    4. ioBroker lässt RAM überlaufen und andere Phänomene
      AnneTheke @AnneTheke last edited by
      Hier das log vom letzten Start...
      2024-02-14 14:21:36.990 - info: host.HK01-MA iobroker.js-controller version 5.0.17 js-controller starting
      2024-02-14 14:21:36.992 - info: host.HK01-MA Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
      2024-02-14 14:21:36.993 - info: host.HK01-MA hostname: HK01-MA, node: v18.19.0
      2024-02-14 14:21:36.993 - info: host.HK01-MA ip addresses: fe80::e813:36d1:6136:d1a4 169.254.81.252 fe80::cee8:cf33:5c20:fb92 169.254.19.167 fe80::e556:8e21:6fc1:a33e 169.254.94.115 192.168.2.37 192.168.2.38 192.168.0.80 fe80::3ec8:d5d9:6bcf:acf3 169.254.94.3
      2024-02-14 14:21:37.203 - info: host.HK01-MA connected to Objects and States
      2024-02-14 14:21:37.210 - info: host.HK01-MA added notifications configuration of host
      2024-02-14 14:21:37.528 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.nodeCurrent"
      2024-02-14 14:21:37.528 - info: host.HK01-MA 6 instances found
      2024-02-14 14:21:37.532 - info: host.HK01-MA starting 6 instances
      2024-02-14 14:21:37.556 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.nodeNewest"
      2024-02-14 14:21:37.560 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.nodeNewestNext"
      2024-02-14 14:21:37.571 - info: host.HK01-MA instance system.adapter.admin.0 started with pid 7672
      2024-02-14 14:21:37.571 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.npmCurrent"
      2024-02-14 14:21:37.574 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.npmNewest"
      2024-02-14 14:21:37.576 - info: host.HK01-MA Delete state "system.host.HK01-MA.versions.npmNewestNext"
      2024-02-14 14:21:37.578 - info: host.HK01-MA Some obsolete host states deleted.
      2024-02-14 14:21:38.769 - error: admin.0 (7672) admin.0 already running
      2024-02-14 14:21:38.770 - warn: admin.0 (7672) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2024-02-14 14:21:39.330 - error: host.HK01-MA instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2024-02-14 14:21:39.330 - info: host.HK01-MA Restart adapter system.adapter.admin.0 because enabled
      2024-02-14 14:21:41.551 - info: host.HK01-MA instance system.adapter.s7.0 started with pid 7200
      2024-02-14 14:21:42.198 - error: s7.0 (7200) s7.0 already running
      2024-02-14 14:21:42.199 - warn: s7.0 (7200) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2024-02-14 14:21:42.717 - error: host.HK01-MA instance system.adapter.s7.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2024-02-14 14:21:42.717 - info: host.HK01-MA Restart adapter system.adapter.s7.0 because enabled
      2024-02-14 14:21:45.550 - info: host.HK01-MA instance system.adapter.s7.1 started with pid 8324
      2024-02-14 14:21:46.265 - error: s7.1 (8324) s7.1 already running
      2024-02-14 14:21:46.267 - warn: s7.1 (8324) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2024-02-14 14:21:46.798 - error: host.HK01-MA instance system.adapter.s7.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2024-02-14 14:21:46.799 - info: host.HK01-MA Restart adapter system.adapter.s7.1 because enabled
      2024-02-14 14:21:49.571 - info: host.HK01-MA instance system.adapter.discovery.0 started with pid 8888
      2024-02-14 14:21:50.323 - error: discovery.0 (8888) discovery.0 already running
      2024-02-14 14:21:50.324 - warn: discovery.0 (8888) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2024-02-14 14:21:50.853 - error: host.HK01-MA instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2024-02-14 14:21:50.853 - info: host.HK01-MA Restart adapter system.adapter.discovery.0 because enabled
      2024-02-14 14:21:53.556 - info: host.HK01-MA instance system.adapter.backitup.0 started with pid 9124
      2024-02-14 14:21:54.217 - error: backitup.0 (9124) backitup.0 already running
      2024-02-14 14:21:54.218 - warn: backitup.0 (9124) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2024-02-14 14:21:54.744 - error: host.HK01-MA instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2024-02-14 14:21:54.744 - info: host.HK01-MA Restart adapter system.adapter.backitup.0 because enabled
      2024-02-14 14:21:57.550 - info: host.HK01-MA instance system.adapter.yahka.0 started with pid 8424
      2024-02-14 14:21:58.665 - error: yahka.0 (8424) yahka.0 already running
      2024-02-14 14:21:58.666 - warn: yahka.0 (8424) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2024-02-14 14:21:59.196 - error: host.HK01-MA instance system.adapter.yahka.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2024-02-14 14:21:59.196 - info: host.HK01-MA Restart adapter system.adapter.yahka.0 because enabled
      2024-02-14 14:22:09.348 - info: host.HK01-MA instance system.adapter.admin.0 started with pid 6272
      2024-02-14 14:22:10.413 - info: admin.0 (6272) starting. Version 6.13.16 in C:/ioBroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
      2024-02-14 14:22:10.430 - info: admin.0 (6272) requesting all objects
      2024-02-14 14:22:10.657 - info: admin.0 (6272) received all objects
      2024-02-14 14:22:10.724 - info: admin.0 (6272) socket.io server listening on port 8081
      2024-02-14 14:22:10.725 - info: admin.0 (6272) http server listening on port 8081
      2024-02-14 14:22:10.725 - info: admin.0 (6272) Use link "http://127.0.0.1:8081" to configure.
      2024-02-14 14:22:12.738 - info: host.HK01-MA instance system.adapter.s7.0 started with pid 3108
      2024-02-14 14:22:13.573 - info: s7.0 (3108) starting. Version 1.4.2 in C:/ioBroker/node_modules/iobroker.s7, node: v18.19.0, js-controller: 5.0.17
      2024-02-14 14:22:13.607 - info: s7.0 (3108) Connect in S7 mode to 0 / 2
      2024-02-14 14:22:13.619 - info: s7.0 (3108) Successfully connected in S7 mode
      2024-02-14 14:22:16.817 - info: host.HK01-MA instance system.adapter.s7.1 started with pid 6132
      2024-02-14 14:22:17.677 - info: s7.1 (6132) starting. Version 1.4.2 in C:/ioBroker/node_modules/iobroker.s7, node: v18.19.0, js-controller: 5.0.17
      2024-02-14 14:22:17.707 - info: s7.1 (6132) Connect in S7 mode to 0 / 2
      2024-02-14 14:22:17.720 - info: s7.1 (6132) Successfully connected in S7 mode
      2024-02-14 14:22:20.876 - info: host.HK01-MA instance system.adapter.discovery.0 started with pid 8124
      2024-02-14 14:22:21.620 - info: discovery.0 (8124) starting. Version 4.2.0 in C:/ioBroker/node_modules/iobroker.discovery, node: v18.19.0, js-controller: 5.0.17
      2024-02-14 14:22:24.768 - info: host.HK01-MA instance system.adapter.backitup.0 started with pid 6556
      2024-02-14 14:22:25.567 - info: backitup.0 (6556) starting. Version 2.9.8 in C:/ioBroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 5.0.17
      2024-02-14 14:22:25.596 - info: backitup.0 (6556) [iobroker] backup will be activated at 02:48 every 1 day(s)
      2024-02-14 14:22:29.222 - info: host.HK01-MA instance system.adapter.yahka.0 started with pid 1848
      2024-02-14 14:22:30.045 - info: yahka.0 (1848) starting. Version 1.0.3 in C:/ioBroker/node_modules/iobroker.yahka, node: v18.19.0, js-controller: 5.0.17
      2024-02-14 14:22:30.060 - info: yahka.0 (1848) adapter ready, checking config
      2024-02-14 14:22:30.064 - info: yahka.0 (1848) publishing bridge Yahka-0 on 0.0.0.0 using avahi
      2024-02-14 14:57:25.412 - info: admin.0 (6272) ==> Connected system.user.admin from ::ffff:127.0.0.1
        AnneTheke @OliverIO last edited by
        @oliverio
        So, es funktioniert wieder. Falls jemand das Problem mal haben sollte, Antiviren-Software kann komische Sachen machen. Was auch immer beim Automatischen Update dieser passiert, es war nicht gut für ioBroker.
        @Homoran
        Thema kann dann geschlossen werden, die Kiste läuft seit mehreren Stunden auf der alten Instanz und fehlerfrei.
        Danke für die Hilfe an alle!
        W OliverIO R 3 Replies Last reply Reply Quote 0
          Wildbill @AnneTheke last edited by
          @annetheke Was sagt uns das? Antivirensoftware gehört heutzutage auch nicht mehr separat installiert. Die in den Systemen integrierten (bei Dir der Windows Defender“ sind ausreichend. Jede zusätzlich installierte Antivirensoftware muss, um zu funktionieren, Löcher in diese Schutzschicht reißen. Die einzigen, die heutzutage noch von Antivirensoftware profitieren sind deren Hersteller.
          Die integrierten Systeme und etwas überlegtes Handeln (nicht alles anklicken, nicht überall alles was kostenlos ist udn woanders Geld kostet herunterladen, …) sind mehr als ausreichend.
          BTW, welche Antivirensoftware war es denn bei Dir?
          Gruss, Jürgen
          • OliverIO
            OliverIO @AnneTheke last edited by
            @annetheke
            Also war doch etwas anders und nicht exakt der gleiche Zustand wieder hergestellt.
              @oliverio Doch, es wurde exakt der gleiche Zustand wiederhergestellt, allerdings war der Zustand eben nicht von Dauer, da die Software nunmal selbstständig ihr Update macht.
              @Wildbill Ja, das habe ich dann jetzt auch wieder gemerkt... Avira Antivir war schuld. Kaum deinstalliert, läuft die Kiste wieder einwandfrei.
              • OliverIO
                OliverIO @AnneTheke last edited by OliverIO
                @annetheke sagte in ioBroker lässt RAM überlaufen und andere Phänomene:
                Auf der Maschine wird kein Update gefahren ohne es vorher zu testen und nach 3 Jahren problemlosen Betrieb glaube ich nicht, dass Windows da wirklich das Problem ist...
                aber ich will da nicht wirklich darauf rumreiten.
                schön das du den fehler gefunden hast
                • Negalein
                  Negalein Global Moderator @AnneTheke last edited by
                  Avira Antivir
                  womöglich sogar die werbeverseuchte Gratisversion?
                  Wenn schon Antivirus (oder besser Internet Security), dann besser zB Bitdefender.
                  Aber Avira ist einfach der letzte Müll.
                    @oliverio said in ioBroker lässt RAM überlaufen und andere Phänomene:
                    Windowsupdate... Dass die Antivirensoftware selbst ein Update macht, was ich nicht beeinflussen kann, war das letzte, an was ich dachte... Und nach 3 Jahren Dauerbetrieb denkt man da auch nicht mehr wirklich dran, da die Updates von Microsoft eher mal ein Problem sind.
                      @negalein said in ioBroker lässt RAM überlaufen und andere Phänomene:
                      Avira Antivir
                      Ja das musste ich dann leider auch wieder feststellen... Dann lasse ich besser von Acronis das mitgelieferte ActiveProtect mitlaufen. Acronis ist ja mittlerweile eine Security-Software, die nebenbei noch Backups erstellen kann.
                      OliverIO 1 Reply Last reply Reply Quote 1
                      • OliverIO
                        @annetheke
                        man sagt der in windows eingebaute defender reicht vollkommen aus
                        https://www.heise.de/download/specials/Virenschutz-Antivirus-Programme-im-Vergleich-5061832#:~:text=Allerdings handelt es,Alltag umsichtig handeln.
                        Negalein 1 Reply Last reply Reply Quote 2
                        • Negalein
                          Negalein Global Moderator @OliverIO last edited by
                          @oliverio sagte in ioBroker lässt RAM überlaufen und andere Phänomene:
                          das stimmt.
                          Kommt darauf an, was man noch möchte/braucht.
                          Ich zB verwende Bitdefender. Hauptgrund ist bei mir aber die Android-App, auf Windows der sehr gute Spam-Schutz, Diebstahlsicherung, ...!
                            Roland 1 @AnneTheke last edited by
                            @annetheke Auch bei meinem Windows 10 Pro HP Notebook ist das 8GB RAM innerhalb von ca. 15 Std. von 60% auf 100% vollgelaufen. Es lief der ioBroker, eine Handvoll Adapterinstanzen und die Influxdb. Als Browser nutze ich Firefox.
                            Nach der DEINSTALLATION VON AVIRA FREE ANTIVIRUS war das Problem behoben, der RAM-Bedarf blieb wieder unten bei 60%. An dieser Stelle: Danke für Deinen Erfahrungsbericht, ohne den ich wahrscheinlich Windows und den ioBroker neu installiert hätte und das mit fraglichem Erfolg.
                            Ich kann nicht sagen, welche Änderung am System den RAM-Überlauf verursacht hat: das Aktualisieren einiger Adapter oder des js-controllers von ? auf 5.0.19 oder eben eher ein automatisches Avira Antivirus Update.
                            Viele Grüße, Roland
                            693
