    3. Einsteigerfragen
    4. Installation
    5. [gelöst] Upgrade einer vernachlässigten ioBroker Inst.
      CoComp @CoComp last edited by
      @cocomp
      So, scheint erfolgreich durchgelaufen zu sein. Nur der Smartmeter-Adapter steht auf gelb, weil er keine Verbindung zum Lesekopf zu haben scheint. War kurz auf grün und dann wieder auf gelb....
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v7+
            Architecture: arm
      Model           : Raspberry Pi 2 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       21:14:18 up 23 min,  1 user,  load average: 6.49, 3.85, 2.97
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Wed 2024-02-14 21:14:19 CET
                 Universal time: Wed 2024-02-14 20:14:19 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            921M        514M        150M        0.0K        256M        347M
      Swap:            99M         17M         82M
      Total:          1.0G        532M        232M
                921 M total memory
                514 M used memory
                141 M active memory
                548 M inactive memory
                150 M free memory
                 38 M buffer memory
                218 M swap cache
                 99 M total swap
                 17 M used swap
                 82 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G  3.6G   25G  13% /
      devtmpfs       devtmpfs  333M     0  333M   0% /dev
      tmpfs          tmpfs     461M     0  461M   0% /dev/shm
      tmpfs          tmpfs     185M  940K  184M   1% /run
      /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
      tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
      [Wed Feb 14 20:51:00 2024] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=6bc33173-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Wed Feb 14 20:51:04 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed Feb 14 20:51:04 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Wed Feb 14 20:51:09 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.3G    /var/
      707M    /var/log
      705M    /var/log/journal/21286045b254429896948513200b4631
      377M    /var/cache
      Archived and active journals take up 704.1M in the file system.
      /opt/iobroker/backups:
      38M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      99M     /opt/iobroker/iobroker-data/
      46M     /opt/iobroker/iobroker-data/files
      37M     /opt/iobroker/iobroker-data/backup-objects
      31M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js
      22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
      11M     /opt/iobroker/iobroker-data/objects.jsonl
      8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      4.7M    /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_383ea6098193eb1196abdcc77d11dc1e-if00-port0
      /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A103R2XZ-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.13.16
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.jeelink.0                : jeelink               : raspberrypi                              -  enabled
      + system.adapter.loxone.0                 : loxone                : raspberrypi                              -  enabled, port: 80
      + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.plenticore.0             : plenticore            : raspberrypi                              -  enabled, port: 443
      + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "jeelink"      : 1.2.3    , installed 1.2.3
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "loxone"       : 3.0.1    , installed 3.0.1
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "node-red"     : 5.1.0    , installed 5.1.0
      Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Objects and States
      Objects:        2443
      States:         1742
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       18352      2444/node-red
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18626      2382/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       18062      2382/iobroker.js-co
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1861       475/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18743      2400/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          1863       475/sshd: /usr/sbin
      udp        0      0 0.0.0.0:33645           0.0.0.0:*                           108        597        354/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12487      533/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        595        354/avahi-daemon: r
      udp6       0      0 :::45120                :::*                                108        598        354/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        596        354/avahi-daemon: r
      2024-02-14 21:14:15.898  - info: plenticore.0 (2560) Configured Wp of panel(s) is 0
      2024-02-14 21:14:15.911  - info: plenticore.0 (2560) [INFO] Configured polling interval: 20000
      2024-02-14 21:14:16.778  - info: loxone.0 (2503) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.loxone, node: v18.19.0, js-controller: 5.0.17
      2024-02-14 21:14:17.749  - info: backitup.0 (2525) starting. Version 2.9.8 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
      2024-02-14 21:14:18.400  - info: smartmeter.0 (2491) Received 14 values, 14 updated
      2024-02-14 21:14:18.608  - info: backitup.0 (2525) [iobroker] backup will be activated at 02:40 every 1 day(s)
      2024-02-14 21:14:20.229  - info: loxone.0 (2503) Trying to connect
      2024-02-14 21:14:22.354  - info: loxone.0 (2503) got structure file; last modified on 2024-02-12 17:02:50
      2024-02-14 21:14:22.773  - info: plenticore.0 (2560) Not enabling forecast data.
      2024-02-14 21:14:22.783  - info: plenticore.0 (2560) Not enabling MinSoC forecast data.
      2024-02-14 21:14:29.736  - info: loxone.0 (2503) Unsupported device control CarCharger
      2024-02-14 21:14:33.278  - info: loxone.0 (2503) Unsupported device control IRoomController
      2024-02-14 21:14:35.286  - info: loxone.0 (2503) Unsupported device control IRoomController
      2024-02-14 21:14:37.782  - info: loxone.0 (2503) Unsupported device control IRoomController
      2024-02-14 21:14:46.993  - info: loxone.0 (2503) Unsupported device control LeftRightAnalog
      2024-02-14 21:14:49.187  - info: loxone.0 (2503) Unsupported device control LeftRightAnalog
      2024-02-14 21:14:49.674  - info: loxone.0 (2503) Unsupported device control LeftRightAnalog
      2024-02-14 21:14:59.027  - info: loxone.0 (2503) Unsupported device control IRoomController
      2024-02-14 21:15:00.877  - info: loxone.0 (2503) Unsupported device control IRoomController
      2024-02-14 21:15:07.012  - info: loxone.0 (2503) Unsupported device control LeftRightAnalog
      2024-02-14 21:15:09.131  - info: loxone.0 (2503) Unsupported device control EFM
      2024-02-14 21:15:09.810  - info: loxone.0 (2503) Unsupported device control EnergyManager2
      2024-02-14 21:15:29.582  - info: loxone.0 (2503) State value to set for "loxone.0.10998e53-004d-364a-ffff145cea42a008.sceneList" has to be stringified but received type "object"
      2024-02-14 21:16:21.871  - info: smartmeter.0 (2491) Error: No or too long answer from Serial Device after last request.
      2024-02-14 21:16:21.875  - warn: smartmeter.0 (2491) No or too long answer from Serial Device after last request.
      und hier die Summary
                              v.2023-10-10
               Icon name: computer
            Architecture: arm
      Installation:           native
      Kernel:                 armv7l
      Userland:               armhf
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
      Recommended versions are nodejs  and npm
      MEMORY:
      Mem:            921M        488M        135M        0.0K        298M        372M
      Swap:            99M         65M         34M
      Total:          1.0G        553M        169M
      Active iob-Instances:   12
      ioBroker Core:          js-controller           5.0.17
                              admin                   6.13.16
      Objects type: jsonl
      States  type: jsonl
      Objects:                2443
      States:                 1742
      Size of iob-Database:
      12M     /opt/iobroker/iobroker-data/objects.jsonl
      5.4M    /opt/iobroker/iobroker-data/states.jsonl
      Fällt dir etwas "krummes" auf?
      node.js scheint jetzt auf 18.19 zu sein.
      wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
      • wendy2702
        wendy2702 @CoComp last edited by
        @cocomp schau mal beim Smartmeter Adapter nach dem Pfad zum Lesekopf ob der noch passt.
          CoComp @wendy2702 last edited by CoComp
          @wendy2702
          Merkwürdig, dass der Adapter eine Zeitlang auf "grün" steht, bevor er dann auf "gelb" wechselt.Smartmeteradapter.png
          Ich habe den Raspi jetzt mal physisch neu gestartet - und er geht wieder auf gelb...
          und das sagt das Protokoll:
          smartmeter.0
          2024-02-14 21:32:18.164	warn	No or too long answer from Serial Device after last request.
          smartmeter.0
          2024-02-14 21:32:18.162	info	Error: No or too long answer from Serial Device after last request.
          smartmeter.0
          2024-02-14 21:30:03.148	warn	No or too long answer from Serial Device after last request.
          smartmeter.0
          2024-02-14 21:30:03.140	info	Error: No or too long answer from Serial Device after last request.
          smartmeter.0
          2024-02-14 21:28:22.511	info	List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB1","manufacturer":"Silicon Labs","serialNumber":"383ea6098193eb1196abdcc77d11dc1e","pnpId":"usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_383ea6098193eb1196abdcc77d11dc1e-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyUSB0","manufacturer":"FTDI","serialNumber":"A103R2XZ","pnpId":"usb-FTDI_FT232R_USB_UART_A103R2XZ-if00-port0","vendorId":"0403","productId":"6001"}]
            Thomas Braun Most Active @CoComp last edited by
            @cocomp sagte in Upgrade einer vernachlässigten ioBroker Installation:
            Nein, passt.
              CoComp @Thomas Braun last edited by CoComp
              Zunächst mal 1000 Dank, nach einem physischen Neustart scheint alles zu laufen und auch der Smartmeteradapter tut, was er soll.
              Soll ich an node.js nochmal ran? Läuft jetzt auf Version 18.19.0
              Plattform: linux
              Betriebssystem: linux
              Architektur: arm
              CPUs: 4
              Geschwindigkeit: 900 MHz
              Modell: ARMv7 Processor rev 5 (v7l)
              RAM: 921.9 MB
              System-Betriebszeit: 00:06:52
              Node.js: v18.19.0
              time: 1707944060753
              timeOffset: -60
              NPM: 10.2.3
              Adapter-Anzahl: 531
              Datenträgergröße: 29.0 GB
              Freier Festplattenspeicher: 25.4 GB
              Aktive Instanzen: 10
              Pfad: /opt/iobroker/
              Betriebszeit: 00:07:55
              aktiv:
                Thomas Braun Most Active @CoComp last edited by Thomas Braun
                Warum? v18 ist genau richtig.
                Halt die Kiste dann künftig egenständig aktuell. Im Sommer ist spätestens ein Wechsel auf 'Bookworm' erforderlich, besser aber jetzt schon mal in Angriff nehmen.
                  Ok, das bedeutet dann aber
                  1.) ioBroker und alle Adapter auf Stand bringen
                  2.) ioBroker Backup
                  3.) vollständige Neuinstallation anstatt Upgrade
                  4. ioBroker BackUp zurückspielen?
                  Thomas Braun da_Woody 2 Replies Last reply Reply Quote 0
                  • wendy2702
                    @cocomp sagte in [Upgrade einer vernachlässigten ioBroker Installation](/post/1128870
                    Also zweimal neu gestartet?
                    Zunächst mal 1000 Dank, nach einem physischen Neustart scheint alles zu laufen und auch der Smartmeteradapter tut, was er soll..
                      @cocomp
                      Ja, im wesentlichen genau so.
                      • da_Woody
                        da_Woody @CoComp last edited by
                        @cocomp Ruhe bewahren. Das kann schon mal ein zeiterl dauern.
                        node.js16 update node js update upgrade iobroker
                        1202
