    4. [ESPHome] Beta release 0.5.0-beta.1 ready
      Thomas Braun Most Active @xdelta last edited by
      @xdelta
      Nein, habe ich zugegebenermaßen nicht.
      Simon42 1 Reply Last reply Reply Quote 0
      • Simon42
        Simon42 @Thomas Braun last edited by
        @thomas-braun das ganze war eigentlich auch mal dynmisch auf immer die neuste Version, kein plan warum es hier geändert / auf eine Version fixiert wurde: https://github.com/DrozmotiX/ioBroker.esphome/commit/6600a6aeb9a82fcecc5f848aa72a780d73998402
        0 yazgoo committed to DrozmotiX/ioBroker.esphome
        bind pillow package to version 10.0.1
        Webranger 1 Reply Last reply Reply Quote 0
        • Webranger
          Webranger @Simon42 last edited by
          Kann mir evtl wer helfen?
          Hab gerade espHome installiert und komme nicht auf das dashbord.
          in den logs taucht dieser Fehler auf.
          [Error caught and send to Sentry, thank you collaborating!] error: Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/python/3.11.7/bin/python3 -m venv /home/iobroker/.cache/autopy/venv/esphomePython path configuration: PYTHONHOME = (not set) PYTHONPATH = (not set) program name = '/home/iobroker/.cache/autopy/python/3.11.7/bin/python3' isolated = 0 environment = 1 user site = 1 safe_path = 0 import site = 1 is in build tree = 0 stdlib dir = '/home/iobroker/.cache/autopy/python/3.11.7/lib/python3.11' sys._base_executable = '/home/iobroker/.cache/autopy/python/3.11.7/bin/python3' sys.base_prefix = '/home/iobroker/.cache/autopy/python/3.11.7' sys.base_exec_prefix = '/home/iobroker/.cache/autopy/python/3.11.7' sys.platlibdir = 'lib' sys.executable = '/home/iobroker/.cache/autopy/python/3.11.7/bin/python3' sys.prefix = '/home/iobroker/.cache/autopy/python/3.11.7' sys.exec_prefix = '/home/iobroker/.cache/autopy/python/3.11.7' sys.path = [ '/home/iobroker/.cache/autopy/python/3.11.7/lib/python311.zip', '/home/iobroker/.cache/autopy/python/3.11.7/lib/python3.11', '/home/iobroker/.cache/autopy/python/3.11.7/lib/python3.11/lib-dynload', ]Fatal Python error: init_fs_encoding: failed to get the Python codec of the filesystem encodingPython runtime state: core initializedLookupError: no codec search functions registered: can't find encodingCurrent thread 0x00007f282281c740 (most recent call first): <no Python frame> at makeError (file:///opt/iobroker/node_modules/autopy/node_modules/execa/lib/error.js:60:11) at handlePromise (file:///opt/iobroker/node_modules/autopy/node_modules/execa/index.js:124:26) at processTicksAndRejections (node:internal/process/task_queues:95:5) at $df9eabe9bda49ea8$export$e522f41234ab669a (file:///opt/iobroker/node_modules/autopy/src/index.ts:228:9) at Esphome.espHomeDashboard (/opt/iobroker/node_modules/iobroker.esphome/main.js:110:19) at Esphome.onReady (/opt/iobroker/node_modules/iobroker.esphome/main.js:78:5)
          Kann damit jemand was anfangen und mir sagen was ich falsch gemacht habe?
            bernd33-1 @Webranger last edited by bernd33-1
            Hi, nachdem ich meinen ESPHome Adapter aktualisiert hab (0.5.0. Beta 8), bekomme ich auch die Meldung:
              Please update your pillow installation to 10.1.0. (pip install "pillow==10.1.0").
              - file: arial.ttf
                glyphs:
            Wie kann ich auf pillow 10.1.0 aktualisieren? mit pip install "pillow==10.1.0" bekomm ich pip:command not found
            Danke und Grüße, Bernd
            • Simon42
              Simon42 @bernd33-1 last edited by
              @bernd33-1 Hi, teste bitte mal mit install direkt von git: https://github.com/SimonFischer04/ioBroker.esphome/tree/fix/latestpillow
                bernd33-1 @Simon42 last edited by
                @simon42 Danke für die schnelle Antwort leider kein Erfolg. Oder muss der Raspy neu gestartetet werden?
                INFO ESPHome 2023.12.9
                INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/42display.yaml...
                Failed config
                font: [source <unicode string>:43]
                  - file: arial.ttf
                    glyphs:
                  bernd33-1 @bernd33-1 last edited by
                  @bernd33-1 Moment mal... das scheint nur den ESP mit dem EPaper Display zu betreffen. Ein anderer ESP der nur 2 Relais ein/aus schaltet tut. Da kann ich das Projekt compilieren. Scheint mit der arial.ttf Datei zusammen zu hängen?
                  • Simon42
                    @bernd33-1 ja das package braucht er nur für bestimmte esphome Komponenten. pls nochmal probiern, hab jetzt fix auf neuere Version geändert.
                      @simon42 Hi Simon, jetzt geht es. Ich hab/musste die ESPHome Instanz nach der Installation einmal von Hand neu starten und jetzt geht alles wieder. Log und Installieren via OTA.
                      Super vielen lieben Dank für die schnelle hilfe! 👍 😊 👏
                      Grüße und noch ein schönes WE, Bernd
                      • Simon42
                        @bernd33-1 Top 👍, No Problem und danke für die Rückmeldung.
                          PhilippIO last edited by
                          Guten Abend die Herren!
                          Ich springe auch von Version zu Version, bleibe aber immer beim selben Punkt stecken:
                          Mit der Adapter-Version aus den iobroker.net Beta repositories kam der Pillow-Fehler:
                          Nach diversen Versuchen habe ich dieses Forum gefunden, und auf v0.5.0-beta.10 aktualisiert. Das Fehlerbild war minimal anders: 10.2.0 statt 10.1.0:
                          INFO ESPHome 2024.2.0b1
                          INFO Reading configuration /opt/iobroker/iobroker-data/esphome.0/waage1.yaml...
                          Failed config
                          font: [source /opt/iobroker/iobroker-data/esphome.0/waage1.yaml:90]
                            Please update your pillow installation to 10.2.0. (pip install "pillow==10.2.0").
                            - file: fonts/Antenna-Bold.ttf
                          Den letzten Beiträgen folgend, habe ich nochmal auf SimonFischer-latestpillow aktualisiert:
                          Der Fehler blieb unverändert.
                          Mein Setup ist wie folgt:
                          Raspi3B+ mit Debian Bookworm 6.1.73 aarch64
                          iobroker v6.13.16 ... frisch installiert als einzige Software auf dem Raspi
                          ESPhome als quasi einziger Adapter
                          Python 3.11.2
                          NPM version 10.2.3
                          Node.js version 18.19.0
                          Python3-pil und pil-imagetk sind aktuell:
                          philipp@testiobroker:~ $ apt policy python3-pil python3-pil.imagetk
                          python3-pil:
                            Installed: 9.4.0-1.1+b1
                            Candidate: 9.4.0-1.1+b1
                            Version table:
                           *** 9.4.0-1.1+b1 500
                                  100 /var/lib/dpkg/status
                          python3-pil.imagetk:
                            Version table:
                          Ich bin für jeden Hinweis dankbar! 🙇‍♂️
                          • Simon42
                            Simon42 last edited by Simon42
                            @philippio said in [ESPHome] Beta release 0.5.0-beta.1 ready:
                            Genau das das Problem, gab schonwieder ein notwendiges update.
                            Habs wieder geupdated
                            Pls nochmal probiern: https://github.com/SimonFischer04/ioBroker.esphome/tree/fix/latestpillow
                            liegt halt wahrscheinlich dran das du hier eine beta 2024.2.0b1 dashboard installed hast, sonst hätt 10.1.0 reichen müssen, aber habs jetzt auf 10.2.0 updated
                            P F 3 Replies Last reply Reply Quote 1
                              PhilippIO @Simon42 last edited by
                              @simon42 Hallo Simon!
                              Zunächst mal vielen Dank für Deine schnelle Hilfe!
                              Über den Pillow-Fehler ist das Installationsskript hinausgelaufen. 👍
                              Jetzt compiliert er seit einer Stunde vor sich hin ... ich werde berichten.
                                Good news: mit der latestpillow-Version hat es funktioniert: mein Projekt ist online, im Netz, sendet Daten, OTA ist möglich ... Vielen Dank!
                                Kleines Aber: Beim Compilieren bleibt der Raspi jedes 2. Mal hängen ... ich habe schon über Nacht gewartet, kein Erfolg. Ausschalten, neu booten, neuer Versuch ... meistens ging es dann weiter. Jetzt aber nicht mehr: nur eine kleine Änderung am YAML-Skript, und er bleibt immer an dieser Stelle stehen:
                                INFO Generating C++ source...
                                INFO Compiling app...
                                Processing waage1 (board: lolin32_lite; framework: arduino; platform: platformio/espressif32@5.4.0)
                                Cannot read termcap database;
                                using dumb terminal settings.
                                HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
                                 - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
                                Dependency Graph
                                |-- AsyncTCP-esphome @ 2.0.1
                                |-- WiFi @ 2.0.0
                                |-- FS @ 2.0.0
                                |-- Update @ 2.0.0
                                |-- ESPAsyncWebServer-esphome @ 3.1.0
                                |-- DNSServer @ 2.0.0
                                |-- ESPmDNS @ 2.0.0
                                |-- noise-c @ 0.1.4
                                |-- SPI @ 2.0.0
                                Compiling .pioenvs/waage1/src/esphome/components/api/api_connection.cpp.o
                                Compiling .pioenvs/waage1/src/esphome/components/api/api_frame_helper.cpp.o
                                Compiling .pioenvs/waage1/src/esphome/components/api/api_pb2.cpp.o
                                Compiling .pioenvs/waage1/src/esphome/components/api/api_pb2_service.cpp.o
                                Erst dreht sich noch der farbige Kreis, dann "Session expired", neu laden des Dashboards funktioniert nicht, dann habe ich auch über SSH keinen Zugriff mehr auf den Raspi. Soweit reproduzierbar. Gibt es noch andere LOG-Dateien, die zeigen könnten, woran es scheitert?
                                Verzweifelt, Philipp
                                • Simon42
                                  Simon42 @PhilippIO last edited by
                                  @philippio hm, hat die yaml recht viele komponenten? schaut aus als würds im pi zu viel werden und stürzt ab maybe? glaub nicht, dass hier der adapter schuld ist
                                    @simon42 ... dann mache ich mich mal an den Umzug. Der "nackte" Raspi3 sollte zunächst nur der Erstbetankung via USB dienen. Mein operativer iobroker ist auf einem Raspi4 (mit Docker) daheim. Wenn es an der Rechenleistung hängt, sollte dieser dann mit dem Compilieren und späteren OTA-Update weniger Probleme haben. Ich probiere es aus und werde berichten! Danke soweit. 🙂
                                    • Simon42
                                      Simon42 @PhilippIO last edited by Simon42
                                      @philippio naja pi3 sollte ja eigentlich "nur langsamer" sein und nicht ewig komplett aufhängen. aber mal schauen vielleicht hilft der umzug ja: andere iobroker installation, ... 👍🏾
                                        Entschuldige die späte Antwort. Ich habe mich einige Abende mit Update und Backup (inkl. der ganzen Docker-Umgebung) beschäftigt, bevor ich mich an den Umzug des ESPhome device machen konnte. Ergebnis: Erfolg! Das Compilieren läuft komplett durch, Flashen OTA funktioniert reibungslos, alles top! 👍
                                        Offenbar reicht ein Raspi3B+ dann doch nicht aus ... wie gesagt: frisch aufgesetzt, iobroker als einzige Software, ESPhome als einziger Adapter. Das yaml-Skript sollte auch keine große Herausforderung gewesen sein: eine HX711-Waage mit Display
                                        Letzter offener Punkt: Ich schaffe es nicht, den Umzug ganz abzuschließen. Ich sehe mein Device unter Instanzeinstellungen.esphome - Geräte als gelistet und connected. Und nach Import des yaml-Files nach /opt/iobroker/iobroker-data/esphome.0/ sehe ich das device auf dem Dashboard. Aber: immer als offline. "edit" und "log" funktionieren problemlos, nachdem ich eine manual-IP im yaml-Skript ergänzt habe.
                                        Fehlt mir da beim Umzug noch ein letzter Schritt? Meine Vermutung ist, dass er den Eintrag unter Geräte und das Device auf dem Dashboard nicht miteinander in Verbindung bringt ... denn sonst hätte er die IP gewusst.
                                        • Simon42
                                          @philippio Sorry für die späte Antwort
                                          Völlig korrekt, das Dashboard (https://github.com/esphome/dashboard) hat mit dem adapter direkt nix zu tun. Adapter startet das einfach nur. (dashboard extern betreiben. oder auch gar nicht würd nix an der adapterfunktionalität / steuern und auslesen der existierenden Geräte im iobroker ändern)
                                          Wird das device nach eintragen der IP dann als online angezeigt? Schaut aus als gäbs bei der Probleme mit mDNS / auflösen von hostname zu ip. Aber wie gesagt, das dasboard ist im Prinzip eine "komplett" externe Komponente. Hat so gesehen nix mit dem adapter zu tun, wird "nur aus user-experience Erleichterung" mitinstalliert
                                            @simon42 sagte in [ESPHome] Beta release 0.5.0-beta.1 ready:
                                            Tatsächlich: nein. Es bleibt auf offline.
                                            Habe ich das Device falsch importiert? Fehlt mir noch eine Eintragung, um hostname zu IP zu verknüpfen?
                                            P.S.: "user-experience" trifft es aber sehr gut. Ich habe schon einige Arduinos, Raspis und Co programmiert. Aber dieser Weg, direkt OTA aus dem Zielsystem (=iobroker) heraus, ist schon eine sehr gelungene Lösung!
                                            adapter entwicklung adapter update esphome
                                            14
                                            88
                                            10662
