    4. IoB startet nicht mit Fehlermeldung zu JSONL
      final @Homoran last edited by
      achso. Hm, tja, das übersteigt meine Kenntnisse.
      hier mal ein zwischenstand vom iob fix - anscheinend habe ich (auch?) ein Speicherplatzproblem?
      @raspberrypi:~ $ iob fix
      library: loaded
      Library version=2024-01-04
          Welcome to the ioBroker installation fixer!
          Script version: 2024-01-04
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
      Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
      Err:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Error writing to file - write (28: No space left on device) [IP: 2a00:1098:0:80:1000:75:0:3 80]
      Err:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Error writing to file - write (28: No space left on device) [IP: 2a00:1098:80:56::3:1 80]
      Get:3 https://deb.nodesource.com/node_14.x bullseye InRelease [4,586 B]
      Err:3 https://deb.nodesource.com/node_14.x bullseye InRelease
        Error writing to file - write (28: No space left on device) [IP: 2606:4700:10::6816:51a 443]
      Reading package lists... Done
      W: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a00:1098:0:80:1000:75:0:3 80]
      W: Failed to fetch https://deb.nodesource.com/node_14.x/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2606:4700:10::6816:51a 443]
      W: Failed to fetch http://archive.raspberrypi.org/debian/dists/bullseye/InRelease  Error writing to file - write (28: No space left on device) [IP: 2a00:1098:80:56::3:1 80]
      W: Some index files failed to download. They have been ignored, or old ones used instead.
          Checking ioBroker user and directory permissions (2/5)
      main: line 702: echo: write error: No space left on device
      Created /etc/sudoers.d/iobroker
      Fixing directory permissions...
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Error: ENOSPC: no space left on device, mkdir '/home/iobroker/.npm/_npx/16826'
      command not found: jsonltool
          Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
        Thomas Braun Most Active last edited by
        @final sagte in IoB startet nicht mit Fehlermeldung zu JSONL:
        Das Dateisystem ist rappelvoll.
        df -h
          final @Thomas Braun last edited by
          @raspberrypi:~ $ systemctl status iobroker
          ● iobroker.service - ioBroker Server
               Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
               Active: activating (auto-restart) (Result: exit-code) since Tue 2024-02-13 20:17:19 CET; 689ms ago
                 Docs: http://iobroker.net
              Process: 17079 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js (code=exited, status=1/FAILURE)
             Main PID: 17079 (code=exited, status=1/FAILURE)
                  CPU: 4.952s
          Feb 13 20:17:19 raspberrypi systemd[1]: iobroker.service: Consumed 4.952s CPU time.
          Feb 13 20:17:22 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 8.
          Feb 13 20:17:22 raspberrypi systemd[1]: Stopped ioBroker Server.
          Feb 13 20:17:22 raspberrypi systemd[1]: iobroker.service: Consumed 4.952s CPU time.
          Feb 13 20:17:22 raspberrypi systemd[1]: Started ioBroker Server.
          Feb 13 20:17:26 raspberrypi bash[17093]: ENOSPC: no space left on device, write
          Feb 13 20:17:26 raspberrypi bash[17093]: Error: ENOSPC: no space left on device, write
          Feb 13 20:17:31 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
          Feb 13 20:17:31 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
          Feb 13 20:17:31 raspberrypi systemd[1]: iobroker.service: Consumed 4.856s CPU time.
            final @Thomas Braun last edited by final
            @thomas-braun said in IoB startet nicht mit Fehlermeldung zu JSONL:
            df -h
            was macht df -h? EDIT: ok, disk free ... (ich muss die meisten Befehle erstmal googlen...)
            kann die volle SD für den Fehler verantwortlich sein, oder ist das ein 2. Problem?
              Thomas Braun Most Active @final last edited by
              @final
              df zeigt die Belegung der Partitionen an.
              sudo apt clean
              räumt da vielleicht wieder etwas frei.
                @raspberrypi:~ $ df -h
                Filesystem      Size  Used Avail Use% Mounted on
                /dev/root       7.1G  6.8G     0 100% /
                devtmpfs        355M     0  355M   0% /dev
                tmpfs           483M     0  483M   0% /dev/shm
                tmpfs           194M  984K  193M   1% /run
                tmpfs           5.0M  4.0K  5.0M   1% /run/lock
                /dev/mmcblk0p1  253M   51M  202M  20% /boot
                tmpfs            97M   16K   97M   1% /run/user/1000
                  @final
                  Da biste aber sehr knauserig gewesen. 7,1GB ist zu wenig.
                    Homoran Global Moderator Administrators @final last edited by
                    rappelvoll!
                    mit 7GB "Plattenplatz" auszukommen war auch ziemlich optimistisch
                      final @Homoran last edited by final
                      ist ne 8GB SD - hätte nicht gedacht dass das zu wenig ist? Läuft jetzt seit knapp einem Jahr. Und dabei logge ich nur meinen Zählerstand und das BKW...
                      Was ist denn eine gute Größe? Hab noch ne 32GB SD liegen ...
                      Oder ist eine IOB EInstellung nicht gut und er generiert zu viele Daten/Backups/Dateien/was weiß ich?
                      Muß ich nur regelmäßig aufräumen/löschen?
                        Kann natürlich auch sein. Aber hier erstreckt sich mein System mittlerweile auf 16GB:
                        echad@chet:~ $ df -h
                        /dev/root       110G   16G   89G  16% /
                        F Homoran 2 Replies Last reply Reply Quote 0
                          hmm. ok.
                          was mache ich nun am besten? SD upgraden?
                          Kann ich die 8er dann auf die 32er klonen?
                          Oder erstmal versuchen, etwas Speicher frei zu bekommen?
                          Kann ich über SSH Dateien runterladen?
                          Greife gerade von einem Windows Rechner über die Powershell über SSH auf den Raspi zu.
                            @final
                            sudo apt clean
                            sudo apt update
                            sudo apt install ncdu
                            Und dann per
                            sudo ncdu /
                            schauen wo der fette Kram liegt. Ich vermute in /opt/iobroker/iobroker-data
                              Immer diese Clownereien...
                              Ich würde auf der 32er ganz frisch ein aktuelles System installieren, den iobroker drauf und dann dort mein Backup reinziehen.
                                Und dann per
                                sudo ncdu /
                                1,4GB iobroker/iobroker-data
                                1,3GB iobroker/iobroker-data/history
                                0,5 GB iobroker/backups
                                  @thomas-braun sagte in IoB startet nicht mit Fehlermeldung zu JSONL:
                                  und alleine meine History ist >50GB groß 😂
                                    @final
                                    Da macht eigentlich nur der Umzug in ein größeres Haus Sinn.
                                    Und dann dort vielleicht die Menge der historisierten Daten überdenken.
                                      Hm, also ich habe gerade mal geschaut in ncdu:
                                      in /backups
                                      ist komischerweise das letzte Backup der historydb und von iobroker von Ende September - was irgendwie sehr alt ist, und ich weiß gar nicht, warum da nicht automatisch regelmäßig ein backup gemacht wurde danach??
                                      Denn unter iobroker/iobroker-data/backup-objects habe ich dateien vom 03.-05.02.2024??
                                      Verliere ich damit automatisch alles nach Ende September? Oder kann ich auch irgendwie die aktuellen json Daten sichern?
                                      Oder jetzt manuell ein backup machen?
                                        Und dann per
                                        sudo ncdu /
                                        bitte den output zeigen!
                                        das sind gerade mal <3GB
                                        da fehlen die wirklich dicken
                                          in /backups
                                          haben Backups gar nichts zu suchen!
                                          die müssen außerhalb der SD extern vom Raspi gesichert werden.
                                            3.0 GiB [##########] /usr
                                                2.2 GiB [#######   ] /opt        1.0 GiB [###       ] /var
                                              270.1 MiB [          ] /home
                                               50.2 MiB [          ] /boot
                                                5.6 MiB [          ] /etc
                                                1.0 MiB [          ] /run
                                               56.0 KiB [          ] /tmp
                                               52.0 KiB [          ] /root
                                            e  16.0 KiB [          ] /lost+found
                                            e   4.0 KiB [          ] /usb_device
                                            e   4.0 KiB [          ] /srv
                                            e   4.0 KiB [          ] /mnt
                                            e   4.0 KiB [          ] /media
                                                0.0   B [          ] /sys
                                            .   0.0   B [          ] /proc
                                                0.0   B [          ] /dev
                                            @   0.0   B [          ]  sbin
                                            @   0.0   B [          ]  lib
                                            @   0.0   B [          ]  bin
                                            4011
