    4. Heizöl24 - MEX
    Heizöl24 - MEX
    • spicer
      spicer last edited by spicer
      @gjo editiere Zeile 95 nach:
      client = mqtt.Client("MEX")
      Ich vermute, dass Du mqtt Version < 2.0 hast.
      Werde das beim nächsten Update abfangen.
        gjo @spicer last edited by
        @spicer
        das war auch meine Vermutung.
        heidenei ... nach:
        root@DietPi:/home/script# pip install paho-mqtt --upgrade
        Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple/
        Requirement already satisfied: paho-mqtt in /usr/local/lib/python3.7/dist-packages (1.6.1)
        Collecting paho-mqtt
         Downloading https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-2.0.0-py3-none-any.whl (66 kB)
            ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 66.9/66.9 kB 746.1 kB/s eta 0:00:00
        Installing collected packages: paho-mqtt
         Attempting uninstall: paho-mqtt
           Found existing installation: paho-mqtt 1.6.1
           Uninstalling paho-mqtt-1.6.1:
             Successfully uninstalled paho-mqtt-1.6.1
        Successfully installed paho-mqtt-2.0.0
        WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
        [notice] A new release of pip is available: 23.3.2 -> 24.0
        [notice] To update, run: python3 -m pip install --upgrade pip
        kommt jetzt:
        root@DietPi:/home/script# python3 /home/script/mex.py
        Traceback (most recent call last):
          File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 49, in <module>
            from typing import Literal
        ImportError: cannot import name 'Literal' from 'typing' (/usr/lib/python3.7/typing.py)
        During handling of the above exception, another exception occurred:
          File "/home/script/mex.py", line 38, in <module>
            import paho.mqtt.client as mqtt
          File "/usr/local/lib/python3.7/dist-packages/paho/mqtt/client.py", line 51, in <module>
            from typing_extensions import Literal  # type: ignore
        ModuleNotFoundError: No module named 'typing_extensions'
        also via:
        root@DietPi:/home/script# pip install typing-extensions
        Collecting typing-extensions
          Downloading https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.whl (33 kB)
        Installing collected packages: typing-extensions
        Successfully installed typing-extensions-4.7.1
        nachinstalliert. dann mit folgendem Ergebnis:
        /home/script/mex.py:95: DeprecationWarning: Callback API version 1 is deprecated, update to latest version
          client = mqtt.Client(mqtt.CallbackAPIVersion.VERSION1, "MEX")
        spicer 1 Reply Last reply Reply Quote 0
        • spicer
          spicer @gjo last edited by spicer
          @gjo
          Diese Warnung ist ok. Die hab ich auch. Sollte eigentlich funktionieren so.
          Funktioniert's denn?
          Frage: Bist Du als root unterwegs, nicht als pi?
          Edit:
          Warnung ist nun weg. Code nutzt nun aktuelle Parameter 😉
            @spicer
            die Daten kommen an ... wie cool. Danke nochmal.
            ja, auf dem Testsystem hatte ich s mir einfacher gemacht.
            • spicer
              V1.2 auf github
              • DataReceived Punkt hinzugefügt
              • paho-mqtt Versionsabfrage
                Thomas Braun Most Active @gjo last edited by Thomas Braun
                @gjo sagte in Heizöl24 - MEX:
                Das ist aber auch nur vermeintlich einfacher.
                In der Realität ist es nämlich aufwändiger die Rechte richtig zu halten.
                Und deswegen gilt halt: NIE root.
                Die Meldung:
                steht nämlich da auch nicht zum Spaß.
                • spicer
                  spicer @Thomas Braun last edited by
                  @thomas-braun sagte in Heizöl24 - MEX:
                  Die Meldung:
                  Jep. Dachte ich mir auch, dass das wegen dem root so ist 😉
                  • spicer
                    V1.3 auch auf github.
                    mex.py
                    #!/usr/bin/python3
                    ###################################             V1.3               ###################
                    ################################### MEX-Daten in ioBroker einlesen ###################
                    ###################################    Benötigt den MQTT Adapter   ###################
                    ###################################    (C) 2024 Daniel Luginbühl   ###################
                    ######################################### WICHTIGE INFOS #############################
                    ################## Im ioBroker ist der MQTT Broker/Client Adapter zu installieren   ##
                    ################## Einstellungen:                                                   ##
                    ##################    IP: Server/Broker                                             ##
                    ##################    Authentifizierungseinstellungen: Benutzer/Passwort definieren ##
                    ##################                  Alles als User PI ausführen!                    ##
                    ################## mex.py Script auf Rechte 754 setzen mit:                         ##
                    ################## chmod 754 mex.py                                                 ##
                    ################## Dieses Script per Cronjob alle 2 bis 4 Stunden ausführen:        ##
                    ################## crontab -e                                                       ##
                    ################## 0 */3 * * * /home/pi/mex.py          # Pfad ggf anpassen!        ##
                    ################## Vorgängig zu installieren (auf Host, wo dieses Script läuft):    ##
                    ##################    sudo apt install python3-requests                             ##
                    ##################    pip3 install paho-mqtt                                        ##
                    ##################    pip3 install typing-extensions                                ##
                    ################################### Hier Einträge anpassen! ##########################
                    username = "AAAAA@gmail.com"    # Deine Email Adresse bei HeizOel24
                    passwort = "BBBBBBBBB"          # Dein Passwort bei HeizOel24
                    broker_address = "192.168.1.50" # ioBroker IP, auf welchem der MQTT (Server) Adapter läuft
                    mqtt_user = "uuuuuu"            # ioBroker MQTT User     (in Authentifizierungseinstellungen definiert)
                    mqtt_pass = "pppppp"            # ioBroker MQTT Passwort (in Authentifizierungseinstellungen definiert)
                    debug = False                   # True = Debug Infos auf die Konsole
                    import requests
                    import time
                    import json
                    def mqtt_send(client, topic, wert):
                        client.publish("MEX/" + topic, wert)
                    def login():
                        if debug:
                            print('Login in...')
                        global session_id
                        url = "https://api.heizoel24.de/app/api/app/Login"
                        newHeaders = {'Content-type': 'application/json'}
                        reply = requests.post(url, json = { "Password" : passwort, "Username" : username}, headers=newHeaders)
                        return_flag = False
                        if reply.status_code == 200:
                            if debug:
                                print("Login OK")
                            reply_json = json.loads(reply.text)
                            if reply_json['ResultCode'] == 0:
                                session_id = reply_json['SessionId']
                                if debug:
                                    print('Session ID: ' + session_id)
                                return_flag = True
                            else:
                                if debug:
                                    print('ResultCode nicht 0. Keine Session ID erhalten!')
                        else:
                            if debug:
                                print('Login fehlgeschlagen! Heizoel24 Login Status Code: ' + str(reply.status_code))
                        return return_flag
                    def mex():
                        login_status = login()
                        if login_status == False:
                            return "error"
                        if debug:
                            print('Refresh sensor data cache...')
                        url = 'https://api.heizoel24.de/app/api/app/GetDashboardData/'+ session_id + '/1/1/False'
                        reply = requests.get(url)
                            if debug:
                                print("Daten wurden empfangen")
                            sensor_data = reply
                        else:
                            if debug:
                                print('Heizoel24 GetDashboardData Status Code: ' + str(reply.status_code))
                            sensor_data = "error"   # Fehler. Keine Daten empfangen.
                        return sensor_data
                    def main():
                        topic1 = ['SensorId', 'IsMain', 'CurrentVolumePercentage', 'CurrentVolume', 'NotifyAtLowLevel', 'NotifyAtAlmostEmptyLevel', 'NotificationsEnabled', 'Usage', 'RemainsUntil', 'MaxVolume', 'ZipCode', 'MexName', 'LastMeasurementTimeStamp', 'LastMeasurementWithDifferentValue', 'BatteryPercentage', 'Battery', 'LitresPerCentimeter', 'LastMeasurementWasSuccessfully', 'SensorTypeId', 'HasMeasurements', 'MeasuredDaysCount', 'LastMeasurementWasTooHigh', 'YearlyOilUsage', 'RemainingDays', 'LastOrderPrice', 'ResultCode', 'ResultMessage']
                        topic2 = ['LastOrderPrice', 'PriceComparedToYesterdayPercentage', 'PriceForecastPercentage', 'HasMultipleMexDevices', 'DashboardViewMode', 'ShowComparedToYesterday', 'ShowForecast', 'ResultCode', 'ResultMessage']
                        RemainsUntilCombined = ['MonthAndYear', 'RemainsValue', 'RemainsUnit']
                        try:
                            client = mqtt.Client("mex")
                            if debug:
                                print("paho-mqtt version < 2.0")
                        except:
                            client = mqtt.Client(mqtt.CallbackAPIVersion.VERSION2, "mex")
                            if debug:
                                print("paho-mqtt version >= 2.0")
                        if debug:
                            print("---------------------")
                            print("client:", client)
                        client.username_pw_set(mqtt_user, mqtt_pass)
                        client.connect(broker_address)
                        daten = mex()
                        if daten == "error":
                            if debug:
                                print("Fehler. Keine Daten empfangen.")
                            mqtt_send(client, "Items/DataReceived", False)
                            client.disconnect()
                            return
                        daten = daten.json()
                        if debug:
                            print()
                            print("JSON-Daten:")
                            print("===========")
                            print()
                            print(daten)
                            print()
                        if debug:
                            print()
                        for n in range(len(topic2)):
                            if debug:
                                print(topic2[n] + ":", daten[topic2[n]])
                            mqtt_send(client, "PricingForecast/" + topic2[n], daten[topic2[n]])
                        daten = daten["Items"]
                        daten = daten[0]
                        if debug:
                        for n in range(len(topic1)):
                            if debug:
                                print(topic1[n] + ":", daten[topic1[n]])
                            mqtt_send(client, "Items/" + topic1[n], daten[topic1[n]])
                        mqtt_send(client, "Items/DataReceived", True)
                        daten3 = daten['RemainsUntilCombined']
                        if debug:
                            print('RemainsUntilCombined:')
                        for n in range(len(RemainsUntilCombined)):
                            if debug:
                                print(RemainsUntilCombined[n] + ":", daten3[RemainsUntilCombined[n]])
                            mqtt_send(client, "RemainsUntilCombined/" + RemainsUntilCombined[n], daten3[RemainsUntilCombined[n]])
                        client.disconnect()
                    if __name__ == '__main__':
                        main()
                    • spicer
                      Ich wäre übrigens sehr empfänglich für Hilfe beim Erstellen eines ioBroker Adapters.
                      Die Links
                      https://iobroker.readthedocs.io/de/latest/development/adapter.html
                      und
                      https://www.codeconvert.ai/python-to-javascript-converter
                      hab ich zwar, aber ohne Hilfe ist das doch etwas schwierig.
                      Ich weiss nichtmal, wie ich meinem Code beibringe, Input- und Output vom/zum ioBroker zu senden/empfangen.
                      Mit anderen Worten: Die Schnittstelle.
                      Bin für jeden Rat dankbar.
                      Totaler Anfänger im programmieren bin ich nicht.
                      Jedoch Java = 0 Ahnung. Python sieht's anders aus (hoffentlich oben im Py-Script ersichtlich).
                      Bin halt ein Basic & Assembler Kind aus den C64 bzw Atari Jahren ^^
                      • mcm1957
                        mcm1957 @spicer last edited by
                        @spicer
                        Hier (aus Zeitgründen) nur eine ganz kurze Info:
                        -) Am besten schaust du dir einen (eher einfachen) Adapter auf github mal an und versuchst zu verstehen was da steht.
                        -) Ein Grundverständnis für javascript (das ist NICHT Java) ist hilfreich. Aber wenn du eine andere Sprache kannst, sollte das nicht das Problem sein.
                        -) Für Testzwecke erstellst du am besten einen neuen Adapter mittels adapter creator.
                        -) Testen tust du am besten mittels dev-server.
                        Ich würde dir empfehlen dich in der telgramm Gruppe adapter-developer-starters anzumelden. Invite Links windest du auf www.iobroker.dev. Dort gibts sicher wen der dir mal ein wenig beim Start helfen kann und wird.
                        P.S: Uns ja, die dokumentation ist (m.E.) eine der größten Baustellen / Schwachstellen von ioB. Wenns es da leite gibt die sowas gener schreiben sind sie sicher gern gesehen. (Viele Code-Entwickler schreiben ungern Dokumentaionen ...)
                        • xadox
                          xadox last edited by xadox
                          Das Script ließt den MEX direkt aus und der Adapter geht über den Heizöl24 Account?
                          Bitte ignorieren wer lesen kann ist im Vorteil 😳
                          • spicer
                            spicer @xadox last edited by spicer
                            @xadox
                            Für den ioBroker hab ich ja einen Adapter erstellt ( https://github.com/ltspicer/ioBroker.heizoel24-mex ) 😉
                            Und hier ist die aktuelle Version vom Script: https://github.com/ltspicer/heizoel24.mex
                            adapter heizöltank oilfox
                            12
                            37
                            6738
