    4. Backitup Adapter Backups ausserhalb Zeit ( gelöst )
      stefu87_CH @Glasfaser last edited by
      @glasfaser sagte in Backitup Adapter Backups ausserhalb Zeit:
      ps auxww|grep io
      Erhalte diesen Eintrag:
      message+     102  0.0  0.0   8764  3328 ?        Ss   Jan16   0:00 @dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
      iobroker     113 15.2  8.2 12104696 696980 ?     Ssl  Jan16 6357:12 iobroker.js-controller
      iobroker     329  0.1  1.4 838376 119256 ?       Sl   Jan16  42:55 io.history.0
      iobroker     378  0.0  0.8 692960 74304 ?        Sl   Jan16  14:59 io.scenes.0
      iobroker     393  0.0  1.4 1101256 123432 ?      Sl   Jan16  41:22 io.sql.0
      iobroker     423  0.0  0.9 954868 76904 ?        Sl   Jan16  11:41 io.whatsapp-cmb.0
      iobroker     438  0.0  0.9 954464 76052 ?        Sl   Jan16  11:45 io.whatsapp-cmb.1
      iobroker     468  0.0  0.8 686492 70468 ?        Sl   Jan16  11:25 io.pushover.0
      iobroker     607  3.7  1.8 756552 155240 ?       Sl   Jan16 1540:18 io.shelly.0
      iobroker     627  0.9  1.7 796660 144800 ?       Sl   Jan16 385:04 io.shelly.1
      iobroker     747  0.0  0.8 685200 68180 ?        Sl   Jan16  11:25 io.alexa-timer-vis.0
      iobroker     869  0.0  1.0 966124 89460 ?        Sl   Jan16  35:09 io.bring.0
      iobroker     884  0.0  0.9 953500 76636 ?        Sl   Jan16  13:31 io.cloud.0
      iobroker    1019  0.0  0.8 686464 69384 ?        Sl   Jan16  11:39 io.discovery.0
      iobroker    1059  0.1  1.3 840376 117340 ?       Sl   Jan16  48:24 io.eventlist.0
      iobroker    1131  0.0  0.9 940328 81324 ?        Sl   Jan16  14:06 io.info.0
      iobroker    1529  0.0  1.0 838596 87684 ?        Sl   Jan16  13:12 io.iot.0
      iobroker    1571  0.0  0.8 686032 67516 ?        Sl   Jan16  17:21 io.mytime.0
      iobroker    1588  0.0  2.6 1094636 222596 ?      Sl   Jan16  28:23 io.octoprint.0
      iobroker    1716  0.0  0.9 705392 78348 ?        Sl   Jan16  24:57 io.sainlogic.0
      iobroker    1733  0.0  0.8 694604 75040 ?        Sl   Jan16  13:29 io.snmp.0
      iobroker    1776  0.0  0.8 689128 71224 ?        Sl   Jan16  11:33 io.socketio.0
      iobroker    1821  0.0  0.9 697040 78964 ?        Sl   Jan16  12:46 io.trashschedule.0
      iobroker    1863  0.0  0.7 684008 66700 ?        Sl   Jan16  11:29 io.vis-inventwo.0
      iobroker    1921  0.1  1.0 11450188 92552 ?      Sl   Jan16  47:48 io.vw-connect.0
      iobroker    2001  1.3  1.0 714844 90220 ?        Sl   Jan16 580:06 io.device-watcher.0
      iobroker    2016  0.0  0.8 769576 74992 ?        Sl   Jan16  12:39 io.vis-2.0
      iobroker    2056  0.0  0.8 684868 69056 ?        Sl   Jan16  11:26 io.telegram-menu.0
      iobroker  158142  0.1  3.1 1143092 266124 ?      Sl   Feb05  17:58 io.admin.0
      iobroker  762696  0.0  0.8 687020 69612 ?        Sl   Jan28   6:43 io.email.0
      iobroker 1556699  0.4  1.0 962936 91576 ?        Sl   Jan20 167:31 io.nuki-extended.0
      iobroker 1969900  0.0  0.8 821040 74632 ?        Sl   Jan21  10:01 io.proxmox.0
      iobroker 1973675  0.0  1.5 1013756 130976 ?      Sl   Jan21  17:03 io.zigbee.0
      iobroker 2209668  0.0  2.2 1057744 193224 ?      Sl   Jan31  17:35 io.web.0
      iobroker 2661068  0.0  1.5 11476384 129240 ?     Sl   Feb01   7:07 io.backitup.0
      iobroker 3073085  0.0  0.9 705184 78212 ?        Sl   Feb02  16:23 io.countdown.0
      iobroker 3085322  1.1  0.9 699060 76544 ?        Sl   Feb02 201:46 io.ping.0
      iobroker 3401966  0.1  1.4 1023056 122508 ?      Sl   Jan24  38:39 io.mihome-vacuum.0
      iobroker 3551699  0.0  1.1 963468 98672 ?        Sl   Feb13   0:57 io.alexa2.0
      iobroker 3901246  0.1  1.5 1003436 126588 ?      Sl   05:04   0:59 io.telegram.0
      iobroker 3966782  0.0  1.0 960004 84700 ?        Sl   Feb04   4:26 io.parser.0
      iobroker 4133463  3.5  1.2 773436 109320 ?       Sl   17:33   1:10 io.influxdb.1
      iobroker 4133741  4.7  4.1 1130892 354168 ?      Sl   17:33   1:32 io.javascript.0
      iobroker 4143815 10.7  1.1 11438452 93868 ?      Sl   18:06   0:03 io.unifi.0
      iobroker 4144110  0.0  0.0   4712  2176 ?        S    18:06   0:00 /bin/ping -n -w 2 -c 1 192.168.0.212
      admin    4144112  0.0  0.0   3472  1920 pts/1    S+   18:06   0:00 grep --color=auto io
      Ja das Backup welches um 11:30 gemacht wird, ist jeweils immer richtig abgelegt im Zielverzeichnis um diese Uhrzeit.
        stefu87_CH @crunchip last edited by
        @crunchip sagte in Backitup Adapter Backups ausserhalb Zeit:
        les da nix das ein backup gemacht wird, nur das dein ftp nicht erreichbar ist
        Ja das ist so, aber dann sollte er kein Backup machen, da ja um 11:30 eingetragen ist im Adapter.
        Glasfaser crunchip 2 Replies Last reply Reply Quote 0
        • Glasfaser
          Glasfaser @stefu87_CH last edited by Glasfaser
          @stefu87_ch
          gibt es nur diese beiden Einträg !?
          Poste mal alles davon !
            @stefu87_ch
            Ja unter dem Befehl:
            ps auxww|grep io
            erhalte ich nur diese Zeilen wie oben angezeigt.
            • Glasfaser
              @stefu87_ch sagte in Backitup Adapter Backups ausserhalb Zeit:
              OK . nur ein PID und die passt auch zum Log also kein ZOMBI
              • Glasfaser
                Nein ... ich meine den ioBroker Log von dir !
                2024-02-14 16:42:37.651 - error: backitup.0 (2661068) [iobroker/ftp] Error: read ECONNRESET
                2024-02-14 16:42:37.655 - error: backitup.0 (2661068) [iobroker] Error: read ECONNRESET
                ob da mehr steht !!
                  crunchip Forum Testing Most Active @stefu87_CH last edited by
                  @stefu87_ch ist vllt ein cron eingestellt und backitup startet da neu?
                    ob da mehr steht !!
                    Ne da steht nur das drin. Sonst keine anderen Meldungen.
                      Ne da ist keine Startzeit drin:
                      • Glasfaser
                        Hatte heute wieder das Bild, das ich um 16:42 eine Fehlermeldung erhielt,
                        Immer die gleiche Uhrzeit !?
                          Nein sind unterschiedliche Zeiten, aber auch nicht jeden Tag.
                          Heute: 16:42
                          Sonntag: 15:11
                          Freitag: 19:32
                          Mittwoch: 11:55
                          • Glasfaser
                            @stefu87_ch
                            Stelle die Logstufe der Instanz auf DEBUG und poste hier das Ergebnis !
                              @stefu87_ch
                              2024-02-14 18:27:08.559 - debug: backitup.0 (4150663) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              2024-02-14 18:27:08.605 - debug: backitup.0 (4150663) Objects client ready ... initialize now
                              2024-02-14 18:27:08.654 - debug: backitup.0 (4150663) Objects create System PubSub Client
                              2024-02-14 18:27:08.655 - debug: backitup.0 (4150663) Objects create User PubSub Client
                              2024-02-14 18:27:08.753 - debug: backitup.0 (4150663) Objects client initialize lua scripts
                              2024-02-14 18:27:08.760 - debug: backitup.0 (4150663) Objects connected to redis: 127.0.0.1:9001
                              2024-02-14 18:27:08.811 - debug: backitup.0 (4150663) Redis States: Use Redis connection: 127.0.0.1:9000
                              2024-02-14 18:27:08.845 - debug: backitup.0 (4150663) States create System PubSub Client
                              2024-02-14 18:27:08.845 - debug: backitup.0 (4150663) States create User PubSub Client
                              2024-02-14 18:27:08.945 - debug: backitup.0 (4150663) States connected to redis: 127.0.0.1:9000
                              2024-02-14 18:27:09.027 - debug: backitup.0 (4150663) Plugin sentry Initialize Plugin (enabled=true)
                              2024-02-14 18:27:09.565 - info: backitup.0 (4150663) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
                              2024-02-14 18:27:09.637 - debug: backitup.0 (4150663) Backitup has recognized a linux system
                              2024-02-14 18:27:09.693 - info: backitup.0 (4150663) [iobroker] backup will be activated at 11:30 every 1 day(s)
                              2024-02-14 18:27:10.172 - debug: backitup.0 (4150663) FTP: connected.
                              2024-02-14 18:27:12.274 - debug: backitup.0 (4150663) detect backup file 1 from ftp: iobroker_2024_01_28-10_04_40_backupiobroker.tar.gz
                              2024-02-14 18:27:12.274 - debug: backitup.0 (4150663) detect backup file 2 from ftp: iobroker_2024_01_28-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.275 - debug: backitup.0 (4150663) detect backup file 3 from ftp: iobroker_2024_01_29-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.275 - debug: backitup.0 (4150663) detect backup file 4 from ftp: iobroker_2024_01_30-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.275 - debug: backitup.0 (4150663) detect backup file 5 from ftp: iobroker_2024_01_31-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.275 - debug: backitup.0 (4150663) detect backup file 6 from ftp: iobroker_2024_02_01-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.275 - debug: backitup.0 (4150663) detect backup file 7 from ftp: iobroker_2024_02_01-19_42_53_backupiobroker.tar.gz
                              2024-02-14 18:27:12.275 - debug: backitup.0 (4150663) detect backup file 8 from ftp: iobroker_2024_02_02-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.275 - debug: backitup.0 (4150663) detect backup file 9 from ftp: iobroker_2024_02_03-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.276 - debug: backitup.0 (4150663) detect backup file 10 from ftp: iobroker_2024_02_04-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.276 - debug: backitup.0 (4150663) detect backup file 11 from ftp: iobroker_2024_02_05-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.276 - debug: backitup.0 (4150663) detect backup file 12 from ftp: iobroker_2024_02_05-16_46_33_backupiobroker.tar.gz
                              2024-02-14 18:27:12.276 - debug: backitup.0 (4150663) detect backup file 13 from ftp: iobroker_2024_02_06-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.276 - debug: backitup.0 (4150663) detect backup file 14 from ftp: iobroker_2024_02_07-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.276 - debug: backitup.0 (4150663) detect backup file 15 from ftp: iobroker_2024_02_07-18_46_27_backupiobroker.tar.gz
                              2024-02-14 18:27:12.276 - debug: backitup.0 (4150663) detect backup file 16 from ftp: iobroker_2024_02_09-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.276 - debug: backitup.0 (4150663) detect backup file 17 from ftp: iobroker_2024_02_09-20_00_20_backupiobroker.tar.gz
                              2024-02-14 18:27:12.276 - debug: backitup.0 (4150663) detect backup file 18 from ftp: iobroker_2024_02_10-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.276 - debug: backitup.0 (4150663) detect backup file 19 from ftp: iobroker_2024_02_11-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.276 - debug: backitup.0 (4150663) detect backup file 20 from ftp: iobroker_2024_02_12-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.276 - debug: backitup.0 (4150663) detect backup file 21 from ftp: iobroker_2024_02_13-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.277 - debug: backitup.0 (4150663) detect backup file 22 from ftp: iobroker_2024_02_14-11_30_10_backupiobroker.tar.gz
                              2024-02-14 18:27:12.277 - debug: backitup.0 (4150663) detect backup file 23 from ftp: iobroker_2024_02_14-18_18_59_backupiobroker.tar.gz
                              2024-02-14 18:27:12.277 - debug: backitup.0 (4150663) detect last backup file: iobroker_2024_02_14-18_18_59_backupiobroker.tar.gz
                              • Glasfaser
                                In deinem Log sind auch verschiedene Backups / Zeiten
                                z.B
                                Am 09.02.2024
                                Einmal 11:30 und 20:00 Uhr .
                                S crunchip 2 Replies Last reply Reply Quote 0
                                  @glasfaser Ja das war ich selber, da ich was an der Visu geändert habe und dies Speichern wollte. Aber z.B. heute war ich um 16:42 noch gar nicht zuhause und der Adapter hat da selber was ausgelöst.
                                    crunchip Forum Testing Most Active @Glasfaser last edited by
                                    @glasfaser und mehr als die eingestellten 8
                                    • Glasfaser
                                      Glasfaser @crunchip last edited by
                                      @crunchip
                                      Die sind Manuell erstellt , daher
                                      • Glasfaser
                                        Ich finde nur das :
                                        Zitat :
                                        Aus dem Grund überprüft backitup beim start des Adapters und auch vor jedem Backup, ob der mount noch vorhanden ist und führt einen umount aus.
                                          Ok. Das ist sehr speziell in meinem Fall, das es nicht jeden Tag passiert, und zu unterschiedlichen Zeiten, und komisch auch das er am Vormittags um 11:30 eine Verbindung zum FTP Server Dienst hat und dazwischen findet er keine, obwohl mein NAS bei mir Zuhause steht wo er das abspeichert.
                                          • Glasfaser
                                            Was mich noch wundert , das die IP und der Port in der Ausgabe fehlen !
                                            Da ich kein FTP habe , kann ich nur anhand von anderen Thread etwas dazu suchen !
                                            so sieht es bei anderen aus , aber nicht mit deine" Mysteriöse Zeitphänomene "
                                            2023-02-07 02:10:28.257 - error: backitup.0 (10156) [iobroker/ftp] Error: connect EHOSTUNREACH 192.168.1.21:21
                                            2023-02-07 02:10:28.258 - error: backitup.0 (10156) [iobroker] Error: connect EHOSTUNREACH 192.168.1.21:21
                                            2012
