    4. [Neuer Adapter] mediola-gateway
    • Nicoloma
      Nicoloma @oelison last edited by
      @oelison oh, sorry ich habe übersehen da du geantwortet hast. Vielen Dank schon mal
      {"XC_SUC":[{"type":"EVENT","adr":"01","state":"0"},{"type":"EVENT","adr":"05","state":"1"},{"type":"EVENT","adr":"03","state":"1"},{"type":"EVENT","adr":"06","state":"1"},{"type":"EVENT","adr":"04","state":"1"}]}
      oelison 1 Reply Last reply Reply Quote 0
      • oelison
        oelison @Nicoloma last edited by
        @nicoloma Hi. Das sieht schlecht aus. Also bleibt nur der manuelle Weg. Ist in der Readme beschrieben und in meinem Vorherigen Post angedeutet.
        Nicoloma 1 Reply Last reply Reply Quote 0
        • Nicoloma
          @oelison Hmm ich habe aber Codes wie "D70D8CE144" nicht NY....
          GetAll
          {"XC_SUC":[{"sys":"ASTRO","id":"03","days":"1111111","time":"2","dateStart":"2000-00-00","dateEnd":"2099-00-00","delay":"000F","t":"","l":""},{"sys":"ACTION","id":"08","type":"NY","code":"D70D8CE144","rf":"00","ir":"00"},{"sys":"ACTION","id":"09","type":"NY","code":"D70D670144","rf":"00","ir":"00"},{"sys":"ACTION","id":"0A","type":"NY","code":"D60D23C144","rf":"00","ir":"00"},{"sys":"ACTION","id":"0B","type":"NY","code":"D70D37B144","rf":"00","ir":"00"},{"sys":"ACTION","id":"0C","type":"NY","code":"D70D95A144","rf":"00","ir":"00"},
          • oelison
            oelison @Nicoloma last edited by oelison
            @nicoloma Alles klar. Deine Nummern lauten dann NYD70D8CE1, NYD70D6701, NYD60D23C1, NYD70D37B1 und NYD70D95A1. (die 44 weglassen, da das der Status ist und NY ist der Typ). Wenn das die 5 sind die Du hast, kannst Du die jetzt in action eintragen. (expert mode!!!)
            Etwa so:
            Dann sieht das so aus:
            Value dann 1 oder 2 oder 3 reinschreiben (rauf, runter, stop)
            • Nicoloma
              @oelison danke dir du bist der beste. ich probiere es sofort aus.
              • Nicoloma
                Nicoloma @Nicoloma last edited by
                @oelison
                mediola-gateway.0
                2024-01-21 22:16:58.126	debug	state mediola-gateway.0.sysvars.id04 changed: 1 (ack = true)
                mediola-gateway.0
                2024-01-21 22:16:58.126	silly	States user redis pmessage mediola-gateway.0.sysvars.id*/mediola-gateway.0.sysvars.id04:{"val":"1","ack":true,"ts":1705871818125,"q":0,"from":"system.adapter.mediola-gateway.0","user":"system.user.admin","lc":1705615620733}
                mediola-gateway.0
                2024-01-21 22:16:58.042	debug	state mediola-gateway.0.sysvars.id06 changed: 1 (ack = true)
                mediola-gateway.0
                2024-01-21 22:16:58.042	silly	States user redis pmessage mediola-gateway.0.sysvars.id*/mediola-gateway.0.sysvars.id06:{"val":"1","ack":true,"ts":1705871818040,"q":0,"from":"system.adapter.mediola-gateway.0","user":"system.user.admin","lc":1705615620733}
                mediola-gateway.0
                2024-01-21 22:16:58.041	debug	state mediola-gateway.0.sysvars.id03 changed: 1 (ack = true)
                mediola-gateway.0
                2024-01-21 22:16:58.041	silly	States user redis pmessage mediola-gateway.0.sysvars.id*/mediola-gateway.0.sysvars.id03:{"val":"1","ack":true,"ts":1705871818038,"q":0,"from":"system.adapter.mediola-gateway.0","user":"system.user.admin","lc":1705615620733}
                mediola-gateway.0
                2024-01-21 22:16:58.041	debug	state mediola-gateway.0.sysvars.id05 changed: 1 (ack = true)
                mediola-gateway.0
                2024-01-21 22:16:58.040	silly	States user redis pmessage mediola-gateway.0.sysvars.id*/mediola-gateway.0.sysvars.id05:{"val":"1","ack":true,"ts":1705871818038,"q":0,"from":"system.adapter.mediola-gateway.0","user":"system.user.admin","lc":1705615620691}
                mediola-gateway.0
                2024-01-21 22:16:58.040	debug	state mediola-gateway.0.sysvars.id01 changed: 0 (ack = true)
                mediola-gateway.0
                2024-01-21 22:16:58.039	silly	States user redis pmessage mediola-gateway.0.sysvars.id*/mediola-gateway.0.sysvars.id01:{"val":"0","ack":true,"ts":1705871818038,"q":0,"from":"system.adapter.mediola-gateway.0","user":"system.user.admin","lc":1705615620691}
                mediola-gateway.0
                2024-01-21 22:16:58.036	debug	{"type":"EVENT","adr":"04","state":"1"}
                mediola-gateway.0
                2024-01-21 22:16:58.036	debug	{"type":"EVENT","adr":"06","state":"1"}
                mediola-gateway.0
                2024-01-21 22:16:58.036	debug	{"type":"EVENT","adr":"03","state":"1"}
                mediola-gateway.0
                2024-01-21 22:16:58.035	debug	{"type":"EVENT","adr":"05","state":"1"}
                mediola-gateway.0
                2024-01-21 22:16:58.035	debug	{"type":"EVENT","adr":"01","state":"0"}
                mediola-gateway.0
                2024-01-21 22:16:58.034	debug	mediola device found data: [{"type":"EVENT","adr":"01","state":"0"},{"type":"EVENT","adr":"05","state":"1"},{"type":"EVENT","adr":"03","state":"1"},{"type":"EVENT","adr":"06","state":"1"},{"type":"EVENT","adr":"04","state":"1"}]
                mediola-gateway.0
                2024-01-21 22:16:58.034	debug	"{XC_SUC}[{\"type\":\"EVENT\",\"adr\":\"01\",\"state\":\"0\"},{\"type\":\"EVENT\",\"adr\":\"05\",\"state\":\"1\"},{\"type\":\"EVENT\",\"adr\":\"03\",\"state\":\"1\"},{\"type\":\"EVENT\",\"adr\":\"06\",\"state\":\"1\"},{\"type\":\"EVENT\",\"adr\":\"04\",\"state\":\"1\"}]"
                mediola-gateway.0
                2024-01-21 22:16:57.895	debug	Source: onReady
                mediola-gateway.0
                2024-01-21 22:16:57.887	debug	http://192.168.178.144/command?XC_USER=admin&XC_PASS=sagichnicht&XC_FNC=getstates
                mediola-gateway.0
                2024-01-21 22:16:57.887	debug	validMediola: true sysvarInti: false timerRead: false cmd false pull false
                mediola-gateway.0
                2024-01-21 22:16:57.887	info	Mediola connected with ip:192.168.178.144 and mac:40-66-7a-00-6e-3f
                mediola-gateway.0
                2024-01-21 22:16:57.887	debug	code_text
                • Nicoloma
                  @oelison Hallo,
                  also ich weis nicht warum es vor einigen Wochen nicht funktionierte. Aber es funktioniert.
                  Aber er kann nicht stoppen. 1,2 funktioniert aber 3 Stoppen nicht.
                  Woran kann es liegen?
                  • oelison
                    @nicoloma
                    Versuch mal folgenden Befehl. Wobei das xx ausgetauscht werden soll.
                    xx=22 sollte hoch sein
                    xx=44 sollte runter sein
                    xx=00 sollte stop sein (das funktioniert ja bei Dir nicht).
                    Spiel mal mit den Zahlen ein wenig. Vielleicht findest Du die Zahl für stop raus.
                    Vielleicht ein Rollo mal auf der hälfte stoppen (mit der Mediolaoberfläche) und dann nochmal GetAll machen.
                    Bei Dir standen alle Werte auf 44 also geschlossen. Stimmte das?
                    http://192.168.178.144/command?XC_USER=admin&XC_PASS=sagichnicht&XC_FNC=SendSC&type=NY&data=D70D8CE1xx
                    • Nicoloma
                      @oelison
                      also ich habs gefunden... es ist die 55. Aber die 55 funktioniert nicht wenn ich es in die States eingebe.0682926b-ea7d-4eed-b9a2-ebfc74c15619-image.png
                      • oelison
                        @nicoloma Ja, das kann nicht funktionieren. Ich werde die 55 als spezial Stop mit 4 aufnehemen, in der Hoffnung, dass das der letzte undokumentierte Stopbefehl ist.
                        • Nicoloma
                          @oelison Super danke
                          • oelison
                            @nicoloma
                            Hat ein wenig gedauert, aber hier die Testversion.
                            Bitte im Expertenmodus drüber installieren.
                            mediola gateway feature ny_55
                              MiP @oelison last edited by MiP
                              @oelison Hallo,
                              Laut dem Adapter ist für Elero: 1=up, 2=down, 3=stop
                              Ich hab allerdings seit Jahren Elero Raffstores und auch Rollos die ich aktuell noch über http Befehle vom iobroker aus ansteuere (was zwar sehr gut funktioniert, aber bei Änderungen ist natürlich ein Adapter bequemer) und da wären die richtigen Codes
                              Rauf Kurz: 03
                              Runter Kurz: 04
                              Stop: 02
                              Rauf Auto (also langer Tastendruck auf der Fernbedienung womit der Raffstore oder Rollo bis in die Endposition fährt): 08
                              Runter Auto: 09
                              also am Beispiel mit meinem Gerät mit der ID 60 (PASSWORD ist jetzt natürlich nicht mein Passwort 😉 )
                              Rauf Auto: http://xxx.xxx.xxx.xxx/command?XC_USER=user&XC_PASS=PASSWORD&XC_FNC=SendSC&type=ER&data=6008
                              Rauf Step: http://xxx.xxx.xxx.xxx/command?XC_USER=user&XC_PASS=PASSWORD&XC_FNC=SendSC&type=ER&data=6003
                              Runter Auto: http://xxx.xxx.xxx.xxx/command?XC_USER=user&XC_PASS=PASSWORD&XC_FNC=SendSC&type=ER&data=6009
                              Runter Step: http://xxx.xxx.xxx.xxx/command?XC_USER=user&XC_PASS=PASSWORD&XC_FNC=SendSC&type=ER&data=6004
                              Stopp: http://xxx.xxx.xxx.xxx/command?XC_USER=user&XC_PASS=PASSWORD&XC_FNC=SendSC&type=ER&data=6002
                              Hier ist auch eine zwar alte aber leider die neueste vorhandene Doku falls noch nicht bekannt: https://www.mediola.com/support-docs/API_AIO_GATEWAYS-All.pdf
                              Edit: Die Steps (also die Codes 03 und 04) funktionieren nur bei Raffstores und sind dort sehr useful.
                                Bendog @rofo1968 last edited by
                                @rofo1968 Servus, mit welcher card steuerst du die Roto Rollläden? Ich bin nen absoluter newbe. Bekomme es einfach nicht gebacken mit 1=up, 2=down, 3=stop, die Option kann ich nirgends einstellen, immer nur true und false.
                                  JEnsR last edited by
                                  ich habe eine V5+ und möchte diese gerne an den iobroker packen, ich habe soweit alles richitg eingetragen (meine ich) und bekommen folgenden Fehler:
                                  mediola-gateway.0
                                  2024-03-07 15:43:11.160 error unknown name line: NAME:sumse
                                  mediola-gateway.0
                                  2024-03-07 15:43:11.160 error unkown device on this port
                                  sumse ist mein Server auf dem der iobroker läuft, aber ich habe nicht so richitig eine idee was ich da falsch gemacht habe.
                                  Ich freu mich von euch zuhören.
                                  Jens
                                  • oelison
                                    oelison @JEnsR last edited by
                                    Hallo @jensr,
                                    Ich wusste gar nicht, dass der Mediola ein eigener Name gegeben werden kann.
                                    Ich prüfe zur Zeit auf
                                    und
                                    Kannst Du Dein Gerät auf "AIO GW Sumse" ode "AIO GATEWAY Sumse" umbenennen? Dann sollte mein Adapter das Gatway wieder erkennen.
                                    • oelison
                                      oelison @MiP last edited by
                                      Hallo @mip, Ich habe diesen Post irgendwie übersehen. Daher die jetzt etwas späte Antwort.
                                      Die Daten die ich von einem Elero Besitzer bekommen habe war data=xxyy wobei wie bei Dir xx die ID ist und YY die Ansteuerung. Da ich für alle Rollos die gleiche Ansteuerung haben wollte, habe ich 1=Auf, 2=Runter und 3=Stop definiert. Diese Zahlen werden in die YY-Werte übersetzt. Auf=01 (bei Dir 08 oder 03), Runter=00 (bei Dir 09 oder 04) und Stop=02 (bei Dir 02 hurra, hier ist es wenigstens gleich). Wenn andere Zahlen als 1,2 oder 3 eingegeben werden sende ich sicherheitshalber immer ein Stop=02.
                                      Die Doku habe ich schon. Leider steht da nichts über die Commando Codes für die ER (Elero) Geräte drin.
                                      Daher weiß ich nicht, ob die von Dir genannten Codes eine Spezielle Version der Rollomotoren benötigt oder ob das für alle gleich ist. Daher probier doch mal
                                      Rauf: http://xxx.xxx.xxx.xxx/command?XC_USER=user&XC_PASS=PASSWORD&XC_FNC=SendSC&type=ER&data=6001
                                      und
                                      Runter: http://xxx.xxx.xxx.xxx/command?XC_USER=user&XC_PASS=PASSWORD&XC_FNC=SendSC&type=ER&data=6002
                                      aus und berichte.
                                      • oelison
                                        oelison @oelison last edited by
                                        @JEnsR Zusammenfassung des parallelen Posts:
                                        Das Umbennen hat zum Erfolg geführt.
                                        es sind Kaiser Nienhaus Motoren
                                        Debug liefert folgenden Output:
                                        debug: mediola-gateway.0 (1234) {"type":"DY2","sid":"01","adr":"xxxxxxxx","config":"12345678","state":"00000000"}
                                        Steuerung erfolgt bisher mit http:
                                         Web Links machen z.b.: http://192.168.x.y/cmd?XC_FNC=SendSC&type=DY2&data=01xxxxxxxx01
                                          JEnsR @oelison last edited by
                                          @oelison Danke, wie geschrieben suche ich die Befehle zum Fahren nochmal raus.
                                          • oelison
                                            @jensr DY2 probe Adapter
                                            Im Experten-Modus installieren.
                                            133
                                            20109
