    3. Entwicklung
    4. Daten aus Fronius Solarweb auslesen
    • maximal1981
      maximal1981 @Strobelix last edited by
      @strobelix vermute das der Wattpilot die Daten an solarweb schickt, oder eben der diese aus dem Wattpilot abgreift, denn die werden dann im Chart violett angezeigt.
      und im json ist seither auch ein Wattpilot drin
      • Andre Hussel
        Andre Hussel last edited by Andre Hussel
        @mods. gerne löschen
          gto last edited by
          Hallo, habe heute morgen diese Warnmeldung erhalten:
          2024-02-06 00:00:00.046 - warn: javascript.0 (76699) You are assigning a number to the state "0_userdata.0.Solarweb.Previous.01_Day.Vergangene_Tageswerte_abrufen" which expects a boolean. Please fix your code to use a boolean or change the state type to number. This warning might become an error in future versions.
          2024-02-06 00:00:00.079 - warn: javascript.0 (76699) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
          2024-02-06 00:00:00.080 - warn: javascript.0 (76699) at script.js.common.SolarWeb:253:5
          2024-02-06 00:00:00.081 - warn: javascript.0 (76699) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:934:29)
          2024-02-06 00:00:00.081 - warn: javascript.0 (76699) at Tag_reset (script.js.common.SolarWeb:252:9)
          2024-02-06 00:00:00.082 - warn: javascript.0 (76699) at Object. (script.js.common.SolarWeb:1014:11)
          2024-02-06 00:00:00.082 - warn: javascript.0 (76699) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1617:34)
          2024-02-06 00:00:00.083 - warn: javascript.0 (76699) at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          2024-02-06 00:00:00.084 - warn: javascript.0 (76699) at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          2024-02-06 00:00:00.084 - warn: javascript.0 (76699) at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          2024-02-06 00:00:00.084 - warn: javascript.0 (76699) at listOnTimeout (node:internal/timers:569:17)
          2024-02-06 00:00:00.085 - warn: javascript.0 (76699) at processTimers (node:internal/timers:512:7)
          2024-02-06 00:00:00.176 - info: javascript.0 (76699) State value to set for "0_userdata.0.Solarweb.Previous.01_Day.Vergangene_Tageswerte_abrufen" has to be type "boolean" but received type "number"
          Kann ich selbst etwas korrigieren oder muss da Strobelix ran?
          LG Thomas
          • Dr. KOAL
            Dr. KOAL @Strobelix last edited by Dr. KOAL
            @strobelix :
            Hallo, danke für das Script.
            Ich hab das seit heute im Einsatz aber bekomme keine Daten.
            Steht immer "Solarweb Token konnte nicht erstellt werden"
            Ich hab im Passwort viele Sonderzeichen ist das eventuell ein Problem?
            User = meien Mail
            ID: Alles Zeichen nach dem = aus diesem Link: "https://www.solarweb.com/PvSystems/PvSystem?pvSystemId=xxxxxx"
            Hab das Script aus dem POST 1, das ZIP File.
            LG
            KOAL
              c1olli @Dr. KOAL last edited by
              @dr-koal
              Hast Du auch die Solarweb ID eingetragen?
                Snopy_16 @Strobelix last edited by
                @strobelix sagte in Daten aus Fronius Solarweb auslesen:
                März 2022:
                Änderung: Ohne Premium Account erfolgt beim Forecast nur noch eine Loginfo und keine Warnung mehr
                javascript.0
                2024-02-09 17:35:06.155	info	script.js.Mein_Ordner.Fronius0: Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
                javascript.0
                2024-02-09 17:35:02.158	info	script.js.Mein_Ordner.Fronius0: Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
                javascript.0
                2024-02-09 17:32:00.215	info	script.js.Mein_Ordner.Fronius0: Solarweb Token erstellt
                Ich will auch das Loginfo abschalten, es müllt mir das Log zu (jede halbe Stunde die Einträge)
                würde da ein Löschen der Funktion "forecast" im Script abhilfe schaffen?
                Oder gibt es da im Hintergrund Abhängigkeiten, sodass das Script nicht mehr funktioniert ?
                Bin leider nicht so bewandert mit den Programmiersachen.
                • JB_Sullivan
                  JB_Sullivan @Snopy_16 last edited by
                  @snopy_16 Braucht man nicht löschen - einfach den Block auf deaktivieren setzen. Habe ich auch gemacht und es gibt meines Wissens keine weiteren Anhängigkeiten, bzw. wenn keine Daten auf diesem Weg rein kommen, wird auch vom Skript nichts weiter in die Datenpunkte geschrieben.
                    Snopy_16 @JB_Sullivan last edited by
                    @jb_sullivan
                    Super
                    Danke für den Tip👍 😊
                      DonAlfredo70 @Strobelix last edited by
                      @strobelix
                      Hallo Strobelix,
                      ich kann, auch nach langem recherchieren, das Blockly Script (Solarweb abfrage Blockly 17-09-2023.txt) nach dem Import nicht speichern, d.h. nach dem Import werden die Blöcke und Funktionen angezeigt, werden aber beim Speichern gelöscht.
                      IoBroker Admin: v6.13.16
                      Skript Adapter: zuerst 7.1.6 und dann 7.8.0 von npm haben das gleiche Verhalten
                      Node: v18.17.1
                      Sind eventuell etwaige Zusatzpakte einzubinden oder sonstige Parameter zu setzen?
                      Danke & lg
                        TimoWald @DonAlfredo70 last edited by
                        @donalfredo70 Das hatte ich auch mal. Aber nicht nur bei diesem Script. Habe den JS Adapter bzw Iobroker neu gestartet dann ging es.
                          DonAlfredo70 @TimoWald last edited by
                          @TimoWald
                          Danke für den Tip, das Problem hat sich leider damit nicht gelöst. Habe zusätzlich noch alle Pakete, angefangen von proxmox, Containern bis zu den Adaptern aktualisiert und neu gestartet. Interessant ist, das sich andere Blockly Exporte (z.B. https://www.smarthome-tricks.de/download/3378/) importieren und speichern lassen.
                            Snopy_16 @DonAlfredo70 last edited by Snopy_16
                            @Strobelix
                            Ich habe immer Warnmeldungen von javascript.0 im log wenn Tages oder Monatswerte abgerufen werden.
                            Der state type wurde im Script dem Objekt so zugewiesen
                            var https = require("https");
                            var request = require("request");
                            var data = JSON.stringify({userId: Mail, password: Pass});
                             var options = {
                              url: 'https://swqapi.solarweb.com/iam/jwt',
                              headers: {
                              'AccessKeyId':'FKIAFFB3D0986CF24CBDBF580755A9F38769',
                              'AccessKeyValue': 'ab5563fb-ff0a-43d0-a526-c07a4d0b03aa',
                              'Content-Type': 'application/json'
                              body: data,
                            function callback(error, response, body) {
                            var result = JSON.parse(body);
                            if (response.statusCode ==200) {
                            token = result.jwtToken;
                            console.log("Solarweb Token erstellt");
                            createState("0_userdata.0.Solarweb.Current.02_Weekdays.Aktuelle_Wochentagwerte_abrufen", {name: "Aktuelle Wochentagwerte abrufen",  type: 'boolean', role: 'button', read: true, write: true, desc: "Manuell erzeugt",def:false}, function () {})
                            createState("0_userdata.0.Solarweb.Current.05_Annual_Months.Aktuelle_Einzelmonatswerte_abrufen", {name: "Aktuelle Einzelmonatswerte abrufen",  type: 'boolean', role: 'button', read: true, write: true, desc: "Manuell erzeugt",def:false}, function () {})
                            createState("0_userdata.0.Solarweb.Previous.01_Day.Vergangene_Tageswerte_abrufen", {name: "Vergangene Tageswerte abrufen",  type: 'boolean', role: 'button', read: true, write: true, desc: "Manuell erzeugt",def:false}, function () {})
                              "common": {
                                "name": "Vergangene Tageswerte abrufen",
                                "type": "boolean",
                                "role": "button",
                                "read": true,
                                "write": true,
                                "desc": "Manuell erzeugt",
                                "def": false
                              "native": {},
                              "type": "state",
                              "_id": "0_userdata.0.Solarweb.Previous.01_Day.Vergangene_Tageswerte_abrufen",
                              "acl": {
                                "object": 1636,
                                "state": 1636,
                                "owner": "system.user.admin",
                              "user": "system.user.admin",
                              "ts": 1709374264274
                            Leider weiss ich jetzt nicht, wo ich den Hebel ansetzen soll.
                            Von wo aus wird dieser Wert geschrieben?
                            Soll ich im Objekt den type manuell auf number setzen?
                            C S 3 Replies Last reply Reply Quote 0
                              c1olli @Snopy_16 last edited by
                              @snopy_16
                              Den Fehler habe ich auch, und auch keine Ahnung warum.
                                c1olli @c1olli last edited by
                                Kann es sein, dass es einen Unterschied macht ob es Solarweb Premium oder der einfache Zugang ist?
                                  Snopy_16 @c1olli last edited by
                                  @c1olli
                                  Das kann ich nicht beurteilen, hab kein Premium.
                                  Aber wie könnte das der Grund sein?
                                    Strobelix @Snopy_16 last edited by Strobelix
                                    @snopy_16 ich hab mir das gerade angesehen suche den Fehler
                                    Ich habe das gerade auch bei mir im Log entdeckt
                                    So ich habe den Fehler gefunden!
                                    Beim Tages/Montas/Jahrewechsel werden ja die jeweiligen Werte alle auf 0 gesetzt.
                                    Da sich der Datenpunkt "0_userdata.0.Solarweb.Previous.01_Day.Vergangene_Tageswerte_abrufen" auch in dem Ordner befindet, wird dieser auch auf 0 gesetzt.
                                    Ich schau mal wie ich diesen Datenpunkt ausschließen kann.
                                      @snopy_16
                                      Fehler behoben!
                                      Im ersten Beitrag ist ein neues Blockly das auch eine Optimierung der Forcastwerte enthält.
                                      Wer die Änderung manuell machen möchte, muss in allen Funktionen die ein "reset" enthalten folgendes anpassen:
                                      Hier am Beispiel "Tag reset":
                                      Es muss am Ende des Datenpunkts noch ein ".*" hinzugefügt werden, damit nur die Werte in den Ordnern resettet werden
                                      alt:
                                      var ids = $('0_userdata.0.Solarweb.*.01_Day.*');
                                      ids.each (function(id,i){
                                      setState(id, 0, true)
                                      neu:
                                      var ids = $('0_userdata.0.Solarweb.*.01_Day.*.*');
                                      S 1 Reply Last reply Reply Quote 3
                                        @strobelix
                                        Herzlichen Dank - funktioniert 👍 😊
                                        • Domi Th
                                          Domi Th last edited by Homoran
                                          danke für das Skript, nutze es schon sehr lange!
                                          Ich bekomme hin und wieder folgende beiden Fehlermeldungen oft bei mehreren Abfragen hintereinander.
                                          Heute zum Beispiel bei den Abfragen zwischen 13:30 und 15:30.
                                          Request error: Error: getaddrinfo ENOTFOUND swqapi.solarweb.com
                                          Error in request callback: SyntaxError: Unexpected token u in JSON at position 0
                                            Strobelix @Domi Th last edited by
                                            @domi-th said in Daten aus Fronius Solarweb auslesen:
                                            das kommt immer, wenn der Solarwebserver nicht (rechtzeitig) antwortet. Kannst du aber ignorieren
                                            616
                                            140755
