    4. Smartmeter: D0 Einstellungen ?
      Thomas Braun Most Active @MathiasL last edited by
      @mathiasl sagte in Smartmeter: D0 Einstellungen ?:
      buster
      Aber auch diese Zusammfassung zeigt, dass du da ein totes Pferd reitest.
      Absteigen...
      Neuinstallatioin von Raspberry OS 12 'Bookworm' in der 64 Bit-Lite-Version.
        MathiasL @Homoran last edited by Homoran
        @Homoran
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspi-IOB
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.103-v7l+
              Architecture: arm
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
         22:07:40 up 30 min,  1 user,  load average: 0.15, 0.55, 0.37
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Thu 2024-02-15 22:07:40 CET
                   Universal time: Thu 2024-02-15 21:07:40 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           3.8G        614M        2.7G        8.0M        543M        3.1G
        Swap:           99M          0B         99M
        Total:         3.9G        614M        2.8G
                 3838 M total memory
                  614 M used memory
                  282 M active memory
                  778 M inactive memory
                 2680 M free memory
                   87 M buffer memory
                  456 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4       15G  8.6G  5.2G  63% /
        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     1.9G  8.5M  1.9G   1% /run
        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
        [Thu Feb 15 21:36:45 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:8D:7F:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=400f6d20-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Thu Feb 15 21:36:46 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Thu Feb 15 21:36:46 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Thu Feb 15 21:36:48 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        TARGET        SOURCE         FSTYPE OPTIONS
        /             /dev/mmcblk0p2 ext4   rw,noatime
        |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.1G    /var/
        832M    /var/cache
        827M    /var/cache/apt
        767M    /var/cache/apt/archives
        93M     /var/lib
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        63M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        697M    /opt/iobroker/iobroker-data/
        541M    /opt/iobroker/iobroker-data/files
        162M    /opt/iobroker/iobroker-data/files/vis-2
        120M    /opt/iobroker/iobroker-data/backup-objects
        78M     /opt/iobroker/iobroker-data/files/vis-2/static
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        24M     /opt/iobroker/iobroker-data/objects.jsonl
        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
        20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.34d14c04.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0081-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.1-1nodesource1
          Version table:
             18.19.1-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         *** 18.19.0-1nodesource1 1001
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.13.16
        javascript:     7.8.0
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspi-IOB                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.awtrix-light.0           : awtrix-light          : raspi-IOB                                -  enabled
          system.adapter.backitup.0               : backitup              : raspi-IOB                                - disabled
          system.adapter.daswetter.0              : daswetter             : raspi-IOB                                -  enabled
          system.adapter.device-reminder.0        : device-reminder       : raspi-IOB                                - disabled
          system.adapter.devices.0                : devices               : raspi-IOB                                -  enabled
        + system.adapter.discovery.0              : discovery             : raspi-IOB                                -  enabled
          system.adapter.dwd.0                    : dwd                   : raspi-IOB                                - disabled
          system.adapter.ekey.0                   : ekey                  : raspi-IOB                                - disabled, port: 56000, bind: 0.0.0.0
          system.adapter.feiertage.0              : feiertage             : raspi-IOB                                -  enabled
        + system.adapter.fritzbox.0               : fritzbox              : raspi-IOB                                -  enabled
          system.adapter.fullybrowser.0           : fullybrowser          : raspi-IOB                                - disabled
          system.adapter.ical.0                   : ical                  : raspi-IOB                                -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspi-IOB                                -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspi-IOB                                -  enabled
        + system.adapter.javascript.0             : javascript            : raspi-IOB                                -  enabled
          system.adapter.knx.0                    : knx                   : raspi-IOB                                - disabled, bind: 192.168.0.205
          system.adapter.modbus.0                 : modbus                : raspi-IOB                                - disabled
          system.adapter.net-tools.0              : net-tools             : raspi-IOB                                - disabled
          system.adapter.openknx.0                : openknx               : raspi-IOB                                - disabled
        + system.adapter.rpi2.0                   : rpi2                  : raspi-IOB                                -  enabled
          system.adapter.sayit.0                  : sayit                 : raspi-IOB                                - disabled
        + system.adapter.smartmeter.0             : smartmeter            : raspi-IOB                                -  enabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : raspi-IOB                                -  enabled
        + system.adapter.telegram.0               : telegram              : raspi-IOB                                -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.terminal.0               : terminal              : raspi-IOB                                - disabled, port: 8088, bind: 192.168.0.205, run as: admin
          system.adapter.time-switch.0            : time-switch           : raspi-IOB                                - disabled
        + system.adapter.trashschedule.0          : trashschedule         : raspi-IOB                                -  enabled
        + system.adapter.vis-2.0                  : vis-2                 : raspi-IOB                                -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspi-IOB                                -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi-IOB                                -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspi-IOB                                -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspi-IOB                                -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspi-IOB                                -  enabled
          system.adapter.vis-material.0           : vis-material          : raspi-IOB                                -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspi-IOB                                -  enabled
          system.adapter.vis-metro.0              : vis-metro             : raspi-IOB                                -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi-IOB                                -  enabled
          system.adapter.vis-weather.0            : vis-weather           : raspi-IOB                                -  enabled
          system.adapter.vis.0                    : vis                   : raspi-IOB                                -  enabled
        + system.adapter.web.0                    : web                   : raspi-IOB                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.worx.0                   : worx                  : raspi-IOB                                - disabled
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Ulanzi Uhr BETA: https://github.com/klein0r/ioBroker.awtrix-light.git
        Active repo(s): Stable (default)
        Installed ioBroker-Instances
        Used repository: Stable (default)
        Adapter    "awtrix-light" : 0.13.1   , installed 0.13.1
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "ekey"         : 1.2.3    , installed 1.2.3
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
        Adapter    "fullcalendar" : 2.3.4    , installed 2.3.4
        Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
        Adapter    "ical"         : 1.13.3   , installed 1.13.5
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "knx"          : 2.0.24   , installed 2.0.24
        Adapter    "modbus"       : 6.1.0    , installed 6.1.0
        Adapter    "openknx"      : 0.6.3    , installed 0.7.0
        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
        Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "worx"         : 2.3.4    , installed 2.3.4
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Objects and States
        Objects:        4710
        States:         4186
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 12
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17523      568/sshd
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16942      573/iobroker.js-con
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        16048      569/redis-server 12
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16202      594/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19679      856/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          17525      568/sshd
        tcp6       0      0 ::1:6379                :::*                    LISTEN      109        16049      569/redis-server 12
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14945      561/dhcpcd
        udp        0      0 0.0.0.0:32931           0.0.0.0:*                           108        14812      389/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14810      389/avahi-daemon: r
        udp6       0      0 :::53256                :::*                                108        14813      389/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        14811      389/avahi-daemon: r
        2024-02-15 22:00:06.928  - info: ical.0 (1826) starting. Version 1.13.5 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
        2024-02-15 22:00:07.704  - info: ical.0 (1826) processing URL: Abfuhrkalender.ics http://cloud.msl-data.de/
        2024-02-15 22:00:07.948  - info: daswetter.0 (1811) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2024-02-15 22:00:08.468  - info: daswetter.0 (1811) cleaned everything up...
        2024-02-15 22:00:08.485  - info: host.raspi-IOB instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-02-15 22:00:10.013  - info: ical.0 (1826) processing URL: Abfuhrkalender.ics https://46.128.125.220/nas/filelink.lua?id=31b695d5fa878f05
        2024-02-15 22:00:15.157  - info: ical.0 (1826) Terminated (NO_ERROR): Without reason
        2024-02-15 22:00:15.706  - info: host.raspi-IOB instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2024-02-15 22:01:25.311  - debug: smartmeter.0 (1499) MESSAGE TIMEOUT TRIGGERED
        2024-02-15 22:01:25.312  - debug: smartmeter.0 (1499) Error: No or too long answer from Serial Device after last request.
        2024-02-15 22:01:25.312  - warn: smartmeter.0 (1499) No or too long answer from Serial Device after last request.
        2024-02-15 22:01:25.313  - debug: smartmeter.0 (1499) Error: No or too long answer from Serial Device after last request.
        2024-02-15 22:01:25.313  - debug: smartmeter.0 (1499) Transport Reset!! Restart = true
        2024-02-15 22:01:25.319  - debug: smartmeter.0 (1499) SERIALPORT CLOSE
        2024-02-15 22:01:25.320  - debug: smartmeter.0 (1499) SCHEDULE NEXT RUN IN 300s
        2024-02-15 22:06:25.320  - debug: smartmeter.0 (1499) CREATE SERIALPORT: 9600 8 1 none
        2024-02-15 22:06:25.327  - debug: smartmeter.0 (1499) SERIALPORT OPEN
        2024-02-15 22:06:25.329  - debug: smartmeter.0 (1499) SET MESSAGE TIMEOUT TIMER: 120000
        2024-02-15 22:08:25.329  - debug: smartmeter.0 (1499) MESSAGE TIMEOUT TRIGGERED
        2024-02-15 22:08:25.330  - debug: smartmeter.0 (1499) Error: No or too long answer from Serial Device after last request.
        2024-02-15 22:08:25.331  - warn: smartmeter.0 (1499) No or too long answer from Serial Device after last request.
        2024-02-15 22:08:25.332  - debug: smartmeter.0 (1499) Error: No or too long answer from Serial Device after last request.
        2024-02-15 22:08:25.333  - debug: smartmeter.0 (1499) Transport Reset!! Restart = true
        2024-02-15 22:08:25.348  - debug: smartmeter.0 (1499) SERIALPORT CLOSE
        2024-02-15 22:08:25.348  - debug: smartmeter.0 (1499) SCHEDULE NEXT RUN IN 300s
          MathiasL @Thomas Braun last edited by
          Ist eben noch die Testumgebung
          Davon abgesehen habe ich als Nicht-Linux-Mensch so meine Probleme:
          Ich müsste jetzt ein Backup vom IOB machen und auf der neuen OS einspielen, davor drück ich mich gerade noch...
            Und wie sinnvoll sind Test in einer veralteten, abgekündigten Umgebung?
            Und genau DAS solltest du als erstes tun. Auf einer stabilen Basis kannste dann weiter testen...
              Das sollte dann eigentlich keine Testumgebung mehr werden.
              Ich denke auch nicht, dass das was daran ändert, warum ich keine Daten vom Zähler bekomme.
                Das spielt aber auch keine Rolle...
                  Ich bin ja gerade dabei ein Image zu schreiben 😉
                  Muss halt nur die ganzen Daten vom IOB aufs neue Image bringen (...und da ich kaum Linux kann, stellt mich das vor einige Probleme)
                    Mit dem Backitup-Adapter. Linuxisch muss man dafür auch nicht können.
                    M 3 Replies Last reply Reply Quote 0
                      OK. Arbeite mich gerade durch Deine Upgrade-Anleitung
                        Keine Angst, ich mache eine komplette Neuinstallation, dient nur dem Lernen von Linux
                          @mathiasl
                          Hab ich was von dist-upgrade geschrieben?
                          Du musst das NEU installieren.
                            Ja, mach ich doch auch. Das wird ein komplett neues Image.
                            Ist trotzdem lehrreich, das Vorgehen zu einem Upgrade durchzulesen
                              ...Der übrigens nicht richtig funktioniert.
                                Natürlich nicht. Ein Dist-Upgrade auf Raspbian 12 von Vorversionen aus funktioniert bekanntermaßen nicht, weswegen ich dir auch gleich zu einer Neuinstallation geraten habe...
                                  Wenn du gelesen hättest, wüsstest Du, dass ich mir das Dist-Upgrade-Verfahre aus reinem Interesse durchgelesen habe, um Hintergrundabläufe unter Linux zu verstehen (Befehle, Repos einbinden, usw).
                                  Ich habe sehr wohl eine Neuinstallation gemacht.
                                  Leider ist 'Backitup' trotzdem fehlerhaft und unvollständig... Und eine Rücksicherung bis dato unmöglich...
                                  Thomas Braun wendy2702 2 Replies Last reply Reply Quote 0
                                    Hab ich.
                                    Muss aber an dir liegen, hier funktioniert das nämlich.
                                    • wendy2702
                                      wendy2702 @MathiasL last edited by
                                      @mathiasl was funktioniert denn nicht bei der Rücksicherung?
                                      Wenn du die alte SD Karte oder was auch immer noch hast kannst du ja auch mal ein Backup ohne Adapter machen und versuchen das wieder herzustellen.
                                        So Fehler wie: Weisser Text auf weissem Grund liegen also an mir? Sowohl im Firefox als auch im Opera kann das Problem auftreten, das man keine Texte mehr sieht.
                                        • Update mit ssh war bisher nicht möglich, da das Zertifikat ungültig ist
                                        • Update ohne ssh geht soweit, das man die Datei direkt runterladen kann, beim raufladen werden aber vom IOB Sachen zerschossen, hier teste ich aber noch.
                                        Das gehört aber eigentlich alles nicht hier her. Es ging ja um die Einbindung des Smartmeter
                                        Thomas Braun wendy2702 Homoran 3 Replies Last reply Reply Quote 0
                                          Nee, deine offenbar hinten und vorne verfummelte Kiste gehört hier nicht hin.
                                          • wendy2702
                                            @mathiasl wo steht denn was von weißem Text auf weißem Grund?
                                            Und was wird wie beim Kopieren zerschossen?
                                            Aber wie du selber schon geschrieben hast dafür besser ein neues Thema aufmachen und dann am besten mit Logausgaben zeigen was du machst und was dann nicht funktioniert
                                            5651
