    3. Einsteigerfragen
    4. Installation
    5. [gelöst] Upgrade einer vernachlässigten ioBroker Inst.
      CoComp @Thomas Braun last edited by CoComp
      da ist nach dem ersten Schritt was schiefgelaufen, scheint es....
      ioBroker nodejs updater 2023-10-13
      Recommended nodejs-version is: 16.20.2
      Checking your installation now. Please be patient!
      Your current setup is:
      /usr/bin/node           v16.18.0
      /usr/bin/npm            8.19.2
      /usr/bin/npx            8.19.2
      /usr/bin/corepack       0.14.1
      We found these nodejs versions available for installation:
      nodejs:
        Installed: 16.18.0-deb-1nodesource1
        Candidate: 16.20.2-deb-1nodesource1
        Version table:
           16.20.2-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
       *** 16.18.0-deb-1nodesource1 100
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      Nothing to do - Your installation is using the correct paths.
      You are running nodejs v16.18.0. Do you want to install recommended version 16.20.2?
      Press <y> to continue or any other key to quit
      Trying to update your installation now. Please be patient.
      Waiting for ioBroker to shut down - Give me a minute...
      *** These repos are active on your system:
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Reading package lists... Done
      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
      (Reading database ... 53643 files and directories currently installed.)
      Preparing to unpack .../curl_7.74.0-1.3+deb11u11_armhf.deb ...
      Unpacking curl (7.74.0-1.3+deb11u11) over (7.74.0-1.3+deb11u3) ...
      Preparing to unpack .../libcurl4_7.74.0-1.3+deb11u11_armhf.deb ...
      Unpacking libcurl4:armhf (7.74.0-1.3+deb11u11) over (7.74.0-1.3+deb11u3) ...
      Setting up libcurl4:armhf (7.74.0-1.3+deb11u11) ...
      Setting up curl (7.74.0-1.3+deb11u11) ...
      Processing triggers for man-db (2.9.4-2) ...
      Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u4) ...
      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      *** These repos are active after the adjustments:
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Get:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
      Get:4 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [7097 B]
      Fetched 19.2 kB in 2s (8129 B/s)
      Installing the recommended nodejs version now!
      /home/iobroker/.nodejs-update.sh: line 329: [: : integer expression expected
      /home/iobroker/.nodejs-update.sh: line 346: [: : integer expression expected
      Installing the recommended nodejs version!
      E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/f/firmware-nonfree/firmware-libertas_20230210-5%7ebpo11%2b1%2brpt2_all.deb  Error reading from server. Remote end closed connection [IP: 46.235.230.122 80]
      E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
      We tried our best to update or fix your nodejs. Please run iob diag again to verify.
        Thomas Braun Most Active @CoComp last edited by
        @cocomp
        sudo apt update
        sudo apt full-upgrade
          @thomas-braun said in Upgrade einer vernachlässigten ioBroker Installation:
          @cocomp
          sudo apt update
          vor
          iob update
          iob upgrade all
          iob stop
          iob upgrade self
          iob start
          oder danach?
            @cocomp
            Davor.
              und danach
              sudo reboot
              und dann den Block komplett nochmal?
              iob nodejs-update
              sudo reboot
              iob update
              iob upgrade all
              iob stop
              iob upgrade self
              iob start
                @cocomp
                Danach sollte ein
                iob nodejs-update
                vermelden, dass alles i.O. ist.
                Dann kann man sich um den ioBroker kümmern.
                  Scheint durchgelaufen zu sein...arbeite jetzt mal die nächsten Schritte ab.
                  iob update
                  iob upgrade all
                  iob stop
                  iob upgrade self
                  iob start
                    CoComp @CoComp last edited by
                    @cocomp
                    So, scheint erfolgreich durchgelaufen zu sein. Nur der Smartmeter-Adapter steht auf gelb, weil er keine Verbindung zum Lesekopf zu haben scheint. War kurz auf grün und dann wieder auf gelb....
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                       Static hostname: raspberrypi
                             Icon name: computer
                      Operating System: Raspbian GNU/Linux 11 (bullseye)
                                Kernel: Linux 6.1.21-v7+
                          Architecture: arm
                    Model           : Raspberry Pi 2 Model B Rev 1.1
                    Docker          : false
                    Virtualization  : none
                    Kernel          : armv7l
                    Userland        : armhf
                    Systemuptime and Load:
                     21:14:18 up 23 min,  1 user,  load average: 6.49, 3.85, 2.97
                    CPU threads: 4
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** Time and Time Zones ***
                                   Local time: Wed 2024-02-14 21:14:19 CET
                               Universal time: Wed 2024-02-14 20:14:19 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    *** User and Groups ***
                    pi
                    /home/pi
                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                    *** X-Server-Setup ***
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    Boot Target:    multi-user.target
                    *** MEMORY ***
                    Mem:            921M        514M        150M        0.0K        256M        347M
                    Swap:            99M         17M         82M
                    Total:          1.0G        532M        232M
                              921 M total memory
                              514 M used memory
                              141 M active memory
                              548 M inactive memory
                              150 M free memory
                               38 M buffer memory
                              218 M swap cache
                               99 M total swap
                               17 M used swap
                               82 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** FILESYSTEM ***
                    /dev/root      ext4       29G  3.6G   25G  13% /
                    devtmpfs       devtmpfs  333M     0  333M   0% /dev
                    tmpfs          tmpfs     461M     0  461M   0% /dev/shm
                    tmpfs          tmpfs     185M  940K  184M   1% /run
                    /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
                    tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
                    [Wed Feb 14 20:51:00 2024] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=6bc33173-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Wed Feb 14 20:51:04 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Wed Feb 14 20:51:04 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Wed Feb 14 20:51:09 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    TARGET  SOURCE         FSTYPE OPTIONS
                    /       /dev/mmcblk0p2 ext4   rw,noatime
                    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    1.3G    /var/
                    707M    /var/log
                    705M    /var/log/journal/21286045b254429896948513200b4631
                    377M    /var/cache
                    Archived and active journals take up 704.1M in the file system.
                    /opt/iobroker/backups:
                    38M     /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    99M     /opt/iobroker/iobroker-data/
                    46M     /opt/iobroker/iobroker-data/files
                    37M     /opt/iobroker/iobroker-data/backup-objects
                    31M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js
                    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
                    11M     /opt/iobroker/iobroker-data/objects.jsonl
                    8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
                    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                    4.7M    /opt/iobroker/iobroker-data/states.jsonl
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_383ea6098193eb1196abdcc77d11dc1e-if00-port0
                    /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A103R2XZ-if00-port0
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v18.19.0
                    /usr/bin/node           v18.19.0
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    /usr/bin/corepack       0.22.0
                    nodejs:
                      Installed: 18.19.0-1nodesource1
                      Candidate: 18.19.0-1nodesource1
                      Version table:
                     *** 18.19.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                         18.18.2-1nodesource1 1001
                         18.18.1-1nodesource1 1001
                         18.18.0-1nodesource1 1001
                         18.17.1-1nodesource1 1001
                         18.17.0-1nodesource1 1001
                         18.16.1-1nodesource1 1001
                         18.16.0-1nodesource1 1001
                         18.15.0-1nodesource1 1001
                         18.14.2-1nodesource1 1001
                         18.14.1-1nodesource1 1001
                         18.14.0-1nodesource1 1001
                         18.13.0-1nodesource1 1001
                         18.12.0-1nodesource1 1001
                         18.11.0-1nodesource1 1001
                         18.10.0-1nodesource1 1001
                         18.9.1-1nodesource1 1001
                         18.9.0-1nodesource1 1001
                         18.8.0-1nodesource1 1001
                         18.7.0-1nodesource1 1001
                         18.6.0-1nodesource1 1001
                         18.5.0-1nodesource1 1001
                         18.4.0-1nodesource1 1001
                         18.3.0-1nodesource1 1001
                         18.2.0-1nodesource1 1001
                         18.1.0-1nodesource1 1001
                         18.0.0-1nodesource1 1001
                    No problems detected
                    Errors in npm tree:
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Core adapters versions
                    js-controller:  5.0.17
                    admin:          6.13.16
                    javascript:     "javascript" not found
                    Adapters from github:   0
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                    + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                    + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
                    + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
                    + system.adapter.jeelink.0                : jeelink               : raspberrypi                              -  enabled
                    + system.adapter.loxone.0                 : loxone                : raspberrypi                              -  enabled, port: 80
                    + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
                    + system.adapter.plenticore.0             : plenticore            : raspberrypi                              -  enabled, port: 443
                    + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Installed ioBroker-Instances
                    Used repository: stable
                    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                    Adapter    "jeelink"      : 1.2.3    , installed 1.2.3
                    Controller "js-controller": 5.0.17   , installed 5.0.17
                    Adapter    "loxone"       : 3.0.1    , installed 3.0.1
                    Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                    Adapter    "node-red"     : 5.1.0    , installed 5.1.0
                    Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
                    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                    Objects and States
                    Objects:        2443
                    States:         1742
                    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       18352      2444/node-red
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18626      2382/iobroker.js-co
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18062      2382/iobroker.js-co
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1861       475/sshd: /usr/sbin
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18743      2400/io.admin.0
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          1863       475/sshd: /usr/sbin
                    udp        0      0 0.0.0.0:33645           0.0.0.0:*                           108        597        354/avahi-daemon: r
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12487      533/dhcpcd
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        595        354/avahi-daemon: r
                    udp6       0      0 :::45120                :::*                                108        598        354/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                108        596        354/avahi-daemon: r
                    2024-02-14 21:14:15.898  - info: plenticore.0 (2560) Configured Wp of panel(s) is 0
                    2024-02-14 21:14:15.911  - info: plenticore.0 (2560) [INFO] Configured polling interval: 20000
                    2024-02-14 21:14:16.778  - info: loxone.0 (2503) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.loxone, node: v18.19.0, js-controller: 5.0.17
                    2024-02-14 21:14:17.749  - info: backitup.0 (2525) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
                    2024-02-14 21:14:18.400  - info: smartmeter.0 (2491) Received 14 values, 14 updated
                    2024-02-14 21:14:18.608  - info: backitup.0 (2525) [iobroker] backup will be activated at 02:40 every 1 day(s)
                    2024-02-14 21:14:20.229  - info: loxone.0 (2503) Trying to connect
                    2024-02-14 21:14:22.354  - info: loxone.0 (2503) got structure file; last modified on 2024-02-12 17:02:50
                    2024-02-14 21:14:22.773  - info: plenticore.0 (2560) Not enabling forecast data.
                    2024-02-14 21:14:22.783  - info: plenticore.0 (2560) Not enabling MinSoC forecast data.
                    2024-02-14 21:14:29.736  - info: loxone.0 (2503) Unsupported device control CarCharger
                    2024-02-14 21:14:33.278  - info: loxone.0 (2503) Unsupported device control IRoomController
                    2024-02-14 21:14:35.286  - info: loxone.0 (2503) Unsupported device control IRoomController
                    2024-02-14 21:14:37.782  - info: loxone.0 (2503) Unsupported device control IRoomController
                    2024-02-14 21:14:46.993  - info: loxone.0 (2503) Unsupported device control LeftRightAnalog
                    2024-02-14 21:14:49.187  - info: loxone.0 (2503) Unsupported device control LeftRightAnalog
                    2024-02-14 21:14:49.674  - info: loxone.0 (2503) Unsupported device control LeftRightAnalog
                    2024-02-14 21:14:59.027  - info: loxone.0 (2503) Unsupported device control IRoomController
                    2024-02-14 21:15:00.877  - info: loxone.0 (2503) Unsupported device control IRoomController
                    2024-02-14 21:15:07.012  - info: loxone.0 (2503) Unsupported device control LeftRightAnalog
                    2024-02-14 21:15:09.131  - info: loxone.0 (2503) Unsupported device control EFM
                    2024-02-14 21:15:09.810  - info: loxone.0 (2503) Unsupported device control EnergyManager2
                    2024-02-14 21:15:29.582  - info: loxone.0 (2503) State value to set for "loxone.0.10998e53-004d-364a-ffff145cea42a008.sceneList" has to be stringified but received type "object"
                    2024-02-14 21:16:21.871  - info: smartmeter.0 (2491) Error: No or too long answer from Serial Device after last request.
                    2024-02-14 21:16:21.875  - warn: smartmeter.0 (2491) No or too long answer from Serial Device after last request.
                    und hier die Summary
                                            v.2023-10-10
                             Icon name: computer
                          Architecture: arm
                    Installation:           native
                    Kernel:                 armv7l
                    Userland:               armhf
                    Timezone:               Europe/Berlin (CET, +0100)
                    User-ID:                1000
                    X-Server:               false
                    Pending OS-Updates:     0
                    Pending iob updates:    0
                    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                            /usr/bin/npm            10.2.3
                                            /usr/bin/npx            10.2.3
                    Recommended versions are nodejs  and npm
                    MEMORY:
                    Mem:            921M        488M        135M        0.0K        298M        372M
                    Swap:            99M         65M         34M
                    Total:          1.0G        553M        169M
                    Active iob-Instances:   12
                    ioBroker Core:          js-controller           5.0.17
                                            admin                   6.13.16
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                2443
                    States:                 1742
                    Size of iob-Database:
                    12M     /opt/iobroker/iobroker-data/objects.jsonl
                    5.4M    /opt/iobroker/iobroker-data/states.jsonl
                    Fällt dir etwas "krummes" auf?
                    node.js scheint jetzt auf 18.19 zu sein.
                    wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
                    • wendy2702
                      wendy2702 @CoComp last edited by
                      @cocomp schau mal beim Smartmeter Adapter nach dem Pfad zum Lesekopf ob der noch passt.
                        CoComp @wendy2702 last edited by CoComp
                        @wendy2702
                        Merkwürdig, dass der Adapter eine Zeitlang auf "grün" steht, bevor er dann auf "gelb" wechselt.Smartmeteradapter.png
                        Ich habe den Raspi jetzt mal physisch neu gestartet - und er geht wieder auf gelb...
                        und das sagt das Protokoll:
                        smartmeter.0
                        2024-02-14 21:32:18.164	warn	No or too long answer from Serial Device after last request.
                        smartmeter.0
                        2024-02-14 21:32:18.162	info	Error: No or too long answer from Serial Device after last request.
                        smartmeter.0
                        2024-02-14 21:30:03.148	warn	No or too long answer from Serial Device after last request.
                        smartmeter.0
                        2024-02-14 21:30:03.140	info	Error: No or too long answer from Serial Device after last request.
                        smartmeter.0
                        2024-02-14 21:28:22.511	info	List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"383ea6098193eb1196abdcc77d11dc1e","pnpId":"usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_383ea6098193eb1196abdcc77d11dc1e-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB0","manufacturer":"FTDI","serialNumber":"A103R2XZ","pnpId":"usb-FTDI_FT232R_USB_UART_A103R2XZ-if00-port0","vendorId":"0403","productId":"6001"}]
                          @cocomp sagte in Upgrade einer vernachlässigten ioBroker Installation:
                          Nein, passt.
                            Zunächst mal 1000 Dank, nach einem physischen Neustart scheint alles zu laufen und auch der Smartmeteradapter tut, was er soll.
                            Soll ich an node.js nochmal ran? Läuft jetzt auf Version 18.19.0
                            Plattform: linux
                            Betriebssystem: linux
                            Architektur: arm
                            CPUs: 4
                            Geschwindigkeit: 900 MHz
                            Modell: ARMv7 Processor rev 5 (v7l)
                            RAM: 921.9 MB
                            System-Betriebszeit: 00:06:52
                            Node.js: v18.19.0
                            time: 1707944060753
                            timeOffset: -60
                            NPM: 10.2.3
                            Adapter-Anzahl: 531
                            Datenträgergröße: 29.0 GB
                            Freier Festplattenspeicher: 25.4 GB
                            Aktive Instanzen: 10
                            Pfad: /opt/iobroker/
                            Betriebszeit: 00:07:55
                            aktiv:
                              Thomas Braun Most Active @CoComp last edited by Thomas Braun
                              Warum? v18 ist genau richtig.
                              Halt die Kiste dann künftig egenständig aktuell. Im Sommer ist spätestens ein Wechsel auf 'Bookworm' erforderlich, besser aber jetzt schon mal in Angriff nehmen.
                                Ok, das bedeutet dann aber
                                1.) ioBroker und alle Adapter auf Stand bringen
                                2.) ioBroker Backup
                                3.) vollständige Neuinstallation anstatt Upgrade
                                4. ioBroker BackUp zurückspielen?
                                Thomas Braun da_Woody 2 Replies Last reply Reply Quote 0
                                • wendy2702
                                  @cocomp sagte in [Upgrade einer vernachlässigten ioBroker Installation](/post/1128870
                                  Also zweimal neu gestartet?
                                  Zunächst mal 1000 Dank, nach einem physischen Neustart scheint alles zu laufen und auch der Smartmeteradapter tut, was er soll..
                                    @cocomp
                                    Ja, im wesentlichen genau so.
                                    • da_Woody
                                      da_Woody @CoComp last edited by
                                      @cocomp Ruhe bewahren. Das kann schon mal ein zeiterl dauern.
                                      1.3k
                                      node.js16 update node js update upgrade iobroker
                                      1902
