    3. Einsteigerfragen
    4. NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?
      raVsu @Homoran last edited by
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
                Kernel: Linux 6.1.0-18-arm64
          Architecture: arm64
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       13:13:27 up 10:12,  2 users,  load average: 0.93, 0.95, 0.90
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Sun 2024-02-11 13:13:27 CET
                 Universal time: Sun 2024-02-11 12:13:27 UTC
                       RTC time: n/a
                    NTP service: n/a
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi sudo iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.0G        3.0G        437M        704K        676M        924M
      Swap:             0B          0B          0B
      Total:          4.0G        3.0G        437M
               3786 M total memory
               2904 M used memory
                293 M active memory
               2793 M inactive memory
                417 M free memory
                 87 M buffer memory
                557 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FAILED SERVICES ***
        UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
      * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     379M  696K  378M   1% /run
      /dev/sda2      ext4      118G   23G   90G  20% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      /dev/sda1      vfat      396M  306M   90M  78% /boot/firmware
      tmpfs          tmpfs     379M     0  379M   0% /run/user/1000
      [Sun Feb 11 03:01:11 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Feb 11 03:01:14 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET           SOURCE    FSTYPE OPTIONS
      /                /dev/sda2 ext4   rw,relatime
      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
      /var:
      12G     /var/
      9.4G    /var/lib
      9.3G    /var/lib/influxdb/engine/data
      Archived and active journals take up 15.3M in the file system.
      /opt/iobroker/backups:
      282M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      2.2G    /opt/iobroker/iobroker-data/
      1.4G    /opt/iobroker/iobroker-data/history
      653M    /opt/iobroker/iobroker-data/files
      145M    /opt/iobroker/iobroker-data/files/vis-2
      116M    /opt/iobroker/iobroker-data/backup-objects
      42M     /opt/iobroker/iobroker-data/objects.jsonl
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            9.2.0
      /usr/bin/npx            9.2.0
      /home/iobroker/.diag.sh: line 281: corepack: command not found
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 18.19.0+dfsg-6~deb12u1
        Candidate: 18.19.0+dfsg-6~deb12u1
        Version table:
       *** 18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
              100 /var/lib/dpkg/status
           18.13.0+dfsg1-1 500
           14.21.3-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.13.16
      javascript:     7.1.6
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.178.64
      + system.adapter.knx.1                    : knx                   : iobroker                                 -  enabled, bind: 192.168.178.64
        system.adapter.material.0               : material              : iobroker                                 -  enabled
      + system.adapter.matrix-org.0             : matrix-org            : iobroker                                 -  enabled
        system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      + system.adapter.senec.0                  : senec                 : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5678
        system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        system.adapter.text2command.0           : text2command          : iobroker                                 - disabled
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.tradfri.0                : tradfri               : iobroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 192.168.178.64, run as: admin
      + instance is alive
      ioBroker-Repositories
      __            :
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "bring"        : 1.8.4    , installed 1.8.4
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "fakeroku"     : 0.2.2    , installed 0.2.2
      Adapter    "harmony"      : 1.3.0    , installed 1.3.0
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "knx"          : 2.0.24   , installed 2.0.24
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "matrix-org"   : 1.0.0    , installed 1.0.0
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "node-red"     : 5.1.0    , installed 5.1.0
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Objects and States
      Objects:        3554
      States:         2849
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Get:3 https://deb.nodesource.com/node_14.x bullseye InRelease [4586 B]
      Fetched 4586 B in 1s (4359 B/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15724      1/init
      tcp        0      0 127.0.0.1:39611         0.0.0.0:*               LISTEN      998        18660      662/influxd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16987      751/iobroker.js-con
      tcp        0      0 192.168.178.64:8082     0.0.0.0:*               LISTEN      1001       23670      1175/io.web.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       19083      877/node-red
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      108        20986      576/redis-server 12
      tcp6       0      0 :::22                   :::*                    LISTEN      0          20904      1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          14485      1/init
      tcp6       0      0 :::3000                 :::*                    LISTEN      109        18640      659/grafana-server
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       21531      1032/io.harmony.0
      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       19423      1107/io.terminal.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       21588      1088/io.simple-api.
      tcp6       0      0 :::8086                 :::*                    LISTEN      998        21112      662/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18733      771/io.admin.0
      tcp6       0      0 ::1:6379                :::*                    LISTEN      108        20987      576/redis-server 12
      udp        0      0 192.168.178.64:49204    0.0.0.0:*                           1001       302103     1077/io.knx.0
      udp        0      0 192.168.178.64:57399    0.0.0.0:*                           1001       330977     1274/io.knx.1
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19501      488/dhclient
      udp        0      0 192.168.178.64:51293    0.0.0.0:*                           1001       469823     1274/io.knx.1
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          14484      1/init
      udp        0      0 192.168.178.64:123      0.0.0.0:*                           0          19660      657/ntpd
      udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          19658      657/ntpd
      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          19654      657/ntpd
      udp        0      0 192.168.178.64:57504    0.0.0.0:*                           1001       429548     1077/io.knx.0
      udp        0      0 192.168.178.64:49319    0.0.0.0:*                           1001       470534     1077/io.knx.0
      udp        0      0 192.168.178.64:51367    0.0.0.0:*                           1001       420774     1077/io.knx.0
      udp        0      0 192.168.178.64:53529    0.0.0.0:*                           1001       22704      1274/io.knx.1
      udp        0      0 192.168.178.64:45388    0.0.0.0:*                           1001       321213     1274/io.knx.1
      udp        0      0 0.0.0.0:35299           0.0.0.0:*                           1001       19091      877/node-red
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       21532      1032/io.harmony.0
      udp        0      0 192.168.178.64:55965    0.0.0.0:*                           1001       385583     1274/io.knx.1
      udp        0      0 192.168.178.64:49892    0.0.0.0:*                           1001       505627     1274/io.knx.1
      udp        0      0 192.168.178.64:45905    0.0.0.0:*                           1001       253074     1077/io.knx.0
      udp        0      0 192.168.178.64:50041    0.0.0.0:*                           1001       422743     1274/io.knx.1
      udp        0      0 192.168.178.64:48017    0.0.0.0:*                           1001       211583     1274/io.knx.1
      udp        0      0 192.168.178.64:37840    0.0.0.0:*                           1001       418223     1077/io.knx.0
      udp        0      0 192.168.178.64:39931    0.0.0.0:*                           1001       122879     1077/io.knx.0
      udp        0      0 192.168.178.64:54375    0.0.0.0:*                           1001       101212     1274/io.knx.1
      udp        0      0 192.168.178.64:44191    0.0.0.0:*                           1001       293347     1077/io.knx.0
      udp        0      0 192.168.178.64:52430    0.0.0.0:*                           1001       128594     1077/io.knx.0
      udp        0      0 192.168.178.64:5353     0.0.0.0:*                           1001       19984      933/io.tr-064.0
      udp        0      0 192.168.178.64:40188    0.0.0.0:*                           1001       156073     1274/io.knx.1
      udp        0      0 192.168.178.64:44358    0.0.0.0:*                           1001       127381     1077/io.knx.0
      udp        0      0 192.168.178.64:50523    0.0.0.0:*                           1001       77832      1274/io.knx.1
      udp        0      0 192.168.178.64:56678    0.0.0.0:*                           1001       233936     1274/io.knx.1
      udp        0      0 192.168.178.64:38283    0.0.0.0:*                           1001       508554     1274/io.knx.1
      udp        0      0 192.168.178.64:40366    0.0.0.0:*                           1001       312936     1077/io.knx.0
      udp        0      0 192.168.178.64:40379    0.0.0.0:*                           1001       477077     1077/io.knx.0
      udp        0      0 192.168.178.64:46531    0.0.0.0:*                           1001       22542      1077/io.knx.0
      udp        0      0 192.168.178.64:56815    0.0.0.0:*                           1001       161599     1077/io.knx.0
      udp        0      0 192.168.178.64:42485    0.0.0.0:*                           1001       155109     1077/io.knx.0
      udp        0      0 192.168.178.64:40468    0.0.0.0:*                           1001       113953     1077/io.knx.0
      udp        0      0 192.168.178.64:36410    0.0.0.0:*                           1001       459628     1274/io.knx.1
      udp        0      0 192.168.178.64:46655    0.0.0.0:*                           1001       282025     1274/io.knx.1
      udp        0      0 192.168.178.64:58975    0.0.0.0:*                           1001       217741     1274/io.knx.1
      udp        0      0 192.168.178.64:36545    0.0.0.0:*                           1001       196604     1274/io.knx.1
      udp        0      0 192.168.178.64:54978    0.0.0.0:*                           1001       46227      1077/io.knx.0
      udp        0      0 192.168.178.64:49036    0.0.0.0:*                           1001       396197     1274/io.knx.1
      udp        0      0 0.0.0.0:36773           0.0.0.0:*                           1001       22558      1118/io.tradfri.0
      udp        0      0 192.168.178.64:36840    0.0.0.0:*                           1001       501851     1274/io.knx.1
      udp        0      0 192.168.178.64:34820    0.0.0.0:*                           1001       360741     1077/io.knx.0
      udp        0      0 192.168.178.64:38926    0.0.0.0:*                           1001       155789     1274/io.knx.1
      udp6       0      0 :::111                  :::*                                0          15725      1/init
      udp6       0      0 fe80::dea6:32ff:fe3:123 :::*                                0          19666      657/ntpd
      udp6       0      0 2003:c5:171c:2200:d:123 :::*                                0          19664      657/ntpd
      udp6       0      0 ::1:123                 :::*                                0          19662      657/ntpd
      udp6       0      0 :::123                  :::*                                0          19651      657/ntpd
      2024-02-11 13:14:52.815  - info: knx.0 (1077) Change state from STATE_READY(7) to STATE_CONNECTION_STATE_REQUEST(5)
      2024-02-11 13:14:52.817  - info: knx.0 (1077) Received CONNECTIONSTATE_RESPONSE :    06 10 02 08 00 08 c6 00                                                              192.168.178.57:3671 ChID : 198 SeqCntIN : 75 SeqCntOUT : 0  msgCode : [object Object]
      2024-02-11 13:14:52.818  - info: knx.0 (1077) Change state from STATE_CONNECTION_STATE_REQUEST(5) to STATE_CONNECTION_STATE_RESPONSE(6)
      2024-02-11 13:14:52.818  - info: knx.0 (1077) Change state from STATE_CONNECTION_STATE_RESPONSE(6) to STATE_READY(7)
      2024-02-11 13:14:52.857  - info: knx.0 (1077) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 17 04 c6 4c 00 29 00 bc e0 00 07 00 09 03 00 80 14 a6   ChID: 198
      2024-02-11 13:14:52.858  - info: knx.0 (1077) WRITE : mappedName : LichtWert Flur Einganfsbereich    dest : 0/0/9  val: 5286   (DPT7.013) LichtWert_Flur_Einganfsbereich
      2024-02-11 13:14:52.858  - info: knx.0 (1077) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
      2024-02-11 13:14:52.859  - info: knx.0 (1077) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
      2024-02-11 13:14:52.859  - info: knx.0 (1077) =====> STATE_TUNNELING_ACK
      2024-02-11 13:14:52.860  - info: knx.0 (1077) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 c6 4c 00   ChID : 198 SeqCntIN : 76 SeqCntOUT : 0 queue length : 0
      2024-02-11 13:14:52.860  - info: knx.0 (1077) ( 4.b ) return to STATE_READY, processing : false
      2024-02-11 13:14:52.861  - info: knx.0 (1077) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
      2024-02-11 13:14:54.862  - info: knx.0 (1077) Send : UDP Connection State Request :  06 10 02 07 00 10 c6 00 08 01 00 00 00 00 9d bb     sent from Port:  to 192.168.178.57:3671
      2024-02-11 13:14:54.863  - info: knx.0 (1077) Change state from STATE_READY(7) to STATE_CONNECTION_STATE_REQUEST(5)
      2024-02-11 13:14:54.865  - info: knx.0 (1077) Received CONNECTIONSTATE_RESPONSE :    06 10 02 08 00 08 c6 00                                                              192.168.178.57:3671 ChID : 198 SeqCntIN : 76 SeqCntOUT : 0  msgCode : [object Object]
      2024-02-11 13:14:54.866  - info: knx.0 (1077) Change state from STATE_CONNECTION_STATE_REQUEST(5) to STATE_CONNECTION_STATE_RESPONSE(6)
      2024-02-11 13:14:54.867  - info: knx.0 (1077) Change state from STATE_CONNECTION_STATE_RESPONSE(6) to STATE_READY(7)
      2024-02-11 13:14:55.295  - info: knx.0 (1077) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK )         :    06 10 04 20 00 19 04 c6 4d 00 29 00 bc e0 00 01 04 0f 05 00 80 42 1c 00 00   ChID: 198
      2024-02-11 13:14:55.296  - info: knx.0 (1077) WRITE : mappedName : Leistung Gesmt Ptot    dest : 0/4/15  val: 39   (DPT14.056) Leistung_Gesmt_Ptot
      2024-02-11 13:14:55.297  - info: knx.0 (1077) Change state from STATE_READY(7) to STATE_TUNNELLING_REQUEST(13)
      2024-02-11 13:14:55.297  - info: knx.0 (1077) Change state from STATE_TUNNELLING_REQUEST(13) to STATE_TUNNELLING_ACK(14)
      2024-02-11 13:14:55.297  - info: knx.0 (1077) =====> STATE_TUNNELING_ACK
      2024-02-11 13:14:55.299  - info: knx.0 (1077) ( 4 ) Sending Tunnel_Request ACK  : 06 10 04 21 00 0a 04 c6 4d 00   ChID : 198 SeqCntIN : 77 SeqCntOUT : 0 queue length : 0
      2024-02-11 13:14:55.299  - info: knx.0 (1077) ( 4.b ) return to STATE_READY, processing : false
      2024-02-11 13:14:55.299  - info: knx.0 (1077) Change state from STATE_TUNNELLING_ACK(14) to STATE_READY(7)
        Hier nochmal die Zusammenfassung:
                                v.2023-10-10
               Icon name: computer
            Architecture: arm64
        Installation:           native
        Kernel:                 aarch64
        Userland:               arm64
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        X-Server:               false
        Boot Target:            graphical.target
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                /usr/bin/npm            9.2.0
                                /usr/bin/npx            9.2.0
        /home/iobroker/.diag.sh: line 490: corepack: command not found
        Recommended versions are nodejs 18.19.0 and npm 10.2.3
        Wrong installation path detected. This needs to be fixed
        Please check
        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
        for more information on how to fix these errors.
        MEMORY:
        Mem:            4.0G        3.0G        280M        712K        848M        928M
        Swap:             0B          0B          0B
        Total:          4.0G        3.0G        280M
        Active iob-Instances:   26
        ioBroker Core:          js-controller           5.0.17
                                admin                   6.13.16
        Objects type: jsonl
        States  type: redis
        Objects:                3554
        States:                 2849
        Size of iob-Database:
        8.6M    /opt/iobroker/iobroker-data/objects.json.migrated
        8.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        408K    /opt/iobroker/iobroker-data/states.json
        32K     /opt/iobroker/iobroker-data/states.json.bak
        • Glasfaser
          Glasfaser @raVsu last edited by
          @ravsu sagte in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
          Wie kann ich das korrigieren?
          wurde dir schon gesagt :
          @djmarc75 sagte in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
          @ravsu
          https://forum.iobroker.net/topic/71478/plötzliche-probleme-durch-nodejs-dfsg-version-npm-fehlt
            Homoran Global Moderator Administrators @Glasfaser last edited by
            @glasfaser sollte das nicht im nodejs-update mit drin sein?
            @Thomas-Braun oder wo war das mit drin?
            Glasfaser DJMarc75 2 Replies Last reply Reply Quote 0
            • Glasfaser
              Glasfaser @Homoran last edited by Glasfaser
              ich kann hier keine Antwort sehen ... was er schon gemacht hat !
                Homoran Global Moderator Administrators @raVsu last edited by
                @Glasfaser
                Ja, den Befehl habe ich ausgeführt
                aber leider weder die Eingabe noch die Ausgabe gezeigt
                • DJMarc75
                  DJMarc75 @Homoran last edited by
                  @homoran sagte in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
                  bei einer Neuinstallation über den Einzeiler
                    raVsu @Homoran last edited by Homoran
                    pi@iobroker:~$ iob nodejs-update
                    iobroker nodejs-update [<major-version>]
                    Upgrade the Node.JS installation to the current LTS
                    Options:
                      --help  Show help  [boolean]
                    Glasfaser Homoran 2 Replies Last reply Reply Quote 0
                    • Glasfaser
                      Glasfaser @raVsu last edited by Glasfaser
                      @ravsu
                      Danke für die Ausgabe ... dann ist alles klar , warum es nicht geht
                      Aktualisiere erstmal :
                      iob stop
                      iob fix
                      iob start
                      dann
                      iob nodejs-update
                        Options:
                        Das ist ein gutes Beispiel warum immer alles gezeigt werden muss!
                        hier steht das alles drin
                          raVsu @Glasfaser last edited by Homoran
                          @glasfaser
                          iob stop
                          iob fix
                          iob start
                          dann
                          iob nodejs-update
                          durchgeführt
                          ioBroker nodejs updater 2023-10-13
                          Recommended nodejs-version is: 18.19.0
                          Checking your installation now. Please be patient!
                          Your current setup is:
                          /home/iobroker/.nodejs-update.sh: line 130: npm: command not found
                          /home/iobroker/.nodejs-update.sh: line 131: npx: command not found
                          /home/iobroker/.nodejs-update.sh: line 147: npm: command not found
                          /home/iobroker/.nodejs-update.sh: line 148: npx: command not found
                          We found these nodejs versions available for installation:
                          nodejs:
                            Candidate: 14.21.3-deb-1nodesource1
                            Version table:
                               18.13.0+dfsg1-1 500
                               14.21.3-deb-1nodesource1 1001
                          Your nodejs-Installation seems to be faulty. Shall we try to fix it?
                          Press <y> to continue or any other key to quit
                          Fixing your nodejs setup
                          *** Deleting  ***
                          rm: cannot remove '': No such file or directory
                          *** Deleting  ***
                          Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
                          Nothing to do - Your version is the recommended one.
                          You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
                          Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
                          jetzt wird folgendes angezeigt:
                            Thomas Braun Most Active @raVsu last edited by
                            @ravsu
                            https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
                              @ravsu
                              bitte in code-tags setzen!
                              bitte nicht nur selektierte Ausschnitte posten!
                                raVsu @Thomas Braun last edited by
                                Danke für den Link.
                                Bei dem Befehl
                                sudo apt install nodejs=18.19.0-1nodesource1
                                wird am ende eine Fehlermeldung geliefert:
                                E: Version '18.19.0-1nodesource1' for 'nodejs' was not found
                                pi@iobroker:~$ apt policy nodejs
                                nodejs:
                                  Version table:
                                     18.13.0+dfsg1-1 500
                                pi@iobroker:~$ echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
                                sudo apt update
                                iob stop
                                sudo apt remove npm
                                iob restart
                                Package: nodejs
                                Pin-Priority: 1001
                                Fetched 4586 B in 1s (4087 B/s)
                                Reading package lists... Done
                                Building dependency tree... Done
                                All packages are up to date.
                                Package 'npm' is not installed, so not removed
                                The following packages were automatically installed and are no longer required:
                                  distro-info-data eslint g++-10 giblib1 gyp handlebars javascript-common libauthen-sasl-perl libcbor0 libclone-perl libdata-dump-perl
                                  libdrm-amdgpu1 libdrm-common libdrm-nouveau2 libdrm-radeon1 libdrm2 libegl-mesa0 libegl1 libencode-locale-perl libevent-2.1-7
                                  libfile-basedir-perl libfile-desktopentry-perl libfile-listing-perl libfile-mimeinfo-perl libfont-afm-perl libgbm1 libgl1
                                  libgl1-mesa-dri libglapi-mesa libgles2 libglvnd0 libglx-mesa0 libglx0 libhtml-form-perl libhtml-format-perl libhtml-parser-perl
                                  libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl libhttp-message-perl
                                  libhttp-negotiate-perl libicu67 libio-html-perl libio-socket-ssl-perl libio-stringy-perl libipc-system-simple-perl libjs-async
                                  libjs-events libjs-inherits libjs-is-typedarray libjs-prettify libjs-regenerate libjs-source-map libjs-sprintf-js
                                  libjs-typedarray-to-buffer libjs-util libjsoncpp24 libldap-2.4-2 libllvm15 liblua5.1-0 liblwp-mediatypes-perl
                                  liblwp-protocol-https-perl libmailtools-perl libmpdec3 libnet-dbus-perl libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl
                                  libnode-dev libnotify-bin libnotify4 libpcre16-3 libpcre2-posix2 libpcre3-dev libpcre32-3 libpcrecpp0v5 libperl5.32
                                  libpython3.9-minimal libpython3.9-stdlib libregexp-ipv6-perl libsensors-config libsensors5 libssl-dev libstdc++-10-dev libtevent0
                                  libtie-ixhash-perl libtiff5 libtimedate-perl libtry-tiny-perl liburi-perl libuv1-dev libwayland-client0 libwayland-server0 libwebp6
                                  libwww-perl libwww-robotrules-perl libx11-protocol-perl libxaw7 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-randr0
                                  libxcb-shape0 libxcb-sync1 libxcb-xfixes0 libxcursor1 libxi6 libxkbfile1 libxml-parser-perl libxml-twig-perl libxml-xpathengine-perl
                                  libxmu6 libxpm4 libxrandr2 libxshmfence1 libxtst6 libxv1 libxxf86dga1 libxxf86vm1 libz3-4 linux-image-5.10.0-21-arm64
                                  linux-image-5.10.0-23-arm64 linux-image-6.1.0-9-arm64 lua-bitop lua-cjson node-abbrev node-agent-base node-ajv node-ajv-keywords
                                  node-ampproject-remapping node-ansi-escapes node-ansi-regex node-ansi-styles node-anymatch node-aproba node-archy
                                  node-are-we-there-yet node-argparse node-arrify node-assert node-async node-async-each node-auto-bind
                                  node-babel-helper-define-polyfill-provider node-babel-plugin-add-module-exports node-babel-plugin-lodash
                                  node-babel-plugin-polyfill-corejs2 node-babel-plugin-polyfill-corejs3 node-babel-plugin-polyfill-regenerator node-babel7
                                  node-babel7-runtime node-balanced-match node-base node-base64-js node-binary-extensions node-brace-expansion node-braces
                                  node-browserslist node-builtins node-cacache node-cache-base node-camelcase node-caniuse-lite node-chalk node-chokidar node-chownr
                                  node-chrome-trace-event node-ci-info node-cli-boxes node-cli-cursor node-cli-table node-cli-truncate node-cliui node-clone
                                  node-clone-deep node-collection-visit node-color-convert node-color-name node-colors node-columnify node-commander node-commondir
                                  node-concat-stream node-console-control-strings node-convert-source-map node-copy-concurrently node-core-js node-core-js-compat
                                  node-core-js-pure node-core-util-is node-coveralls node-css-loader node-css-selector-tokenizer node-data-uri-to-buffer
                                  node-debbundle-es-to-primitive node-debug node-decamelize node-decompress-response node-deep-equal node-deep-is node-defaults
                                  node-define-properties node-define-property node-defined node-del node-delegates node-depd node-diff node-doctrine
                                  node-electron-to-chromium node-encoding node-end-of-stream node-enhanced-resolve node-err-code node-errno node-error-ex
                                  node-es-abstract node-es-module-lexer node-es6-error node-escape-string-regexp node-escodegen node-eslint-scope node-eslint-utils
                                  node-eslint-visitor-keys node-espree node-esprima node-esquery node-esrecurse node-estraverse node-esutils node-events node-fancy-log
                                  node-fast-deep-equal node-fast-levenshtein node-fetch node-file-entry-cache node-fill-range node-find-cache-dir node-find-up
                                  node-flat-cache node-flatted node-for-in node-for-own node-foreground-child node-fs-readdir-recursive node-fs-write-stream-atomic
                                  node-fs.realpath node-function-bind node-functional-red-black-tree node-gauge node-get-caller-file node-get-stream node-get-value
                                  node-glob node-glob-parent node-globals node-globby node-got node-graceful-fs node-growl node-gyp node-has-flag node-has-unicode
                                  node-has-value node-has-values node-hosted-git-info node-https-proxy-agent node-iconv-lite node-icss-utils node-ieee754 node-iferr
                                  node-ignore node-imurmurhash node-indent-string node-inflight node-inherits node-ini node-interpret node-ip node-ip-regex
                                  node-is-arrayish node-is-binary-path node-is-buffer node-is-descriptor node-is-extendable node-is-extglob node-is-glob node-is-number
                                  node-is-path-cwd node-is-path-inside node-is-plain-obj node-is-plain-object node-is-primitive node-is-stream node-is-typedarray
                                  node-is-windows node-isarray node-isexe node-isobject node-istanbul node-jest-debbundle node-jest-worker node-js-tokens node-js-yaml
                                  node-jsesc node-json-buffer node-json-parse-better-errors node-json-schema node-json-schema-traverse node-json-stable-stringify
                                  node-json5 node-jsonify node-jsonparse node-kind-of node-lcov-parse node-levn node-loader-runner node-locate-path node-lodash
                                  node-lodash-packages node-log-driver node-lowercase-keys node-lru-cache node-make-dir node-map-visit node-memfs node-memory-fs
                                  node-merge-stream node-micromatch node-mime node-mime-types node-mimic-response node-minimatch node-minimist node-minipass
                                  node-mixin-deep node-mkdirp node-move-concurrently node-ms node-mute-stream node-n3 node-negotiator node-neo-async node-nopt
                                  node-normalize-package-data node-normalize-path node-npm-bundled node-npm-package-arg node-npm-run-path node-npmlog node-object-assign
                                  node-object-inspect node-object-visit node-once node-opener node-optimist node-optionator node-osenv node-p-cancelable node-p-limit
                                  node-p-locate node-p-map node-parse-json node-pascalcase node-path-dirname node-path-exists node-path-is-absolute node-path-is-inside
                                  node-path-type node-picocolors node-pify node-pkg-dir node-postcss node-postcss-modules-extract-imports node-postcss-modules-values
                                  node-postcss-value-parser node-prelude-ls node-process-nextick-args node-progress node-promise-inflight node-promise-retry
                                  node-promzard node-prr node-pump node-punycode node-quick-lru node-randombytes node-read node-read-package-json node-read-pkg
                                  node-readable-stream node-readdirp node-rechoir node-regenerate node-regenerate-unicode-properties node-regenerator-runtime
                                  node-regenerator-transform node-regexpp node-regexpu-core node-regjsgen node-regjsparser node-repeat-string node-require-directory
                                  node-resolve node-resolve-cwd node-resolve-from node-restore-cursor node-resumer node-retry node-rimraf node-run-queue
                                  node-safe-buffer node-schema-utils node-sellside-emitter node-semver node-serialize-javascript node-set-blocking
                                  node-set-immediate-shim node-set-value node-shebang-command node-shebang-regex node-shell-quote node-signal-exit node-slash
                                  node-slice-ansi node-source-list-map node-source-map node-source-map-support node-spdx-correct node-spdx-exceptions
                                  node-spdx-expression-parse node-spdx-license-ids node-sprintf-js node-ssri node-stack-utils node-string-decoder node-string-width
                                  node-strip-ansi node-strip-bom node-strip-json-comments node-supports-color node-tap node-tap-mocha-reporter node-tap-parser
                                  node-tapable node-tape node-tar node-terser node-text-table node-through node-time-stamp node-to-fast-properties node-to-regex-range
                                  node-tslib node-type-check node-typedarray node-typedarray-to-buffer node-unicode-canonical-property-names-ecmascript
                                  node-unicode-match-property-ecmascript node-unicode-match-property-value-ecmascript node-unicode-property-aliases-ecmascript
                                  node-union-value node-unique-filename node-unset-value node-uri-js node-util node-util-deprecate node-uuid node-v8-compile-cache
                                  node-v8flags node-validate-npm-package-license node-validate-npm-package-name node-watchpack node-wcwidth.js node-webassemblyjs
                                  node-webpack-sources node-which node-wide-align node-widest-line node-wordwrap node-wrap-ansi node-wrappy node-write
                                  node-write-file-atomic node-ws node-y18n node-yallist node-yaml node-yargs node-yargs-parser perl-modules-5.32 perl-openssl-defaults
                                  pigz python3-pkg-resources python3-six python3.9 python3.9-minimal terser webpack x11-utils x11-xserver-utils x11proto-xext-dev
                                  xdg-utils zutty
                                Use 'sudo apt autoremove' to remove them.
                                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                Package nodejs is not available, but is referred to by another package.
                                This may mean that the package is missing, has been obsoleted, or
                                is only available from another source
                                However the following packages replace it:
                                  nodejs-doc
                                  @ravsu
                                  Da fehlt die nodesource.list
                                  iob nodejs-update 18
                                  legt die aber eigentlich an.
                                  Zuvor
                                  sudo apt autoremove
                                  sudo apt remove node-* nodejs-doc
                                  dann
                                  sollte zu einer richtigen Installation führen.
                                    danke für den Hinweis, habe etwas gebraucht um herauszufinden wie die code-tags zu setzen sind 🙂
                                      das und noch viel mehr nützliches steht hier
                                        Vielen, vielen Dank. Jetzt schein alles upgedatet zu sein. 😃
                                        Besseren support kann man nicht haben.
                                        Danke an alle.
                                          Thomas Braun Most Active @raVsu last edited by Thomas Braun
                                          Und was sagt ein erneutes
                                          iob nodejs-update
                                          Und ein
                                          apt policy nodejs
                                          liefert?
                                            raVsu @Thomas Braun last edited by raVsu
                                            @thomas-braun said in NPM: 9.2.0 (10.2.3) "Einige Update verfügbar" Update?:
                                            iob nodejs-update
                                            Alles bestens 😄
                                            /usr/bin/npm            10.2.3
                                            /usr/bin/npx            10.2.3
                                            /usr/bin/corepack       0.22.0
                                            nodejs:
                                              Installed: 18.19.0-1nodesource1
                                              Candidate: 18.19.0-1nodesource1
                                              Version table:
                                             *** 18.19.0-1nodesource1 1001
                                                 18.18.2-1nodesource1 1001
                                                 18.18.1-1nodesource1 1001
                                                 18.18.0-1nodesource1 1001
                                                 18.17.1-1nodesource1 1001
                                                 18.17.0-1nodesource1 1001
                                                 18.16.1-1nodesource1 1001
                                                 18.16.0-1nodesource1 1001
                                                 18.15.0-1nodesource1 1001
                                                 18.14.2-1nodesource1 1001
                                                 18.14.1-1nodesource1 1001
                                                 18.14.0-1nodesource1 1001
                                                 18.13.0+dfsg1-1 500
                                                 18.13.0-1nodesource1 1001
                                                 18.12.0-1nodesource1 1001
                                                 18.11.0-1nodesource1 1001
                                                 18.10.0-1nodesource1 1001
                                                 18.9.1-1nodesource1 1001
                                                 18.9.0-1nodesource1 1001
                                                 18.8.0-1nodesource1 1001
                                                 18.7.0-1nodesource1 1001
                                                 18.6.0-1nodesource1 1001
                                                 18.5.0-1nodesource1 1001
                                                 18.4.0-1nodesource1 1001
                                                 18.3.0-1nodesource1 1001
                                                 18.2.0-1nodesource1 1001
                                                 18.1.0-1nodesource1 1001
                                                 18.0.0-1nodesource1 1001
                                            Nothing to do - Your installation is using the correct paths.
                                            1956
