    4. [GELÖST] ble Adapter macht Probleme auf Raspi 5
    • wauzzi
      wauzzi @Glasfaser last edited by
      @glasfaser Das hatte ich vorhin auch schon versucht. Hab es eben nochmals versucht.
      Scheint aber alles sauber zu sein:
      admin@iobroker:/opt/iobroker $ sudo npm install --production
      npm WARN config production Use `--omit=dev` instead.
      up to date in 3s
      145 packages are looking for funding
        run `npm fund` for details
      admin@iobroker:/opt/iobroker $ npm fund
      iobroker.inst@3.0.0
      ├── https://github.com/sponsors/epoberezkin
      │   └── ajv@6.12.6
      ├── https://github.com/sponsors/jaredhanson
      │   └── passport@0.6.0, oauth2orize@1.11.1
      ├── https://github.com/sponsors/isaacs
      │   └── glob@7.2.3, minimatch@7.4.6, rimraf@3.0.2
      ├── https://github.com/sponsors/feross
      │   └── safe-buffer@5.2.1, base64-js@1.5.1, buffer@6.0.3, simple-concat@1.0.1
      ├── https://github.com/sponsors/RubenVerborgh
      │   └── follow-redirects@1.15.5
      ├── https://github.com/sponsors/ljharb
      │   └── qs@6.10.4, minimist@1.2.8, define-properties@1.2.1, es-abstract@1.22.3, array-buffer-byte-length@1.0.1, arraybuffer.prototype.slice@1.0.3, available-typed-arrays@1.0.6, es-to-primitive@1.2.1, is-date-object@1.0.5, is-symbol@1.0.4, function.prototype.name@1.1.6, functions-have-names@1.2.3, get-symbol-description@1.0.2, globalthis@1.0.3, is-array-buffer@3.0.4, is-callable@1.2.7, is-negative-zero@2.0.2, is-regex@1.1.4, is-shared-array-buffer@1.0.2, is-string@1.0.7, is-typed-array@1.1.13, is-weakref@1.0.2, object.assign@4.1.5, regexp.prototype.flags@1.5.1, safe-array-concat@1.1.0, safe-regex-test@1.0.3, string.prototype.trim@1.2.8, string.prototype.trimend@1.0.7, string.prototype.trimstart@1.0.7, typed-array-byte-length@1.0.0, typed-array-byte-offset@1.0.0, typed-array-length@1.0.4, unbox-primitive@1.0.2, has-bigints@1.0.2, which-boxed-primitive@1.0.2, is-bigint@1.0.4, is-boolean-object@1.1.2, is-number-object@1.0.7, which-typed-array@1.1.14, has-tostringtag@1.0.2, traverse@0.6.8
      ├── https://github.com/sponsors/broofa
      │   └── uuid@9.0.1
      ├── https://github.com/sponsors/sindresorhus
      │   └── is-plain-obj@3.0.0, is-stream@2.0.1, responselike@2.0.1, clone-response@1.0.3, get-stream@5.2.0, normalize-url@6.1.0, onetime@5.1.2, make-dir@3.1.0, mimic-response@2.1.0, component-emitter@1.3.1, debounce@2.0.0
      ├── https://github.com/sponsors/jonschlinkert
      │   └── picomatch@2.3.1
      ├─┬ https://github.com/sindresorhus/got?sponsor=1
      │ │ └── got@11.8.6
      │ └── https://github.com/sindresorhus/is?sponsor=1
      │     └── @sindresorhus/is@4.6.0
      ├── https://github.com/sponsors/NaturalIntelligence
      │   └── fast-xml-parser@4.3.4
      ├─┬ https://opencollective.com/node-fetch
      │ │ └── node-fetch@3.3.2
      │ └── https://github.com/sponsors/jimmywarting
      │     └── fetch-blob@3.2.0, node-domexception@1.0.0
      ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
      │ │ └── wrap-ansi@7.0.0
      │ └── https://github.com/chalk/ansi-styles?sponsor=1
      │     └── ansi-styles@4.3.0
      ├── https://opencollective.com/serialport/donate
      │   └── serialport@12.0.0, @serialport/bindings-cpp@12.0.1, @serialport/parser-readline@11.0.0, @serialport/parser-delimiter@11.0.0, @serialport/parser-byte-length@12.0.0, @serialport/parser-cctalk@12.0.0, @serialport/parser-delimiter@12.0.0, @serialport/parser-inter-byte-timeout@12.0.0, @serialport/parser-readline@12.0.0, @serialport/parser-ready@12.0.0, @serialport/parser-regex@12.0.0, @serialport/parser-slip-encoder@12.0.0, @serialport/parser-spacepacket@12.0.0, @serialport/stream@12.0.0
      ├─┬ https://github.com/chalk/chalk-template?sponsor=1
      │ │ └── chalk-template@0.4.0
      │ └── https://github.com/chalk/chalk?sponsor=1
      │     └── chalk@4.1.2
      ├── https://opencollective.com/date-fns
      │   └── date-fns@2.30.0
      ├── https://opencollective.com/ioredis
      │   └── ioredis@4.28.5
      ├── https://github.com/sindresorhus/execa?sponsor=1
      │   └── execa@5.1.1
      ├── https://paulmillr.com/funding/
      │   └── chokidar@3.6.0
      ├── https://github.com/sponsors/sibiraj-s
      │   └── ci-info@3.9.0
      ├── https://opencollective.com/js-sdsl
      │   └── js-sdsl@4.3.0
      ├─┬ https://github.com/cheeriojs/cheerio?sponsor=1
      │ │ └── cheerio@1.0.0-rc.10
      │ ├─┬ https://github.com/sponsors/fb55
      │ │ │ └── cheerio-select@1.6.0, css-select@4.3.0, css-what@6.1.0, domelementtype@2.3.0
      │ │ └── https://github.com/fb55/domutils?sponsor=1
      │ │     └── domutils@2.8.0, domutils@3.1.0
      │ ├─┬ https://github.com/cheeriojs/dom-serializer?sponsor=1
      │ │ │ └── dom-serializer@1.4.1, dom-serializer@2.0.0
      │ │ └── https://github.com/fb55/entities?sponsor=1
      │ │     └── entities@2.2.0, entities@4.5.0
      │ ├── https://github.com/fb55/domhandler?sponsor=1
      │ │   └── domhandler@4.3.1, domhandler@5.0.3
      │ └── https://github.com/fb55/htmlparser2?sponsor=1
      │     └── htmlparser2@6.1.0, htmlparser2@8.0.2
      ├── https://locize.com
      │   └── i18next@21.10.0
      ├── https://ko-fi.com/killymxi
      │   └── @selderee/plugin-htmlparser2@0.11.0, selderee@0.11.0, parseley@0.12.1, leac@0.6.0, peberminta@0.9.0
      ├── https://github.com/sponsors/3846masa
      │   └── http-cookie-agent@5.0.4
      └── https://github.com/inikulin/parse5?sponsor=1
        └── parse5@7.1.2
      Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @wauzzi last edited by Glasfaser
        @wauzzi
        ins Verzeichniss
        cd /opt/iobroker/node_modules/bluetooth-hci-socket
        dann dort
        Bitte alles in Ruhe lesen , es steht auch dort !!
        wauzzi 1 Reply Last reply Reply Quote 0
        • wauzzi
          @glasfaser
          Danke für Deine Geduld mit mir 😌
          Das Verzeichnis "opt/iobroker/node_modules/bluetooth-hci-socket" existiert bei mir nicht.
          Ich hab eben nochmals mit dem Winscp geschaut. nicht vorhanden
            Thomas Braun Most Active @wauzzi last edited by
            @wauzzi sagte in ble Adapter macht Probleme auf Raspi 5:
            sudo npm
            Arrrgh. Nie npm in Verbindung mit sudo verwenden.
            • Glasfaser
              Beim Versuch "npm install bluetooth-hci-socket" durchzuführen
              cd /opt/iobroker
              sudo -H -u iobroker npm install bluetooth-hci-socket
                @wauzzi
                bluetooth-hci-socket wird auf aktuellen Systemen auch gar nicht mehr verwendet. Auf meinem jedenfalls nicht...
                echad@chet:/opt/iobroker $ npm ls iobroker.ble bluetooth-hci-socket
                iobroker.inst@3.0.0 /opt/iobroker
                └── iobroker.ble@0.14.0
                • wauzzi
                  @glasfaser said in ble Adapter macht Probleme auf Raspi 5:
                  admin@iobroker:~ $ cd /opt/iobroker
                  admin@iobroker:/opt/iobroker $ sudo -H -u iobroker npm install bluetooth-hci-socket
                  npm ERR! code 1
                  npm ERR! path /opt/iobroker/node_modules/bluetooth-hci-socket
                  npm ERR! command failed
                  npm ERR! command sh -c node-gyp rebuild
                  npm ERR! make: Entering directory '/opt/iobroker/node_modules/bluetooth-hci-socket/build'
                  npm ERR!   CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
                  npm ERR! make: Leaving directory '/opt/iobroker/node_modules/bluetooth-hci-socket/build'
                  npm ERR! gyp info it worked if it ends with ok
                  npm ERR! gyp info using node-gyp@10.0.1
                  npm ERR! gyp info using node@18.19.0 | linux | arm64
                  npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
                  npm ERR! gyp info spawn /usr/bin/python3
                  npm ERR! gyp info spawn args [
                  npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
                  npm ERR! gyp info spawn args 'binding.gyp',
                  npm ERR! gyp info spawn args '-f',
                  npm ERR! gyp info spawn args 'make',
                  npm ERR! gyp info spawn args '-I',
                  npm ERR! gyp info spawn args '/opt/iobroker/node_modules/bluetooth-hci-socket/build/config.gypi',
                  npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
                  npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.19.0/include/node/common.gypi',
                  npm ERR! gyp info spawn args '-Dlibrary=shared_library',
                  npm ERR! gyp info spawn args '-Dvisibility=default',
                  npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.19.0',
                  npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
                  npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.19.0/<(target_arch)/node.lib',
                  npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bluetooth-hci-socket',
                  npm ERR! gyp info spawn args '-Dnode_engine=v8',
                  npm ERR! gyp info spawn args '--depth=.',
                  npm ERR! gyp info spawn args '--no-parallel',
                  npm ERR! gyp info spawn args '--generator-output',
                  npm ERR! gyp info spawn args 'build',
                  npm ERR! gyp info spawn args '-Goutput_dir=.'
                  npm ERR! gyp info spawn args ]
                  npm ERR! gyp info spawn make
                  npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
                  npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static void BluetoothHciSocket::Init(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’:
                  npm ERR! ../src/BluetoothHciSocket.cpp:128:81: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’
                  npm ERR!   128 |   target->Set(Nan::New("BluetoothHciSocket").ToLocalChecked(), tmpl->GetFunction());
                  npm ERR!       |        ~~~~~~~~~~~~~~~~~^~
                  npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:15,
                  npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8.h:33,
                  npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:73,
                  npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/node_buffer.h:25,
                  npm ERR!                  from ../src/BluetoothHciSocket.cpp:7:
                  npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note: candidate: ‘v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)’
                  npm ERR!   513 |   V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(
                  npm ERR!       |                                              ^~~~~~~~~~~
                  npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note:   candidate expects 1 argument, 0 provided
                  npm ERR! ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:
                  npm ERR! ../src/BluetoothHciSocket.cpp:251:22: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                  npm ERR!   251 |     Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
                  npm ERR!       |     ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                  npm ERR! In file included from ../src/BluetoothHciSocket.cpp:8:
                  npm ERR! ../../nan/nan.h:1053:46: note: declared here
                  npm ERR!  1053 |   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
                  npm ERR!       |                                              ^~~~~~~~~~~~
                  npm ERR! ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:
                  npm ERR! ../src/BluetoothHciSocket.cpp:269:74: error: no matching function for call to ‘v8::Object::Get(v8::Local<v8::String>)’
                  npm ERR!   269 |   Local<Function> errorConstructor = Local<Function>::Cast(globalObj->Get(Nan::New("Error").ToLocalChecked()));
                  npm ERR!       |                                                            ~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                  npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-array-buffer.h:13,
                  npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8.h:24:
                  npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
                  npm ERR!   290 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
                  npm ERR!       |                                           ^~~
                  npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note:   candidate expects 2 arguments, 1 provided
                  npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
                  npm ERR!   293 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
                  npm ERR!       |                                           ^~~
                  npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note:   candidate expects 2 arguments, 1 provided
                  npm ERR! ../src/BluetoothHciSocket.cpp:275:53: error: no matching function for call to ‘v8::Function::NewInstance(int, v8::Local<v8::Value> [1])’
                  npm ERR!   275 |   Local<Value> error = errorConstructor->NewInstance(1, constructorArgs);
                  npm ERR!       |                        ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~
                  npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const’
                  npm ERR!    38 |   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
                  npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note:   candidate expects 3 arguments, 2 provided
                  npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const’
                  npm ERR!    41 |   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
                  npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note:   candidate expects 1 argument, 2 provided
                  npm ERR! ../src/BluetoothHciSocket.cpp:282:20: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                  npm ERR!   282 |   Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
                  npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)’:
                  npm ERR! ../src/BluetoothHciSocket.cpp:395:33: error: no matching function for call to ‘v8::Value::IntegerValue()’
                  npm ERR!   395 |       devId = arg0->IntegerValue();
                  npm ERR!       |               ~~~~~~~~~~~~~~~~~~^~
                  npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-primitive.h:11,
                  npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:11:
                  npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note: candidate: ‘v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const’
                  npm ERR!   413 |   V8_WARN_UNUSED_RESULT Maybe<int64_t> IntegerValue(
                  npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note:   candidate expects 1 argument, 0 provided
                  npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:
                  npm ERR! ../src/BluetoothHciSocket.cpp:417:33: error: no matching function for call to ‘v8::Value::IntegerValue()’
                  npm ERR!   417 |       devId = arg0->IntegerValue();
                  npm ERR! ../src/BluetoothHciSocket.cpp: At global scope:
                  npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:1014:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                  npm ERR!  1014 |       (node::addon_register_func) (regfunc),                          \
                  npm ERR!       |       ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                  npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:1048:3: note: in expansion of macro ‘NODE_MODULE_X’
                  npm ERR!  1048 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                  npm ERR! ../src/BluetoothHciSocket.cpp:499:1: note: in expansion of macro ‘NODE_MODULE’
                  npm ERR!   499 | NODE_MODULE(binding, BluetoothHciSocket::Init);
                  npm ERR! make: *** [binding.target.mk:111: Release/obj.target/binding/src/BluetoothHciSocket.o] Error 1
                  npm ERR! gyp ERR! build error
                  npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
                  npm ERR! gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)
                  npm ERR! gyp ERR! System Linux 6.1.0-rpi8-rpi-2712
                  npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                  npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socket
                  npm ERR! gyp ERR! node -v v18.19.0
                  npm ERR! gyp ERR! node-gyp -v v10.0.1
                  npm ERR! gyp ERR! not ok
                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-10T22_35_01_714Z-debug-0.log
                  • wauzzi
                    wauzzi @Thomas Braun last edited by
                    @thomas-braun said in ble Adapter macht Probleme auf Raspi 5:
                    sieht bei mir ähnlich aus:
                    admin@iobroker:/opt/iobroker $ npm ls iobroker.ble bluetooth-hci-socket
                    wird dies denn zwingend für den ble Adapter benötigt ?
                    • Glasfaser
                      keine Ahnung was das mit python3 zu tun hat
                        @wauzzi
                        Grundvoraussetzungen sind da?
                        sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
                        sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                        • wauzzi
                          sudo setcap cap_net_raw+eip $(eval readlink -f which node)
                          offensichtlich, ja. Wenn ich dies beurteilen würde
                          admin@iobroker:/opt/iobroker $ sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
                          Reading package lists... Done
                          Building dependency tree... Done
                          bluetooth is already the newest version (5.66-1+rpt1+deb12u1).
                          bluez is already the newest version (5.66-1+rpt1+deb12u1).
                          libbluetooth-dev is already the newest version (5.66-1+rpt1+deb12u1).
                          libudev-dev is already the newest version (252.22-1~deb12u1).
                          libcap2-bin is already the newest version (1:2.66-4).
                          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          admin@iobroker:/opt/iobroker $ sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                            @wauzzi
                            Dann schau dir einen Kaltstart des Adapters per
                            iob logs --watch | uniq
                            an.
                            Glasfaser wauzzi 2 Replies Last reply Reply Quote 0
                            • Glasfaser
                              Glasfaser @Thomas Braun last edited by
                              Kommt wohl öfters der Fehler vor :
                              https://github.com/AlCalzone/ioBroker.ble/issues/837
                              nifu777 created this issue in AlCalzone/ioBroker.ble
                              open Cannot find module #837
                              • wauzzi
                                2024-02-10 23:45:58.679  - info: ble.0 (1699) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v18.19.0, js-controller: 5.0.17
                                2024-02-10 23:45:58.740  - info: ble.0 (1699) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                                2024-02-10 23:45:58.741  - info: ble.0 (1699) enabled plugins: _default
                                2024-02-10 23:45:58.741  - info: ble.0 (1699) monitoring all services
                                2024-02-10 23:45:58.790  - info: ble.0 (1699) starting scanner process...
                                2024-02-10 23:45:58.901  - error: ble.0 (1699) Cannot find module '@abandonware/bluetooth-hci-socket'
                                Require stack:
                                - /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js
                                - /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/bindings.js
                                - /opt/iobroker/node_modules/@abandonware/noble/lib/resolve-bindings.js
                                - /opt/iobroker/node_modules/@abandonware/noble/with-custom-binding.js
                                - /opt/iobroker/node_modules/@abandonware/noble/index.js
                                - /opt/iobroker/node_modules/iobroker.ble/build/scanProcess.js
                                Require stack:
                                  @wauzzi
                                  Dann versuch
                                  sudo -H -u iobroker npm i @abandonware/bluetooth-hci-socket --omit=dev
                                  wauzzi 1 Reply Last reply Reply Quote 2
                                  • wauzzi
                                    wauzzi @Thomas Braun last edited by wauzzi
                                    @wauzzi
                                    Dann versuch
                                    Ja Geil !!!! Hat geklappt !!! Alles grün und die BT Geräte werden gefunden. MEGA !!!!👯
                                    Vielen lieben Dank Thomas
                                    Auch vielen lieben an alle anderen die mir versucht haben zu helfen 💞
                                    Jetzt kann Charlie wieder selbst nach Hause kommen 😉
                                    https://youtu.be/6ebXPKz4bSc?si=bCU5lA-OjBXOasHM
                                      wrod last edited by
                                      @wauzzi
                                      wegen solcher Probleme mit BLE habe ich schon länger ein Skript "fixble.sh" folgenden Inhalts:
                                      iobroker stop
                                      sudo apt update
                                      sudo apt upgrade
                                      cd /opt/iobroker/node_modules/iobroker.ble
                                      npm install --omit=dev
                                      iobroker fix
                                      sudo reboot
                                      Dieses startet u.a. npm install.
                                      Datin wird eine Abfrage gestellt, ob man etwas erneuern will.
                                      Ich würde das Skript gerne auch unattended (per cron) laufen lassen. (Wie) kann man dabei erreichen, dass diese Abfrage immer als mit "Y" beantwortet gilt, ohne dass ein Eingriff nötig ist?
                                      Dank im Voraus
                                      1869
