    3. Einsteigerfragen
    4. NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?
    • DJMarc75
      DJMarc75 @raVsu last edited by
      @ravsu
      https://forum.iobroker.net/topic/71478/plötzliche-probleme-durch-nodejs-dfsg-version-npm-fehlt
        Homoran Global Moderator Administrators @raVsu last edited by
        @ravsu leider ist das nicht die Langversion, sondern ur ein Ausschnitt.
        bitte nachliefern!
          raVsu @Homoran last edited by
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
                    Kernel: Linux 6.1.0-18-arm64
              Architecture: arm64
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           13:13:27 up 10:12,  2 users,  load average: 0.93, 0.95, 0.90
          CPU threads: 4
          *** Time and Time Zones ***
                         Local time: Sun 2024-02-11 13:13:27 CET
                     Universal time: Sun 2024-02-11 12:13:27 UTC
                           RTC time: n/a
                        NTP service: n/a
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi sudo iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            4.0G        3.0G        437M        704K        676M        924M
          Swap:             0B          0B          0B
          Total:          4.0G        3.0G        437M
                   3786 M total memory
                   2904 M used memory
                    293 M active memory
                   2793 M inactive memory
                    417 M free memory
                     87 M buffer memory
                    557 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          *** FAILED SERVICES ***
            UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
          * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          1 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  1.9G     0  1.9G   0% /dev
          tmpfs          tmpfs     379M  696K  378M   1% /run
          /dev/sda2      ext4      118G   23G   90G  20% /
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
          /dev/sda1      vfat      396M  306M   90M  78% /boot/firmware
          tmpfs          tmpfs     379M     0  379M   0% /run/user/1000
          [Sun Feb 11 03:01:11 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sun Feb 11 03:01:14 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
          TARGET           SOURCE    FSTYPE OPTIONS
          /                /dev/sda2 ext4   rw,relatime
          `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
          /var:
          12G     /var/
          9.4G    /var/lib
          9.3G    /var/lib/influxdb/engine/data
          Archived and active journals take up 15.3M in the file system.
          /opt/iobroker/backups:
          282M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          2.2G    /opt/iobroker/iobroker-data/
          1.4G    /opt/iobroker/iobroker-data/history
          653M    /opt/iobroker/iobroker-data/files
          145M    /opt/iobroker/iobroker-data/files/vis-2
          116M    /opt/iobroker/iobroker-data/backup-objects
          42M     /opt/iobroker/iobroker-data/objects.jsonl
          41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
          24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.19.0
          /usr/bin/node           v18.19.0
          /usr/bin/npm            9.2.0
          /usr/bin/npx            9.2.0
          /home/iobroker/.diag.sh: line 281: corepack: command not found
          *** nodejs is NOT correctly installed ***
          nodejs:
            Installed: 18.19.0+dfsg-6~deb12u1
            Candidate: 18.19.0+dfsg-6~deb12u1
            Version table:
           *** 18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
                  100 /var/lib/dpkg/status
               18.13.0+dfsg1-1 500
               14.21.3-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: redis
          Core adapters versions
          js-controller:  5.0.17
          admin:          6.13.16
          javascript:     7.1.6
          Adapters from github:   0
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
            system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
          + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
          + system.adapter.history.0                : history               : iobroker                                 -  enabled
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.178.64
          + system.adapter.knx.1                    : knx                   : iobroker                                 -  enabled, bind: 192.168.178.64
            system.adapter.material.0               : material              : iobroker                                 -  enabled
          + system.adapter.matrix-org.0             : matrix-org            : iobroker                                 -  enabled
            system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
          + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
          + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
          + system.adapter.senec.0                  : senec                 : iobroker                                 -  enabled
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5678
            system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
          + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
            system.adapter.text2command.0           : text2command          : iobroker                                 - disabled
          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.tradfri.0                : tradfri               : iobroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 192.168.178.64, run as: admin
          + instance is alive
          ioBroker-Repositories
          __            :
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "backitup"     : 2.9.8    , installed 2.9.8
          Adapter    "bring"        : 1.8.4    , installed 1.8.4
          Adapter    "echarts"      : 1.7.2    , installed 1.7.2
          Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
          Adapter    "harmony"      : 1.3.0    , installed 1.3.0
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "knx"          : 2.0.24   , installed 2.0.24
          Adapter    "material"     : 1.3.1    , installed 1.3.1
          Adapter    "matrix-org"   : 1.0.0    , installed 1.0.0
          Adapter    "modbus"       : 6.1.0    , installed 6.1.0
          Adapter    "node-red"     : 5.1.0    , installed 5.1.0
          Adapter    "synology"     : 3.0.1    , installed 3.0.1
          Adapter    "telegram"     : 3.0.1    , installed 3.0.1
          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
          Adapter    "trashschedule": 2.3.0    , installed 2.3.0
          Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
          Adapter    "web"          : 6.2.3    , installed 6.2.3
          Adapter    "ws"           : 2.5.10   , installed 2.5.10
          Objects and States
          Objects:        3554
          States:         2849
          Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:2 http://deb.debian.org/debian bookworm InRelease
          Get:3 https://deb.nodesource.com/node_14.x bullseye InRelease [4586 B]
          Fetched 4586 B in 1s (4359 B/s)
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15724      1/init
          tcp        0      0 127.0.0.1:39611         0.0.0.0:*               LISTEN      998        18660      662/influxd
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16987      751/iobroker.js-con
          tcp        0      0 192.168.178.64:8082     0.0.0.0:*               LISTEN      1001       23670      1175/io.web.0
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       19083      877/node-red
          tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      108        20986      576/redis-server 12
          tcp6       0      0 :::22                   :::*                    LISTEN      0          20904      1/init
          tcp6       0      0 :::111                  :::*                    LISTEN      0          14485      1/init
          tcp6       0      0 :::3000                 :::*                    LISTEN      109        18640      659/grafana-server
          tcp6       0      0 :::61991                :::*                    LISTEN      1001       21531      1032/io.harmony.0
          tcp6       0      0 :::8088                 :::*                    LISTEN      1001       19423      1107/io.terminal.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21588      1088/io.simple-api.
          tcp6       0      0 :::8086                 :::*                    LISTEN      998        21112      662/influxd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18733      771/io.admin.0
          tcp6       0      0 ::1:6379                :::*                    LISTEN      108        20987      576/redis-server 12
          udp        0      0 192.168.178.64:49204    0.0.0.0:*                           1001       302103     1077/io.knx.0
          udp        0      0 192.168.178.64:57399    0.0.0.0:*                           1001       330977     1274/io.knx.1
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19501      488/dhclient
          udp        0      0 192.168.178.64:51293    0.0.0.0:*                           1001       469823     1274/io.knx.1
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14484      1/init
          udp        0      0 192.168.178.64:123      0.0.0.0:*                           0          19660      657/ntpd
          udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          19658      657/ntpd
          udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          19654      657/ntpd
          udp        0      0 192.168.178.64:57504    0.0.0.0:*                           1001       429548     1077/io.knx.0
          udp        0      0 192.168.178.64:49319    0.0.0.0:*                           1001       470534     1077/io.knx.0
          udp        0      0 192.168.178.64:51367    0.0.0.0:*                           1001       420774     1077/io.knx.0
          udp        0      0 192.168.178.64:53529    0.0.0.0:*                           1001       22704      1274/io.knx.1
          udp        0      0 192.168.178.64:45388    0.0.0.0:*                           1001       321213     1274/io.knx.1
          udp        0      0 0.0.0.0:35299           0.0.0.0:*                           1001       19091      877/node-red
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       21532      1032/io.harmony.0
          udp        0      0 192.168.178.64:55965    0.0.0.0:*                           1001       385583     1274/io.knx.1
          udp        0      0 192.168.178.64:49892    0.0.0.0:*                           1001       505627     1274/io.knx.1
          udp        0      0 192.168.178.64:45905    0.0.0.0:*                           1001       253074     1077/io.knx.0
          udp        0      0 192.168.178.64:50041    0.0.0.0:*                           1001       422743     1274/io.knx.1
          udp        0      0 192.168.178.64:48017    0.0.0.0:*                           1001       211583     1274/io.knx.1
          udp        0      0 192.168.178.64:37840    0.0.0.0:*                           1001       418223     1077/io.knx.0
          udp        0      0 192.168.178.64:39931    0.0.0.0:*                           1001       122879     1077/io.knx.0
          udp        0      0 192.168.178.64:54375    0.0.0.0:*                           1001       101212     1274/io.knx.1
          udp        0      0 192.168.178.64:44191    0.0.0.0:*                           1001       293347     1077/io.knx.0
          udp        0      0 192.168.178.64:52430    0.0.0.0:*                           1001       128594     1077/io.knx.0
          udp        0      0 192.168.178.64:5353     0.0.0.0:*                           1001       19984      933/io.tr-064.0
          udp        0      0 192.168.178.64:40188    0.0.0.0:*                           1001       156073     1274/io.knx.1
          udp        0      0 192.168.178.64:44358    0.0.0.0:*                           1001       127381     1077/io.knx.0
          udp        0      0 192.168.178.64:50523    0.0.0.0:*                           1001       77832      1274/io.knx.1
          udp        0      0 192.168.178.64:56678    0.0.0.0:*                           1001       233936     1274/io.knx.1
          udp        0      0 192.168.178.64:38283    0.0.0.0:*                           1001       508554     1274/io.knx.1
          udp        0      0 192.168.178.64:40366    0.0.0.0:*                           1001       312936     1077/io.knx.0
          udp        0      0 192.168.178.64:40379    0.0.0.0:*                           1001       477077     1077/io.knx.0
          udp        0      0 192.168.178.64:46531    0.0.0.0:*                           1001       22542      1077/io.knx.0
          udp        0      0 192.168.178.64:56815    0.0.0.0:*                           1001       161599     1077/io.knx.0
          udp        0      0 192.168.178.64:42485    0.0.0.0:*                           1001       155109     1077/io.knx.0
          udp        0      0 192.168.178.64:40468    0.0.0.0:*                           1001       113953     1077/io.knx.0
          udp        0      0 192.168.178.64:36410    0.0.0.0:*                           1001       459628     1274/io.knx.1
          udp        0      0 192.168.178.64:46655    0.0.0.0:*                           1001       282025     1274/io.knx.1
          udp        0      0 192.168.178.64:58975    0.0.0.0:*                           1001       217741     1274/io.knx.1
          udp        0      0 192.168.178.64:36545    0.0.0.0:*                           1001       196604     1274/io.knx.1
          udp        0      0 192.168.178.64:54978    0.0.0.0:*                           1001       46227      1077/io.knx.0
          udp        0      0 192.168.178.64:49036    0.0.0.0:*                           1001       396197     1274/io.knx.1
          udp        0      0 0.0.0.0:36773           0.0.0.0:*                           1001       22558      1118/io.tradfri.0
          udp        0      0 192.168.178.64:36840    0.0.0.0:*                           1001       501851     1274/io.knx.1
          udp        0      0 192.168.178.64:34820    0.0.0.0:*                           1001       360741     1077/io.knx.0
          udp        0      0 192.168.178.64:38926    0.0.0.0:*                           1001       155789     1274/io.knx.1
          udp6       0      0 :::111                  :::*                                0          15725      1/init
          udp6       0      0 fe80::dea6:32ff:fe3:123 :::*                                0          19666      657/ntpd
          udp6       0      0 2003:c5:171c:2200:d:123 :::*                                0          19664      657/ntpd
          udp6       0      0 ::1:123                 :::*                                0          19662      657/ntpd
          udp6       0      0 :::123                  :::*                                0          19651      657/ntpd
          2024-02-11 13:14:52.815  - info: knx.0 (1077) Change state from STATE_READY(7) to STATE_CONNECTION_STATE_REQUEST(5)
          2024-02-11 13:14:52.817  - info: knx.0 (1077) Received CONNECTIONSTATE_RESPONSE :    06 10 02 08 00 08 c6 00                                                              192.168.178.57:3671 ChID : 198 SeqCntIN : 75 SeqCntOUT : 0  msgCode : [object Object]
          2024-02-11 13:14:52.818  - info: knx.0 (1077) Change state from STATE_CONNECTION_STATE_REQUEST(5) to STATE_CONNECTION_STATE_RESPONSE(6)
          2024-02-11 13:14:52.818  - info: knx.0 (1077) Change state from STATE_CONNECTION_STATE_RESPONSE(6) to STATE_READY(7)
          2024-02-11 13:14:52.857  - info: knx.0 (1077) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 c6 4c 00 29 00 bc e0 00 07 00 09 03 00 80 14 a6   ChID: 198
          2024-02-11 13:14:52.858  - info: knx.0 (1077) WRITE : mappedName : LichtWert Flur Einganfsbereich    dest : 0/0/9  val: 5286   (DPT7.013) LichtWert_Flur_Einganfsbereich
          2024-02-11 13:14:52.858  - info: knx.0 (1077) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
          2024-02-11 13:14:52.859  - info: knx.0 (1077) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
          2024-02-11 13:14:52.859  - info: knx.0 (1077) =====> STATE_TUNNELING_ACK
          2024-02-11 13:14:52.860  - info: knx.0 (1077) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 c6 4c 00   ChID : 198 SeqCntIN : 76 SeqCntOUT : 0 queue length : 0
          2024-02-11 13:14:52.860  - info: knx.0 (1077) ( 4.b ) return to STATE_READY, processing : false
          2024-02-11 13:14:52.861  - info: knx.0 (1077) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
          2024-02-11 13:14:54.862  - info: knx.0 (1077) Send : UDP Connection State Request :  06 10 02 07 00 10 c6 00 08 01 00 00 00 00 9d bb     sent from Port:  to 192.168.178.57:3671
          2024-02-11 13:14:54.863  - info: knx.0 (1077) Change state from STATE_READY(7) to STATE_CONNECTION_STATE_REQUEST(5)
          2024-02-11 13:14:54.865  - info: knx.0 (1077) Received CONNECTIONSTATE_RESPONSE :    06 10 02 08 00 08 c6 00                                                              192.168.178.57:3671 ChID : 198 SeqCntIN : 76 SeqCntOUT : 0  msgCode : [object Object]
          2024-02-11 13:14:54.866  - info: knx.0 (1077) Change state from STATE_CONNECTION_STATE_REQUEST(5) to STATE_CONNECTION_STATE_RESPONSE(6)
          2024-02-11 13:14:54.867  - info: knx.0 (1077) Change state from STATE_CONNECTION_STATE_RESPONSE(6) to STATE_READY(7)
          2024-02-11 13:14:55.295  - info: knx.0 (1077) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 19 04 c6 4d 00 29 00 bc e0 00 01 04 0f 05 00 80 42 1c 00 00   ChID: 198
          2024-02-11 13:14:55.296  - info: knx.0 (1077) WRITE : mappedName : Leistung Gesmt Ptot    dest : 0/4/15  val: 39   (DPT14.056) Leistung_Gesmt_Ptot
          2024-02-11 13:14:55.297  - info: knx.0 (1077) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
          2024-02-11 13:14:55.297  - info: knx.0 (1077) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
          2024-02-11 13:14:55.297  - info: knx.0 (1077) =====> STATE_TUNNELING_ACK
          2024-02-11 13:14:55.299  - info: knx.0 (1077) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 c6 4d 00   ChID : 198 SeqCntIN : 77 SeqCntOUT : 0 queue length : 0
          2024-02-11 13:14:55.299  - info: knx.0 (1077) ( 4.b ) return to STATE_READY, processing : false
          2024-02-11 13:14:55.299  - info: knx.0 (1077) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
            Hier nochmal die Zusammenfassung:
                                    v.2023-10-10
                   Icon name: computer
                Architecture: arm64
            Installation:           native
            Kernel:                 aarch64
            Userland:               arm64
            Timezone:               Europe/Berlin (CET, +0100)
            User-ID:                1000
            X-Server:               false
            Boot Target:            graphical.target
            Pending OS-Updates:     0
            Pending iob updates:    0
            Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                    /usr/bin/npm            9.2.0
                                    /usr/bin/npx            9.2.0
            /home/iobroker/.diag.sh: line 490: corepack: command not found
            Recommended versions are nodejs 18.19.0 and npm 10.2.3
            Wrong installation path detected. This needs to be fixed
            Please check
            https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
            for more information on how to fix these errors.
            MEMORY:
            Mem:            4.0G        3.0G        280M        712K        848M        928M
            Swap:             0B          0B          0B
            Total:          4.0G        3.0G        280M
            Active iob-Instances:   26
            ioBroker Core:          js-controller           5.0.17
                                    admin                   6.13.16
            Objects type: jsonl
            States  type: redis
            Objects:                3554
            States:                 2849
            Size of iob-Database:
            8.6M    /opt/iobroker/iobroker-data/objects.json.migrated
            8.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
            408K    /opt/iobroker/iobroker-data/states.json
            32K     /opt/iobroker/iobroker-data/states.json.bak
            • Glasfaser
              Glasfaser @raVsu last edited by
              @ravsu sagte in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
              Wie kann ich das korrigieren?
              wurde dir schon gesagt :
              @djmarc75 sagte in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
              @ravsu
                Homoran Global Moderator Administrators @Glasfaser last edited by
                @glasfaser sollte das nicht im nodejs-update mit drin sein?
                @Thomas-Braun oder wo war das mit drin?
                Glasfaser DJMarc75 2 Replies Last reply Reply Quote 0
                • Glasfaser
                  Glasfaser @Homoran last edited by Glasfaser
                  ich kann hier keine Antwort sehen ... was er schon gemacht hat !
                    @Glasfaser
                    Ja, den Befehl habe ich ausgeführt
                    aber leider weder die Eingabe noch die Ausgabe gezeigt
                    • DJMarc75
                      DJMarc75 @Homoran last edited by
                      @homoran sagte in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
                      bei einer Neuinstallation über den Einzeiler
                        raVsu @Homoran last edited by Homoran
                        pi@iobroker:~$ iob nodejs-update
                        iobroker nodejs-update [<major-version>]
                        Upgrade the Node.JS installation to the current LTS
                        Options:
                          --help  Show help  [boolean]
                        Glasfaser Homoran 2 Replies Last reply Reply Quote 0
                        • Glasfaser
                          Glasfaser @raVsu last edited by Glasfaser
                          @ravsu
                          Danke für die Ausgabe ... dann ist alles klar , warum es nicht geht
                          Aktualisiere erstmal :
                          iob stop
                          iob fix
                          iob start
                          dann
                          iob nodejs-update
                            Options:
                            Das ist ein gutes Beispiel warum immer alles gezeigt werden muss!
                            hier steht das alles drin
                              raVsu @Glasfaser last edited by Homoran
                              @glasfaser
                              iob stop
                              iob fix
                              iob start
                              dann
                              iob nodejs-update
                              durchgeführt
                              ioBroker nodejs updater 2023-10-13
                              Recommended nodejs-version is: 18.19.0
                              Checking your installation now. Please be patient!
                              Your current setup is:
                              /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
                              /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
                              /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
                              /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
                              We found these nodejs versions available for installation:
                              nodejs:
                                Candidate: 14.21.3-deb-1nodesource1
                                Version table:
                                   18.13.0+dfsg1-1 500
                                   14.21.3-deb-1nodesource1 1001
                              Your nodejs-Installation seems to be faulty. Shall we try to fix it?
                              Press <y> to continue or any other key to quit
                              Fixing your nodejs setup
                              *** Deleting  ***
                              rm: cannot remove '': No such file or directory
                              *** Deleting  ***
                              Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
                              Nothing to do - Your version is the recommended one.
                              You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
                              Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
                              jetzt wird folgendes angezeigt:
                                Thomas Braun Most Active @raVsu last edited by
                                @ravsu
                                https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
                                  @ravsu
                                  bitte in code-tags setzen!
                                  bitte nicht nur selektierte Ausschnitte posten!
                                    raVsu @Thomas Braun last edited by
                                    Danke für den Link.
                                    Bei dem Befehl
                                    sudo apt install nodejs=18.19.0-1nodesource1
                                    wird am ende eine Fehlermeldung geliefert:
                                    E: Version '18.19.0-1nodesource1' for 'nodejs' was not found
                                    pi@iobroker:~$ apt policy nodejs
                                    nodejs:
                                      Version table:
                                         18.13.0+dfsg1-1 500
                                    pi@iobroker:~$ echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
                                    sudo apt update
                                    iob stop
                                    sudo apt remove npm
                                    iob restart
                                    Package: nodejs
                                    Pin-Priority: 1001
                                    Fetched 4586 B in 1s (4087 B/s)
                                    Reading package lists... Done
                                    Building dependency tree... Done
                                    All packages are up to date.
                                    Package 'npm' is not installed, so not removed
                                    The following packages were automatically installed and are no longer required:
                                      distro-info-data eslint g++-10 giblib1 gyp handlebars javascript-common libauthen-sasl-perl libcbor0 libclone-perl libdata-dump-perl
                                      libdrm-amdgpu1 libdrm-common libdrm-nouveau2 libdrm-radeon1 libdrm2 libegl-mesa0 libegl1 libencode-locale-perl libevent-2.1-7
                                      libfile-basedir-perl libfile-desktopentry-perl libfile-listing-perl libfile-mimeinfo-perl libfont-afm-perl libgbm1 libgl1
                                      libgl1-mesa-dri libglapi-mesa libgles2 libglvnd0 libglx-mesa0 libglx0 libhtml-form-perl libhtml-format-perl libhtml-parser-perl
                                      libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl libhttp-message-perl
                                      libhttp-negotiate-perl libicu67 libio-html-perl libio-socket-ssl-perl libio-stringy-perl libipc-system-simple-perl libjs-async
                                      libjs-events libjs-inherits libjs-is-typedarray libjs-prettify libjs-regenerate libjs-source-map libjs-sprintf-js
                                      libjs-typedarray-to-buffer libjs-util libjsoncpp24 libldap-2.4-2 libllvm15 liblua5.1-0 liblwp-mediatypes-perl
                                      liblwp-protocol-https-perl libmailtools-perl libmpdec3 libnet-dbus-perl libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl
                                      libnode-dev libnotify-bin libnotify4 libpcre16-3 libpcre2-posix2 libpcre3-dev libpcre32-3 libpcrecpp0v5 libperl5.32
                                      libpython3.9-minimal libpython3.9-stdlib libregexp-ipv6-perl libsensors-config libsensors5 libssl-dev libstdc++-10-dev libtevent0
                                      libtie-ixhash-perl libtiff5 libtimedate-perl libtry-tiny-perl liburi-perl libuv1-dev libwayland-client0 libwayland-server0 libwebp6
                                      libwww-perl libwww-robotrules-perl libx11-protocol-perl libxaw7 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-randr0
                                      libxcb-shape0 libxcb-sync1 libxcb-xfixes0 libxcursor1 libxi6 libxkbfile1 libxml-parser-perl libxml-twig-perl libxml-xpathengine-perl
                                      libxmu6 libxpm4 libxrandr2 libxshmfence1 libxtst6 libxv1 libxxf86dga1 libxxf86vm1 libz3-4 linux-image-5.10.0-21-arm64
                                      linux-image-5.10.0-23-arm64 linux-image-6.1.0-9-arm64 lua-bitop lua-cjson node-abbrev node-agent-base node-ajv node-ajv-keywords
                                      node-ampproject-remapping node-ansi-escapes node-ansi-regex node-ansi-styles node-anymatch node-aproba node-archy
                                      node-are-we-there-yet node-argparse node-arrify node-assert node-async node-async-each node-auto-bind
                                      node-babel-helper-define-polyfill-provider node-babel-plugin-add-module-exports node-babel-plugin-lodash
                                      node-babel-plugin-polyfill-corejs2 node-babel-plugin-polyfill-corejs3 node-babel-plugin-polyfill-regenerator node-babel7
                                      node-babel7-runtime node-balanced-match node-base node-base64-js node-binary-extensions node-brace-expansion node-braces
                                      node-browserslist node-builtins node-cacache node-cache-base node-camelcase node-caniuse-lite node-chalk node-chokidar node-chownr
                                      node-chrome-trace-event node-ci-info node-cli-boxes node-cli-cursor node-cli-table node-cli-truncate node-cliui node-clone
                                      node-clone-deep node-collection-visit node-color-convert node-color-name node-colors node-columnify node-commander node-commondir
                                      node-concat-stream node-console-control-strings node-convert-source-map node-copy-concurrently node-core-js node-core-js-compat
                                      node-core-js-pure node-core-util-is node-coveralls node-css-loader node-css-selector-tokenizer node-data-uri-to-buffer
                                      node-debbundle-es-to-primitive node-debug node-decamelize node-decompress-response node-deep-equal node-deep-is node-defaults
                                      node-define-properties node-define-property node-defined node-del node-delegates node-depd node-diff node-doctrine
                                      node-electron-to-chromium node-encoding node-end-of-stream node-enhanced-resolve node-err-code node-errno node-error-ex
                                      node-es-abstract node-es-module-lexer node-es6-error node-escape-string-regexp node-escodegen node-eslint-scope node-eslint-utils
                                      node-eslint-visitor-keys node-espree node-esprima node-esquery node-esrecurse node-estraverse node-esutils node-events node-fancy-log
                                      node-fast-deep-equal node-fast-levenshtein node-fetch node-file-entry-cache node-fill-range node-find-cache-dir node-find-up
                                      node-flat-cache node-flatted node-for-in node-for-own node-foreground-child node-fs-readdir-recursive node-fs-write-stream-atomic
                                      node-fs.realpath node-function-bind node-functional-red-black-tree node-gauge node-get-caller-file node-get-stream node-get-value
                                      node-glob node-glob-parent node-globals node-globby node-got node-graceful-fs node-growl node-gyp node-has-flag node-has-unicode
                                      node-has-value node-has-values node-hosted-git-info node-https-proxy-agent node-iconv-lite node-icss-utils node-ieee754 node-iferr
                                      node-ignore node-imurmurhash node-indent-string node-inflight node-inherits node-ini node-interpret node-ip node-ip-regex
                                      node-is-arrayish node-is-binary-path node-is-buffer node-is-descriptor node-is-extendable node-is-extglob node-is-glob node-is-number
                                      node-is-path-cwd node-is-path-inside node-is-plain-obj node-is-plain-object node-is-primitive node-is-stream node-is-typedarray
                                      node-is-windows node-isarray node-isexe node-isobject node-istanbul node-jest-debbundle node-jest-worker node-js-tokens node-js-yaml
                                      node-jsesc node-json-buffer node-json-parse-better-errors node-json-schema node-json-schema-traverse node-json-stable-stringify
                                      node-json5 node-jsonify node-jsonparse node-kind-of node-lcov-parse node-levn node-loader-runner node-locate-path node-lodash
                                      node-lodash-packages node-log-driver node-lowercase-keys node-lru-cache node-make-dir node-map-visit node-memfs node-memory-fs
                                      node-merge-stream node-micromatch node-mime node-mime-types node-mimic-response node-minimatch node-minimist node-minipass
                                      node-mixin-deep node-mkdirp node-move-concurrently node-ms node-mute-stream node-n3 node-negotiator node-neo-async node-nopt
                                      node-normalize-package-data node-normalize-path node-npm-bundled node-npm-package-arg node-npm-run-path node-npmlog node-object-assign
                                      node-object-inspect node-object-visit node-once node-opener node-optimist node-optionator node-osenv node-p-cancelable node-p-limit
                                      node-p-locate node-p-map node-parse-json node-pascalcase node-path-dirname node-path-exists node-path-is-absolute node-path-is-inside
                                      node-path-type node-picocolors node-pify node-pkg-dir node-postcss node-postcss-modules-extract-imports node-postcss-modules-values
                                      node-postcss-value-parser node-prelude-ls node-process-nextick-args node-progress node-promise-inflight node-promise-retry
                                      node-promzard node-prr node-pump node-punycode node-quick-lru node-randombytes node-read node-read-package-json node-read-pkg
                                      node-readable-stream node-readdirp node-rechoir node-regenerate node-regenerate-unicode-properties node-regenerator-runtime
                                      node-regenerator-transform node-regexpp node-regexpu-core node-regjsgen node-regjsparser node-repeat-string node-require-directory
                                      node-resolve node-resolve-cwd node-resolve-from node-restore-cursor node-resumer node-retry node-rimraf node-run-queue
                                      node-safe-buffer node-schema-utils node-sellside-emitter node-semver node-serialize-javascript node-set-blocking
                                      node-set-immediate-shim node-set-value node-shebang-command node-shebang-regex node-shell-quote node-signal-exit node-slash
                                      node-slice-ansi node-source-list-map node-source-map node-source-map-support node-spdx-correct node-spdx-exceptions
                                      node-spdx-expression-parse node-spdx-license-ids node-sprintf-js node-ssri node-stack-utils node-string-decoder node-string-width
                                      node-strip-ansi node-strip-bom node-strip-json-comments node-supports-color node-tap node-tap-mocha-reporter node-tap-parser
                                      node-tapable node-tape node-tar node-terser node-text-table node-through node-time-stamp node-to-fast-properties node-to-regex-range
                                      node-tslib node-type-check node-typedarray node-typedarray-to-buffer node-unicode-canonical-property-names-ecmascript
                                      node-unicode-match-property-ecmascript node-unicode-match-property-value-ecmascript node-unicode-property-aliases-ecmascript
                                      node-union-value node-unique-filename node-unset-value node-uri-js node-util node-util-deprecate node-uuid node-v8-compile-cache
                                      node-v8flags node-validate-npm-package-license node-validate-npm-package-name node-watchpack node-wcwidth.js node-webassemblyjs
                                      node-webpack-sources node-which node-wide-align node-widest-line node-wordwrap node-wrap-ansi node-wrappy node-write
                                      node-write-file-atomic node-ws node-y18n node-yallist node-yaml node-yargs node-yargs-parser perl-modules-5.32 perl-openssl-defaults
                                      pigz python3-pkg-resources python3-six python3.9 python3.9-minimal terser webpack x11-utils x11-xserver-utils x11proto-xext-dev
                                      xdg-utils zutty
                                    Use 'sudo apt autoremove' to remove them.
                                    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                    Package nodejs is not available, but is referred to by another package.
                                    This may mean that the package is missing, has been obsoleted, or
                                    is only available from another source
                                    However the following packages replace it:
                                      nodejs-doc
                                      @ravsu
                                      Da fehlt die nodesource.list
                                      iob nodejs-update 18
                                      legt die aber eigentlich an.
                                      Zuvor
                                      sudo apt autoremove
                                      sudo apt remove node-* nodejs-doc
                                      dann
                                      sollte zu einer richtigen Installation führen.
                                        danke für den Hinweis, habe etwas gebraucht um herauszufinden wie die code-tags zu setzen sind 🙂
                                          das und noch viel mehr nützliches steht hier
                                            Vielen, vielen Dank. Jetzt schein alles upgedatet zu sein. 😃
                                            Besseren support kann man nicht haben.
                                            Danke an alle.
                                            1956
