    4. LG TV schalten direkt oder über iobroker
      spaddel @Homoran last edited by spaddel
      @homoran Der TV wird über die ganz normale Fernbedienung eingeschaltet. Die Rega ID passt, dass habe ich geprüft. Die Variable wird immer noch nicht im Log gezeigt. Es taucht nur das Polling Trigger auf. Hier noch mal ein Log
      2024-02-13 07:42:45.102 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316239.1.DIRECTION" has value "1" greater than max "-1"
      2024-02-13 07:42:45.262 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1315953.1.DIRECTION" has value "1" greater than max "-1"
      2024-02-13 07:42:45.417 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316244.1.DIRECTION" has value "1" greater than max "-1"
      2024-02-13 07:42:45.573 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316007.1.DIRECTION" has value "1" greater than max "-1"
      2024-02-13 07:42:48.630 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316239.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 07:42:49.285 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1315953.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 07:42:50.689 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316244.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 07:42:51.249 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316007.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 07:46:22.198 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316248.1.DIRECTION" has value "1" greater than max "-1"
      2024-02-13 07:46:42.682 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1850610.1.DIRECTION" has value "1" greater than max "-1"
      2024-02-13 07:46:51.962 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316248.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 07:46:56.542 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1850610.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 18:00:10.958 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1315953.1.DIRECTION" has value "2" greater than max "-1"
      2024-02-13 18:00:11.110 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316007.1.DIRECTION" has value "2" greater than max "-1"
      2024-02-13 18:00:11.274 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316239.1.DIRECTION" has value "2" greater than max "-1"
      2024-02-13 18:00:11.426 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316244.1.DIRECTION" has value "2" greater than max "-1"
      2024-02-13 18:00:19.658 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1315953.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 18:00:20.110 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316244.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 18:00:20.901 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316007.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 18:00:21.346 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316239.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 18:15:01.214 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316248.1.DIRECTION" has value "2" greater than max "-1"
      2024-02-13 18:15:01.361 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1850610.1.DIRECTION" has value "2" greater than max "-1"
      2024-02-13 18:15:14.450 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1850610.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 18:15:30.778 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316248.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 18:51:16.618 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316297.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 18:51:19.502 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316297.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 18:18:05.899 - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.2.31
      2024-02-13 18:18:13.220 - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.2.31
      2024-02-13 18:19:44.849 - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.2.31 javascript
      2024-02-13 18:19:44.853 - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.2.31 admin
      2024-02-13 18:44:57.646 - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.2.31
      2024-02-13 18:44:57.665 - info: admin.0 (1828) ==> Connected system.user.admin from ::ffff:192.168.2.31
      2024-02-13 18:57:58.905 - info: admin.0 (1828) <== Disconnect system.user.admin from ::ffff:192.168.2.31 javascript
      2024-02-13 20:19:31.035 - info: hm-rega.0 (2404345) Program received for not-known dp 16188, requesting programs
      2024-02-13 20:19:31.107 - info: hm-rega.0 (2404345) got 32 programs
      2024-02-13 20:19:31.151 - info: hm-rega.0 (2404345) added/updated 33 programs
      2024-02-13 20:19:31.151 - info: hm-rega.0 (2404345) deleted 0 programs
      2024-02-13 20:20:32.058 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316297.1.DIRECTION" has value "2" greater than max "-1"
      2024-02-13 20:20:32.210 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316053.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 20:20:32.370 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1850610.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 20:20:32.526 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1315961.1.DIRECTION" has value "2" greater than max "-1"
      2024-02-13 20:20:32.694 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316252.1.DIRECTION" has value "2" greater than max "-1"
      2024-02-13 20:20:32.846 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316264.1.DIRECTION" has value "2" greater than max "-1"
      2024-02-13 20:20:33.002 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316248.1.DIRECTION" has value "1" greater than max "-1"
      2024-02-13 20:20:38.342 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316248.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 20:20:52.370 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316252.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 20:20:58.372 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1315961.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 20:20:58.942 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316297.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 20:21:00.454 - warn: hm-rpc.0 (2404363) State value to set for "hm-rpc.0.OEQ1316264.1.DIRECTION" has value "0" greater than max "-1"
      2024-02-13 20:21:01.073 - info: hm-rega.0 (2404345) Program received for not-known dp 16202, requesting programs
      2024-02-13 20:21:01.090 - info: hm-rega.0 (2404345) got 33 programs
      2024-02-13 20:21:01.128 - info: hm-rega.0 (2404345) added/updated 32 programs
      2024-02-13 20:21:01.198 - info: hm-rega.0 (2404345) deleted 2 programs
      2024-02-13 20:23:50.801 - info: hm-rega.0 (2404345) pollingTrigger
      Die Warnmeldungen sind neu und konnte ich noch nicht zuordnen.
        Homoran Global Moderator Administrators @spaddel last edited by
        @spaddel sagte in LG TV schalten direkt oder über iobroker:
        stell mal die logstufe im debug Baustein auf warn
        sieht nach fehlkonfiguration eines Rollladen Datenpunkts aus.
        Möglicherweise auch wegen Problemen mit hm-rega.
        Es ergibt aus meiner Sicht keinen Sinn eine Fehler-/Problemsuche an einer Installation durchzuführen, in der schon Basisdinge nicht richtig funktionieren
          Homoran Global Moderator Administrators @spaddel last edited by Homoran
          @homoran Hallo zusammen, leider habe ich es erst jetzt geschafft, mir eure Antworten anzugucken.
          Ich hoffe, dass ich jetzt das richtige zeige. Hier meine Einstellungen vom hm-rega:
          ich habe mir gerade nochmal diese Einstellungen angesehen, die sind auf jeden Fall falsch!
          Welche HM Dienste nutzst du?
          wie sind die zugehörigen hm-rpc Instanzen konfiguriert?
            @homoran Ich nutze HM-rega und hm-rpc.
            HM Rega
            Da ich die Screenshot über das Handy mache muss ich mehrere Bilder einstellen:
            HM RPC
            Ich hoffe, dass ich alle Einstellungen, die du benötigst zeige. Wenn nicht bitte melden. Dann reiche ich die nach.
            Samson71 Homoran 2 Replies Last reply Reply Quote 0
            • Samson71
              Samson71 Global Moderator @spaddel last edited by
              @spaddel
              Die Screenshots sind so - wohlwollend ausgedrückt - etwas "unübersichtlich". Selbst am PC lässt sich das echt nicht sinnvoll lesen. Vom Handy will ich lieber gar nicht erst reden (ich denke da vor allem an @Homoran der Dir hier mit Engelsgeduld versucht zu helfen). Bitte mache das (ggf. später) nochmal von anderer Stelle aus jeweils als einen Screenshot pro Adapter/Instanz.
                heisst was?
                @homoran sagte in LG TV schalten direkt oder über iobroker:
                da braucht es mehrere!
                Adapter Homematic RPC
                Dieser Adapter bietet die Anbindung an die Kommunikationsmodule einer Homematic-Zentrale (CCU/CCU2/CCU3 …). Eine Instanz des Adapters ist für genau EIN Module (rfd, wired usw.) zuständig. Sollen mehrere Module parallel unterstützt werden, muss für jedes Modul eine eigene Instanz installiert werden.
                https://www.iobroker.net/#de/adapters/adapterref/iobroker.hm-rpc/README.md?
                  @homoran Das heißt, dass jeweils eine Instanz HM-Rega und HM-RPC installiert sind.
                  Wenn ich das richtig verstanden habe, muss ich also für jedes Modul wie z.B. rfd (funk), cuxd usw. jeweils eine Instanz HM-RPC installieren und dann diese Instanz so konfigurieren, dass ich jedem eine Instanz zuweisen?
                  So in etwa:
                  3da2c23b-5679-43ff-8617-52b6b4c76496-image.png 1fb7f9c2-f38b-4ff5-b41b-12f0c3d86fe4-image.png
                    So in etwa:
                    ja!
                    nur dass die Screenshots so gestaucht sind, dass man die Einträge nicht lesen kann
                    CuxD müsste BIN RPC sein
                      @homoran Dann sollte es jetzt so passen:
                        @spaddel dann mal nacheinander überall "neu einlesen" anhaken und speichern.
                        Dann das log beobachten. wenn das zur Ruhe kommt beim nächsten weitermachen
                          @homoran Ist erledigt.
                            und was stand auffälliges im log?
                              @homoran Es gab 2 Warnungen:
                              Hier das gesamte Log:
                              Log.txt
                                Es gab 2 Warnungen:
                                bitte als Text in code-tags posten.
                                Ich kann damit nichts anfangen, sieht nicht gut aus.
                                ich hoffe das liest dann ein Wissender
                                  @homoran Der gesamte Log funktioniert nicht, da er zu groß. Deswegen nur die Warnungen.
                                  2024-02-14 19:40:09.536 - warn: admin.0 (1828) hm-rpc has an invalid jsonConfig: [{"instancePath":"/items/_deviceManager","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"innerStyle"},"message":"must NOT have additional properties"}]
                                  2024-02-14 19:40:22.975 - warn: admin.0 (1828) hm-rpc has an invalid jsonConfig: [{"instancePath":"/items/_deviceManager","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"innerStyle"},"message":"must NOT have additional properties"}]
                                    spaddel @spaddel last edited by
                                    @spaddel Hallo zusammen, ich habe die Log Einträge ein paar Tage beobachtet und die Fehlermeldungen sind nicht mehr aufgetreten. Deswegen wäre es super, wenn mir jemand noch mal unter die Arme greifen könnte, wie ich jetzt mit der Fehlersuche weitermachen kann.
                                    Danke un Gruß
                                    Ch
                                      @spaddel nimm noch mal das alte Blockly und das alte CCU Skript.
                                      Schalte dann über die CCU ein und aus.
                                      Ist jetzt der Wert aus dem debug Baustein im log zu sehen?
                                        @homoran Entschuldige ich bin erst jetzt dazu gekommen, mich wieder um das Thema zu kümmern.
                                        Wenn ich das Programm der HM ausführe bleibt der Fernseher an. Auch wenn ich die CUXD Taster für ein oder aus direkt drücke passiert nichts. Im Log steht lediglich
                                        hm-rega.0 2024-02-21 22:08:57.465	info	pollingTrigger
                                        Die Variable 14895 bleibt immer auf Status false.
                                        9761
