    4. [GELÖST] ble Adapter macht Probleme auf Raspi 5
    • Glasfaser
      Glasfaser last edited by
      @wauzzi sagte in ble Adapter macht Probleme auf Raspi 5:
      Beim Versuch "npm install bluetooth-hci-socket" durchzuführen
      cd /opt/iobroker
      sudo -H -u iobroker npm install bluetooth-hci-socket
      wauzzi 1 Reply Last reply Reply Quote 0
        Thomas Braun Most Active @wauzzi last edited by
        @wauzzi
        bluetooth-hci-socket wird auf aktuellen Systemen auch gar nicht mehr verwendet. Auf meinem jedenfalls nicht...
        echad@chet:/opt/iobroker $ npm ls iobroker.ble bluetooth-hci-socket
        iobroker.inst@3.0.0 /opt/iobroker
        └── iobroker.ble@0.14.0
        • wauzzi
          wauzzi @Glasfaser last edited by
          @glasfaser said in ble Adapter macht Probleme auf Raspi 5:
          admin@iobroker:~ $ cd /opt/iobroker
          admin@iobroker:/opt/iobroker $ sudo -H -u iobroker npm install bluetooth-hci-socket
          npm ERR! code 1
          npm ERR! path /opt/iobroker/node_modules/bluetooth-hci-socket
          npm ERR! command failed
          npm ERR! command sh -c node-gyp rebuild
          npm ERR! make: Entering directory '/opt/iobroker/node_modules/bluetooth-hci-socket/build'
          npm ERR!   CXX(target) Release/obj.target/binding/src/BluetoothHciSocket.o
          npm ERR! make: Leaving directory '/opt/iobroker/node_modules/bluetooth-hci-socket/build'
          npm ERR! gyp info it worked if it ends with ok
          npm ERR! gyp info using node-gyp@10.0.1
          npm ERR! gyp info using node@18.19.0 | linux | arm64
          npm ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
          npm ERR! gyp info spawn /usr/bin/python3
          npm ERR! gyp info spawn args [
          npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
          npm ERR! gyp info spawn args 'binding.gyp',
          npm ERR! gyp info spawn args '-f',
          npm ERR! gyp info spawn args 'make',
          npm ERR! gyp info spawn args '-I',
          npm ERR! gyp info spawn args '/opt/iobroker/node_modules/bluetooth-hci-socket/build/config.gypi',
          npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
          npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/18.19.0/include/node/common.gypi',
          npm ERR! gyp info spawn args '-Dlibrary=shared_library',
          npm ERR! gyp info spawn args '-Dvisibility=default',
          npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.19.0',
          npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
          npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.19.0/<(target_arch)/node.lib',
          npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/bluetooth-hci-socket',
          npm ERR! gyp info spawn args '-Dnode_engine=v8',
          npm ERR! gyp info spawn args '--depth=.',
          npm ERR! gyp info spawn args '--no-parallel',
          npm ERR! gyp info spawn args '--generator-output',
          npm ERR! gyp info spawn args 'build',
          npm ERR! gyp info spawn args '-Goutput_dir=.'
          npm ERR! gyp info spawn args ]
          npm ERR! gyp info spawn make
          npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
          npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static void BluetoothHciSocket::Init(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’:
          npm ERR! ../src/BluetoothHciSocket.cpp:128:81: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’
          npm ERR!   128 |   target->Set(Nan::New("BluetoothHciSocket").ToLocalChecked(), tmpl->GetFunction());
          npm ERR!       |        ~~~~~~~~~~~~~~~~~^~
          npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:15,
          npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8.h:33,
          npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:73,
          npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/node_buffer.h:25,
          npm ERR!                  from ../src/BluetoothHciSocket.cpp:7:
          npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note: candidate: ‘v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)’
          npm ERR!   513 |   V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(
          npm ERR!       |                                              ^~~~~~~~~~~
          npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-template.h:513:46: note:   candidate expects 1 argument, 0 provided
          npm ERR! ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:
          npm ERR! ../src/BluetoothHciSocket.cpp:251:22: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
          npm ERR!   251 |     Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
          npm ERR!       |     ~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
          npm ERR! In file included from ../src/BluetoothHciSocket.cpp:8:
          npm ERR! ../../nan/nan.h:1053:46: note: declared here
          npm ERR!  1053 |   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
          npm ERR!       |                                              ^~~~~~~~~~~~
          npm ERR! ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:
          npm ERR! ../src/BluetoothHciSocket.cpp:269:74: error: no matching function for call to ‘v8::Object::Get(v8::Local<v8::String>)’
          npm ERR!   269 |   Local<Function> errorConstructor = Local<Function>::Cast(globalObj->Get(Nan::New("Error").ToLocalChecked()));
          npm ERR!       |                                                            ~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
          npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-array-buffer.h:13,
          npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8.h:24:
          npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
          npm ERR!   290 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
          npm ERR!       |                                           ^~~
          npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:290:43: note:   candidate expects 2 arguments, 1 provided
          npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
          npm ERR!   293 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
          npm ERR!       |                                           ^~~
          npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:293:43: note:   candidate expects 2 arguments, 1 provided
          npm ERR! ../src/BluetoothHciSocket.cpp:275:53: error: no matching function for call to ‘v8::Function::NewInstance(int, v8::Local<v8::Value> [1])’
          npm ERR!   275 |   Local<Value> error = errorConstructor->NewInstance(1, constructorArgs);
          npm ERR!       |                        ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~
          npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const’
          npm ERR!    38 |   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
          npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:38:44: note:   candidate expects 3 arguments, 2 provided
          npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const’
          npm ERR!    41 |   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(
          npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-function.h:41:44: note:   candidate expects 1 argument, 2 provided
          npm ERR! ../src/BluetoothHciSocket.cpp:282:20: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
          npm ERR!   282 |   Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
          npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindRaw(Nan::NAN_METHOD_ARGS_TYPE)’:
          npm ERR! ../src/BluetoothHciSocket.cpp:395:33: error: no matching function for call to ‘v8::Value::IntegerValue()’
          npm ERR!   395 |       devId = arg0->IntegerValue();
          npm ERR!       |               ~~~~~~~~~~~~~~~~~~^~
          npm ERR! In file included from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-primitive.h:11,
          npm ERR!                  from /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-object.h:11:
          npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note: candidate: ‘v8::Maybe<long int> v8::Value::IntegerValue(v8::Local<v8::Context>) const’
          npm ERR!   413 |   V8_WARN_UNUSED_RESULT Maybe<int64_t> IntegerValue(
          npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/v8-value.h:413:40: note:   candidate expects 1 argument, 0 provided
          npm ERR! ../src/BluetoothHciSocket.cpp: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE BluetoothHciSocket::BindUser(Nan::NAN_METHOD_ARGS_TYPE)’:
          npm ERR! ../src/BluetoothHciSocket.cpp:417:33: error: no matching function for call to ‘v8::Value::IntegerValue()’
          npm ERR!   417 |       devId = arg0->IntegerValue();
          npm ERR! ../src/BluetoothHciSocket.cpp: At global scope:
          npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:1014:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
          npm ERR!  1014 |       (node::addon_register_func) (regfunc),                          \
          npm ERR!       |       ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
          npm ERR! /home/iobroker/.cache/node-gyp/18.19.0/include/node/node.h:1048:3: note: in expansion of macro ‘NODE_MODULE_X’
          npm ERR!  1048 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
          npm ERR! ../src/BluetoothHciSocket.cpp:499:1: note: in expansion of macro ‘NODE_MODULE’
          npm ERR!   499 | NODE_MODULE(binding, BluetoothHciSocket::Init);
          npm ERR! make: *** [binding.target.mk:111: Release/obj.target/binding/src/BluetoothHciSocket.o] Error 1
          npm ERR! gyp ERR! build error
          npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
          npm ERR! gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:209:23)
          npm ERR! gyp ERR! System Linux 6.1.0-rpi8-rpi-2712
          npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
          npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/bluetooth-hci-socket
          npm ERR! gyp ERR! node -v v18.19.0
          npm ERR! gyp ERR! node-gyp -v v10.0.1
          npm ERR! gyp ERR! not ok
          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-02-10T22_35_01_714Z-debug-0.log
          Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
          • wauzzi
            wauzzi @Thomas Braun last edited by
            @thomas-braun said in ble Adapter macht Probleme auf Raspi 5:
            sieht bei mir ähnlich aus:
            admin@iobroker:/opt/iobroker $ npm ls iobroker.ble bluetooth-hci-socket
            wird dies denn zwingend für den ble Adapter benötigt ?
            • Glasfaser
              Glasfaser @wauzzi last edited by
              keine Ahnung was das mit python3 zu tun hat
                @wauzzi
                Grundvoraussetzungen sind da?
                sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
                sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                • wauzzi
                  sudo setcap cap_net_raw+eip $(eval readlink -f which node)
                  offensichtlich, ja. Wenn ich dies beurteilen würde
                  admin@iobroker:/opt/iobroker $ sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
                  Reading package lists... Done
                  Building dependency tree... Done
                  bluetooth is already the newest version (5.66-1+rpt1+deb12u1).
                  bluez is already the newest version (5.66-1+rpt1+deb12u1).
                  libbluetooth-dev is already the newest version (5.66-1+rpt1+deb12u1).
                  libudev-dev is already the newest version (252.22-1~deb12u1).
                  libcap2-bin is already the newest version (1:2.66-4).
                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  admin@iobroker:/opt/iobroker $ sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                    @wauzzi
                    Dann schau dir einen Kaltstart des Adapters per
                    iob logs --watch | uniq
                    an.
                    Glasfaser wauzzi 2 Replies Last reply Reply Quote 0
                    • Glasfaser
                      Glasfaser @Thomas Braun last edited by
                      Kommt wohl öfters der Fehler vor :
                      https://github.com/AlCalzone/ioBroker.ble/issues/837
                      nifu777 created this issue in AlCalzone/ioBroker.ble
                      open Cannot find module #837
                      • wauzzi
                        2024-02-10 23:45:58.679  - info: ble.0 (1699) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v18.19.0, js-controller: 5.0.17
                        2024-02-10 23:45:58.740  - info: ble.0 (1699) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                        2024-02-10 23:45:58.741  - info: ble.0 (1699) enabled plugins: _default
                        2024-02-10 23:45:58.741  - info: ble.0 (1699) monitoring all services
                        2024-02-10 23:45:58.790  - info: ble.0 (1699) starting scanner process...
                        2024-02-10 23:45:58.901  - error: ble.0 (1699) Cannot find module '@abandonware/bluetooth-hci-socket'
                        Require stack:
                        - /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/hci.js
                        - /opt/iobroker/node_modules/@abandonware/noble/lib/hci-socket/bindings.js
                        - /opt/iobroker/node_modules/@abandonware/noble/lib/resolve-bindings.js
                        - /opt/iobroker/node_modules/@abandonware/noble/with-custom-binding.js
                        - /opt/iobroker/node_modules/@abandonware/noble/index.js
                        - /opt/iobroker/node_modules/iobroker.ble/build/scanProcess.js
                        Require stack:
                          @wauzzi
                          Dann versuch
                          cd /opt/iobroker/node_modules
                          sudo -H -u iobroker npm i @abandonware/bluetooth-hci-socket --omit=dev
                          wauzzi 1 Reply Last reply Reply Quote 2
                          • wauzzi
                            wauzzi @Thomas Braun last edited by wauzzi
                            @wauzzi
                            Dann versuch
                            Ja Geil !!!! Hat geklappt !!! Alles grün und die BT Geräte werden gefunden. MEGA !!!!👯
                            Vielen lieben Dank Thomas
                            Auch vielen lieben an alle anderen die mir versucht haben zu helfen 💞
                            Jetzt kann Charlie wieder selbst nach Hause kommen 😉
                            https://youtu.be/6ebXPKz4bSc?si=bCU5lA-OjBXOasHM
                              wrod last edited by
                              @wauzzi
                              wegen solcher Probleme mit BLE habe ich schon länger ein Skript "fixble.sh" folgenden Inhalts:
                              iobroker stop
                              sudo apt update
                              sudo apt upgrade
                              cd /opt/iobroker/node_modules/iobroker.ble
                              npm install --omit=dev
                              iobroker fix
                              sudo reboot
                              Dieses startet u.a. npm install.
                              Datin wird eine Abfrage gestellt, ob man etwas erneuern will.
                              Ich würde das Skript gerne auch unattended (per cron) laufen lassen. (Wie) kann man dabei erreichen, dass diese Abfrage immer als mit "Y" beantwortet gilt, ohne dass ein Eingriff nötig ist?
                              Dank im Voraus
                              1869
