    4. [GELÖST] ble Adapter macht Probleme auf Raspi 5
      Thomas Braun Most Active @wauzzi last edited by
      @wauzzi
      Installier den ble Adapter nochmal, mit --debug Option.
      wauzzi 2 Replies Last reply Reply Quote 0
      • wauzzi
        wauzzi @Thomas Braun last edited by
        $ iobroker add ble --host iobroker
        NPM version: 10.2.3
        Installing iobroker.ble@0.14.0... (System call)
        145 packages are looking for funding run `npm fund` for details
        host.iobroker install adapter ble
        upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/.eslintrc.js .eslintrc.js application/javascript
        upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
        upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
        upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
        upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
        host.iobroker object system.adapter.ble created/updated
        host.iobroker object system.adapter.ble.0.memHeapUsed created
        host.iobroker object system.adapter.ble.0.memHeapTotal created
        host.iobroker object system.adapter.ble.0.memRss created
        host.iobroker object system.adapter.ble.0.uptime created
        host.iobroker object system.adapter.ble.0.inputCount created
        host.iobroker object system.adapter.ble.0.outputCount created
        host.iobroker object system.adapter.ble.0.eventLoopLag created
        host.iobroker object system.adapter.ble.0.sigKill created
        host.iobroker object system.adapter.ble.0.logLevel created
        host.iobroker object ble.0.info created
        host.iobroker object ble.0.info.connection created
        host.iobroker object ble.0.info.driverState created
        host.iobroker object ble.0.options created
        host.iobroker object ble.0.options.allowNewDevices created
        host.iobroker Set default value of ble.0.options.allowNewDevices: false
        host.iobroker object system.adapter.ble.0 created
        Process exited with code 0
        • wauzzi
          @thomas-braun said in ble Adapter macht Probleme auf Raspi 5:
          @wauzzi
          Hab den BLE Adapter deinstalliert und neuinstalliert.
          Jetzt bleibt er auf Gelb stehen. Fehlermeldung noch die gleiche 😞
          • Glasfaser
            Glasfaser last edited by
            @wauzzi sagte in ble Adapter macht Probleme auf Raspi 5:
            gehe diesen Thread mal durch :
            https://forum.iobroker.net/post/150869
            wauzzi 1 Reply Last reply Reply Quote 1
            • wauzzi
              wauzzi @Glasfaser last edited by
              @glasfaser said in ble Adapter macht Probleme auf Raspi 5:
              Danke für Deinen Tipp !
              Beim Versuch "npm install bluetooth-hci-socket" durchzuführen erhalte ich diese Meldungen. Ich schätze irgendwo ist der Wurm drin 😞
              admin@iobroker:~ $ sudo npm install bluetooth-hci-socket
              npm ERR! code 1
              npm ERR! path /home/admin/node_modules/bluetooth-hci-socket
              npm ERR! command failed
              npm ERR! command sh -c node-gyp rebuild
              npm ERR! make: Entering directory '/home/admin/node_modules/bluetooth-hci-socket/build'
              npm ERR!   CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
              npm ERR! make: Leaving directory '/home/admin/node_modules/bluetooth-hci-socket/build'
              npm ERR! gyp info it worked if it ends with ok
              npm ERR! gyp info using node-gyp@10.0.1
              npm ERR! gyp info using node@18.19.0 | linux | arm64
              npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
              npm ERR! gyp info spawn /usr/bin/python3
              npm ERR! gyp info spawn args [
              npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
              npm ERR! gyp info spawn args 'binding.gyp',
              npm ERR! gyp info spawn args '-f',
              npm ERR! gyp info spawn args 'make',
              npm ERR! gyp info spawn args '-I',
              npm ERR! gyp info spawn args '/home/admin/node_modules/bluetooth-hci-socket/build/config.gypi',
              npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
              npm ERR! gyp info spawn args '/root/.cache/node-gyp/18.19.0/include/node/common.gypi',
              npm ERR! gyp info spawn args '-Dlibrary=shared_library',
              npm ERR! gyp info spawn args '-Dvisibility=default',
              npm ERR! gyp info spawn args '-Dnode_root_dir=/root/.cache/node-gyp/18.19.0',
              npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
              npm ERR! gyp info spawn args '-Dnode_lib_file=/root/.cache/node-gyp/18.19.0/<(target_arch)/node.lib',
              npm ERR! gyp info spawn args '-Dmodule_root_dir=/home/admin/node_modules/bluetooth-hci-socket',
              npm ERR! gyp info spawn args '-Dnode_engine=v8',
              npm ERR! gyp info spawn args '--depth=.',
              npm ERR! gyp info spawn args '--no-parallel',
              npm ERR! gyp info spawn args '--generator-output',
              npm ERR! gyp info spawn args 'build',
              npm ERR! gyp info spawn args '-Goutput_dir=.'
              npm ERR! gyp info spawn args ]
              npm ERR! gyp info spawn make
              npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
              npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static void BluetoothHciSocket::Init(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’:
              npm ERR! ../src/BluetoothHciSocket.cpp:128:81: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’
              npm ERR!   128 |   target->Set(Nan::New("BluetoothHciSocket").ToLocalChecked(), tmpl->GetFunction());
              npm ERR!       |        ~~~~~~~~~~~~~~~~~^~
              npm ERR! In file included from /root/.cache/node-gyp/18.19.0/include/node/v8-function.h:15,
              npm ERR!                  from /root/.cache/node-gyp/18.19.0/include/node/v8.h:33,
              npm ERR!                  from /root/.cache/node-gyp/18.19.0/include/node/node.h:73,
              npm ERR!                  from /root/.cache/node-gyp/18.19.0/include/node/node_buffer.h:25,
              npm ERR!                  from ../src/BluetoothHciSocket.cpp:7:
              npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note: candidate: ‘v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)’
              npm ERR!   513 |   V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(
              npm ERR!       |                                              ^~~~~~~~~~~
              npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note:   candidate expects 1 argument, 0 provided
              npm ERR! ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:
              npm ERR! ../src/BluetoothHciSocket.cpp:251:22: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
              npm ERR!   251 |     Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
              npm ERR!       |     ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
              npm ERR! In file included from ../src/BluetoothHciSocket.cpp:8:
              npm ERR! ../../nan/nan.h:1053:46: note: declared here
              npm ERR!  1053 |   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
              npm ERR!       |                                              ^~~~~~~~~~~~
              npm ERR! ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:
              npm ERR! ../src/BluetoothHciSocket.cpp:269:74: error: no matching function for call to ‘v8::Object::Get(v8::Local<v8::String>)’
              npm ERR!   269 |   Local<Function> errorConstructor = Local<Function>::Cast(globalObj->Get(Nan::New("Error").ToLocalChecked()));
              npm ERR!       |                                                            ~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
              npm ERR! In file included from /root/.cache/node-gyp/18.19.0/include/node/v8-array-buffer.h:13,
              npm ERR!                  from /root/.cache/node-gyp/18.19.0/include/node/v8.h:24:
              npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
              npm ERR!   290 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
              npm ERR!       |                                           ^~~
              npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note:   candidate expects 2 arguments, 1 provided
              npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
              npm ERR!   293 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
              npm ERR!       |                                           ^~~
              npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note:   candidate expects 2 arguments, 1 provided
              npm ERR! ../src/BluetoothHciSocket.cpp:275:53: error: no matching function for call to ‘v8::Function::NewInstance(int, v8::Local<v8::Value> [1])’
              npm ERR!   275 |   Local<Value> error = errorConstructor->NewInstance(1, constructorArgs);
              npm ERR!       |                        ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~
              npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const’
              npm ERR!    38 |   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
              npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note:   candidate expects 3 arguments, 2 provided
              npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const’
              npm ERR!    41 |   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
              npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note:   candidate expects 1 argument, 2 provided
              npm ERR! ../src/BluetoothHciSocket.cpp:282:20: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
              npm ERR!   282 |   Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
              npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)’:
              npm ERR! ../src/BluetoothHciSocket.cpp:395:33: error: no matching function for call to ‘v8::Value::IntegerValue()’
              npm ERR!   395 |       devId = arg0->IntegerValue();
              npm ERR!       |               ~~~~~~~~~~~~~~~~~~^~
              npm ERR! In file included from /root/.cache/node-gyp/18.19.0/include/node/v8-primitive.h:11,
              npm ERR!                  from /root/.cache/node-gyp/18.19.0/include/node/v8-object.h:11:
              npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note: candidate: ‘v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const’
              npm ERR!   413 |   V8_WARN_UNUSED_RESULT Maybe<int64_t> IntegerValue(
              npm ERR! /root/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note:   candidate expects 1 argument, 0 provided
              npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:
              npm ERR! ../src/BluetoothHciSocket.cpp:417:33: error: no matching function for call to ‘v8::Value::IntegerValue()’
              npm ERR!   417 |       devId = arg0->IntegerValue();
              npm ERR! ../src/BluetoothHciSocket.cpp: At global scope:
              npm ERR! /root/.cache/node-gyp/18.19.0/include/node/node.h:1014:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
              npm ERR!  1014 |       (node::addon_register_func) (regfunc),                          \
              npm ERR!       |       ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
              npm ERR! /root/.cache/node-gyp/18.19.0/include/node/node.h:1048:3: note: in expansion of macro ‘NODE_MODULE_X’
              npm ERR!  1048 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
              npm ERR! ../src/BluetoothHciSocket.cpp:499:1: note: in expansion of macro ‘NODE_MODULE’
              npm ERR!   499 | NODE_MODULE(binding, BluetoothHciSocket::Init);
              npm ERR! make: *** [binding.target.mk:111: Release/obj.target/binding/src/BluetoothHciSocket.o] Error 1
              npm ERR! gyp ERR! build error
              npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
              npm ERR! gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)
              npm ERR! gyp ERR! System Linux 6.1.0-rpi8-rpi-2712
              npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
              npm ERR! gyp ERR! cwd /home/admin/node_modules/bluetooth-hci-socket
              npm ERR! gyp ERR! node -v v18.19.0
              npm ERR! gyp ERR! node-gyp -v v10.0.1
              npm ERR! gyp ERR! not ok
              npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2024-02-10T22_07_22_661Z-debug-0.log
              admin@iobroker:~ $
              • Glasfaser
                Glasfaser @wauzzi last edited by Glasfaser
                du stehst falsch
                cd
                /opt/iobroker
                • wauzzi
                  du stehst falsch
                  cd
                  /opt/iobroker
                  selbes spiel
                  admin@iobroker:~ $ cd /opt/iobroker
                  admin@iobroker:/opt/iobroker $ sudo npm install bluetooth-hci-socket
                  npm ERR! code 1
                  npm ERR! path /opt/iobroker/node_modules/bluetooth-hci-socket
                  npm ERR! make: Entering directory '/opt/iobroker/node_modules/bluetooth-hci-socket/build'
                  npm ERR! make: Leaving directory '/opt/iobroker/node_modules/bluetooth-hci-socket/build'
                  npm ERR! gyp info spawn args '/opt/iobroker/node_modules/bluetooth-hci-socket/build/config.gypi',
                  npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bluetooth-hci-socket',
                  npm ERR!       |                                           ^~~
                  npm ERR!       |                                           ^~~
                  npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socket
                  npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2024-02-10T22_11_48_917Z-debug-0.log
                  • wauzzi
                    @glasfaser irgendwie kann er das Verzeichnis nicht erstellen, oder liege ich falsch mit meiner Vermutung ?
                    • Glasfaser
                      selbes spiel
                      sorry habe den Thread nicht ganz dazu gelesen .
                      nur das machen ..
                      https://forum.iobroker.net/post/151081
                      nicht die Befehle darunter !
                      wauzzi 1 Reply Last reply Reply Quote 0
                      • wauzzi
                        @glasfaser Das hatte ich vorhin auch schon versucht. Hab es eben nochmals versucht.
                        Scheint aber alles sauber zu sein:
                        admin@iobroker:/opt/iobroker $ sudo npm install --production
                        npm WARN config production Use `--omit=dev` instead.
                        up to date in 3s
                        admin@iobroker:/opt/iobroker $ npm fund
                        iobroker.inst@3.0.0
                        ├── https://github.com/sponsors/epoberezkin
                        │   └── ajv@6.12.6
                        ├── https://github.com/sponsors/jaredhanson
                        │   └── passport@0.6.0, oauth2orize@1.11.1
                        ├── https://github.com/sponsors/isaacs
                        │   └── glob@7.2.3, minimatch@7.4.6, rimraf@3.0.2
                        ├── https://github.com/sponsors/feross
                        │   └── safe-buffer@5.2.1, base64-js@1.5.1, buffer@6.0.3, simple-concat@1.0.1
                        ├── https://github.com/sponsors/RubenVerborgh
                        │   └── follow-redirects@1.15.5
                        ├── https://github.com/sponsors/ljharb
                        │   └── qs@6.10.4, minimist@1.2.8, define-properties@1.2.1, es-abstract@1.22.3, array-buffer-byte-length@1.0.1, arraybuffer.prototype.slice@1.0.3, available-typed-arrays@1.0.6, es-to-primitive@1.2.1, is-date-object@1.0.5, is-symbol@1.0.4, function.prototype.name@1.1.6, functions-have-names@1.2.3, get-symbol-description@1.0.2, globalthis@1.0.3, is-array-buffer@3.0.4, is-callable@1.2.7, is-negative-zero@2.0.2, is-regex@1.1.4, is-shared-array-buffer@1.0.2, is-string@1.0.7, is-typed-array@1.1.13, is-weakref@1.0.2, object.assign@4.1.5, regexp.prototype.flags@1.5.1, safe-array-concat@1.1.0, safe-regex-test@1.0.3, string.prototype.trim@1.2.8, string.prototype.trimend@1.0.7, string.prototype.trimstart@1.0.7, typed-array-byte-length@1.0.0, typed-array-byte-offset@1.0.0, typed-array-length@1.0.4, unbox-primitive@1.0.2, has-bigints@1.0.2, which-boxed-primitive@1.0.2, is-bigint@1.0.4, is-boolean-object@1.1.2, is-number-object@1.0.7, which-typed-array@1.1.14, has-tostringtag@1.0.2, traverse@0.6.8
                        ├── https://github.com/sponsors/broofa
                        │   └── uuid@9.0.1
                        ├── https://github.com/sponsors/sindresorhus
                        │   └── is-plain-obj@3.0.0, is-stream@2.0.1, responselike@2.0.1, clone-response@1.0.3, get-stream@5.2.0, normalize-url@6.1.0, onetime@5.1.2, make-dir@3.1.0, mimic-response@2.1.0, component-emitter@1.3.1, debounce@2.0.0
                        ├── https://github.com/sponsors/jonschlinkert
                        │   └── picomatch@2.3.1
                        ├─┬ https://github.com/sindresorhus/got?sponsor=1
                        │ │ └── got@11.8.6
                        │ └── https://github.com/sindresorhus/is?sponsor=1
                        │     └── @sindresorhus/is@4.6.0
                        ├── https://github.com/sponsors/NaturalIntelligence
                        │   └── fast-xml-parser@4.3.4
                        ├─┬ https://opencollective.com/node-fetch
                        │ │ └── node-fetch@3.3.2
                        │ └── https://github.com/sponsors/jimmywarting
                        │     └── fetch-blob@3.2.0, node-domexception@1.0.0
                        ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
                        │ │ └── wrap-ansi@7.0.0
                        │ └── https://github.com/chalk/ansi-styles?sponsor=1
                        │     └── ansi-styles@4.3.0
                        ├── https://opencollective.com/serialport/donate
                        │   └── serialport@12.0.0, @serialport/bindings-cpp@12.0.1, @serialport/parser-readline@11.0.0, @serialport/parser-delimiter@11.0.0, @serialport/parser-byte-length@12.0.0, @serialport/parser-cctalk@12.0.0, @serialport/parser-delimiter@12.0.0, @serialport/parser-inter-byte-timeout@12.0.0, @serialport/parser-readline@12.0.0, @serialport/parser-ready@12.0.0, @serialport/parser-regex@12.0.0, @serialport/parser-slip-encoder@12.0.0, @serialport/parser-spacepacket@12.0.0, @serialport/stream@12.0.0
                        ├─┬ https://github.com/chalk/chalk-template?sponsor=1
                        │ │ └── chalk-template@0.4.0
                        │ └── https://github.com/chalk/chalk?sponsor=1
                        │     └── chalk@4.1.2
                        ├── https://opencollective.com/date-fns
                        │   └── date-fns@2.30.0
                        ├── https://opencollective.com/ioredis
                        │   └── ioredis@4.28.5
                        ├── https://github.com/sindresorhus/execa?sponsor=1
                        │   └── execa@5.1.1
                        ├── https://paulmillr.com/funding/
                        │   └── chokidar@3.6.0
                        ├── https://github.com/sponsors/sibiraj-s
                        │   └── ci-info@3.9.0
                        ├── https://opencollective.com/js-sdsl
                        │   └── js-sdsl@4.3.0
                        ├─┬ https://github.com/cheeriojs/cheerio?sponsor=1
                        │ │ └── cheerio@1.0.0-rc.10
                        │ ├─┬ https://github.com/sponsors/fb55
                        │ │ │ └── cheerio-select@1.6.0, css-select@4.3.0, css-what@6.1.0, domelementtype@2.3.0
                        │ │ └── https://github.com/fb55/domutils?sponsor=1
                        │ │     └── domutils@2.8.0, domutils@3.1.0
                        │ ├─┬ https://github.com/cheeriojs/dom-serializer?sponsor=1
                        │ │ │ └── dom-serializer@1.4.1, dom-serializer@2.0.0
                        │ │ └── https://github.com/fb55/entities?sponsor=1
                        │ │     └── entities@2.2.0, entities@4.5.0
                        │ ├── https://github.com/fb55/domhandler?sponsor=1
                        │ │   └── domhandler@4.3.1, domhandler@5.0.3
                        │ └── https://github.com/fb55/htmlparser2?sponsor=1
                        │     └── htmlparser2@6.1.0, htmlparser2@8.0.2
                        ├── https://locize.com
                        │   └── i18next@21.10.0
                        ├── https://ko-fi.com/killymxi
                        │   └── @selderee/plugin-htmlparser2@0.11.0, selderee@0.11.0, parseley@0.12.1, leac@0.6.0, peberminta@0.9.0
                        ├── https://github.com/sponsors/3846masa
                        │   └── http-cookie-agent@5.0.4
                        └── https://github.com/inikulin/parse5?sponsor=1
                          └── parse5@7.1.2
                        Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                        • Glasfaser
                          @wauzzi
                          ins Verzeichniss
                          cd /opt/iobroker/node_modules/bluetooth-hci-socket
                          dann dort
                          Bitte alles in Ruhe lesen , es steht auch dort !!
                          • wauzzi
                            @glasfaser
                            Danke für Deine Geduld mit mir 😌
                            Das Verzeichnis "opt/iobroker/node_modules/bluetooth-hci-socket" existiert bei mir nicht.
                            Ich hab eben nochmals mit dem Winscp geschaut. nicht vorhanden
                              sudo npm
                              Arrrgh. Nie npm in Verbindung mit sudo verwenden.
                              • Glasfaser
                                cd /opt/iobroker
                                sudo -H -u iobroker npm install bluetooth-hci-socket
                                  @wauzzi
                                  bluetooth-hci-socket wird auf aktuellen Systemen auch gar nicht mehr verwendet. Auf meinem jedenfalls nicht...
                                  echad@chet:/opt/iobroker $ npm ls iobroker.ble bluetooth-hci-socket
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  └── iobroker.ble@0.14.0
                                  • wauzzi
                                    admin@iobroker:/opt/iobroker $ sudo -H -u iobroker npm install bluetooth-hci-socket
                                    npm ERR! code 1
                                    npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.19.0/include/node/common.gypi',
                                    npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.19.0',
                                    npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.19.0/<(target_arch)/node.lib',
                                    npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:15,
                                    npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8.h:33,
                                    npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:73,
                                    npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/node_buffer.h:25,
                                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note: candidate: ‘v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)’
                                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note:   candidate expects 1 argument, 0 provided
                                    npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-array-buffer.h:13,
                                    npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8.h:24:
                                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
                                    npm ERR!       |                                           ^~~
                                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note:   candidate expects 2 arguments, 1 provided
                                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
                                    npm ERR!       |                                           ^~~
                                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note:   candidate expects 2 arguments, 1 provided
                                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const’
                                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note:   candidate expects 3 arguments, 2 provided
                                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const’
                                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note:   candidate expects 1 argument, 2 provided
                                    npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-primitive.h:11,
                                    npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:11:
                                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note: candidate: ‘v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const’
                                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note:   candidate expects 1 argument, 0 provided
                                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:1014:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                    npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:1048:3: note: in expansion of macro ‘NODE_MODULE_X’
                                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-10T22_35_01_714Z-debug-0.log
                                    • wauzzi
                                      sieht bei mir ähnlich aus:
                                      admin@iobroker:/opt/iobroker $ npm ls iobroker.ble bluetooth-hci-socket
                                      wird dies denn zwingend für den ble Adapter benötigt ?
                                      • Glasfaser
                                        keine Ahnung was das mit python3 zu tun hat
                                          @wauzzi
                                          Grundvoraussetzungen sind da?
                                          sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
                                          sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                                          • wauzzi
                                            sudo setcap cap_net_raw+eip $(eval readlink -f which node)
                                            offensichtlich, ja. Wenn ich dies beurteilen würde
                                            admin@iobroker:/opt/iobroker $ sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
                                            Reading package lists... Done
                                            Building dependency tree... Done
                                            bluetooth is already the newest version (5.66-1+rpt1+deb12u1).
                                            bluez is already the newest version (5.66-1+rpt1+deb12u1).
                                            libbluetooth-dev is already the newest version (5.66-1+rpt1+deb12u1).
                                            libudev-dev is already the newest version (252.22-1~deb12u1).
                                            libcap2-bin is already the newest version (1:2.66-4).
                                            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                            admin@iobroker:/opt/iobroker $ sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                                            1869
