    4. [Vorlage] View Visualisierung eMobility VW Connect / Audi
    • Glasfaser
      Glasfaser @djegge last edited by Glasfaser
      @djegge sagte in [Vorlage] View Visualisierung eMobility VW Connect / Audi:
      @glasfaser und wie könnten man es machen das anstatt closed als wert geschlossen ausgegeben wird
      So ... mit einem Binding z.b
      Im VIS1 Runtime nur sichtbar !
      Schiebedach: {v:0_userdata.0.1; v == "closed" ? "geschlossen" : v == "open" ? "offen" :: ""}
      Datenpunkt 0_userdata.0.1 gegen deinen tauschen !
      Widget :
      [{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"html":"Schiebedach: {v:0_userdata.0.1; v == \"closed\" ? \"geschlossen\" : v == \"open\" ? \"offen\" :: \"\"}\n\n","class":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Schiebedach geschlossen","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"13px","top":"370px","color":"white","height":"20px","width":"243px","text-align":"left","line-height":"","z-index":"10","text-shadow":"","font-family":"Jura-Regular","font-style":"normal","font-variant":"normal","font-weight":"normal","font-size":"medium"},"widgetSet":"basic"}]
      D Glasfaser 2 Replies Last reply Reply Quote 0
        djegge @Glasfaser last edited by
        • Glasfaser
          @djegge
          probiere es nochmal , habe das widget neu eingefügt !
            @glasfaser import hat geklappt….
            Was muss ich ersetzen wenn mein DAtenpunkt der Tür vw-connect.0.xy.status.accessStatus.doors03.status ist
            • Glasfaser
              Glasfaser @Glasfaser last edited by Glasfaser
              @djegge
              @glasfaser sagte in [Vorlage] View Visualisierung eMobility VW Connect / Audi:
              also :
              tür: {v:vw-connect.0.xy.status.accessStatus.doors03.status; v == "closed" ? "geschlossen" : v == "open" ? "offen" :: ""}
                @glasfaser Danke
                Eine frage noch wo finde ich die Außentemp
                • Glasfaser
                  @djegge
                  die gab es mal
                  https://forum.iobroker.net/post/815650
                  ist aber jetzt aktuell nicht mehr vorhanden :
                  D W 2 Replies Last reply Reply Quote 0
                    @glasfaser danke und einen schönen Sonntag
                      woupi @Glasfaser last edited by woupi
                      @djegge
                      die gab es mal
                      Die AT steht bei mir hier (Adapter Version 0.5.1):
                      • Glasfaser
                        Glasfaser @woupi last edited by Glasfaser
                        @woupi
                        Die AT steht bei mir hier:
                        Das ist aber Versions abhängig ! ( Prüfe auch, ob der Wert sich darin aktualisiert )
                        Bitte auch die Adapter Version vw-connect angeben die du hast !
                          Ist eingefügt.
                          • Glasfaser
                            @woupi
                            Mein Edit ... hat sich mit deiner Antwort überschnitten !
                              Aktuell passt die überein. Ich werde aber nochmal heute Mittag nachsehen, ob der Wert sich geändert hat und berichten.
                              PS:
                              Sie aktualisiert sich. Achso übrigens, Skoda Citigo, ist eventuell ja auch noch wichtig.
                                Dennis84 last edited by
                                seit kurzem funktioniert mein senden an Telegram nicht mehr.
                                Anscheinend erkennt Javascript das ändern des Wertes nicht.
                                aktuell habe ich es so geändert - ist da etwas falsch?
                                Danke vorab!
                                on({ id: "vw-connect.0.XXX.charging.status.charging.chargingState.content", change: "ne" }, function (obj) {
                                   var status = getState("vw-connect.0.XXX.charging.status.charging.chargingState.content").val;
                                   log("Change in vw-connect.0.XXX.charging.status.charging.chargingState.content detected" + status.val)
                                   if (status == "chargePurposeReachedAndNotConservationCharging") {
                                       log("sendTo Telegram: Complete")
                                       sendTo('telegram.0', { text: "Das Auto ist vollständig geladen.", disable_notification: true});
                                  Homoran Global Moderator Administrators @Dennis84 last edited by
                                  @dennis84 Was hat das mit der Visualisierung zu tun?
                                  gehört das nicht eher in die Kategorie Javascript?
                                    Dennis84 @Homoran last edited by
                                    @homoran Das script ist annährend 1zu1 oben so verlinkt und ich habe es von hier. Deswegen dachte ich, es ist ok es hier zu posten. Kann mich aber auch in die Javascript Sektion wenden - kein Problem 🙂
                                    Homoran Glasfaser 2 Replies Last reply Reply Quote 0
                                      @dennis84 sagte in [Vorlage] View Visualisierung eMobility VW Connect / Audi:
                                      dann lassen wir es jetzt auch hier
                                      Bitte dann noch den Post mit dem Ursprungsscript (oben??) im Beitrag verlinken.
                                      • Glasfaser
                                        Glasfaser @Dennis84 last edited by Glasfaser
                                        das ist Ok so ,
                                        aber meine Vorlage ( Skript ) mit den Datenpunkten von dem Adapter ioBroker.vw-connect basiert von 2021 .
                                        In laufe der Jahre wurden die Datenpunkte vom Adapter geändert / angepasst ,
                                        Beispiel neu :
                                        das von dir würde schonmal nicht passen :
                                        denn charging habe ich schon mal nicht .
                                        daher bitte im zuständigen Adapter Thread reinschauen.
                                        Edit :
                                        wäre dann eigentlich ,
                                        vw-connect.0.xxxxxxx.status.chargingStatus.chargingScenario
                                        aber soll nur als Hilfe sein .
                                          hallo @Glasfaser
                                          danke für deine prompte Antwort.
                                          Leider hat sich auch bei dem Adapter einiges geändert, ich habe aber aus meiner Sicht den richtigen Wert aus meinen Objekten übernommen.
                                          Der alte Adapter geht ja leider nicht mehr, da es da einige Änderungen von VW/Cupra/Skoda usw gab.
                                          Dieser Wert ändert sich aber, aber es wird irgendwie vom Script nicht erkannt.
                                          Deswegen dachte ich, dass es vielleicht durch irgendwelche Updates Änderungen gibt (ausser eben der genannten Objecte, die ich ja bereits angepasst habe).
                                          • Glasfaser
                                            @dennis84
                                            ich möchte diesen Thread nicht für ( Probleme ) mit Datenpunkten usw. schmücken ,
                                            nur mit Aussagen , kann man nicht viel anfangen , es wäre schön wenn du Screenshots wie ich selber gezeigt habe erstellst , dann kann man auch mehr erkennen und schneller zum Ziel kommen .
                                            Also eine Gesamtübersicht wie ich schon zuvor gepostet habe und einmal vom Datenpunkt den du in den Objekten siehst inkl. des Wertes.
                                            1.0k
                                            vis
                                            17
                                            92
                                            22699
