-api.
      tcp6       0      0 :::8086                 :::*                    LISTEN      0          25136573   43328/docker-proxy
      tcp6       0      0 :::8000                 :::*                    LISTEN      0          25137740   43291/portainer
      tcp6       0      0 :::7999                 :::*                    LISTEN      1000       24897177   1465/io.geofency.0
      tcp6       0      0 ::1:3493                :::*                    LISTEN      0          24912461   2251/upsd
      tcp6       0      0 :::33673                :::*                    LISTEN      1000       24925115   5470/io.yahka.1
      tcp6       0      0 :::111                  :::*                    LISTEN      0          24902937   1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          25124647   42354/sshd: /usr/sb
      tcp6       0      0 :::3000                 :::*                    LISTEN      0          25136558   43283/docker-proxy
      tcp6       0      0 ::1:6379                :::*                    LISTEN      110        25137585   42449/redis-server
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       24939778   5941/io.fakeroku.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       24925116   5470/io.yahka.1
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       24925111   5470/io.yahka.1
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       24925070   5411/io.wled.0
      udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        24896897   110/systemd-resolve
      udp        0   1280 0.0.0.0:38293           0.0.0.0:*                           1000       24992278   2073/io.artnet.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       24905690   1786/io.shelly.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       24898507   1840/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       24898508   1840/io.tuya.0
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       24918298   2359/io.harmony.0
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        24896903   110/systemd-resolve
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1000       24910383   1746/io.radar2.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          24902936   1/init
      udp6       0      0 :::5355                 :::*                                104        24896900   110/systemd-resolve
      udp6       0      0 :::111                  :::*                                0          24902938   1/init
      2024-02-10 16:15:24.043  - warn: influxdb.0 (1098) Error on writePoint("{"value":3738,"time":"2024-02-10T15:15:23.994Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: connect ECONNREFUSED 127.0.0.1:8086 / "connect ECONNREFUSED 127.0.0.1:8086""
      2024-02-10 16:15:25.576  - warn: shelly.0 (1786) Cannot get view: NOSCRIPT No matching script. Please use EVAL.
      2024-02-10 16:15:25.577  - error: shelly.0 (1786) ReplyError: NOSCRIPT No matching script. Please use EVAL.
      2024-02-10 16:15:34.045  - info: influxdb.0 (1098) Connecting http://localhost:8086/ ...
      2024-02-10 16:15:34.045  - info: influxdb.0 (1098) Influx DB Version used: 1.x
      2024-02-10 16:15:34.049  - error: influxdb.0 (1098) Error: socket hang up
      2024-02-10 16:15:37.256  - error: host.iobroker-lxc Could not execute primary host determination: NOSCRIPT No matching script. Please use EVAL.
      2024-02-10 16:15:44.049  - info: influxdb.0 (1098) Connecting http://localhost:8086/ ...
      2024-02-10 16:15:44.050  - info: influxdb.0 (1098) Influx DB Version used: 1.x
      2024-02-10 16:15:47.514  - error: javascript.0 (1135) Objects database error: write EPIPE
      2024-02-10 16:15:47.533  - error: javascript.0 (1135) States database error: write EPIPE
      2024-02-10 16:16:00.012  - info: host.iobroker-lxc instance system.adapter.yr.0 started with pid 46200
      2024-02-10 16:16:01.506  - info: yr.0 (46200) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v18.19.0, js-controller: 5.0.17
      2024-02-10 16:16:01.513  - info: yr.0 (46200) longitude/longitude not set, get data from system
      2024-02-10 16:16:01.523  - info: yr.0 (46200) system latitude: 51.2374097 longitude: 6.4129197
      2024-02-10 16:16:11.537  - info: yr.0 (46200) Data updated.
      2024-02-10 16:16:11.538  - info: yr.0 (46200) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-02-10 16:16:12.049  - info: host.iobroker-lxc instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-02-10 16:16:20.977  - info: influxdb.0 (1098) Store 29 buffered influxDB history points
      2024-02-10 16:16:21.027  - warn: fullybrowser.0 (2333) [REST] 192.168.77.128: Sending command get axiosGetDevicesInfo  failed: No response
      2024-02-10 16:16:48.013  - info: host.iobroker-lxc instance system.adapter.odl.0 started with pid 47702
      2024-02-10 16:16:49.745  - info: odl.0 (47702) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.odl, node: v18.19.0, js-controller: 5.0.17
      2024-02-10 16:16:51.174  - info: odl.0 (47702) Terminated (NO_ERROR): Without reason
      2024-02-10 16:16:51.687  - info: host.iobroker-lxc instance system.adapter.odl.0 terminated with code 0 (NO_ERROR)
      2024-02-10 16:17:21.027  - warn: fullybrowser.0 (2333) [REST] 192.168.77.128: Sending command get axiosGetDevicesInfo  failed: No response
      Glasfaser 2 Replies Last reply Reply Quote 0
        Roelli @haselchen last edited by
        @haselchen sagte in vis Editor "Verbindungsfehler":
        @roelli
        Warum Iobroker unter Port 7777 ?
        Weis auch nicht mehr genau. Irgendwas wollte in der Vergangenheit auch mal 8082 sein, hab dann ioBroker von 8082 auf 7777 gemacht. Nicht so gut? Hat 3 Jahre funktioniert bisher.
          Thomas Braun Most Active @Roelli last edited by
          @roelli
          Leg dir einen User an und hantiere mit dem.
          Der user 'iobroker' ist nicht dafür gedacht und vorgesehen.
            Roelli @Thomas Braun last edited by
            @thomas-braun sagte in vis Editor "Verbindungsfehler":
            @roelli sagte in vis Editor "Verbindungsfehler":
            Pending OS-Updates: 42
            Aktuell halten.
            Update hab ich jetzt gemacht. Jetzt ist's schlimmer als vorher. 🙂
            Javascript Adapter hat Wackelkontakt... geht an.. geht kaputt.. geht an... geht kaputt...
            Machst Du auch virtuelle Hausbesuche per Teamviewer gegen Stundenlohn? Besser wenn man jemand drüber guckt der schlauer ist als ich!
              Aktuell halten.
              Die OS-Updates haben aber nix (unmittelbar) mit dem ioBroker zu tun.
              Nein. Mit TeamViewer ohnehin nicht, weil das kein Werkzeug für einen Server ist. Da geht man ausschließlich per SSH/einem Terminal drauf.
                Und der sagt dazu nichts im LogFile?
                • wendy2702
                  wendy2702 last edited by
                  Das VIS Problem lässt sich vermutlich durch eine zweite WEB Instanz lösen.
                  Dazu gibt es hier schon Beiträge. Da ich aber gerade unterwegs bin ist die Suche für mich danach kein Thema.
                    Garnix! Dafür verbraucht die javascript Instanz jetzt so zwischen 800MB und 1,2GB. Fühlt sich eher viel an.
                      @roelli
                      Hast du denn den LXC gescheit eingerichtet? Mit einem user? Siehe:
                      https://www.iobroker.net/#de/documentation/install/proxmox.md
                      • Glasfaser
                        Glasfaser @Roelli last edited by
                        Objects: 340478
                        States: 199813
                        Mhh ... was ist das 🤔 ...
                        Du toppst ja die Objects und States in Rekordhöhe !
                          @roelli
                          Eher nicht gescheit eingerichtet. Damals gab's dieses praktische Tutorial nocht nicht. Das hatte mein "Linux-Kumpel" eingerichtet.
                          Ist immer noch meine erste ioBroker Installation von vor Jahren. Als man z.B. noch Datenpunkte direkt im Javascript-Adapter erstellt hatte.
                          Was muss ich tun? Alles nochmal neu machen, diese mal nach Anleitung und dann Backup aus dem Backitup-Adapter einspielen? Hab ganz doll Angst. Willst Du das nicht für mich machen? 100€/h? (ich arbeite nämlich schon 12h/Tag von Montags-Sonntags) Ich hab heute so viele Lichtschalter manuell! betätigt wie noch nie. 🙂 Ging früher irgenwie alles automatisch. 😉
                            Roelli @Glasfaser last edited by
                            @glasfaser sagte in vis Editor "Verbindungsfehler":
                            Objects: 340478
                            States: 199813
                            Vermutlich ein unfreiwilliger Rekord! 🙂 Aber ich weis auch nicht wie ich das weg bekomme.
                              Wäre ein Ansatz.
                              Nein.
                              • Glasfaser
                                Glasfaser last edited by Glasfaser
                                Ich hab so ein Problemchen mit dem VIS Editor.
                                und warum nicht in deinem Thread weiter gemacht !?
                                https://forum.iobroker.net/topic/71386/gelöst-vis-kaputt-verbindungsfehler
                                Auch nochmal gleicher Hinweis .. von
                                @wendy2702 sagte in vis Editor "Verbindungsfehler":
                                • Glasfaser
                                  Glasfaser @Roelli last edited by Glasfaser
                                  tcp 0 0 0.0.0.0:4100 0.0.0.0:* LISTEN 1000 24912194 1867/io.vds2465-server
                                  Schon sehr Profihaft aufgebaut ... !
                                    Weil der Fehler danach erstmal weg war. Hat auch ein paar Wochen funktioniert.
                                    Installieren kann ich! 🙂 Aber... warum hilft ein zweiter Web Adapter? Egal.
                                    Was muss einstellen? Nix? Nirgendwo ein Haken machen? Port auch 8082?
                                      Und was noch schlimmer ist... ich weis nicht mal was falsch ist und/oder wie ich's verbessern kann oder wonach ich googeln müsste. Deswegen wäre es besser wenn's mal jemand macht der weis wie's geht. 😉
                                      • haselchen
                                        haselchen Most Active @Roelli last edited by
                                        @roelli
                                        Und dann?
                                        Lebenslanger personal Support?
                                        Befasse Dich einfach damit.
                                        Wir können nur UNTERSTÜTZEND helfen.
                                        R 1 Reply Last reply Reply Quote 2
                                          @roelli
                                          Und dann?
                                          Am liebsten! Vielleicht finde ich ja jemand der Zeit gegen Geld tauschen will.
                                          Ich versuche!
                                          Aber, ein vernünftig installierter LXC Container den ich nur importieren müsste wäre einfacher für jemanden wie mich der zeitlich und know-how-technisch eingeschränkt ist. 😉
                                          • Glasfaser
                                            Wenn ich ein Objekt anklicke um einen Datenpunkt auszuwählen dann dauert es immer 1 Minute und 45 Sekunden bis sich das Fenster öffnet.
                                            Und danach kommt "Verbindungsfehler" und man kann garnix mehr machen, weil nichts mehr gespeichert wird.
                                            Ich habe 339544 Objekte, 202389 Zustände
                                            und deshalb dauert es ..... so lange
                                            Erlich gesagt , hab ich so etwas noch nie gesehn an eine Rekordhöhe
                                            Du mußt doch auch beim Admin Probleme haben ( Objekte ) !?
                                            1137
