2024-02-14 10:20:49.815 - info: host.HK01-MA iobroker.js-controller version 5.0.17 js-controller starting
2024-02-14 10:20:49.816 - info: host.HK01-MA Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
2024-02-14 10:20:49.817 - info: host.HK01-MA hostname: HK01-MA, node: v18.19.0
2024-02-14 10:20:49.817 - info: host.HK01-MA ip addresses: fe80::e813:36d1:6136:d1a4 169.254.81.252 fe80::cee8:cf33:5c20:fb92 169.254.19.167 fe80::e556:8e21:6fc1:a33e 169.254.94.115 192.168.2.37 192.168.2.38 192.168.0.80 fe80::3ec8:d5d9:6bcf:acf3 169.254.94.3
2024-02-14 10:20:49.917 - info: host.HK01-MA connected to Objects and States
2024-02-14 10:20:49.924 - info: host.HK01-MA Node.js version has changed from unknown to 18.19.0
2024-02-14 10:20:49.936 - info: host.HK01-MA added notifications configuration of host
2024-02-14 10:20:50.450 - info: host.HK01-MA 3 instances found
2024-02-14 10:20:50.454 - info: host.HK01-MA starting 3 instances
2024-02-14 10:20:50.489 - info: host.HK01-MA instance system.adapter.admin.0 started with pid 2852
2024-02-14 10:20:52.782 - info: admin.0 (2852) starting. Version 6.13.16 in C:/ioBroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:20:52.800 - info: admin.0 (2852) requesting all objects
2024-02-14 10:20:52.857 - info: admin.0 (2852) received all objects
2024-02-14 10:20:52.901 - info: admin.0 (2852) socket.io server listening on port 8081
2024-02-14 10:20:52.903 - info: admin.0 (2852) http server listening on port 8081
2024-02-14 10:20:52.903 - info: admin.0 (2852) Use link "http://127.0.0.1:8081" to configure.
2024-02-14 10:20:52.915 - warn: admin.0 (2852) Repository cannot be read: Active repo - stable
2024-02-14 10:20:52.915 - warn: admin.0 (2852) Active repository "stable" cannot be read
2024-02-14 10:20:54.511 - info: host.HK01-MA instance system.adapter.discovery.0 started with pid 3856
2024-02-14 10:20:54.886 - info: admin.0 (2852) register notification info
2024-02-14 10:20:55.961 - info: discovery.0 (3856) starting. Version 4.2.0 in C:/ioBroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:20:58.484 - info: host.HK01-MA instance system.adapter.backitup.0 started with pid 3244
2024-02-14 10:20:59.693 - info: backitup.0 (3244) starting. Version 2.9.8 in C:/ioBroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:20:59.723 - info: backitup.0 (3244) [iobroker] backup will be activated at 02:48 every 1 day(s)
2024-02-14 10:21:07.156 - info: admin.0 (2852) ==> Connected system.user.admin from ::ffff:127.0.0.1
2024-02-14 10:21:07.199 - info: host.HK01-MA Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
2024-02-14 10:23:00.334 - info: host.HK01-MA iobroker add s7 --host HK01-MA
2024-02-14 10:23:03.145 - info: host.HK01-MA iobroker NPM version: 10.2.3
2024-02-14 10:23:03.147 - info: host.HK01-MA iobroker Installing iobroker.s7@1.4.2... (System call)
2024-02-14 10:23:15.482 - info: host.HK01-MA iobroker
added 23 packages, and audited 597 packages in 11s
2024-02-14 10:23:15.483 - info: host.HK01-MA iobroker
63 packages are looking for funding
run `npm fund` for details
2024-02-14 10:23:15.542 - info: host.HK01-MA iobroker
28 vulnerabilities (1 low, 20 moderate, 7 high)
To address issues that do not require attention, run:
2024-02-14 10:23:15.543 - info: host.HK01-MA iobroker npm audit fix
To address all issues (including breaking changes), run:
npm audit fix --force
Run `npm audit` for details.
2024-02-14 10:23:15.573 - info: host.HK01-MA iobroker host.HK01-MA install adapter s7
2024-02-14 10:23:15.611 - info: host.HK01-MA iobroker upload [129] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/asset-manifest.json asset-manifest.json application/json
2024-02-14 10:23:18.840 - info: host.HK01-MA iobroker upload [100] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Cold Water.937aad5fa21b0c20a856.svg static/media/Cold Water.937aad5fa21b0c20a856.svg image/svg+xml
2024-02-14 10:23:18.886 - info: host.HK01-MA iobroker upload [90] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Doorstep.10630b759b4867a10776.svg static/media/Doorstep.10630b759b4867a10776.svg image/svg+xml
2024-02-14 10:23:18.947 - info: host.HK01-MA iobroker upload [80] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg image/svg+xml
2024-02-14 10:23:18.996 - info: host.HK01-MA iobroker upload [70] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Handle.3de1d1320fc3ce2f9712.svg static/media/Handle.3de1d1320fc3ce2f9712.svg image/svg+xml
2024-02-14 10:23:19.043 - info: host.HK01-MA iobroker upload [60] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Laundry Room.58da550dff0173676e02.svg static/media/Laundry Room.58da550dff0173676e02.svg image/svg+xml
2024-02-14 10:23:19.096 - info: host.HK01-MA iobroker upload [50] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Music.67bc6063cb601642fd74.svg static/media/Music.67bc6063cb601642fd74.svg image/svg+xml
2024-02-14 10:23:19.147 - info: host.HK01-MA iobroker upload [40] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Power Consumption.4faab614c3c788f2d338.svg static/media/Power Consumption.4faab614c3c788f2d338.svg image/svg+xml
2024-02-14 10:23:19.184 - info: host.HK01-MA iobroker upload [30] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Shutters.db7d7b0d498f40779210.svg static/media/Shutters.db7d7b0d498f40779210.svg image/svg+xml
2024-02-14 10:23:19.231 - info: host.HK01-MA iobroker upload [20] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Swimming Pool.190b378cb0707edb9461.svg static/media/Swimming Pool.190b378cb0707edb9461.svg image/svg+xml
2024-02-14 10:23:19.235 - info: host.HK01-MA iobroker upload [19] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Table Lamps.bd92de33bf86b6cbaec9.svg static/media/Table Lamps.bd92de33bf86b6cbaec9.svg image/svg+xml
2024-02-14 10:23:19.242 - info: host.HK01-MA iobroker upload [18] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Temperature Sensors.75d805988a6b77b231d8.svg static/media/Temperature Sensors.75d805988a6b77b231d8.svg image/svg+xml
2024-02-14 10:23:19.249 - info: host.HK01-MA iobroker upload [17] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
2024-02-14 10:23:19.255 - info: host.HK01-MA iobroker upload [16] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
2024-02-14 10:23:19.260 - info: host.HK01-MA iobroker upload [15] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
2024-02-14 10:23:19.265 - info: host.HK01-MA iobroker upload [14] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
2024-02-14 10:23:19.270 - info: host.HK01-MA iobroker upload [13] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
2024-02-14 10:23:19.278 - info: host.HK01-MA iobroker upload [12] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
2024-02-14 10:23:19.284 - info: host.HK01-MA iobroker upload [11] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
2024-02-14 10:23:19.289 - info: host.HK01-MA iobroker upload [10] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
2024-02-14 10:23:19.293 - info: host.HK01-MA iobroker upload [9] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
2024-02-14 10:23:19.297 - info: host.HK01-MA iobroker upload [8] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
2024-02-14 10:23:19.303 - info: host.HK01-MA iobroker upload [7] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
2024-02-14 10:23:19.311 - info: host.HK01-MA iobroker upload [6] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
2024-02-14 10:23:19.317 - info: host.HK01-MA iobroker upload [5] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
2024-02-14 10:23:19.322 - info: host.HK01-MA iobroker upload [4] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
2024-02-14 10:23:19.327 - info: host.HK01-MA iobroker upload [3] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
2024-02-14 10:23:19.331 - info: host.HK01-MA iobroker upload [2] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
2024-02-14 10:23:19.340 - info: host.HK01-MA iobroker upload [1] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
2024-02-14 10:23:19.346 - info: host.HK01-MA iobroker upload [0] s7.admin C:/ioBroker/node_modules/iobroker.s7/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
2024-02-14 10:23:19.370 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7 created/updated
2024-02-14 10:23:19.405 - info: host.HK01-MA iobroker host.HK01-MA create instance s7
2024-02-14 10:23:19.410 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.0.alive created
2024-02-14 10:23:19.413 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.0.connected created
2024-02-14 10:23:19.415 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.0.compactMode created
2024-02-14 10:23:19.418 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.0.cpu created
2024-02-14 10:23:19.421 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.0.cputime created
2024-02-14 10:23:19.424 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.0.memHeapUsed created
2024-02-14 10:23:19.428 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.0.memHeapTotal created
2024-02-14 10:23:19.432 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.0.memRss created
2024-02-14 10:23:19.436 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.0.uptime created
2024-02-14 10:23:19.440 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.0.inputCount created
2024-02-14 10:23:19.443 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.0.outputCount created
2024-02-14 10:23:19.445 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.0.eventLoopLag created
2024-02-14 10:23:19.447 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.0.sigKill created
2024-02-14 10:23:19.449 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.0.logLevel created
2024-02-14 10:23:19.459 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.0 created
2024-02-14 10:23:20.498 - info: host.HK01-MA iobroker exit 0
2024-02-14 10:23:22.289 - info: admin.0 (2852) ==> Connected system.user.admin from ::ffff:127.0.0.1
2024-02-14 10:25:04.055 - info: admin.0 (2852) <== Disconnect system.user.admin from ::ffff:127.0.0.1 s7
2024-02-14 10:25:06.591 - info: host.HK01-MA "system.adapter.s7.0" enabled
2024-02-14 10:25:06.611 - info: host.HK01-MA instance system.adapter.s7.0 started with pid 7592
2024-02-14 10:25:07.819 - info: s7.0 (7592) starting. Version 1.4.2 in C:/ioBroker/node_modules/iobroker.s7, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:25:07.848 - info: s7.0 (7592) Connect in S7 mode to 0 / 2
2024-02-14 10:25:07.858 - info: s7.0 (7592) Successfully connected in S7 mode
2024-02-14 10:29:27.439 - info: admin.0 (2852) <== Disconnect system.user.admin from ::ffff:127.0.0.1 admin
2024-02-14 10:29:41.317 - error: discovery.0 (3856) uncaught exception: spawn EROFS
2024-02-14 10:29:41.317 - error: discovery.0 (3856) Error: spawn EROFS
at ChildProcess.spawn (node:internal/child_process:414:11)
at spawn (node:child_process:761:9)
at run (C:\ioBroker\node_modules\pidusage\lib\bin.js:18:14)
at wmic (C:\ioBroker\node_modules\pidusage\lib\wmic.js:48:3)
at get (C:\ioBroker\node_modules\pidusage\lib\stats.js:82:3)
at pidusage (C:\ioBroker\node_modules\pidusage\index.js:30:5)
at AdapterClass._reportStatus (C:\ioBroker\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.ts:10587:21)
at Timeout._onTimeout (C:\ioBroker\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.ts:11834:40)
at listOnTimeout (node:internal/timers:569:17)
at processTimers (node:internal/timers:512:7)
2024-02-14 10:29:41.318 - error: discovery.0 (3856) Exception-Code: EROFS: spawn EROFS
2024-02-14 10:29:41.327 - info: discovery.0 (3856) terminating
2024-02-14 10:29:41.327 - warn: discovery.0 (3856) Terminated (UNCAUGHT_EXCEPTION): Without reason
2024-02-14 10:29:41.397 - error: host.HK01-MA Caught by controller[0]: Error: spawn EROFS
2024-02-14 10:29:41.397 - error: host.HK01-MA Caught by controller[0]: at ChildProcess.spawn (node:internal/child_process:414:11)
2024-02-14 10:29:41.397 - error: host.HK01-MA Caught by controller[0]: at spawn (node:child_process:761:9)
2024-02-14 10:29:41.397 - error: host.HK01-MA Caught by controller[0]: at run (C:\ioBroker\node_modules\pidusage\lib\bin.js:18:14)
2024-02-14 10:29:41.398 - error: host.HK01-MA Caught by controller[0]: at wmic (C:\ioBroker\node_modules\pidusage\lib\wmic.js:48:3)
2024-02-14 10:29:41.398 - error: host.HK01-MA Caught by controller[0]: at get (C:\ioBroker\node_modules\pidusage\lib\stats.js:82:3)
2024-02-14 10:29:41.398 - error: host.HK01-MA Caught by controller[0]: at pidusage (C:\ioBroker\node_modules\pidusage\index.js:30:5)
2024-02-14 10:29:41.398 - error: host.HK01-MA Caught by controller[0]: at AdapterClass._reportStatus (C:\ioBroker\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.ts:10587:21)
2024-02-14 10:29:41.398 - error: host.HK01-MA Caught by controller[0]: at Timeout._onTimeout (C:\ioBroker\node_modules\@iobroker\js-controller-adapter\src\lib\adapter\adapter.ts:11834:40)
2024-02-14 10:29:41.398 - error: host.HK01-MA Caught by controller[0]: at listOnTimeout (node:internal/timers:569:17)
2024-02-14 10:29:41.398 - error: host.HK01-MA Caught by controller[0]: at processTimers (node:internal/timers:512:7) {
2024-02-14 10:29:41.398 - error: host.HK01-MA Caught by controller[0]: errno: -4043,
2024-02-14 10:29:41.398 - error: host.HK01-MA Caught by controller[0]: code: 'EROFS',
2024-02-14 10:29:41.398 - error: host.HK01-MA Caught by controller[0]: syscall: 'spawn'
2024-02-14 10:29:41.398 - error: host.HK01-MA Caught by controller[0]: }
2024-02-14 10:29:41.398 - error: host.HK01-MA instance system.adapter.discovery.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
2024-02-14 10:29:41.398 - info: host.HK01-MA Restart adapter system.adapter.discovery.0 because enabled
2024-02-14 10:30:12.886 - info: host.HK01-MA iobroker.js-controller version 5.0.17 js-controller starting
2024-02-14 10:30:12.888 - info: host.HK01-MA Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
2024-02-14 10:30:12.889 - info: host.HK01-MA hostname: HK01-MA, node: v18.19.0
2024-02-14 10:30:12.889 - info: host.HK01-MA ip addresses: fe80::e813:36d1:6136:d1a4 169.254.81.252 fe80::cee8:cf33:5c20:fb92 169.254.19.167 fe80::e556:8e21:6fc1:a33e 169.254.94.115 192.168.2.37 169.254.245.206 192.168.2.38 169.254.60.37 169.254.78.228 fe80::3ec8:d5d9:6bcf:acf3 169.254.94.3
2024-02-14 10:30:13.083 - info: host.HK01-MA connected to Objects and States
2024-02-14 10:30:13.093 - info: host.HK01-MA added notifications configuration of host
2024-02-14 10:30:13.420 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.nodeCurrent"
2024-02-14 10:30:13.421 - info: host.HK01-MA 4 instances found
2024-02-14 10:30:13.424 - info: host.HK01-MA starting 4 instances
2024-02-14 10:30:13.443 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.nodeNewest"
2024-02-14 10:30:13.447 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.nodeNewestNext"
2024-02-14 10:30:13.452 - info: host.HK01-MA instance system.adapter.admin.0 started with pid 3652
2024-02-14 10:30:13.454 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.npmCurrent"
2024-02-14 10:30:13.456 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.npmNewest"
2024-02-14 10:30:13.458 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.npmNewestNext"
2024-02-14 10:30:13.460 - info: host.HK01-MA Some obsolete host states deleted.
2024-02-14 10:30:15.640 - error: admin.0 (3652) admin.0 already running
2024-02-14 10:30:15.641 - warn: admin.0 (3652) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2024-02-14 10:30:17.849 - info: host.HK01-MA instance system.adapter.s7.0 started with pid 7284
2024-02-14 10:30:17.861 - error: host.HK01-MA instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2024-02-14 10:30:17.862 - info: host.HK01-MA Restart adapter system.adapter.admin.0 because enabled
2024-02-14 10:30:19.065 - error: s7.0 (7284) s7.0 already running
2024-02-14 10:30:19.067 - warn: s7.0 (7284) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2024-02-14 10:30:19.582 - error: host.HK01-MA instance system.adapter.s7.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2024-02-14 10:30:19.582 - info: host.HK01-MA Restart adapter system.adapter.s7.0 because enabled
2024-02-14 10:30:21.444 - info: host.HK01-MA instance system.adapter.discovery.0 started with pid 7972
2024-02-14 10:30:22.054 - error: discovery.0 (7972) discovery.0 already running
2024-02-14 10:30:22.055 - warn: discovery.0 (7972) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2024-02-14 10:30:22.578 - error: host.HK01-MA instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2024-02-14 10:30:22.578 - info: host.HK01-MA Restart adapter system.adapter.discovery.0 because enabled
2024-02-14 10:30:25.457 - info: host.HK01-MA instance system.adapter.backitup.0 started with pid 8280
2024-02-14 10:30:26.224 - error: backitup.0 (8280) backitup.0 already running
2024-02-14 10:30:26.225 - warn: backitup.0 (8280) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2024-02-14 10:30:26.749 - error: host.HK01-MA instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2024-02-14 10:30:26.749 - info: host.HK01-MA Restart adapter system.adapter.backitup.0 because enabled
2024-02-14 10:30:47.884 - info: host.HK01-MA instance system.adapter.admin.0 started with pid 8196
2024-02-14 10:30:49.250 - info: admin.0 (8196) starting. Version 6.13.16 in C:/ioBroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:30:49.274 - info: admin.0 (8196) requesting all objects
2024-02-14 10:30:49.519 - info: admin.0 (8196) received all objects
2024-02-14 10:30:49.580 - info: admin.0 (8196) socket.io server listening on port 8081
2024-02-14 10:30:49.582 - info: admin.0 (8196) http server listening on port 8081
2024-02-14 10:30:49.582 - info: admin.0 (8196) Use link "http://127.0.0.1:8081" to configure.
2024-02-14 10:30:49.604 - info: host.HK01-MA instance system.adapter.s7.0 started with pid 8684
2024-02-14 10:30:50.709 - info: s7.0 (8684) starting. Version 1.4.2 in C:/ioBroker/node_modules/iobroker.s7, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:30:50.749 - info: s7.0 (8684) Connect in S7 mode to 0 / 2
2024-02-14 10:30:50.763 - info: s7.0 (8684) Successfully connected in S7 mode
2024-02-14 10:30:52.602 - info: host.HK01-MA instance system.adapter.discovery.0 started with pid 4596
2024-02-14 10:30:53.531 - info: discovery.0 (4596) starting. Version 4.2.0 in C:/ioBroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:30:56.771 - info: host.HK01-MA instance system.adapter.backitup.0 started with pid 8324
2024-02-14 10:30:57.610 - info: backitup.0 (8324) starting. Version 2.9.8 in C:/ioBroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:30:57.639 - info: backitup.0 (8324) [iobroker] backup will be activated at 02:48 every 1 day(s)
2024-02-14 10:40:42.868 - info: admin.0 (8196) ==> Connected system.user.admin from ::ffff:127.0.0.1
2024-02-14 10:43:01.308 - info: host.HK01-MA iobroker add yahka --host HK01-MA
2024-02-14 10:43:03.626 - info: host.HK01-MA iobroker NPM version: 10.2.3
2024-02-14 10:43:03.626 - info: host.HK01-MA iobroker Installing iobroker.yahka@1.0.3... (System call)
2024-02-14 10:43:21.919 - info: host.HK01-MA iobroker
2024-02-14 10:43:21.920 - info: host.HK01-MA iobroker added 74 packages, and audited 671 packages in 17s
94 packages are looking for funding
2024-02-14 10:43:21.975 - info: host.HK01-MA iobroker
31 vulnerabilities (1 low, 20 moderate, 10 high)
2024-02-14 10:43:21.976 - info: host.HK01-MA iobroker npm audit fix
2024-02-14 10:43:22.004 - info: host.HK01-MA iobroker host.HK01-MA install adapter yahka
2024-02-14 10:43:22.030 - info: host.HK01-MA iobroker upload [19] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/css/yahka.admin.css css/yahka.admin.css text/css
2024-02-14 10:43:22.040 - info: host.HK01-MA iobroker upload [18] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-colors.min.css ext/metroui/css/metro-colors.min.css text/css
2024-02-14 10:43:22.048 - info: host.HK01-MA iobroker upload [17] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-icons.min.css ext/metroui/css/metro-icons.min.css text/css
2024-02-14 10:43:22.056 - info: host.HK01-MA iobroker upload [16] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-responsive.min.css ext/metroui/css/metro-responsive.min.css text/css
2024-02-14 10:43:22.067 - info: host.HK01-MA iobroker upload [15] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-rtl.min.css ext/metroui/css/metro-rtl.min.css text/css
2024-02-14 10:43:22.074 - info: host.HK01-MA iobroker upload [14] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-schemes.min.css ext/metroui/css/metro-schemes.min.css text/css
2024-02-14 10:43:22.082 - info: host.HK01-MA iobroker upload [13] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro.min.css ext/metroui/css/metro.min.css text/css
2024-02-14 10:43:22.092 - info: host.HK01-MA iobroker upload [12] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.eot ext/metroui/fonts/metro.eot application/vnd.ms-fontobject
2024-02-14 10:43:22.097 - info: host.HK01-MA iobroker upload [11] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.svg ext/metroui/fonts/metro.svg image/svg+xml
2024-02-14 10:43:22.104 - info: host.HK01-MA iobroker upload [10] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf font/ttf
2024-02-14 10:43:22.110 - info: host.HK01-MA iobroker upload [9] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff font/woff
2024-02-14 10:43:22.116 - info: host.HK01-MA iobroker upload [8] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/selection.json ext/metroui/fonts/selection.json application/json
2024-02-14 10:43:22.129 - info: host.HK01-MA iobroker upload [7] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/ext/metroui/js/metro.min.js ext/metroui/js/metro.min.js application/javascript
2024-02-14 10:43:22.148 - info: host.HK01-MA iobroker upload [6] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/home_icon_large.png home_icon_large.png image/png
2024-02-14 10:43:22.155 - info: host.HK01-MA iobroker upload [5] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/index.html index.html text/html
2024-02-14 10:43:22.173 - info: host.HK01-MA iobroker upload [4] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/index_m.html index_m.html text/html
2024-02-14 10:43:22.184 - info: host.HK01-MA iobroker upload [3] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/words.js words.js application/javascript
2024-02-14 10:43:22.191 - info: host.HK01-MA iobroker upload [2] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/yahka.admin.js yahka.admin.js application/javascript
2024-02-14 10:43:22.472 - info: host.HK01-MA iobroker upload [1] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/yahka.admin.js.map yahka.admin.js.map application/json
2024-02-14 10:43:22.612 - info: host.HK01-MA iobroker upload [0] yahka.admin C:/ioBroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png
2024-02-14 10:43:22.626 - info: host.HK01-MA iobroker host.HK01-MA object yahka.meta._accessoryCategories created/updated
2024-02-14 10:43:22.629 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.yahka created/updated
2024-02-14 10:43:22.645 - info: host.HK01-MA iobroker host.HK01-MA create instance yahka
2024-02-14 10:43:22.650 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.yahka.0.alive created
2024-02-14 10:43:22.653 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.yahka.0.connected created
2024-02-14 10:43:22.655 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.yahka.0.compactMode created
2024-02-14 10:43:22.658 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.yahka.0.cpu created
2024-02-14 10:43:22.662 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.yahka.0.cputime created
2024-02-14 10:43:22.664 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.yahka.0.memHeapUsed created
2024-02-14 10:43:22.667 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.yahka.0.memHeapTotal created
2024-02-14 10:43:22.669 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.yahka.0.memRss created
2024-02-14 10:43:22.672 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.yahka.0.uptime created
2024-02-14 10:43:22.675 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.yahka.0.inputCount created
2024-02-14 10:43:22.678 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.yahka.0.outputCount created
2024-02-14 10:43:22.681 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.yahka.0.eventLoopLag created
2024-02-14 10:43:22.683 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.yahka.0.sigKill created
2024-02-14 10:43:22.686 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.yahka.0.logLevel created
2024-02-14 10:43:22.699 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.yahka.0 created
2024-02-14 10:43:23.726 - info: host.HK01-MA iobroker exit 0
2024-02-14 10:43:25.046 - info: admin.0 (8196) ==> Connected system.user.admin from ::ffff:127.0.0.1
2024-02-14 10:43:25.714 - info: host.HK01-MA instance system.adapter.yahka.0 started with pid 15256
2024-02-14 10:43:27.364 - info: yahka.0 (15256) starting. Version 1.0.3 in C:/ioBroker/node_modules/iobroker.yahka, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:43:27.378 - info: yahka.0 (15256) adapter ready, checking config
2024-02-14 10:43:27.378 - info: yahka.0 (15256) first time initialization
2024-02-14 10:43:27.383 - info: yahka.0 (15256) publishing bridge Yahka-0 on 0.0.0.0 using avahi
2024-02-14 10:43:27.442 - info: host.HK01-MA stopInstance system.adapter.yahka.0 (force=false, process=true)
2024-02-14 10:43:27.444 - info: yahka.0 (15256) Got terminate signal TERMINATE_YOURSELF
2024-02-14 10:43:27.444 - info: host.HK01-MA stopInstance system.adapter.yahka.0 send kill signal
2024-02-14 10:43:27.444 - info: yahka.0 (15256) cleaning up ...
2024-02-14 10:43:27.444 - info: yahka.0 (15256) cleaned up ...
2024-02-14 10:43:27.444 - info: yahka.0 (15256) terminating
2024-02-14 10:43:27.445 - info: yahka.0 (15256) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2024-02-14 10:43:27.951 - info: yahka.0 (15256) terminating
2024-02-14 10:43:27.971 - info: host.HK01-MA instance system.adapter.yahka.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2024-02-14 10:43:30.467 - info: host.HK01-MA instance system.adapter.yahka.0 started with pid 3968
2024-02-14 10:43:31.517 - info: yahka.0 (3968) starting. Version 1.0.3 in C:/ioBroker/node_modules/iobroker.yahka, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:43:31.531 - info: yahka.0 (3968) adapter ready, checking config
2024-02-14 10:43:31.535 - info: yahka.0 (3968) publishing bridge Yahka-0 on 0.0.0.0 using avahi
2024-02-14 10:47:24.896 - info: admin.0 (8196) <== Disconnect system.user.admin from ::ffff:127.0.0.1
2024-02-14 10:47:42.057 - info: host.HK01-MA iobroker add s7 --host HK01-MA
2024-02-14 10:47:43.213 - info: host.HK01-MA iobroker host.HK01-MA create instance s7
2024-02-14 10:47:43.223 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.1.alive created
2024-02-14 10:47:43.225 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.1.connected created
2024-02-14 10:47:43.229 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.1.compactMode created
2024-02-14 10:47:43.232 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.1.cpu created
2024-02-14 10:47:43.235 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.1.cputime created
2024-02-14 10:47:43.238 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.1.memHeapUsed created
2024-02-14 10:47:43.241 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.1.memHeapTotal created
2024-02-14 10:47:43.244 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.1.memRss created
2024-02-14 10:47:43.247 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.1.uptime created
2024-02-14 10:47:43.251 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.1.inputCount created
2024-02-14 10:47:43.254 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.1.outputCount created
2024-02-14 10:47:43.257 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.1.eventLoopLag created
2024-02-14 10:47:43.259 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.1.sigKill created
2024-02-14 10:47:43.263 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.1.logLevel created
2024-02-14 10:47:43.273 - info: host.HK01-MA iobroker host.HK01-MA object system.adapter.s7.1 created
2024-02-14 10:47:44.292 - info: host.HK01-MA iobroker exit 0
2024-02-14 10:47:46.629 - info: admin.0 (8196) ==> Connected system.user.admin from ::ffff:127.0.0.1
2024-02-14 10:48:11.569 - info: admin.0 (8196) <== Disconnect system.user.admin from ::ffff:127.0.0.1 s7
2024-02-14 10:48:13.821 - info: host.HK01-MA "system.adapter.s7.1" enabled
2024-02-14 10:48:13.842 - info: host.HK01-MA instance system.adapter.s7.1 started with pid 16204
2024-02-14 10:48:14.803 - info: s7.1 (16204) starting. Version 1.4.2 in C:/ioBroker/node_modules/iobroker.s7, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:48:14.834 - info: s7.1 (16204) Connect in S7 mode to 0 / 2
2024-02-14 10:48:14.843 - info: s7.1 (16204) Successfully connected in S7 mode
2024-02-14 10:50:31.391 - error: host.HK01-MA instance system.adapter.admin.0 terminated with code 4294967295 ()
2024-02-14 10:50:31.392 - info: host.HK01-MA Restart adapter system.adapter.admin.0 because enabled
2024-02-14 10:50:31.470 - error: host.HK01-MA instance system.adapter.s7.0 terminated with code 4294967295 ()
2024-02-14 10:50:31.470 - info: host.HK01-MA Restart adapter system.adapter.s7.0 because enabled
2024-02-14 10:50:31.554 - error: host.HK01-MA instance system.adapter.discovery.0 terminated with code 4294967295 ()
2024-02-14 10:50:31.554 - info: host.HK01-MA Restart adapter system.adapter.discovery.0 because enabled
2024-02-14 10:50:31.633 - error: host.HK01-MA instance system.adapter.backitup.0 terminated with code 4294967295 ()
2024-02-14 10:50:31.634 - info: host.HK01-MA Restart adapter system.adapter.backitup.0 because enabled
2024-02-14 10:50:31.723 - error: host.HK01-MA instance system.adapter.yahka.0 terminated with code 4294967295 ()
2024-02-14 10:50:31.724 - info: host.HK01-MA Restart adapter system.adapter.yahka.0 because enabled
2024-02-14 10:50:53.308 - info: host.HK01-MA iobroker.js-controller version 5.0.17 js-controller starting
2024-02-14 10:50:53.310 - info: host.HK01-MA Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
2024-02-14 10:50:53.310 - info: host.HK01-MA hostname: HK01-MA, node: v18.19.0
2024-02-14 10:50:53.310 - info: host.HK01-MA ip addresses: fe80::e813:36d1:6136:d1a4 169.254.81.252 fe80::cee8:cf33:5c20:fb92 169.254.19.167 fe80::e556:8e21:6fc1:a33e 169.254.94.115 192.168.2.37 192.168.2.38 192.168.0.80 fe80::3ec8:d5d9:6bcf:acf3 169.254.94.3
2024-02-14 10:50:53.484 - info: host.HK01-MA connected to Objects and States
2024-02-14 10:50:53.491 - info: host.HK01-MA added notifications configuration of host
2024-02-14 10:50:53.761 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.nodeCurrent"
2024-02-14 10:50:53.761 - info: host.HK01-MA 6 instances found
2024-02-14 10:50:53.763 - info: host.HK01-MA starting 6 instances
2024-02-14 10:50:53.784 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.nodeNewest"
2024-02-14 10:50:53.788 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.nodeNewestNext"
2024-02-14 10:50:53.801 - info: host.HK01-MA instance system.adapter.admin.0 started with pid 17820
2024-02-14 10:50:53.804 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.npmCurrent"
2024-02-14 10:50:53.806 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.npmNewest"
2024-02-14 10:50:53.808 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.npmNewestNext"
2024-02-14 10:50:53.810 - info: host.HK01-MA Some obsolete host states deleted.
2024-02-14 10:50:54.778 - error: admin.0 (17820) admin.0 already running
2024-02-14 10:50:54.779 - warn: admin.0 (17820) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2024-02-14 10:50:55.327 - error: host.HK01-MA instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2024-02-14 10:50:55.327 - info: host.HK01-MA Restart adapter system.adapter.admin.0 because enabled
2024-02-14 10:50:57.794 - info: host.HK01-MA instance system.adapter.s7.0 started with pid 17772
2024-02-14 10:50:58.875 - error: s7.0 (17772) s7.0 already running
2024-02-14 10:50:58.876 - warn: s7.0 (17772) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2024-02-14 10:50:59.438 - error: host.HK01-MA instance system.adapter.s7.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2024-02-14 10:50:59.438 - info: host.HK01-MA Restart adapter system.adapter.s7.0 because enabled
2024-02-14 10:51:01.795 - info: host.HK01-MA instance system.adapter.s7.1 started with pid 3400
2024-02-14 10:51:02.499 - error: s7.1 (3400) s7.1 already running
2024-02-14 10:51:02.500 - warn: s7.1 (3400) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2024-02-14 10:51:03.027 - error: host.HK01-MA instance system.adapter.s7.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2024-02-14 10:51:03.027 - info: host.HK01-MA Restart adapter system.adapter.s7.1 because enabled
2024-02-14 10:51:05.783 - info: host.HK01-MA instance system.adapter.discovery.0 started with pid 7024
2024-02-14 10:51:06.449 - error: discovery.0 (7024) discovery.0 already running
2024-02-14 10:51:06.450 - warn: discovery.0 (7024) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2024-02-14 10:51:06.987 - error: host.HK01-MA instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2024-02-14 10:51:06.987 - info: host.HK01-MA Restart adapter system.adapter.discovery.0 because enabled
2024-02-14 10:51:09.787 - info: host.HK01-MA instance system.adapter.backitup.0 started with pid 17816
2024-02-14 10:51:10.464 - error: backitup.0 (17816) backitup.0 already running
2024-02-14 10:51:10.465 - warn: backitup.0 (17816) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2024-02-14 10:51:10.995 - error: host.HK01-MA instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2024-02-14 10:51:10.995 - info: host.HK01-MA Restart adapter system.adapter.backitup.0 because enabled
2024-02-14 10:51:13.780 - info: host.HK01-MA instance system.adapter.yahka.0 started with pid 6828
2024-02-14 10:51:14.688 - error: yahka.0 (6828) yahka.0 already running
2024-02-14 10:51:14.689 - warn: yahka.0 (6828) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2024-02-14 10:51:15.230 - error: host.HK01-MA instance system.adapter.yahka.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2024-02-14 10:51:15.230 - info: host.HK01-MA Restart adapter system.adapter.yahka.0 because enabled
2024-02-14 10:51:25.356 - info: host.HK01-MA instance system.adapter.admin.0 started with pid 19056
2024-02-14 10:51:26.580 - info: admin.0 (19056) starting. Version 6.13.16 in C:/ioBroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:51:26.598 - info: admin.0 (19056) requesting all objects
2024-02-14 10:51:26.825 - info: admin.0 (19056) received all objects
2024-02-14 10:51:26.890 - info: admin.0 (19056) socket.io server listening on port 8081
2024-02-14 10:51:26.891 - info: admin.0 (19056) http server listening on port 8081
2024-02-14 10:51:26.891 - info: admin.0 (19056) Use link "http://127.0.0.1:8081" to configure.
2024-02-14 10:51:27.643 - info: admin.0 (19056) ==> Connected system.user.admin from ::1
2024-02-14 10:51:29.467 - info: host.HK01-MA instance system.adapter.s7.0 started with pid 14232
2024-02-14 10:51:30.370 - info: s7.0 (14232) starting. Version 1.4.2 in C:/ioBroker/node_modules/iobroker.s7, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:51:30.404 - info: s7.0 (14232) Connect in S7 mode to 0 / 2
2024-02-14 10:51:30.427 - info: s7.0 (14232) Successfully connected in S7 mode
2024-02-14 10:51:33.053 - info: host.HK01-MA instance system.adapter.s7.1 started with pid 19072
2024-02-14 10:51:33.950 - info: s7.1 (19072) starting. Version 1.4.2 in C:/ioBroker/node_modules/iobroker.s7, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:51:33.984 - info: s7.1 (19072) Connect in S7 mode to 0 / 2
2024-02-14 10:51:33.993 - info: s7.1 (19072) Successfully connected in S7 mode
2024-02-14 10:51:34.783 - info: admin.0 (19056) ==> Connected system.user.admin from ::1
2024-02-14 10:51:37.005 - info: host.HK01-MA instance system.adapter.discovery.0 started with pid 18008
2024-02-14 10:51:37.865 - info: discovery.0 (18008) starting. Version 4.2.0 in C:/ioBroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:51:41.009 - info: host.HK01-MA instance system.adapter.backitup.0 started with pid 19036
2024-02-14 10:51:41.960 - info: backitup.0 (19036) starting. Version 2.9.8 in C:/ioBroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:51:41.987 - info: backitup.0 (19036) [iobroker] backup will be activated at 02:48 every 1 day(s)
2024-02-14 10:51:42.859 - info: admin.0 (19056) <== Disconnect system.user.admin from ::1
2024-02-14 10:51:45.241 - info: host.HK01-MA instance system.adapter.yahka.0 started with pid 19344
2024-02-14 10:51:46.370 - info: yahka.0 (19344) starting. Version 1.0.3 in C:/ioBroker/node_modules/iobroker.yahka, node: v18.19.0, js-controller: 5.0.17
2024-02-14 10:51:46.389 - info: yahka.0 (19344) adapter ready, checking config
2024-02-14 10:51:46.394 - info: yahka.0 (19344) publishing bridge Yahka-0 on 0.0.0.0 using avahi
2024-02-14 11:05:38.844 - info: admin.0 (19056) <== Disconnect system.user.admin from ::1 admin
2024-02-14 11:05:44.061 - error: host.HK01-MA instance system.adapter.admin.0 terminated with code 4294967295 ()
2024-02-14 11:05:44.061 - info: host.HK01-MA Restart adapter system.adapter.admin.0 because enabled
2024-02-14 11:05:44.140 - error: host.HK01-MA instance system.adapter.s7.0 terminated with code 4294967295 ()
2024-02-14 11:05:44.140 - info: host.HK01-MA Restart adapter system.adapter.s7.0 because enabled
2024-02-14 11:05:44.210 - error: host.HK01-MA instance system.adapter.s7.1 terminated with code 4294967295 ()
2024-02-14 11:05:44.210 - info: host.HK01-MA Restart adapter system.adapter.s7.1 because enabled
2024-02-14 11:05:44.279 - error: host.HK01-MA instance system.adapter.discovery.0 terminated with code 4294967295 ()
2024-02-14 11:05:44.279 - info: host.HK01-MA Restart adapter system.adapter.discovery.0 because enabled
2024-02-14 11:05:44.349 - error: host.HK01-MA instance system.adapter.backitup.0 terminated with code 4294967295 ()
2024-02-14 11:05:44.349 - info: host.HK01-MA Restart adapter system.adapter.backitup.0 because enabled
2024-02-14 11:21:35.512 - info: host.HK01-MA iobroker.js-controller version 5.0.17 js-controller starting
2024-02-14 11:21:35.513 - info: host.HK01-MA Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
2024-02-14 11:21:35.514 - info: host.HK01-MA hostname: HK01-MA, node: v18.19.0
2024-02-14 11:21:35.514 - info: host.HK01-MA ip addresses: fe80::e813:36d1:6136:d1a4 169.254.81.252 fe80::cee8:cf33:5c20:fb92 169.254.19.167 fe80::e556:8e21:6fc1:a33e 169.254.94.115 192.168.2.37 192.168.2.38 192.168.0.80 fe80::3ec8:d5d9:6bcf:acf3 169.254.94.3
2024-02-14 11:21:35.674 - info: host.HK01-MA connected to Objects and States
2024-02-14 11:21:35.680 - info: host.HK01-MA added notifications configuration of host
2024-02-14 11:21:35.919 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.nodeCurrent"
2024-02-14 11:21:35.920 - info: host.HK01-MA 6 instances found
2024-02-14 11:21:35.923 - info: host.HK01-MA starting 6 instances
2024-02-14 11:21:35.946 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.nodeNewest"
2024-02-14 11:21:35.950 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.nodeNewestNext"
2024-02-14 11:21:35.963 - info: host.HK01-MA instance system.adapter.admin.0 started with pid 3820
2024-02-14 11:21:35.965 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.npmCurrent"
2024-02-14 11:21:35.968 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.npmNewest"
2024-02-14 11:21:35.970 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.npmNewestNext"
2024-02-14 11:21:35.973 - info: host.HK01-MA Some obsolete host states deleted.
2024-02-14 11:21:36.962 - error: admin.0 (3820) admin.0 already running
2024-02-14 11:21:36.963 - warn: admin.0 (3820) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2024-02-14 11:21:37.496 - error: host.HK01-MA instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2024-02-14 11:21:37.496 - info: host.HK01-MA Restart adapter system.adapter.admin.0 because enabled
2024-02-14 11:21:39.942 - info: host.HK01-MA instance system.adapter.s7.0 started with pid 8344
2024-02-14 11:21:40.629 - error: s7.0 (8344) s7.0 already running
2024-02-14 11:21:40.630 - warn: s7.0 (8344) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2024-02-14 11:21:41.148 - error: host.HK01-MA instance system.adapter.s7.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2024-02-14 11:21:41.148 - info: host.HK01-MA Restart adapter system.adapter.s7.0 because enabled
2024-02-14 11:21:43.941 - info: host.HK01-MA instance system.adapter.s7.1 started with pid 19448
2024-02-14 11:21:44.635 - error: s7.1 (19448) s7.1 already running
2024-02-14 11:21:44.636 - warn: s7.1 (19448) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2024-02-14 11:21:45.154 - error: host.HK01-MA instance system.adapter.s7.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2024-02-14 11:21:45.154 - info: host.HK01-MA Restart adapter system.adapter.s7.1 because enabled
2024-02-14 11:21:47.943 - info: host.HK01-MA instance system.adapter.discovery.0 started with pid 10784
2024-02-14 11:21:48.599 - error: discovery.0 (10784) discovery.0 already running
2024-02-14 11:21:48.600 - warn: discovery.0 (10784) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2024-02-14 11:21:49.135 - error: host.HK01-MA instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2024-02-14 11:21:49.135 - info: host.HK01-MA Restart adapter system.adapter.discovery.0 because enabled
2024-02-14 11:21:51.941 - info: host.HK01-MA instance system.adapter.backitup.0 started with pid 11040
2024-02-14 11:21:52.634 - error: backitup.0 (11040) backitup.0 already running
2024-02-14 11:21:52.635 - warn: backitup.0 (11040) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2024-02-14 11:21:53.168 - error: host.HK01-MA instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2024-02-14 11:21:53.168 - info: host.HK01-MA Restart adapter system.adapter.backitup.0 because enabled
2024-02-14 11:21:55.947 - info: host.HK01-MA instance system.adapter.yahka.0 started with pid 15708
2024-02-14 11:21:56.869 - error: yahka.0 (15708) yahka.0 already running
2024-02-14 11:21:56.870 - warn: yahka.0 (15708) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
2024-02-14 11:21:57.401 - error: host.HK01-MA instance system.adapter.yahka.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
2024-02-14 11:21:57.402 - info: host.HK01-MA Restart adapter system.adapter.yahka.0 because enabled
2024-02-14 11:22:07.521 - info: host.HK01-MA instance system.adapter.admin.0 started with pid 8376
2024-02-14 11:22:09.439 - info: admin.0 (8376) starting. Version 6.13.16 in C:/ioBroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
2024-02-14 11:22:09.459 - info: admin.0 (8376) requesting all objects
2024-02-14 11:22:09.657 - info: admin.0 (8376) received all objects
2024-02-14 11:22:09.768 - info: admin.0 (8376) socket.io server listening on port 8081
2024-02-14 11:22:09.769 - info: admin.0 (8376) http server listening on port 8081
2024-02-14 11:22:09.769 - info: admin.0 (8376) Use link "http://127.0.0.1:8081" to configure.
2024-02-14 11:22:11.172 - info: host.HK01-MA instance system.adapter.s7.0 started with pid 20476
2024-02-14 11:22:12.274 - info: s7.0 (20476) starting. Version 1.4.2 in C:/ioBroker/node_modules/iobroker.s7, node: v18.19.0, js-controller: 5.0.17
2024-02-14 11:22:12.309 - info: s7.0 (20476) Connect in S7 mode to 0 / 2
2024-02-14 11:22:12.320 - info: s7.0 (20476) Successfully connected in S7 mode
2024-02-14 11:22:15.172 - info: host.HK01-MA instance system.adapter.s7.1 started with pid 20724
2024-02-14 11:22:15.917 - info: admin.0 (8376) ==> Connected system.user.admin from ::ffff:127.0.0.1
2024-02-14 11:22:16.934 - info: s7.1 (20724) starting. Version 1.4.2 in C:/ioBroker/node_modules/iobroker.s7, node: v18.19.0, js-controller: 5.0.17
2024-02-14 11:22:16.973 - info: s7.1 (20724) Connect in S7 mode to 0 / 2
2024-02-14 11:22:16.986 - info: s7.1 (20724) Successfully connected in S7 mode
2024-02-14 11:22:19.151 - info: host.HK01-MA instance system.adapter.discovery.0 started with pid 21240
2024-02-14 11:22:20.070 - info: discovery.0 (21240) starting. Version 4.2.0 in C:/ioBroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.17
2024-02-14 11:22:23.184 - info: host.HK01-MA instance system.adapter.backitup.0 started with pid 20316
2024-02-14 11:22:24.076 - info: backitup.0 (20316) starting. Version 2.9.8 in C:/ioBroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
2024-02-14 11:22:24.109 - info: backitup.0 (20316) [iobroker] backup will be activated at 02:48 every 1 day(s)
2024-02-14 11:22:27.421 - info: host.HK01-MA instance system.adapter.yahka.0 started with pid 21116
2024-02-14 11:22:28.506 - info: yahka.0 (21116) starting. Version 1.0.3 in C:/ioBroker/node_modules/iobroker.yahka, node: v18.19.0, js-controller: 5.0.17
2024-02-14 11:22:28.521 - info: yahka.0 (21116) adapter ready, checking config
2024-02-14 11:22:28.526 - info: yahka.0 (21116) publishing bridge Yahka-0 on 0.0.0.0 using avahi
