    4. InfluxDB: Error: connect ECONNREFUSED 127.0.0.1:8086
    • Glasfaser
      Glasfaser @obstbauer last edited by
      @obstbauer
      Was sagt :
      sudo apt update
      apt policy influxdb*
      systemctl status influx*
      • O
        obstbauer @Glasfaser last edited by
        @glasfaser
        pi@raspberrypi:~ $ sudo apt update
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:3 http://deb.debian.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 https://apt.grafana.com stable InRelease
        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:7 https://repos.influxdata.com/debian stable InRelease
        Hit:8 https://repos.influxdata.com/debian bullseye InRelease
        Get:9 http://weewx.com/apt/python3 buster InRelease [4,252 B]
        Err:9 http://weewx.com/apt/python3 buster InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY E788768B9CB16E10
        Fetched 4,252 B in 5s (855 B/s)
        Reading package lists... Done
        Building dependency tree... Done
        21 packages can be upgraded. Run 'apt list --upgradable' to see them.
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://weewx.com/apt/python3 buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY E788768B9CB16E10
        W: Failed to fetch http://weewx.com/apt/python3/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY E788768B9CB16E10
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        bei weewx gab es ein Update, da scheine ich noch ein Problem zu haben, hat aber denk eich nichts mit influx zu tun
        pi@raspberrypi:~ $ apt policy influxdb*
        influxdb2-cli:
          Installed: (none)
          Candidate: 2.7.3-1
          Version table:
             2.7.3-1 500
                500 https://repos.influxdata.com/debian stable/main arm64 Packages
                500 https://repos.influxdata.com/debian bullseye/stable arm64 Packages
             2.7.1-2 500
             2.6.1 500
             2.6.0 500
             2.5.0 500
             2.4.0 500
             2.3.0 500
        influxdb-client:
          Installed: (none)
          Candidate: 1.6.7~rc0-1+b5
          Version table:
             1.6.7~rc0-1+b5 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        influxdb-dev:
          Installed: (none)
          Candidate: (none)
          Version table:
        influxdb2-client:
          Installed: (none)
          Candidate: 2.7.1-1
          Version table:
             2.7.1-1 500
        influxdb:
          Installed: 1.8.10-1
          Candidate: 1.8.10-1
          Version table:
         *** 1.8.10-1 500
                100 /var/lib/dpkg/status
             1.6.7~rc0-1+b5 500
        influxdb2:
          Installed: (none)
          Candidate: 2.7.5-1
          Version table:
             2.7.5-1 500
             2.7.4-1 500
             2.7.3-1 500
             2.7.1-1 500
             2.7.0-1 500
             2.6.1-1 500
             2.6.0-1 500
             2.5.1-1 500
             2.4.0-1 500
             2.3.0-1 500
             2.2.0 500
        pi@raspberrypi:~ $ systemctl status influx*
        Unit influxdata-archive_compat.key.service could not be found.
        Unit influxdata-archive_compat.key.1.service could not be found.
        Unit influxdata-archive_compat.key.2.service could not be found.
        irgendwie scheint mein influx nicht mehr da zu sein, warum auch immer......
          Thomas Braun Most Active @obstbauer last edited by
          @obstbauer
          influxdb:
            Installed: 1.8.10-1
          Ist doch da...
            @obstbauer
            Aber die Keys musst du an der Stelle löschen:
            rm influxdata-archive_compat*
            • O
              obstbauer @Thomas Braun last edited by
              @thomas-braun Hallo,sudo apt update macht jetzt keine Probleme mehr
              ich habe rm influxdata-archive_compat* ausgeführt erhalte aber immer noch die selbe Fehlermeldung Error: connect ECONNREFUSED 127.0.0.1:8086
              • O
                obstbauer @obstbauer last edited by
                ● influxdb.service - InfluxDB is an open-source, distributed, time series datab>
                     Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor pres>
                     Active: activating (start) since Mon 2024-02-12 10:59:27 CET; 1min 27s ago
                       Docs: https://docs.influxdata.com/influxdb/
                Cntrl PID: 17670 (influxd-systemd)
                      Tasks: 14 (limit: 3933)
                        CPU: 2min 40.311s
                     CGroup: /system.slice/influxdb.service
                             ├─17670 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-sta>
                             ├─17671 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                             └─18132 sleep 1
                Feb 12 11:00:48 raspberrypi influxd-systemd-start.sh[17670]: InfluxDB API unava>
                Feb 12 11:00:48 raspberrypi influxd-systemd-start.sh[17671]: ts=2024-02-12T10:0>
                Feb 12 11:00:49 raspberrypi influxd-systemd-start.sh[17670]: InfluxDB API unava>
                Feb 12 11:00:50 raspberrypi influxd-systemd-start.sh[17670]: InfluxDB API unava>
                Feb 12 11:00:51 raspberrypi influxd-systemd-start.sh[17670]: InfluxDB API unava>
                Feb 12 11:00:51 raspberrypi influxd-systemd-start.sh[17671]: ts=2024-02-12T10:0>
                Feb 12 11:00:52 raspberrypi influxd-systemd-start.sh[17670]: InfluxDB API unava>
                Feb 12 11:00:53 raspberrypi influxd-systemd-start.sh[17670]: InfluxDB API unava>
                Feb 12 11:00:53 raspberrypi influxd-systemd-start.sh[17671]: ts=2024-02-12T10:0>
                Feb 12 11:00:54 raspberrypi influxd-systemd-start.sh[17670]: InfluxDB API unava>
                Feb 12 11:00:55 raspberrypi influxd-systemd-start.sh[17670]: InfluxDB API unava>
                lines 1-23...skipping...
                beim googlen habe ich jetzt rausgefunden, dass es an der timeout Zeit liegen kann und ich diese anpassen soll, beispielsweise so:
                $ cat /etc/systemd/system/influxdb.service.d/override.conf
                [Service]
                TimeoutStartSec=45m
                würde das Sinn machen?
                • O
                  @obstbauer mit htop sehe ich auch, dass influxdp das System ordentlich auslastet, verstehe ich auch nicht...
                  • Marc Berg
                    Marc Berg Most Active @obstbauer last edited by
                    @obstbauer sagte in InfluxDB: Error: connect ECONNREFUSED 127.0.0.1:8086:
                    Ich vermute, dass deine Datenbank einfach zu groß ist und/oder korrupte Daten vorhanden sind. Was sagt:
                    sudo du -sh /var/lib/influxdb/
                    • O
                      obstbauer @Marc Berg last edited by
                      @marc-berg
                      pi@raspberrypi:~ $ sudo du -sh /var/lib/influxdb/
                      1.1G	/var/lib/influxdb/
                      is jetzt nicht sooo groß oder ?
                      • Marc Berg
                        Nein, das geht. Dann wird wohl was kaputt gegangen sein. Bevor du da lange rumdokterst, würde ich ein Restore machen.
                        • O
                          @marc-berg ok also mein backup wieder reinladen? Das habe ich noch nicht gemacht bisher, werde es aber morgen mal versuchen. Der Kaltstart hat irgendwas zerschossen leider 😕 aber das ist ja bekannt, dass der Pi so etwas nicht mag....
                          Wenn ich mal Zeit habe werde ich alles neu und frisch installieren, dann läuft es auch stabiler....
                          Thomas Braun Marc Berg 2 Replies Last reply Reply Quote 0
                            Der Kaltstart hat irgendwas zerschossen leider aber das ist ja bekannt, dass der Pi so etwas nicht mag....
                            Das mag gar kein EDV-System. Da ist der Pi nicht alleine.
                            • Marc Berg
                              ja, genau.
                              Ohne mit dem erhobenen Zeigefinger wedeln zu wollen: Es ist immer eine gute Idee, das zu üben, wenn man keinen "Druck" hat 🙂
                              • O
                                @marc-berg ja ich hatte eh mal vor die Datenbank auf die Festplatte umzusiedeln damit die SD Karte geschont wird, auch dafür is es jetzt ein guter Zeitpunkt 🙂 es ist halt die mangelnde Zeit....
                                • O
                                  @marc-berg aktuell scheitere ich an dem restore... ich habe die Backup Datei die der iobroker als letztes erstellt hat auf meinen Pi kopiert (das Backup geht auf einen ftp) und es entpackt
                                  Mit diesem Befehl wollte ich es nun wieder herstellen, erhalte aber folgende Meldung mit der ich nichts anfangen kann:
                                  pi@raspberrypi:~ $ influxd restore \ -db iobroker \ -datadir /var/lib/influxdb/data/iobroker \ -metadir /var/lib/influxdb/meta \ /home/pi/influx_backup
                                  restore: backup path should be a valid directory:  -db
                                  ich wollte es mit der offline legacy methode machen nach folgendem Beispiel von der influx Seite
                                  influxd restore \
                                    -db example-db \
                                    -datadir /path/to/data-directory \
                                    -metadir /path/to/meta-directory \
                                    /path/to/backup-directory
                                  O Homoran Marc Berg 3 Replies Last reply Reply Quote 0
                                  • O
                                    das bekomme ich als Fehler, wenn ich das Backup über iobroker laden will:
                                    Started restore ...
                                    [DEBUG] [influxDB] - Created tmp directory
                                    [DEBUG] [influxDB] - Start infuxDB Restore ...
                                    [DEBUG] [influxDB] - influxdb.0 is stopped
                                    [ERROR] [influxDB] - 2024/02/13 18:18:29 error updating meta: updating metadata on influxd service failed: err=read tcp 127.0.0.1:55584->127.0.0.1:8088: read: connection reset by peer, n=0
                                    restore: updating metadata on influxd service failed: err=read tcp 127.0.0.1:55584->127.0.0.1:8088: read: connection reset by peer, n=0
                                    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                                    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                                    [DEBUG] [influxDB] - infuxDB Restore completed successfully
                                    [EXIT] influxDB restore done
                                    [DEBUG] [influxDB] - influxdb.0 started
                                      Homoran Global Moderator Administrators @obstbauer last edited by
                                      und es entpackt
                                      warum?
                                      das macht der restore!
                                      • O
                                        obstbauer @Homoran last edited by
                                        @homoran es ging weder gepackt noch entpackt
                                        Backup von iobroker stellt das Backup ja auch nicht wieder her
                                        • O
                                          ich habe nun auch diese Lösung versucht:
                                          Influx DB abgelehnt aus dem Forum, die sleep zeit von 1 auf 10 und erneutes eingeben des Passwortes, aber auch das will das Problem nicht lösen
                                          langsam weiß ich nicht mehr weiter....
                                          • O
                                            das erhalte ich nun auch:
                                            Unit influx_backup.service could not be found.
                                            3171
